[Mapbender-commits] r8332 - branches/2.7/http/plugins
svn_mapbender at osgeo.org
Fri Apr 27 07:45:29 EDT 2012
Author: astrid_emde
Date: 2012-04-27 04:45:29 -0700 (Fri, 27 Apr 2012)
New Revision: 8332
branches/2.7/http/plugins/mb_overview.js
merged the mb_mobile code
Modified: branches/2.7/http/plugins/mb_overview.js
--- branches/2.7/http/plugins/mb_overview.js 2012-04-26 15:37:03 UTC (rev 8331)
+++ branches/2.7/http/plugins/mb_overview.js 2012-04-27 11:45:29 UTC (rev 8332)
@@ -2,32 +2,32 @@
* Package: Overview
* Description:
- * Use the overview map to navigate the main map window. You can select a new
- * rectangle in the overview map, the details will be displayed in the main
- * map window. Recenter the main map window section by just clicking a new
- * position in the overview map (the scale will not change).
+ * Use the overview map to navigate the main map window. You can select a new
+ * rectangle in the overview map, the details will be displayed in the main
+ * map window. Recenter the main map window section by just clicking a new
+ * position in the overview map (the scale will not change).
* Files:
* - http/javascripts/mod_overview.js
* SQL:
- * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
* > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','overview',
* > 2,1,'OverviewFrame','Overview','div','','',15,25,150,150,2,
* > 'overflow:hidden;',
* > '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>',
* > 'div','../plugins/mb_overview.js','mod_box1.js','mapframe1','mapframe1',
* > 'http://www.mapbender.org/index.php/Overview');
- * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES ('<app_id>', 'overview',
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<app_id>', 'overview',
* > 'overview_wms', '0', 'wms that shows up as overview' ,'var');
- * > 'skipWmsIfSrsNotSupported', '0',
+ * > 'skipWmsIfSrsNotSupported', '0',
* > 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,
* > 'var');
@@ -36,27 +36,27 @@
* Maintainer:
* http://www.mapbender.org/User:Christoph_Baudson
* Parameters:
* overview_wms - wms that shows up as overview
- * skipWmsIfSrsNotSupported - *[optional]* if set to 1, it skips the WMS
- * request if the current SRS is not supported by the WMS; if set
- * to 0, the WMS is always queried. Default is 0, because of
+ * skipWmsIfSrsNotSupported - *[optional]* if set to 1, it skips the WMS
+ * request if the current SRS is not supported by the WMS; if set
+ * to 0, the WMS is always queried. Default is 0, because of
* backwards compatibility
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
if (typeof options.overview_wms === "undefined") {
- options.overview_wms = 0;
+ options.overview_wms = 0;
if (typeof options.enable_mouse === "undefined") {
- options.enable_mouse = 1;
+ options.enable_mouse = 1;
options.overview_wms = parseInt(options.overview_wms, 10);
@@ -70,22 +70,24 @@
var $this = $(this);
Mapbender.events.initMaps.register(function () {
+ var touch;
+ var isTouchable = false;
+ try {document.createEvent("TouchEvent"); isTouchable = true; } catch(e){}
$this.data("isMap", true);
$this.mapbender(new Mapbender.Map({
- id: options.id,
- width: options.width,
- height: options.height,
+ id: options.id,
+ width: options.width,
+ height: options.height,
wms: wms,
wmsIndexOverview: options.overview_wms
map = Mapbender.modules[options.id];
map.isOverview = true;
- map.skipWmsIfSrsNotSupported =
+ map.skipWmsIfSrsNotSupported =
options.skipWmsIfSrsNotSupported === 1 ? true : false;
@@ -93,60 +95,162 @@
mb_mapObj.push(map);
- // add select area behaviour
- box = new Mapbender.Box({
- target: options.id
- $(map.getDomElement()).mousedown(function (e) {
- if (options.enable_mouse == '0') {
- return false;
- box.start(e);
- return false;
- }).mouseup(function (e) {
- var targetMap = Mapbender.modules[options.target];
- if (!targetMap) {
- return false;
- box.stop(e, function (extent) {
- if (typeof extent === "undefined") {
- return false;
- if (extent.constructor === Mapbender.Extent) {
- targetMap.calculateExtent(extent);
- targetMap.setMapRequest();
- else if (extent.constructor === Mapbender.Point) {
- targetMap.setCenter(extent);
- return false;
+ if (isTouchable) {
+ box = new Mapbender.BoxMobile({target: options.id});
+ touch = new mapTouch(map,$(map.getDomElement()), map.getDomElement(), box);
+ touch.activate();
+ } else {
+ // add select area behaviour
+ box = new Mapbender.Box({
+ target: options.id
+ $(map.getDomElement()).mousedown(function (e) {
+ if (options.enable_mouse == '0') {
+ return false;
+ box.start(e);
+ return false;
+ }).mouseup(function (e) {
+ var targetMap = Mapbender.modules[options.target];
+ if (!targetMap) {
+ return false;
+ box.stop(e, function (extent) {
+ if (typeof extent === "undefined") {
+ return false;
+ if (extent.constructor === Mapbender.Extent) {
+ targetMap.calculateExtent(extent);
+ targetMap.setMapRequest();
+ else if (extent.constructor === Mapbender.Point) {
+ targetMap.setCenter(extent);
+ return false;
// if the setBackground module is active,
// the overview wms might be hidden.
