[Mapbender-commits] r8334 - branches/2.7/http/javascripts
svn_mapbender at osgeo.org
Fri Apr 27 07:53:21 EDT 2012
Author: astrid_emde
Date: 2012-04-27 04:53:21 -0700 (Fri, 27 Apr 2012)
New Revision: 8334
branches/2.7/http/javascripts/mod_box1.js
script modified for use with IPAD http://trac.osgeo.org/mapbender/ticket/822
Modified: branches/2.7/http/javascripts/mod_box1.js
--- branches/2.7/http/javascripts/mod_box1.js 2012-04-27 11:46:54 UTC (rev 8333)
+++ branches/2.7/http/javascripts/mod_box1.js 2012-04-27 11:53:21 UTC (rev 8334)
@@ -229,3 +229,216 @@
bottomNode = document.getElementById(map.elementName + bottomSuffix);
+Mapbender.BoxMobile = function (options) {
+ var map = (typeof options.target !== "undefined") ?
+ getMapObjByName(options.target) : null;
+ var color = (typeof options.color !== "undefined") ?
+ options.color : "#ff0000";
+ var isActive = false;
+ var top = 0;
+ var topSuffix = "_l_top";
+ var topNode;
+ var left = 0;
+ var leftSuffix = "_l_left";
+ var leftNode;
+ var bottom = 0;
+ var bottomSuffix = "_l_bottom";
+ var bottomNode;
+ var right = 0;
+ var rightSuffix = "_l_right";
+ var rightNode;
+ var startPos = null;
+ var stopPos = null;
+ var exists = false;
+ var that = this;
+ this.start = function (startPosition, stopPosition) {
+ startPos = startPosition;
+ stopPos = stopPosition;
+ isActive = true;
+ top = startPos.y;
+ left = startPos.y;
+ bottom = startPos.y;
+ right = startPos.x;
+ return true;
+ this.run = function (startPosition, stopPosition) {
+ if (startPosition !== null && stopPosition != null) {
+ var width = map.width;
+ var height = map.height;
+ if (startPos.x > stopPos.x) {
+ left = stopPos.x;
+ else {
+ left = startPos.x;
+ right = stopPos.x;
+ if (startPos.y > stopPos.y) {
+ top = stopPos.y;
+ else {
+ top = startPos.y;
+ bottom = stopPos.y;
+ if (!startPos.equals(stopPos)) {
+ this.draw();
+ return true;
+ this.stop = function (callback) {
+ hideElement(topNode);
+ hideElement(leftNode);
+ hideElement(rightNode);
+ hideElement(bottomNode);
+ if (isActive) {
+ isActive = false;
+ if (typeof callback === "function") {
+ return callback(getExtent());
+ return getExtent();
+ isActive = false;
+ var arrangeBox = function (node, left, top, right, bottom) {
+ var el = node.style;
+ el.height = Math.abs(bottom - top) + "px";
+ el.width = Math.abs(right - left) + "px";
+ el.top = top + "px";
+ el.left = left + "px";
+ var displayElement = function (node) {
+ node.style.visibility = "visible";
+ var hideElement = function (node) {
+ node.style.visibility = "hidden";
+ var domElementsExist = function () {
+ if (!map) {
+ return;
+ return map.getDomElement(
+ ).ownerDocument.getElementById(
+ map.elementName + topSuffix
+ ) !== null;
+ var createDomElements = function () {
+ if (!map) {
+ return;
+ var map_el = map.getDomElement();
+ topNode = map_el.ownerDocument.createElement("div");
+ topNode.style.position = "absolute";
+ topNode.style.top = "0px";
+ topNode.style.left = "0px";
+ topNode.style.width = "0px";
+ topNode.style.height = "0px";
+ topNode.style.overflow = "hidden";
+ // topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
+ topNode.style.zIndex = 100;
+ topNode.style.visibility = "visible";
+ topNode.style.cursor = "crosshair";
+ topNode.style.backgroundColor = color;
+ leftNode = topNode.cloneNode(false);
+ rightNode = topNode.cloneNode(false);
+ bottomNode = topNode.cloneNode(false);
+ topNode.id = map.elementName + topSuffix;
+ leftNode.id = map.elementName + leftSuffix;
+ rightNode.id = map.elementName + rightSuffix;
+ bottomNode.id = map.elementName + bottomSuffix;
+ map_el.appendChild(topNode);
+ map_el.appendChild(leftNode);
+ map_el.appendChild(rightNode);
+ map_el.appendChild(bottomNode);
+ exists = true;
+ this.draw = function (extent) {
+ if (!map) {
+ return;
+ if (typeof extent === "object"
+ && extent.constructor === Mapbender.Extent) {
+ left = extent.min.x;
+ right = extent.max.x;
+ bottom = extent.min.y;
+ top = extent.max.y;
+ arrangeBox(topNode, left, top, right, top + 2);
+ arrangeBox(leftNode, left, top, left + 2, bottom);
+ arrangeBox(rightNode, right - 2, top, right, bottom);
+ arrangeBox(bottomNode, left, bottom - 2, right, bottom);
+ displayElement(topNode);
+ displayElement(leftNode);
+ displayElement(rightNode);
+ displayElement(bottomNode);
+ var getExtent = function () {
+ if (!map) {
+ return null;
+ var x1 = startPos.x;
+ var x2 = stopPos.x;
+ var y1 = startPos.y;
+ var y2 = stopPos.y;
+ var minx = x2;
+ var maxx = x1;
+ if(x1 < x2){
+ minx = x1;
+ maxx = x2;
+ var miny = y1;
+ var maxy = y2;
+ if(y1 < y2){
+ miny = y2;
+ maxy = y1;
+ // area or clickpoint ?
+ var posMin = map.convertPixelToReal(new Point(minx,miny));
+ if((maxx - minx) > 3 && (miny - maxy) > 3){
+ var posMax = map.convertPixelToReal(new Point(maxx,maxy));
+ return new Mapbender.Extent(posMin, posMax);
+ return posMin;
+ if (!domElementsExist()) {
+ createDomElements();
+ else {
+ topNode = document.getElementById(map.elementName + topSuffix);
+ leftNode = document.getElementById(map.elementName + leftSuffix);
+ rightNode = document.getElementById(map.elementName + rightSuffix);
+ bottomNode = document.getElementById(map.elementName + bottomSuffix);
More information about the Mapbender_commits
