[Mapbender-commits] r8698 - in trunk/mapbender: http/classes http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 29 07:57:08 PDT 2013
Author: armin11
Date: 2013-08-29 07:57:08 -0700 (Thu, 29 Aug 2013)
New Revision: 8698
   trunk/mapbender/http/classes/class_iso19139.php
   trunk/mapbender/http/plugins/mb_metadata_addon.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
Enhancement to store url handle url for download at metadata level. The urls are stored as json in mb_metadata.datalinks column.
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2013-08-28 20:04:37 UTC (rev 8697)
+++ trunk/mapbender/http/classes/class_iso19139.php	2013-08-29 14:57:08 UTC (rev 8698)
@@ -35,7 +35,7 @@
 	var $isoCategories = array();
 	var $inspireCategories = array();
 	var $customCategories = array();
+	var $downloadLinks = array();  //store in db as json object!!!!
 	var $hierachyLevel;
 	var $tmpExtentBegin;
 	var $tmpExtentEnd;
@@ -79,6 +79,7 @@
 		$this->isoCategories = array();
 		$this->inspireCategories = array();
 		$this->customCategories = array();
+		$this->downloadLinks = array();
 		$this->hierachyLevel = "dataset";
 		$this->tmpExtentBegin = "1900-01-01";
@@ -233,7 +234,10 @@
 			foreach ($this->customCategories as $category) {
 				$e = new mb_exception("class_iso19139.php: customcat: ".$category);
+			$this->downloadLinks = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource[gmd:function/gmd:CI_OnLineFunctionCode/@codeListValue="download"]/gmd:linkage/gmd:URL');
 			/*<gmd:extent><gmd:EX_Extent><gmd:geographicElement><gmd:EX_GeographicBoundingBox><gmd:westBoundLongitude><gco:Decimal>5</gco:Decimal></gmd:westBoundLongitude><gmd:eastBoundLongitude><gco:Decimal>10</gco:Decimal></gmd:eastBoundLongitude><gmd:southBoundLatitude><gco:Decimal>48</gco:Decimal></gmd:southBoundLatitude><gmd:northBoundLatitude><gco:Decimal>52</gco:Decimal></gmd:northBoundLatitude></gmd:EX_GeographicBoundingBox></gmd:geographicElement></gmd:EX_Extent></gmd:extent>*/
+			//esri
+			/*<gmd:extent><gmd:EX_Extent><gmd:geographicElement><gmd:EX_GeographicBoundingBox><gmd:westBoundLongitude><gco:Decimal>11.1414</gco:Decimal></gmd:westBoundLongitude><gmd:eastBoundLongitude><gco:Decimal>11.7284</gco:Decimal></gmd:eastBoundLongitude><gmd:southBoundLatitude><gco:Decimal>58.8838</gco:Decimal></gmd:southBoundLatitude><gmd:northBoundLatitude><gco:Decimal>59.2562</gco:Decimal></gmd:northBoundLatitude></gmd:EX_GeographicBoundingBox></gmd:geographicElement><gmd:temporalElement><gmd:EX_TemporalExtent><gmd:extent><gml:TimePeriod gml:id="idNummer1"><gml:beginPosition>1999-05-05</gml:beginPosition><gml:endPosition>2012-04-04</gml:endPosition></gml:TimePeriod></gmd:extent></gmd:EX_TemporalExtent></gmd:temporalElement></gmd:EX_Extent></gmd:extent>*/
 			//get bbox from xml:
 			$minx = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:westBoundLongitude/gco:Decimal');
 			$minx = $minx[0];
@@ -691,7 +695,7 @@
 			$this->datasetIdCodeSpace = $row['datasetid_codespace'];
 			if (isset($row['bbox2d']) && $row['bbox2d'] != '') {
 				$bbox = str_replace(' ',',',str_replace(')','',str_replace('BOX(','',$row['bbox2d'])));
-				$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
+				//$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
 				$this->wgs84Bbox = explode(',',$bbox);
 			//fill keywords and categories later cause they are stored in relations!
