[Mapbender-commits] r8697 - in trunk/mapbender: http/classes http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 28 13:04:37 PDT 2013
Author: armin11
Date: 2013-08-28 13:04:37 -0700 (Wed, 28 Aug 2013)
New Revision: 8697
   trunk/mapbender/http/classes/class_iso19139.php
   trunk/mapbender/http/plugins/mb_metadata_addon.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js
   trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
   trunk/mapbender/http/plugins/wfsConfTree.js
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
Allow bequeath spatial extent from layer/featuretype to coupled metadata resource.
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/classes/class_iso19139.php	2013-08-28 20:04:37 UTC (rev 8697)
@@ -26,12 +26,12 @@
 	var $title;
 	var $abstract;
 	var $metadata;
+	var $wgs84Bbox = array(); //minx, miny, maxx, maxy in EPSG:4326
 	var $datasetId;
 	var $datasetIdCodeSpace;
 	var $keywords = array();
 	var $keywordsThesaurusName = array();
 	var $isoCategoryKeys = array();
 	var $isoCategories = array();
 	var $inspireCategories = array();
 	var $customCategories = array();
@@ -69,6 +69,7 @@
 		$this->createDate = "1900-01-01";
 		$this->changeDate = "1900-01-01";
 		$this->metadata = "";
+		$this->wgs84Bbox = array(-180.0,-90.0,180.0,90.0); //minx, miny, maxx, maxy in EPSG:4326
 		$this->datasetId = "";
 		$this->datasetIdCodeSpace = "";
 		$this->keywords = array();
@@ -232,6 +233,17 @@
 			foreach ($this->customCategories as $category) {
 				$e = new mb_exception("class_iso19139.php: customcat: ".$category);
+			/*<gmd:extent><gmd:EX_Extent><gmd:geographicElement><gmd:EX_GeographicBoundingBox><gmd:westBoundLongitude><gco:Decimal>5</gco:Decimal></gmd:westBoundLongitude><gmd:eastBoundLongitude><gco:Decimal>10</gco:Decimal></gmd:eastBoundLongitude><gmd:southBoundLatitude><gco:Decimal>48</gco:Decimal></gmd:southBoundLatitude><gmd:northBoundLatitude><gco:Decimal>52</gco:Decimal></gmd:northBoundLatitude></gmd:EX_GeographicBoundingBox></gmd:geographicElement></gmd:EX_Extent></gmd:extent>*/
+			//get bbox from xml:
+			$minx = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:westBoundLongitude/gco:Decimal');
+			$minx = $minx[0];
+			$miny = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:southBoundLatitude/gco:Decimal');
+			$miny = $miny[0];
+			$maxx = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:eastBoundLongitude/gco:Decimal');
+			$maxx = $maxx[0];
+			$maxy = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:northBoundLatitude/gco:Decimal');
+			$maxy = $maxy[0];
+			$this->wgs84Bbox = array($minx,$miny,$maxx,$maxy);
 			$this->hierachyLevel = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
 			$this->hierachyLevel = $this->hierachyLevel[0];
 			$this->tmpExtentBegin = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
@@ -660,7 +672,7 @@
 	public function createFromDBInternalId($metadataId){
-		$sql = "SELECT * from mb_metadata WHERE metadata_id = $1";
+		$sql = "SELECT * , box2d(the_geom) as bbox2d from mb_metadata WHERE metadata_id = $1";
 		$v = array($metadataId);
 		$t = array('i');
 		$res = db_prep_query($sql,$v,$t);
@@ -677,7 +689,11 @@
 			//some possibilities:
 			$this->datasetId = $row['datasetid'];
 			$this->datasetIdCodeSpace = $row['datasetid_codespace'];
+			if (isset($row['bbox2d']) && $row['bbox2d'] != '') {
+				$bbox = str_replace(' ',',',str_replace(')','',str_replace('BOX(','',$row['bbox2d'])));
+				$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
+				$this->wgs84Bbox = explode(',',$bbox);
 			//fill keywords and categories later cause they are stored in relations!
