[Mapbender-commits] r8694 - trunk/mapbender/http/print
svn_mapbender at osgeo.org
Thu Aug 22 23:15:55 PDT 2013
Author: armin11
Date: 2013-08-22 23:15:55 -0700 (Thu, 22 Aug 2013)
New Revision: 8694
Added:
trunk/mapbender/http/print/Hochformat_A3.json
trunk/mapbender/http/print/Hochformat_A3.odg
trunk/mapbender/http/print/Hochformat_A3.pdf
trunk/mapbender/http/print/Hochformat_A4.json
trunk/mapbender/http/print/Hochformat_A4.odg
trunk/mapbender/http/print/Hochformat_A4.pdf
trunk/mapbender/http/print/Hochformat_A4_Legende.json
trunk/mapbender/http/print/Querformat_A3.json
trunk/mapbender/http/print/Querformat_A3.odg
trunk/mapbender/http/print/Querformat_A3.pdf
trunk/mapbender/http/print/Querformat_A4.json
trunk/mapbender/http/print/Querformat_A4.odg
trunk/mapbender/http/print/Querformat_A4.pdf
trunk/mapbender/http/print/Querformat_A4_Legende.json
Some more print templates for geoportals
Added: trunk/mapbender/http/print/Hochformat_A3.json
--- trunk/mapbender/http/print/Hochformat_A3.json (rev 0)
+++ trunk/mapbender/http/print/Hochformat_A3.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,167 @@
+ "type" : "templatePDF",
+ "orientation" : "P",
+ "units" : "mm",
+ "format" : "a3",
+ "controls" : [
+ "id" : "title",
+ "label" : "Titel",
+ "type" : "text",
+ "size" : 18,
+ "maxCharacter" : 20,
+ "pageElementsLink" : {
+ "titel" : "value"
+ "id" : "dpi",
+ "label" : "Auflösung",
+ "type" : "select",
+ "size" : 20,
+ "karte" : "res_dpi"
+ "options" : [
+ "value" : "72",
+ "label" : "72 dpi"
+ "value" : "144",
+ "label" : "144 dpi"
+ "id" : "comment1",
+ "label" : "Notiz",
+ "type" : "textarea",
+ "maxCharacter" : 250,
+ "size" : 5,
+ "kommentar1" : "value"
+ "id" : "angle",
+ "label" : "Drehwinkel",
+ "type" : "text",
+ "nordpfeil" : "angle",
+ "karte" : "angle",
+ "minikarte" : "angle"
+ "id" : "scale",
+ "label" : "Maßstab",
+ "type" : "text",
+ "scale" : "value"
+ "id" : "coordinates",
+ "type" : "hidden"
+ "pages" : [
+ "tpl" : "Hochformat_A3.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 20.2,
+ "y_ul" : 27.3,
+ "width" : 262,
+ "height" : 304,
+ "coords" : 1,
+ "coords_font_family" : "Arial",
+ "coords_font_size" : 11
+ "minikarte" : {
+ "type" : "overview",
+ "res_dpi" : 72,
+ "x_ul" : 19.8,
+ "y_ul" : 26.6,
+ "width" : 50,
+ "height" : 50
+ "scale" : {
+ "type" : "text",
+ "x_ul" : 150.0,
+ "y_ul" : 349.0,
+ "font_family" : "Arial",
+ "font_size" : 14,
+ "value" : "scale"
+ "date" : {
+ "type" : "text",
+ "x_ul" : 50.5,
+ "y_ul" : 349.0,
+ "font_size" : 14,
+ "value" : "date"
+ "nordpfeil" : {
+ "type" : "image",
+ "x_ul" : 265,
+ "y_ul" : 356,
+ "width" : 35,
+ "height" : 35,
+ "angle" : 0,
+ "filename" : "./img/northarrow.png"
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 145,
+ "y_ul" : 18,
+ "font_size" : 18
+ "messung" : {
+ "type" : "measure",
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "stroke_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "kommentar1" : {
+ "type" : "para",
+ "x_ul" : 20.1,
+ "y_ul" : 365.2,
+ "font_size" : 11,
+ "width" : 215,
+ "height" : 5,
+ "align" : "L",
+ "border" : 0,
+ "fill" :0,
+ "border_width" : 0.3
Added: trunk/mapbender/http/print/Hochformat_A3.odg
(Binary files differ)
Property changes on: trunk/mapbender/http/print/Hochformat_A3.odg
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/mapbender/http/print/Hochformat_A3.pdf
Property changes on: trunk/mapbender/http/print/Hochformat_A3.pdf
Added: trunk/mapbender/http/print/Hochformat_A4.json
--- trunk/mapbender/http/print/Hochformat_A4.json (rev 0)
+++ trunk/mapbender/http/print/Hochformat_A4.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,167 @@
