[Mapbender-commits] r8428 - in trunk/mapbender/resources/db: . pgsql
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 6 02:54:57 PDT 2012
Author: armin11
Date: 2012-07-06 02:54:57 -0700 (Fri, 06 Jul 2012)
New Revision: 8428
   trunk/mapbender/resources/db/admin_wfs_metadata.sql
   trunk/mapbender/resources/db/admin_wms_metadata.sql
   trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql
new versions of admin_guis for metadata and gui for admin wms scheduler
Modified: trunk/mapbender/resources/db/admin_wfs_metadata.sql
--- trunk/mapbender/resources/db/admin_wfs_metadata.sql	2012-07-06 08:37:48 UTC (rev 8427)
+++ trunk/mapbender/resources/db/admin_wfs_metadata.sql	2012-07-06 09:54:57 UTC (rev 8428)
@@ -311,3 +311,6 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
+insert into gui_mb_user  (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('admin_wfs_metadata',1,'owner');
Modified: trunk/mapbender/resources/db/admin_wms_metadata.sql
--- trunk/mapbender/resources/db/admin_wms_metadata.sql	2012-07-06 08:37:48 UTC (rev 8427)
+++ trunk/mapbender/resources/db/admin_wms_metadata.sql	2012-07-06 09:54:57 UTC (rev 8428)
@@ -388,3 +388,5 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
+insert into gui_mb_user  (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('admin_wms_metadata',1,'owner');
Modified: trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql
--- trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql	2012-07-06 08:37:48 UTC (rev 8427)
+++ trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql	2012-07-06 09:54:57 UTC (rev 8428)
@@ -67,3 +67,5 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+insert into gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('admin_ows_scheduler',1,'owner');
More information about the Mapbender_commits mailing list
