[Mapbender-commits] r8496 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 26 06:05:41 PDT 2012
Author: armin11
Date: 2012-09-26 06:05:41 -0700 (Wed, 26 Sep 2012)
New Revision: 8496
Added:
   trunk/mapbender/http/geoportal/gazetteerdogprofile.css
   trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_client.php
   trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_server.php
DOG Client Module from geoportal-rlp
Added: trunk/mapbender/http/geoportal/gazetteerdogprofile.css
--- trunk/mapbender/http/geoportal/gazetteerdogprofile.css	                        (rev 0)
+++ trunk/mapbender/http/geoportal/gazetteerdogprofile.css	2012-09-26 13:05:41 UTC (rev 8496)
@@ -0,0 +1,62 @@
+#gazetteerDOGForm
+/*background-color:lightgray;*/
+width:180px;
+height:inherit;
+padding-left:8px;
+#gazetteerDOGForm div
+width:inherit;
+height:auto;
+padding-bottom:6px;
+#selectResultsearchGemeinden
+background-color:#F2F2F2;
+width:inherit;
+height:inherit;
+#selectResultsearchStrassen
+width:inherit;
+height:inherit;
+.gazetteerDOG
+border: solid gray 1px;
+width:190px;
+height:inherit;
+width:190px;
+height:inherit;
+#gazetteerDOGOrtPlz
+width:110px;
+#gazetteerDOGStrasse
+width:110px;
Added: trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_client.php
--- trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_client.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_client.php	2012-09-26 13:05:41 UTC (rev 8496)
@@ -0,0 +1,606 @@
+<?php
+# $Id: mod_gazetteerDOGProfile.php
+# http://www.mapbender.org/GazetteerDOGProfile
+# Copyright (C) 2009 OSGeo
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require(dirname(__FILE__)."/../php/mb_validateSession.php");
+include '../include/dyn_js.php';
+include '../include/dyn_php.php';
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'gazetteerDOGProfile' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+	$e_target = $row["e_target"];
+	$cnt++;
+echo "var targetString = '" . $e_target . "';";
+try {if(featuretypeGemeinden){}}catch(e) {featuretypeGemeinden = "dog:gemeinden";}
+try {if(featuretypeStrassen){}}catch(e) {featuretypeStrassen = "dog:Strassen";}
+try {if(featuretypeHauskoordinaten){}}catch(e) {featuretypeHauskoordinaten = "dog:Hauskoordinaten";}
+try {if(searchAttrGemeinden){}}catch(e) {searchAttrGemeinden = "iso19112:geographicIdentifier";}
+try {if(searchAttrStrassen){}}catch(e) {searchAttrStrassen = "dog:strassenschluessel,dog:strassenname";}
+try {if(searchAttrHauskoordinaten){}}catch(e) {searchAttrHauskoordinaten = "iso19112:parent";}
+try {if(gemeindenAttributes){}}catch(e) {gemeindenAttributes = "geographicIdentifier,parent,gemeindeschluessel";}
+try {if(strassenAttributes){}}catch(e) {strassenAttributes = "geographicIdentifier,strassenname";}
+try {if(hauskoordinatenAttributes){}}catch(e) {hauskoordinatenAttributes = "hausnummer,hausnummernzusatz";}
+try {if(noResultMsg){}}catch(e) {noResultMsg = "No result.";}
+try {if(serverErrorMsg){}}catch(e) {serverErrorMsg = "Server error.";}
+try {if(markerImage){}}catch(e) {markerImage = "../img/marker_fett.gif";}
+var geomArrayGemeinden = null;
+var geomArrayStrassen = null;
+var geomArrayHauskoordinaten = null;
+var gazetteerStep = "searchGemeinden";
+var searchString;
+var searchFeaturetype;
+var searchFor;
+var showAttributeName;
+var noResultMsg
+var serverErrorMsg = "";
+var gazetteerResultHighlight;
+var highlightColor = "#cc33cc";
+var currentMarker_mapframe1 = null;
+var currentMarker_overview = null;
+var permanentMarker = null;
+var targetArray = targetString.split(",");
