[Mapbender-commits] r8497 - in trunk/mapbender/http: geoportal img
    svn_mapbender at osgeo.org
    Wed Sep 26 07:09:58 PDT 2012
Author: armin11
Date: 2012-09-26 07:09:57 -0700 (Wed, 26 Sep 2012)
New Revision: 8497
Added:
   trunk/mapbender/http/geoportal/class_gml2_DOG.php
   trunk/mapbender/http/geoportal/dog_client.sql
   trunk/mapbender/http/geoportal/marker_fett.gif
   trunk/mapbender/http/img/marker_fett.gif
further DOG modules from geoportal.rlp
Added: trunk/mapbender/http/geoportal/class_gml2_DOG.php
--- trunk/mapbender/http/geoportal/class_gml2_DOG.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/class_gml2_DOG.php	2012-09-26 14:09:57 UTC (rev 8497)
@@ -0,0 +1,1026 @@
+<?php
+# $Id: class_gml2.php 3099 2008-10-02 15:29:23Z nimix $
+# http://www.mapbender.org/index.php/class_gml2.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+class gml2 {
+	var $geomtype_point = 'Point';
+	var $geomtype_polygon = 'Polygon';
+	var $geomtype_line = 'LineString';
+	var $geomtype_multipolygon = 'MultiPolygon';
+	var $geomtype_multiline = 'MultiLine';
+	var $geometries = array();
+	var $member = -1;
+	var $geomtype = array();
+	var $keys = array();
+	var $values = array();
+	var $geometry = array();
+	var $bbox = array();
+	var $doc;
+	var $geomFeaturetypeElement = null;
+	function gml2(){
+		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
+	function getGml($req){
+		$x = new connector($req);
+		return $x->file;
+	function parseFile($req){
+		#$data = implode("",file($req));
+		$data = $x->file;
+		$data = $this->removeWhiteSpace($data);
+		$this->parseXML($data);
+		#$e = new mb_exception("data = ".$data);
+	function parseXML($data) {
+		if (func_num_args() == 2) {
+			$this->geomFeaturetypeElement = func_get_arg(1);
+		$this->doc = $this->removeWhiteSpace($data);
+		return $this->toGeoJSON();
+	function removeWhiteSpace ($string) {
+		return preg_replace("/\>(\s)+\</", "><", trim($string));
+	function sepNameSpace($s){
+		$c = mb_strpos($s,":");
+		if($c>0){
+			return mb_substr($s,$c+1);
+		else{
+			return $s;
+	function toGeoJSON () {
+		$gmlDoc = new SimpleXMLElement($this->doc);
+		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$gmlDoc->registerXPathNamespace('wfs', 'http://www.opengis.net/wfs');
+		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		// build feature collection
+		$featureCollection = new FeatureCollection();
+		// segments of the featzreCollection
+		$gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
+		if(count($gmlFeatureMembers)>0){
+			$cnt=0;
+			foreach ($gmlFeatureMembers as $gmlFeatureMember) {
+				$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
+				$feature = new Feature();
+				if ($this->geomFeaturetypeElement != null) {
+					$feature->parse($featureMember_dom, $this->geomFeaturetypeElement);
+				else {
+					$feature->parse($featureMember_dom);
+				if (isset($feature->geometry)) {
+					$featureCollection->addFeature($feature);
+				$cnt++;
+			return $featureCollection->toGeoJSON();
+		else{
+			return "{}";
+	 * Exports the file to SHP.
