[Mapbender-commits] r8472 - in trunk/mapbender: http/classes http/javascripts http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Tue Aug 28 03:41:46 PDT 2012
Author: armin11
Date: 2012-08-28 03:41:45 -0700 (Tue, 28 Aug 2012)
New Revision: 8472
trunk/mapbender/http/classes/class_georss_geometry.php
trunk/mapbender/http/classes/class_georss_item.php
trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
trunk/mapbender/http/plugins/mb_downloadFeedServer.php
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Enhancement of the inspire download service client and bugfix of georss parsing/generating.
Modified: trunk/mapbender/http/classes/class_georss_geometry.php
--- trunk/mapbender/http/classes/class_georss_geometry.php 2012-08-27 13:48:29 UTC (rev 8471)
+++ trunk/mapbender/http/classes/class_georss_geometry.php 2012-08-28 10:41:45 UTC (rev 8472)
@@ -266,7 +266,7 @@
class geoRSSPolygon extends GMLPolygon{
var $targetEPSG;
public function parsePolygon ($georssPolygon) {
- if (gettype == 'object') {
+ if (gettype($georssPolygon) == 'object') {
//polygon is given as dom node
$coordArray = explode(' ',$georssPolygon->nodeValue);
} else {
@@ -284,7 +284,16 @@
class geoRSSBox extends GMLPolygon{
var $targetEPSG;
public function parseBox ($domNode) {
- list($x1,$y1,$x2,$y2) = explode(' ',$domNode->nodeValue);
+ ////in georss lat/lon is given, in geojson lon lat will be used http://www.georss.org/simple http://www.geojson.org/geojson-spec.html#coordinate-reference-system-objects
+ if (gettype($domNode) == 'object') {
+ //polygon is given as dom node
+ list($y1,$x1,$y2,$x2) = explode(' ',$domNode->nodeValue);
+ } else {
+ //bbox is given as string
+ list($y1,$x1,$y2,$x2) = explode(' ',$domNode);
if ($this->targetEPSG != '4326') {
$tCoords = transform($x1, $y1,'4326', $this->targetEPSG);
$x1 = $tCoords["x"];
@@ -293,6 +302,7 @@
$x2 = $tCoords["x"];
$y2 = $tCoords["y"];
$this->addPoint($x1, $y1);
$this->addPoint($x1, $y2);
$this->addPoint($x2, $y2);
Modified: trunk/mapbender/http/classes/class_georss_item.php
--- trunk/mapbender/http/classes/class_georss_item.php 2012-08-27 13:48:29 UTC (rev 8471)
+++ trunk/mapbender/http/classes/class_georss_item.php 2012-08-28 10:41:45 UTC (rev 8472)
@@ -25,18 +25,18 @@
public function getBbox () {
return $this->bbox;
+ //to note georss defines lat/lon not lon/lat
protected function getItemString () {
$str = parent::getItemString();
if (is_a($this->bbox, "Mapbender_bbox")) {
$str .= "<georss:box>" .
+ $this->bbox->min->y . " " .
$this->bbox->min->x . " " .
- $this->bbox->min->y . " " .
- $this->bbox->max->x . " " .
- $this->bbox->max->y .
+ $this->bbox->max->y . " " .
+ $this->bbox->max->x .
"</georss:box>\n";
return $str;
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js 2012-08-27 13:48:29 UTC (rev 8471)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js 2012-08-28 10:41:45 UTC (rev 8472)
@@ -191,6 +191,7 @@
//initialize options
var selectROptions = "";
//iterate over all possible representations, which are modeled as entries in the dataset feed (here features of the featureCollection)
+ //alert(featureCollection.features.length);
for(var i=0; i<featureCollection.features.length; ++i) {
selectROptions = selectROptions+"<option value='"+i+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
@@ -213,9 +214,11 @@
//initialize option string
var selectFOptions = "";
//count number of links in representation
- var numberOfLinks = featureCollection.features[0].properties.entry[k].link.length;
+ var numberOfLinks = featureCollection.features[k].properties.link.length;
+ //alert("number of links: "+numberOfLinks+"for representation: "+k);
+ //alert(featureCollection.features[0].properties.entry[0].title);
//alert("number of links: "+numberOfLinks);
- if (numberOfLinks >= 1) {
+ if (numberOfLinks >= 1 || numberOfLinks === undefined) {
//show list
$("#representation_select").css("display","block");
//deactivate mapframe2 by default
@@ -225,18 +228,13 @@
//extent size of outer fieldset
$("#client").css("height","730px");
} else {
- /*if (numberOfLinks == 1) {
- //open single link for download!