+ * get html content for gazetteer form
+function getHtmlForGazetteerForm () {
+	mb_ajax_post("../geoportal/mod_gazetteerDOGProfile_server.php", {"command":"getHtml"}, function(jsCode, status) {
+		if(status == 'success'){
+			$("#gazetteerDOGProfile").html(jsCode);
+		else{
+			$("#gazetteerDOGProfile").html("HTML could not be loaded.");
+function normalizeString(str){
+	str = str.replace(/\./g,'*');
+    str = str.replace(/-/g,' ');
+    str = str.toUpperCase();
+    str = str.replace(/ß/g,'ß');
+    str = str.replace(/Ä/g,'ä');
+    str = str.replace(/Ö/g,'ö');
+    str = str.replace(/Ü/g,'ü');
+    return str;
+ * search for Gemeinden in featuretype dog:gemeinden
+function startGazetteer () {
+	$("#gazetteerDOGHausnummer").empty();
+	var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
+	gazetteerResultHighlight = new Highlight(targetArray, "gazetteerDOGProfileHighlight", styleProperties, 2);
+	if(gazetteerStep == "searchStrassen"){
+		searchFeaturetype = featuretypeStrassen;
+		searchAttr = searchAttrStrassen;
+//		var searchString1 = document.getElementById('selectResultsearchGemeinden').options[document.getElementById('selectResultsearchGemeinden').selectedIndex].value;
+		var selectboxIndex = parseInt(document.getElementById('selectResultsearchGemeinden').value, 10);
+		var showField = gemeindenAttributes.split(",");
+		var searchString1 = geomArrayGemeinden.get(selectboxIndex).e.getElementValueByName(showField[2]);
+		var searchString2 = document.getElementById('gazetteerDOGStrasse').value;
+		if (searchString1 == "" || searchString2 == "") {
+			alert("Bitte Ort und Straße angeben.");
+			return false;
+		var singleSearchAttr = searchAttr.split(",");
+		//searchFor = singleSearchAttr[0] + "=" + searchString1 + "|" + singleSearchAttr[1] + "=" + normalizeString(searchString2);
+		searchFor = singleSearchAttr[0] + "=" + searchString1 + "|" + singleSearchAttr[1] + "=" + searchString2;
+		showAttributeName = strassenAttributes;
+	else if(gazetteerStep == "searchHauskoordinaten") {
+		searchFeaturetype = featuretypeHauskoordinaten;
+		searchAttr = searchAttrHauskoordinaten;
+//		searchString = document.getElementById('selectResultsearchStrassen').options[document.getElementById('selectResultsearchStrassen').selectedIndex].value;
+		var selectboxIndex = parseInt(document.getElementById('selectResultsearchStrassen').value, 10);
+		var showField = strassenAttributes.split(",");
+		searchString = geomArrayStrassen.get(selectboxIndex).e.getElementValueByName(showField[0]);
+		if (searchString == "") {
+			alert("Bitte Straße angeben.");
+			return false;
+		searchFor = searchAttr + "="  + searchString;
+		showAttributeName = hauskoordinatenAttributes;
+	else{
+		searchString = document.getElementById('gazetteerDOGOrtPlz').value;
+		if(isNaN(searchString) == false) {
+			if(searchString.length != 5) {
+				alert("PLZ bitte vollständig eingeben.");
+				return false;
+			searchFeaturetype = featuretypePLZ;
+			searchAttr = searchAttrPLZ;
+			showAttributeName = plzAttributes;
+			gazetteerStep = "searchPlz";
+		else{
+			searchFeaturetype = featuretypeGemeinden;
+			searchAttr = searchAttrGemeinden;
+			//searchFor = searchAttr + "="  + normalizeString(searchString);
+				alert("Bitte Ort/PLZ eingeben.");
+				return false;
+			showAttributeName = gemeindenAttributes;
+	var parameters = {
+		"command" : gazetteerStep,
+		"wfsUrl" : wfsUrl,
+//		"authUserNameWfs" : authUserName,
+//		"authUserPasswordWfs" : authUserPassword,
+		"searchFeaturetype" : searchFeaturetype,
+		"searchFor" : searchFor
