[Mapbender-commits] r7483 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Jan 28 05:41:27 EST 2011
Author: kmq
Date: 2011-01-28 02:41:27 -0800 (Fri, 28 Jan 2011)
New Revision: 7483
Added:
trunk/mapbender/http/plugins/mb_print.php
Removed:
trunk/mapbender/http/plugins/mb_print.js
renamed mb_print.js to mb_.php, undoing a previous rename that left two files instead of just one
Deleted: trunk/mapbender/http/plugins/mb_print.js
--- trunk/mapbender/http/plugins/mb_print.js 2011-01-28 10:29:54 UTC (rev 7482)
+++ trunk/mapbender/http/plugins/mb_print.js 2011-01-28 10:41:27 UTC (rev 7483)
@@ -1,567 +0,0 @@
- * Package: printPDF
- * Description:
- * Mapbender print PDF with PDF templates module.
- * Files:
- * - http/plugins/mb_print.php
- * - http/print/classes
- * - http/print/printFactory.php
- * - http/print/printPDF_download.php
- * - lib/printbox.js
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','printPDF',
- * > 2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
- * > '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
- * > 'div','../plugins/mb_print.php',
- * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
- * > 'mapframe1','','http://www.mapbender.org/index.php/Print');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES('<appId>', 'printPDF',
- * > 'mbPrintConfig', '{"Standard": "mapbender_template.json"}', '' ,'var');
- * > var_value, context, var_type) VALUES('<appId>', 'body',
- * > 'print_css', '../css/print_div.css', '' ,'file/css');
- * Help:
- * http://www.mapbender.org/PrintPDF_with_template
- * Maintainer:
- * http://www.mapbender.org/User:Michael_Schulz
- * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * mbPrintConfig - *[optional]* object with name and filename of template,
- * like {
- * "Standard": "a_template.json",
- * "Different": "another_template.json"
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var myTarget = options.target ? options.target[0] : "mapframe1";
-var myId = options ? options.id : "printPDF";
-var mbPrintConfig = options.mbPrintConfig;
-/* the array of json print config files */
-if (typeof mbPrintConfig === "object") {
- mbPrintConfigFilenames = [];
- mbPrintConfigTitles = [];
- for (var i in mbPrintConfig) {
- mbPrintConfigFilenames.push(mbPrintConfig[i]);
- mbPrintConfigTitles.push(i);
-if (typeof mbPrintConfigFilenames === "undefined") {
- mbPrintConfigFilenames = ["mapbender_template.json"];
-if (typeof mbPrintConfigTitles === "undefined") {
- mbPrintConfigTitles = ["Default"];
-var mbPrintConfigPath = "../print/";
-/* ------------- printbox addition ------------- */
-var PrintPDF = function (options) {
- var that = this;
- * Property: actualConfig
- * object, holds the actual configuration after loading the json file
- var actualConfig;
- * constructor
- eventInit.register(function () {
- mod_printPDF_init();
- * Property: printBox
- * the movable printframe
- var printBox = null;
- eventAfterMapRequest.register(function () {
- if (printBox !== null) {
- printBox.repaint();
- * Method: createPrintBox
- * creates a printBox in the current view, calculates the scale
- * (tbd. if not set from the config) so that the printbox fits in the mapframe.
- * Width and height are taken from the configuration.
- this.createPrintBox = function () {
- size = "A4";
- //document.form1.size.value = size;
- format = "portrait";
- var w, h;
- //validate();
- var map = getMapObjByName(myTarget);
- var map_el = map.getDomElement();
- var jqForm = $("#"+myId+"_form");
- var $scaleInput = $("#scale");
- printBox.destroy();
- printBox = null;
- jqForm[0].scale.value = "";
- jqForm[0].coordinates.value = "";
- jqForm[0].angle.value = "";
- else {
- printBox = new Mapbender.PrintBox({
- target : myTarget,
- printWidth : getPDFMapSize("width")/10,
- printHeight : getPDFMapSize("height")/10,
- scale : $scaleInput.size() > 0 && !isNaN(parseInt($scaleInput.val(), 10)) ?