+	 * @param string $filenamePrefix the filename without an ending like .shp
+	function toShape ($filenamePrefix) {
+		$unique = TMPDIR . "/" . $filenamePrefix;
+		$fShape = $unique.".shp";
+		$fGml = $unique.".gml";
+//		$pathOgr = '/appserver/postgresql/templates/postgresql824/bin/ogr2ogr';
+		$pathOgr = '/usr/bin/ogr2ogr';
+//		$pathOgr = OGR2OGR_PATH;
+		$w = $this->toFile($fGml);
+		// - get EPSC-Code from GML-File--
+		$data = file_get_contents($fGml);//
+		$gmlDoc = new SimpleXMLElement($data);
+		$gmlBboxes = $gmlDoc->xpath("//gml:Box");	//<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
+		if(count($gmlBboxes)>0){
+			$bbox_str = $gmlBboxes[0]['srsName'];
+			$pos_raute = strpos($bbox_str, '#');
+			$epsg = substr($bbox_str, $pos_raute+1);
+		} else {
+			$e = new mb_exception("class_gml2.php:toShape() => no EPSG in GML(" . $fGml . ").");
+		$str_ogr = $pathOgr.' -a_srs EPSG:'.$epsg.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+		$e = new mb_exception("ogr-Befehl:".$str_ogr);
+ 		$exec = $pathOgr.' -a_srs EPSG:'.$epsg.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+		 * @security_patch exec done
+		 * Added escapeshellcmd()
+ 		//$exec = $pathOgr.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+ 		exec(escapeshellcmd($exec));
+ 		$exec = 'zip -j '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml '.$unique.'.prj ';
+		$exec = 'rm -f '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml '.$unique.'.prj ';
+		$exec = 'chmod 777 '.$unique.'.*';
+		//echo "<a href='../tmp/".$unique.".zip'>Download ".$prefix."<a>";
+	 * Writes a file containing the GML.
+	 * @param string $path the path to the file.
+	 * @return bool true if the file could be saved; else false.
+	function toFile ($file) {
+		$handle = fopen($file, "w");
+		if (!$handle) {
+			$e = new mb_exception("class_gml2.php: Filehandler error (" . $file . ").");
+			return false;
+		if (!fwrite($handle,$this->__toString())) {
+			$e = new mb_exception("class_gml2.php: Could not write file (" . $file . ").");
+			fclose($handle);
+			return false;
+		fclose($handle);
+		return true;
+	function __toString () {
+		return $this->doc;
+	 * @deprecated
+	function parsegml($req){
+		$this->parse_xml($x->file);
+	 * @deprecated
+	function parse_xml($data){
+		$this->doc = $data;
+		$section = false;
+		$geom = false;
+		$boundedBy = false;
+		$coordinates = false;
+		$el = -1;
+		$parser = xml_parser_create(CHARSET);
+		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+		xml_parse_into_struct($parser,$data,$values,$tags);
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		xml_parser_free($parser);
+		foreach ($values as $element) {
+			#$e = new mb_exception($element[tag]);
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
+				$boundedBy = true;
+			if ($boundedBy) {
+				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("box")){
+					$epsgAttr = "";
+					if(isset($element['attributes'])){
+						$epsgAttr = isset($element['attributes']['srsName']) ? $element['attributes']['srsName'] : "";
+					if(strstr($epsgAttr,'#') !== false){
+						// http://www.opengis.net/gml/srs/epsg.xml#4326
+						$parts = explode('#',$epsgAttr);
+						$epsg == isset($parts[1]) ? $parts[1] : "";
+					}else if (strstr($epsgAttr,':') !== false){
+						// EPSG:31466
+						// urn:ogc:def:crs:EPSG:6.5:4326
+						$parts = explode(':',$epsgAttr);
+						$parts = array_reverse($parts);
+						 if(isset($parts[0])){
+						 	$epsg =  $parts[0];
+						}else{
+							$epsg = "";
+						new mb_exception(print_r(isset($parts[0]),true));
+						new mb_exception(print_r($epsg,true));
+					}else {
+						$epsg="";
+					$this->epsg = $epsg;
+				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
+					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
+					$boundedBy=false;
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
+				$this->member++;
+				$this->keys[$this->member] = array();
+				$this->value[$this->member] = array();
+				$this->geometry[$this->member] = array();
+				$section = true;
+				$cnt_geom = 0;
+			if($section == true){
+				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
+					$geom = true;
+					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
