[Mapbender-commits] r8672 - branches/2.7/http/javascripts trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Jul 16 04:08:58 PDT 2013
Author: verenadiewald
Date: 2013-07-16 04:08:58 -0700 (Tue, 16 Jul 2013)
New Revision: 8672
branches/2.7/http/javascripts/geometry.js
trunk/mapbender/http/javascripts/geometry.js
if Raphael.js is used for highlighting geometries, don't use calculateVisibleDashes in function drawGeometry, because svg is not shown correctly then in the map
Modified: branches/2.7/http/javascripts/geometry.js
--- branches/2.7/http/javascripts/geometry.js 2013-07-16 10:46:36 UTC (rev 8671)
+++ branches/2.7/http/javascripts/geometry.js 2013-07-16 11:08:58 UTC (rev 8672)
@@ -1840,7 +1840,11 @@
(function(){
var currentPoint = realToMap(mapframe, currentGeom.get(j));
- var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
+ //don't use calculateVisibleDash here anymore, because Raphael svg is drawn not correctly when shown in the corner of the map
+ //var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
+ var pq = [];
+ pq[0] = new Mapbender.Point(previousPoint);
+ pq[1] = new Mapbender.Point(currentPoint);
if (pq) {
if (segment === "") {
segment += "M" + pq[0].x + " " + pq[0].y;
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js 2013-07-16 10:46:36 UTC (rev 8671)
+++ trunk/mapbender/http/javascripts/geometry.js 2013-07-16 11:08:58 UTC (rev 8672)
@@ -1840,7 +1840,12 @@
(function(){
+ var pq = [];
if (pq) {
More information about the Mapbender_commits