- parseInt($scaleInput.val(), 10) :
- Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
- afterChangeAngle : function (obj) {
- if (typeof(obj) == "object") {
- if (typeof(obj.angle) == "number") {
- jqForm[0].angle.value = obj.angle;
- if (obj.coordinates) {
- jqForm[0].coordinates.value = String(obj.coordinates);
- afterChangeSize : function (obj) {
- if (obj.scale) {
- jqForm[0].scale.value = parseInt(obj.scale / 10, 10) * 10;
- printBox.paintPoints();
- printBox.paintBox();
- * Method: getPDFMapSize
- * checks the actual config for the size w/h values.
- * Parameters:
- * key - string, the key which value to retrieve (currently width or height)
- var getPDFMapSize = function (key) {
- for (var page in actualConfig.pages) {
- for (var pageElement in actualConfig.pages[page].elements) {
- if (actualConfig.pages[page].elements[pageElement].type == "map") {
- return actualConfig.pages[page].elements[pageElement][key];
- * Method: destroyPrintBox
- * removes an existing printBox.
- var destroyPrintBox = function () {
- if (printBox) {
- * Method: mod_printPDF_init
- * initializes the print modules, generates template chooser and loads first configuration.
- var mod_printPDF_init = function () {
- /* first we'd need to build the configuration selection */
- buildConfigSelector();
- /* second we'd need to read the json configuration */
- that.loadConfig(mbPrintConfigFilenames[0]);
- * Method: loadConfig
- * GETs the config, build corresponding form, remove an existing printBox
- this.loadConfig = function (configFilename, callback) {
- // the dataType to $.get is given explicitely, because there were instances of Mapbender that were returning
- // either json or a string, which trips up $.parseJSON which was being used in the callback
- $.get(mbPrintConfigPath + configFilename, function(json, status){
- actualConfig = json;
- buildForm();
- hookForm();
- if (typeof callback === "function") {
- printBox = null;
- callback();
- },"json");
- destroyPrintBox();
- * Method: hookForm
- * utility method to connect the form plugin to the print form.
- var hookForm = function () {
- var o = {
- url: '../print/printFactory.php',
- type: 'post',
- dataType: 'json',
- beforeSubmit: validate,
- success: showResult
- $("#"+myId+"_form").ajaxForm(o);
- * Change status of the working elements. These should begin with "$myId_working"
- * @param {String} newStatus either "hide or "show"
- var showHideWorking = function (newStatus) {
- if (newStatus=="hide") {
- $("[id^='"+myId+"_working']").hide();
- else {
- $("[id^='"+myId+"_working']").show();
- * update form values helper function
- var updateFormField = function (formData, key, value) {
- for(var j=0; j < formData.length; j++){
- if (formData[j].name == key) {
- formData[j].value = value;
- break;
- var getCurrentResolution = function (type) {
- // default resolution is 72 dpi
- var dpi = 72;
- // set resolution according to map configuration in template
- for (var i in actualConfig.pages) {
- var page = actualConfig.pages[i];
- for (var j in page.elements) {
- var el = page.elements[j];
- if (type === el.type && typeof el.res_dpi === "number") {
- dpi = el.res_dpi;
- // set resolution according to resolution select box (if present)
- // check if hq print is requested
- var resolutionControl = null;
- for (var i in actualConfig.controls) {
- var c = actualConfig.controls[i];
- try {
- for (var j in c.pageElementsLink) {
- if (c.pageElementsLink[j] === "res_dpi") {
- resolutionControl = typeof c.id === "string" &&
- c.id.length > 0 ? $("#" + c.id) : null;
- catch (e) {
- if (resolutionControl !== null && resolutionControl.size() === 1) {
- dpi = resolutionControl.val();
- return parseInt(dpi, 10);
- var replaceMapFileForHighQualityPrint = function (currentMapUrl, type) {
- var dpi = getCurrentResolution(type);
- // replace map file with hq map file (if configured)
- var hqmapfiles = $.isArray(options.highqualitymapfiles) ?
- options.highqualitymapfiles : [];
- for (var i = 0; i < hqmapfiles.length; i++) {
- var exp = new RegExp(hqmapfiles[i].pattern);
- if (hqmapfiles[i].pattern && typeof currentMapUrl === "string" && currentMapUrl.match(exp)) {
- // check if mapping in current resolution exists
- var resolutions = hqmapfiles[i].replacement;
- var resolutionExists = false;
- for (var r in resolutions) {
- if (parseInt(r, 10) === dpi) {
- resolutionExists = true;
- if (resolutionExists) {
- // replace with hqmapfile
- var hqmapfile = resolutions[dpi];
- currentMapUrl = currentMapUrl.replace(exp, hqmapfile);
- return currentMapUrl;
- * Validates and updates form data values.