+				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
+					$cnt_geom++;
+					$geom = false;
+				if($geom == true){
+					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
+						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$coordinates = true;
+						// XXX: Increment counter to get all geometries of a feature member,
+						// comment it out to only show first geometry of featuremember
+						$cnt_geom++;
+					else if (!$coordinates && trim($element[value])) {
+						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$tmp_array = explode(",", $coords);
+						if (count($tmp_array > 1)) {
+							$this->geometry[$this->member][$cnt_geom] =  $coords;
+							$cnt_geom++;
+				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
+					$section = false;
+					$el = -1;
+				else{
+					$el++;
+					$this->values[$this->member][$el] = $element[value];
+					$this->keys[$this->member][$el] = $element[tag];
+	 * @deprecated
+	function getMemberCount(){
+		return ($this->member+1);
+	 * @deprecated
+	function getValueBySeparatedKey($memberCount,$keyName){
+		for($i=0; $i<count($this->keys[$memberCount]); $i++){
+			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
+				return $this->values[$memberCount][$i];
+	 * @deprecated
+	function getValueByKey($memberCount,$keyName){
+			if($this->keys[$memberCount][$i] == $keyName){
+	 * @deprecated
+	function getXfromMemberAsString($memberCount,$geomCount){
+		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
+		$x = array();
+		for($i=0; $i<(count($t)-1); $i=$i+2){
+			array_push($x,$t[$i]);
+		return implode(",",$x);
+	 * @deprecated
+	function getYfromMemberAsString($memberCount,$geomCount){
+		$y = array();
+		for($i=1; $i<=(count($t)-1); $i=$i+2){
+			array_push($y,$t[$i]);
+		return implode(",",$y);
+	 * @deprecated
+	function getGeometriesFromMember($memberCount){
+		return $this->geometry[$memberCount];
+	 * @deprecated
+	function getGeometryTypeFromMember($memberCount){
+		return 	$this->geomtype[$memberCount];
+	 * @deprecated
+	function exportGeometriesToJS ($isInFrame) {
+		$prefix = "";
+		if ($isInFrame == true) {
+			$prefix = "parent.";
+		$js = "";
+		$js .= "var geom = new ".$prefix."GeometryArray();\n";
+		for ($i=0; $i<count($this->geometry); $i++) {
+			$js .= $this->exportMemberToJS($i, $isInFrame);
+			$js .= "geom.addCopy(q);\n";
+		return $js;
+	 * @deprecated
+	function exportMemberToJS ($i, $isInFrame) {
+		$prefix = "";
+		$js = "";
+		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
+			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
+			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
+			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
+		else {
+			$e = new mb_notice("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."' or no geometry existing");
+			return "";
+		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
+		for ($j=0; $j<count($this->geometry[$i]); $j++) {
+			$js .= "q.addGeometry(current_geomtype);\n";
+			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
+			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
+			for ($k=0; $k<count($x_array); $k++) {
+				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
+				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
+			$js .= "q.get(-1).close();\n";
+//		$js .= "alert(q);\n";
+		return $js;
+class FeatureCollection {
+	var $type = "FeatureCollection";
+	var $featureArray = array();
+	public function __construct() {
+	public function addFeature ($aFeature) {
+		array_push($this->featureArray, $aFeature);
+	public function toGeoJSON () {
+		$str = "";
+		$len = count($this->featureArray);
+		if ($len > 0) {
+			$str .= "{\"type\": \"FeatureCollection\", \"features\": [";
+			for ($i=0; $i < $len; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= $this->featureArray[$i]->toGeoJSON();
+			$str .= "]}";
+		return $str;
+class Feature {
+	var $type = "Feature";
+	var $fid;
+	var $geometry = false;
+	var $properties = array();
+		list($ns,$FeaturePropertyName) = split(":",$s);
+		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
+		return $nodeName;
+	 * Parses the feature segment of a GML and stores the geometry in the
+	 * $geometry variable of the class.
