[Mapbender-commits] r7679 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Mar 3 05:50:08 EST 2011
Author: armin11
Date: 2011-03-03 02:50:08 -0800 (Thu, 03 Mar 2011)
New Revision: 7679
trunk/mapbender/http/php/mod_wmc2ol.php
Bugfix: Use only layer as baselayer for ol which is not hidden in the wmc doc. Exchange urls of wms that are stored in the mapbender database - they may have changed!
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php 2011-03-03 10:31:44 UTC (rev 7678)
+++ trunk/mapbender/http/php/mod_wmc2ol.php 2011-03-03 10:50:08 UTC (rev 7679)
@@ -16,7 +16,11 @@
#http://www.geoportal.rlp.de/mapbender/php/mod_wmc2ol.php?wmc_id=45_1291218568&GEORSS=1&LayerSwitcher=1
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_wmc.php");
+//require_once(dirname(__FILE__)."/../classes/class_user.php");
+//require_once(dirname(__FILE__)."/../classes/class_json.php");
+//require_once(dirname(__FILE__)."/../classes/class_administration.php");
+//require_once(dirname(__FILE__)."/../classes/class_wmcToXml.php");
$userId = Mapbender::session()->get("mb_user_id");
//check for parameter wmc_id
@@ -176,21 +180,27 @@
//Function to create an OpenLayers Javascript from a mapbender wmc document
function createOlFromWMC_id($wmc_id, $pointRadius, $fillColor){
+ $myWmc = new wmc();
global $userId;
//Get WMC out of mb Database
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_serial_id = $1";
+ $sql = "SELECT wmc, wmc_serial_id FROM mb_user_wmc WHERE wmc_serial_id = $1";
$res = db_prep_query($sql, array($wmc_id), array("s"));
$wmc = db_fetch_row($res);
//control if wmc was found else use old wmc_id
if (!$wmc[0]) {
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
+ $sql = "SELECT wmc, wmc_serial_id FROM mb_user_wmc WHERE wmc_id = $1";
//echo "Wmc with this id was not found in Database!<br>";
//die;
+ //generate wmc object and update urls of services in this object:
+ $wmcId = $wmc[1];
+ $myWmc->createFromDb($wmcId);
+ $updatedWmc = $myWmc->updateUrlsFromDb();
//Read out WMC into XML object
- $xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
+ $xml=simplexml_load_string($updatedWmc, "SimpleXMLElement", LIBXML_NOBLANKS);
if ($_REQUEST['withoutBody'] == '1') {
} else {
@@ -372,7 +382,15 @@
$html.=" var bounds = new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy.");\n";
//if some layer defined, create base layer -> first layer in the wmc document
if (count($layer_array) != 0){
- $i=0;
+ //get layer id for the base layer - this should be the first layer which is not hidden - in the wmc this should be visible (active)!!
+ //first get this id:
+ for ($i=0; $i<count($layer_array); $i++) {
+ if ($xml->LayerList->Layer[$i]->attributes()->hidden=='0'){
+ $firstLayerId = $i;
+ break;
+ $i = $firstLayerId;
$html.=" layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org');
$layer_id=dom_import_simplexml($extensions->layer_id)->nodeValue;
@@ -380,7 +398,8 @@
$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id
//echo $layer_id."<br>";
if ($has_permission || $layer_id==''){
- $html.=" \"".$xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href."\",\n";
+ $getMapUrl = $xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href;
+ $html.=" \"".$getMapUrl."\",\n";
$html.=" {\n";
$html.=" layers: \"".$xml->LayerList->Layer[$i]->Name."\",\n";
//get FormatList and the current active format -> TODO: make a function for getting actual format for request
@@ -421,7 +440,8 @@
//create the overlay layers for which the user guest has permissions
- for ($i=1; $i<count($layer_array); $i++) {
+ $startLayerId = $firstLayerId+1;
+ for ($i=$startLayerId; $i<count($layer_array); $i++) {
#$layer_id=$extensions->layer_id;
$wms_id=$extensions->wms_id;
More information about the Mapbender_commits