- //show download symbol
+ alert("No links to datasets or parts of them found in feed!");
- for (var i = 0; i < featureCollection.features[0].properties.entry[k].link.length; i++) {
- if (featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox == '' || featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox === undefined) {
- selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"' onclick='window.open(\""+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"\");'>"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"</option>";
+ for (var i = 0; i < numberOfLinks; i++) {
+ if (featureCollection.features[k].properties.link[i]['@attributes'].bbox == '' || featureCollection.features[k].properties.link[i]['@attributes'].bbox === undefined) {
+ selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"' onclick='window.open(\""+featureCollection.features[k].properties.link[i]['@attributes'].href+"\");'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
} else {
- ext = featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox;
+ ext = featureCollection.features[k].properties.link[i]['@attributes'].bbox;
extArrayNew = new Array();
extArray = ext.split(",");
//sort array to lat lon
@@ -245,10 +243,10 @@
extArrayNew[2] = extArray[3];
extArrayNew[3] = extArray[2];
bound = OpenLayers.Bounds.fromArray(extArrayNew);
- attributes = {id: i, url:featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href};
+ attributes = {id: i, url:featureCollection.features[k].properties.link[i]['@attributes'].href};
box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
bboxFiles.addFeatures(box);
- selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"</option>";
+ selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
Modified: trunk/mapbender/http/plugins/mb_downloadFeedServer.php
--- trunk/mapbender/http/plugins/mb_downloadFeedServer.php 2012-08-27 13:48:29 UTC (rev 8471)
+++ trunk/mapbender/http/plugins/mb_downloadFeedServer.php 2012-08-28 10:41:45 UTC (rev 8472)
@@ -82,6 +82,7 @@
$feedXML->registerXPathNamespace("defaultns", "http://www.w3.org/2005/Atom");
$title = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:title');
+ //$content = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:content');
$rights = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:rights');
$summary = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:summary');
$date = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:date');
@@ -89,7 +90,8 @@
$namespace = $feedXML->xpath('/defaultns:feed/defaultns:entry/inspire_dls:spatial_dataset_identifier_namespace');
- $bbox = $feedXML->xpath('/defaultns:feed/defaultns:entry/georss:polygon');
+ $polygon = $feedXML->xpath('/defaultns:feed/defaultns:entry/georss:polygon');
+ $bbox = $feedXML->xpath('/defaultns:feed/defaultns:entry/georss:box');
$metadataLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'describedby\')]/@href');
$datasetFeedLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'alternate\')]/@href');
//new feature collection
@@ -99,17 +101,20 @@
$uuid = new Uuid;
$feature->fid = $uuid;
$titleArray = (array)$title[$i];
+ $contentArray = (array)$content[$i];
$rightsArray = (array)$rights[$i];
$summaryArray = (array)$summary[$i];
$dateArray = (array)$date[$i];
$codeArray = (array)$code[$i];
$namespaceArray = (array)$namespace[$i];
$bboxArray = (array)$bbox[$i];
+ $polygonArray = (array)$polygon[$i];
$mdLinkArray = (array)$metadataLink[$i];
$mdLinkArray = $mdLinkArray["@attributes"];
$dsLinkArray = (array)$datasetFeedLink[$i];
$dsLinkArray = $dsLinkArray["@attributes"];
$feature->properties["title"] = $titleArray[0];
+ //$feature->properties["content"] = $contentArray[0];
$feature->properties["summary"] = $summaryArray[0];
$feature->properties["rights"] = $rightsArray[0];
$feature->properties["date"] = $dateArray[0];
@@ -117,8 +122,22 @@
$feature->properties["namespace"] = $namespaceArray[0];
$feature->properties["metadataLink"] = $mdLinkArray["href"];
$feature->properties["datasetFeedLink"] = $dsLinkArray["href"];
- $feature->geometry = new geoRSSPolygon();
- $feature->geometry->parsePolygon($bboxArray[0]);
+ //check if polygon is given
+ if (isset($polygonArray[0]) && $polygonArray[0] != '') {
+ $feature->geometry = new geoRSSPolygon();
+ $feature->geometry->parsePolygon($polygonArray[0]);
+ } else { //maybe bbox is given
+ if (isset($bboxArray[0]) && $bboxArray[0] != '') {
+ $feature->geometry = new geoRSSBox();
+ $feature->geometry->targetEPSG = '4326';
+ $feature->geometry->parseBox($bboxArray[0]);
+ } else {
+ //set dummy extent - maybe the one of the first feed
+ $feature->geometry = null;
//$feature->geometry->targetEPSG = "EPSG:4326";
if (isset($feature->geometry) && $feature->geometry!==false) {
$featureCollection->addFeature($feature);
@@ -160,9 +179,9 @@
+ $content = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:content');
//$link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
//$datasetFeedLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'alternate\')]/@href');
@@ -172,29 +191,42 @@
$uuid = new Uuid;
- $entry = $feedXML->xpath('/defaultns:feed/defaultns:entry');
+ $links = $feedXML->xpath('/defaultns:feed/defaultns:entry['.(string)($i + 1).']/defaultns:link');
+ $feature->properties["content"] = $contentArray[0];
- $feature->properties["entry"] = array();
- for ($j=0; $j<=(count($entry)-1); $j++) {
- $feature->properties["entry"][$j] = $entry[$j];
+ //$feature->properties["entry"] = array();
+ } else {
- $link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
- $e = new mb_notice("mod_downloadFeedServer.php: bboxArray[0]: ".$bboxArray[0]);
- if (!isset($bboxArray[0]) || $bboxArray[0] == "") {
- $feature->geometry = null;
- } else {
+ //extract all links
+ for ($j=0; $j<=(count($links)-1); $j++) {
+ $feature->properties["link"][$j] = $links[$j];
+ //$link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
//set geometry to null if geometry is not given!
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2012-08-27 13:48:29 UTC (rev 8471)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2012-08-28 10:41:45 UTC (rev 8472)
@@ -3561,7 +3561,7 @@
msgid "Search for addresses"
msgstr "Suche nach Adressen"
-#plugins/mod_downloadFeedClient.php
+#: ../plugins/mod_downloadFeedClient.php
msgid "INSPIRE ATOM Feed Client"
msgstr "INSPIRE ATOM Feed Client"
@@ -3583,5 +3583,3 @@
msgid "Select to download dataset"
msgstr "Auswahl zum Download"
More information about the Mapbender_commits