+	 * Example of a feature segment of a GML.
+	 * 	<gml:featureMember>
+	 * 		<ms:ROUTE fid="ROUTE.228168">
+	 * 			<gml:boundedBy>
+	 * 				<gml:Box srsName="EPSG:31466">
+	 * 					<gml:coordinates>2557381.0,5562371.1 2557653.7,5562526.0</gml:coordinates>
+	 * 				</gml:Box>
+	 * 			</gml:boundedBy>
+	 * 			<ms:geometry>
+	 * 				<gml:LineString>
+	 * 						2557380.97,5562526 2557390.96,
+	 * 						5562523.22 2557404.03,5562518.2 2557422.31,
+	 * 						5562512 2557437.16,5562508.37 2557441.79,
+	 * 						5562507.49 2557454.31,5562505.1 2557464.27,
+	 * 						5562503.97 2557473.24,5562502.97 2557491.67,
+	 * 						5562502.12 2557505.65,5562502.43 2557513.78,
+	 * 						5562501.12 2557520.89,5562498.79 2557528.5,
+	 * 						5562495.07 2557538.9,5562488.91 2557549.5,
+	 * 						5562483.83 2557558.55,5562476.61 2557569.07,
+	 * 						5562469.82 2557576.61,5562462.72 2557582.75,
+	 * 						5562457.92 2557588.57,5562452.56 2557590.38,
+	 * 						5562449.69 2557593.57,5562445.07 2557596.17,
+	 * 						5562441.31 2557601.71,5562433.93 2557612.97,
+	 * 						5562421.03 2557626,5562405.33 2557639.66,
+	 * 						5562389.75 2557653.69,5562371.12
+	 * 					</gml:coordinates>
+	 * 				</gml:LineString>
+	 * 			</ms:geometry>
+	 * 			<code>354</code>
+	 * 			<Verkehr>0</Verkehr>
+	 * 			<rlp>t</rlp>
+	 * 		</ms:ROUTE>
+	 * 	</gml:featureMember>
+	 * @return void
+	 * @param $domNode DOMNodeObject the feature tag of the GML
+	 * 								(<gml:featureMember> in the above example)
+	public function parse($domNode) {
+		$currentSibling = $domNode->firstChild;
+		$this->fid = $currentSibling->getAttribute("fid");
+		$currentSibling = $currentSibling->firstChild;
+		while ($currentSibling) {
+			$name = $currentSibling->nodeName;
+			$value = $currentSibling->nodeValue;
+			$namespace = $this->sepNameSpace($name);
+			$ns = $namespace['ns'];
+			$columnName = $namespace['value'];
+			$isGeomColumn = ($this->geomFeaturetypeElement == null || $columnName == $this->geomFeaturetypeElement);
+			// check if this node is a geometry node.
+			// however, even if it is a property node,
+			// it has a child node, the text node!
+			// So we might need to do something more
+			// sophisticated here...