- * Adds the elements before the submit button.
- * @see jquery.forms#beforeSubmitHandler
- var validate = function (formData, jqForm, params) {
- showHideWorking("show");
- // map urls
- var ind = getMapObjIndexByName(myTarget);
- var f = jqForm[0];
- f.map_url.value = '';
- var scale = f.scale.value || mb_mapObj[ind].getScale();
- scale = parseInt(scale, 10);
- var legendUrlArray = [];
- f.overview_url.value = '';
- for(var i=0; i < mb_mapObj[ind].wms.length; i++){
- var currentWms = mb_mapObj[ind].wms[i];
- if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if (mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
- if(f.map_url.value != ""){
- f.map_url.value += '___';
- var currentMapUrl = mb_mapObj[ind].getMapUrl(i, mb_mapObj[ind].getExtentInfos(), scale);
- currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl, "map");
- f.map_url.value += currentMapUrl
- var wmsLegendObj = [];
- var layers = currentWms.getLayers(mb_mapObj[ind], scale);
- for (var j = 0; j < layers.length; j++) {
- var currentLayer = currentWms.getLayerByLayerName(layers[j]);
- // TODO: add only visible layers
- var isVisible = (currentLayer.gui_layer_visible === 1);
- var hasNoChildren = (!currentLayer.has_childs);
- if (isVisible && hasNoChildren){
- var layerLegendObj = {};
- layerLegendObj.name = currentLayer.layer_name;
- layerLegendObj.title = currentWms.getTitleByLayerName(currentLayer.layer_name);
- var layerStyle = currentWms.getCurrentStyleByLayerName(currentLayer.layer_name);
- if (layerStyle === false) {
- layerStyle = "default";
- layerLegendObj.legendUrl = currentWms.getLegendUrlByGuiLayerStyle(currentLayer.layer_name, layerStyle);
- if (layerLegendObj.legendUrl !== false) {
- wmsLegendObj.push(layerLegendObj);
- if (wmsLegendObj.length > 0) {
- var tmpObj = {};
- tmpObj[currentWms.wms_currentTitle] = wmsLegendObj;
- legendUrlArray.push(tmpObj);
- updateFormField(formData, "legend_url", $.toJSON(legendUrlArray));
- updateFormField(formData, "map_url", f.map_url.value);
- updateFormField(formData, "scale", scale);
- //overview_url
- var ind_overview = getMapObjIndexByName('overview');
- if(mb_mapObj[ind_overview].mapURL != false ){
- var overviewUrl = mb_mapObj[ind_overview].mapURL;
- overviewUrl = $.isArray(overviewUrl) ? overviewUrl[0] : overviewUrl;
- f.overview_url.value = replaceMapFileForHighQualityPrint(overviewUrl, "overview");
- updateFormField(formData, "overview_url", f.overview_url.value);
- updateFormField(formData, "map_scale", mb_getScale(myTarget));
- // write the measured coordinates
- if (typeof(mod_measure_RX) !== "undefined") {
- var tmp_x = '';
- var tmp_y = '';
- for(i = 0; i < mod_measure_RX.length; i++) {
- if(tmp_x != '') {
- tmp_x += ',';
- tmp_x += mod_measure_RX[i];
- for(i = 0; i < mod_measure_RY.length; i++) {
- if(tmp_y != '') {
- tmp_y += ',';
- tmp_y += mod_measure_RY[i];
- updateFormField(formData, "measured_x_values", tmp_x);
- updateFormField(formData, "measured_y_values", tmp_y);
- if (f.map_url.value!="") {
- //return true;
- } else {
- showHideWorking("hide");
- return false;
- * Method: showResult
- * load the generated PDF from the returned URL as an attachment,
- * that triggers a download popup or is displayed in PDF plugin.