 			/*$this->keywords = array();
 			$this->keywordsThesaurusName = array();
@@ -995,6 +1011,13 @@
 			return false;
+	private function createWktBboxFromArray($bboxArray) {
+		$postGisBbox = "";
+		//"SRID=4326;POLYGON((-140 -80,-140 80,170 80,170 -80,-140 -80))"
+		$postGisBbox = "SRID=4326;POLYGON((".$bboxArray[0]." ".$bboxArray[1].",".$bboxArray[0]." ".$bboxArray[3].",".$bboxArray[2]." ".$bboxArray[3].",".$bboxArray[2]." ".$bboxArray[1].",".$bboxArray[0]." ".$bboxArray[1]."))";
+		return $postGisBbox;
 	public function insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId){
 		//first delete old classifications - after that create new ones
@@ -1281,7 +1304,7 @@
 	public function insertMetadataIntoDB() {
 		//insert an instance for iso19139 into mapbenders database
 		$sql = <<<SQL
-INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29)
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30)
 SQL;
 		$v = array(
 			$this->href,
@@ -1312,9 +1335,10 @@
 			$this->updateFrequency,
 			$this->dataFormat,
 			$this->inspireCharset,
-			$this->refSystem
+			$this->refSystem,
+			$this->createWktBboxFromArray($this->wgs84Bbox)
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s');
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON');
 			return $res;
@@ -1328,7 +1352,7 @@
 		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
 		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
 		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29 WHERE metadata_id = $19";
+		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30 WHERE metadata_id = $19";
 		$v = array(
 			$this->href,
@@ -1360,9 +1384,10 @@
 			$this->dataFormat,
-			$this->refSystem
+			$this->refSystem,
 		return $res;
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-08-28 20:04:37 UTC (rev 8697)
@@ -67,6 +67,9 @@
 			<li><a href="#tabs-3"><?php echo _mb("Temporal extent");?></a></li>
 			<li><a href="#tabs-4"><?php echo _mb("Quality");?></a></li>
 			<li><a href="#tabs-5"><?php echo _mb("Spatial Extent");?></a></li>
+			<li><a href="#tabs-7"><?php echo _mb("Covering Area");?></a></li>
+			<li><a href="#tabs-8"><?php echo _mb("Licences/Constraints");?></a></li>
 		</ul>
 		<!--<legend><?php echo _mb("Simple metadata editor");?></legend>-->
 		<div id="tabs-1">
@@ -213,8 +216,40 @@
 	</div>
 	<div id="tabs-5">
-	undefined
+		<fieldset>
+			<legend><?php echo _mb("Bounding Box");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("This is the bounding box of the dataset given in geographic coordinates in WGS84 (EPSG:4326). The bounding box may be inherited by the calling service contents bounding box (layer/featuretype) or defined by the registrating person later on.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+		<label for="west">
+			<?php echo _mb("West [decimal degrees]");?>
+			<input class="required" name="west" id="west"/>
+		</label><br>
+		<label for="north">
+			<?php echo _mb("North [decimal degrees]");?>
+			<input class="required" name="north" id="north"/>
+		</label><br>
+		<label for="east">
+			<?php echo _mb("East [decimal degrees]");?>
+			<input class="required" name="east" id="east"/>
+		</label><br>
+		<label for="south">
+			<?php echo _mb("South [decimal degrees]");?>
+			<input class="required" name="south" id="south"/>
+		</label>
+		</fieldset>
+		<fieldset>
+			<legend><?php echo _mb("User defined region");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("You can define your own bounding box or region if you upload an gml geometry object. Only bbox and polygons are accepted at the moment!");?>'}" src="../img/questionmark.png" alt="" /></legend>
+			<table id='geometryuploadtable' name='geometryuploadtable'><tr><td><img onclick='initUploadForm();' src='../img/button_blue_red/up.png' id='uploadImage' title='upload'  /></td><td><?php echo _mb("Upload a surronding geometry for this dataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Help for geometry upload possibility");?>'}" src="../img/questionmark.png" alt="" /></td></tr></table>
+		</fieldset>
 	</div>
+	<div id="tabs-6">
+	</div>
+	<div id="tabs-7">
+	</div>
+	<div id="tabs-8">
+	</div>
 	</div><!--accordion-->
 	</div><!--demo-->
 	</fieldset>
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2013-08-28 20:04:37 UTC (rev 8697)
@@ -221,10 +221,10 @@
 	case "getLayerMetadata" :
 		$layerId = $ajaxResponse->getParameter("id");
 		getLayer($layerId);
+		//new - only layers with latlonbboxes are supported!