+			if ($currentSibling->hasChildNodes() && $isGeomColumn){
+				$geomNode = $currentSibling->firstChild;
+					$geomType = $geomNode->nodeName;
+					switch ($geomType) {
+						case "gml:Polygon" :
+							$this->geometry = new GMLPolygon();
+							$this->geometry->parsePolygon($geomNode);
+							break;
+						case "gml:LineString" :
+							$this->geometry = new GMLLine();
+							$this->geometry->parseLine($geomNode);
+							break;
+						case "gml:Point" :
+							$this->geometry = new GMLPoint();
+							$this->geometry->parsePoint($geomNode);
+							break;
+						case "gml:MultiLineString" :
+							$this->geometry = new GMLMultiLine();
+							$this->geometry->parseMultiLine($geomNode);
+							break;
+						case "gml:MultiPolygon" :
+							$this->geometry = new GMLMultiPolygon();
+							$this->geometry->parseMultiPolygon($geomNode);
+							break;
+						case "gml:Envelope" :
+							$this->geometry = new GMLEnvelope();
+							$this->geometry->parseEnvelope($geomNode);
+							break;
+						default:
+							$this->properties[$columnName] = $value;
+							break;
+			else {
+			$currentSibling = $currentSibling->nextSibling;
+		$str = "";
+		$str .= "{\"type\":\"Feature\", \"id\":\"".$this->fid."\", \"geometry\": ";
+		if ($this->geometry) {
+			$str .= $this->geometry->toGeoJSON();
+		else {
+			$str .= "\"\"";
+		$prop = array();
+		$str .= ", \"properties\": ";
+		$cnt = 0;
+		foreach ($this->properties as $key => $value) {
+				$prop[$key] = $value;
+				$cnt ++;
+		$json = new Mapbender_JSON();
+		$str .= $json->encode($prop);
+		$str .= "}";
+		return $str;
+class GMLLine {
+	var $pointArray = array();
+	public function parseLine ($domNode) {
+			foreach(explode(' ',$currentSibling->nodeValue) as $cords){
+				list($x,$y,$z) = explode(',',$cords);
+				$this->addPoint($x, $y);
+	protected function addPoint ($x, $y) {
+		array_push($this->pointArray, array("x" => $x, "y" => $y));
+		$numberOfPoints = count($this->pointArray);
+		$str = "";
+		if ($numberOfPoints > 0) {
+			$str .= "{\"type\": \"LineString\", \"coordinates\":[";
+			for ($i=0; $i < $numberOfPoints; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLLine: toGeoJSON: this point is null.");
+		return $str;
+class GMLPoint {
+	var $point;
+// in explode " " instead of "," for DOG (Deutschland Online Gazateer)
+	public function parsePoint ($domNode) {
+			list($x, $y, $z) = explode(" ", $currentSibling->nodeValue);
+			$this->setPoint($x, $y);
+	protected function setPoint ($x, $y) {
+#		echo "x: " . $x . " y: " . $y . "\n";
+		$this->point = array("x" => $x, "y" => $y);
+		$str = "";
+		if ($this->point) {
+			$str .= "{\"type\": \"Point\", \"coordinates\":";
+			$str .= "[".$this->point["x"].",".$this->point["y"]."]";
+			$str .= "}";
+		else {
+			$e = new mb_exception("GMLPoint: toGeoJSON: this point is null.");
+		return $str;
+class GMLPolygon {
+	var $innerRingArray = array();
+	public function parsePolygon ($domNode) {
+		$simpleXMLNode = simplexml_import_dom($domNode);
+		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		$allCoords = $simpleXMLNode->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+		$cnt=0;
+		foreach ($allCoords as $Coords) {
+			$coordsDom = dom_import_simplexml($Coords);
+//			$name = $coordsDom->nodeName;
+//			$value = $coordsDom->nodeValue;
+//			echo "===> name: ".$name. ", Value: ".$value."<br>";
+			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
+				list($x,$y,$z) = explode(',',$pointCoords);
+			$cnt++;
+		$innerRingNodeArray = $simpleXMLNode->xpath("gml:innerBoundaryIs/gml:LinearRing");
+		if ($innerRingNodeArray) {
+			$ringCount = 0;
+			foreach ($innerRingNodeArray as $ringNode) {
+				$coordinates = $ringNode->xpath("gml:coordinates");
+				foreach ($coordinates as $coordinate) {
+					$coordsDom = dom_import_simplexml($coordinate);
+						$this->addPointToRing($ringCount, $x, $y);
+				$ringCount++;
+	protected function addPointToRing ($i, $x, $y) {
+		if (count($this->innerRingArray) <= $i) {
