[Mapbender-commits] r8333 - branches/2.7/http/plugins
svn_mapbender at osgeo.org
Fri Apr 27 07:46:54 EDT 2012
Author: astrid_emde
Date: 2012-04-27 04:46:54 -0700 (Fri, 27 Apr 2012)
New Revision: 8333
Added:
branches/2.7/http/plugins/mb_mobile.js
new Skript for use with IPAD http://trac.osgeo.org/mapbender/ticket/822
Added: branches/2.7/http/plugins/mb_mobile.js
--- branches/2.7/http/plugins/mb_mobile.js (rev 0)
+++ branches/2.7/http/plugins/mb_mobile.js 2012-04-27 11:46:54 UTC (rev 8333)
@@ -0,0 +1,288 @@
+//var defaultTouch = null;
+eventInit.register(function () {
+ try {
+ var map = Mapbender.modules[options.target];
+ var defaultTouch = new MapTouch(map, $(map.getDomElement()), map.getDomElement());
+ defaultTouch.activate();
+ $.extend(map, {defaultTouch: defaultTouch});
+ return true;
+ } catch (e) {
+ return false;
+var defaultTouch;
+function MapTouch(map, $map, mapDom){
+ this.map = map;
+ this.$elm = $map;
+ this.elm = mapDom;
+ this.started = false;
+ this.startPos = 0, this.stopPos = 0;
+ this.timestamp = 0;
+ this.dblclick = false;
+ this.move = false;
+ this.pinch = false;
+ this.pinchObj = null;
+ this.activ = false;
+ defaultTouch = this;
+ this.activate = function() {
+ this.elm.addEventListener("touchstart", defaultTouch.startTouch, true);
+ this.elm.addEventListener("touchmove", defaultTouch.moveTouch, true);
+ this.elm.addEventListener("touchend", defaultTouch.endTouch, true);
+ this.activ = true;
+ this.activateTouchstart = function() {
+ this.activateTouchmove = function() {
+ this.activateTouchend = function() {
+ this.setActivate = function() {
+ this.deactivate = function() {
+ this.elm.removeEventListener("touchstart", defaultTouch.startTouch, true);
+ this.elm.removeEventListener("touchmove", defaultTouch.moveTouch, true);
+ this.elm.removeEventListener("touchend", defaultTouch.endTouch, true);
+ this.deactivateTouchstart = function() {
+ this.deactivateTouchmove = function() {
+ this.deactivateTouchend = function() {
+ this.setDeactivate = function() {
+ this.isActiv = function() {
+ return this.activ;
+// this.registerObject = function(obj) {
+// this.obj = obj;
+// alert(this.obj);
+ this.startTouch = function(event) {
+ event.preventDefault();
+ var elm = findElement(event, "");
+ if (isSingleTouch(event)) {
+ defaultTouch.startPos = new Mapbender.Point(
+ event.touches[0].pageX - defaultTouch.$elm.offset().left,
+ event.touches[0].pageY - defaultTouch.$elm.offset().top);
+ defaultTouch.stopPos = new Point(defaultTouch.startPos.x, defaultTouch.startPos.y);
+ var timestamp = new Date().getTime();
+ if (timestamp - defaultTouch.timestamp < 300) {
+ defaultTouch.dblclick = true;
+ defaultTouch.timestamp = timestamp;
+ } else if (isMultiTouch(event)) {
+ defaultTouch.dblclick = false;
+ defaultTouch.move = false;
+ defaultTouch.pinch = true;
+ defaultTouch.pinchObj = new Pinch(defaultTouch);
+ defaultTouch.pinchObj.pinchStart(event);
+ return true;
+ this.moveTouch = function(event) {
+ defaultTouch.moveMapMove(event);
+ defaultTouch.move = true;
+ } else if(isMultiTouch(event)) {
+ defaultTouch.pinchObj.pinchRun(event);
+ return true;
+ this.endTouch = function(event) {
+ if (defaultTouch.dblclick) {
+ defaultTouch.zoomSingle(event);
+ } else {
+ if (defaultTouch.move) {
+ defaultTouch.moveMapStop(event);
+ } else if (defaultTouch.pinch){
+ defaultTouch.pinchObj.pinchStop(event);
+ defaultTouch.pinch = false;
+ return true;
+ this.moveMapMove = function(event){
+ this.stopPos = new Mapbender.Point(
+ event.touches[0].pageX - this.$elm.offset().left,
+ event.touches[0].pageY - this.$elm.offset().top);
+ var dif = this.stopPos.minus(this.startPos);
+ this.map.moveMap(dif.x, dif.y);
+ this.moveMapStop = function(event){
+ var mapCenter = new Mapbender.Point(
+ parseInt(parseInt(this.map.getWidth()) / 2),
+ parseInt(parseInt(this.map.getHeight()) / 2)
+ var center = mapCenter.minus(dif);
+ var realCenter = this.map.convertPixelToReal(center);