- var showResult = function (res, text) {
- if (text == 'success') {
- var $downloadFrame = $("#" + myId + "_frame");
- if ($downloadFrame.size() === 0) {
- $downloadFrame = $(
- "<iframe id='" + myId + "_frame' name='" +
- myId + "_frame' width='0' height='0' style='display:none'></iframe>"
- ).appendTo("body");
- if ($.browser.msie && $.browser.version === "6.0") {
- var newWin = window.open(stripslashes(res.outputFileName), "Druckausgabe", "width=200,height=200,left=700,top=200,resizable=yes");
- else {
- window.frames[myId + "_frame"].location.href =
- stripslashes(res.outputFileName);
- else {
- /* something went wrong */
- $("#"+myId+"_result").html(text);
- * Generates form elements as specified in the config controls object.
- * @param {Object} json the config object in json
- var buildForm = function () {
- $(".print_option_dyn").remove();
- var str = "";
- for (var item in actualConfig.controls) {
- var element = actualConfig.controls[item];
- var element_id = myId + "_" + element.id;
- if (element.type != "hidden") {
- str += '<div class="print_option_dyn">\n';
- str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
- } else {
- str += '<div class="print_option_dyn" style="display:none;">\n';
- switch (element.type) {
- case "text":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
- break;
- case "hidden":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
- break;
- case "textarea":
- str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
- break;
- case "select":
- str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
- for (var option_index in element.options) {
- option = element.options[option_index];
- str += '<option value="'+option.value+'">'+option.label+'</option>\n';
- str += '</select><br>\n';
- break;
- str += '</div>\n';
- if (str) {
- $("#" + myId + "_formsubmit").before(str);
- $("#scale").keydown(function (e) {
- if (e.keyCode !== 13) {
- return;
- var scale = parseInt(this.value, 10);
- if (isNaN(scale) || typeof printBox === "undefined") {
- return false;
- printBox.setScale(scale);
- return false;
- * Generates the configuration select element from the gui element vars
- * mbPrintConfigFilenames and mbPrintConfigTitles
- var buildConfigSelector = function () {
- var str = "";
- str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
- str += '<select id="printPDF_template" name="printPDF_template" size="1">\n';
- for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
- str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
- str += '</select><img id="printPDF_handle" src="../print/img/shape_handles.png" title="Use printbox">\n';
- if (str) {
- $("#printPDF_selector").append(str).find("#printPDF_template").change(function () {
- printObj.loadConfig(mbPrintConfigFilenames[this.selectedIndex], function () {
- printObj.createPrintBox()
- $("#printPDF_handle").click(function () {
- printObj.createPrintBox();
- $("#printPDF_working").bgiframe({
- src: "BLOCKED SCRIPT'<html></html>';",
- width: 200,
- height: 200
- var stripslashes = function ( str ) {
- return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
-var printObj = new PrintPDF(options);
Deleted: trunk/mapbender/http/plugins/mb_print.php
--- trunk/mapbender/http/plugins/mb_print.php 2011-01-28 10:29:54 UTC (rev 7482)
+++ trunk/mapbender/http/plugins/mb_print.php 2011-01-28 10:41:27 UTC (rev 7483)
@@ -1,584 +0,0 @@
- * Description:
- * Files:
- * SQL:
- * Help:
- * Maintainer:
- * Parameters:
- * like {
- * License:
- var that = this;
- var actualConfig;
- * constructor
- size = "A4";
- var w, h;
- //validate();
- printBox = null;
- else {
- if (obj.scale) {
- * Parameters:
- if (printBox) {
- actualConfig = $.parseJSON(json);
- buildForm();
- hookForm();
- printBox = null;
- callback();
- var o = {
- type: 'post',
- dataType: 'json',
- else {
- break;
- var dpi = 72;
- dpi = el.res_dpi;
- try {
- catch (e) {
- // map urls
- var tmpObj = {};
- //overview_url
- var tmp_x = '';
- var tmp_y = '';
- if(tmp_x != '') {
- tmp_x += ',';
- if(tmp_y != '') {
- tmp_y += ',';
- //return true;
- } else {
- return false;
- var newWin = window.open(stripslashes(res.outputFileName), "<?php echo htmlentities(_mb("print document"), ENT_QUOTES, "UTF-8");?>", "width=200,height=200,left=700,top=200,resizable=yes");
- else {
- else {
- var str = "";
- } else {
- case "text":
- break;
- case "hidden":
- break;
- case "textarea":
- break;
- case "select":
- break;
- if (str) {
- if (e.keyCode === 13) {
- return false;
- }).keyup(function (e) {
- return false;
- return true;
- return true;
- $("#angle").keydown(function (e) {
- return false;
- return false;
- var angle = parseInt(this.value, 10);
- if (isNaN(angle) || typeof printBox === "undefined") {
- return true;
- printBox.setAngle(angle);
- return true;
- var str = "";
- str += '</select><img id="printPDF_handle" src="../print/img/shape_handles.png" title="<?php echo htmlentities(_mb("use print box"), ENT_QUOTES, "UTF-8");?>">\n';
- if (str) {
- width: 200,
- height: 200
Copied: trunk/mapbender/http/plugins/mb_print.php (from rev 7482, trunk/mapbender/http/plugins/mb_print.js)
--- trunk/mapbender/http/plugins/mb_print.php (rev 0)
@@ -0,0 +1,587 @@
+ * Package: printPDF
+ * Description:
+ * Mapbender print PDF with PDF templates module.
