[Mapbender-commits] r8022 - trunk/mapbender
svn_mapbender at osgeo.org
Thu Jul 28 10:03:02 EDT 2011
Author: astrid_emde
Date: 2011-07-28 07:03:02 -0700 (Thu, 28 Jul 2011)
New Revision: 8022
trunk/mapbender/Changes.txt
trunk/mapbender/Install.txt
version 2.7.2
Modified: trunk/mapbender/Changes.txt
--- trunk/mapbender/Changes.txt 2011-07-28 14:02:25 UTC (rev 8021)
+++ trunk/mapbender/Changes.txt 2011-07-28 14:03:02 UTC (rev 8022)
@@ -4,6 +4,107 @@
The mapbender trac provides different reports. The reports give detailed information about the enhancements
+Changelog 2.7.2
+http://trac.osgeo.org/mapbender/query?status=closed&group=resolution&milestone=2.7.2+release
+790 Mapbender StartUpParams are not handled
+840 IE: WFS featureType configuration - popup helptext ok button not displayed size incorrect
+765 jquery ui dialog (jumps)
+786 savewms and loadwmc in my updated guis
+807 mod_usemap divs um_img and um_draw are missing
+816 Digitize: Wrong mouse position in scrolled page in IE
+817 New Constant in mapbender.conf
+818 Digitize: Does not work properly in scrolled IE page
+819 WMC Update to 2.7
+821 Mod_digitize_splitline don't intersect closed lines.
+827 Dynamic print frame: provide possibility to cancel a running print
+828 Dynamic print frame: delete temporary files after pdf creation
+829 Dynamic print frame: log WMS request in mb_log table in Mapbender db
+830 Dynamic print frame: avoid reload with ie
+831 Dynamic print frame: scale modification
+834 administration - remove application from category does not work
+836 admin2_de fails to load with IE8
+838 wrong entry new at the top of the treeGDE
+839 login.php application overview - change switch on mouseover to click
+841 IE: WFS featureType configuration - attribute columns - wrong number of header columns and columns
+846 layer with sld settings not displayed...
+852 scaleSelect has to refer to ../plugins/mb_selectScale.js and does not need e_attributes
+853 update script overwrites the user defined EPSG options
+854 open Legend with a button in a dialog
+858 integration of new applications PortalAdmin and PortalAdmin_DE
+859 french translation update in table translation for textes with '
+796 mismatching i18-Strings de
+808 mb_background doesn't work in 2.7
+812 Wrong Value in SQL-Update-Script
+813 Clean 'layer_load_count'
+814 URL of OL-Link to WMC
+815 Title of OL-Link from WMC
+844 guis looses Category when renamed
+848 2.7.x: Count of failure-login by users is not counted
+851 initial icon for Layer-Group wrong
+823 Show Icons in real Size
+833 Picture for showCoords not transparent (blue_red)
+782 table mb_meetingpoint does not exist
+842 add createCategory to Administzration and Administration_DE
+811 spatial search and digitize conflict
+850 FeatureInfo Dialog jumping arround
+527 HTTP authentication for OWS Proxy
+837 function getAvailableWfsForGeom(geom wfsConf) does not check for gml:MultiPolygonPropertyType and other element_types gml:* (with GeoServer 2.1.0)
+Changelog 2.7.1
+http://trac.osgeo.org/mapbender/query?status=closed&group=resolution&milestone=2.7.1+release
+778 WFS administration
+791 copy application - gui_lyer_title are not copied to new application
+799 gui_digitize update of a geometry does not work
+801 setbackground - background wms is not displayed
+806 load wfs doesn't load describeFeatureType information
+506 Use WMS monitor from www.geoportal.rlp.de
+661 Northarrow Print Overview
+715 Cutting two lines does not work as expected when
+720 login.php creates a session even if the user is not logged in
+734 temporary load GeoRSS and KML
+743 reloadTree triggers a single map request for every layer
+746 Layertree for GeoRSS and KML files GeoRSS
+747 WFS conf Layertree for selection
+749 setbackground - mb_background
+773 senseful description for new metadata applications
+774 admin_wmc_metadata does not load when no wmc is in the database
+776 slippy map (Browser overflow)
+777 change application description does not work
+784 WMS Metadata fails to start - authentication issue?
+787 Monitoring runs on database errors
+788 some scripts refer to x_geoportal instead of geoportal
+789 create and edit user - filter for users does not filter correctly
+792 featureInfoResults in dialog windows are displayed at the same position
+793 Can't insert Basepoint
+794 Digitize/update feature shows all configured Featuretypes
+800 resizeMapsize does not work on start
+802 slider in template_print is not displayed correctly
+699 wms status in treGDE
+739 Installation from script
+756 enhanced Metadatainformations for service and layer - check Abo alert a notice
+780 slippy map in Internet Explorer ...
+781 MousewheelZoom and selArea
+795 undefined targets of toogelModule after upgrade
+775 translation mistake in AdWMSFromFilteredListAjax
+503 Digitize module pop-ups
+810 WFS update has problem with updating featuretypes
+316 Mapbender treeGDE Observations
+451 select tool problem
+454 polish translation for Mapbender
+459 Administration Interface - TranslationBuilder
+485 Update Governance pages
+476 scale parameter for getlegendgraphic dropped by owsproxy
+785 setBBOX doesn't work
+500 Bug in WFS-Update
+779 Digitizing
+803 Administration_DE and Administration: Delete WFS Conf module does not load
Changelog 2.7
http://trac.osgeo.org/mapbender/report/48
20 addWMS beim Login
Modified: trunk/mapbender/Install.txt
--- trunk/mapbender/Install.txt 2011-07-28 14:02:25 UTC (rev 8021)
+++ trunk/mapbender/Install.txt 2011-07-28 14:03:02 UTC (rev 8022)
@@ -20,6 +20,7 @@
** php-gd2
** php5-imagick
** php-gettext
+** php5-curl (if you want to use cURL - have a look in mapbender.conf)
The following instructions only describe the configuration process for these packages, please follow the installation instructions for your operating system individually as the paths to files will vary on your systems.
More information about the Mapbender_commits
