[Mapbender-commits] r8674 - in trunk/mapbender/http/extensions/mobilemap: . _build css css/images js js/dev mod_mapbender
svn_mapbender at osgeo.org
Wed Jul 17 20:44:11 PDT 2013
Author: armin11
Date: 2013-07-17 20:44:11 -0700 (Wed, 17 Jul 2013)
New Revision: 8674
Added:
trunk/mapbender/http/extensions/mobilemap/css/images/
trunk/mapbender/http/extensions/mobilemap/css/images/ajax-loader.gif
trunk/mapbender/http/extensions/mobilemap/css/images/gpspoint.png
trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-black.png
trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-white.png
trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-black.png
trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-white.png
trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.custom.min.css
trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.min.css
trunk/mapbender/http/extensions/mobilemap/js/jquery.min.js
trunk/mapbender/http/extensions/mobilemap/js/jquery.mobile.min.js
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/css/ngstyle.css
trunk/mapbender/http/extensions/mobilemap/js/OpenLayers.mobile.min.js
trunk/mapbender/http/extensions/mobilemap/js/dev/2_ngms_global.js
trunk/mapbender/http/extensions/mobilemap/js/dev/3_ngms_layer.js
trunk/mapbender/http/extensions/mobilemap/js/dev/4_ngms_base.js
trunk/mapbender/http/extensions/mobilemap/js/dev/5_ngms_jq.js
trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/map.php
trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
New function for mobile client to follow gps position and new jquery mobile version with ie10 support - thanx to sven schroeter ;-) .
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -442,18 +442,17 @@
graphicName: 'circle'};
//OpenLayers Symbol (Objekt) GPS-Lokalisierung, mögliche Namen: "star", "cross", "x", "square", "triangle", "circle"
-var olGpsSymbol = { graphicName: 'cross',
- strokeColor: '#871D33',
- strokeWidth: 2,
- fillOpacity: 0,
- pointRadius: 12 };
+var olGpsSymbol = { externalGraphic: 'css/images/gpspoint.png',
+ graphicHeight: 16,
+ graphicWidth:16
//OpenLayers Symbol (Objekt) zur Markierung der GPS-Kreisfarbe + Stil
-var olGpscircleStyle = { fillOpacity: 0.1,
- fillColor: '#000',
+var olGpscircleStyle = { fillOpacity: 0.2,
+ fillColor: '#06C',
+ strokeColor: '#06C',
strokeOpacity: 0.6 };
// default style für Zeichnungen
var sketchSymbolizers = {
"Point": {
@@ -480,7 +479,65 @@
fillOpacity: 0.5
+//Styles für Markierungen
+var umkreisstyles = new OpenLayers.StyleMap({
+ "default": new OpenLayers.Style(null, {
+ rules: [
+ new OpenLayers.Rule({
+ symbolizer: {
+ "Point": {
+ pointRadius: 5,
+ graphicName: "circle",
+ fillColor: "white",
+ fillOpacity: 0.6,
+ strokeWidth: 1,
+ strokeOpacity: 1,
+ strokeColor: "#CC0000"
+ "Line": {
+ strokeWidth: 3,
+ strokeOpacity: 1,
+ "Polygon": {
+ strokeWidth: 2,
+ strokeOpacity: 1,
+ fillColor: "#CC0000",
+//Hilfsfunktion zur Ermittlung des Symbols
+var poicontext = {
+ getGraphic: function(feature) {
+ return feature.attributes.symbol;
+//Template für POIs
+var poitemplate = {
+ externalGraphic: 'config/img/symbol/'+ "${getGraphic}", graphicHeight: 26, graphicWidth:26, cursor:"pointer"
+//Template für selektierte POIs
+var selectpoiTemplate = {
+ externalGraphic: 'config/img/symbol/'+ "${getGraphic}", graphicHeight: 26, graphicWidth:26, cursor:"pointer", fillOpacity: 0.7
+//Definieren der POI-Styles
+var poiStyle = new OpenLayers.Style(poitemplate, {context: poicontext});
+var poiStyleselect = new OpenLayers.Style(selectpoiTemplate, {context: poicontext});
+//StyleMap der POIs
+var styleMapPoi = new OpenLayers.StyleMap({
+ 'default':poiStyle,
+ 'select':poiStyleselect
//default Style für Zeich- / Messfunktion)
var style = new OpenLayers.Style();
style.addRules([
@@ -737,14 +794,16 @@
//Suchfeld
- $('#mapbendersearchfield').live('keypress', function(e) {
+ //$('#mapbendersearchfield').live('keypress', function(e) {
+ $(document).on('keypress', '#mapbendersearchfield', function(e) {
if(e.keyCode === 13){
searchMaps(searchUrl+'&searchText='+$('#mapbendersearchfield').val());
// Alle anderen Layer einklappen
- $('div[data-role=collapsible]').live('expand', function(){
+ //$('div[data-role=collapsible]').live('expand', function(){
+ $(document).on('expand', 'div[data-role=collapsible]', function(e) {
$("div[data-role=collapsible]").not($(this)).trigger("collapse");
@@ -1255,7 +1314,9 @@
// Vektorlayer
vector_marker = new OpenLayers.Layer.Vector("Vector Layer", {});
+ gps_marker = new OpenLayers.Layer.Vector("gps_marker", {
+ rendererOptions: {zIndexing: true}
// Hintergrund:Topographie ect.
/* var atkis_praes_tms = new OpenLayers.Layer.TMS(
"Hybrid",
@@ -1316,7 +1377,7 @@
$('#baselayers').append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));
- map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker]);
+ map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker,gps_marker]);
// Dynamische Hintergrundkarten hinzufügen
for(i in baseinfo){
@@ -1379,7 +1440,7 @@
//map.zoomToMaxExtent();
//map.setCenter(new OpenLayers.LonLat(739108, 6403856),10);
- var geolocate = new OpenLayers.Control.Geolocate({
+ /* var geolocate = new OpenLayers.Control.Geolocate({
geolocationOptions: {
enableHighAccuracy: true,
@@ -1389,8 +1450,8 @@
map.addControl(geolocate);
- geolocate.events.register("locationupdated", this, function(e) {
+/* geolocate.events.register("locationupdated", this, function(e) {
vector_marker.removeAllFeatures();
vector_marker.addFeatures([
@@ -1410,14 +1471,7 @@
olGpscircleStyle
- console.log(e.point.x + " - " + e.point.y);
- console.log(map.maxExtent.top);
- console.log(map.maxExtent.bottom);
- console.log(map.maxExtent.left);
- console.log(map.maxExtent.right);
- //Wenn Standoert innerhalb Maxextent
if(e.point.x > map.maxExtent.left && e.point.x < map.maxExtent.right && e.point.y > map.maxExtent.bottom && e.point.y < map.maxExtent.top){
setMarkerhint(window.lang.convert('Positionsgenauigkeit:'),'~ ' + e.position.coords.accuracy + ' Meter');
map.zoomToExtent(vector_marker.getDataExtent());
@@ -1426,7 +1480,7 @@
alert(window.lang.convert('Die ermittelte Position liegt außerhalb des darstellbaren Kartenausschnitts!'));
$('#markerhint').css('visibility','hidden');
@@ -1475,7 +1529,6 @@
//Initialisierung
$(document).ready(function() {
// Start with the map page
if (window.location.hash && window.location.hash!='#mappage') {
$.mobile.changePage($("#mappage"),pageTransition);
@@ -1572,7 +1625,7 @@
//Suchfeld
- $('#searchfield').live('keypress', function(e) {
+ $(document).on('keypress', '#searchfield', function(e) {
searchCall();
@@ -1582,10 +1635,40 @@
$(".mapbackbut").click(function(){
$('body').css('overflow', 'hidden');
+ //Popup für erweitertes Popup-Menü initialisieren und öffnen
+ $("#popupMenu").popup();
+ $("#menubut").click(function(){
+ $("#popupMenu").popup( "open" );
+ //Popup für Geolocation Dialog öffnen
+ $("#popupMenu_gps").popup();
+ $("#locatebut").click(function(){
+ $("#popupMenu_gps").popup( "open");
+ //Ausrichtung Popup links oben berechnen und mit hilfsdiv popuppos ausrichten
+ var popupheight = $("#popupMenu_gps").height() / 2 + 68;
+ $('#popuppos').css({top: popupheight+'px'});
+ $("#popupMenu_gps").popup( "open", {x:0,y:0,positionTo:'#popuppos'});
+ //GPS Status ändern
+ $("#gpsstatus").change(function(){
+ var mystatus = this.value;
+ if(mystatus === "on"){
+ startgpsWatch();
+ else{
+ stopgpsWatch();
//Geolocation Aktivieren
- $("#locatebut").click(function(){
+/* $("#locatebut").click(function(){
setMarkerhint(window.lang.convert('Meldung:'),window.lang.convert('bitte warten...'));
var control = map.getControlsBy("id", "locate-control")[0];
if (control.active) {
@@ -1593,7 +1676,7 @@
} else {
control.activate();
//Baselayer einstellen
@@ -1706,7 +1789,7 @@
//Suchbutton
- $('.searchbutton').live('touchstart', function(e) {
+ $(document).on('touchstart', '.searchbutton', function(e) {
$(this).css("border","2px solid #808080");
@@ -2205,4 +2288,115 @@
+//GPS Start Watch Funktion
+var startgpsWatch = function(){
+ if(navigator.geolocation){
+ $('#gpsmessage').html('<div id="gpsmessagebox">start watching...</div>');
+ gpswatch = navigator.geolocation.watchPosition(gpsokCallback, gpsfailCallback, gpsOptions);
+//GPS Stop Watch Funktion
+var stopgpsWatch = function(){
+ navigator.geolocation.clearWatch(gpswatch);
+ $('#gpsmessage').html("");
+ $("#gpsinfo").css('visibility','hidden');
+ gps_marker.removeAllFeatures();
+ $("#activePosition").val("");
+//GPS Erfolgs Callback
+var gpsokCallback = function(position){
+ var gpsmsg = '' +
+ 'Lat: ' + position.coords.latitude + "<br>" +
+ 'Lon: ' + position.coords.longitude + "<br>" +
+ 'Genauigkeit: ~' + Math.round(position.coords.accuracy) + ' m';
+ /*var gpszoombut = '<br>' +
+ '<a href="#" id="zoomGpspoint" data-role="button" data-icon="arrow-r" data-iconpos="right" data-inline="true" data-mini="true" >Zoom auf Position</a>' +
+ '<br><br>' +
+ '<a href="#" id="searchGpspoint" data-role="button" data-icon="search" data-iconpos="right" data-inline="true" data-mini="true" >Suche in der Nähe</a>' +
+ '<br><br>';*/
+ var gpszoombut = '<br>' +
+ '<br><br>';
+ $('#gpsmessage').html(gpszoombut);
+ $('#gpsinfo').html('<strong>Positionierung aktiv</strong><br>' + gpsmsg);
+ $("#gpsinfo").css('visibility','visible');
+ var wgspoint = new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude);
+ var transpoint = wgspoint.transform(wgs84Proj,mapProj);
+ //Zoombutton erzeugen
+ $("#zoomGpspoint").bind( "click", function(event, ui) {
+ map.setCenter(transpoint,getZoomlevel());
+ $("#zoomGpspoint").button();
+ //Suchbutton erzeugen
+ $("#searchGpspoint").bind( "click", function(event, ui) {
+ $.mobile.changePage($("#searchpage2"),pageTransition);
+ $("#searchSort").val('sortdist1');
+ $('#searchSort').selectmenu('refresh');
+ $('#search_results_poi').empty();
+ $('#searchfield_poi').empty();
+ $("#searchGpspoint").button();
+ $("#activePosition").val(Math.round(transpoint.lon) + "," + Math.round(transpoint.lat));
+ //Wenn Standoert innerhalb Maxextent
+ if(transpoint.lon > map.maxExtent.left && transpoint.lon < map.maxExtent.right && transpoint.lat > map.maxExtent.bottom && transpoint.lat < map.maxExtent.top){
+ var geompoint = new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat);
+ var geompoint1 = new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat);
+ gps_marker.addFeatures([
+ new OpenLayers.Feature.Vector(
+ geompoint,
+ olGpsSymbol
+ OpenLayers.Geometry.Polygon.createRegularPolygon(
+ new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat),
+ position.coords.accuracy / 2,
+ 50,
+ 0
+ olGpscircleStyle
+ //Immer im center halten
+ if($('#gpscenter').val() === "on"){
+ map.setCenter(transpoint);
+ else{
+ alert(window.lang.convert('Die ermittelte Position liegt außerhalb des darstellbaren Kartenausschnitts!'));
+ $("#gpsstatus").val('off');
+ $("#gpsstatus").slider('refresh');
+ stopgpsWatch();
+//GPS Fehler Callback
+var gpsfailCallback = function(e){
+ var msg = 'Fehler ' + e.code + ': ' + e.message;
+ //console.log(msg);
+//GPS Optionen
+var gpsOptions = {
+ enableHighAccuracy: true,
+ timeout: 5000,
+ maximumAge: 0
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -11,8 +11,10 @@
this,this.increaseCounter),a.layer.events.register("loadend",this,this.decreaseCounter))},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register("preaddlayer",this,this.addLayer);for(var b=0;b<this.map.layers.length;b++){var c=this.map.layers[b];c.events.register("loadstart",this,this.increaseCounter);c.events.register("loadend",this,this.decreaseCounter)}},increaseCounter:function(){this.counter++;0<this.counter&&!this.maximized&&this.visible&&this.maximizeControl()},
decreaseCounter:function(){0<this.counter&&this.counter--;0==this.counter&&this.maximized&&this.visible&&this.minimizeControl()},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);return this.div},minimizeControl:function(a){this.div.style.display="none";this.maximized=!1;null!=a&&OpenLayers.Event.stop(a)},maximizeControl:function(a){this.div.style.display="block";this.maximized=!0;null!=a&&OpenLayers.Event.stop(a)},destroy:function(){if(this.map&&(this.map.events.unregister("preaddlayer",
this,this.addLayer),this.map.layers))for(var a=0;a<this.map.layers.length;a++){var b=this.map.layers[a];b.events.unregister("loadstart",this,this.increaseCounter);b.events.unregister("loadend",this,this.decreaseCounter)}OpenLayers.Control.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.LoadingPanel"});
-var map,clickCtrl,measureControls,olSearchSymbol={graphicName:"cross",strokeColor:"#00FFFF",strokeWidth:1,fillOpacity:0,pointRadius:11},olFeaturequerySymbol={graphicName:"circle",strokeColor:"#00FFFF",fillColor:"#00FFFF",strokeWidth:3,fillOpacity:0.2,pointRadius:15,graphicName:"circle"},olGpsSymbol={graphicName:"cross",strokeColor:"#871D33",strokeWidth:2,fillOpacity:0,pointRadius:12},olGpscircleStyle={fillOpacity:0.1,fillColor:"#000",strokeColor:"#871D33",strokeOpacity:0.6},sketchSymbolizers={Point:{pointRadius:6,
-graphicName:"square",fillColor:"white",fillOpacity:1,strokeWidth:2,strokeOpacity:0.8,strokeColor:"#00FFFF"},Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000"},Polygon:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000",fillColor:"white",fillOpacity:0.5}},style=new OpenLayers.Style;style.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);var styleMap=new OpenLayers.StyleMap({"default":style});
+var map,clickCtrl,measureControls,olSearchSymbol={graphicName:"cross",strokeColor:"#00FFFF",strokeWidth:1,fillOpacity:0,pointRadius:11},olFeaturequerySymbol={graphicName:"circle",strokeColor:"#00FFFF",fillColor:"#00FFFF",strokeWidth:3,fillOpacity:0.2,pointRadius:15,graphicName:"circle"},olGpsSymbol={externalGraphic:"css/images/gpspoint.png",graphicHeight:16,graphicWidth:16},olGpscircleStyle={fillOpacity:0.2,fillColor:"#06C",strokeColor:"#06C",strokeOpacity:0.6},sketchSymbolizers={Point:{pointRadius:6,
+graphicName:"square",fillColor:"white",fillOpacity:1,strokeWidth:2,strokeOpacity:0.8,strokeColor:"#00FFFF"},Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000"},Polygon:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000",fillColor:"white",fillOpacity:0.5}},umkreisstyles=new OpenLayers.StyleMap({"default":new OpenLayers.Style(null,{rules:[new OpenLayers.Rule({symbolizer:{Point:{pointRadius:5,graphicName:"circle",fillColor:"white",fillOpacity:0.6,strokeWidth:1,strokeOpacity:1,strokeColor:"#CC0000"},
+Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#CC0000"},Polygon:{strokeWidth:2,strokeOpacity:1,fillColor:"#CC0000",strokeColor:"#CC0000"}}})]})}),poicontext={getGraphic:function(a){return a.attributes.symbol}},poitemplate={externalGraphic:"config/img/symbol/${getGraphic}",graphicHeight:26,graphicWidth:26,cursor:"pointer"},selectpoiTemplate={externalGraphic:"config/img/symbol/${getGraphic}",graphicHeight:26,graphicWidth:26,cursor:"pointer",fillOpacity:0.7},poiStyle=new OpenLayers.Style(poitemplate,
+{context:poicontext}),poiStyleselect=new OpenLayers.Style(selectpoiTemplate,{context:poicontext}),styleMapPoi=new OpenLayers.StyleMap({"default":poiStyle,select:poiStyleselect}),style=new OpenLayers.Style;style.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);var styleMap=new OpenLayers.StyleMap({"default":style});
function Service(a,b,c,d,e,f,g,h){a=$("<li>",{serviceid:a,"class":"service",title:b,desc:c,getMapURL:d,status:e,logoUrl:f,symbolLink:g,avail:h});d=$('<div class="service_container"></div>');d.append($('<table style="margin: 0px; padding: 0px; float:left;"><tr style="margin: 0px; padding: 0px;"><td style="margin: 0px; padding: 0px; height:43px; width:55px; text-align: center; vertical-align: middle;"><img style="max-height: 43px; max-width: 55px; max-height: 43px;" src="'+f+'" class="service_logo" alt="Logo"/></td></tr></table>'));
d.append($("<div>",{"class":"icon layer_remove",text:" "}).click(function(){removeService($(this).parent().parent())}));d.append($("<div>",{"class":"icon layer_add",text:" "}).click(function(){addService($(this).parent().parent())}));d.append('<div class="collapsible unselected" data-role="collapsible" data-collapsed="true" data-theme="a" data-content-theme="c" data-inset="true"><h3>'+b+"</h3><h3>"+b+"</h3><p>"+c+"</p></div>");a.append(d);return a}
function BaseLayer(a,b){return $("<div>",{text:a,title:a,layerids:b,"class":"baselayer base_unchecked"}).click(function(){switchVisibility($(this))})}
@@ -25,8 +27,8 @@
d=$("#select-lang").val(),e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);e="p"===$("#select-feature-info").val()?!0:!1;!0==e?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):0==c.length?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):
($.mobile.changePage($("#featureinforesult"),pageTransition),$("#ficontentdiv").text(window.lang.convert("Bitte warten...")));0<c.length?(a=c.attr("getmapurl")+"&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),
setMarkerhint("Abfrageergebnis:",a)):(a=$('<iframe src="'+a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterqueryWms.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+
-"&searchText="+$("#mapbendersearchfield").val())});$("#mapbendersearchfield").live("keypress",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
-function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
+"&searchText="+$("#mapbendersearchfield").val())});$(document).on("keypress","#mapbendersearchfield",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$(document).on("expand","div[data-role=collapsible]",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});
+addBaselayers()}function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
getInfo=function(a){$("#info_content").empty();$("#info_content").append(a);$("#info").popup("open")};function getOpenlayersIndex(a){for(var b=0;b<map.layers.length;b++)if(map.layers[b].name==a)return b;return-1}function addOpenlayer(a,b,c){a=new OpenLayers.Layer.WMS(a,c,{layers:b,format:"image/png",transparent:"TRUE",transitionEffect:"resize"},{projection:mapProj,units:projUnits,opacity:0.8,singleTile:!0,isBaseLayer:!1,visibility:!0,alwaysInRange:!0});map.addLayer(a);map.setLayerIndex(a,0)}
function removeOpenlayer(a){a=getOpenlayersIndex(a);0<=a&&map.removeLayer(map.layers[a])}function setOpenBaselayer(a){a=getOpenlayersIndex(a);0<=a&&map.setBaseLayer(map.layers[a])}function selectOpenlayer(a,b){var c=getOpenlayersIndex(a);0<=c&&map.layers[c].setVisibility(b)}
function addOpenBaselayer(a,b){$.getJSON("mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&resourceIds="+b,function(b){$.each(b.wms.srv,function(b,c){$.each(c.layer,function(b,d){d.layer&&(d=d.layer[0]);var h=new OpenLayers.Layer.WMS(a,c.getMapUrl,{layers:d.name,format:"image/png",transparent:"false",transitionEffect:"resize"},{projection:mapProj,units:projUnits,singleTile:!0,isBaseLayer:!0,alwaysInRange:!0});map.addLayers([h])})})})}
@@ -48,21 +50,19 @@
function appendWmcData(a,b,c,d,e){$("#ownlist").empty();for(var f=[],g=0;g<a.length;g++)for(var h=a[g],j=0;j<b.length;j++){var k=b[j],l=k[1];k[0]==h.id&&f.push(OwnLayer(l.id,l.title,l.name,$(l).attr("abstract"),h.title,$(h).attr("abstract"),l.previewURL,"1"==l.queryable,h.getMapUrl,l.bbox,h.avail))}for(g=0;g<c.length;g++)for(j=0;j<f.length;j++)if(c[g].layerId==f[j].attr("layerid")){k=f[j];$("#ownlist").append(k);addOpenlayer(k.attr("layerid"),k.attr("name"),k.attr("getMapUrl"));c[g].active||switchVisibility(k);
break}validateLayers();validateArrows();b=d.split(",");a=(new OpenLayers.LonLat(b[0],b[1])).transform(e,mapProj);e=(new OpenLayers.LonLat(b[2],b[3])).transform(e,mapProj);map.zoomToExtent(new OpenLayers.Bounds(a.lon,a.lat,e.lon,e.lat))}function clearOwnlist(){for(var a=$("#ownlist").find(".layer"),b=0;b<a.length;b++)removeLayer(a[b])}
function appendWmc(a){for(var b=0;b<a.backGroundLayer.length;b++){var c=a.backGroundLayer[b];if(c.active)for(var d=$("#baselayers").find(".baselayer"),e=0;e<d.length;e++)if($(d[e]).attr("layerids")==c.name){switchVisibility(d[e]);break}}clearOwnlist();var f="";$.each(a.layerList,function(a,b){f=f+","+b.layerId});f=f.substr(1,f.length);$.getJSON(searchUrl+"&resourceIds="+f,function(b){b=parseMapBenderJson(b);appendWmcData(b.services,b.layers,a.layerList,a.wmc.bbox,a.wmc.crs);$.mobile.hidePageLoadingMsg()})}
-function addBaselayers(){$("#baselayers").empty();vector_marker=new OpenLayers.Layer.Vector("Vector Layer",{});$("#baselayers").append(BaseLayer("RLP Zusammenstellung",atkis_praes_tms.name));$("#baselayers").append(BaseLayer("Luftbilder",luftbilder.name));$("#baselayers").append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker]);for(i in baseinfo){var a=baseinfo[i][0],b=baseinfo[i][1];$("#baselayers").append(BaseLayer(a,b));
-addOpenBaselayer(a,b)}base_check($("#baselayers").find(".baselayer").first())}
+function addBaselayers(){$("#baselayers").empty();vector_marker=new OpenLayers.Layer.Vector("Vector Layer",{});gps_marker=new OpenLayers.Layer.Vector("gps_marker",{rendererOptions:{zIndexing:!0}});$("#baselayers").append(BaseLayer("RLP Zusammenstellung",atkis_praes_tms.name));$("#baselayers").append(BaseLayer("Luftbilder",luftbilder.name));$("#baselayers").append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker,gps_marker]);
+for(i in baseinfo){var a=baseinfo[i][0],b=baseinfo[i][1];$("#baselayers").append(BaseLayer(a,b));addOpenBaselayer(a,b)}base_check($("#baselayers").find(".baselayer").first())}
var initmap=function(){var a={theme:null,projection:mapProj,units:projUnits,maxExtent:mymapbounds,maxScale:mymaxscale,minScale:myminscale,numZoomLevels:myzoomlevels,scales:myscales,controls:[new OpenLayers.Control.Attribution,new OpenLayers.Control.Navigation({zoomWheelEnabled:!0}),new OpenLayers.Control.KeyboardDefaults,new OpenLayers.Control.TouchNavigation({dragPanOptions:{interval:10,enableKinetic:!0}}),new OpenLayers.Control.ScaleLine({div:document.getElementById("scaleline"),geodesic:!1,maxWidth:100,
-topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null}),new OpenLayers.Control.LoadingPanel({})]};map=new OpenLayers.Map("map",a);addmyLayer();"off"!==myzoombounds?map.zoomToExtent(myzoombounds):map.zoomToExtent(map.maxExtent);a=new OpenLayers.Control.Geolocate({id:"locate-control",geolocationOptions:{enableHighAccuracy:!0,maximumAge:0,timeout:7E3}});map.addControl(a);a.events.register("locationupdated",this,function(a){vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(a.point,
-{},olGpsSymbol),new OpenLayers.Feature.Vector(OpenLayers.Geometry.Polygon.createRegularPolygon(new OpenLayers.Geometry.Point(a.point.x,a.point.y),a.position.coords.accuracy/2,50,0),{},olGpscircleStyle)]);a.point.x>map.maxExtent.left&&a.point.x<map.maxExtent.right&&a.point.y>map.maxExtent.bottom&&a.point.y<map.maxExtent.top?(setMarkerhint(window.lang.convert("Positionsgenauigkeit:"),"~ "+a.position.coords.accuracy+" Meter"),map.zoomToExtent(vector_marker.getDataExtent())):(alert(window.lang.convert("Die ermittelte Position liegt au\u00dferhalb des darstellbaren Kartenausschnitts!")),
-$("#markerhint").css("visibility","hidden"))});a=new OpenLayers.Style;a.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);a=new OpenLayers.StyleMap({"default":a});measureControls={line:new OpenLayers.Control.Measure(OpenLayers.Handler.Path,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}}),polygon:new OpenLayers.Control.Measure(OpenLayers.Handler.Polygon,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}})};for(var b in measureControls)a=measureControls[b],a.events.on({measure:handleMeasurements,
-measurepartial:handleMeasurements}),map.addControl(a)};
