[Mapbender-commits] r8673 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Tue Jul 16 05:03:02 PDT 2013
Author: armin11
Date: 2013-07-16 05:03:01 -0700 (Tue, 16 Jul 2013)
New Revision: 8673
trunk/mapbender/http/geoportal/mod_readCSWResults.php
trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
Little bugfix && intstead of || ;-)
Modified: trunk/mapbender/http/geoportal/mod_readCSWResults.php
--- trunk/mapbender/http/geoportal/mod_readCSWResults.php 2013-07-16 11:08:58 UTC (rev 8672)
+++ trunk/mapbender/http/geoportal/mod_readCSWResults.php 2013-07-16 12:03:01 UTC (rev 8673)
@@ -214,6 +214,7 @@
//echo "<br>CAT ID from DB: ".$row_csw["fkey_cat_id"]."<br>";
//get urls for getrecords and getrecordbyid from table cat
$v = $row_csw["fkey_cat_id"];
+ $e = new mb_notice("<br>cat id: ".$row_csw["fkey_cat_id"]);
$t = 'i';
$sql_gr = "select param_value, param_name from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords'";
$res_gr = db_prep_query($sql_gr, $v, $t);
@@ -222,21 +223,22 @@
switch ($row_gr['param_name']) {
case "get" :
$csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "get";
- if (isset($row_gr['param_value']) || $row_gr['param_value'] != '') {
+ if (isset($row_gr['param_value']) && $row_gr['param_value'] != '') {
$csw_list[$cnt_csw] ['getrecordsurl'] = $row_gr['param_value'];
break 2;
break 1;
case "post" :
$csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "post";
+ $e = new mb_exception("<br>getrecords: ".$row_gr['param_value']);
break 2;
break 1;
case "post_xml" :
$csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "post_xml";
- if (isset($row_gr['param_value']) || $row_gr['param_value'] != '' ) {
+ if (isset($row_gr['param_value']) && $row_gr['param_value'] != '' ) {
break 2;
Modified: trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php 2013-07-16 11:08:58 UTC (rev 8672)
+++ trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php 2013-07-16 12:03:01 UTC (rev 8673)
@@ -696,21 +696,21 @@
case "get" :
break 2;
break 1;
case "post" :
break 2;
break 1;
case "post_xml" :
break 2;
More information about the Mapbender_commits
