[Mapbender-commits] r8331 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Thu Apr 26 11:37:03 EDT 2012
Author: armin11
Date: 2012-04-26 08:37:03 -0700 (Thu, 26 Apr 2012)
New Revision: 8331
Added:
trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js
trunk/mapbender/http/plugins/mb_metadata_wfs_edit.js
trunk/mapbender/http/plugins/mb_metadata_wfs_submit.js
Initial things to add service - data - metadata coupling to wfs to support inspire download services.
Added: trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js
--- trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js 2012-04-26 15:37:03 UTC (rev 8331)
@@ -0,0 +1,300 @@
+var $showMetadataAddonDiv = $(this);
+var $metadataAddonForm = $("<form></form>").appendTo($showMetadataAddonDiv);
+//var $metadataUploadForm = $("<form></form>").appendTo($showMetadataAddonDiv);
+var $metadataAddonPopup = $("<div></div>");
+var $metadataUploadPopup = $("<div></div>");
+var ShowMetadataAddonApi = function() {
+ var that = this;
+ var featuretypeId;
+ var metadataId;
+ //var wfsId;
+ //Function, which pulls the metadata out off the mapbender registry and give a possibility to edit the record or link
+ this.valid = function () {
+ if (validator && validator.numberOfInvalids() > 0) {
+ $metadataAddonForm.valid();
+ return false;
+ return true;
+ this.getInitialFeaturetypeMetadata = function(metadataId, featuretypeId){
+ // get metadata from server
+ var req = new Mapbender.Ajax.Request({
+ url: "../plugins/mb_metadata_server.php",
+ method: "getInitialFeaturetypeMetadata",
+ parameters: {
+ "featuretypeId": featuretypeId,
+ "metadataId": metadataId
+ callback: function (obj, result, message) {
+ if (!result) {
+ return;
+ $metadataAddonForm.easyform("reset");
+ $metadataAddonForm.easyform("fill", obj);
+ //that.showForm(metadataId, featuretypeId);
+ //enable link element to edit link!
+ $("#link").removeAttr("disabled");
+ switch (obj.origin) {
+ case "external":
+ $("#metadataUrlEditor").css("display","block");
+ $("#link_editor").css("display","block");
+ break;
+ case "metador":
+ $("#simple_metadata_editor").css("display","block");
+ break;
+ case "capabilities":
+ break;
+ default:
+ break;
+ req.send();
+ this.getAddedMetadata = function(metadataId, featuretypeId){
+ method: "getFeaturetypeMetadataAddon",
+ parameters: {
+ if (!result) {
+ return;
+ case "external":
+ break;
+ case "metador":
+ break;
+ break;
+ default:
+ break;
+ //select the right list entries:
+ $(".format_selectbox").val(obj.format);
+ $(".charset_selectbox").val(obj.inspire_charset);
+ $(".ref_system_selectbox").val(obj.ref_system);
+ $(".cyclic_selectbox").val(obj.update_frequency);
+ $(".radioRes").filter('[value='+obj.spatial_res_type+']').attr('checked', true);
+ req.send();
+ this.insertAddedMetadata = function(featuretypeId, data){
+ // push metadata from server
+ method: "insertFeaturetypeMetadataAddon",
+ parameters: {
+ "data": data
+ $("<div></div>").text(message).dialog({
+ modal: true
+ //update featuretype form to show edited data
+ that.fillFeaturetypeForm(featuretypeId);
+ req.send();
+ this.updateAddedMetadata = function(metadataId, featuretypeId, data){
+ method: "updateFeaturetypeMetadataAddon",
+ parameters: {
+ "metadataId": metadataId,
+ "data": data
+ if (!result) {
+ return;
+ modal: true
+ req.send();
+ //function to fill featuretype form with changed metadata entries TODO: this function is defined in mb_metadata_featuretype.js before but it cannot be called - maybe s.th. have to be changed
+ this.fillFeaturetypeForm = function (featuretypeId) {
+ method: "getFeaturetypeMetadata",
+ parameters: {
+ "id": featuretypeId
+ if (!result) {
+ return;
+ //this.wfsId = obj.wfs_id;
+ //delete metadataURL entries
+ $('.metadataEntry').remove();
+ //fill MetadataURLs into metadata_selectbox_id - notice: the name of the module is fix!