-$(document).ready(function(){window.location.hash&&"#mappage"!=window.location.hash&&$.mobile.changePage($("#mappage"),pageTransition);initmap();zoomSelect&&($("#zoomscale").css("visibility","visible"),createZoomselect(),map.events.register("moveend",null,displayZoom));clickCtrl=new OpenLayers.Control.Click;map.addControl(clickCtrl);clickCtrl.activate();checkLayers();$("#autolayerchange").change(function(){directLayerChange=this.value});$("#layerbut").click(function(){$.mobile.changePage($("#layerpage"),pageTransition)});
-$("#searchbut").click(function(){$.mobile.changePage($("#searchpage"),pageTransition)});$("#helpbut").click(function(){$.mobile.changePage($("#helppage"),pageTransition)});$("#gearbut").click(function(){$.mobile.changePage($("#gearpage"),pageTransition)});$("#measurelinebut").click(function(){toggleMeasure("line")});$("#measurepolybut").click(function(){toggleMeasure("polygon")});$("#ovbut").click(function(){map.zoomToExtent(map.maxExtent)});$("#zoominbut").click(function(){map.zoomIn()});$("#zoomoutbut").click(function(){map.zoomOut()});
-$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#xheader").click(function(){$("#markerhint").css("visibility","hidden");vector_marker.removeAllFeatures()});$("#mheader").click(function(){$("#measurehint").css("visibility","hidden");toggleMeasure("off")});$("#searchformbut").click(function(){searchCall()});$("#searchfield").live("keypress",function(a){13===a.keyCode&&searchCall()});$(".mapbackbut").click(function(){$.mobile.changePage($("#mappage"),pageTransition);
-$("body").css("overflow","hidden")});$("#locatebut").click(function(){setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten..."));var a=map.getControlsBy("id","locate-control")[0];a.active?a.getCurrentLocation():a.activate()});$(".baselayer_check").click(function(){$(".baselayer_check").css("background-image","url(img/ico_basecheck.png)");$(this).css("background-image","url(img/ico_basecheck_active.png)");for(var a=0;a<map.layers.length;a++)$(this).attr("id")===map.layers[a].name&&
-map.setBaseLayer(map.layers[a]);clearanimation();checktranspage()});$(".layer_check").click(function(){for(var a=0;a<map.layers.length;a++)if($(this).attr("id")===map.layers[a].name)var b=a;map.layers[b].getVisibility()?(map.layers[b].setVisibility(!1),$(this).css("background-image","url(img/ico_check.png)")):(map.layers[b].setVisibility(!0),$(this).css("background-image","url(img/ico_check_active.png)"));clearanimation();checktranspage()});$(".poi_check").click(function(){var a=poilayer.params.LAYERS,
-b=[];""!=a&&(b=a.split(","));if(-1!=jQuery.inArray($(this).attr("id"),b)){for(a=0;a<b.length;a++)$(this).attr("id")===b[a]&&b.splice(a,1);$(this).css("background-image","url(img/ico_check.png)")}else b.push($(this).attr("id")),$(this).css("background-image","url(img/ico_check_active.png)");a=b.join(",");poilayer.mergeNewParams({layers:a});0<b.length&&poilayer.setVisibility(!0);poilayer.redraw();clearanimation();checktranspage()});$(".query_check").click(function(){$(".query_check").css("background-image",
-"url(img/ico_checkop.png)");$(this).css("background-image","url(img/ico_checkop_active.png)");var a=$(this).attr("id"),a=a.substring(0,a.length-6);$("#queryselect").val(a);clearanimation()});$(".query_check").touchstart(function(){$(this).css("background-color","#808080")});$(".layer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});$(".baselayer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});
-$(".navbuttons").touchstart(function(){$(this).css("border","2px solid #808080")});$(".navbuttons").touchend(function(){$(this).css("border","2px solid "+toolColor)});$(".searchbutton").live("touchstart",function(){$(this).css("border","2px solid #808080")});changeHand(defaultHand);$("#autolayerchange").val(directLayerChange);hideAddressBar()});
+topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null}),new OpenLayers.Control.LoadingPanel({})]};map=new OpenLayers.Map("map",a);addmyLayer();"off"!==myzoombounds?map.zoomToExtent(myzoombounds):map.zoomToExtent(map.maxExtent);a=new OpenLayers.Style;a.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);a=new OpenLayers.StyleMap({"default":a});measureControls={line:new OpenLayers.Control.Measure(OpenLayers.Handler.Path,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}}),
+polygon:new OpenLayers.Control.Measure(OpenLayers.Handler.Polygon,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}})};for(var b in measureControls)a=measureControls[b],a.events.on({measure:handleMeasurements,measurepartial:handleMeasurements}),map.addControl(a)};
+$(document).ready(function(){window.location.hash&&"#mappage"!=window.location.hash&&$.mobile.changePage($("#mappage"),pageTransition);initmap();zoomSelect&&($("#zoomscale").css("visibility","visible"),createZoomselect(),map.events.register("moveend",null,displayZoom));clickCtrl=new OpenLayers.Control.Click;map.addControl(clickCtrl);clickCtrl.activate();checkLayers();$("#autolayerchange").change(function(){directLayerChange=this.value});$("#layerbut").click(function(){$.mobile.changePage($("#layerpage"),
+pageTransition)});$("#searchbut").click(function(){$.mobile.changePage($("#searchpage"),pageTransition)});$("#helpbut").click(function(){$.mobile.changePage($("#helppage"),pageTransition)});$("#gearbut").click(function(){$.mobile.changePage($("#gearpage"),pageTransition)});$("#measurelinebut").click(function(){toggleMeasure("line")});$("#measurepolybut").click(function(){toggleMeasure("polygon")});$("#ovbut").click(function(){map.zoomToExtent(map.maxExtent)});$("#zoominbut").click(function(){map.zoomIn()});
+$("#zoomoutbut").click(function(){map.zoomOut()});$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#xheader").click(function(){$("#markerhint").css("visibility","hidden");vector_marker.removeAllFeatures()});$("#mheader").click(function(){$("#measurehint").css("visibility","hidden");toggleMeasure("off")});$("#searchformbut").click(function(){searchCall()});$(document).on("keypress","#searchfield",function(a){13===a.keyCode&&searchCall()});$(".mapbackbut").click(function(){$.mobile.changePage($("#mappage"),
+pageTransition);$("body").css("overflow","hidden")});$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#popupMenu_gps").popup();$("#locatebut").click(function(){$("#popupMenu_gps").popup("open")});$("#gpsstatus").change(function(){"on"===this.value?startgpsWatch():stopgpsWatch()});$(".baselayer_check").click(function(){$(".baselayer_check").css("background-image","url(img/ico_basecheck.png)");$(this).css("background-image","url(img/ico_basecheck_active.png)");
+for(var a=0;a<map.layers.length;a++)$(this).attr("id")===map.layers[a].name&&map.setBaseLayer(map.layers[a]);clearanimation();checktranspage()});$(".layer_check").click(function(){for(var a=0;a<map.layers.length;a++)if($(this).attr("id")===map.layers[a].name)var b=a;map.layers[b].getVisibility()?(map.layers[b].setVisibility(!1),$(this).css("background-image","url(img/ico_check.png)")):(map.layers[b].setVisibility(!0),$(this).css("background-image","url(img/ico_check_active.png)"));clearanimation();
+checktranspage()});$(".poi_check").click(function(){var a=poilayer.params.LAYERS,b=[];""!=a&&(b=a.split(","));if(-1!=jQuery.inArray($(this).attr("id"),b)){for(a=0;a<b.length;a++)$(this).attr("id")===b[a]&&b.splice(a,1);$(this).css("background-image","url(img/ico_check.png)")}else b.push($(this).attr("id")),$(this).css("background-image","url(img/ico_check_active.png)");a=b.join(",");poilayer.mergeNewParams({layers:a});0<b.length&&poilayer.setVisibility(!0);poilayer.redraw();clearanimation();checktranspage()});
+$(".query_check").click(function(){$(".query_check").css("background-image","url(img/ico_checkop.png)");$(this).css("background-image","url(img/ico_checkop_active.png)");var a=$(this).attr("id"),a=a.substring(0,a.length-6);$("#queryselect").val(a);clearanimation()});$(".query_check").touchstart(function(){$(this).css("background-color","#808080")});$(".layer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});$(".baselayer_check").touchstart(function(){$(this).css("background-color",
+"#808080");$(this).css("color","#FFFFFF")});$(".navbuttons").touchstart(function(){$(this).css("border","2px solid #808080")});$(".navbuttons").touchend(function(){$(this).css("border","2px solid "+toolColor)});$(document).on("touchstart",".searchbutton",function(){$(this).css("border","2px solid #808080")});changeHand(defaultHand);$("#autolayerchange").val(directLayerChange);hideAddressBar()});
var clearanimation=function(){$(".query_check").css("background-color","#808080");$(".layer_check, .baselayer_check, .poi_check").css("background-color","#FFFFFF");$(".layer_check, .baselayer_check, .poi_check").css("color","#000000")},checktranspage=function(){"on"===directLayerChange&&$.mobile.changePage($("#mappage"),pageTransition)},checkLayers=function(){$(".baselayer_check").each(function(){for(var a=0;a<map.layers.length;a++)map.layers[a].name===$(this).attr("id")&&map.layers[a].visibility&&
$(this).css("background-image","url(img/ico_basecheck_active.png)")});$(".layer_check").each(function(){for(var a=0;a<map.layers.length;a++)map.layers[a].name===$(this).attr("id")&&map.layers[a].visibility&&$(this).css("background-image","url(img/ico_check_active.png)")});$(".poi_check").each(function(){var a=poilayer.params.LAYERS,b=[];""!=a&&(b=a.split(","));-1!=jQuery.inArray($(this).attr("id"),b)&&$(this).css("background-image","url(img/ico_check.png)")});$(".query_check").each(function(){var a=
$(this).attr("id");a.substring(0,a.length-6)===$("#queryselect").val()&&$(this).css("background-image","url(img/ico_checkop_active.png)")})};function searchCall(){"google"===searchMode?codeAddress():"streetsearch"===searchMode?searchStreet($("#searchfield").val()):"mapbendersearch"===searchMode?searchMapbender($("#searchfield").val()):alert("kein Suchmodus konfiguriert!")}function setMarkerhint(a,b){$("#xheader").html(a);$("#xcontent").html(b);$("#markerhint").css("visibility","visible")}
@@ -86,4 +86,9 @@
function handleMeasurements(a){var b=a.units,c=a.order,a=a.measure,d=document.getElementById("measureoutput"),e="",e=1==c?e+(window.lang.convert("Entfernung: ")+"<strong>"+a.toFixed(2)+"</strong> "+b):e+(window.lang.convert("Fl\u00e4che: ")+"<strong>"+a.toFixed(2)+"</strong> "+b+"<sup>2</sup>");d.innerHTML=e}
function toggleMeasure(a){clickCtrl.deactivate();$("#popupMenu").popup("close");measureControls.line.deactivate();measureControls.polygon.deactivate();"line"===a?($("#measurehint").css("visibility","visible"),measureControls[a].activate(),$("#measureoutput").html(window.lang.convert("Entfernungsmessung aktiv!"))):"polygon"===a?($("#measurehint").css("visibility","visible"),measureControls[a].activate(),$("#measureoutput").html(window.lang.convert("Fl\u00e4chenmessung aktiv!"))):clickCtrl.activate()}
function setmapsize(){window.scrollTo(0,0);var a=$.mobile.getScreenHeight(),b=$('[data-role="header"]').first().outerHeight(),c=$('[data-role="footer"]').first().outerHeight(),d=$('[data-role="content"]'),e=parseInt(d.css("padding-left").replace("px",""))+parseInt($('[data-role="content"]').css("padding-right").replace("px","")),f=parseInt(d.css("padding-top").replace("px",""))+parseInt($('[data-role="content"]').css("padding-bottom").replace("px","")),a=a-b-c-f;winwide=$(document).width();winwide-=
-e;d.css("width",winwide+"px").css("height",a+"px");$("#map").css("width",winwide+"px").css("height",a+"px")}function checkZindex(){for(var a=map.layers,b=0,c=a.length;b<c;b++)"tk_grau"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex),"Vector Layer"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex)};
+e;d.css("width",winwide+"px").css("height",a+"px");$("#map").css("width",winwide+"px").css("height",a+"px")}function checkZindex(){for(var a=map.layers,b=0,c=a.length;b<c;b++)"tk_grau"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex),"Vector Layer"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex)}
+var startgpsWatch=function(){navigator.geolocation&&($("#gpsmessage").html('<div id="gpsmessagebox">start watching...</div>'),gpswatch=navigator.geolocation.watchPosition(gpsokCallback,gpsfailCallback,gpsOptions))},stopgpsWatch=function(){navigator.geolocation.clearWatch(gpswatch);$("#gpsmessage").html("");$("#gpsinfo").css("visibility","hidden");gps_marker.removeAllFeatures();$("#activePosition").val("")},gpsokCallback=function(a){var b="Lat: "+a.coords.latitude+"<br>Lon: "+a.coords.longitude+"<br>Genauigkeit: ~"+
+Math.round(a.coords.accuracy)+" m";$("#gpsmessage").html('<br><a href="#" id="zoomGpspoint" data-role="button" data-icon="arrow-r" data-iconpos="right" data-inline="true" data-mini="true" >Zoom auf Position</a><br><br>');$("#gpsinfo").html("<strong>Positionierung aktiv</strong><br>"+b);$("#gpsinfo").css("visibility","visible");var c=(new OpenLayers.LonLat(a.coords.longitude,a.coords.latitude)).transform(wgs84Proj,mapProj);$("#zoomGpspoint").bind("click",function(){map.setCenter(c,getZoomlevel())});
+$("#zoomGpspoint").button();$("#searchGpspoint").bind("click",function(){$.mobile.changePage($("#searchpage2"),pageTransition);$("#searchSort").val("sortdist1");$("#searchSort").selectmenu("refresh");$("#search_results_poi").empty();$("#searchfield_poi").empty()});$("#searchGpspoint").button();$("#activePosition").val(Math.round(c.lon)+","+Math.round(c.lat));c.lon>map.maxExtent.left&&c.lon<map.maxExtent.right&&c.lat>map.maxExtent.bottom&&c.lat<map.maxExtent.top?(b=new OpenLayers.Geometry.Point(c.lon,
+c.lat),new OpenLayers.Geometry.Point(c.lon,c.lat),gps_marker.removeAllFeatures(),gps_marker.addFeatures([new OpenLayers.Feature.Vector(b,{},olGpsSymbol),new OpenLayers.Feature.Vector(OpenLayers.Geometry.Polygon.createRegularPolygon(new OpenLayers.Geometry.Point(c.lon,c.lat),a.coords.accuracy/2,50,0),{},olGpscircleStyle)]),"on"===$("#gpscenter").val()&&map.setCenter(c)):(alert(window.lang.convert("Die ermittelte Position liegt au\u00dferhalb des darstellbaren Kartenausschnitts!")),$("#gpsstatus").val("off"),
+$("#gpsstatus").slider("refresh"),stopgpsWatch())},gpsfailCallback=function(){},gpsOptions={enableHighAccuracy:!0,timeout:5E3,maximumAge:0};
Added: trunk/mapbender/http/extensions/mobilemap/css/images/ajax-loader.gif
(Binary files differ)
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/ajax-loader.gif
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/mapbender/http/extensions/mobilemap/css/images/gpspoint.png
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/gpspoint.png
Added: trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-black.png
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-black.png
Added: trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-white.png
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/icons-18-white.png
Added: trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-black.png
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-black.png
Added: trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-white.png
Property changes on: trunk/mapbender/http/extensions/mobilemap/css/images/icons-36-white.png
Added: trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.custom.min.css
--- trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.custom.min.css (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.custom.min.css 2013-07-18 03:44:11 UTC (rev 8674)
@@ -0,0 +1,12 @@
+* jQuery Mobile 1.3.1
+* Git HEAD hash: 74b4bec049fd93e4fe40205e6157de16eb64eb46 <> Date: Mon Apr 8 2013 19:41:28 UTC
+* http://jquerymobile.com
+* Copyright 2010, 2013 jQuery Foundation, Inc. and other contributors
+* Released under the MIT license.
+* http://jquery.org/license
+.ui-bar-a{border:1px solid #b3b3b3 ;background:#eeeeee ;color:#3e3e3e ;font-weight:bold;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f0f0f0 ),to( #dddddd )); background-image:-webkit-linear-gradient( #f0f0f0,#dddddd ); background-image: -moz-linear-gradient( #f0f0f0,#dddddd ); background-image: -ms-linear-gradient( #f0f0f0,#dddddd ); background-image: -o-linear-gradient( #f0f0f0,#dddddd ); background-image: linear-gradient( #f0f0f0,#dddddd );}.ui-bar-a .ui-link-inherit{color:#3e3e3e ;}.ui-bar-a a.ui-link{color:#7cc4e7 ;font-weight:bold;}.ui-bar-a a.ui-link:visited{ color:#2489ce ;}.ui-bar-a a.ui-link:hover{color:#2489ce ;}.ui-bar-a a.ui-link:active{color:#2489ce ;}.ui-bar-a,.ui-bar-a input,.ui-bar-a select,.ui-bar-a textarea,.ui-bar-a button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-a,.ui-overlay-a{border:1px solid #aaaaaa ;color:#333333 ;text-shadow:0 1px 0 #ffffff ;background:#f9f9f9 ;back
ground-image:-webkit-gradient(linear,left top,left bottom,from( #f9f9f9 ),to( #eeeeee )); background-image:-webkit-linear-gradient( #f9f9f9,#eeeeee ); background-image: -moz-linear-gradient( #f9f9f9,#eeeeee ); background-image: -ms-linear-gradient( #f9f9f9,#eeeeee ); background-image: -o-linear-gradient( #f9f9f9,#eeeeee ); background-image: linear-gradient( #f9f9f9,#eeeeee );}.ui-overlay-a{background-image:none;border-width:0;}.ui-body-a,.ui-body-a input,.ui-body-a select,.ui-body-a textarea,.ui-body-a button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-a .ui-link-inherit{color:#333333 ;}.ui-body-a .ui-link{color:#871D33 ;font-weight:bold;}.ui-body-a .ui-link:visited{ color:#2489ce ;}.ui-body-a .ui-link:hover{color:#2489ce ;}.ui-body-a .ui-link:active{color:#2489ce ;}.ui-btn-up-a{border:1px solid #cccccc ;background:#eeeeee ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,fro
m( #ffffff ),to( #f1f1f1 )); background-image:-webkit-linear-gradient( #ffffff,#f1f1f1 ); background-image: -moz-linear-gradient( #ffffff,#f1f1f1 ); background-image: -ms-linear-gradient( #ffffff,#f1f1f1 ); background-image: -o-linear-gradient( #ffffff,#f1f1f1 ); background-image: linear-gradient( #ffffff,#f1f1f1 );}.ui-btn-up-a:visited,.ui-btn-up-a a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-hover-a{border:1px solid #bbbbbb ;background:#dfdfdf ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f6f6f6 ),to( #e0e0e0 )); background-image:-webkit-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -moz-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -ms-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -o-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: linear-gradient( #f6f6f6,#e0e0e0 );}.ui-btn-hover-a:visited,.ui-btn-hover-a:hover,.ui-btn-hover-a
a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-down-a{border:1px solid #bbbbbb ;background:#d6d6d6 ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #d0d0d0 ),to( #dfdfdf )); background-image:-webkit-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -moz-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -ms-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -o-linear-gradient( #d0d0d0,#dfdfdf ); background-image: linear-gradient( #d0d0d0,#dfdfdf );}.ui-btn-down-a:visited,.ui-btn-down-a:hover,.ui-btn-down-a a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-up-a,.ui-btn-hover-a,.ui-btn-down-a{font-family:Helvetica,Arial,sans-serif ;text-decoration:none;}.ui-bar-b{border:1px solid #b3b3b3 ;background:#eeeeee ;color:#3e3e3e ;font-weight:bold;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f0f0f0 ),to( #dddddd )); background-image:-
webkit-linear-gradient( #f0f0f0,#dddddd ); background-image: -moz-linear-gradient( #f0f0f0,#dddddd ); background-image: -ms-linear-gradient( #f0f0f0,#dddddd ); background-image: -o-linear-gradient( #f0f0f0,#dddddd ); background-image: linear-gradient( #f0f0f0,#dddddd );}.ui-bar-b .ui-link-inherit{color:#3e3e3e ;}.ui-bar-b a.ui-link{color:#7cc4e7 ;font-weight:bold;}.ui-bar-b a.ui-link:visited{ color:#2489ce ;}.ui-bar-b a.ui-link:hover{color:#2489ce ;}.ui-bar-b a.ui-link:active{color:#2489ce ;}.ui-bar-b,.ui-bar-b input,.ui-bar-b select,.ui-bar-b textarea,.ui-bar-b button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-b,.ui-overlay-b{border:1px solid #aaaaaa ;color:#333333 ;text-shadow:0 1px 0 #ffffff ;background:#f9f9f9 ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f9f9f9 ),to( #eeeeee )); background-image:-webkit-linear-gradient( #f9f9f9,#eeeeee ); background-image: -moz-linear-gradient( #f9f9f9,#eeeeee ); background-image:
-ms-linear-gradient( #f9f9f9,#eeeeee ); background-image: -o-linear-gradient( #f9f9f9,#eeeeee ); background-image: linear-gradient( #f9f9f9,#eeeeee );}.ui-overlay-b{background-image:none;border-width:0;}.ui-body-b,.ui-body-b input,.ui-body-b select,.ui-body-b textarea,.ui-body-b button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-b .ui-link-inherit{color:#333333 ;}.ui-body-b .ui-link{color:#871D33 ;font-weight:bold;}.ui-body-b .ui-link:visited{ color:#2489ce ;}.ui-body-b .ui-link:hover{color:#2489ce ;}.ui-body-b .ui-link:active{color:#2489ce ;}.ui-btn-up-b{border:1px solid #cccccc ;background:#eeeeee ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #ffffff ),to( #f1f1f1 )); background-image:-webkit-linear-gradient( #ffffff,#f1f1f1 ); background-image: -moz-linear-gradient( #ffffff,#f1f1f1 ); background-image: -ms-linear-gradient( #ffffff,#f1f1f1 ); background-image:
-o-linear-gradient( #ffffff,#f1f1f1 ); background-image: linear-gradient( #ffffff,#f1f1f1 );}.ui-btn-up-b:visited,.ui-btn-up-b a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-hover-b{border:1px solid #bbbbbb ;background:#dfdfdf ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f6f6f6 ),to( #e0e0e0 )); background-image:-webkit-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -moz-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -ms-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -o-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: linear-gradient( #f6f6f6,#e0e0e0 );}.ui-btn-hover-b:visited,.ui-btn-hover-b:hover,.ui-btn-hover-b a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-down-b{border:1px solid #bbbbbb ;background:#d6d6d6 ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #d0d0
d0 ),to( #dfdfdf )); background-image:-webkit-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -moz-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -ms-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -o-linear-gradient( #d0d0d0,#dfdfdf ); background-image: linear-gradient( #d0d0d0,#dfdfdf );}.ui-btn-down-b:visited,.ui-btn-down-b:hover,.ui-btn-down-b a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-up-b,.ui-btn-hover-b,.ui-btn-down-b{font-family:Helvetica,Arial,sans-serif ;text-decoration:none;}.ui-bar-c{border:1px solid #b3b3b3 ;background:#eeeeee ;color:#3e3e3e ;font-weight:bold;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f0f0f0 ),to( #dddddd )); background-image:-webkit-linear-gradient( #f0f0f0,#dddddd ); background-image: -moz-linear-gradient( #f0f0f0,#dddddd ); background-image: -ms-linear-gradient( #f0f0f0,#dddddd ); background-image: -o-linear-gradient( #f0f0f0,#dddddd ); backgr
ound-image: linear-gradient( #f0f0f0,#dddddd );}.ui-bar-c .ui-link-inherit{color:#3e3e3e ;}.ui-bar-c a.ui-link{color:#7cc4e7 ;font-weight:bold;}.ui-bar-c a.ui-link:visited{ color:#2489ce ;}.ui-bar-c a.ui-link:hover{color:#2489ce ;}.ui-bar-c a.ui-link:active{color:#2489ce ;}.ui-bar-c,.ui-bar-c input,.ui-bar-c select,.ui-bar-c textarea,.ui-bar-c button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-c,.ui-overlay-c{border:1px solid #aaaaaa ;color:#333333 ;text-shadow:0 1px 0 #ffffff ;background:#f9f9f9 ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f9f9f9 ),to( #eeeeee )); background-image:-webkit-linear-gradient( #f9f9f9,#eeeeee ); background-image: -moz-linear-gradient( #f9f9f9,#eeeeee ); background-image: -ms-linear-gradient( #f9f9f9,#eeeeee ); background-image: -o-linear-gradient( #f9f9f9,#eeeeee ); background-image: linear-gradient( #f9f9f9,#eeeeee );}.ui-overlay-c{background-image:none;border-width:0;}.ui-body-c,.ui-bo
