[Mapbender-commits] r8427 - branches/2.7/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 6 01:37:49 PDT 2012
Author: astrid_emde
Date: 2012-07-06 01:37:48 -0700 (Fri, 06 Jul 2012)
New Revision: 8427
   branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
Position jsonAutoCompleteGazetteer left 250
Modified: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2012-07-06 08:24:05 UTC (rev 8426)
+++ branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2012-07-06 08:37:48 UTC (rev 8427)
@@ -220,7 +220,7 @@
 -- new gazetteer jsonAutocompleteGazetteer
 INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_autocomplete',5,1,'Module to manage jQuery UI autocomplete module','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.autocomplete.js','','jq_ui,jq_ui_widget,jq_ui_position','http://jqueryui.com/demos/autocomplete/');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jsonAutocompleteGazetteer',12,1,'Client for json webservices like geonames.org','Gazetteer','div','','',220,110,NULL ,NULL ,999,'','','div','../plugins/mod_jsonAutocompleteGazetteer.php','','mapframe1','','http://www.mapbender.org/index.php/mod_jsonAutocompleteGazetteer');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jsonAutocompleteGazetteer',12,1,'Client for json webservices like geonames.org','Gazetteer','div','','',250,110,NULL ,NULL ,999,'','','div','../plugins/mod_jsonAutocompleteGazetteer.php','','mapframe1','','http://www.mapbender.org/index.php/mod_jsonAutocompleteGazetteer');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jsonAutocompleteGazetteer', 'gazetteerUrl', 'http://ws.geonames.org/searchJSON?lang=de&',
   '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jsonAutocompleteGazetteer', 'isGeonames', 'true', '' ,'var');
More information about the Mapbender_commits mailing list
