[Mapbender-commits] r7482 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Jan 28 05:29:54 EST 2011
Author: kmq
Date: 2011-01-28 02:29:54 -0800 (Fri, 28 Jan 2011)
New Revision: 7482
trunk/mapbender/http/plugins/mb_print.js
fix contentTupe ambiguity problem in print
Modified: trunk/mapbender/http/plugins/mb_print.js
--- trunk/mapbender/http/plugins/mb_print.js 2011-01-28 08:39:46 UTC (rev 7481)
+++ trunk/mapbender/http/plugins/mb_print.js 2011-01-28 10:29:54 UTC (rev 7482)
@@ -217,15 +217,17 @@
* GETs the config, build corresponding form, remove an existing printBox
this.loadConfig = function (configFilename, callback) {
+ // the dataType to $.get is given explicitely, because there were instances of Mapbender that were returning
+ // either json or a string, which trips up $.parseJSON which was being used in the callback
$.get(mbPrintConfigPath + configFilename, function(json, status){
- actualConfig = $.parseJSON(json);
+ actualConfig = json;
buildForm();
hookForm();
if (typeof callback === "function") {
printBox = null;
callback();
+ },"json");
destroyPrintBox();
More information about the Mapbender_commits