dy-c input,.ui-body-c select,.ui-body-c textarea,.ui-body-c button{font-family:Helvetica,Arial,sans-serif ;}.ui-body-c .ui-link-inherit{color:#333333 ;}.ui-body-c .ui-link{color:#871D33 ;font-weight:bold;}.ui-body-c .ui-link:visited{ color:#2489ce ;}.ui-body-c .ui-link:hover{color:#2489ce ;}.ui-body-c .ui-link:active{color:#2489ce ;}.ui-btn-up-c{border:1px solid #cccccc ;background:#eeeeee ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #ffffff ),to( #f1f1f1 )); background-image:-webkit-linear-gradient( #ffffff,#f1f1f1 ); background-image: -moz-linear-gradient( #ffffff,#f1f1f1 ); background-image: -ms-linear-gradient( #ffffff,#f1f1f1 ); background-image: -o-linear-gradient( #ffffff,#f1f1f1 ); background-image: linear-gradient( #ffffff,#f1f1f1 );}.ui-btn-up-c:visited,.ui-btn-up-c a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-hover-c{border:1px solid #bbbbbb ;background:#dfdfdf ;
font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #f6f6f6 ),to( #e0e0e0 )); background-image:-webkit-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -moz-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -ms-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: -o-linear-gradient( #f6f6f6,#e0e0e0 ); background-image: linear-gradient( #f6f6f6,#e0e0e0 );}.ui-btn-hover-c:visited,.ui-btn-hover-c:hover,.ui-btn-hover-c a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-down-c{border:1px solid #bbbbbb ;background:#d6d6d6 ;font-weight:bold;color:#2f3e46 ;text-shadow:0 1px 0 #ffffff ;background-image:-webkit-gradient(linear,left top,left bottom,from( #d0d0d0 ),to( #dfdfdf )); background-image:-webkit-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -moz-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -ms-linear-gradient( #d0d0d0,#dfdfdf ); background-image: -o-lin
ear-gradient( #d0d0d0,#dfdfdf ); background-image: linear-gradient( #d0d0d0,#dfdfdf );}.ui-btn-down-c:visited,.ui-btn-down-c:hover,.ui-btn-down-c a.ui-link-inherit{color:#2f3e46 ;}.ui-btn-up-c,.ui-btn-hover-c,.ui-btn-down-c{font-family:Helvetica,Arial,sans-serif ;text-decoration:none;}a.ui-link-inherit{text-decoration:none !important;}.ui-btn-active{border:1px solid #871D33 ;background:#871D33 ;font-weight:bold;color:#ffffff ;cursor:pointer;text-shadow:0 1px 0 #871D33 ;text-decoration:none;background-image:-webkit-gradient(linear,left top,left bottom,from( #871d33 ),to( #871d33 )); background-image:-webkit-linear-gradient( #871d33,#871d33 ); background-image: -moz-linear-gradient( #871d33,#871d33 ); background-image: -ms-linear-gradient( #871d33,#871d33 ); background-image: -o-linear-gradient( #871d33,#871d33 ); background-image: linear-gradient( #871d33,#871d33 ); font-family:Helvetica,Arial,sans-serif ;}.ui-btn-active:visited,.ui-btn-active:hover,
.ui-btn-active a.ui-link-inherit{color:#ffffff ;}.ui-btn-inner{border-top:1px solid #fff;border-color:rgba(255,255,255,.3);}.ui-corner-all{-webkit-border-radius:.6em ;border-radius:.6em ;}.ui-br{border-color:rgb(130,130,130);border-color:rgba(130,130,130,.3);border-style:solid;}.ui-disabled{filter:Alpha(Opacity=30);opacity:.3;zoom:1;}.ui-disabled,.ui-disabled a{cursor:default !important;pointer-events:none;}.ui-icon,.ui-icon-searchfield:after{background-color:#871D33 ;background-color:rgba(135,29,51,0.4) ;background-image:url(images/icons-18-white.png) ;background-repeat:no-repeat;-webkit-border-radius:9px;border-radius:9px;}.ui-icon-alt .ui-icon,.ui-icon-alt .ui-icon-searchfield:after{background-color:#fff;background-color:rgba(255,255,255,.3);background-image:url(images/icons-18-black.png);background-repeat:no-repeat;}.ui-icon-nodisc .ui-icon,.ui-icon-nodisc .ui-icon-searchfield:after,.ui-icon-nodisc .ui-icon-alt .ui-icon,.ui-icon-nodisc .ui-icon-alt .ui-icon-searchfield:a
fter{background-color:transparent;}.ui-icon-plus{background-position:-1px -1px;}.ui-icon-minus{background-position:-37px -1px;}.ui-icon-delete{background-position:-73px -1px;}.ui-icon-arrow-r{background-position:-108px -1px;}.ui-icon-arrow-l{background-position:-144px -1px;}.ui-icon-arrow-u{background-position:-180px -1px;}.ui-icon-arrow-d{background-position:-216px -1px;}.ui-icon-check{background-position:-252px -1px;}.ui-icon-gear{background-position:-288px -1px;}.ui-icon-refresh{background-position:-323px -1px;}.ui-icon-forward{background-position:-360px -1px;}.ui-icon-back{background-position:-396px -1px;}.ui-icon-grid{background-position:-432px -1px;}.ui-icon-star{background-position:-467px -1px;}.ui-icon-alert{background-position:-503px -1px;}.ui-icon-info{background-position:-539px -1px;}.ui-icon-home{background-position:-575px -1px;}.ui-icon-search,.ui-icon-searchfield:after{background-position:-611px -1px;}.ui-icon-checkbox-on{background-position:-647px -1px;}.ui-ic
on-checkbox-off{background-position:-683px -1px;}.ui-icon-radio-on{background-position:-718px -1px;}.ui-icon-radio-off{background-position:-754px -1px;}.ui-icon-bars{background-position:-788px -1px;}.ui-icon-edit{background-position:-824px -1px;}@media only screen and (-webkit-min-device-pixel-ratio:1.3), only screen and (min--moz-device-pixel-ratio:1.3), only screen and (min-resolution:200dpi){.ui-icon-plus,.ui-icon-minus,.ui-icon-delete,.ui-icon-arrow-r,.ui-icon-arrow-l,.ui-icon-arrow-u,.ui-icon-arrow-d,.ui-icon-check,.ui-icon-gear,.ui-icon-refresh,.ui-icon-forward,.ui-icon-back,.ui-icon-grid,.ui-icon-star,.ui-icon-alert,.ui-icon-info,.ui-icon-home,.ui-icon-bars,.ui-icon-edit,.ui-icon-search,.ui-icon-searchfield:after,.ui-icon-checkbox-off,.ui-icon-checkbox-on,.ui-icon-radio-off,.ui-icon-radio-on{background-image:url(images/icons-36-white.png);-moz-background-size:864px 18px;-o-background-size:864px 18px;-webkit-background-size:864px 18px;background-size:864px 18
px;}.ui-icon-alt .ui-icon{background-image:url(images/icons-36-black.png);}.ui-icon-plus{background-position:0 50%;}.ui-icon-minus{background-position:-36px 50%;}.ui-icon-delete{background-position:-72px 50%;}.ui-icon-arrow-r{background-position:-108px 50%;}.ui-icon-arrow-l{background-position:-144px 50%;}.ui-icon-arrow-u{background-position:-179px 50%;}.ui-icon-arrow-d{background-position:-215px 50%;}.ui-icon-check{background-position:-252px 50%;}.ui-icon-gear{background-position:-287px 50%;}.ui-icon-refresh{background-position:-323px 50%;}.ui-icon-forward{background-position:-360px 50%;}.ui-icon-back{background-position:-395px 50%;}.ui-icon-grid{background-position:-431px 50%;}.ui-icon-star{background-position:-467px 50%;}.ui-icon-alert{background-position:-503px 50%;}.ui-icon-info{background-position:-538px 50%;}.ui-icon-home{background-position:-575px 50%;}.ui-icon-search,.ui-icon-searchfield:after{background-position:-611px 50%;}.ui-icon-checkbox-on{background-position:
-647px 50%;}.ui-icon-checkbox-off{background-position:-683px 50%;}.ui-icon-radio-on{background-position:-718px 50%;}.ui-icon-radio-off{background-position:-754px 50%;}.ui-icon-bars{background-position:-788px 50%;}.ui-icon-edit{background-position:-824px 50%;}}.ui-checkbox .ui-icon,.ui-selectmenu-list .ui-icon{-webkit-border-radius:3px;border-radius:3px;}.ui-icon-checkbox-off,.ui-icon-radio-off{background-color:transparent;}.ui-checkbox-on .ui-icon,.ui-radio-on .ui-icon{background-color:#871D33 ; }.ui-icon-loading{background:url(images/ajax-loader.gif);background-size:46px 46px;}.ui-btn-corner-all{-webkit-border-radius:1em ;border-radius:1em ;}.ui-corner-all,.ui-btn-corner-all{-webkit-background-clip:padding;background-clip:padding-box;}.ui-overlay{background:#666;filter:Alpha(Opacity=50);opacity:.5;position:absolute;width:100%;height:100%;}.ui-overlay-shadow{-moz-box-shadow:0 0 12px rgba(0,0,0,.6);-webkit-box-shadow:0 0 12px rgba(0,0,0,.6);box-shadow:0 0 12px rgba(0,0,0,.6);
}.ui-shadow{-moz-box-shadow:0 1px 3px rgba(0,0,0,.2) ;-webkit-box-shadow:0 1px 3px rgba(0,0,0,.2) ;box-shadow:0 1px 3px rgba(0,0,0,.2) }.ui-bar-a .ui-shadow,.ui-bar-b .ui-shadow,.ui-bar-c .ui-shadow {-moz-box-shadow:0 1px 0 rgba(255,255,255,.3);-webkit-box-shadow:0 1px 0 rgba(255,255,255,.3);box-shadow:0 1px 0 rgba(255,255,255,.3);}.ui-shadow-inset{-moz-box-shadow:inset 0 1px 4px rgba(0,0,0,.2);-webkit-box-shadow:inset 0 1px 4px rgba(0,0,0,.2);box-shadow:inset 0 1px 4px rgba(0,0,0,.2);}.ui-icon-shadow{-moz-box-shadow:0 1px 0 rgba(255,255,255,.4) ;-webkit-box-shadow:0 1px 0 rgba(255,255,255,.4) ;box-shadow:0 1px 0 rgba(255,255,255,.4) ;}.ui-btn:focus,.ui-link-inherit:focus{outline:0;}.ui-btn.ui-focus{z-index:1;}.ui-focus,.ui-btn:focus{-moz-box-shadow:inset 0 0 3px #871D33,0 0 9px #871D33 ;-webkit-box-shadow:inset 0 0 3px #871D33,0 0 9px #871D33 ;box-shadow:inset 0 0 3px #871D33,0 0 9px #871D33 ;}.ui-input-text.ui-focus,.ui-input-search.ui-focus{-moz-box-shadow:0 0 12px #87
1D33 ;-webkit-box-shadow:0 0 12px #871D33 ;box-shadow:0 0 12px #871D33 ;}.ui-mobile-nosupport-boxshadow *{-moz-box-shadow:none !important;-webkit-box-shadow:none !important;box-shadow:none !important;}.ui-mobile-nosupport-boxshadow .ui-focus,.ui-mobile-nosupport-boxshadow .ui-btn:focus,.ui-mobile-nosupport-boxshadow .ui-link-inherit:focus{outline-width:1px;outline-style:auto;}
\ No newline at end of file
Added: trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.min.css
--- trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.min.css (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/css/jquery.mobile.min.css 2013-07-18 03:44:11 UTC (rev 8674)
@@ -0,0 +1,3 @@
+/*! jQuery Mobile 1.3.1 | Git HEAD hash: 74b4bec <> 2013-05-07T17:40:22Z | (c) 2010, 2013 jQuery Foundation, Inc. | jquery.org/license */
+.ui-bar-a{border:1px solid #333;background:#111;color:#fff;font-weight:700;text-shadow:0 -1px 0 #000;background-image:-webkit-gradient(linear,left top,left bottom,from(#3c3c3c),to(#111));background-image:-webkit-linear-gradient(#3c3c3c,#111);background-image:-moz-linear-gradient(#3c3c3c,#111);background-image:-ms-linear-gradient(#3c3c3c,#111);background-image:-o-linear-gradient(#3c3c3c,#111);background-image:linear-gradient(#3c3c3c,#111)}.ui-bar-a,.ui-bar-a input,.ui-bar-a select,.ui-bar-a textarea,.ui-bar-a button{font-family:Helvetica,Arial,sans-serif}.ui-bar-a .ui-link-inherit{color:#fff}.ui-bar-a a.ui-link{color:#7cc4e7;font-weight:700}.ui-bar-a a.ui-link:visited{color:#2489ce}.ui-bar-a a.ui-link:hover{color:#2489ce}.ui-bar-a a.ui-link:active{color:#2489ce}.ui-body-a,.ui-overlay-a{border:1px solid #444;background:#222;color:#fff;text-shadow:0 1px 0 #111;font-weight:400;background-image:-webkit-gradient(linear,left top,left bottom,from(#444),to(#222));background-image:-we
bkit-linear-gradient(#444,#222);background-image:-moz-linear-gradient(#444,#222);background-image:-ms-linear-gradient(#444,#222);background-image:-o-linear-gradient(#444,#222);background-image:linear-gradient(#444,#222)}.ui-overlay-a{background-image:none;border-width:0}.ui-body-a,.ui-body-a input,.ui-body-a select,.ui-body-a textarea,.ui-body-a button{font-family:Helvetica,Arial,sans-serif}.ui-body-a .ui-link-inherit{color:#fff}.ui-body-a .ui-link{color:#2489ce;font-weight:700}.ui-body-a .ui-link:visited{color:#2489ce}.ui-body-a .ui-link:hover{color:#2489ce}.ui-body-a .ui-link:active{color:#2489ce}.ui-btn-up-a{border:1px solid #111;background:#333;font-weight:700;color:#fff;text-shadow:0 1px 0 #111;background-image:-webkit-gradient(linear,left top,left bottom,from(#444),to(#2d2d2d));background-image:-webkit-linear-gradient(#444,#2d2d2d);background-image:-moz-linear-gradient(#444,#2d2d2d);background-image:-ms-linear-gradient(#444,#2d2d2d);background-image:-o-linear-gradient(
#444,#2d2d2d);background-image:linear-gradient(#444,#2d2d2d)}.ui-btn-up-a:visited,.ui-btn-up-a a.ui-link-inherit{color:#fff}.ui-btn-hover-a{border:1px solid #000;background:#444;font-weight:700;color:#fff;text-shadow:0 1px 0 #111;background-image:-webkit-gradient(linear,left top,left bottom,from(#555),to(#383838));background-image:-webkit-linear-gradient(#555,#383838);background-image:-moz-linear-gradient(#555,#383838);background-image:-ms-linear-gradient(#555,#383838);background-image:-o-linear-gradient(#555,#383838);background-image:linear-gradient(#555,#383838)}.ui-btn-hover-a:visited,.ui-btn-hover-a:hover,.ui-btn-hover-a a.ui-link-inherit{color:#fff}.ui-btn-down-a{border:1px solid #000;background:#222;font-weight:700;color:#fff;text-shadow:0 1px 0 #111;background-image:-webkit-gradient(linear,left top,left bottom,from(#202020),to(#2c2c2c));background-image:-webkit-linear-gradient(#202020,#2c2c2c);background-image:-moz-linear-gradient(#202020,#2c2c2c);background-image:-ms
-linear-gradient(#202020,#2c2c2c);background-image:-o-linear-gradient(#202020,#2c2c2c);background-image:linear-gradient(#202020,#2c2c2c)}.ui-btn-down-a:visited,.ui-btn-down-a:hover,.ui-btn-down-a a.ui-link-inherit{color:#fff}.ui-btn-up-a,.ui-btn-hover-a,.ui-btn-down-a{font-family:Helvetica,Arial,sans-serif;text-decoration:none}.ui-bar-b{border:1px solid #456f9a;background:#5e87b0;color:#fff;font-weight:700;text-shadow:0 1px 0 #3e6790;background-image:-webkit-gradient(linear,left top,left bottom,from(#6facd5),to(#497bae));background-image:-webkit-linear-gradient(#6facd5,#497bae);background-image:-moz-linear-gradient(#6facd5,#497bae);background-image:-ms-linear-gradient(#6facd5,#497bae);background-image:-o-linear-gradient(#6facd5,#497bae);background-image:linear-gradient(#6facd5,#497bae)}.ui-bar-b,.ui-bar-b input,.ui-bar-b select,.ui-bar-b textarea,.ui-bar-b button{font-family:Helvetica,Arial,sans-serif}.ui-bar-b .ui-link-inherit{color:#fff}.ui-bar-b a.ui-link{color:#ddf0f8;fo
nt-weight:700}.ui-bar-b a.ui-link:visited{color:#ddf0f8}.ui-bar-b a.ui-link:hover{color:#ddf0f8}.ui-bar-b a.ui-link:active{color:#ddf0f8}.ui-body-b,.ui-overlay-b{border:1px solid #999;background:#f3f3f3;color:#222;text-shadow:0 1px 0 #fff;font-weight:400;background-image:-webkit-gradient(linear,left top,left bottom,from(#ddd),to(#ccc));background-image:-webkit-linear-gradient(#ddd,#ccc);background-image:-moz-linear-gradient(#ddd,#ccc);background-image:-ms-linear-gradient(#ddd,#ccc);background-image:-o-linear-gradient(#ddd,#ccc);background-image:linear-gradient(#ddd,#ccc)}.ui-overlay-b{background-image:none;border-width:0}.ui-body-b,.ui-body-b input,.ui-body-b select,.ui-body-b textarea,.ui-body-b button{font-family:Helvetica,Arial,sans-serif}.ui-body-b .ui-link-inherit{color:#333}.ui-body-b .ui-link{color:#2489ce;font-weight:700}.ui-body-b .ui-link:visited{color:#2489ce}.ui-body-b .ui-link:hover{color:#2489ce}.ui-body-b .ui-link:active{color:#2489ce}.ui-btn-up-b{border:1px s
olid #044062;background:#396b9e;font-weight:700;color:#fff;text-shadow:0 1px 0 #194b7e;background-image:-webkit-gradient(linear,left top,left bottom,from(#5f9cc5),to(#396b9e));background-image:-webkit-linear-gradient(#5f9cc5,#396b9e);background-image:-moz-linear-gradient(#5f9cc5,#396b9e);background-image:-ms-linear-gradient(#5f9cc5,#396b9e);background-image:-o-linear-gradient(#5f9cc5,#396b9e);background-image:linear-gradient(#5f9cc5,#396b9e)}.ui-btn-up-b:visited,.ui-btn-up-b a.ui-link-inherit{color:#fff}.ui-btn-hover-b{border:1px solid #00415e;background:#4b88b6;font-weight:700;color:#fff;text-shadow:0 1px 0 #194b7e;background-image:-webkit-gradient(linear,left top,left bottom,from(#6facd5),to(#4272a4));background-image:-webkit-linear-gradient(#6facd5,#4272a4);background-image:-moz-linear-gradient(#6facd5,#4272a4);background-image:-ms-linear-gradient(#6facd5,#4272a4);background-image:-o-linear-gradient(#6facd5,#4272a4);background-image:linear-gradient(#6facd5,#4272a4)}.ui-bt
n-hover-b:visited,.ui-btn-hover-b:hover,.ui-btn-hover-b a.ui-link-inherit{color:#fff}.ui-btn-down-b{border:1px solid #225377;background:#4e89c5;font-weight:700;color:#fff;text-shadow:0 1px 0 #194b7e;background-image:-webkit-gradient(linear,left top,left bottom,from(#295b8e),to(#3e79b5));background-image:-webkit-linear-gradient(#295b8e,#3e79b5);background-image:-moz-linear-gradient(#295b8e,#3e79b5);background-image:-ms-linear-gradient(#295b8e,#3e79b5);background-image:-o-linear-gradient(#295b8e,#3e79b5);background-image:linear-gradient(#295b8e,#3e79b5)}.ui-btn-down-b:visited,.ui-btn-down-b:hover,.ui-btn-down-b a.ui-link-inherit{color:#fff}.ui-btn-up-b,.ui-btn-hover-b,.ui-btn-down-b{font-family:Helvetica,Arial,sans-serif;text-decoration:none}.ui-bar-c{border:1px solid #b3b3b3;background:#eee;color:#3e3e3e;font-weight:700;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#f0f0f0),to(#ddd));background-image:-webkit-linear-gradient(#f0f0f
0,#ddd);background-image:-moz-linear-gradient(#f0f0f0,#ddd);background-image:-ms-linear-gradient(#f0f0f0,#ddd);background-image:-o-linear-gradient(#f0f0f0,#ddd);background-image:linear-gradient(#f0f0f0,#ddd)}.ui-bar-c .ui-link-inherit{color:#3e3e3e}.ui-bar-c a.ui-link{color:#7cc4e7;font-weight:700}.ui-bar-c a.ui-link:visited{color:#2489ce}.ui-bar-c a.ui-link:hover{color:#2489ce}.ui-bar-c a.ui-link:active{color:#2489ce}.ui-bar-c,.ui-bar-c input,.ui-bar-c select,.ui-bar-c textarea,.ui-bar-c button{font-family:Helvetica,Arial,sans-serif}.ui-body-c,.ui-overlay-c{border:1px solid #aaa;color:#333;text-shadow:0 1px 0 #fff;background:#f9f9f9;background-image:-webkit-gradient(linear,left top,left bottom,from(#f9f9f9),to(#eee));background-image:-webkit-linear-gradient(#f9f9f9,#eee);background-image:-moz-linear-gradient(#f9f9f9,#eee);background-image:-ms-linear-gradient(#f9f9f9,#eee);background-image:-o-linear-gradient(#f9f9f9,#eee);background-image:linear-gradient(#f9f9f9,#eee)}.ui-ov
erlay-c{background-image:none;border-width:0}.ui-body-c,.ui-body-c input,.ui-body-c select,.ui-body-c textarea,.ui-body-c button{font-family:Helvetica,Arial,sans-serif}.ui-body-c .ui-link-inherit{color:#333}.ui-body-c .ui-link{color:#2489ce;font-weight:700}.ui-body-c .ui-link:visited{color:#2489ce}.ui-body-c .ui-link:hover{color:#2489ce}.ui-body-c .ui-link:active{color:#2489ce}.ui-btn-up-c{border:1px solid #ccc;background:#eee;font-weight:700;color:#222;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#fff),to(#f1f1f1));background-image:-webkit-linear-gradient(#fff,#f1f1f1);background-image:-moz-linear-gradient(#fff,#f1f1f1);background-image:-ms-linear-gradient(#fff,#f1f1f1);background-image:-o-linear-gradient(#fff,#f1f1f1);background-image:linear-gradient(#fff,#f1f1f1)}.ui-btn-up-c:visited,.ui-btn-up-c a.ui-link-inherit{color:#2f3e46}.ui-btn-hover-c{border:1px solid #bbb;background:#dfdfdf;font-weight:700;color:#222;text-shadow:0 1
px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#f6f6f6),to(#e0e0e0));background-image:-webkit-linear-gradient(#f6f6f6,#e0e0e0);background-image:-moz-linear-gradient(#f6f6f6,#e0e0e0);background-image:-ms-linear-gradient(#f6f6f6,#e0e0e0);background-image:-o-linear-gradient(#f6f6f6,#e0e0e0);background-image:linear-gradient(#f6f6f6,#e0e0e0)}.ui-btn-hover-c:visited,.ui-btn-hover-c:hover,.ui-btn-hover-c a.ui-link-inherit{color:#2f3e46}.ui-btn-down-c{border:1px solid #bbb;background:#d6d6d6;font-weight:700;color:#222;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#d0d0d0),to(#dfdfdf));background-image:-webkit-linear-gradient(#d0d0d0,#dfdfdf);background-image:-moz-linear-gradient(#d0d0d0,#dfdfdf);background-image:-ms-linear-gradient(#d0d0d0,#dfdfdf);background-image:-o-linear-gradient(#d0d0d0,#dfdfdf);background-image:linear-gradient(#d0d0d0,#dfdfdf)}.ui-btn-down-c:visited,.ui-btn-down-c:hover,.ui-btn-down-c
a.ui-link-inherit{color:#2f3e46}.ui-btn-up-c,.ui-btn-hover-c,.ui-btn-down-c{font-family:Helvetica,Arial,sans-serif;text-decoration:none}.ui-bar-d{border:1px solid #bbb;background:#bbb;color:#333;font-weight:700;text-shadow:0 1px 0 #eee;background-image:-webkit-gradient(linear,left top,left bottom,from(#ddd),to(#bbb));background-image:-webkit-linear-gradient(#ddd,#bbb);background-image:-moz-linear-gradient(#ddd,#bbb);background-image:-ms-linear-gradient(#ddd,#bbb);background-image:-o-linear-gradient(#ddd,#bbb);background-image:linear-gradient(#ddd,#bbb)}.ui-bar-d,.ui-bar-d input,.ui-bar-d select,.ui-bar-d textarea,.ui-bar-d button{font-family:Helvetica,Arial,sans-serif}.ui-bar-d .ui-link-inherit{color:#333}.ui-bar-d a.ui-link{color:#2489ce;font-weight:700}.ui-bar-d a.ui-link:visited{color:#2489ce}.ui-bar-d a.ui-link:hover{color:#2489ce}.ui-bar-d a.ui-link:active{color:#2489ce}.ui-body-d,.ui-overlay-d{border:1px solid #bbb;color:#333;text-shadow:0 1px 0 #fff;background:#fff;ba
ckground-image:-webkit-gradient(linear,left top,left bottom,from(#fff),to(#fff));background-image:-webkit-linear-gradient(#fff,#fff);background-image:-moz-linear-gradient(#fff,#fff);background-image:-ms-linear-gradient(#fff,#fff);background-image:-o-linear-gradient(#fff,#fff);background-image:linear-gradient(#fff,#fff)}.ui-overlay-d{background-image:none;border-width:0}.ui-body-d,.ui-body-d input,.ui-body-d select,.ui-body-d textarea,.ui-body-d button{font-family:Helvetica,Arial,sans-serif}.ui-body-d .ui-link-inherit{color:#333}.ui-body-d .ui-link{color:#2489ce;font-weight:700}.ui-body-d .ui-link:visited{color:#2489ce}.ui-body-d .ui-link:hover{color:#2489ce}.ui-body-d .ui-link:active{color:#2489ce}.ui-btn-up-d{border:1px solid #bbb;background:#fff;font-weight:700;color:#333;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#fafafa),to(#f6f6f6));background-image:-webkit-linear-gradient(#fafafa,#f6f6f6);background-image:-moz-linear-gra
dient(#fafafa,#f6f6f6);background-image:-ms-linear-gradient(#fafafa,#f6f6f6);background-image:-o-linear-gradient(#fafafa,#f6f6f6);background-image:linear-gradient(#fafafa,#f6f6f6)}.ui-btn-up-d:visited,.ui-btn-up-d a.ui-link-inherit{color:#333}.ui-btn-hover-d{border:1px solid #aaa;background:#eee;font-weight:700;color:#333;cursor:pointer;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#eee),to(#fff));background-image:-webkit-linear-gradient(#eee,#fff);background-image:-moz-linear-gradient(#eee,#fff);background-image:-ms-linear-gradient(#eee,#fff);background-image:-o-linear-gradient(#eee,#fff);background-image:linear-gradient(#eee,#fff)}.ui-btn-hover-d:visited,.ui-btn-hover-d:hover,.ui-btn-hover-d a.ui-link-inherit{color:#333}.ui-btn-down-d{border:1px solid #aaa;background:#eee;font-weight:700;color:#333;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#e5e5e5),to(#f2f2f2));background-image:
-webkit-linear-gradient(#e5e5e5,#f2f2f2);background-image:-moz-linear-gradient(#e5e5e5,#f2f2f2);background-image:-ms-linear-gradient(#e5e5e5,#f2f2f2);background-image:-o-linear-gradient(#e5e5e5,#f2f2f2);background-image:linear-gradient(#e5e5e5,#f2f2f2)}.ui-btn-down-d:visited,.ui-btn-down-d:hover,.ui-btn-down-d a.ui-link-inherit{color:#333}.ui-btn-up-d,.ui-btn-hover-d,.ui-btn-down-d{font-family:Helvetica,Arial,sans-serif;text-decoration:none}.ui-bar-e{border:1px solid #f7c942;background:#fadb4e;color:#333;font-weight:700;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#fceda7),to(#fbef7e));background-image:-webkit-linear-gradient(#fceda7,#fbef7e);background-image:-moz-linear-gradient(#fceda7,#fbef7e);background-image:-ms-linear-gradient(#fceda7,#fbef7e);background-image:-o-linear-gradient(#fceda7,#fbef7e);background-image:linear-gradient(#fceda7,#fbef7e)}.ui-bar-e,.ui-bar-e input,.ui-bar-e select,.ui-bar-e textarea,.ui-bar-e button{
font-family:Helvetica,Arial,sans-serif}.ui-bar-e .ui-link-inherit{color:#333}.ui-bar-e a.ui-link{color:#2489ce;font-weight:700}.ui-bar-e a.ui-link:visited{color:#2489ce}.ui-bar-e a.ui-link:hover{color:#2489ce}.ui-bar-e a.ui-link:active{color:#2489ce}.ui-body-e,.ui-overlay-e{border:1px solid #f7c942;color:#222;text-shadow:0 1px 0 #fff;background:#fff9df;background-image:-webkit-gradient(linear,left top,left bottom,from(#fffadf),to(#fff3a5));background-image:-webkit-linear-gradient(#fffadf,#fff3a5);background-image:-moz-linear-gradient(#fffadf,#fff3a5);background-image:-ms-linear-gradient(#fffadf,#fff3a5);background-image:-o-linear-gradient(#fffadf,#fff3a5);background-image:linear-gradient(#fffadf,#fff3a5)}.ui-overlay-e{background-image:none;border-width:0}.ui-body-e,.ui-body-e input,.ui-body-e select,.ui-body-e textarea,.ui-body-e button{font-family:Helvetica,Arial,sans-serif}.ui-body-e .ui-link-inherit{color:#222}.ui-body-e .ui-link{color:#2489ce;font-weight:700}.ui-body-e .