+	document.getElementById("gazetteerProgressWheel").innerHTML = "<img src='../img/indicator_wheel.gif'></img>Suche läuft...";
+	$.post("../geoportal/mod_gazetteerDOGProfile_server.php", parameters, function(jsCode, status) {
+		document.getElementById("gazetteerProgressWheel").innerHTML = "";
+			try {
+				if(typeof(jsCode) == 'string'){
+					alert(jsCode);
+					return false;
+				else if(typeof(jsCode) == 'object'){
+					var geoObj = jsCode;
+				else{
+					var geoObj = parent.$.parseJSON(jsCode);
+			catch (exc) {
+				alert("Invalid data returned from service.");
+				return false;
+       		if (typeof geoObj === "undefined") {
+			else if (jsCode) {
+				if (typeof(geoObj) == 'object') {
+					if(gazetteerStep == "searchHauskoordinaten") {
+						if(typeof geoObj.errorMessage != "undefined"){
+							alert(noResultMsg);
+							gazetteerStep = "searchHauskoordinaten";
+						else {
+							geomArrayHauskoordinaten = new GeometryArray();
+							geomArrayHauskoordinaten.importGeoJSON(geoObj);
+							if(geomArrayHauskoordinaten.count() > 0) {
+								$("#gazetteerDOGHausnummer").html(showHausnummern(geomArrayHauskoordinaten));
+							else {
+								$("#gazetteerDOGHausnummer").show();
+								$("#gazetteerDOGHausnummer").css("color","#000000");
+								var resultHtml = "Hausnummern:<br>";
+								resultHtml += $("#selectResultsearchStrassen option:selected").html() + "<br>";
+								resultHtml += "Kein Ergebnis<br>";
+								$("#gazetteerDOGHausnummer").html(resultHtml);
+					else if(gazetteerStep == "searchStrassen") {
+							$("#gazetteerDOGStrasse").val("");
+							$("#gazetteerDOGStrasse").focus();
+							gazetteerStep = "searchStrassen";
+						else {
+							geomArrayStrassen = new GeometryArray();
+							geomArrayStrassen.importGeoJSON(geoObj);
+							if(geomArrayStrassen.count() < 1) {
+								return;
+							$("#gazetteerDOGStrasseField").empty();
+							$("#gazetteerDOGStrasseField").html(showResult(geomArrayStrassen));
+							//wenn nur ein Suchergebnis vorhanden, führe Zoom und startGazetteer direkt aus
+							if(geomArrayStrassen.count() == 1) {
+								zoomToStrassen(gazetteerStep, 0);
+								startGazetteer();
+							else {
+								$("#gazetteerDOGHausnummer").css("color","#808080");
+					else {
+							$("#gazetteerDOGOrtPlz").val("");
+							$("#gazetteerDOGOrtPlz").focus();
+							gazetteerStep = "searchGemeinden";
+						else {
+							geomArrayGemeinden = new GeometryArray();
+							geomArrayGemeinden.importGeoJSON(geoObj);
+							if(geomArrayGemeinden.count() < 1) {
+								return;
+							if(gazetteerStep == "searchPlz") {
+								showResultPlz(geomArrayGemeinden);
+							else {
+								$("#gazetteerDOGOrtField").empty();
+								$("#gazetteerDOGOrtField").html(showResult(geomArrayGemeinden));
+								//wenn nur ein Suchergebnis vorhanden, führe Zoom und setStrassenField direkt aus
+								if(geomArrayGemeinden.count() == 1) {
+									zoomToGemeinden(gazetteerStep, 0);
+									setStrassenField();
+									//$("#gazetteerDOGStrasse").focus();
+	       		else {
+       	else {
+       		alert(serverErrorMsg);
+	},"json");
+	return false;
+var sortFunction = function (a, b) {
+	if (a.title.toUpperCase() < b.title.toUpperCase() ) {
+		return -1;
+	return 1;
+var sortIntFunction = function (a, b) {
+	if (a.title < b.title) {
+		return -1;
+	return 1;
+var sortHausnummernFunction = function (a, b) {
+	if (a.showTitle.toUpperCase() > b.showTitle.toUpperCase()) {
+		return -1;
+	return 1;
+ * show search results