+ this.map.zoom(false, 1.0, realCenter);
+ this.startPos = null;
+ this.stopPos = null;
+ this.zoomSingle = function(event){
+ var pos = this.map.convertPixelToReal(this.stopPos);
+ var extentAfterZoom = this.map.calculateExtentAfterZoom(
+ true,
+ 2.0,
+ pos.x,
+ pos.y
+ var newPos = this.map.convertRealToPixel(
+ pos,
+ extentAfterZoom
+ var diff = newPos.minus(this.stopPos);
+ var newSouthEast = this.map.convertPixelToReal(
+ (new Point(0, this.map.getHeight())).plus(diff),
+ extentAfterZoom
+ var newNorthWest = this.map.convertPixelToReal(
+ (new Point(this.map.getWidth(), 0)).plus(diff),
+ extentAfterZoom
+ var newExtent = new Mapbender.Extent(newSouthEast, newNorthWest);
+ this.map.setExtent(newExtent);
+ this.map.setMapRequest();
+ function findElement(event, tagName) {
+ var element = getElement(event);
+ while (element.parentNode && (!element.tagName ||
+ (element.tagName.toUpperCase() != tagName.toUpperCase()))){
+ element = element.parentNode;
+ return element;
+ function getElement(event) {
+ return event.target || event.srcElement;
+ function isSingleTouch(event) {
+ return event.touches && event.touches.length == 1;
+ function isMultiTouch(event) {
+ return event.touches && event.touches.length > 1;
+ function Pinch(mmtouch){
+ this.mmtouch = mmtouch;
+ this.scale = 1;
+ this.pinchStart = function(event) {
+ this.pinchCenter = new Mapbender.Point(
+ parseInt((event.touches[0].pageX - this.mmtouch.$elm.offset().left +
+ event.touches[1].pageX - this.mmtouch.$elm.offset().left) / 2),
+ parseInt((event.touches[0].pageY - this.mmtouch.$elm.offset().top +
+ event.touches[1].pageY - this.mmtouch.$elm.offset().top) / 2));
+ this.pos0 = new Mapbender.Point(
+ event.touches[0].pageX - this.mmtouch.$elm.offset().left,
+ event.touches[0].pageY - this.mmtouch.$elm.offset().top);
+ this.pos1 = new Mapbender.Point(
+ event.touches[1].pageX - this.mmtouch.$elm.offset().left,
+ event.touches[1].pageY - this.mmtouch.$elm.offset().top);
+ this.startDist = Math.sqrt(
+ Math.pow(this.pos0.x - this.pos1.x, 2) +
+ Math.pow(this.pos0.y - this.pos1.y, 2));
+ this.pinchRun = function(event) {
+ this.lastPinchCenter = new Mapbender.Point(
+ // var dif = this.lastCenter.minus(this.center);
+ var pos0 = new Mapbender.Point(
+ var pos1 = new Mapbender.Point(
+ var dist = Math.sqrt(
+ Math.pow(pos0.x - pos1.x, 2) +
+ Math.pow(pos0.y - pos1.y, 2));
+ this.scale = dist / this.startDist;
+ var index = this.mmtouch.map.history.getCurrentIndex();
+ var width = parseInt(parseInt(this.mmtouch.$elm.css("width")) * this.scale);
+ var height = parseInt(parseInt(this.mmtouch.$elm.css("height")) * this.scale);
+ var leftAt = parseInt(this.lastPinchCenter.x * this.scale);
+ var topAt = parseInt(this.lastPinchCenter.y * this.scale);
+ var left = this.lastPinchCenter.x - leftAt;
+ var top = this.lastPinchCenter.y - topAt;
+ $("#" + this.mmtouch.map.elementName + "_request_" + (index) + " div img").css({
+ position: "absolute",
+ width: width + "px",
+ height: height + "px",
+ left: left + "px",
+ top: top + "px"
+ this.pinchStop = function(event) {
+ var pos = this.mmtouch.map.convertPixelToReal(this.lastPinchCenter);
+// var dist = this.startDist * this.scale;
+// var isZoomIn = false;
+// if (this.startDist - dist < 0){
+// isZoomIn = true;
+ var extentAfterZoom = this.mmtouch.map.calculateExtentAfterZoom(
+ true,
+ this.scale,
+ pos.x,
+ pos.y
+ var newPos = this.mmtouch.map.convertRealToPixel(
+ pos,
+ extentAfterZoom
+ var diff = newPos.minus(this.lastPinchCenter);
+ var newSouthEast = this.mmtouch.map.convertPixelToReal(
+ (new Point(0, this.mmtouch.map.getHeight())).plus(diff),
+ extentAfterZoom
+ var newNorthWest = this.mmtouch.map.convertPixelToReal(
+ (new Point(this.mmtouch.map.getWidth(), 0)).plus(diff),
+ extentAfterZoom
+ this.mmtouch.map.setExtent(newExtent);
+ this.mmtouch.map.setMapRequest();
\ No newline at end of file
More information about the Mapbender_commits