ui-link:visited{color:#2489ce}.ui-body-e .ui-link:hover{color:#2489ce}.ui-body-e .ui-link:active{color:#2489ce}.ui-btn-up-e{border:1px solid #f4c63f;background:#fadb4e;font-weight:700;color:#222;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#ffefaa),to(#ffe155));background-image:-webkit-linear-gradient(#ffefaa,#ffe155);background-image:-moz-linear-gradient(#ffefaa,#ffe155);background-image:-ms-linear-gradient(#ffefaa,#ffe155);background-image:-o-linear-gradient(#ffefaa,#ffe155);background-image:linear-gradient(#ffefaa,#ffe155)}.ui-btn-up-e:visited,.ui-btn-up-e a.ui-link-inherit{color:#222}.ui-btn-hover-e{border:1px solid #f2c43d;background:#fbe26f;font-weight:700;color:#111;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#fff5ba),to(#fbdd52));background-image:-webkit-linear-gradient(#fff5ba,#fbdd52);background-image:-moz-linear-gradient(#fff5ba,#fbdd52);background-image:-ms-linear-gradi
ent(#fff5ba,#fbdd52);background-image:-o-linear-gradient(#fff5ba,#fbdd52);background-image:linear-gradient(#fff5ba,#fbdd52)}.ui-btn-hover-e:visited,.ui-btn-hover-e:hover,.ui-btn-hover-e a.ui-link-inherit{color:#333}.ui-btn-down-e{border:1px solid #f2c43d;background:#fceda7;font-weight:700;color:#111;text-shadow:0 1px 0 #fff;background-image:-webkit-gradient(linear,left top,left bottom,from(#f8d94c),to(#fadb4e));background-image:-webkit-linear-gradient(#f8d94c,#fadb4e);background-image:-moz-linear-gradient(#f8d94c,#fadb4e);background-image:-ms-linear-gradient(#f8d94c,#fadb4e);background-image:-o-linear-gradient(#f8d94c,#fadb4e);background-image:linear-gradient(#f8d94c,#fadb4e)}.ui-btn-down-e:visited,.ui-btn-down-e:hover,.ui-btn-down-e a.ui-link-inherit{color:#333}.ui-btn-up-e,.ui-btn-hover-e,.ui-btn-down-e{font-family:Helvetica,Arial,sans-serif;text-decoration:none}a.ui-link-inherit{text-decoration:none!important}.ui-btn-active{border:1px solid #2373a5;background:#5393c5;font
-weight:700;color:#fff;cursor:pointer;text-shadow:0 1px 0 #3373a5;text-decoration:none;background-image:-webkit-gradient(linear,left top,left bottom,from(#5393c5),to(#6facd5));background-image:-webkit-linear-gradient(#5393c5,#6facd5);background-image:-moz-linear-gradient(#5393c5,#6facd5);background-image:-ms-linear-gradient(#5393c5,#6facd5);background-image:-o-linear-gradient(#5393c5,#6facd5);background-image:linear-gradient(#5393c5,#6facd5);font-family:Helvetica,Arial,sans-serif}.ui-btn-active:visited,.ui-btn-active:hover,.ui-btn-active a.ui-link-inherit{color:#fff}.ui-btn-inner{border-top:1px solid #fff;border-color:rgba(255,255,255,.3)}.ui-corner-all{-webkit-border-radius:.6em;border-radius:.6em}.ui-br{border-color:#828282;border-color:rgba(130,130,130,.3);border-style:solid}.ui-disabled{filter:Alpha(Opacity=30);opacity:.3;zoom:1}.ui-disabled,.ui-disabled a{cursor:default!important;pointer-events:none}.ui-icon,.ui-icon-searchfield:after{background-color:#666;background-co
lor:rgba(0,0,0,.4);background-image:url(images/icons-18-white.png);background-repeat:no-repeat;-webkit-border-radius:9px;border-radius:9px}.ui-icon-alt .ui-icon,.ui-icon-alt .ui-icon-searchfield:after{background-color:#fff;background-color:rgba(255,255,255,.3);background-image:url(images/icons-18-black.png);background-repeat:no-repeat}.ui-icon-nodisc .ui-icon,.ui-icon-nodisc .ui-icon-searchfield:after,.ui-icon-nodisc .ui-icon-alt .ui-icon,.ui-icon-nodisc .ui-icon-alt .ui-icon-searchfield:after{background-color:transparent}.ui-icon-plus{background-position:-1px -1px}.ui-icon-minus{background-position:-37px -1px}.ui-icon-delete{background-position:-73px -1px}.ui-icon-arrow-r{background-position:-108px -1px}.ui-icon-arrow-l{background-position:-144px -1px}.ui-icon-arrow-u{background-position:-180px -1px}.ui-icon-arrow-d{background-position:-216px -1px}.ui-icon-check{background-position:-252px -1px}.ui-icon-gear{background-position:-288px -1px}.ui-icon-refresh{background-positio
n:-323px -1px}.ui-icon-forward{background-position:-360px -1px}.ui-icon-back{background-position:-396px -1px}.ui-icon-grid{background-position:-432px -1px}.ui-icon-star{background-position:-467px -1px}.ui-icon-alert{background-position:-503px -1px}.ui-icon-info{background-position:-539px -1px}.ui-icon-home{background-position:-575px -1px}.ui-icon-search,.ui-icon-searchfield:after{background-position:-611px -1px}.ui-icon-checkbox-on{background-position:-647px -1px}.ui-icon-checkbox-off{background-position:-683px -1px}.ui-icon-radio-on{background-position:-718px -1px}.ui-icon-radio-off{background-position:-754px -1px}.ui-icon-bars{background-position:-788px -1px}.ui-icon-edit{background-position:-824px -1px}@media only screen and (-webkit-min-device-pixel-ratio:1.3),only screen and (min--moz-device-pixel-ratio:1.3),only screen and (min-resolution:200dpi){.ui-icon-plus,.ui-icon-minus,.ui-icon-delete,.ui-icon-arrow-r,.ui-icon-arrow-l,.ui-icon-arrow-u,.ui-icon-arrow-d,.ui-icon-ch
eck,.ui-icon-gear,.ui-icon-refresh,.ui-icon-forward,.ui-icon-back,.ui-icon-grid,.ui-icon-star,.ui-icon-alert,.ui-icon-info,.ui-icon-home,.ui-icon-bars,.ui-icon-edit,.ui-icon-search,.ui-icon-searchfield:after,.ui-icon-checkbox-off,.ui-icon-checkbox-on,.ui-icon-radio-off,.ui-icon-radio-on{background-image:url(images/icons-36-white.png);-moz-background-size:864px 18px;-o-background-size:864px 18px;-webkit-background-size:864px 18px;background-size:864px 18px}.ui-icon-alt .ui-icon{background-image:url(images/icons-36-black.png)}.ui-icon-plus{background-position:0 50%}.ui-icon-minus{background-position:-36px 50%}.ui-icon-delete{background-position:-72px 50%}.ui-icon-arrow-r{background-position:-108px 50%}.ui-icon-arrow-l{background-position:-144px 50%}.ui-icon-arrow-u{background-position:-179px 50%}.ui-icon-arrow-d{background-position:-215px 50%}.ui-icon-check{background-position:-252px 50%}.ui-icon-gear{background-position:-287px 50%}.ui-icon-refresh{background-position:-323px 5
0%}.ui-icon-forward{background-position:-360px 50%}.ui-icon-back{background-position:-395px 50%}.ui-icon-grid{background-position:-431px 50%}.ui-icon-star{background-position:-467px 50%}.ui-icon-alert{background-position:-503px 50%}.ui-icon-info{background-position:-538px 50%}.ui-icon-home{background-position:-575px 50%}.ui-icon-search,.ui-icon-searchfield:after{background-position:-611px 50%}.ui-icon-checkbox-on{background-position:-647px 50%}.ui-icon-checkbox-off{background-position:-683px 50%}.ui-icon-radio-on{background-position:-718px 50%}.ui-icon-radio-off{background-position:-754px 50%}.ui-icon-bars{background-position:-788px 50%}.ui-icon-edit{background-position:-824px 50%}}.ui-checkbox .ui-icon,.ui-selectmenu-list .ui-icon{-webkit-border-radius:3px;border-radius:3px}.ui-icon-checkbox-off,.ui-icon-radio-off{background-color:transparent}.ui-checkbox-on .ui-icon,.ui-radio-on .ui-icon{background-color:#4596ce}.ui-icon-loading{background:url(images/ajax-loader.gif);backg
round-size:46px 46px}.ui-btn-corner-all{-webkit-border-radius:1em;border-radius:1em}.ui-corner-all,.ui-btn-corner-all{-webkit-background-clip:padding;background-clip:padding-box}.ui-overlay{background:#666;filter:Alpha(Opacity=50);opacity:.5;position:absolute;width:100%;height:100%}.ui-overlay-shadow{-moz-box-shadow:0 0 12px rgba(0,0,0,.6);-webkit-box-shadow:0 0 12px rgba(0,0,0,.6);box-shadow:0 0 12px rgba(0,0,0,.6)}.ui-shadow{-moz-box-shadow:0 1px 3px rgba(0,0,0,.2);-webkit-box-shadow:0 1px 3px rgba(0,0,0,.2);box-shadow:0 1px 3px rgba(0,0,0,.2)}.ui-bar-a .ui-shadow,.ui-bar-b .ui-shadow,.ui-bar-c .ui-shadow{-moz-box-shadow:0 1px 0 rgba(255,255,255,.3);-webkit-box-shadow:0 1px 0 rgba(255,255,255,.3);box-shadow:0 1px 0 rgba(255,255,255,.3)}.ui-shadow-inset{-moz-box-shadow:inset 0 1px 4px rgba(0,0,0,.2);-webkit-box-shadow:inset 0 1px 4px rgba(0,0,0,.2);box-shadow:inset 0 1px 4px rgba(0,0,0,.2)}.ui-icon-shadow{-moz-box-shadow:0 1px 0 rgba(255,255,255,.4);-webkit-box-shadow:0 1px
0 rgba(255,255,255,.4);box-shadow:0 1px 0 rgba(255,255,255,.4)}.ui-btn:focus,.ui-link-inherit:focus{outline:0}.ui-btn.ui-focus{z-index:1}.ui-focus,.ui-btn:focus{-moz-box-shadow:inset 0 0 3px #387bbe,0 0 9px #387bbe;-webkit-box-shadow:inset 0 0 3px #387bbe,0 0 9px #387bbe;box-shadow:inset 0 0 3px #387bbe,0 0 9px #387bbe}.ui-input-text.ui-focus,.ui-input-search.ui-focus{-moz-box-shadow:0 0 12px #387bbe;-webkit-box-shadow:0 0 12px #387bbe;box-shadow:0 0 12px #387bbe}.ui-mobile-nosupport-boxshadow *{-moz-box-shadow:none!important;-webkit-box-shadow:none!important;box-shadow:none!important}.ui-mobile-nosupport-boxshadow .ui-focus,.ui-mobile-nosupport-boxshadow .ui-btn:focus,.ui-mobile-nosupport-boxshadow .ui-link-inherit:focus{outline-width:1px;outline-style:auto}.ui-mobile,.ui-mobile body{height:99.9%}.ui-mobile fieldset,.ui-page{padding:0;margin:0}.ui-mobile a img,.ui-mobile fieldset{border-width:0}.ui-mobile-viewport{margin:0;overflow-x:visible;-webkit-text-size-adjust:100%;-
ms-text-size-adjust:none;-webkit-tap-highlight-color:rgba(0,0,0,0)}body.ui-mobile-viewport,div.ui-mobile-viewport{overflow-x:hidden}.ui-mobile [data-role=page],.ui-mobile [data-role=dialog],.ui-page{top:0;left:0;width:100%;min-height:100%;position:absolute;display:none;border:0}.ui-mobile .ui-page-active{display:block;overflow:visible}.ui-page{outline:0}@media screen and (orientation:portrait){.ui-mobile .ui-page{min-height:420px}}@media screen and (orientation:landscape){.ui-mobile .ui-page{min-height:300px}}.ui-loading .ui-loader{display:block}.ui-loader{display:none;z-index:9999999;position:fixed;top:50%;left:50%;border:0}.ui-loader-default{background:0;filter:Alpha(Opacity=18);opacity:.18;width:46px;height:46px;margin-left:-23px;margin-top:-23px}.ui-loader-verbose{width:200px;filter:Alpha(Opacity=88);opacity:.88;box-shadow:0 1px 1px -1px #fff;height:auto;margin-left:-110px;margin-top:-43px;padding:10px}.ui-loader-default h1{font-size:0;width:0;height:0;overflow:hidden}.u
i-loader-verbose h1{font-size:16px;margin:0;text-align:center}.ui-loader .ui-icon{background-color:#000;display:block;margin:0;width:44px;height:44px;padding:1px;-webkit-border-radius:36px;border-radius:36px}.ui-loader-verbose .ui-icon{margin:0 auto 10px;filter:Alpha(Opacity=75);opacity:.75}.ui-loader-textonly{padding:15px;margin-left:-115px}.ui-loader-textonly .ui-icon{display:none}.ui-loader-fakefix{position:absolute}.ui-mobile-rendering>*{visibility:hidden}.ui-bar,.ui-body{position:relative;padding:.4em 15px;overflow:hidden;display:block;clear:both}.ui-bar{font-size:16px;margin:0}.ui-bar h1,.ui-bar h2,.ui-bar h3,.ui-bar h4,.ui-bar h5,.ui-bar h6{margin:0;padding:0;font-size:16px;display:inline-block}.ui-header,.ui-footer{position:relative;zoom:1}.ui-mobile .ui-header,.ui-mobile .ui-footer{border-left-width:0;border-right-width:0}.ui-header .ui-btn-left,.ui-header .ui-btn-right,.ui-footer .ui-btn-left,.ui-footer .ui-btn-right,.ui-header-fixed.ui-fixed-hidden .ui-btn-left,.u
i-header-fixed.ui-fixed-hidden .ui-btn-right{position:absolute;top:3px}.ui-header-fixed .ui-btn-left,.ui-header-fixed .ui-btn-right{top:4px}.ui-header .ui-btn-left,.ui-footer .ui-btn-left{left:5px}.ui-header .ui-btn-right,.ui-footer .ui-btn-right{right:5px}.ui-footer>.ui-btn-icon-notext,.ui-header>.ui-btn-icon-notext,.ui-header-fixed.ui-fixed-hidden>.ui-btn-icon-notext{top:6px}.ui-header-fixed>.ui-btn-icon-notext{top:7px}.ui-header .ui-title,.ui-footer .ui-title{min-height:1.1em;text-align:center;font-size:16px;display:block;margin:.6em 30% .8em;padding:0;text-overflow:ellipsis;overflow:hidden;white-space:nowrap;outline:0!important}.ui-footer .ui-title{margin:.6em 15px .8em}.ui-content{border-width:0;overflow:visible;overflow-x:hidden;padding:15px}.ui-corner-all>.ui-header:first-child,.ui-corner-all>.ui-content:first-child,.ui-corner-all>.ui-footer:first-child{-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit;-webkit-border-top-right-radius:inherit;border
-top-right-radius:inherit}.ui-corner-all>.ui-header:last-child,.ui-corner-all>.ui-content:last-child,.ui-corner-all>.ui-footer:last-child{-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit;-webkit-border-bottom-right-radius:inherit;border-bottom-right-radius:inherit}.ui-icon{width:18px;height:18px}.ui-nojs{position:absolute;left:-9999px}.ui-hide-label label.ui-input-text,.ui-hide-label label.ui-select,.ui-hide-label label.ui-slider,.ui-hide-label label.ui-submit,.ui-hide-label .ui-controlgroup-label,.ui-hidden-accessible{position:absolute!important;left:-9999px;clip:rect(1px 1px 1px 1px);clip:rect(1px,1px,1px,1px)}.ui-mobile-viewport-transitioning,.ui-mobile-viewport-transitioning .ui-page{width:100%;height:100%;overflow:hidden;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}.ui-page-pre-in{opacity:0}.in{-webkit-animation-timing-function:ease-out;-webkit-animation-duration:350ms;-moz-animation-timing-function:ease-out;-
moz-animation-duration:350ms;animation-timing-function:ease-out;animation-duration:350ms}.out{-webkit-animation-timing-function:ease-in;-webkit-animation-duration:225ms;-moz-animation-timing-function:ease-in;-moz-animation-duration:225ms;animation-timing-function:ease-in;animation-duration:225ms}@-webkit-keyframes fadein{from{opacity:0}to{opacity:1}}@-moz-keyframes fadein{from{opacity:0}to{opacity:1}}@keyframes fadein{from{opacity:0}to{opacity:1}}@-webkit-keyframes fadeout{from{opacity:1}to{opacity:0}}@-moz-keyframes fadeout{from{opacity:1}to{opacity:0}}@keyframes fadeout{from{opacity:1}to{opacity:0}}.fade.out{opacity:0;-webkit-animation-duration:125ms;-webkit-animation-name:fadeout;-moz-animation-duration:125ms;-moz-animation-name:fadeout;animation-duration:125ms;animation-name:fadeout}.fade.in{opacity:1;-webkit-animation-duration:225ms;-webkit-animation-name:fadein;-moz-animation-duration:225ms;-moz-animation-name:fadein;animation-duration:225ms;animation-name:fadein}.pop{
-webkit-transform-origin:50% 50%;-moz-transform-origin:50% 50%;transform-origin:50% 50%}.pop.in{-webkit-transform:scale(1);-webkit-animation-name:popin;-webkit-animation-duration:350ms;-moz-transform:scale(1);-moz-animation-name:popin;-moz-animation-duration:350ms;transform:scale(1);animation-name:popin;animation-duration:350ms;opacity:1}.pop.out{-webkit-animation-name:fadeout;-webkit-animation-duration:100ms;-moz-animation-name:fadeout;-moz-animation-duration:100ms;animation-name:fadeout;animation-duration:100ms;opacity:0}.pop.in.reverse{-webkit-animation-name:fadein;-moz-animation-name:fadein;animation-name:fadein}.pop.out.reverse{-webkit-transform:scale(.8);-webkit-animation-name:popout;-moz-transform:scale(.8);-moz-animation-name:popout;transform:scale(.8);animation-name:popout}@-webkit-keyframes popin{from{-webkit-transform:scale(.8);opacity:0}to{-webkit-transform:scale(1);opacity:1}}@-moz-keyframes popin{from{-moz-transform:scale(.8);opacity:0}to{-moz-transform:scale(1
);opacity:1}}@keyframes popin{from{transform:scale(.8);opacity:0}to{transform:scale(1);opacity:1}}@-webkit-keyframes popout{from{-webkit-transform:scale(1);opacity:1}to{-webkit-transform:scale(.8);opacity:0}}@-moz-keyframes popout{from{-moz-transform:scale(1);opacity:1}to{-moz-transform:scale(.8);opacity:0}}@keyframes popout{from{transform:scale(1);opacity:1}to{transform:scale(.8);opacity:0}}@-webkit-keyframes slideinfromright{from{-webkit-transform:translate3d(100%,0,0)}to{-webkit-transform:translate3d(0,0,0)}}@-moz-keyframes slideinfromright{from{-moz-transform:translateX(100%)}to{-moz-transform:translateX(0)}}@keyframes slideinfromright{from{transform:translateX(100%)}to{transform:translateX(0)}}@-webkit-keyframes slideinfromleft{from{-webkit-transform:translate3d(-100%,0,0)}to{-webkit-transform:translate3d(0,0,0)}}@-moz-keyframes slideinfromleft{from{-moz-transform:translateX(-100%)}to{-moz-transform:translateX(0)}}@keyframes slideinfromleft{from{transform:translateX(-10
0%)}to{transform:translateX(0)}}@-webkit-keyframes slideouttoleft{from{-webkit-transform:translate3d(0,0,0)}to{-webkit-transform:translate3d(-100%,0,0)}}@-moz-keyframes slideouttoleft{from{-moz-transform:translateX(0)}to{-moz-transform:translateX(-100%)}}@keyframes slideouttoleft{from{transform:translateX(0)}to{transform:translateX(-100%)}}@-webkit-keyframes slideouttoright{from{-webkit-transform:translate3d(0,0,0)}to{-webkit-transform:translate3d(100%,0,0)}}@-moz-keyframes slideouttoright{from{-moz-transform:translateX(0)}to{-moz-transform:translateX(100%)}}@keyframes slideouttoright{from{transform:translateX(0)}to{transform:translateX(100%)}}.slide.out,.slide.in{-webkit-animation-timing-function:ease-out;-webkit-animation-duration:350ms;-moz-animation-timing-function:ease-out;-moz-animation-duration:350ms;animation-timing-function:ease-out;animation-duration:350ms}.slide.out{-webkit-transform:translate3d(-100%,0,0);-webkit-animation-name:slideouttoleft;-moz-transform:trans
lateX(-100%);-moz-animation-name:slideouttoleft;transform:translateX(-100%);animation-name:slideouttoleft}.slide.in{-webkit-transform:translate3d(0,0,0);-webkit-animation-name:slideinfromright;-moz-transform:translateX(0);-moz-animation-name:slideinfromright;transform:translateX(0);animation-name:slideinfromright}.slide.out.reverse{-webkit-transform:translate3d(100%,0,0);-webkit-animation-name:slideouttoright;-moz-transform:translateX(100%);-moz-animation-name:slideouttoright;transform:translateX(100%);animation-name:slideouttoright}.slide.in.reverse{-webkit-transform:translate3d(0,0,0);-webkit-animation-name:slideinfromleft;-moz-transform:translateX(0);-moz-animation-name:slideinfromleft;transform:translateX(0);animation-name:slideinfromleft}.slidefade.out{-webkit-transform:translateX(-100%);-webkit-animation-name:slideouttoleft;-webkit-animation-duration:225ms;-moz-transform:translateX(-100%);-moz-animation-name:slideouttoleft;-moz-animation-duration:225ms;transform:transl