+function showResult(geomArray) {
+	var selectHtml = "";
+	var attributeNames = showAttributeName.split(",");
+	if (geomArray != null && geomArray.count() > 0) {
+		if(gazetteerStep == "searchStrassen") {
+			selectHtml += "<select onchange=\"zoomToStrassen('"+gazetteerStep+"',this.value);startGazetteer();\" id='selectResult" + gazetteerStep + "'>";
+			if(geomArray.count() > 1) {
+				selectHtml += "<option value=''>" + geomArray.count() + " Treffer:</option>";
+			var optionArray = [];
+			for (var i = 0 ; i < geomArray.count(); i ++) {
+				optionArray.push({
+					value: i,
+					title: geomArray.get(i).e.getElementValueByName(attributeNames[0])
+			optionArray.sort(sortFunction);
+			for (var i = 0; i < optionArray.length; i++) {
+				selectHtml += "<option value='" + optionArray[i].value + "'>";
+				selectHtml += geomArray.get(i).e.getElementValueByName(attributeNames[1]);
+				selectHtml += "</option>";
+		else {
+			selectHtml += "<select onchange=\"zoomToGemeinden('"+gazetteerStep+"', this.value);setStrassenField();\" id='selectResult" + gazetteerStep + "'>";
+					value: i,
+					title: geomArray.get(i).e.getElementValueByName(attributeNames[0]) +
+						" (" + geomArray.get(i).e.getElementValueByName(attributeNames[1]) + ")"
+				selectHtml += optionArray[i].title;
+		selectHtml += "</select>";
+		return selectHtml;
+	else {
+		return false;
+function showHausnummern(geomArray) {
+	var resultHtml = "";
+		var spanArray = [];
+			var zusatz = geomArray.get(i).e.getElementValueByName(attributeNames[1])?geomArray.get(i).e.getElementValueByName(attributeNames[1]) : "";
+			var hsnrTitle = geomArray.get(i).e.getElementValueByName(attributeNames[0]) + zusatz;
+			spanArray.push({
+				value: i,
+				title: parseInt(geomArray.get(i).e.getElementValueByName(attributeNames[0]), 10),
+				showTitle: hsnrTitle,
+				htmlOpen: "<span style='cursor:pointer;padding:2px;' " +
+						  "	onclick=\"setResult('click',"+i+");\" " +
+						  " onmouseover=\"setResult('over',"+i+");\"  " +
+						  " onmouseout=\"setResult('out',"+i+");\">",
+				htmlClose: "</span> "
+		spanArray.sort(sortHausnummernFunction);
+		spanArray.sort(sortIntFunction);
+		resultHtml += "Hausnummern:<br>";
+		if(geomArray.count() < 1) {
+			resultHtml += "Kein Ergebnis";
+		for (var i = 0 ; i < spanArray.length; i ++) {
+			resultHtml += spanArray[i].htmlOpen;
+			resultHtml += spanArray[i].showTitle;
+			resultHtml += spanArray[i].htmlClose;
+		return resultHtml;
+	else {
+		return false;
+function showResultPlz(geomArray) {
+	if (geomArray != null && geomArray.count() == 1) {
+		$("#gazetteerDOGOrtPlz").val(geomArray.get(0).e.getElementValueByName(attributeNames[0]));
+		mb_repaintScale(targetArray[0],geomArray.get(0).get(0).get(0).x,geomArray.get(0).get(0).get(0).y,"20000");
+		return true;
+	else {
+		return false;
+function zoomToGemeinden(gazetteerStep, index) {
+//	var searchResultIndex = parseInt(document.getElementById("selectResult"+gazetteerStep).selectedIndex)-1;
+	if (index === "") {
+		return;
+	var searchResultIndex = parseInt(index, 10);
+	var currentGeom = geomArrayGemeinden.get(searchResultIndex);
+	mb_repaintScale(targetArray[0],currentGeom.get(0).get(0).x,currentGeom.get(0).get(0).y,"20000");
+function zoomToStrassen(gazetteerStep, index) {
+		return;
+	var currentGeom = geomArrayStrassen.get(searchResultIndex);
+	mb_repaintScale(targetArray[0],currentGeom.get(0).get(0).x,currentGeom.get(0).get(0).y,"2000");
+* event -> {over || out || click}
+* geom -> commaseparated coordinates x1,y1,x2,y2 ...