@@ -724,7 +728,10 @@
 			$this->updateFrequency = $row['update_frequency'];//"";
 			$this->dataFormat = $row['format'];//"";
 			$this->inspireCharset = $row['inspire_charset'];//"";
+			//$test = print_r($row['datalinks'],true);
+			//$e = new mb_exception((string)$test);
+			$this->downloadLinks  = $this->jsonDecodeDownloadLinks($row['datalinks']);
+			//$e = new mb_exception($this->downloadLinks[0]);
 			//$this->linkAlreadyInDB = false;
 			//$this->fileIdentifierAlreadyInDB = false;
 			//get relations from other tables:
@@ -868,7 +875,7 @@
 		//bequeath categories from coupled resources
 		$this->bequeathCategoriesToCoupledResource($metadataId,$resourceType,$resourceId);
-		$e = new mb_exception("iso19139.php: bequeathed categories to ".$resourceType." : ".$resourceId);
+		//$e = new mb_exception("iso19139.php: bequeathed categories to ".$resourceType." : ".$resourceId);
 		$returnObject['success'] = true;
 		$returnObject['message'] = _mb("Internal metadata linkage inserted!");
 		return $returnObject;
@@ -1016,9 +1023,11 @@
 		$postGisBbox = "";
 		//"SRID=4326;POLYGON((-140 -80,-140 80,170 80,170 -80,-140 -80))"
 		$postGisBbox = "SRID=4326;POLYGON((".$bboxArray[0]." ".$bboxArray[1].",".$bboxArray[0]." ".$bboxArray[3].",".$bboxArray[2]." ".$bboxArray[3].",".$bboxArray[2]." ".$bboxArray[1].",".$bboxArray[0]." ".$bboxArray[1]."))";
+		//$e = new mb_exception("class_iso19139.php: bbox: ".$postGisBbox);
 		return $postGisBbox;
 	public function insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId){
 		//first delete old classifications - after that create new ones
 		$this->deleteKeywordsAndCategoriesFromDB($metadataId,$resourceType,$resourceId);
@@ -1304,7 +1313,7 @@
 	public function insertMetadataIntoDB() {
 		//insert an instance for iso19139 into mapbenders database
 		$sql = <<<SQL
-INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30)
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31)
 SQL;
 		$v = array(
 			$this->href,
@@ -1336,13 +1345,24 @@
 			$this->dataFormat,
 			$this->inspireCharset,
 			$this->refSystem,
-			$this->createWktBboxFromArray($this->wgs84Bbox)
+			$this->createWktBboxFromArray($this->wgs84Bbox),
+			$this->jsonEncodeDownloadLinks($this->downloadLinks)
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON');
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s');
 			$res = db_prep_query($sql,$v,$t);
 			return $res;
+	private function jsonEncodeDownloadLinks($dlArray) {
+		$dummy->downloadLinks = $dlArray;
+		return json_encode($dummy);
+	//TODO - maybe we will encode more things than only the url ;-)
+	private function jsonDecodeDownloadLinks($dlJson) {
+		$dummy = json_decode($dlJson);
+		$dummy = $dummy->downloadLinks;
+		return $dummy;
 	public function updateMetadataById($metadataId) {
 		//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
@@ -1352,7 +1372,7 @@
 		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
 		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
 		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30 WHERE metadata_id = $19";
+		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31 WHERE metadata_id = $19";
 		$v = array(
 			$this->href,
@@ -1385,9 +1405,10 @@
 			$this->dataFormat,
 			$this->refSystem,
 		return $res;
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-08-28 20:04:37 UTC (rev 8697)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-08-29 14:57:08 UTC (rev 8698)
@@ -221,22 +221,18 @@
 		<label for="west">
 			<?php echo _mb("West [decimal degrees]");?>
 			<input class="required" name="west" id="west"/>
-		</label><br>
+		</label><br />
+		<label for="south">
+			<?php echo _mb("South [decimal degrees]");?>
+			<input class="required" name="south" id="south"/>
+		</label><br />
+		<label for="east">
+			<?php echo _mb("East [decimal degrees]");?>
+			<input class="required" name="east" id="east"/>
+		</label><br />
 		<label for="north">
 			<?php echo _mb("North [decimal degrees]");?>
 			<input class="required" name="north" id="north"/>
-		</label><br>
-		<label for="east">
-			<?php echo _mb("East [decimal degrees]");?>
-			<input class="required" name="east" id="east"/>
-		</label><br>
-		<label for="south">
-			<?php echo _mb("South [decimal degrees]");?>
-			<input class="required" name="south" id="south"/>
 		</label>
 		</fieldset>
 		<fieldset>
@@ -245,6 +241,12 @@
 		</fieldset>
 	</div>
 	<div id="tabs-6">
+		<fieldset>
+		<label for="downloadlink">
+			<input class="" name="downloadlink" id="downloadlink"/>
+		</label>
+		</fieldset>
 	</div>
 	<div id="tabs-7">
 	</div>
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2013-08-28 20:04:37 UTC (rev 8697)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2013-08-29 14:57:08 UTC (rev 8698)
@@ -668,6 +668,7 @@
 			$resultObj["south"] = $mbMetadata->wgs84Bbox[1];
 			$resultObj["east"] = $mbMetadata->wgs84Bbox[2];
 			$resultObj["north"] = $mbMetadata->wgs84Bbox[3];
+			$resultObj["downloadlink"] = $mbMetadata->downloadLinks[0]; //only the first link!