ateX(-100%);animation-name:slideouttoleft;animation-duration:225ms}.slidefade.in{-webkit-transform:translateX(0);-webkit-animation-name:fadein;-webkit-animation-duration:200ms;-moz-transform:translateX(0);-moz-animation-name:fadein;-moz-animation-duration:200ms;transform:translateX(0);animation-name:fadein;animation-duration:200ms}.slidefade.out.reverse{-webkit-transform:translateX(100%);-webkit-animation-name:slideouttoright;-webkit-animation-duration:200ms;-moz-transform:translateX(100%);-moz-animation-name:slideouttoright;-moz-animation-duration:200ms;transform:translateX(100%);animation-name:slideouttoright;animation-duration:200ms}.slidefade.in.reverse{-webkit-transform:translateX(0);-webkit-animation-name:fadein;-webkit-animation-duration:200ms;-moz-transform:translateX(0);-moz-animation-name:fadein;-moz-animation-duration:200ms;transform:translateX(0);animation-name:fadein;animation-duration:200ms}.slidedown.out{-webkit-animation-name:fadeout;-webkit-animation-duratio
n:100ms;-moz-animation-name:fadeout;-moz-animation-duration:100ms;animation-name:fadeout;animation-duration:100ms}.slidedown.in{-webkit-transform:translateY(0);-webkit-animation-name:slideinfromtop;-webkit-animation-duration:250ms;-moz-transform:translateY(0);-moz-animation-name:slideinfromtop;-moz-animation-duration:250ms;transform:translateY(0);animation-name:slideinfromtop;animation-duration:250ms}.slidedown.in.reverse{-webkit-animation-name:fadein;-webkit-animation-duration:150ms;-moz-animation-name:fadein;-moz-animation-duration:150ms;animation-name:fadein;animation-duration:150ms}.slidedown.out.reverse{-webkit-transform:translateY(-100%);-webkit-animation-name:slideouttotop;-webkit-animation-duration:200ms;-moz-transform:translateY(-100%);-moz-animation-name:slideouttotop;-moz-animation-duration:200ms;transform:translateY(-100%);animation-name:slideouttotop;animation-duration:200ms}@-webkit-keyframes slideinfromtop{from{-webkit-transform:translateY(-100%)}to{-webkit-tr
ansform:translateY(0)}}@-moz-keyframes slideinfromtop{from{-moz-transform:translateY(-100%)}to{-moz-transform:translateY(0)}}@keyframes slideinfromtop{from{transform:translateY(-100%)}to{transform:translateY(0)}}@-webkit-keyframes slideouttotop{from{-webkit-transform:translateY(0)}to{-webkit-transform:translateY(-100%)}}@-moz-keyframes slideouttotop{from{-moz-transform:translateY(0)}to{-moz-transform:translateY(-100%)}}@keyframes slideouttotop{from{transform:translateY(0)}to{transform:translateY(-100%)}}.slideup.out{-webkit-animation-name:fadeout;-webkit-animation-duration:100ms;-moz-animation-name:fadeout;-moz-animation-duration:100ms;animation-name:fadeout;animation-duration:100ms}.slideup.in{-webkit-transform:translateY(0);-webkit-animation-name:slideinfrombottom;-webkit-animation-duration:250ms;-moz-transform:translateY(0);-moz-animation-name:slideinfrombottom;-moz-animation-duration:250ms;transform:translateY(0);animation-name:slideinfrombottom;animation-duration:250ms}
.slideup.in.reverse{-webkit-animation-name:fadein;-webkit-animation-duration:150ms;-moz-animation-name:fadein;-moz-animation-duration:150ms;animation-name:fadein;animation-duration:150ms}.slideup.out.reverse{-webkit-transform:translateY(100%);-webkit-animation-name:slideouttobottom;-webkit-animation-duration:200ms;-moz-transform:translateY(100%);-moz-animation-name:slideouttobottom;-moz-animation-duration:200ms;transform:translateY(100%);animation-name:slideouttobottom;animation-duration:200ms}@-webkit-keyframes slideinfrombottom{from{-webkit-transform:translateY(100%)}to{-webkit-transform:translateY(0)}}@-moz-keyframes slideinfrombottom{from{-moz-transform:translateY(100%)}to{-moz-transform:translateY(0)}}@keyframes slideinfrombottom{from{transform:translateY(100%)}to{transform:translateY(0)}}@-webkit-keyframes slideouttobottom{from{-webkit-transform:translateY(0)}to{-webkit-transform:translateY(100%)}}@-moz-keyframes slideouttobottom{from{-moz-transform:translateY(0)}to{-m
oz-transform:translateY(100%)}}@keyframes slideouttobottom{from{transform:translateY(0)}to{transform:translateY(100%)}}.viewport-flip{-webkit-perspective:1000;-moz-perspective:1000;perspective:1000;position:absolute}.flip{-webkit-backface-visibility:hidden;-webkit-transform:translateX(0);-moz-backface-visibility:hidden;-moz-transform:translateX(0);backface-visibility:hidden;transform:translateX(0)}.flip.out{-webkit-transform:rotateY(-90deg) scale(.9);-webkit-animation-name:flipouttoleft;-webkit-animation-duration:175ms;-moz-transform:rotateY(-90deg) scale(.9);-moz-animation-name:flipouttoleft;-moz-animation-duration:175ms;transform:rotateY(-90deg) scale(.9);animation-name:flipouttoleft;animation-duration:175ms}.flip.in{-webkit-animation-name:flipintoright;-webkit-animation-duration:225ms;-moz-animation-name:flipintoright;-moz-animation-duration:225ms;animation-name:flipintoright;animation-duration:225ms}.flip.out.reverse{-webkit-transform:rotateY(90deg) scale(.9);-webkit-ani
mation-name:flipouttoright;-moz-transform:rotateY(90deg) scale(.9);-moz-animation-name:flipouttoright;transform:rotateY(90deg) scale(.9);animation-name:flipouttoright}.flip.in.reverse{-webkit-animation-name:flipintoleft;-moz-animation-name:flipintoleft;animation-name:flipintoleft}@-webkit-keyframes flipouttoleft{from{-webkit-transform:rotateY(0)}to{-webkit-transform:rotateY(-90deg) scale(.9)}}@-moz-keyframes flipouttoleft{from{-moz-transform:rotateY(0)}to{-moz-transform:rotateY(-90deg) scale(.9)}}@keyframes flipouttoleft{from{transform:rotateY(0)}to{transform:rotateY(-90deg) scale(.9)}}@-webkit-keyframes flipouttoright{from{-webkit-transform:rotateY(0)}to{-webkit-transform:rotateY(90deg) scale(.9)}}@-moz-keyframes flipouttoright{from{-moz-transform:rotateY(0)}to{-moz-transform:rotateY(90deg) scale(.9)}}@keyframes flipouttoright{from{transform:rotateY(0)}to{transform:rotateY(90deg) scale(.9)}}@-webkit-keyframes flipintoleft{from{-webkit-transform:rotateY(-90deg) scale(.9)}to{
-webkit-transform:rotateY(0)}}@-moz-keyframes flipintoleft{from{-moz-transform:rotateY(-90deg) scale(.9)}to{-moz-transform:rotateY(0)}}@keyframes flipintoleft{from{transform:rotateY(-90deg) scale(.9)}to{transform:rotateY(0)}}@-webkit-keyframes flipintoright{from{-webkit-transform:rotateY(90deg) scale(.9)}to{-webkit-transform:rotateY(0)}}@-moz-keyframes flipintoright{from{-moz-transform:rotateY(90deg) scale(.9)}to{-moz-transform:rotateY(0)}}@keyframes flipintoright{from{transform:rotateY(90deg) scale(.9)}to{transform:rotateY(0)}}.viewport-turn{-webkit-perspective:200px;-moz-perspective:200px;-ms-perspective:200px;perspective:200px;position:absolute}.turn{-webkit-backface-visibility:hidden;-webkit-transform:translateX(0);-webkit-transform-origin:0;-moz-backface-visibility:hidden;-moz-transform:translateX(0);-moz-transform-origin:0;backface-visibility :hidden;transform:translateX(0);transform-origin:0}.turn.out{-webkit-transform:rotateY(-90deg) scale(.9);-webkit-animation-name:
flipouttoleft;-webkit-animation-duration:125ms;-moz-transform:rotateY(-90deg) scale(.9);-moz-animation-name:flipouttoleft;-moz-animation-duration:125ms;transform:rotateY(-90deg) scale(.9);animation-name:flipouttoleft;animation-duration:125ms}.turn.in{-webkit-animation-name:flipintoright;-webkit-animation-duration:250ms;-moz-animation-name:flipintoright;-moz-animation-duration:250ms;animation-name:flipintoright;animation-duration:250ms}.turn.out.reverse{-webkit-transform:rotateY(90deg) scale(.9);-webkit-animation-name:flipouttoright;-moz-transform:rotateY(90deg) scale(.9);-moz-animation-name:flipouttoright;transform:rotateY(90deg) scale(.9);animation-name:flipouttoright}.turn.in.reverse{-webkit-animation-name:flipintoleft;-moz-animation-name:flipintoleft;animation-name:flipintoleft}@-webkit-keyframes flipouttoleft{from{-webkit-transform:rotateY(0)}to{-webkit-transform:rotateY(-90deg) scale(.9)}}@-moz-keyframes flipouttoleft{from{-moz-transform:rotateY(0)}to{-moz-transform:rot
ateY(-90deg) scale(.9)}}@keyframes flipouttoleft{from{transform:rotateY(0)}to{transform:rotateY(-90deg) scale(.9)}}@-webkit-keyframes flipouttoright{from{-webkit-transform:rotateY(0)}to{-webkit-transform:rotateY(90deg) scale(.9)}}@-moz-keyframes flipouttoright{from{-moz-transform:rotateY(0)}to{-moz-transform:rotateY(90deg) scale(.9)}}@keyframes flipouttoright{from{transform:rotateY(0)}to{transform:rotateY(90deg) scale(.9)}}@-webkit-keyframes flipintoleft{from{-webkit-transform:rotateY(-90deg) scale(.9)}to{-webkit-transform:rotateY(0)}}@-moz-keyframes flipintoleft{from{-moz-transform:rotateY(-90deg) scale(.9)}to{-moz-transform:rotateY(0)}}@keyframes flipintoleft{from{transform:rotateY(-90deg) scale(.9)}to{transform:rotateY(0)}}@-webkit-keyframes flipintoright{from{-webkit-transform:rotateY(90deg) scale(.9)}to{-webkit-transform:rotateY(0)}}@-moz-keyframes flipintoright{from{-moz-transform:rotateY(90deg) scale(.9)}to{-moz-transform:rotateY(0)}}@keyframes flipintoright{from{tran
sform:rotateY(90deg) scale(.9)}to{transform:rotateY(0)}}.flow{-webkit-transform-origin:50% 30%;-webkit-box-shadow:0 0 20px rgba(0,0,0,.4);-moz-transform-origin:50% 30%;-moz-box-shadow:0 0 20px rgba(0,0,0,.4);transform-origin:50% 30%;box-shadow:0 0 20px rgba(0,0,0,.4)}.ui-dialog.flow{-webkit-transform-origin:none;-webkit-box-shadow:none;-moz-transform-origin:none;-moz-box-shadow:none;transform-origin:none;box-shadow:none}.flow.out{-webkit-transform:translateX(-100%) scale(.7);-webkit-animation-name:flowouttoleft;-webkit-animation-timing-function:ease;-webkit-animation-duration:350ms;-moz-transform:translateX(-100%) scale(.7);-moz-animation-name:flowouttoleft;-moz-animation-timing-function:ease;-moz-animation-duration:350ms;transform:translateX(-100%) scale(.7);animation-name:flowouttoleft;animation-timing-function:ease;animation-duration:350ms}.flow.in{-webkit-transform:translateX(0) scale(1);-webkit-animation-name:flowinfromright;-webkit-animation-timing-function:ease;-webki
t-animation-duration:350ms;-moz-transform:translateX(0) scale(1);-moz-animation-name:flowinfromright;-moz-animation-timing-function:ease;-moz-animation-duration:350ms;transform:translateX(0) scale(1);animation-name:flowinfromright;animation-timing-function:ease;animation-duration:350ms}.flow.out.reverse{-webkit-transform:translateX(100%);-webkit-animation-name:flowouttoright;-moz-transform:translateX(100%);-moz-animation-name:flowouttoright;transform:translateX(100%);animation-name:flowouttoright}.flow.in.reverse{-webkit-animation-name:flowinfromleft;-moz-animation-name:flowinfromleft;animation-name:flowinfromleft}@-webkit-keyframes flowouttoleft{0%{-webkit-transform:translateX(0) scale(1)}60%,70%{-webkit-transform:translateX(0) scale(.7)}100%{-webkit-transform:translateX(-100%) scale(.7)}}@-moz-keyframes flowouttoleft{0%{-moz-transform:translateX(0) scale(1)}60%,70%{-moz-transform:translateX(0) scale(.7)}100%{-moz-transform:translateX(-100%) scale(.7)}}@keyframes flowouttol
eft{0%{transform:translateX(0) scale(1)}60%,70%{transform:translateX(0) scale(.7)}100%{transform:translateX(-100%) scale(.7)}}@-webkit-keyframes flowouttoright{0%{-webkit-transform:translateX(0) scale(1)}60%,70%{-webkit-transform:translateX(0) scale(.7)}100%{-webkit-transform:translateX(100%) scale(.7)}}@-moz-keyframes flowouttoright{0%{-moz-transform:translateX(0) scale(1)}60%,70%{-moz-transform:translateX(0) scale(.7)}100%{-moz-transform:translateX(100%) scale(.7)}}@keyframes flowouttoright{0%{transform:translateX(0) scale(1)}60%,70%{transform:translateX(0) scale(.7)}100%{transform:translateX(100%) scale(.7)}}@-webkit-keyframes flowinfromleft{0%{-webkit-transform:translateX(-100%) scale(.7)}30%,40%{-webkit-transform:translateX(0) scale(.7)}100%{-webkit-transform:translateX(0) scale(1)}}@-moz-keyframes flowinfromleft{0%{-moz-transform:translateX(-100%) scale(.7)}30%,40%{-moz-transform:translateX(0) scale(.7)}100%{-moz-transform:translateX(0) scale(1)}}@keyframes flowinfroml
eft{0%{transform:translateX(-100%) scale(.7)}30%,40%{transform:translateX(0) scale(.7)}100%{transform:translateX(0) scale(1)}}@-webkit-keyframes flowinfromright{0%{-webkit-transform:translateX(100%) scale(.7)}30%,40%{-webkit-transform:translateX(0) scale(.7)}100%{-webkit-transform:translateX(0) scale(1)}}@-moz-keyframes flowinfromright{0%{-moz-transform:translateX(100%) scale(.7)}30%,40%{-moz-transform:translateX(0) scale(.7)}100%{-moz-transform:translateX(0) scale(1)}}@keyframes flowinfromright{0%{transform:translateX(100%) scale(.7)}30%,40%{transform:translateX(0) scale(.7)}100%{transform:translateX(0) scale(1)}}.ui-grid-a,.ui-grid-b,.ui-grid-c,.ui-grid-d{overflow:hidden}.ui-block-a,.ui-block-b,.ui-block-c,.ui-block-d,.ui-block-e{margin:0;padding:0;border:0;float:left;min-height:1px;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;-ms-box-sizing:border-box;box-sizing:border-box}.ui-grid-solo .ui-block-a{display:block;float:none}.ui-grid-a .ui-block-a,.ui-grid-a .ui
-block-b{width:49.95%}.ui-grid-a>:nth-child(n){width:50%;margin-right:-.5px}.ui-grid-a .ui-block-a{clear:left}.ui-grid-b .ui-block-a,.ui-grid-b .ui-block-b,.ui-grid-b .ui-block-c{width:33.25%}.ui-grid-b>:nth-child(n){width:33.333%;margin-right:-.5px}.ui-grid-b .ui-block-a{clear:left}.ui-grid-c .ui-block-a,.ui-grid-c .ui-block-b,.ui-grid-c .ui-block-c,.ui-grid-c .ui-block-d{width:24.925%}.ui-grid-c>:nth-child(n){width:25%;margin-right:-.5px}.ui-grid-c .ui-block-a{clear:left}.ui-grid-d .ui-block-a,.ui-grid-d .ui-block-b,.ui-grid-d .ui-block-c,.ui-grid-d .ui-block-d,.ui-grid-d .ui-block-e{width:19.925%}.ui-grid-d>:nth-child(n){width:20%}.ui-grid-d .ui-block-a{clear:left}@media all and (max-width:35em){.ui-responsive .ui-block-a,.ui-responsive .ui-block-b,.ui-responsive .ui-block-c,.ui-responsive .ui-block-d,.ui-responsive .ui-block-e{width:100%;float:none}}.ui-header-fixed,.ui-footer-fixed{left:0;right:0;width:100%;position:fixed;z-index:1000}.ui-header-fixed{top:-1px;padding-t
op:1px}.ui-header-fixed.ui-fixed-hidden{top:0;padding-top:0}.ui-footer-fixed{bottom:-1px;padding-bottom:1px}.ui-footer-fixed.ui-fixed-hidden{bottom:0;padding-bottom:0}.ui-header-fullscreen,.ui-footer-fullscreen{filter:Alpha(Opacity=90);opacity:.9}.ui-page-header-fixed{padding-top:2.6875em}.ui-page-footer-fixed{padding-bottom:2.6875em}.ui-page-header-fullscreen>.ui-content,.ui-page-footer-fullscreen>.ui-content{padding:0}.ui-fixed-hidden{position:absolute}.ui-page-header-fullscreen .ui-fixed-hidden,.ui-page-footer-fullscreen .ui-fixed-hidden{left:-9999px}.ui-header-fixed .ui-btn,.ui-footer-fixed .ui-btn{z-index:10}.ui-android-2x-fixed .ui-li-has-thumb{-webkit-transform:translate3d(0,0,0)}.ui-navbar{max-width:100%}.ui-navbar.ui-mini{margin:0}.ui-navbar ul:before,.ui-navbar ul:after{content:" ";display:table}.ui-navbar ul:after{clear:both}.ui-navbar ul{list-style:none;margin:0;padding:0;position:relative;display:block;border:0;max-width:100%;overflow:visible;zoom:1}.ui-navbar l
i .ui-btn{display:block;text-align:center;margin:0 -1px 0 0;border-right-width:0}.ui-navbar li .ui-btn-icon-right .ui-icon{right:6px}.ui-navbar li:last-child .ui-btn,.ui-navbar .ui-grid-duo .ui-block-b .ui-btn{margin-right:0;border-right-width:1px}.ui-header .ui-navbar li:last-child .ui-btn,.ui-footer .ui-navbar li:last-child .ui-btn,.ui-header .ui-navbar .ui-grid-duo .ui-block-b .ui-btn,.ui-footer .ui-navbar .ui-grid-duo .ui-block-b .ui-btn{margin-right:-1px;border-right-width:0}.ui-navbar .ui-grid-duo li.ui-block-a:last-child .ui-btn{margin-right:-1px;border-right-width:1px}.ui-header .ui-navbar li .ui-btn,.ui-footer .ui-navbar li .ui-btn{border-top-width:0;border-bottom-width:0}.ui-header .ui-navbar .ui-grid-b li.ui-block-c .ui-btn,.ui-footer .ui-navbar .ui-grid-b li.ui-block-c .ui-btn{margin-right:-5px}.ui-header .ui-navbar .ui-grid-c li.ui-block-d .ui-btn,.ui-footer .ui-navbar .ui-grid-c li.ui-block-d .ui-btn,.ui-header .ui-navbar .ui-grid-d li.ui-block-e .ui-btn,.ui-fo
oter .ui-navbar .ui-grid-d li.ui-block-e .ui-btn{margin-right:-4px}.ui-header .ui-navbar .ui-grid-b li.ui-block-c .ui-btn-icon-right .ui-icon,.ui-footer .ui-navbar .ui-grid-b li.ui-block-c .ui-btn-icon-right .ui-icon,.ui-header .ui-navbar .ui-grid-c li.ui-block-d .ui-btn-icon-right .ui-icon,.ui-footer .ui-navbar .ui-grid-c li.ui-block-d .ui-btn-icon-right .ui-icon,.ui-header .ui-navbar .ui-grid-d li.ui-block-e .ui-btn-icon-right .ui-icon,.ui-footer .ui-navbar .ui-grid-d li.ui-block-e .ui-btn-icon-right .ui-icon{right:8px}.ui-navbar li .ui-btn .ui-btn-inner{padding-top:.7em;padding-bottom:.8em}.ui-navbar li .ui-btn-icon-top .ui-btn-inner{padding-top:30px}.ui-navbar li .ui-btn-icon-bottom .ui-btn-inner{padding-bottom:30px}.ui-btn{display:block;text-align:center;cursor:pointer;position:relative;margin:.5em 0;padding:0}.ui-mini{margin-top:.25em;margin-bottom:.25em}.ui-btn-left,.ui-btn-right,.ui-input-clear,.ui-btn-inline,.ui-grid-a .ui-btn,.ui-grid-b .ui-btn,.ui-grid-c .ui-btn,.