 		$sql = <<<SQL
-SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable, inspire_download, fkey_wms_id as wms_id
+SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable, inspire_download, fkey_wms_id as wms_id
 FROM layer WHERE layer_id = $layerId;
 SQL;
@@ -280,9 +280,14 @@
 		$resultObj['inspire_download'] = $resultObj['inspire_download'] == 1 ? true : false;
+		//get wgs84Bbox for relevant layer - to be bequeathed to the metadata
+		/*$sql = <<<SQL
+SELECT minx, miny, maxx, maxy from layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'
+SQL;
+		$res = db_query($sql);*/
+		//read out values
 		//get coupled MetadataURLs from md_metadata and ows_relation_metadata table
 		$sql = <<<SQL
 SELECT metadata_id, uuid, link, linktype, md_format, relation.relation_type, origin FROM mb_metadata
@@ -488,7 +493,7 @@
 				"layer_inspire_category_id",
 				"layer_custom_category_id"
-			//extract relevant information from json and fill them into the wms object
+			//extract relevant information from json and fill them into the wms object // both are filled together!!
 			foreach ($columns as $c) {
 				$value = $data->layer->$c;
 				$e = new mb_notice("plugins/mb_metadata_server.php: layer entry for ".$c.": ".$data->layer->$c);
@@ -659,6 +664,10 @@
 			$resultObj["lineage"] = $mbMetadata->lineage; //text
 			$resultObj["tmp_reference_1"] = $mbMetadata->tmpExtentBegin; //text
 			$resultObj["tmp_reference_2"] = $mbMetadata->tmpExtentEnd; //text
+			$resultObj["west"] = $mbMetadata->wgs84Bbox[0];
+			$resultObj["south"] = $mbMetadata->wgs84Bbox[1];
+			$resultObj["east"] = $mbMetadata->wgs84Bbox[2];
+			$resultObj["north"] = $mbMetadata->wgs84Bbox[3];
 			$export2csw = $mbMetadata->export2Csw; //boolean
 			$resultObj["update_frequency"] = $mbMetadata->updateFrequency; //text
 			switch ($export2csw) {
@@ -707,7 +716,8 @@
 		$layerId = $ajaxResponse->getParameter("layerId");
 		$metadataId = $ajaxResponse->getParameter("metadataId");
 		$sql = <<<SQL
-SELECT layer_title, layer_abstract from layer where layer_id = $1
+SELECT layer_title, layer_abstract, minx as west, miny as south, maxx as east, maxy as north
+FROM layer INNER JOIN layer_epsg ON layer.layer_id = layer_epsg.fkey_layer_id WHERE layer_id = $1 AND epsg = 'EPSG:4326';
 SQL;
 		$v = array($layerId);
 		$t = array('i');
@@ -717,6 +727,10 @@
 			$row = db_fetch_assoc($res);
 			$resultObj["title"]= $row['layer_title']; //serial
 			$resultObj["abstract"] = $row["layer_abstract"]; //char
+			$resultObj["west"]= $row['west']; //double
+			$resultObj["south"] = $row["south"]; //double
+			$resultObj["east"]= $row['east']; //double
+			$resultObj["north"] = $row["north"]; //double
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
@@ -754,6 +768,7 @@
 			$mbMetadata->spatialResValue = $data->spatial_res_value;
 			$mbMetadata->inspireCharset = $data->inspire_charset;
 			$mbMetadata->updateFrequency = $data->update_frequency;
 			//categories ...
 			//new for keywords and classifications:
 			if (isset($data->keywords) && $data->keywords != "") {
@@ -772,6 +787,19 @@
 			if (isset($data->md_custom_category_id)) {
 				$mbMetadata->customCategories = $data->md_custom_category_id;
+			//use information from bbox!
+			if (isset($data->west)) {
+				$mbMetadata->wgs84Bbox[0] = $data->west;
+			if (isset($data->east)) {
+				$mbMetadata->wgs84Bbox[2] = $data->east;
+			if (isset($data->north)) {
+				$mbMetadata->wgs84Bbox[3] = $data->north;
+			if (isset($data->south)) {
+				$mbMetadata->wgs84Bbox[1] = $data->south;
 			//try to update metadata object (only mb_metadata)
 			$res = $mbMetadata->updateMetadataById($metadataId);
 			if (!$res) {
@@ -931,6 +959,19 @@
 		//Check if origin is external and export2csw is activated!