+ * Files:
+ * - http/plugins/mb_print.php
+ * - http/print/classes
+ * - http/print/printFactory.php
+ * - http/print/printPDF_download.php
+ * - lib/printbox.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','printPDF',
+ * > 2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
+ * > '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
+ * > 'div','../plugins/mb_print.php',
+ * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
+ * > 'mapframe1','','http://www.mapbender.org/index.php/Print');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'printPDF',
+ * > 'mbPrintConfig', '{"Standard": "mapbender_template.json"}', '' ,'var');
+ * > var_value, context, var_type) VALUES('<appId>', 'body',
+ * > 'print_css', '../css/print_div.css', '' ,'file/css');
+ * Help:
+ * http://www.mapbender.org/PrintPDF_with_template
+ * Maintainer:
+ * http://www.mapbender.org/User:Michael_Schulz
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * mbPrintConfig - *[optional]* object with name and filename of template,
+ * like {
+ * "Standard": "a_template.json",
+ * "Different": "another_template.json"
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var myTarget = options.target ? options.target[0] : "mapframe1";
+var myId = options ? options.id : "printPDF";
+var mbPrintConfig = options.mbPrintConfig;
+/* the array of json print config files */
+if (typeof mbPrintConfig === "object") {
+ mbPrintConfigFilenames = [];
+ mbPrintConfigTitles = [];
+ for (var i in mbPrintConfig) {
+ mbPrintConfigFilenames.push(mbPrintConfig[i]);
+ mbPrintConfigTitles.push(i);
+if (typeof mbPrintConfigFilenames === "undefined") {
+ mbPrintConfigFilenames = ["mapbender_template.json"];
+if (typeof mbPrintConfigTitles === "undefined") {
+ mbPrintConfigTitles = ["Default"];
+var mbPrintConfigPath = "../print/";
+/* ------------- printbox addition ------------- */
+var PrintPDF = function (options) {
+ var that = this;
+ * Property: actualConfig
+ * object, holds the actual configuration after loading the json file
+ var actualConfig;
+ * constructor
+ eventInit.register(function () {
+ mod_printPDF_init();
+ * Property: printBox
+ * the movable printframe
+ var printBox = null;
+ eventAfterMapRequest.register(function () {
+ if (printBox !== null) {
+ printBox.repaint();
+ * Method: createPrintBox
+ * creates a printBox in the current view, calculates the scale
+ * (tbd. if not set from the config) so that the printbox fits in the mapframe.
+ * Width and height are taken from the configuration.
+ this.createPrintBox = function () {
+ size = "A4";
+ //document.form1.size.value = size;
+ format = "portrait";
+ var w, h;
+ //validate();
+ var map = getMapObjByName(myTarget);
+ var map_el = map.getDomElement();
+ var jqForm = $("#"+myId+"_form");
+ var $scaleInput = $("#scale");
+ printBox.destroy();
+ printBox = null;
+ jqForm[0].scale.value = "";
+ jqForm[0].coordinates.value = "";
+ jqForm[0].angle.value = "";
+ else {
+ printBox = new Mapbender.PrintBox({
+ target : myTarget,
+ printWidth : getPDFMapSize("width")/10,
+ printHeight : getPDFMapSize("height")/10,
+ scale : $scaleInput.size() > 0 && !isNaN(parseInt($scaleInput.val(), 10)) ?