+ "units" : "mm",
+ "format" : "a4",
+ "controls" : [
+ "id" : "title",
+ "type" : "text",
+ "size" : 18,
+ "titel" : "value"
+ "id" : "dpi",
+ "size" : 23,
+ "options" : [
+ "value" : "72",
+ "value" : "144",
+ "size" : 10,
+ "id" : "angle",
+ "type" : "text",
+ "id" : "scale",
+ "type" : "text",
+ "scale" : "value"
+ "type" : "hidden"
+ "pages" : [
+ "tpl" : "Hochformat_A4.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 16.2,
+ "y_ul" : 22.5,
+ "width" : 180,
+ "height" : 212,
+ "coords" : 1,
+ "coords_font_size" : 8
+ "minikarte" : {
+ "res_dpi" : 72,
+ "x_ul" : 15.6,
+ "y_ul" : 21.8,
+ "width" : 40,
+ "height" : 40
+ "scale" : {
+ "type" : "text",
+ "x_ul" : 106.0,
+ "y_ul" : 246.0,
+ "font_size" : 11,
+ "value" : "scale"
+ "date" : {
+ "type" : "text",
+ "x_ul" : 35.5,
+ "y_ul" : 246.0,
+ "font_size" : 11,
+ "value" : "date"
+ "nordpfeil" : {
+ "type" : "image",
+ "x_ul" : 184,
+ "y_ul" : 254,
+ "width" : 25,
+ "height" : 25,
+ "angle" : 0,
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 110,
+ "y_ul" : 17,
+ "font_size" : 16
+ "messung" : {
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "kommentar1" : {
+ "type" : "para",
+ "x_ul" : 16.1,
+ "y_ul" : 255.2,
+ "font_size" : 11,
+ "width" : 145,
+ "height" : 5,
+ "align" : "L",
+ "border" : 0,
+ "fill" : 0,
Added: trunk/mapbender/http/print/Hochformat_A4.odg
Property changes on: trunk/mapbender/http/print/Hochformat_A4.odg
Added: trunk/mapbender/http/print/Hochformat_A4.pdf
Property changes on: trunk/mapbender/http/print/Hochformat_A4.pdf
Added: trunk/mapbender/http/print/Hochformat_A4_Legende.json
--- trunk/mapbender/http/print/Hochformat_A4_Legende.json (rev 0)
+++ trunk/mapbender/http/print/Hochformat_A4_Legende.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,114 @@
+ "units" : "mm",
+ "format" : "a4",
+ "controls" : [
+ "id" : "title",
+ "type" : "text",
+ "size" : 20,
+ "titel" : "value"
+ "id" : "dpi",
+ "label" : "DPI",
+ "size" : 20,
+ "options" : [
+ "value" : "72",
+ "value" : "144",
+ "id" : "angle",
+ "label" : "Winkel",
+ "type" : "text",
+ "type" : "hidden"
+ "id" : "scale",
+ "type" : "text",
+ "scale" : "value"
+ "pages" : [
+ "tpl" : "Hochformat_A4_Legende.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 10.8,
+ "y_ul" : 20.6,
+ "width" : 188,
+ "height" : 169.3,
+ "coords" : 1,
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 10.8,
+ "y_ul" : 12,
+ "font_size" : 15
+ "messung" : {
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "legende" : {
+ "type" : "legend",
+ "x_ul" : 10,
+ "y_ul" : 205,
+ "width" : 200,
+ "height" : 10,
+ "font_size" : 9,
+ "scale" : 0.5
Added: trunk/mapbender/http/print/Querformat_A3.json
--- trunk/mapbender/http/print/Querformat_A3.json (rev 0)
+++ trunk/mapbender/http/print/Querformat_A3.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,167 @@
+ "orientation" : "L",
+ "units" : "mm",
+ "format" : "a3",
+ "controls" : [
+ "id" : "title",
+ "type" : "text",
+ "size" : 18,
+ "titel" : "value"
+ "id" : "dpi",
+ "size" : 20,
+ "options" : [
+ "value" : "72",
+ "value" : "144",
+ "size" : 5,
+ "id" : "angle",
+ "type" : "text",
+ "id" : "scale",
+ "type" : "text",
+ "scale" : "value"
+ "type" : "hidden"
+ "pages" : [
+ "tpl" : "Querformat_A3.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 16.5,
+ "y_ul" : 29.5,
+ "width" : 308,
+ "height" : 250,
+ "coords" : 1,
+ "minikarte" : {
+ "res_dpi" : 72,
+ "x_ul" : 16.2,
+ "y_ul" : 29.2,
+ "width" : 50,
+ "height" : 50
+ "scale" : {
+ "type" : "text",
+ "x_ul" : 370.0,
+ "y_ul" : 67.5,
+ "font_size" : 11,
+ "value" : "scale"
+ "date" : {
+ "type" : "text",
+ "x_ul" : 370.0,
+ "y_ul" : 53.5,