// so we activate it here.
- var ovWmsArray = map.wms;
- if (typeof ovWmsArray !== "object" || ovWmsArray.length === 0) {
- return;
- ovWmsArray[0].gui_wms_visible = 1;
+ var ovWmsArray = map.wms;
+ if (typeof ovWmsArray !== "object" || ovWmsArray.length === 0) {
+ return;
+ ovWmsArray[0].gui_wms_visible = 1;
+ function mapTouch(map, $map, mapDom, box){
+ this.map = map;
+ this.$elm = $map;
+ this.elm = mapDom;
+ this.box = box;
+ this.activate = function() {
+ this.elm.addEventListener("touchstart", touch.startTouch, true);
+ this.elm.addEventListener("touchmove", touch.moveTouch, true);
+ this.elm.addEventListener("touchend", touch.endTouch, true);
+ this.deactivate = function() {
+ this.elm.removeEventListener("touchstart", touch.startTouch, true);
+ this.elm.removeEventListener("touchmove", touch.moveTouch, true);
+ this.elm.removeEventListener("touchend", touch.endTouch, true);
+ this.startTouch = function(event) {
+ return false;
+ event.preventDefault();
+ var elm = findElement(event, "");
+ if (isSingleTouch(event)) {
+ touch.startPos = new Point(
+ event.touches[0].pageX - touch.$elm.offset().left,
+ event.touches[0].pageY - touch.$elm.offset().top);
+ var stopPos = new Point(touch.startPos.x, touch.startPos.y);
+ touch.box.start(touch.startPos, stopPos);
+ } else if (isMultiTouch(event)) {
+ var startPos = new Point(
+ event.touches[1].pageX - touch.$elm.offset().left,
+ event.touches[1].pageY - touch.$elm.offset().top);
+ touch.box.start(startPos, stopPos);
+ return true;
+ this.moveTouch = function(event) {
+ touch.box.run(touch.startPos, stopPos);
+ touch.box.run(startPos, stopPos);
+ return true;
+ this.endTouch = function(event) {
+ if (!targetMap) {
+ return false;
+ return touch.box.stop(function (extent) {
+ return false;
+ function findElement(event, tagName) {
+ var element = getElement(event);
+ while (element.parentNode && (!element.tagName ||
+ (element.tagName.toUpperCase() != tagName.toUpperCase()))){
+ element = element.parentNode;
+ return element;
+ function getElement(event) {
+ return event.target || event.srcElement;
+ function isSingleTouch (event) {
+ return event.touches && event.touches.length == 1;
+ function isMultiTouch(event) {
+ return event.touches && event.touches.length > 1;
-// update the rectangle indicating the current extent
+// update the rectangle indicating the current extent
// of the target map after each map request in the target
Mapbender.events.init.register(function () {
options.$target.mapbender(function () {
var targetMap = this;
targetMap.events.afterMapRequest.register(function () {
var min = map.convertRealToPixel(targetMap.extent.min);
var max = map.convertRealToPixel(targetMap.extent.max);
if (min.x < 0) {
min.x = 0;
@@ -172,8 +276,8 @@
max.y = centerY - 4;
var extent = new Mapbender.Extent(min, max);
box.draw(extent);
\ No newline at end of file
More information about the Mapbender_commits