+ parseInt($scaleInput.val(), 10) :
+ Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
+ afterChangeAngle : function (obj) {
+ if (typeof(obj) == "object") {
+ if (typeof(obj.angle) == "number") {
+ jqForm[0].angle.value = obj.angle;
+ if (obj.coordinates) {
+ jqForm[0].coordinates.value = String(obj.coordinates);
+ afterChangeSize : function (obj) {
+ if (obj.scale) {
+ jqForm[0].scale.value = parseInt(obj.scale / 10, 10) * 10;
+ printBox.paintPoints();
+ printBox.paintBox();
+ * Method: getPDFMapSize
+ * checks the actual config for the size w/h values.
+ * Parameters:
+ * key - string, the key which value to retrieve (currently width or height)
+ var getPDFMapSize = function (key) {
+ for (var page in actualConfig.pages) {
+ for (var pageElement in actualConfig.pages[page].elements) {
+ if (actualConfig.pages[page].elements[pageElement].type == "map") {
+ return actualConfig.pages[page].elements[pageElement][key];
+ * Method: destroyPrintBox
+ * removes an existing printBox.
+ var destroyPrintBox = function () {
+ if (printBox) {
+ * Method: mod_printPDF_init
+ * initializes the print modules, generates template chooser and loads first configuration.
+ var mod_printPDF_init = function () {
+ /* first we'd need to build the configuration selection */
+ buildConfigSelector();
+ /* second we'd need to read the json configuration */
+ that.loadConfig(mbPrintConfigFilenames[0]);
+ * Method: loadConfig
+ * GETs the config, build corresponding form, remove an existing printBox
+ this.loadConfig = function (configFilename, callback) {
+ // the dataType to $.get is given explicitely, because there were instances of Mapbender that were returning
+ // either json or a string, which trips up $.parseJSON which was being used in the callback
+ $.get(mbPrintConfigPath + configFilename, function(json, status){
+ actualConfig = json;
+ buildForm();
+ hookForm();
+ if (typeof callback === "function") {
+ printBox = null;
+ callback();
+ },"json");
+ destroyPrintBox();
+ * Method: hookForm
+ * utility method to connect the form plugin to the print form.
+ var hookForm = function () {
+ var o = {
+ url: '../print/printFactory.php',
+ type: 'post',
+ dataType: 'json',
+ beforeSubmit: validate,
+ success: showResult
+ $("#"+myId+"_form").ajaxForm(o);
+ * Change status of the working elements. These should begin with "$myId_working"
+ * @param {String} newStatus either "hide or "show"
+ var showHideWorking = function (newStatus) {
+ if (newStatus=="hide") {
+ $("[id^='"+myId+"_working']").hide();
+ else {
+ $("[id^='"+myId+"_working']").show();
+ * update form values helper function
+ var updateFormField = function (formData, key, value) {
+ for(var j=0; j < formData.length; j++){
+ if (formData[j].name == key) {
+ formData[j].value = value;
+ break;
+ var getCurrentResolution = function (type) {
+ // default resolution is 72 dpi
+ var dpi = 72;
+ // set resolution according to map configuration in template
+ for (var i in actualConfig.pages) {
+ var page = actualConfig.pages[i];
+ for (var j in page.elements) {
+ var el = page.elements[j];
+ if (type === el.type && typeof el.res_dpi === "number") {
+ dpi = el.res_dpi;
+ // set resolution according to resolution select box (if present)
+ // check if hq print is requested
+ var resolutionControl = null;
+ for (var i in actualConfig.controls) {
+ var c = actualConfig.controls[i];
+ try {
+ for (var j in c.pageElementsLink) {
+ if (c.pageElementsLink[j] === "res_dpi") {
+ resolutionControl = typeof c.id === "string" &&
+ c.id.length > 0 ? $("#" + c.id) : null;
+ catch (e) {
+ if (resolutionControl !== null && resolutionControl.size() === 1) {
+ dpi = resolutionControl.val();
+ return parseInt(dpi, 10);
+ var replaceMapFileForHighQualityPrint = function (currentMapUrl, type) {
+ var dpi = getCurrentResolution(type);
+ // replace map file with hq map file (if configured)
+ var hqmapfiles = $.isArray(options.highqualitymapfiles) ?