+function setResult(event, index) {
+	var currentGeom = geomArrayHauskoordinaten.get(index);
+	if (event == "over") {
+		setMarker("mapframe1", currentGeom.get(0).get(0).x, currentGeom.get(0).get(0).y);
+	else if (event == "out"){
+		delMarker("mapframe1");
+	else if (event == "click"){
+		//setze zusätzlich einen permanenten Marker
+		setMarker("mapframe1", currentGeom.get(0).get(0).x, currentGeom.get(0).get(0).y, "permanent");
+	return true;
+function newSearch() {
+	if(geomArrayGemeinden !== null) {
+		if(geomArrayGemeinden.count()>0) {
+ 			geomArrayGemeinden.empty();
+	if(geomArrayStrassen !== null) {
+		if(geomArrayStrassen.count()>0) {
+ 			geomArrayStrassen.empty();
+	if(geomArrayHauskoordinaten !== null) {
+ 		if(geomArrayHauskoordinaten.count()>0) {
+ 			geomArrayHauskoordinaten.empty();
+	getHtmlForGazetteerForm();
+	delMarker();
+function setStrassenField () {
+	document.getElementById("gazetteerDOGStrasseField").innerHTML = '<input value="Straße" id="gazetteerDOGStrasse" class="gazetteerDOG" type="text" name="gazetteerDOGStrasse"><input type="submit" name="DOGGazetteerSearchButton" id="DOGGazetteerSearchButton" value="Suche">';
+	//$("#gazetteerDOGStrasse").css("color", "#808080");
+	$("#gazetteerDOGStrasse").focus(function () {
+		$("#gazetteerDOGStrasse").css("color", "#000000");
+function delMarker() {
+	var frameName;
+	if (arguments.length === 1) {
+		frameName = arguments[0];
+		if (frameName == "overview") {
+			if (currentMarker_overview !== null) {
+				currentMarker_overview.remove();
+		else if (frameName === "mapframe1") {
+			if (currentMarker_mapframe1 !== null) {
+				currentMarker_mapframe1.remove();
+		else if (frameName === "permanent") {
+			if (permanentMarker !== null) {
+				permanentMarker.remove();
+		return;
+function setMarker(frameName,x,y) {
+   var scale = mb_getScale(frameName);
+	 if (scale < 5001) {
+	 	var width  = 20;
+	 	var height = 20;
+	 if (scale >= 5001 && scale < 25001) {
+	 	var width  = 10;
+	 	var height = 10;
+	 if (scale > 25001) {
+	 	var width  = 5;
+	 	var height = 5;
+	if (arguments.length === 4 && arguments[3] === "permanent") {
+		permanentMarker = new Mapbender.Marker(new Mapbender.Point(x, y), Mapbender.modules.mapframe1, {
+			img: {
+				url: markerImage,
+				width: width,
+				height: height,
+				offset: new Mapbender.Point(-parseInt(width / 2, 10), -parseInt(height / 2, 10))
+	else {
+			currentMarker_overview = new Mapbender.Marker(new Mapbender.Point(x, y), Mapbender.modules.overview, {
+				img: {
+					url: "../img/redball.gif",
+					width: width,
+					height: height,
+		else {
+			currentMarker_mapframe1 = new Mapbender.Marker(new Mapbender.Point(x, y), Mapbender.modules.mapframe1, {
+				img: {
+					url: "../img/marker_fett.gif",
+					width: width,
+					height: height,
+mb_registerInitFunctions("getHtmlForGazetteerForm()");
Added: trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_server.php
--- trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_server.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_gazetteerDOGProfile_server.php	2012-09-26 13:05:41 UTC (rev 8496)
@@ -0,0 +1,176 @@
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../geoportal/class_gml2_DOG.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+function sendErrorMessage($data) {
+	$resObj = array();
+	$response = "error";
+	$resObj["errorMessage"] = $data;
+	$resObj["response"] = $response;
+	header("Content-Type:application/x-json");
+	$json = new Mapbender_JSON();
+	echo $json->encode($resObj);
+	die;
+$command = $_POST["command"];
+$pattern = "/[a-z]/i";
+if (!preg_match($pattern, $command)) {
+	sendErrorMessage("Invalid command " . htmlentities($command, ENT_QUOTES, CHARSET));
+switch ($command) {
+	case "getHtml" :
+		getHtmlForm();
+		break;
+	case "searchGemeinden" :
+		startSearch($command);
+		break;
+	case "searchStrassen" :
+		break;
+	case "searchHauskoordinaten" :
+		break;
+	case "searchPlz" :
+		break;
+	default :
+		getHtmlForm();
+		break;
+function getHtmlForm() {
+	$htmlFormString = "<form onsubmit='return startGazetteer()' name='gazetteerDOGForm' id='gazetteerDOGForm' method='post' action=''>" .
+					  "<div><b>Adresssuche:</b></div>" .
+					  "<div id='gazetteerDOGOrtField'>" .
+				        "<input onclick='this.value = \"\";gazetteerStep = \"searchGemeinden\";' class='gazetteerDOG' type='text' name='gazetteerDOGOrtPlz' id='gazetteerDOGOrtPlz' value='Ort oder PLZ'>" .
+						"<input type='submit' name='DOGGazetteerSearchButton' id='DOGGazetteerSearchButton' value='Suche'>" .
+				      "</div>" .
+					  "<div id='gazetteerDOGStrasseField'>" .
+				        "<input class='gazetteerDOG' disabled type='text' name='gazetteerDOGStrasse' id='gazetteerDOGStrasse' value='Straße'>" .