ui-grid-d .ui-btn,.ui-grid-e .ui-btn,.ui-grid-solo .ui-btn{margin-right:5px;margin-left:5px}.ui-btn-inner{font-size:16px;padding:.6em 20px;min-width:.75em;display:block;position:relative;text-overflow:ellipsis;overflow:hidden;white-space:nowrap;zoom:1}.ui-btn input,.ui-btn button{z-index:2}.ui-btn-left,.ui-btn-right,.ui-btn-inline{display:inline-block;vertical-align:middle}.ui-mobile .ui-btn-left,.ui-mobile .ui-btn-right,.ui-btn-left>.ui-btn,.ui-btn-right>.ui-btn{margin:0}.ui-btn-block{display:block}.ui-header>.ui-btn,.ui-footer>.ui-btn{display:inline-block;margin:0}.ui-header .ui-btn-block,.ui-footer .ui-btn-block{display:block}.ui-header .ui-btn-inner,.ui-footer .ui-btn-inner,.ui-mini .ui-btn-inner{font-size:12.5px;padding:.55em 11px .5em}.ui-fullsize .ui-btn-inner,.ui-fullsize .ui-btn-inner{font-size:16px;padding:.6em 20px}.ui-btn-icon-notext{width:24px;height:24px}.ui-btn-icon-notext .ui-btn-inner{padding:0;height:100%}.ui-btn-icon-notext .ui-btn-inner .ui-icon{margin:2p
x 1px 2px 3px;float:left}.ui-btn-text{position:relative;z-index:1;width:100%;-moz-user-select:none;-webkit-user-select:none;-ms-user-select:none}div.ui-btn-text{width:auto}.ui-btn-icon-notext .ui-btn-text{position:absolute;left:-9999px}.ui-btn-icon-left .ui-btn-inner{padding-left:40px}.ui-btn-icon-right .ui-btn-inner{padding-right:40px}.ui-btn-icon-top .ui-btn-inner{padding-top:40px}.ui-btn-icon-bottom .ui-btn-inner{padding-bottom:40px}.ui-header .ui-btn-icon-left .ui-btn-inner,.ui-footer .ui-btn-icon-left .ui-btn-inner,.ui-mini.ui-btn-icon-left .ui-btn-inner,.ui-mini .ui-btn-icon-left .ui-btn-inner{padding-left:30px}.ui-header .ui-btn-icon-right .ui-btn-inner,.ui-footer .ui-btn-icon-right .ui-btn-inner,.ui-mini.ui-btn-icon-right .ui-btn-inner,.ui-mini .ui-btn-icon-right .ui-btn-inner{padding-right:30px}.ui-header .ui-btn-icon-top .ui-btn-inner,.ui-footer .ui-btn-icon-top .ui-btn-inner{padding:30px 3px .5em}.ui-mini.ui-btn-icon-top .ui-btn-inner,.ui-mini .ui-btn-icon-top .ui
-btn-inner{padding-top:30px}.ui-header .ui-btn-icon-bottom .ui-btn-inner,.ui-footer .ui-btn-icon-bottom .ui-btn-inner{padding:.55em 3px 30px}.ui-mini.ui-btn-icon-bottom .ui-btn-inner,.ui-mini .ui-btn-icon-bottom .ui-btn-inner{padding-bottom:30px}.ui-btn-inner{-webkit-border-radius:inherit;border-radius:inherit}.ui-btn-icon-notext .ui-icon{display:block;z-index:0}.ui-btn-icon-left>.ui-btn-inner>.ui-icon,.ui-btn-icon-right>.ui-btn-inner>.ui-icon{position:absolute;top:50%;margin-top:-9px}.ui-btn-icon-top .ui-btn-inner .ui-icon,.ui-btn-icon-bottom .ui-btn-inner .ui-icon{position:absolute;left:50%;margin-left:-9px}.ui-btn-icon-left .ui-icon{left:10px}.ui-btn-icon-right .ui-icon{right:10px}.ui-btn-icon-top .ui-icon{top:10px}.ui-btn-icon-bottom .ui-icon{top:auto;bottom:10px}.ui-header .ui-btn-icon-left .ui-icon,.ui-footer .ui-btn-icon-left .ui-icon,.ui-mini.ui-btn-icon-left .ui-icon,.ui-mini .ui-btn-icon-left .ui-icon{left:5px}.ui-header .ui-btn-icon-right .ui-icon,.ui-footer .ui-b
tn-icon-right .ui-icon,.ui-mini.ui-btn-icon-right .ui-icon,.ui-mini .ui-btn-icon-right .ui-icon{right:5px}.ui-header .ui-btn-icon-top .ui-icon,.ui-footer .ui-btn-icon-top .ui-icon,.ui-mini.ui-btn-icon-top .ui-icon,.ui-mini .ui-btn-icon-top .ui-icon{top:5px}.ui-header .ui-btn-icon-bottom .ui-icon,.ui-footer .ui-btn-icon-bottom .ui-icon,.ui-mini.ui-btn-icon-bottom .ui-icon,.ui-mini .ui-btn-icon-bottom .ui-icon{bottom:5px}.ui-btn-hidden{position:absolute;top:0;left:0;width:100%;height:100%;-webkit-appearance:none;cursor:pointer;background:#fff;background:rgba(255,255,255,0);filter:Alpha(Opacity=0);opacity:.1;font-size:1px;border:0;text-indent:-9999px}.ui-disabled .ui-btn-hidden{display:none}.ui-disabled{z-index:1}.ui-field-contain .ui-btn.ui-submit{margin:0}label.ui-submit{font-size:16px;line-height:1.4;font-weight:400;margin:0 0 .3em;display:block}@media all and (min-width:28em){.ui-field-contain label.ui-submit{vertical-align:top;display:inline-block;width:20%;margin:0 2% 0 0
}.ui-field-contain .ui-btn.ui-submit{width:78%;display:inline-block;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;-ms-box-sizing:border-box;box-sizing:border-box}.ui-hide-label .ui-btn.ui-submit{width:auto;display:block}}.ui-collapsible-inset{margin:.5em 0}.ui-collapsible-heading{font-size:16px;display:block;margin:0 -15px;padding:0;position:relative}.ui-collapsible-inset .ui-collapsible-heading{margin:0}.ui-collapsible-heading .ui-btn{text-align:left;margin:0;border-left-width:0;border-right-width:0}.ui-collapsible-inset .ui-collapsible-heading .ui-btn{border-right-width:1px;border-left-width:1px}.ui-collapsible-collapsed+.ui-collapsible:not(.ui-collapsible-inset) .ui-collapsible-heading .ui-btn{border-top-width:0}.ui-collapsible-set .ui-collapsible:not(.ui-collapsible-inset) .ui-collapsible-heading .ui-btn{border-top-width:1px}.ui-collapsible-heading .ui-btn-inner{padding-left:12px;padding-right:12px}.ui-collapsible-heading .ui-btn-icon-left .ui-btn-inner{paddin
g-left:40px}.ui-collapsible-heading .ui-btn-icon-right .ui-btn-inner{padding-right:40px}.ui-collapsible-heading .ui-btn-icon-top .ui-btn-inner,.ui-collapsible-heading .ui-btn-icon-bottom .ui-btn-inner{text-align:center}.ui-collapsible-heading .ui-btn-icon-left.ui-mini .ui-btn-inner{padding-left:30px}.ui-collapsible-heading .ui-btn-icon-right.ui-mini .ui-btn-inner{padding-right:30px}.ui-collapsible-heading .ui-btn span.ui-btn{position:absolute;left:6px;top:50%;margin:-12px 0 0 0;width:20px;height:20px;padding:1px 0 1px 2px;text-indent:-9999px}.ui-collapsible-heading .ui-btn span.ui-btn .ui-btn-inner{padding:10px 0}.ui-collapsible-heading .ui-btn span.ui-btn .ui-icon{left:0;margin-top:-10px}.ui-collapsible-heading-status{position:absolute;top:-9999px;left:0}.ui-collapsible-content{display:block;margin:0 -15px;padding:10px 15px;border-left-width:0;border-right-width:0;border-top:0;background-image:none}.ui-collapsible-inset .ui-collapsible-content{margin:0;border-right-width:1p
x;border-left-width:1px}.ui-collapsible-content-collapsed{display:none}.ui-collapsible-set>.ui-collapsible.ui-corner-all{-webkit-border-radius:0;border-radius:0}.ui-collapsible-heading,.ui-collapsible-heading>.ui-btn{-webkit-border-radius:inherit;border-radius:inherit}.ui-collapsible-set .ui-collapsible.ui-first-child{-webkit-border-top-right-radius:inherit;border-top-right-radius:inherit;-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit}.ui-collapsible-content,.ui-collapsible-set .ui-collapsible.ui-last-child{-webkit-border-bottom-right-radius:inherit;border-bottom-right-radius:inherit;-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit}.ui-collapsible-themed-content:not(.ui-collapsible-collapsed)>.ui-collapsible-heading{-webkit-border-bottom-right-radius:0;border-bottom-right-radius:0;-webkit-border-bottom-left-radius:0;border-bottom-left-radius:0}.ui-collapsible-set{margin:.5em 0}.ui-collapsible-set .ui-collapsible{margin:-1px 0
0}.ui-collapsible-set .ui-collapsible.ui-first-child{margin-top:0}.ui-controlgroup,fieldset.ui-controlgroup{padding:0;margin:.5em 0;zoom:1}.ui-controlgroup.ui-mini,fieldset.ui-controlgroup.ui-mini{margin:.25em 0}.ui-field-contain .ui-controlgroup,.ui-field-contain fieldset.ui-controlgroup{margin:0}.ui-bar .ui-controlgroup{margin:0 5px}.ui-controlgroup-label{font-size:16px;line-height:1.4;font-weight:400;margin:0 0 .4em}.ui-controlgroup-controls label.ui-select,.ui-controlgroup-controls label.ui-submit{position:absolute;left:-9999px}.ui-controlgroup li{list-style:none}.ui-controlgroup .ui-btn{margin:0}.ui-controlgroup .ui-btn-icon-notext{width:auto;height:auto;top:auto}.ui-controlgroup .ui-btn-icon-notext .ui-btn-inner{height:20px;padding:.6em 20px}.ui-controlgroup-horizontal .ui-btn-icon-notext .ui-btn-inner{width:18px}.ui-controlgroup.ui-mini .ui-btn-icon-notext .ui-btn-inner,.ui-header .ui-controlgroup .ui-btn-icon-notext .ui-btn-inner,.ui-footer .ui-controlgroup .ui-btn-
icon-notext .ui-btn-inner{height:16px;padding:.55em 11px .5em}.ui-controlgroup .ui-btn-icon-notext .ui-btn-inner .ui-icon{position:absolute;top:50%;right:50%;margin:-9px -9px 0 0}.ui-controlgroup-horizontal .ui-btn-inner{text-align:center}.ui-controlgroup-horizontal.ui-mini .ui-btn-inner{height:16px;line-height:16px}.ui-controlgroup .ui-checkbox label,.ui-controlgroup .ui-radio label{font-size:16px}.ui-controlgroup-horizontal .ui-controlgroup-controls:before,.ui-controlgroup-horizontal .ui-controlgroup-controls:after{content:"";display:table}.ui-controlgroup-horizontal .ui-controlgroup-controls:after{clear:both}.ui-controlgroup-horizontal .ui-controlgroup-controls{display:inline-block;vertical-align:middle;zoom:1}.ui-controlgroup-horizontal .ui-controlgroup-controls>.ui-btn,.ui-controlgroup-horizontal .ui-controlgroup-controls li>.ui-btn,.ui-controlgroup-horizontal .ui-checkbox,.ui-controlgroup-horizontal .ui-radio,.ui-controlgroup-horizontal .ui-select{float:left;clear:none
;margin:0}.ui-controlgroup-horizontal .ui-select .ui-btn-text{width:auto}.ui-controlgroup-vertical .ui-btn{border-bottom-width:0}.ui-controlgroup-vertical .ui-btn.ui-last-child{border-bottom-width:1px}.ui-controlgroup-horizontal .ui-btn{border-right-width:0}.ui-controlgroup-horizontal .ui-btn.ui-last-child{border-right-width:1px}.ui-controlgroup .ui-btn-corner-all{-webkit-border-radius:0;border-radius:0}.ui-controlgroup .ui-controlgroup-controls,.ui-controlgroup .ui-radio,.ui-controlgroup .ui-checkbox,.ui-controlgroup .ui-select,.ui-controlgroup li{-webkit-border-radius:inherit;border-radius:inherit}.ui-controlgroup-vertical .ui-btn.ui-first-child{-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit;-webkit-border-top-right-radius:inherit;border-top-right-radius:inherit}.ui-controlgroup-vertical .ui-btn.ui-last-child{-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit;-webkit-border-bottom-right-radius:inherit;border-bottom-right-radi
us:inherit}.ui-controlgroup-horizontal .ui-btn.ui-first-child{-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit;-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit}.ui-controlgroup-horizontal .ui-btn.ui-last-child{-webkit-border-top-right-radius:inherit;border-top-right-radius:inherit;-webkit-border-bottom-right-radius:inherit;border-bottom-right-radius:inherit}.ui-controlgroup .ui-shadow:not(.ui-focus){-moz-box-shadow:none;-webkit-box-shadow:none;box-shadow:none}@media all and (min-width:28em){.ui-field-contain .ui-controlgroup-label{vertical-align:top;display:inline-block;width:20%;margin:0 2% 0 0}.ui-field-contain .ui-controlgroup-controls{width:78%;display:inline-block}.ui-field-contain .ui-controlgroup .ui-select{width:100%;display:block}.ui-field-contain .ui-controlgroup-horizontal .ui-select{width:auto}.ui-hide-label .ui-controlgroup-controls{width:100%}}.ui-dialog{background:none!important}.ui-dialog-contain{width:92.5%;max
-width:500px;margin:10% auto 15px;padding:0;position:relative;top:-15px}.ui-dialog-contain>.ui-header,.ui-dialog-contain>.ui-content,.ui-dialog-contain>.ui-footer{display:block;position:relative;width:auto;margin:0}.ui-dialog-contain>.ui-header{border:0;overflow:hidden;z-index:10;padding:0}.ui-dialog-contain>.ui-content{padding:15px}.ui-dialog-contain>.ui-footer{z-index:10;padding:0 15px}.ui-popup-open .ui-header-fixed,.ui-popup-open .ui-footer-fixed{position:absolute!important}.ui-popup-screen{background-image:url(data:image/gif;base64,R0lGODlhAQABAID/AMDAwAAAACH5BAEAAAAALAAAAAABAAEAAAICRAEAOw==);top:0;left:0;right:0;bottom:1px;position:absolute;filter:Alpha(Opacity=0);opacity:0;z-index:1099}.ui-popup-screen.in{opacity:.5;filter:Alpha(Opacity=50)}.ui-popup-screen.out{opacity:0;filter:Alpha(Opacity=0)}.ui-popup-container{z-index:1100;display:inline-block;position:absolute;padding:0;outline:0}.ui-popup{position:relative}.ui-popup.ui-content,.ui-popup .ui-content{overflow:visi
ble}.ui-popup>p,.ui-popup>h1,.ui-popup>h2,.ui-popup>h3,.ui-popup>h4,.ui-popup>h5,.ui-popup>h6{margin:.5em 7px}.ui-popup>span{display:block;margin:.5em 7px}.ui-popup .ui-title{font-size:16px;font-weight:700;margin-top:.5em;margin-bottom:.5em}.ui-popup-container .ui-content>p,.ui-popup-container .ui-content>h1,.ui-popup-container .ui-content>h2,.ui-popup-container .ui-content>h3,.ui-popup-container .ui-content>h4,.ui-popup-container .ui-content>h5,.ui-popup-container .ui-content>h6{margin:.5em 0}.ui-popup-container .ui-content>span{margin:0}.ui-popup-container .ui-content>p:first-child,.ui-popup-container .ui-content>h1:first-child,.ui-popup-container .ui-content>h2:first-child,.ui-popup-container .ui-content>h3:first-child,.ui-popup-container .ui-content>h4:first-child,.ui-popup-container .ui-content>h5:first-child,.ui-popup-container .ui-content>h6:first-child{margin-top:0}.ui-popup-container .ui-content>p:last-child,.ui-popup-container .ui-content>h1:last-child,.ui-popup-co
ntainer .ui-content>h2:last-child,.ui-popup-container .ui-content>h3:last-child,.ui-popup-container .ui-content>h4:last-child,.ui-popup-container .ui-content>h5:last-child,.ui-popup-container .ui-content>h6:last-child{margin-bottom:0}.ui-popup>img{width:auto;height:auto;max-width:100%;max-height:100%;vertical-align:middle}.ui-popup:not(.ui-content)>img:only-child,.ui-popup:not(.ui-content)>.ui-btn-left:first-child+img:last-child,.ui-popup:not(.ui-content)>.ui-btn-right:first-child+img:last-child{-webkit-border-radius:inherit;border-radius:inherit}.ui-popup iframe{vertical-align:middle}@media all and (min-width:28em){.ui-popup .ui-field-contain label.ui-submit,.ui-popup .ui-field-contain .ui-controlgroup-label,.ui-popup .ui-field-contain label.ui-select,.ui-popup .ui-field-contain label.ui-input-text{font-size:16px;line-height:1.4;display:block;font-weight:400;margin:0 0 .3em}.ui-popup .ui-field-contain .ui-btn.ui-submit,.ui-popup .ui-field-contain .ui-controlgroup-controls,.
ui-popup .ui-field-contain .ui-select,.ui-popup .ui-field-contain input.ui-input-text,.ui-popup .ui-field-contain textarea.ui-input-text,.ui-popup .ui-field-contain .ui-input-search{width:100%;display:block}}.ui-popup>.ui-btn-left,.ui-popup>.ui-btn-right{position:absolute;top:-9px;margin:0;z-index:1101}.ui-popup>.ui-btn-left{left:-9px}.ui-popup>.ui-btn-right{right:-9px}.ui-popup-hidden{top:-99999px;left:-9999px}.ui-checkbox,.ui-radio{position:relative;clear:both;margin:0;z-index:1}.ui-checkbox .ui-btn,.ui-radio .ui-btn{text-align:left;z-index:2}.ui-controlgroup .ui-checkbox .ui-btn,.ui-controlgroup .ui-radio .ui-btn{margin:0}.ui-checkbox .ui-btn-inner,.ui-radio .ui-btn-inner{white-space:normal}.ui-checkbox .ui-btn-icon-left .ui-btn-inner,.ui-radio .ui-btn-icon-left .ui-btn-inner{padding-left:45px}.ui-checkbox .ui-mini.ui-btn-icon-left .ui-btn-inner,.ui-radio .ui-mini.ui-btn-icon-left .ui-btn-inner{padding-left:36px}.ui-checkbox .ui-btn-icon-right .ui-btn-inner,.ui-radio .ui-
btn-icon-right .ui-btn-inner{padding-right:45px}.ui-checkbox .ui-mini.ui-btn-icon-right .ui-btn-inner,.ui-radio .ui-mini.ui-btn-icon-right .ui-btn-inner{padding-right:36px}.ui-checkbox .ui-btn-icon-top .ui-btn-inner,.ui-radio .ui-btn-icon-top .ui-btn-inner{padding-right:0;padding-left:0;text-align:center}.ui-checkbox .ui-btn-icon-bottom .ui-btn-inner,.ui-radio .ui-btn-icon-bottom .ui-btn-inner{padding-right:0;padding-left:0;text-align:center}.ui-checkbox .ui-icon,.ui-radio .ui-icon{top:1.1em}.ui-checkbox .ui-btn-icon-left .ui-icon,.ui-radio .ui-btn-icon-left .ui-icon{left:15px}.ui-checkbox .ui-mini.ui-btn-icon-left .ui-icon,.ui-radio .ui-mini.ui-btn-icon-left .ui-icon{left:9px}.ui-checkbox .ui-btn-icon-right .ui-icon,.ui-radio .ui-btn-icon-right .ui-icon{right:15px}.ui-checkbox .ui-mini.ui-btn-icon-right .ui-icon,.ui-radio .ui-mini.ui-btn-icon-right .ui-icon{right:9px}.ui-checkbox .ui-btn-icon-top .ui-icon,.ui-radio .ui-btn-icon-top .ui-icon{top:10px}.ui-checkbox .ui-btn-ico
n-bottom .ui-icon,.ui-radio .ui-btn-icon-bottom .ui-icon{top:auto;bottom:10px}.ui-checkbox .ui-btn-icon-right .ui-icon,.ui-radio .ui-btn-icon-right .ui-icon{right:15px}.ui-checkbox .ui-mini.ui-btn-icon-right .ui-icon,.ui-radio .ui-mini.ui-btn-icon-right .ui-icon{right:9px}.ui-controlgroup-horizontal .ui-checkbox .ui-icon,.ui-controlgroup-horizontal .ui-radio .ui-icon{display:none}.ui-controlgroup-horizontal .ui-checkbox .ui-btn-inner,.ui-controlgroup-horizontal .ui-radio .ui-btn-inner{padding:.6em 20px}.ui-controlgroup-horizontal .ui-checkbox .ui-mini .ui-btn-inner,.ui-controlgroup-horizontal .ui-radio .ui-mini .ui-btn-inner{padding:.55em 11px .5em}.ui-checkbox input,.ui-radio input{position:absolute;left:20px;top:50%;width:10px;height:10px;margin:-5px 0 0 0;outline:0!important;z-index:1}.ui-field-contain,fieldset.ui-field-contain{padding:.8em 0;margin:0;border-width:0 0 1px;overflow:visible}.ui-field-contain:last-child{border-bottom-width:0}.ui-field-contain{max-width:100%}
@media all and (min-width:28em){.ui-field-contain,.ui-mobile fieldset.ui-field-contain{border-width:0;padding:0;margin:1em 0}}.ui-select{display:block;position:relative}.ui-select select{position:absolute;left:-9999px;top:-9999px}.ui-select .ui-btn{opacity:1}.ui-field-contain .ui-select .ui-btn{margin:0}.ui-select .ui-btn select{cursor:pointer;-webkit-appearance:none;left:0;top:0;width:100%;min-height:1.5em;min-height:100%;height:3em;max-height:100%;filter:Alpha(Opacity=0);opacity:0;z-index:2}.ui-select .ui-disabled{opacity:.3}.ui-select .ui-disabled select{display:none}@-moz-document url-prefix(){.ui-select .ui-btn select{opacity:.0001}}.ui-select .ui-btn.ui-select-nativeonly{border-radius:0;border:0}.ui-select .ui-btn.ui-select-nativeonly select{opacity:1;text-indent:0;display:block}.ui-select .ui-disabled.ui-select-nativeonly .ui-btn-inner{opacity:0}.ui-select .ui-btn-icon-right .ui-btn-inner,.ui-select .ui-li-has-count .ui-btn-inner{padding-right:45px}.ui-select .ui-mini
.ui-btn-icon-right .ui-btn-inner{padding-right:32px}.ui-select .ui-btn-icon-right.ui-li-has-count .ui-btn-inner{padding-right:80px}.ui-select .ui-mini.ui-btn-icon-right.ui-li-has-count .ui-btn-inner{padding-right:67px}.ui-select .ui-btn-icon-right .ui-icon{right:15px}.ui-select .ui-mini.ui-btn-icon-right .ui-icon{right:7px}.ui-select .ui-btn-icon-right.ui-li-has-count .ui-li-count{right:45px}.ui-select .ui-mini.ui-btn-icon-right.ui-li-has-count .ui-li-count{right:32px}label.ui-select{font-size:16px;line-height:1.4;font-weight:400;margin:0 0 .3em;display:block}.ui-select .ui-btn-text,.ui-selectmenu .ui-btn-text{display:block;min-height:1em;overflow:hidden!important}.ui-select .ui-btn-text{text-overflow:ellipsis}.ui-selectmenu{padding:6px;min-width:160px}.ui-selectmenu .ui-listview{margin:0}.ui-selectmenu .ui-btn.ui-li-divider{cursor:default}.ui-screen-hidden,.ui-selectmenu-list .ui-li .ui-icon{display:none}.ui-selectmenu-list .ui-li .ui-icon{display:block}.ui-li.ui-selectmenu
-placeholder{display:none}.ui-selectmenu .ui-header{margin:0;padding:0}.ui-selectmenu.ui-popup .ui-header{-webkit-border-top-left-radius:0;border-top-left-radius:0;-webkit-border-top-right-radius:0;border-top-right-radius:0}.ui-selectmenu .ui-header .ui-title{margin:.6em 46px .8em}@media all and (min-width:28em){.ui-field-contain label.ui-select{vertical-align:top;display:inline-block;width:20%;margin:0 2% 0 0}.ui-field-contain .ui-select{width:78%;display:inline-block}.ui-hide-label .ui-select{width:100%}}.ui-selectmenu .ui-header h1:after{content:'.';visibility:hidden}label.ui-input-text{font-size:16px;line-height:1.4;display:block;font-weight:400;margin:0 0 .3em}input.ui-input-text,textarea.ui-input-text{background-image:none;padding:.4em;margin:.5em 0;min-height:1.4em;line-height:1.4em;font-size:16px;display:block;width:100%;outline:0}input.ui-mini,.ui-mini input,textarea.ui-mini{font-size:14px}div.ui-input-text input.ui-input-text,div.ui-input-text textarea.ui-input-tex
t,.ui-input-search input.ui-input-text{border:0;width:100%;padding:.4em 0;margin:0;display:block;background:transparent none;outline:0!important}.ui-input-search,div.ui-input-text{margin:.5em 0;background-image:none;position:relative}.ui-input-search{padding:0 30px}div.ui-input-text{padding:0 .4em}div.ui-input-has-clear{padding:0 30px 0 .4em}input.ui-input-text.ui-mini,textarea.ui-input-text.ui-mini,.ui-input-search.ui-mini,div.ui-input-text.ui-mini{margin:.25em 0}.ui-field-contain input.ui-input-text,.ui-field-contain textarea.ui-input-text,.ui-field-contain .ui-input-search,.ui-field-contain div.ui-input-text{margin:0}textarea.ui-input-text{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;-ms-box-sizing:border-box;box-sizing:border-box}input.ui-input-text{-webkit-appearance:none}textarea.ui-input-text{height:50px;-webkit-transition:height 200ms linear;-moz-transition:height 200ms linear;-o-transition:height 200ms linear;transition:height 200ms linear}textarea.ui-mi
ni{height:45px}.ui-icon-searchfield:after{position:absolute;left:7px;top:50%;margin-top:-9px;content:"";width:18px;height:18px;opacity:.5}.ui-input-search .ui-input-clear,.ui-input-text .ui-input-clear{position:absolute;right:0;top:50%;margin-top:-13px}.ui-mini .ui-input-clear{right:-3px}.ui-input-search .ui-input-clear-hidden,.ui-input-text .ui-input-clear-hidden{display:none}input::-moz-placeholder,textarea::-moz-placeholder{color:#aaa}input[type=number]::-webkit-outer-spin-button{margin:0}@media all and (min-width:28em){.ui-field-contain label.ui-input-text{vertical-align:top;display:inline-block;width:20%;margin:0 2% 0 0}.ui-field-contain input.ui-input-text,.ui-field-contain textarea.ui-input-text,.ui-field-contain .ui-input-search,.ui-field-contain div.ui-input-text{width:78%;display:inline-block}.ui-field-contain .ui-input-search,.ui-field-contain div.ui-input-text{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;-ms-box-sizing:border-box;box-sizing:border-box
}.ui-hide-label input.ui-input-text,.ui-hide-label textarea.ui-input-text,.ui-hide-label .ui-input-search,.ui-hide-label div.ui-input-text,.ui-input-search input.ui-input-text,div.ui-input-text input.ui-input-text{width:100%}}.ui-rangeslider{zoom:1;margin:0}.ui-rangeslider:before,.ui-rangeslider:after{content:"";display:table}.ui-rangeslider:after{clear:both}.ui-rangeslider input.ui-input-text.ui-slider-input{margin:.57143em 0}.ui-rangeslider.ui-mini input.ui-slider-input{margin:.28571em 0}.ui-rangeslider input.ui-slider-input.ui-rangeslider-last{float:right}.ui-rangeslider .ui-rangeslider-sliders{position:relative;overflow:visible;height:30px;margin:.5em 68px}.ui-rangeslider.ui-mini .ui-rangeslider-sliders{margin:.25em 68px}.ui-field-contain .ui-rangeslider input.ui-slider-input,.ui-field-contain .ui-rangeslider.ui-mini input.ui-slider-input,.ui-field-contain .ui-rangeslider .ui-rangeslider-sliders,.ui-field-contain .ui-rangeslider.ui-mini .ui-rangeslider-sliders{margin-top
:0;margin-bottom:0}.ui-rangeslider .ui-rangeslider-sliders .ui-slider-track{position:absolute;top:6px;right:0;left:0;margin:0}.ui-rangeslider.ui-mini .ui-rangeslider-sliders .ui-slider-track{top:8px}.ui-rangeslider .ui-slider-track:first-child .ui-slider-bg{display:none}.ui-rangeslider .ui-rangeslider-sliders .ui-slider-track:first-child{background-color:transparent;background:0;border-width:0;height:0}html >body .ui-rangeslider .ui-rangeslider-sliders .ui-slider-track:first-child{height:15px;border-width:1px}html >body .ui-rangeslider.ui-mini .ui-rangeslider-sliders .ui-slider-track:first-child{height:12px}@media all and (min-width:28em){.ui-field-contain .ui-rangeslider label.ui-slider{float:left}.ui-field-contain .ui-rangeslider input.ui-slider-input{position:relative;z-index:1}.ui-field-contain .ui-rangeslider input.ui-slider-input.ui-rangeslider-first,.ui-field-contain .ui-rangeslider.ui-mini input.ui-slider-input.ui-rangeslider-first{margin-right:17px}.ui-field-contain
.ui-rangeslider .ui-rangeslider-sliders,.ui-field-contain .ui-rangeslider.ui-mini .ui-rangeslider-sliders{float:left;width:78%;margin:0 -68px}.ui-field-contain .ui-rangeslider .ui-slider-track,.ui-field-contain .ui-rangeslider.ui-mini .ui-slider-track{right:68px;left:68px}.ui-field-contain.ui-hide-label .ui-rangeslider input.ui-slider-input.ui-rangeslider-first{margin:0}.ui-field-contain.ui-hide-label .ui-rangeslider .ui-rangeslider-sliders,.ui-field-contain.ui-hide-label .ui-rangeslider.ui-mini .ui-rangeslider-sliders{width:auto;float:none;margin:0 68px}.ui-field-contain.ui-hide-label .ui-rangeslider .ui-slider-track,.ui-field-contain.ui-hide-label .ui-rangeslider.ui-mini .ui-slider-track{right:0;left:0}}.ui-listview{margin:0}ol.ui-listview,ol.ui-listview .ui-li-divider{counter-reset:listnumbering}.ui-content .ui-listview,.ui-panel-inner>.ui-listview{margin:-15px}.ui-collapsible-content>.ui-listview{margin:-10px -15px}.ui-content .ui-listview-inset,.ui-panel-inner .ui-list
view-inset{margin:1em 0}.ui-collapsible-content .ui-listview-inset{margin:.5em 0}.ui-listview,.ui-li{list-style:none;padding:0}.ui-li,.ui-li.ui-field-contain{display:block;margin:0;position:relative;overflow:visible;text-align:left;border-width:0;border-top-width:1px}.ui-li.ui-btn,.ui-li.ui-field-contain,.ui-li-divider,.ui-li-static{margin:0}.ui-listview-inset .ui-li{border-right-width:1px;border-left-width:1px}.ui-li.ui-last-child,.ui-li.ui-field-contain.ui-last-child{border-bottom-width:1px}.ui-collapsible-content>.ui-listview:not(.ui-listview-inset)>.ui-li.ui-first-child{border-top-width:0}.ui-collapsible-themed-content .ui-listview:not(.ui-listview-inset)>.ui-li.ui-last-child{border-bottom-width:0}.ui-li .ui-btn-text a.ui-link-inherit{text-overflow:ellipsis;overflow:hidden;white-space:nowrap}.ui-li-static{background-image:none}.ui-li-divider{padding:.5em 15px;font-size:14px;font-weight:700}ol.ui-listview .ui-link-inherit:before,ol.ui-listview .ui-li-static:before,.ui-li-
dec{font-size:.8em;display:inline-block;padding-right:.3em;font-weight:400;counter-increment:listnumbering;content:counter(listnumbering) ". "}ol.ui-listview .ui-li-jsnumbering:before{content:""!important}.ui-listview .ui-li>.ui-btn-text{-webkit-border-radius:inherit;border-radius:inherit}.ui-listview>.ui-li.ui-first-child,.ui-listview .ui-btn.ui-first-child>.ui-li>.ui-btn-text>.ui-link-inherit{-webkit-border-top-right-radius:inherit;border-top-right-radius:inherit;-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit}.ui-listview>.ui-li.ui-last-child,.ui-listview .ui-btn.ui-last-child>.ui-li>.ui-btn-text>.ui-link-inherit,.ui-collapsible-content>.ui-listview:not(.ui-listview-inset),.ui-collapsible-content>.ui-listview:not(.ui-listview-inset) .ui-li.ui-last-child{-webkit-border-bottom-right-radius:inherit;border-bottom-right-radius:inherit;-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit}.ui-listview>.ui-li.ui-first-child .ui-li-link
-alt{-webkit-border-top-right-radius:inherit;border-top-right-radius:inherit}.ui-listview>.ui-li.ui-last-child .ui-li-link-alt{-webkit-border-bottom-right-radius:inherit;border-bottom-right-radius:inherit}.ui-listview>.ui-li.ui-first-child .ui-li-thumb:not(.ui-li-icon){-webkit-border-top-left-radius:inherit;border-top-left-radius:inherit}.ui-listview>.ui-li.ui-last-child .ui-li-thumb:not(.ui-li-icon){-webkit-border-bottom-left-radius:inherit;border-bottom-left-radius:inherit}.ui-li>.ui-btn-inner{display:block;position:relative;padding:0}.ui-li .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li{padding:.7em 15px;display:block}.ui-li-has-thumb .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-thumb{min-height:59px;padding-left:100px}.ui-li-has-icon .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-icon{min-height:20px;padding-left:40px}.ui-li-has-count .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-count,.ui-li-divider.ui-li-has-count{padding-right:45px}.