 		if ($origin == 'external' ) {
 			//harvest link from location, parse the content for datasetid and push xml into data column
Modified: trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js
--- trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/plugins/mb_metadata_showMetadataAddonWfs.js	2013-08-28 20:04:37 UTC (rev 8697)
@@ -317,6 +317,16 @@
 		$metadataAddonPopup.dialog("open");
+	initGeometryUpload = function () {
+		//start upload form
+		//check if edit or create new - or store it in tmp folder to hold it later
+		//after upload send
+		//generate bbox if upload successful
 	initUploadForm = function (featuretypeId) {
 		$metadataAddonPopup.dialog("close");
 		initXmlImport(featuretypeId);
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php	2013-08-28 20:04:37 UTC (rev 8697)
@@ -324,8 +324,10 @@
 	case "getInitialFeaturetypeMetadata" :
 		$featuretypeId = $ajaxResponse->getParameter("featuretypeId");
+		//TODO: check like operator and ambigious wfs_featuretype_epsg - are they not deleted on update? Get rid of the limit 1
 		$sql = <<<SQL
-SELECT featuretype_title, featuretype_abstract from wfs_featuretype where featuretype_id = $1
+SELECT featuretype_title, featuretype_abstract, minx as west, miny as south, maxx as east, maxy as north
+FROM  wfs_featuretype INNER JOIN wfs_featuretype_epsg ON wfs_featuretype.featuretype_id = wfs_featuretype_epsg.fkey_featuretype_id WHERE featuretype_id = $1 AND epsg like '%:4326' LIMIT 1
 SQL;
 		$v = array($featuretypeId);
 		$t = array('i');
@@ -335,6 +337,10 @@
 			$resultObj["title"]= $row['featuretype_title']; //serial
 			$resultObj["abstract"] = $row["featuretype_abstract"]; //char
Modified: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/http/plugins/wfsConfTree.js	2013-08-28 20:04:37 UTC (rev 8697)
@@ -20,11 +20,8 @@
 	//Mapbender.modules.i18n.localize(Mapbender.languageId);
 var $confTree = $(this);
 var ConfTree = function(o){
 	var that = this;
 	var wfsConfIdString = o.wfsConfIdString || "";
 	var wfsconfs = wfsConfIdString.split(',');
@@ -35,8 +32,6 @@
 	wfsConfIdString = wfsconfs.join(',');
 	var currentWFSConf = {};
 	if(Mapbender.modules.loadwmc){
 		Mapbender.modules.loadwmc.events.loaded.register(function (obj) {
 			if (obj.extensionData && obj.extensionData.WFSCONFIDSTRING) {
@@ -54,7 +49,6 @@
 	var $wfsConfDialog = $("<div></div>").dialog({
 		width: 500,
 		height: 600,
@@ -75,7 +69,6 @@
 	var reset = function(aWFSConf){
 		wfsconfs = [];
 		$confTree.children().remove();
@@ -97,7 +90,6 @@
 			}else{
 				$featuretypeList = $featuretypeFolder.find("ul");
 			//parseInt because one version of wfsConf creates this as a string, the other as an int
 			switch(parseInt(aWFSConf[i].type,10)){
 					/* search */
@@ -112,7 +104,7 @@
 					/* download */
 					case 2:
-						$wfsconfEntry = $('<li class="download" ><img src="../img/gnome/document_save.png" /><button class="remove">remo</button><img class="meta" src="../img/button_blue_red/getArea_over.png" />  <a href="#" class="dialogopen">'+ aWFSConf[i].label +'</a></li>');
+						$wfsconfEntry = $('<li class="download" ><img src="../img/gnome/document-save.png" /><button class="remove">remo</button><img class="meta" src="../img/button_blue_red/getArea_over.png" />  <a href="#" class="dialogopen">'+ aWFSConf[i].label +'</a></li>');
 					break;
@@ -127,8 +119,6 @@
 				$wfsConfDialog.empty();
 				$wfsConfDialog.append($iframe);
 				$wfsConfDialog.dialog("open");
 			})(aWFSConf[i]));
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-08-28 06:37:01 UTC (rev 8696)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-08-28 20:04:37 UTC (rev 8697)
@@ -597,3 +597,14 @@
 ALTER TABLE wfs ADD COLUMN inspire_daily_requests double precision;
+-- Check: enforce_geotype_the_geom - allow also polygons!
+ALTER TABLE mb_metadata DROP CONSTRAINT enforce_geotype_the_geom;
+  ADD CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL OR geometrytype(the_geom) = 'POLYGON'::text);
More information about the Mapbender_commits mailing list