+			array_push($this->innerRingArray, array());
+		$index = count($this->innerRingArray);
+		$currentIndex = ($i < $index ? $i : $index);
+		array_push($this->innerRingArray[$currentIndex], array("x" => $x, "y" => $y));
+		$str = "";
+			$str .= "{\"type\": \"Polygon\", \"coordinates\":[[";
+				if ($i > 0) {
+					$str .= ",";
+			$str .= "]";
+			for ($i=0; $i < count($this->innerRingArray); $i++) {
+				$str .= ",[";
+				for ($j=0; $j < count($this->innerRingArray[$i]); $j++) {
+					if ($j > 0) {
+						$str .= ",";
+					$str .= "[".$this->innerRingArray[$i][$j]["x"].",".$this->innerRingArray[$i][$j]["y"]."]";
+				$str .= "]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLPolygon: toGeoJSON: this point is null.");
+		return $str;
+class GMLEnvelope extends GMLPolygon{
+/*      <gml:Envelope>
+         <gml:lowerCorner>42.943 -71.032</gml:lowerCorner>
+         <gml:upperCorner>43.039 -69.856</gml:upperCorner>
+      </gml:Envelope>
+	public function parseEnvelope ($domNode) {
+		$corner1 = $domNode->firstChild;
+		$corner2 = $corner1->nextSibling;
+		list($y1,$x1) = explode(' ',$corner1->nodeValue);
+		list($y2,$x2) = explode(' ',$corner2->nodeValue);
+		$this->addPoint($x1, $y1);
+		$this->addPoint($x1, $y2);
+		$this->addPoint($x2, $y2);
+		$this->addPoint($x2, $y1);
+class GMLMultiLine {
+	var $lineArray = array();
+	public function parseMultiLine ($domNode) {
+		$allCoords = $simpleXMLNode->xpath("gml:lineStringMember/gml:LineString/gml:coordinates");
+		$cnt=0;
+			$this->lineArray[$cnt] = array();
+				$this->addPoint($x, $y, $cnt);
+			$cnt++;
+	protected function addPoint ($x, $y, $i) {
+		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
+		$numberlineArray = count($this->lineArray);
+		$str = "";
+		if ($numberlineArray > 0) {
+			$str .= "{\"type\": \"MultiLineString\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberlineArray; $cnt++){
+				if ($cnt > 0) {
+						$str .= ",";
+					$str .="[";
+				for ($i=0; $i < count($this->lineArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->lineArray[$cnt][$i]["x"].",".$this->lineArray[$cnt][$i]["y"]."]";
+				$str .="]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiLine: toGeoJSON: this multiLine is null.");
+		return $str;
+class GMLMultiPolygon {
+	var $polygonArray = array();
+	protected function addPointToRing ($i, $j, $x, $y) {
+		if (count($this->innerRingArray[$i]) <= $j) {
+			array_push($this->innerRingArray[$i], array());
+		array_push($this->innerRingArray[$i][$j], array("x" => $x, "y" => $y));
+	public function parseMultiPolygon ($domNode) {
+//		echo $domNode->nodeName."<br>";
+		$allPolygons = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon");
+		$cnt=0;
+		foreach ($allPolygons as $polygon) {
+			$allCoords = $polygon->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+			$this->polygonArray[$cnt] = array();
+				foreach (explode(' ',$coordsDom->nodeValue) as $pointCoords) {
+			$this->innerRingArray[$cnt] = array();
+			$innerRingNodeArray = $polygon->xpath("gml:innerBoundaryIs");
+				$ringCount = 0;
+					$currentRingNode = $ringNode->xpath("gml:LinearRing");
+					foreach ($currentRingNode as $node) {
+						$coordinates = $node->xpath("gml:coordinates");
+								$this->addPointToRing($cnt, $ringCount, $x, $y);
+						$ringCount++;
+			$cnt++;
+			new mb_notice("create multipolygon " . serialize($this->innerRingArray));
+		array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
+		$numberPolygonArray = count($this->polygonArray);
+		$str = "";
+		if ($numberPolygonArray > 0) {
+			$str .= "{\"type\": \"MultiPolygon\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberPolygonArray; $cnt++){
+				if ($cnt > 0) {
+					$str .= ",";
+				$str .= "[";
+				$str .= "[";
+				for ($i=0; $i < count($this->polygonArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->polygonArray[$cnt][$i]["x"].",".$this->polygonArray[$cnt][$i]["y"]."]";
+				$str .= "]";
+				for ($i=0; $i < count($this->innerRingArray[$cnt]); $i++) {