ui-li-has-arrow .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-arrow{padding-right:40px}.ui-li-has-arrow.ui-li-has-count .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-arrow.ui-li-has-count{padding-right:75px}.ui-li-heading{font-size:16px;font-weight:700;display:block;margin:.6em 0;text-overflow:ellipsis;overflow:hidden;white-space:nowrap}.ui-li-desc{font-size:12px;font-weight:400;display:block;margin:-.5em 0 .6em;text-overflow:ellipsis;overflow:hidden;white-space:nowrap}ol.ui-listview>.ui-li .ui-li-heading{display:inline-block;width:100%;margin-left:-1.3em;text-indent:1.3em;vertical-align:middle}ol.ui-listview>.ui-li .ui-li-desc:not(.ui-li-aside){text-indent:1.55em}.ui-li-thumb,.ui-listview .ui-li-icon{position:absolute;left:1px;top:0;max-height:80px;max-width:80px}.ui-listview .ui-li-icon{max-height:16px;max-width:16px;left:10px;top:.9em}.ui-li-thumb,.ui-listview .ui-li-icon,.ui-li-content{float:left;margin-right:10px}.ui-li-aside{float:right;width:50%;te
xt-align:right;margin:.3em 0}@media all and (min-width:480px){.ui-li-aside{width:45%}}.ui-li-divider{cursor:default}.ui-li-has-alt .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-alt{padding-right:53px}.ui-li-has-alt.ui-li-has-count .ui-btn-inner a.ui-link-inherit,.ui-li-static.ui-li-has-alt.ui-li-has-count{padding-right:88px}.ui-li-has-count .ui-li-count{position:absolute;font-size:11px;font-weight:700;padding:.2em .5em;top:50%;margin-top:-.9em;right:10px}.ui-li-has-count.ui-li-divider .ui-li-count,.ui-li-has-count .ui-link-inherit .ui-li-count{margin-top:-.95em}.ui-li-has-arrow.ui-li-has-count .ui-li-count{right:40px}.ui-li-has-alt.ui-li-has-count .ui-li-count{right:53px}.ui-li-link-alt{position:absolute;width:40px;height:100%;border-width:0;border-left-width:1px;top:0;right:0;margin:0;padding:0;z-index:2}.ui-li-link-alt .ui-btn{overflow:hidden;position:absolute;right:8px;top:50%;margin:-13px 0 0 0;border-bottom-width:1px;z-index:-1}.ui-li-link-alt .ui-btn-inner{pa
dding:0;height:100%;position:absolute;width:100%;top:0;left:0}.ui-li-link-alt .ui-btn .ui-icon{right:50%;margin-right:-9px}.ui-li-link-alt .ui-btn-icon-notext .ui-btn-inner .ui-icon{position:absolute;top:50%;margin-top:-9px}.ui-listview * .ui-btn-inner>.ui-btn>.ui-btn-inner{border-top:0}.ui-listview-filter{border-width:0;overflow:hidden;margin:-15px -15px 15px -15px}.ui-collapsible-content .ui-listview-filter{margin:-10px -15px 10px -15px;border-bottom:inherit}.ui-listview-filter-inset{margin:-15px -5px;background:transparent}.ui-collapsible-content .ui-listview-filter-inset{margin:-5px;border-bottom-width:0}.ui-listview-filter .ui-input-search{margin:5px;width:auto;display:block}.ui-li.ui-screen-hidden{display:none}@media only screen and (min-device-width:768px) and (max-device-width:1024px){.ui-li .ui-btn-text{overflow:visible}}label.ui-slider{font-size:16px;line-height:1.4;font-weight:400;margin:0;display:block}.ui-field-contain label.ui-slider{margin-bottom:.4em}div.ui-s
lider{height:30px;margin:.5em 0;zoom:1}div.ui-slider.ui-mini{margin:.25em 0}.ui-field-contain div.ui-slider,.ui-field-contain div.ui-slider.ui-mini{margin:0}div.ui-slider:before,div.ui-slider:after{content:"";display:table}div.ui-slider:after{clear:both}input.ui-input-text.ui-slider-input{display:block;float:left;margin:0;padding:4px;width:40px;height:22px;line-height:22px;font-size:14px;border-width:0;background-image:none;font-weight:700;text-align:center;vertical-align:text-bottom;outline:0;-webkit-box-sizing:content-box;-moz-box-sizing:content-box;-ms-box-sizing:content-box;box-sizing:content-box}.ui-slider-input::-webkit-outer-spin-button,.ui-slider-input::-webkit-inner-spin-button{-webkit-appearance:none;margin:0}.ui-slider-track,.ui-slider-switch{position:relative;overflow:visible;height:15px;margin:0 15px 0 68px;top:6px}.ui-slider-track.ui-mini{height:12px;top:8px}.ui-slider-bg{border:0;height:100%}.ui-slider-track .ui-btn.ui-slider-handle,.ui-slider-switch .ui-btn.u
i-slider-handle{position:absolute;z-index:1;top:50%;width:28px;height:28px;margin:-15px 0 0 -15px;outline:0}.ui-slider-track.ui-mini .ui-slider-handle{height:14px;width:14px;margin:-8px 0 0 -7px}.ui-slider-handle .ui-btn-inner{padding:0;height:100%}.ui-slider-track.ui-mini .ui-slider-handle .ui-btn-inner{height:30px;width:30px;padding:0;margin:-9px 0 0 -9px;border-top:0}select.ui-slider-switch{display:none}div.ui-slider-switch{display:inline-block;height:32px;width:5.8em;margin:.5em 0;top:0}div.ui-slider-switch:before,div.ui-slider-switch:after{display:none;clear:none}div.ui-slider-switch.ui-mini{width:5em;height:29px;margin:.25em 0;top:0}.ui-field-contain .ui-slider-switch,.ui-field-contain .ui-slider-switch.ui-mini{margin:0}.ui-slider-inneroffset{margin:0 16px;position:relative;z-index:1}.ui-slider-switch.ui-mini .ui-slider-inneroffset{margin:0 15px 0 14px}.ui-slider-switch .ui-btn.ui-slider-handle{margin:1px 0 0 -15px}.ui-slider-switch.ui-mini .ui-slider-handle{width:25px
;height:25px;margin:1px 0 0 -13px;padding:0}.ui-slider-handle-snapping{-webkit-transition:left 70ms linear;-moz-transition:left 70ms linear}.ui-slider-switch.ui-mini .ui-slider-handle .ui-btn-inner{height:30px;width:30px;padding:0;margin:0;border-top:0}.ui-slider-switch .ui-slider-label{position:absolute;text-align:center;width:100%;overflow:hidden;font-size:16px;top:0;line-height:2;min-height:100%;border-width:0;white-space:nowrap;cursor:pointer}.ui-slider-switch.ui-mini .ui-slider-label{font-size:14px}.ui-slider-switch .ui-slider-label-a{z-index:1;left:0;text-indent:-1.5em}.ui-slider-switch .ui-slider-label-b{z-index:0;right:0;text-indent:1.5em}@media all and (min-width:28em){.ui-field-contain label.ui-slider{vertical-align:top;display:inline-block;width:20%;margin:0 2% 0 0}.ui-field-contain div.ui-slider{display:inline-block;width:78%}.ui-field-contain.ui-hide-label div.ui-slider{display:block;width:auto}.ui-field-contain div.ui-slider-switch,.ui-field-contain.ui-hide-lab
el div.ui-slider-switch{display:inline-block;width:5.8em}.ui-field-contain div.ui-slider-switch.ui-mini{width:5em}}.ui-table{border:0;border-collapse:collapse;padding:0;width:100%}.ui-table th,.ui-table td{line-height:1.5em;text-align:left;padding:.4em .5em;vertical-align:top}.ui-table th .ui-btn,.ui-table td .ui-btn{line-height:normal}.ui-table th{font-weight:700}.ui-table caption{text-align:left;margin-bottom:1.4em;opacity:.5}.table-stroke thead th{border-bottom:1px solid #d6d6d6;border-bottom:1px solid rgba(0,0,0,.1)}.table-stroke tbody th,.table-stroke tbody td{border-bottom:1px solid #e6e6e6;border-bottom:1px solid rgba(0,0,0,.05)}.table-stripe tbody tr:nth-child(odd) td,.table-stripe tbody tr:nth-child(odd) th{background-color:#eee;background-color:rgba(0,0,0,.04)}.table-stripe thead th,.table-stripe tbody tr:last-child{border-bottom:1px solid #d6d6d6;border-bottom:1px solid rgba(0,0,0,.1)}.ui-table-columntoggle-btn{float:right;margin-bottom:.8em}.ui-table-columntoggle
-popup fieldset{margin:0}@media only all{th.ui-table-priority-6,td.ui-table-priority-6,th.ui-table-priority-5,td.ui-table-priority-5,th.ui-table-priority-4,td.ui-table-priority-4,th.ui-table-priority-3,td.ui-table-priority-3,th.ui-table-priority-2,td.ui-table-priority-2,th.ui-table-priority-1,td.ui-table-priority-1{display:none}}@media screen and (min-width:20em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-1,.ui-table-columntoggle.ui-responsive td.ui-table-priority-1{display:table-cell}}@media screen and (min-width:30em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-2,.ui-table-columntoggle.ui-responsive td.ui-table-priority-2{display:table-cell}}@media screen and (min-width:40em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-3,.ui-table-columntoggle.ui-responsive td.ui-table-priority-3{display:table-cell}}@media screen and (min-width:50em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-4,.ui-table-columntoggle.ui-responsive t
d.ui-table-priority-4{display:table-cell}}@media screen and (min-width:60em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-5,.ui-table-columntoggle.ui-responsive td.ui-table-priority-5{display:table-cell}}@media screen and (min-width:70em){.ui-table-columntoggle.ui-responsive th.ui-table-priority-6,.ui-table-columntoggle.ui-responsive td.ui-table-priority-6{display:table-cell}}.ui-table-columntoggle th.ui-table-cell-hidden,.ui-table-columntoggle td.ui-table-cell-hidden,.ui-table-columntoggle.ui-responsive th.ui-table-cell-hidden,.ui-table-columntoggle.ui-responsive td.ui-table-cell-hidden{display:none}.ui-table-columntoggle th.ui-table-cell-visible,.ui-table-columntoggle td.ui-table-cell-visible,.ui-table-columntoggle.ui-responsive th.ui-table-cell-visible,.ui-table-columntoggle.ui-responsive td.ui-table-cell-visible{display:table-cell}.ui-table-reflow td .ui-table-cell-label,.ui-table-reflow th .ui-table-cell-label{display:none}@media only all{.ui-table-reflow t
head td,.ui-table-reflow thead th{display:none}.ui-table-reflow td,.ui-table-reflow th{text-align:left;display:block}.ui-table-reflow tbody th{margin-top:3em}.ui-table-reflow td .ui-table-cell-label,.ui-table-reflow th .ui-table-cell-label{display:block;padding:.4em;min-width:30%;display:inline-block;margin:-.4em 1em -.4em -.4em}.ui-table-reflow th .ui-table-cell-label-top,.ui-table-reflow td .ui-table-cell-label-top{display:block;padding:.4em 0;margin:.4em 0;text-transform:uppercase;font-size:.9em;font-weight:400}}@media (min-width:35em){.ui-table-reflow.ui-responsive{display:table-row-group}.ui-table-reflow.ui-responsive td,.ui-table-reflow.ui-responsive th,.ui-table-reflow.ui-responsive tbody th,.ui-table-reflow.ui-responsive tbody td,.ui-table-reflow.ui-responsive thead td,.ui-table-reflow.ui-responsive thead th{display:table-cell;margin:0}.ui-table-reflow.ui-responsive td .ui-table-cell-label,.ui-table-reflow.ui-responsive th .ui-table-cell-label{display:none}}@media (m
ax-width:35em){.ui-table-reflow.ui-responsive td,.ui-table-reflow.ui-responsive th{width:100%;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box;float:left;clear:left}}.ui-panel{width:17em;min-height:100%;max-height:none;border-width:0;position:absolute;top:0;display:block}.ui-panel-closed{width:0;max-height:100%;overflow:hidden;visibility:hidden}.ui-panel-fixed{position:fixed;bottom:-1px;padding-bottom:1px}.ui-panel-display-overlay{z-index:1001}.ui-panel-display-reveal{z-index:0}.ui-panel-display-push{z-index:999}.ui-panel-inner{padding:15px}.ui-panel-content-wrap{position:relative;left:0;min-height:inherit;border:0;z-index:999}.ui-panel-content-wrap-display-overlay,.ui-panel-animate.ui-panel-content-wrap>.ui-header,.ui-panel-content-wrap-closed{position:static}.ui-panel-dismiss{position:absolute;top:0;left:0;height:100%;width:100%;z-index:1002;display:none}.ui-panel-dismiss-open{display:block}.ui-panel-animate{-webkit-transition:-webkit-transfor
m 350ms ease;-moz-transition:-moz-transform 350ms ease;transition:transform 350ms ease}.ui-panel-animate.ui-panel:not(.ui-panel-display-reveal),.ui-panel-animate.ui-panel:not(.ui-panel-display-reveal)>div,.ui-panel-animate.ui-panel-closed.ui-panel-display-reveal>div,.ui-panel-animate.ui-panel-content-wrap,.ui-panel-animate.ui-panel-content-fixed-toolbar{-webkit-backface-visibility:hidden;-webkit-transform:translate3d(0,0,0)}.ui-panel-position-left{left:-17em}.ui-panel-animate.ui-panel-position-left.ui-panel-display-overlay,.ui-panel-animate.ui-panel-position-left.ui-panel-display-push{left:0;-webkit-transform:translate3d(-17em,0,0);-moz-transform:translate3d(-17em,0,0);transform:translate3d(-17em,0,0)}.ui-panel-position-left.ui-panel-display-reveal,.ui-panel-position-left.ui-panel-open{left:0}.ui-panel-animate.ui-panel-position-left.ui-panel-open.ui-panel-display-overlay,.ui-panel-animate.ui-panel-position-left.ui-panel-open.ui-panel-display-push{-webkit-transform:translate3
d(0,0,0);transform:translate3d(0,0,0);-moz-transform:none}.ui-panel-position-right{right:-17em}.ui-panel-animate.ui-panel-position-right.ui-panel-display-overlay,.ui-panel-animate.ui-panel-position-right.ui-panel-display-push{right:0;-webkit-transform:translate3d(17em,0,0);-moz-transform:translate3d(17em,0,0);transform:translate3d(17em,0,0)}.ui-panel-position-right.ui-panel-display-reveal,.ui-panel-position-right.ui-panel-open{right:0}.ui-panel-animate.ui-panel-position-right.ui-panel-open.ui-panel-display-overlay,.ui-panel-animate.ui-panel-position-right.ui-panel-open.ui-panel-display-push{-webkit-transform:translate3d(0,0,0);transform:translate3d(0,0,0);-moz-transform:none}.ui-panel-content-fixed-toolbar-position-left.ui-panel-content-fixed-toolbar-open,.ui-panel-content-wrap-position-left.ui-panel-content-wrap-open,.ui-panel-dismiss-position-left.ui-panel-dismiss-open{left:17em;right:-17em}.ui-panel-animate.ui-panel-content-fixed-toolbar-position-left.ui-panel-content-fix
ed-toolbar-open.ui-panel-content-fixed-toolbar-display-reveal,.ui-panel-animate.ui-panel-content-fixed-toolbar-position-left.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-push,.ui-panel-animate.ui-panel-content-wrap-position-left.ui-panel-content-wrap-open.ui-panel-content-wrap-display-reveal,.ui-panel-animate.ui-panel-content-wrap-position-left.ui-panel-content-wrap-open.ui-panel-content-wrap-display-push{left:0;right:0;-webkit-transform:translate3d(17em,0,0);-moz-transform:translate3d(17em,0,0);transform:translate3d(17em,0,0)}.ui-panel-content-fixed-toolbar-position-right.ui-panel-content-fixed-toolbar-open,.ui-panel-content-wrap-position-right.ui-panel-content-wrap-open,.ui-panel-dismiss-position-right.ui-panel-dismiss-open{left:-17em;right:17em}.ui-panel-animate.ui-panel-content-fixed-toolbar-position-right.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-reveal,.ui-panel-animate.ui-panel-content-fixed-toolbar-positi
on-right.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-push,.ui-panel-animate.ui-panel-content-wrap-position-right.ui-panel-content-wrap-open.ui-panel-content-wrap-display-reveal,.ui-panel-animate.ui-panel-content-wrap-position-right.ui-panel-content-wrap-open.ui-panel-content-wrap-display-push{left:0;right:0;-webkit-transform:translate3d(-17em,0,0);-moz-transform:translate3d(-17em,0,0);transform:translate3d(-17em,0,0)}.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-overlay,.ui-panel-content-wrap-open.ui-panel-content-wrap-display-overlay{left:0}.ui-page-active.ui-page-panel{overflow-x:hidden}.ui-panel-display-reveal{-webkit-box-shadow:inset -5px 0 5px rgba(0,0,0,.15);-moz-box-shadow:inset -5px 0 5px rgba(0,0,0,.15);box-shadow:inset -5px 0 5px rgba(0,0,0,.15)}.ui-panel-position-right.ui-panel-display-reveal{-webkit-box-shadow:inset 5px 0 5px rgba(0,0,0,.15);-moz-box-shadow:inset 5px 0 5px rgba(0,0,0,.15);box-shadow:ins
et 5px 0 5px rgba(0,0,0,.15)}.ui-panel-display-overlay{-webkit-box-shadow:5px 0 5px rgba(0,0,0,.15);-moz-box-shadow:5px 0 5px rgba(0,0,0,.15);box-shadow:5px 0 5px rgba(0,0,0,.15)}.ui-panel-position-right.ui-panel-display-overlay{-webkit-box-shadow:-5px 0 5px rgba(0,0,0,.15);-moz-box-shadow:-5px 0 5px rgba(0,0,0,.15);box-shadow:-5px 0 5px rgba(0,0,0,.15)}.ui-panel-display-push.ui-panel-open.ui-panel-position-left{border-right-width:1px;margin-right:-1px}.ui-panel-animate.ui-panel-content-fixed-toolbar-position-left.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-push{margin-left:1px}.ui-panel-display-push.ui-panel-open.ui-panel-position-right{border-left-width:1px;margin-left:-1px}.ui-panel-animate.ui-panel-content-fixed-toolbar-position-right.ui-panel-content-fixed-toolbar-open.ui-panel-content-fixed-toolbar-display-push{margin-right:1px}@media (min-width:55em){.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixed-toolbar-display-push.ui-
panel-content-fixed-toolbar-position-left,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixed-toolbar-display-reveal.ui-panel-content-fixed-toolbar-position-left,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-wrap-display-push.ui-panel-content-wrap-position-left,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-wrap-display-reveal.ui-panel-content-wrap-position-left{margin-right:17em}.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixed-toolbar-display-push.ui-panel-content-fixed-toolbar-position-right,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixed-toolbar-display-reveal.ui-panel-content-fixed-toolbar-position-right,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-wrap-display-push.ui-panel-content-wrap-position-right,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-wrap-display-reveal.ui-panel-content-wrap-position-right{margin-left:17em}.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixe
d-toolbar-display-push,.ui-responsive-panel.ui-page-panel-open .ui-panel-content-fixed-toolbar-display-reveal{width:auto}.ui-responsive-panel .ui-panel-dismiss-display-push{display:none}}
\ No newline at end of file
Modified: trunk/mapbender/http/extensions/mobilemap/css/ngstyle.css
--- trunk/mapbender/http/extensions/mobilemap/css/ngstyle.css 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/css/ngstyle.css 2013-07-18 03:44:11 UTC (rev 8674)
@@ -1,4 +1,4 @@
-html ,
+html ,
body {
margin: 0;
padding: 0;
@@ -69,6 +69,23 @@
#zoominbut{ background-image:url(../img/but_sprite.png); background-position: 0 -540px; width: 40px; height: 40px; }
#zoomoutbut{ background-image:url(../img/but_sprite.png); background-position: 0 -630px; width: 40px; height: 40px; }
+.smallbuttons{
+ width:70px;
+ height:26px;
+ z-index:1002;
+ cursor:pointer;
+ border: 1px solid #C5C5C5;
+ -moz-border-radius: 4px;
+ -webkit-border-radius: 4px;
+ border-radius: 2px;
+ -moz-box-shadow: 2px 2px 1px #999;
+ -webkit-box-shadow: 2px 2px 1px #9;
+ float:left;
+#zoombut{ background-image:url(../img/background_zoombut.png); }
#menubut {
background-image:url(../img/but_menu.png);
@@ -169,6 +186,10 @@
font-size:12px;
+#queryHead {
+ font-size:10x;
/* Scaleline */
#scaleline {
position:fixed;
@@ -246,9 +267,14 @@
font-size: 14px;
+#xcontent{
+ margin:4px;
#markerhint, #measurehint {
position:absolute;
- top:50px;
+ top:48px;
left:0px;
visibility:hidden;
padding:1px;
@@ -265,8 +291,9 @@
-moz-box-shadow: 4px 4px 2px #333;
-webkit-box-shadow: 4px 4px 2px #333;
box-shadow: 4px 4px 4px #333;
- max-width:310px;
+ max-width:320px;
overflow:auto;
+ max-height:420px;
/* Layersteuerung */
@@ -324,7 +351,8 @@
.poi_check img {
- vertical-align:bottom;
+ vertical-align: bottom;
+ margin-right: 4px;
.baselayer_check {
@@ -355,23 +383,6 @@
border-radius: 8px;
-.searchbutton {
- z-index:1002;
- cursor:pointer;
- border: 2px solid #871D33;
- -moz-border-radius: 8px;
- -webkit-border-radius: 8px;
- border-radius: 8px;
- margin:4px;
- background-image: url(../img/ico_zoomin.png);
- background-repeat: no-repeat;
- background-position: 5px center;
- padding-top: 10px;
- padding-right: 8px;
- padding-bottom: 10px;
- padding-left: 28px;
- background-color:#FFFFFF;
#mygooglemap{
height:220px;
@@ -385,7 +396,7 @@
.apptools{
background-color:#E8E8E8;
- border: 1px solid #666;
+ border: 1px solid #871D33;
padding:5px;
@@ -398,15 +409,52 @@
-o-transition: opacity 0.2s linear;
-/* Enable 3d acceleration when operating on tiles, this is
- known to yield better performance on IOS Safari.
- http://osgeo-org.1803224.n2.nabble.com/Harware-accelerated-CSS3-animations-for-iOS-td6255560.html
- It also prevents tile blinking effects in iOS 5.
- See https://github.com/openlayers/openlayers/issues/511
@media (-webkit-transform-3d) {
img.olTileImage {
-webkit-transform: translate3d(0, 0, 0);
+.query_coords {
+ font-size:10px;
+#popuppos{
+ position:fixed;
+ left:0px;
+ top: 120px;
+ z-index:1008;
+#gpsinfo {
+ font-size:9px;
+ color: #871D33;
+ position:absolute;
+ top:48px;
+ right:0px;
+ visibility:hidden;
+ padding:2px;
+ z-index:1200;
+ border: 1px solid #CCCCCC;
+ background-color: #FFFFFF;
+ -ms-filter: "progid:DXImageTransform.Microsoft.Alpha(Opacity=90)";
+ filter: progid:DXImageTransform.Microsoft.Alpha(Opacity=90);
+ opacity:0.9;
+#gpsmessage {
+ font-size:9px;
+ color: #871D33;
+.ui-icon-netgis-zoomin {
+ background-image: url(../img/201-zoomin.png);
+.ui-listview .ui-li-icon {
+ left: 10px;
+ max-height: 24px;
+ max-width: 24px;
+ top: 1.6em;
Modified: trunk/mapbender/http/extensions/mobilemap/js/OpenLayers.mobile.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/OpenLayers.mobile.min.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/OpenLayers.mobile.min.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -2,7 +2,7 @@
OpenLayers.js -- OpenLayers Map Viewer Library
- Copyright (c) 2006-2012 by OpenLayers Contributors
+ Copyright (c) 2006-2013 by OpenLayers Contributors
Published under the 2-clause BSD license.
See http://openlayers.org/dev/license.txt for the full text of the license, and http://openlayers.org/dev/authors.txt for full list of contributors.