+ Mapbender.modules.mb_md_featuretype.fillMetadataURLs(obj);
+ //reload featuretype tree for showing symbols
+ Mapbender.modules.mb_md_featuretype_tree.init(Mapbender.modules.mb_md_featuretype.getWfsId());
+ req.send();
+ deleteAddedMetadata = function(metadataId, featuretypeId){
+ method: "deleteFeaturetypeMetadataAddon",
+ parameters: {
+ if (!result) {
+ return;
+ //alert(wfsId);
+ modal: true
+ req.send();
+ this.showForm = function (metadataId, featuretypeId, isNew) {
+ $metadataAddonPopup.append($metadataAddonForm);
+ $metadataAddonPopup.dialog({
+ title : "Metadata Addon Editor",
+ autoOpen : false,
+ draggable : true,
+ modal : true,
+ width : 600,
+ position : [600, 75],
+ buttons: {
+ "close": function() {
+ $(this).dialog('close');
+ "save": function() {
+ //get data from form
+ //supress validation for the link only way
+ //example $("#myform").validate().element( "#myselect" );
+ //$("#myform").validate({
+ // ignore: ".ignore"
+ if ($("#addonChooser").css("display") == "block") {
+ //don't allow saving but do something else
+ return;
+ if ($("#simple_metadata_editor").css("display") == "block") {
+ //validate form before send it!
+ if ($metadataAddonForm.valid() != true) {
+ alert("Form not valid - please check your input!"); //TODO use translations and make a php file from this
+ return;
+ var formData = $metadataAddonForm.easyform("serialize");
+ if (!isNew) {
+ that.updateAddedMetadata(metadataId, featuretypeId, formData);
+ } else {
+ that.insertAddedMetadata(featuretypeId, formData);
+ //$('#mb_md_featuretype_tree').refresh;
+ close: function() {
+ //what to do when the dialog is closed
+ $metadataAddonPopup.dialog("open");
+ initUploadForm = function (featuretypeId) {
+ $metadataAddonPopup.dialog("close");
+ initXmlImport(featuretypeId);
+ this.init = function (metadataId, featuretypeId, isNew) {
+ $metadataAddonForm.load("../plugins/mb_metadata_addon.php", function () {
+ //push infos to help dialogs
+ $metadataAddonForm.find(".help-dialog").helpDialog();
+ //initialize datepicker
+ $('.hasdatepicker').datepicker({dateFormat:'yy-mm-dd', yearRange: '1900:2050', buttonImageOnly: true, changeYear: true,
+constraintInput: true});
+ //first get json
+ if (!isNew) {
+ that.getAddedMetadata(metadataId, featuretypeId);
+ } else {
+ //show chooser
+ $("#addonChooser").css("display","block");
+ //get initial values (title/abstract)
+ that.getInitialFeaturetypeMetadata(metadataId, featuretypeId);
+ that.showForm(metadataId, featuretypeId, isNew);
+ $("#uploadImage").click(function () {
+ initUploadForm(featuretypeId);
+ //alert($("#uploadImage").attr('onclick')); //there has been a bigger problem when setting an onclick attribut with jquery :-(
+ //TODO: make the fields resizable
+ //$( "#abstract" ).resizable({ minWidth: 75 });
+ initMetadataAddon = function(metadataId, featuretypeId, isNew) {
+ //close old window and load form
+ that.init(metadataId, featuretypeId, isNew);
+ //fill form
+$showMetadataAddonDiv.mapbender(new ShowMetadataAddonApi());
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_wfs_edit.js 2012-04-26 14:48:16 UTC (rev 8330)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_edit.js 2012-04-26 15:37:03 UTC (rev 8331)
@@ -122,7 +122,11 @@
this.init = function (obj) {
wfsId = obj;
+ if (!wfsId) {
+ return;
var formData = arguments.length >= 2 ? arguments[1] : undefined;
if (!formReady) {
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_submit.js
--- trunk/mapbender/http/plugins/mb_metadata_wfs_submit.js 2012-04-26 14:48:16 UTC (rev 8330)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_submit.js 2012-04-26 15:37:03 UTC (rev 8331)
@@ -10,7 +10,15 @@
return;
if (formData !== null) {
- formData = $.extend(formData, data);
+ if (formData.wfs && data.wfs) {
+ formDatawfs = $.extend(formData.wfs, data.wfs);
+ else if (formData.featuretype && data.featuretype) {
+ formData.featuretype = $.extend(formData.featuretype, data.featuretype);
+ else {
+ formData = $.extend(formData, data);
@@ -25,6 +33,7 @@
if (formData === null) {
+ alert("Please complete or correct the data in the form.");
return;
More information about the Mapbender_commits