+					$str .= ",[";
+					for ($j=0; $j < count($this->innerRingArray[$cnt][$i]); $j++) {
+						if ($j > 0) {
+							$str .= ",";
+						$str .= "[".$this->innerRingArray[$cnt][$i][$j]["x"].",".$this->innerRingArray[$cnt][$i][$j]["y"]."]";
+					$str .= "]";
+				$str .= "]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiPolygon: toGeoJSON: this multiLine is null.");
+		return $str;
Added: trunk/mapbender/http/geoportal/dog_client.sql
--- trunk/mapbender/http/geoportal/dog_client.sql	                        (rev 0)
+++ trunk/mapbender/http/geoportal/dog_client.sql	2012-09-26 14:09:57 UTC (rev 8497)
@@ -0,0 +1,20 @@
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','gazetteerDOGProfile',2,1,'a gazetteer based on the DOG profile','Adresssuche','div','','',10,10,225,235,1000,'visibility:visible;padding-top:8px;overflow:auto;','','div','../geoportal/mod_gazetteerDOGProfile_client.php','','mapframe1,overview','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'authUserName', '******', 'User name for authentication for WFS' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'authUserPassword', '******', 'User password for authentication for WFS' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'featuretypeGemeinden', 'dog:Gemeinden', 'featuretype for search for gemeinden' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'featuretypeHauskoordinaten', 'dog:Hauskoordinaten', 'featuretype for search for Hauskoordinaten' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'featuretypePLZ', 'dog:Postleitzahlgebiete', 'featuretype for search for PLZ' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'featuretypeStrassen', 'dog:Strassen', 'featuretype for search for strassen' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'gemeindenAttributes', 'geographicIdentifier,parent,gemeindeschluessel', 'needed attributes of featuretype Gemeinden' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'hauskoordinatenAttributes', 'hausnummer,hausnummernzusatz', 'needed attributes of featuretype Hauskoordinaten' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'markerImage', '../geoportal/marker_fett.gif', 'path to the marker image' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'noResultMsg', 'Kein Ergebnis gefunden. Bitte Suchanfrage ändern.', 'message which is shown if there is no search result' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'plzAttributes', 'geographicIdentifier', 'needed attributes of featuretype PLZ' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'searchAttrGemeinden', 'iso19112:geographicIdentifier', 'search attribute for featuretype Gemeinden' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'searchAttrHauskoordinaten', 'iso19112:parent', 'search attribute for featuretype Hauskoordinaten' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'searchAttrPLZ', 'iso19112:geographicIdentifier', 'search attribute for featuretype PLZ' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'searchAttrStrassen', 'dog:strassenschluessel,dog:strassenname', 'search attributes for featuretype Strassen' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'serverErrorMsg', 'Serverfehler, bitte versuchen Sie es erneut oder wenden Sie sich an (Servicestelle eintragen).', 'message which is shown if there is a server error' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'strassenAttributes', 'geographicIdentifier,strassenname', 'needed attributes of featuretype strassen' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<gui_id>', 'gazetteerDOGProfile', 'wfsUrl', 'http://geodaten.service24.rlp.de/hauskoordinaten/services', 'url to WFS for search' ,'var');
Added: trunk/mapbender/http/geoportal/marker_fett.gif
(Binary files differ)
Property changes on: trunk/mapbender/http/geoportal/marker_fett.gif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/img/marker_fett.gif
Property changes on: trunk/mapbender/http/img/marker_fett.gif
More information about the Mapbender_commits