+ options.highqualitymapfiles : [];
+ for (var i = 0; i < hqmapfiles.length; i++) {
+ var exp = new RegExp(hqmapfiles[i].pattern);
+ if (hqmapfiles[i].pattern && typeof currentMapUrl === "string" && currentMapUrl.match(exp)) {
+ // check if mapping in current resolution exists
+ var resolutions = hqmapfiles[i].replacement;
+ var resolutionExists = false;
+ for (var r in resolutions) {
+ if (parseInt(r, 10) === dpi) {
+ resolutionExists = true;
+ if (resolutionExists) {
+ // replace with hqmapfile
+ var hqmapfile = resolutions[dpi];
+ currentMapUrl = currentMapUrl.replace(exp, hqmapfile);
+ return currentMapUrl;
+ * Validates and updates form data values.
+ * Adds the elements before the submit button.
+ * @see jquery.forms#beforeSubmitHandler
+ var validate = function (formData, jqForm, params) {
+ showHideWorking("show");
+ // map urls
+ var ind = getMapObjIndexByName(myTarget);
+ var f = jqForm[0];
+ f.map_url.value = '';
+ var scale = f.scale.value || mb_mapObj[ind].getScale();
+ scale = parseInt(scale, 10);
+ var legendUrlArray = [];
+ f.overview_url.value = '';
+ for(var i=0; i < mb_mapObj[ind].wms.length; i++){
+ var currentWms = mb_mapObj[ind].wms[i];
+ if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if (mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
+ if(f.map_url.value != ""){
+ f.map_url.value += '___';
+ var currentMapUrl = mb_mapObj[ind].getMapUrl(i, mb_mapObj[ind].getExtentInfos(), scale);
+ currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl, "map");
+ f.map_url.value += currentMapUrl
+ var wmsLegendObj = [];
+ var layers = currentWms.getLayers(mb_mapObj[ind], scale);
+ for (var j = 0; j < layers.length; j++) {
+ var currentLayer = currentWms.getLayerByLayerName(layers[j]);
+ // TODO: add only visible layers
+ var isVisible = (currentLayer.gui_layer_visible === 1);
+ var hasNoChildren = (!currentLayer.has_childs);
+ if (isVisible && hasNoChildren){
+ var layerLegendObj = {};
+ layerLegendObj.name = currentLayer.layer_name;
+ layerLegendObj.title = currentWms.getTitleByLayerName(currentLayer.layer_name);
+ var layerStyle = currentWms.getCurrentStyleByLayerName(currentLayer.layer_name);
+ if (layerStyle === false) {
+ layerStyle = "default";
+ layerLegendObj.legendUrl = currentWms.getLegendUrlByGuiLayerStyle(currentLayer.layer_name, layerStyle);
+ if (layerLegendObj.legendUrl !== false) {
+ wmsLegendObj.push(layerLegendObj);
+ if (wmsLegendObj.length > 0) {
+ var tmpObj = {};
+ tmpObj[currentWms.wms_currentTitle] = wmsLegendObj;
+ legendUrlArray.push(tmpObj);
+ updateFormField(formData, "legend_url", $.toJSON(legendUrlArray));
+ updateFormField(formData, "map_url", f.map_url.value);
+ updateFormField(formData, "scale", scale);
+ //overview_url
+ var ind_overview = getMapObjIndexByName('overview');
+ if(mb_mapObj[ind_overview].mapURL != false ){
+ var overviewUrl = mb_mapObj[ind_overview].mapURL;
+ overviewUrl = $.isArray(overviewUrl) ? overviewUrl[0] : overviewUrl;
+ f.overview_url.value = replaceMapFileForHighQualityPrint(overviewUrl, "overview");
+ updateFormField(formData, "overview_url", f.overview_url.value);
+ updateFormField(formData, "map_scale", mb_getScale(myTarget));
+ // write the measured coordinates
+ if (typeof(mod_measure_RX) !== "undefined") {
+ var tmp_x = '';
+ var tmp_y = '';
+ for(i = 0; i < mod_measure_RX.length; i++) {
+ if(tmp_x != '') {
+ tmp_x += ',';
+ tmp_x += mod_measure_RX[i];
+ for(i = 0; i < mod_measure_RY.length; i++) {
+ if(tmp_y != '') {
+ tmp_y += ',';
+ tmp_y += mod_measure_RY[i];
+ updateFormField(formData, "measured_x_values", tmp_x);
+ updateFormField(formData, "measured_y_values", tmp_y);
+ if (f.map_url.value!="") {
+ //return true;
+ } else {
+ showHideWorking("hide");
+ return false;
+ * Method: showResult
+ * load the generated PDF from the returned URL as an attachment,
+ * that triggers a download popup or is displayed in PDF plugin.
