[Mapbender-commits] r8695 - in trunk/mapbender/http: html javascripts
svn_mapbender at osgeo.org
Mon Aug 26 07:20:08 PDT 2013
Author: verenadiewald
Date: 2013-08-26 07:20:08 -0700 (Mon, 26 Aug 2013)
New Revision: 8695
trunk/mapbender/http/html/mod_treefolderPlain.php
trunk/mapbender/http/javascripts/map_obj.js
handle service exceptions of getMap requests (imgerror) in treeGDE
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php 2013-08-23 06:15:55 UTC (rev 8694)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php 2013-08-26 14:20:08 UTC (rev 8695)
@@ -223,7 +223,9 @@
//parent.eventMapRequestFailed.register(function(t){imgerror(t)});
eventAfterLoadWMS.register(reloadTree);
-eventAfterLoadWMS.register(registerInitMapCheck);
+eventInit.register(registerInitMapCheck);
Mapbender.events.init.register(function () {
$("#" + mod_treeGDE_map).mapbender().events.afterMoveWms.register(reloadTree);
@@ -412,18 +414,24 @@
Mapbender.events.treeReloaded.trigger();
-function imgerror(t){
+function imgerror(wms, path, imgObj){
var map= getMapObjIndexByName(mod_treeGDE_map);
- var wms=Number(t.id.substr(4));
- t.onerror=null;
- t.onabort=null;
+ //t.onerror=null;
+ //t.onabort=null;
if(state[wms]!=-1 && alerterror=='true'){
state[wms]=-1;
- if(confirm('<?php echo _mb("Failed to load WMS");?> ' +
+ var errorMsg = '<?php echo _mb("Failed to load WMS");?> ' + mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle;
+ $('<div id="imgErrorDialog">' + errorMsg + ':<iframe style="width:90%;height:90%;" src="' + imgObj.attr("src") + '"></iframe></div>').dialog();
+ checkNode(path, 0, false);
+ /*if(confirm('<?php echo _mb("Failed to load WMS");?> ' +
mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle +
'\n<?php echo _mb("Do you want to try to load it in a new window?");?>')) {
- window.open(t.src,"");
+ window.open(imgObj.attr("src"),"");
state[wms]=-1;
errors++;
@@ -456,8 +464,10 @@
else{
if(first){
state[wms]=0;
-// frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
-// frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
+ $("#" + map).error(function () {
+ imgerror(wms, img, $(this));
+ //$(map).onabort=imgerror;
if(showstatus=='true')
setNodeImage(img, "loading_folder.gif");
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2013-08-23 06:15:55 UTC (rev 8694)
+++ trunk/mapbender/http/javascripts/map_obj.js 2013-08-26 14:20:08 UTC (rev 8695)
@@ -879,7 +879,8 @@
url += "TRANSPARENT=TRUE&";
- url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+ //url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+ url += "EXCEPTIONS=application/vnd.ogc.se_xml&";
// add vendor-specific
for (var v = 0; v < mb_vendorSpecific.length; v++) {
More information about the Mapbender_commits
