[Mapbender-commits] r8021 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Thu Jul 28 10:02:25 EDT 2011
Author: astrid_emde
Date: 2011-07-28 07:02:25 -0700 (Thu, 28 Jul 2011)
New Revision: 8021
trunk/mapbender/resources/db/install.sh
merged with 2.7
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2011-07-28 14:00:46 UTC (rev 8020)
+++ trunk/mapbender/resources/db/install.sh 2011-07-28 14:02:25 UTC (rev 8021)
@@ -187,6 +187,7 @@
then
echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
read setowner
+ : ${setowner:="n"}
if test $setowner != "n"
then
echo "Please specify the webserver user (on Debian Linux typically www-data)"
@@ -227,6 +228,7 @@
then
echo "Continue? (y)es or (n)o"
read disclaimer
+ : ${disclaimer:="n"}
if test $disclaimer != "y"
then
exit 1
@@ -237,6 +239,7 @@
show_db_config;
echo "Look ok? Start Install? (y)es or (n)o"
read ANSWER
+ : ${ANSWER:="n"}
if test $ANSWER != "y"
then
exec $0
More information about the Mapbender_commits