 			$export2csw = $mbMetadata->export2Csw; //boolean
 			$resultObj["update_frequency"] = $mbMetadata->updateFrequency; //text
 			switch ($export2csw) {
@@ -768,7 +769,7 @@
 			$mbMetadata->spatialResValue = $data->spatial_res_value;
 			$mbMetadata->inspireCharset = $data->inspire_charset;
 			$mbMetadata->updateFrequency = $data->update_frequency;
+			$mbMetadata->downloadLinks = array($data->downloadlink);
 			//categories ...
 			//new for keywords and classifications:
 			if (isset($data->keywords) && $data->keywords != "") {
@@ -942,6 +943,9 @@
 		if (isset($data->update_frequency)) {
+		if (isset($data->update_frequency)) {
 			$mbMetadata->keywords = array_map('trim',explode(',',$data->keywords));
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php	2013-08-28 20:04:37 UTC (rev 8697)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php	2013-08-29 14:57:08 UTC (rev 8698)
@@ -326,8 +326,8 @@
 		$metadataId = $ajaxResponse->getParameter("metadataId");
 		//TODO: check like operator and ambigious wfs_featuretype_epsg - are they not deleted on update? Get rid of the limit 1
 		$sql = <<<SQL
-SELECT featuretype_title, featuretype_abstract, minx as west, miny as south, maxx as east, maxy as north
-FROM  wfs_featuretype INNER JOIN wfs_featuretype_epsg ON wfs_featuretype.featuretype_id = wfs_featuretype_epsg.fkey_featuretype_id WHERE featuretype_id = $1 AND epsg like '%:4326' LIMIT 1
+SELECT featuretype_title, featuretype_abstract, featuretype_latlon_bbox
+FROM  wfs_featuretype WHERE featuretype_id = $1
 SQL;
 		$v = array($featuretypeId);
 		$t = array('i');
@@ -336,11 +336,16 @@
 		if ($res) {
 			$row = db_fetch_assoc($res);
 			$resultObj["title"]= $row['featuretype_title']; //serial
-			$resultObj["abstract"] = $row["featuretype_abstract"]; //char
-			$resultObj["west"]= $row['west']; //double
-			$resultObj["south"] = $row["south"]; //double
-			$resultObj["east"]= $row['east']; //double
-			$resultObj["north"] = $row["north"]; //double
+			$resultObj["abstract"] = $row["featuretype_abstract"]; //char
+			if (isset($resultObj["featuretype_latlon_bbox"]) && $resultObj["featuretype_latlon_bbox"] != '') {
+				$bbox = explode(',',$resultObj["featuretype_latlon_bbox"]);
+			} else {
+				$bbox = array(-180,-90,180,90);
+			$resultObj["west"] = $bbox[0]; //double
+			$resultObj["south"] = $bbox[1]; //double
+			$resultObj["east"]= $bbox[2]; //double
+			$resultObj["north"] = $bbox[3]; //double
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-08-28 20:04:37 UTC (rev 8697)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-08-29 14:57:08 UTC (rev 8698)
@@ -606,5 +606,9 @@
 ALTER TABLE mb_metadata
   ADD CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL OR geometrytype(the_geom) = 'POLYGON'::text);
+-- Column: datalinks - for storing download links to datasets as json object
+-- ALTER TABLE mb_metadata DROP COLUMN datalinks;
+ALTER TABLE mb_metadata ADD COLUMN datalinks text;
More information about the Mapbender_commits mailing list