+ "font_size" : 11,
+ "value" : "date"
+ "nordpfeil" : {
+ "type" : "image",
+ "x_ul" : 370,
+ "y_ul" : 100,
+ "width" : 35,
+ "height" : 35,
+ "angle" : 0,
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 160,
+ "y_ul" : 18,
+ "font_size" : 18
+ "messung" : {
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "kommentar1" : {
+ "type" : "para",
+ "x_ul" : 338.2,
+ "y_ul" : 140.0,
+ "font_size" : 11,
+ "width" : 70,
+ "height" : 5,
+ "align" : "L",
+ "border" : 0,
+ "fill" : 0,
Added: trunk/mapbender/http/print/Querformat_A3.odg
Property changes on: trunk/mapbender/http/print/Querformat_A3.odg
Added: trunk/mapbender/http/print/Querformat_A3.pdf
Property changes on: trunk/mapbender/http/print/Querformat_A3.pdf
Added: trunk/mapbender/http/print/Querformat_A4.json
--- trunk/mapbender/http/print/Querformat_A4.json (rev 0)
+++ trunk/mapbender/http/print/Querformat_A4.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,167 @@
+ "units" : "mm",
+ "format" : "a4",
+ "controls" : [
+ "id" : "title",
+ "type" : "text",
+ "size" : 18,
+ "titel" : "value"
+ "id" : "dpi",
+ "size" : 20,
+ "options" : [
+ "value" : "72",
+ "value" : "144",
+ "size" : 5,
+ "id" : "angle",
+ "type" : "text",
+ "id" : "scale",
+ "type" : "text",
+ "scale" : "value"
+ "type" : "hidden"
+ "pages" : [
+ "tpl" : "Querformat_A4.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 15.5,
+ "y_ul" : 22.5,
+ "width" : 212,
+ "height" : 174,
+ "coords" : 1,
+ "minikarte" : {
+ "res_dpi" : 72,
+ "x_ul" : 15.0,
+ "y_ul" : 22.0,
+ "width" : 40,
+ "height" : 40
+ "scale" : {
+ "type" : "text",
+ "x_ul" : 257.0,
+ "y_ul" : 52.5,
+ "font_size" : 11,
+ "value" : "scale"
+ "date" : {
+ "type" : "text",
+ "x_ul" : 257.0,
+ "y_ul" : 41.5,
+ "font_size" : 11,
+ "value" : "date"
+ "nordpfeil" : {
+ "type" : "image",
+ "x_ul" : 254,
+ "y_ul" : 72,
+ "width" : 25,
+ "height" : 25,
+ "angle" : 0,
+ "messung" : {
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 110,
+ "y_ul" : 15,
+ "font_size" : 16
+ "kommentar1" : {
+ "type" : "para",
+ "x_ul" : 233.8,
+ "y_ul" : 95.4,
+ "font_size" : 11,
+ "width" : 60,
+ "height" : 5,
+ "align" : "L",
+ "border" : 0,
+ "fill" : 0,
Added: trunk/mapbender/http/print/Querformat_A4.odg
Property changes on: trunk/mapbender/http/print/Querformat_A4.odg
Added: trunk/mapbender/http/print/Querformat_A4.pdf
Property changes on: trunk/mapbender/http/print/Querformat_A4.pdf
Added: trunk/mapbender/http/print/Querformat_A4_Legende.json
--- trunk/mapbender/http/print/Querformat_A4_Legende.json (rev 0)
+++ trunk/mapbender/http/print/Querformat_A4_Legende.json 2013-08-23 06:15:55 UTC (rev 8694)
@@ -0,0 +1,123 @@
+ "units" : "mm",
+ "format" : "a4",
+ "controls" : [
+ "id" : "title",
+ "type" : "text",
+ "size" : 16,
+ "titel" : "value"
+ "id" : "dpi",
+ "label" : "DPI",
+ "size" : 20,
+ "options" : [
+ "value" : "72",
+ "value" : "144",
+ "id" : "angle",
+ "type" : "text",
+ "id" : "scale",
+ "type" : "text",
+ "scale" : "value"
+ "type" : "hidden"
+ "pages" : [
+ "tpl" : "Querformat_A4_Legende.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 15.3,
+ "y_ul" : 22.5,
+ "width" : 189.4,
+ "height" : 174,
+ "coords" : 1,
+ "date" : {
+ "type" : "text",
+ "x_ul" : 250.0,
+ "y_ul" : 15,
+ "font_size" : 11,
+ "value" : "date"
+ "legende" : {
+ "x_ul" : 212,
+ "y_ul" : 38,
+ "width" : 90,
+ "height" : 5,
+ "font_size" : 8,
+ "scale" : 0.5
+ "messung" : {
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 1,
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 2.0
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 110,
+ "y_ul" : 15,
+ "font_size" : 15
More information about the Mapbender_commits