+				      "</div>" .
+					  #"<div>Hausnummer</div>" .
+	                  "<div>" .
+				        "<input type='button' name='DOGGazetteerNewButton' value='Neue Suche' onClick='newSearch();'>" .
+				      "</div>" .
+					  "<div id='gazetteerDOGHausnummer' style='display:none;color:#808080;'>Hausnummern:</div>" .
+				      "<div name='gazetteerProgressWheel' id='gazetteerProgressWheel' style='width:180px;'></div>" .
+					"</form>";
+	echo $htmlFormString;
+function startSearch($command) {
+	$wfsUrl = $_POST["wfsUrl"];
+	$pattern = "/^(http(s?):\/\/{1})((\w+\.){1,})\w{2,}(\/?)$/i";
+	$searchString = $_POST["searchFor"];
+	$pattern = "/[a-z0-9]/i";
+	if (!preg_match($pattern, $searchString)) {
+		sendErrorMessage("Invalid searchString " . htmlentities($searchString, ENT_QUOTES, CHARSET));
+	$searchFeaturetype = $_POST["searchFeaturetype"];
+	if (!preg_match($pattern, $searchFeaturetype)) {
+		sendErrorMessage("Invalid searchFeaturetype " . htmlentities($searchFeaturetype, ENT_QUOTES, CHARSET));
+	$admin = new administration();
+	$searchConditions = explode("|", $searchString);
+	$propertyConditions = "";
+	for ($i = 0; $i < count($searchConditions);$i++) {
+		$conditionParams = explode("=",$searchConditions[$i]);
+		if($command == "searchHauskoordinaten" || $command == "searchPlz") {
+			$propertyConditions .= '<PropertyIsEqualTo>
+                				<PropertyName>' . $conditionParams[0] . '</PropertyName>
+                    			<Literal>' . $conditionParams[1] . '</Literal>
+            					</PropertyIsEqualTo>';
+		else {
+			$propertyConditions .= '<PropertyIsLike wildCard="*" singleChar="?" escape="#">
+                    			<Literal>' . $conditionParams[1] . '*</Literal>
+            					</PropertyIsLike>';
+	if(count($searchConditions) > 1) {
+		$propertyConditionsString = "<And>" . $propertyConditions . "</And>";
+	else {
+		$propertyConditionsString = $propertyConditions;
+	$filter = '<wfs:GetFeature version="1.1.0" outputFormat="text/xml; subtype=gml/3.1.1"
+        xmlns:wfs="http://www.opengis.net/wfs">
+    <wfs:Query xmlns:app="http://www.deegree.org/app" typeName="' . $searchFeaturetype . '"
+            xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
+            xmlns:wfs="http://www.opengis.net/wfs" xmlns:dog="http://www.lverma.nrw.de/namespaces/dog"
+            xmlns:iso19112="http://www.opengis.net/iso19112">
+        <Filter xmlns="http://www.opengis.net/ogc">' . utf8_encode($propertyConditionsString) . '</Filter>
+    </wfs:Query>
+</wfs:GetFeature>';
+	$filter = $admin->char_decode(stripslashes($filter));
+	$connection = new connector();
+	$connection->set("httpType", "post");
+	$connection->set("httpContentType", "xml");
+	$connection->set("httpPostData", $filter);
+	$data = $connection->load($wfsUrl);
+	if ($data === null) die('{}');
+	$gml = new gml2();
+	$geoJson = $gml->parseXML($data);
+	header("Content-type:application/json; charset=utf-8");
+	echo $geoJson;
+	#$e = new mb_exception($filter);
+	#$wfsUrl = $wfsUrl . "/services?REQUEST=GetFeature&SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=5&TYPENAME=" . $featuretypeGemeinden . "&filter="; #REQUEST=GetFeature&SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=5&TYPENAME=" . $featuretypeGemeinden . "&
+	//$wfsUrl = $wfsUrl . "/services&filter=";
+	//$req = urldecode($wfsUrl).urlencode($admin->char_decode(stripslashes($filter)));
+	//$e = new mb_exception($req);
+	//$mygml = new gml2();
+	#$auth = array();
+	#$auth['username'] = $authUserName;
+	#$auth['password'] = $authUserPassword;
+	#$auth['auth_type'] = "basic";
+	#$mygml->parseFile($req);
+	#print_r($mygml); die;
+	#header("Content-type:application/x-json; charset=utf-8");
+	#echo $mygml->toGeoJSON();
More information about the Mapbender_commits mailing list
