[Mapbender-commits] r7680 - in trunk/mapbender: . conf
http/extensions http/extensions/FirePHP-0.3 http/javascripts
http/print resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Mar 3 05:58:25 EST 2011
Author: kmq
Date: 2011-03-03 02:58:25 -0800 (Thu, 03 Mar 2011)
New Revision: 7680
trunk/mapbender/
trunk/mapbender/conf/digitize_default.conf
trunk/mapbender/conf/wfs_default.conf
trunk/mapbender/http/extensions/FirePHP-0.3/FirePHP.class.php
trunk/mapbender/http/extensions/FirePHP-0.3/fb.php
trunk/mapbender/http/extensions/jqjson.min.js
trunk/mapbender/http/javascripts/mod_sandclock.js
trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
trunk/mapbender/http/print/mapbender_template.json
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
merged -c7677 from kmq_dev, fix for #793
Property changes on: trunk/mapbender
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/kmq_dev:4021-4487
+ /branches/kmq_dev:4021-4487,7677
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf 2011-03-03 10:50:08 UTC (rev 7679)
+++ trunk/mapbender/conf/digitize_default.conf 2011-03-03 10:58:25 UTC (rev 7680)
@@ -33,7 +33,7 @@
var geomHighlightColour = "#ff0000";
-var snappingHighlightZIndex = 85;
+var snappingHighlightZIndex = 75;
var digitizeTransactionalZIndex = 80;
var digitizeNonTransactionalZIndex = 20;
// see also "generalHighlightZIndex" in wfs_default.conf
Modified: trunk/mapbender/conf/wfs_default.conf
--- trunk/mapbender/conf/wfs_default.conf 2011-03-03 10:50:08 UTC (rev 7679)
+++ trunk/mapbender/conf/wfs_default.conf 2011-03-03 10:58:25 UTC (rev 7680)
@@ -69,7 +69,7 @@
* z-Index of the highlighted geometries
-var generalHighlightZIndex = 80;
+var generalHighlightZIndex = 70;
* Line width of the highlighted geometries in pixel
Property changes on: trunk/mapbender/http/extensions/FirePHP-0.3/FirePHP.class.php
- /branches/kmq_dev/http/extensions/FirePHP.class.php:4021-4487
+ /branches/kmq_dev/http/extensions/FirePHP-0.3/FirePHP.class.php:7677
Property changes on: trunk/mapbender/http/extensions/FirePHP-0.3/fb.php
- /branches/kmq_dev/http/extensions/fb.php:4021-4487
+ /branches/kmq_dev/http/extensions/FirePHP-0.3/fb.php:7677
Property changes on: trunk/mapbender/http/extensions/jqjson.min.js
+ /branches/kmq_dev/http/extensions/jqjson.min.js:7677
Property changes on: trunk/mapbender/http/javascripts/mod_sandclock.js
+ /branches/kmq_dev/http/javascripts/mod_sandclock.js:7677
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2011-03-03 10:50:08 UTC (rev 7679)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2011-03-03 10:58:25 UTC (rev 7680)
@@ -292,7 +292,7 @@
// creates a Highlight object for the request geometry
- var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":80};
+ var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":70};
requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
@@ -1390,4 +1390,4 @@
<div id="uploader"></div>
<div class='resultDiv' name='res' id='res'></div>
</body>
-</html>
\ No newline at end of file
+</html>
Property changes on: trunk/mapbender/http/print/mapbender_template.json
+ /branches/kmq_dev/http/print/mapbender_template.json:7677
Property changes on: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
- /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
+ /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:7677
More information about the Mapbender_commits