+ var showResult = function (res, text) {
+ if (text == 'success') {
+ var $downloadFrame = $("#" + myId + "_frame");
+ if ($downloadFrame.size() === 0) {
+ $downloadFrame = $(
+ "<iframe id='" + myId + "_frame' name='" +
+ myId + "_frame' width='0' height='0' style='display:none'></iframe>"
+ ).appendTo("body");
+ if ($.browser.msie && $.browser.version === "6.0") {
+ var newWin = window.open(stripslashes(res.outputFileName), "<?php echo htmlentities(_mb("print document"), ENT_QUOTES, "UTF-8");?>", "width=200,height=200,left=700,top=200,resizable=yes");
+ else {
+ window.frames[myId + "_frame"].location.href =
+ stripslashes(res.outputFileName);
+ else {
+ /* something went wrong */
+ $("#"+myId+"_result").html(text);
+ * Generates form elements as specified in the config controls object.
+ * @param {Object} json the config object in json
+ var buildForm = function () {
+ $(".print_option_dyn").remove();
+ var str = "";
+ for (var item in actualConfig.controls) {
+ var element = actualConfig.controls[item];
+ var element_id = myId + "_" + element.id;
+ if (element.type != "hidden") {
+ str += '<div class="print_option_dyn">\n';
+ str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
+ } else {
+ str += '<div class="print_option_dyn" style="display:none;">\n';
+ switch (element.type) {
+ case "text":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
+ break;
+ case "hidden":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
+ break;
+ case "textarea":
+ str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
+ break;
+ case "select":
+ str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
+ for (var option_index in element.options) {
+ option = element.options[option_index];
+ str += '<option value="'+option.value+'">'+option.label+'</option>\n';
+ str += '</select><br>\n';
+ break;
+ str += '</div>\n';
+ if (str) {
+ $("#" + myId + "_formsubmit").before(str);
+ $("#scale").keydown(function (e) {
+ if (e.keyCode === 13) {
+ return false;
+ }).keyup(function (e) {
+ return false;
+ var scale = parseInt(this.value, 10);
+ if (isNaN(scale) || typeof printBox === "undefined") {
+ return true;
+ printBox.setScale(scale);
+ return true;
+ $("#angle").keydown(function (e) {
+ return false;
+ return false;
+ var angle = parseInt(this.value, 10);
+ if (isNaN(angle) || typeof printBox === "undefined") {
+ return true;
+ printBox.setAngle(angle);
+ return true;
+ * Generates the configuration select element from the gui element vars
+ * mbPrintConfigFilenames and mbPrintConfigTitles
+ var buildConfigSelector = function () {
+ var str = "";
+ str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
+ str += '<select id="printPDF_template" name="printPDF_template" size="1">\n';
+ for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
+ str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
+ str += '</select><img id="printPDF_handle" src="../print/img/shape_handles.png" title="<?php echo htmlentities(_mb("use print box"), ENT_QUOTES, "UTF-8");?>">\n';
+ if (str) {
+ $("#printPDF_selector").append(str).find("#printPDF_template").change(function () {
+ printObj.loadConfig(mbPrintConfigFilenames[this.selectedIndex], function () {
+ printObj.createPrintBox()
+ $("#printPDF_handle").click(function () {
+ printObj.createPrintBox();
+ $("#printPDF_working").bgiframe({
+ src: "BLOCKED SCRIPT'<html></html>';",
+ width: 200,
+ height: 200
+ var stripslashes = function ( str ) {
+ return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
+var printObj = new PrintPDF(options);
More information about the Mapbender_commits