@@ -55,25 +55,28 @@
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
-var OpenLayers={VERSION_NUMBER:"Release 2.12",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers[^\\/]*?\\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){m=src.match(r);if(m){l=m[1];break;}}}
-return(function(){return l;});})(),ImgPath:''};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.prototype.initialize.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
-return C;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
-OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
-var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
-return destination;};OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s\s*/,'').replace(/\s\s*$/,'');},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1,len=oStringList.length;i<len;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
+var OpenLayers={VERSION_NUMBER:"Release 2.13.1",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers[^\\/]*?\\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){m=src.match(r);if(m){l=m[1];break;}}}
+return(function(){return l;});})(),ImgPath:''};OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s\s*/,'').replace(/\s\s*$/,'');},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1,len=oStringList.length;i<len;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
return camelizedString;},format:function(template,context,args){if(!context){context=window;}
var replacer=function(str,match){var replacement;var subs=match.split(/\.+/);for(var i=0;i<subs.length;i++){if(i==0){replacement=context;}
+if(replacement===undefined){break;}
replacement=replacement[subs[i]];}
if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
-if(typeof replacement=='undefined'){return'undefined';}else{return replacement;}};return template.replace(OpenLayers.String.tokenRegEx,replacer);},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);},numericIf:function(value){return OpenLayers.String.isNumeric(value)?parseFloat(value):value;}};OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
+if(typeof replacement=='undefined'){return'undefined';}else{return replacement;}};return template.replace(OpenLayers.String.tokenRegEx,replacer);},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);},numericIf:function(value,trimWhitespace){var originalValue=value;if(trimWhitespace===true&&value!=null&&value.replace){value=value.replace(/^\s*|\s*$/g,"");}
+return OpenLayers.String.isNumeric(value)?parseFloat(value):originalValue;}};OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
str=integer+dsep+rem;}
+return str;},zeroPad:function(num,len,radix){var str=num.toString(radix||10);while(str.length<len){str="0"+str;}
return str;}};OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};},False:function(){return false;},True:function(){return true;},Void:function(){}};OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
-return selected;}};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(OpenLayers.Util.isArray(left)){top=left[3];right=left[2];bottom=left[1];left=left[0];}
+return selected;}};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.prototype.initialize.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
+return C;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
+OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
+return destination;};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(OpenLayers.Util.isArray(left)){top=left[3];right=left[2];bottom=left[1];left=left[0];}
if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
if(bottom!=null){this.bottom=OpenLayers.Util.toFloat(bottom);}
if(right!=null){this.right=OpenLayers.Util.toFloat(right);}
@@ -83,11 +86,14 @@
return this.centerLonLat;},scale:function(ratio,origin){if(origin==null){origin=this.getCenterLonLat();}
var origx,origy;if(origin.CLASS_NAME=="OpenLayers.LonLat"){origx=origin.lon;origy=origin.lat;}else{origx=origin.x;origy=origin.y;}
var left=(this.left-origx)*ratio+origx;var bottom=(this.bottom-origy)*ratio+origy;var right=(this.right-origx)*ratio+origx;var top=(this.top-origy)*ratio+origy;return new OpenLayers.Bounds(left,bottom,right,top);},add:function(x,y){if((x==null)||(y==null)){throw new TypeError('Bounds.add cannot receive null values');}
-return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
-if(bounds){this.centerLonLat=null;if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
-if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
-if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
-if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,options){if(typeof options==="boolean"){options={inclusive:options};}
+return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":this.extendXY(object.lon,object.lat);break;case"OpenLayers.Geometry.Point":this.extendXY(object.x,object.y);break;case"OpenLayers.Bounds":this.centerLonLat=null;if((this.left==null)||(object.left<this.left)){this.left=object.left;}
+if((this.bottom==null)||(object.bottom<this.bottom)){this.bottom=object.bottom;}
+if((this.right==null)||(object.right>this.right)){this.right=object.right;}
+if((this.top==null)||(object.top>this.top)){this.top=object.top;}
+break;}}},extendXY:function(x,y){this.centerLonLat=null;if((this.left==null)||(x<this.left)){this.left=x;}
+if((this.bottom==null)||(y<this.bottom)){this.bottom=y;}
+if((this.right==null)||(x>this.right)){this.right=x;}
+if((this.top==null)||(y>this.top)){this.top=y;}},containsLonLat:function(ll,options){if(typeof options==="boolean"){options={inclusive:options};}
options=options||{};var contains=this.contains(ll.lon,ll.lat,options.inclusive),worldBounds=options.worldBounds;if(worldBounds&&!contains){var worldWidth=worldBounds.getWidth();var worldCenterX=(worldBounds.left+worldBounds.right)/2;var worldsAway=Math.round((ll.lon-worldCenterX)/worldWidth);contains=this.containsLonLat({lon:ll.lon-worldsAway*worldWidth,lat:ll.lat},{inclusive:options.inclusive});}
return contains;},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
if(x==null||y==null){return false;}
@@ -127,10 +133,9 @@
return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0,len=arguments.length;i<len;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
if(arguments.length==1){return element;}
elements.push(element);}
-return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};OpenLayers.Util.isArray=function(a){return(Object.prototype.toString.call(a)==='[object Array]');};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
-OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
+return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};OpenLayers.Util.isArray=function(a){return(Object.prototype.toString.call(a)==='[object Array]');};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
return array;};OpenLayers.Util.indexOf=function(array,obj){if(typeof array.indexOf=="function"){return array.indexOf(obj);}else{for(var i=0,len=array.length;i<len;i++){if(array[i]==obj){return i;}}
-return-1;}};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
+return-1;}};OpenLayers.Util.dotless=/\./g;OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id.replace(OpenLayers.Util.dotless,"_");}
if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
if(position){element.style.position=position;}
@@ -170,22 +175,23 @@
var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.destinationVincenty=function(lonlat,brng,dist){var u=OpenLayers.Util;var ct=u.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var lon1=lonlat.lon;var lat1=lonlat.lat;var s=dist;var alpha1=u.rad(brng);var sinAlpha1=Math.sin(alpha1);var cosAlpha1=Math.cos(alpha1);var tanU1=(1-f)*Math.tan(u.rad(lat1));var cosU1=1/Math.sqrt((1+tanU1*tanU1)),sinU1=tanU1*cosU1;var sigma1=Math.atan2(tanU1,cosAlpha1);var sinAlpha=cosU1*sinAlpha1;var cosSqAlpha=1-sinAlpha*sinAlpha;var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var sigma=s/(b*A),sigmaP=2*Math.PI;while(Math.abs(sigma-sigmaP)>1e-12){var cos2SigmaM=Math.cos(2*sigma1+sigma);var sinSigma=Math.sin(sigma);var cosSigma=Math.cos(sigma);var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2Sigm
aM)-
B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));sigmaP=sigma;sigma=s/(b*A)+deltaSigma;}
-var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=(url===null||url===undefined)?window.location.href:url;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url,options){options=options||{};url=(url===null||url===undefined)?window.location.href:url;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0,len=pairs.length;i<len;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=keyValue[0];try{key=decodeURIComponent(key);}catch(err){key=unescape(key);}
var value=(keyValue[1]||'').replace(/\+/g," ");try{value=decodeURIComponent(value);}catch(err){value=unescape(value);}
-value=value.split(",");if(value.length==1){value=value[0];}
+if(options.splitArgs!==false){value=value.split(",");}
+if(value.length==1){value=value[0];}
parameters[key]=value;}}
-return parameters;};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
-OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.02540005080010160020;OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"Inch":OpenLayers.INCHES_PER_UNIT.inches,"Meter":1.0/OpenLayers.METERS_PER_INCH,"Foot":0.30480060960121920243/OpenLayers.METERS_PER_INCH,"IFoot":0.30480000000000000000/OpenLayers.METERS_PER_INCH,"ClarkeFoot":0.3047972651151/OpenLayers.METERS_PER_INCH,"SearsFoot":0.30479947153867624624/OpenLayers.METERS_PER_INCH,"GoldCoastFoot":0.30479971018150881758/OpenLayers.METERS_PER_INCH,"IInch":0.02540000000000000000/OpenLayers.METERS_PER_INCH,"MicroInch":0.00002540000000000000/OpenLayers.METERS_PER_INCH,"Mil
":0.00000002540000000000/OpenLayers.METERS_PER_INCH,"Centimeter":0.01000000000000000000/OpenLayers.METERS_PER_INCH,"Kilometer":1000.00000000000000000000/OpenLayers.METERS_PER_INCH,"Yard":0.91440182880365760731/OpenLayers.METERS_PER_INCH,"SearsYard":0.914398414616029/OpenLayers.METERS_PER_INCH,"IndianYard":0.91439853074444079983/OpenLayers.METERS_PER_INCH,"IndianYd37":0.91439523/OpenLayers.METERS_PER_INCH,"IndianYd62":0.9143988/OpenLayers.METERS_PER_INCH,"IndianYd75":0.9143985/OpenLayers.METERS_PER_INCH,"IndianFoot":0.30479951/OpenLayers.METERS_PER_INCH,"IndianFt37":0.30479841/OpenLayers.METERS_PER_INCH,"IndianFt62":0.3047996/OpenLayers.METERS_PER_INCH,"IndianFt75":0.3047995/OpenLayers.METERS_PER_INCH,"Mile":1609.34721869443738887477/OpenLayers.METERS_PER_INCH,"IYard":0.91440000000000000000/OpenLayers.METERS_PER_INCH,"IMile":1609.34400000000000000000/OpenLayers.METERS_PER_INCH,"NautM":1852.00000000000000000000/OpenLayers.METERS_PER_INCH,"Lat-66":110943.316488932731/OpenLayers
.METERS_PER_INCH,"Lat-83":110946.25736872234125/OpenLayers.METERS_PER_INCH,"Decimeter":0.10000000000000000000/OpenLayers.METERS_PER_INCH,"Millimeter":0.00100000000000000000/OpenLayers.METERS_PER_INCH,"Dekameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Decameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Hectometer":100.00000000000000000000/OpenLayers.METERS_PER_INCH,"GermanMeter":1.0000135965/OpenLayers.METERS_PER_INCH,"CaGrid":0.999738/OpenLayers.METERS_PER_INCH,"ClarkeChain":20.1166194976/OpenLayers.METERS_PER_INCH,"GunterChain":20.11684023368047/OpenLayers.METERS_PER_INCH,"BenoitChain":20.116782494375872/OpenLayers.METERS_PER_INCH,"SearsChain":20.11676512155/OpenLayers.METERS_PER_INCH,"ClarkeLink":0.201166194976/OpenLayers.METERS_PER_INCH,"GunterLink":0.2011684023368047/OpenLayers.METERS_PER_INCH,"BenoitLink":0.20116782494375872/OpenLayers.METERS_PER_INCH,"SearsLink":0.2011676512155/OpenLayers.METERS_PER_INCH,"Rod":5.02921005842012/OpenLayers.METERS_
PER_INCH,"IntnlChain":20.1168/OpenLayers.METERS_PER_INCH,"IntnlLink":0.201168/OpenLayers.METERS_PER_INCH,"Perch":5.02921005842012/OpenLayers.METERS_PER_INCH,"Pole":5.02921005842012/OpenLayers.METERS_PER_INCH,"Furlong":201.1684023368046/OpenLayers.METERS_PER_INCH,"Rood":3.778266898/OpenLayers.METERS_PER_INCH,"CapeFoot":0.3047972615/OpenLayers.METERS_PER_INCH,"Brealey":375.00000000000000000000/OpenLayers.METERS_PER_INCH,"ModAmFt":0.304812252984505969011938/OpenLayers.METERS_PER_INCH,"Fathom":1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":50000.0/OpenLayers.METERS_PER_INCH,"150kilometers":150000.0/OpenLayers.METERS_PER_INCH});OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"mm":OpenLayers.INCHES_PER_UNIT["Meter"]/1000.0,"cm":OpenLayers.INCHES_PER_UNIT["Meter"]/100.0,"dm":OpenLayers.INCHES_PER_UNIT["Meter"]*100.0,"km":OpenLayers.INCHES_PER_UNIT["Meter"]*1000.0,"kmi":OpenLayers.INCHES_PER_UNIT["nmi"],"fath":OpenLayers.INCHES_PER
_UNIT["Fathom"],"ch":OpenLayers.INCHES_PER_UNIT["IntnlChain"],"link":OpenLayers.INCHES_PER_UNIT["IntnlLink"],"us-in":OpenLayers.INCHES_PER_UNIT["inches"],"us-ft":OpenLayers.INCHES_PER_UNIT["Foot"],"us-yd":OpenLayers.INCHES_PER_UNIT["Yard"],"us-ch":OpenLayers.INCHES_PER_UNIT["GunterChain"],"us-mi":OpenLayers.INCHES_PER_UNIT["Mile"],"ind-yd":OpenLayers.INCHES_PER_UNIT["IndianYd37"],"ind-ft":OpenLayers.INCHES_PER_UNIT["IndianFt37"],"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){var resolution;if(scale){if(units==null){units="degrees";}
+return parameters;};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}else{prefix=prefix.replace(OpenLayers.Util.dotless,"_");}
+OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.37,'km':39370,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.02540005080010160020;OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"Inch":OpenLayers.INCHES_PER_UNIT.inches,"Meter":1.0/OpenLayers.METERS_PER_INCH,"Foot":0.30480060960121920243/OpenLayers.METERS_PER_INCH,"IFoot":0.30480000000000000000/OpenLayers.METERS_PER_INCH,"ClarkeFoot":0.3047972651151/OpenLayers.METERS_PER_INCH,"SearsFoot":0.30479947153867624624/OpenLayers.METERS_PER_INCH,"GoldCoastFoot":0.30479971018150881758/OpenLayers.METERS_PER_INCH,"IInch":0.02540000000000000000/OpenLayers.METERS_PER_INCH,"MicroInch":0.00002540000000000000/OpenLayers.METERS_PER_INCH,"Mil":0.
00000002540000000000/OpenLayers.METERS_PER_INCH,"Centimeter":0.01000000000000000000/OpenLayers.METERS_PER_INCH,"Kilometer":1000.00000000000000000000/OpenLayers.METERS_PER_INCH,"Yard":0.91440182880365760731/OpenLayers.METERS_PER_INCH,"SearsYard":0.914398414616029/OpenLayers.METERS_PER_INCH,"IndianYard":0.91439853074444079983/OpenLayers.METERS_PER_INCH,"IndianYd37":0.91439523/OpenLayers.METERS_PER_INCH,"IndianYd62":0.9143988/OpenLayers.METERS_PER_INCH,"IndianYd75":0.9143985/OpenLayers.METERS_PER_INCH,"IndianFoot":0.30479951/OpenLayers.METERS_PER_INCH,"IndianFt37":0.30479841/OpenLayers.METERS_PER_INCH,"IndianFt62":0.3047996/OpenLayers.METERS_PER_INCH,"IndianFt75":0.3047995/OpenLayers.METERS_PER_INCH,"Mile":1609.34721869443738887477/OpenLayers.METERS_PER_INCH,"IYard":0.91440000000000000000/OpenLayers.METERS_PER_INCH,"IMile":1609.34400000000000000000/OpenLayers.METERS_PER_INCH,"NautM":1852.00000000000000000000/OpenLayers.METERS_PER_INCH,"Lat-66":110943.316488932731/OpenLayers.MET
ERS_PER_INCH,"Lat-83":110946.25736872234125/OpenLayers.METERS_PER_INCH,"Decimeter":0.10000000000000000000/OpenLayers.METERS_PER_INCH,"Millimeter":0.00100000000000000000/OpenLayers.METERS_PER_INCH,"Dekameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Decameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Hectometer":100.00000000000000000000/OpenLayers.METERS_PER_INCH,"GermanMeter":1.0000135965/OpenLayers.METERS_PER_INCH,"CaGrid":0.999738/OpenLayers.METERS_PER_INCH,"ClarkeChain":20.1166194976/OpenLayers.METERS_PER_INCH,"GunterChain":20.11684023368047/OpenLayers.METERS_PER_INCH,"BenoitChain":20.116782494375872/OpenLayers.METERS_PER_INCH,"SearsChain":20.11676512155/OpenLayers.METERS_PER_INCH,"ClarkeLink":0.201166194976/OpenLayers.METERS_PER_INCH,"GunterLink":0.2011684023368047/OpenLayers.METERS_PER_INCH,"BenoitLink":0.20116782494375872/OpenLayers.METERS_PER_INCH,"SearsLink":0.2011676512155/OpenLayers.METERS_PER_INCH,"Rod":5.02921005842012/OpenLayers.METERS_PER_
INCH,"IntnlChain":20.1168/OpenLayers.METERS_PER_INCH,"IntnlLink":0.201168/OpenLayers.METERS_PER_INCH,"Perch":5.02921005842012/OpenLayers.METERS_PER_INCH,"Pole":5.02921005842012/OpenLayers.METERS_PER_INCH,"Furlong":201.1684023368046/OpenLayers.METERS_PER_INCH,"Rood":3.778266898/OpenLayers.METERS_PER_INCH,"CapeFoot":0.3047972615/OpenLayers.METERS_PER_INCH,"Brealey":375.00000000000000000000/OpenLayers.METERS_PER_INCH,"ModAmFt":0.304812252984505969011938/OpenLayers.METERS_PER_INCH,"Fathom":1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":50000.0/OpenLayers.METERS_PER_INCH,"150kilometers":150000.0/OpenLayers.METERS_PER_INCH});OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"mm":OpenLayers.INCHES_PER_UNIT["Meter"]/1000.0,"cm":OpenLayers.INCHES_PER_UNIT["Meter"]/100.0,"dm":OpenLayers.INCHES_PER_UNIT["Meter"]*100.0,"km":OpenLayers.INCHES_PER_UNIT["Meter"]*1000.0,"kmi":OpenLayers.INCHES_PER_UNIT["nmi"],"fath":OpenLayers.INCHES_PER_UNI
var normScale=OpenLayers.Util.normalizeScale(scale);resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);}
return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.pagePosition=function(forElement){var pos=[0,0];var viewportElement=OpenLayers.Util.getViewportElement();if(!forElement||forElement==window||forElement==viewportElement){return pos;}
-var BUGGY_GECKO_BOX_OBJECT=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(forElement,'position')=='absolute'&&(forElement.style.top==''||forElement.style.left=='');var parent=null;var box;if(forElement.getBoundingClientRect){box=forElement.getBoundingClientRect();var scrollTop=viewportElement.scrollTop;var scrollLeft=viewportElement.scrollLeft;pos[0]=box.left+scrollLeft;pos[1]=box.top+scrollTop;}else if(document.getBoxObjectFor&&!BUGGY_GECKO_BOX_OBJECT){box=document.getBoxObjectFor(forElement);var vpBox=document.getBoxObjectFor(viewportElement);pos[0]=box.screenX-vpBox.screenX;pos[1]=box.screenY-vpBox.screenY;}else{pos[0]=forElement.offsetLeft;pos[1]=forElement.offsetTop;parent=forElement.offsetParent;if(parent!=forElement){while(parent){pos[0]+=parent.offsetLeft;pos[1]+=parent.offsetTop;parent=parent.offsetParent;}}
+var BUGGY_GECKO_BOX_OBJECT=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(forElement,'position')=='absolute'&&(forElement.style.top==''||forElement.style.left=='');var parent=null;var box;if(forElement.getBoundingClientRect){box=forElement.getBoundingClientRect();var scrollTop=window.pageYOffset||viewportElement.scrollTop;var scrollLeft=window.pageXOffset||viewportElement.scrollLeft;pos[0]=box.left+scrollLeft;pos[1]=box.top+scrollTop;}else if(document.getBoxObjectFor&&!BUGGY_GECKO_BOX_OBJECT){box=document.getBoxObjectFor(forElement);var vpBox=document.getBoxObjectFor(viewportElement);pos[0]=box.screenX-vpBox.screenX;pos[1]=box.screenY-vpBox.screenY;}else{pos[0]=forElement.offsetLeft;pos[1]=forElement.offsetTop;parent=forElement.offsetParent;if(parent!=forElement){while(parent){pos[0]+=parent.offsetLeft;pos[1]+=parent.offsetTop;parent=parent.offsetParent;}}
var browser=OpenLayers.BROWSER_NAME;if(browser=="opera"||(browser=="safari"&&OpenLayers.Element.getStyle(forElement,'position')=='absolute')){pos[1]-=document.body.offsetTop;}
parent=forElement.offsetParent;while(parent&&parent!=document.body){pos[0]-=parent.scrollLeft;if(browser!="opera"||parent.tagName!='TR'){pos[1]-=parent.scrollTop;}
return pos;};OpenLayers.Util.getViewportElement=function(){var viewportElement=arguments.callee.viewportElement;if(viewportElement==undefined){viewportElement=(OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!='CSS1Compat')?document.body:document.documentElement;arguments.callee.viewportElement=viewportElement;}
-return viewportElement;};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(key!=="args"){if(urlObj1[key]!=urlObj2[key]){return false;}}}
+return viewportElement;};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true,splitArgs:false});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(key!=="args"){if(urlObj1[key]!=urlObj2[key]){return false;}}}
for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
delete urlObj2.args[key];}
for(var key in urlObj2.args){return false;}
@@ -193,7 +199,7 @@
if(options.ignoreCase){url=url.toLowerCase();}
var a=document.createElement('a');a.href=url;var urlObject={};urlObject.host=a.host.split(":").shift();urlObject.protocol=a.protocol;if(options.ignorePort80){urlObject.port=(a.port=="80"||a.port=="0")?"":a.port;}else{urlObject.port=(a.port==""||a.port=="0")?"80":a.port;}
urlObject.hash=(options.ignoreHash||a.hash==="#")?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
-urlObject.args=OpenLayers.Util.getParameters(queryString);urlObject.pathname=(a.pathname.charAt(0)=="/")?a.pathname:"/"+a.pathname;return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
+urlObject.args=OpenLayers.Util.getParameters(queryString,{splitArgs:options.splitArgs});urlObject.pathname=(a.pathname.charAt(0)=="/")?a.pathname:"/"+a.pathname;return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
return head;};OpenLayers.IS_GECKO=(function(){var ua=navigator.userAgent.toLowerCase();return ua.indexOf("webkit")==-1&&ua.indexOf("gecko")!=-1;})();OpenLayers.CANVAS_SUPPORTED=(function(){var elem=document.createElement('canvas');return!!(elem.getContext&&elem.getContext('2d'));})();OpenLayers.BROWSER_NAME=(function(){var name="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){name="opera";}else if(ua.indexOf("msie")!=-1){name="msie";}else if(ua.indexOf("safari")!=-1){name="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){name="firefox";}else{name="mozilla";}}
return name;})();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size,options){var w,h;var container=document.createElement("div");container.style.visibility="hidden";var containerElement=(options&&options.containerElement)?options.containerElement:document.body;var parentHasPositionAbsolute=false;var superContainer=null;var parent=containerElement;while(parent&&parent.tagName.toLowerCase()!="body"){var parentPosition=OpenLayers.Element.getStyle(parent,"position");if(parentPosition=="absolute"){parentHasPositionAbsolute=true;break;}else if(parentPosition&&parentPosition!="static"){break;}
parent=parent.parentNode;}
@@ -213,43 +219,86 @@
str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
str+=coordinateseconds+'"';}}
if(axis=="lon"){str+=coordinate<0?OpenLayers.i18n("W"):OpenLayers.i18n("E");}else{str+=coordinate<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");}
-return str;};OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
-if(this.layer!=null&&this.marker!=null){this.layer.removeMarker(this.marker);}
-this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
-if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
-return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){if(!this.popup){var anchor=(this.marker)?this.marker.icon:null;var popupClass=this.popupClass?this.popupClass:OpenLayers.Popup.Anchored;this.popup=new popupClass(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
-if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
-this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
-this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;this.modified=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
-return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
-return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
-var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
-var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",str
okeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'delete':{display:"none"}};OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
-this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}
-if(style.label!=null&&typeof style.label!=="string"){style.label=String(style.label);}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
-if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
-if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
-return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
-options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Animation=(function(window){var isNative=!!(window.requestAnimationFrame||window.webkitRequestAnimationFrame||window.mozRequestAnimationFrame||window.oRequestAnimationFrame||window.msRequestAnimationFrame);var requestFrame=(function(){var request=window.requestAnimationFrame||window.webkitRequestAnimationFrame||window.mozRequestAnimationFrame||window.oRequestAnimationFrame||window.msRequestAnimationFrame||function(callback,element){window.setTimeout(callback,16);};return function(callback,element){request.apply(window,[callback,element]);};})();var counter=0;var loops={};function start(callback,duration,element){duration=duration>0?duration:Number.POSITIVE_INFINITY;var id=++counter;var start=+new Date;loops[id]=function(){if(loops[id]&&+new Date-start<=duration){callback();if(loops[id]){requestFrame(loops[id],element);}}else{delete loops[id];}};requestFrame(loops[id],ele
ment);return id;}
-function stop(id){delete loops[id];}
-return{isNative:isNative,requestFrame:requestFrame,start:start,stop:stop};})(window);OpenLayers.Tween=OpenLayers.Class({easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,animationId:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;OpenLayers.Animation.stop(this.animationId);this.animationId=null;if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
-this.animationId=OpenLayers.Animation.start(OpenLayers.Function.bind(this.play,this));},stop:function(){if(!this.playing){return;}
-if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
-OpenLayers.Animation.stop(this.animationId);this.animationId=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){throw new TypeError('invalid value for Tween');}
-var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
-this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,boun
ds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return str;};OpenLayers.Event={observers:false,KEY_SPACE:32,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){OpenLayers.Event.preventDefault(event);}
+if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},preventDefault:function(event){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
+return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
+if(!this.observers){this.observers={};}
+if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
+element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
+var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
+this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];OpenLayers.Event.stopObserving.apply(this,[entry.element,entry.name,entry.observer,entry.useCapture]);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.detachEvent){
name='keydown';}}
+var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
+foundEntry=true;break;}
+i++;}}
+if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
+return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
+OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend","keydown"],listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:false,extensions:null,extensionCount:null,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};this.extensions={};this.extensionCount={};this._msTouches=[];if(element!=null){this.attachToElement(element);}},destroy:function(){for(var e in this.extensions){if(typeof this.extensions[e]!=="boolean"){this.extensions[e].destroy();}}
+this.extensions=null;if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
+this.element=null;this.listeners=null;this.object=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}else{this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);}
+this.element=element;var msTouch=!!window.navigator.msMaxTouchPoints;var type;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){type=this.BROWSER_EVENTS[i];OpenLayers.Event.observe(element,type,this.eventHandler);if(msTouch&&type.indexOf('touch')===0){this.addMsTouchListener(element,type,this.eventHandler);}}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func,priority){if(type in OpenLayers.Events&&!this.extensions[type]){this.extensions[type]=new OpenLayers.Events[type](this);}
+if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(!listeners){listeners=[];this.listeners[type]=listeners;this.extensionCount[type]=0;}
+var listener={obj:obj,func:func};if(priority){listeners.splice(this.extensionCount[type],0,listener);if(typeof priority==="object"&&priority.extension){this.extensionCount[type]++;}}else{listeners.push(listener);}}},registerPriority:function(type,obj,func){this.register(type,obj,func,true);},un:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return undefined;}
+if(evt==null){evt={};}
+evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
+listeners=listeners.slice();var continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
+if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}
+return continueChain;},handleBrowserEvent:function(evt){var type=evt.type,listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
+var touches=evt.touches;if(touches&&touches[0]){var x=0;var y=0;var num=touches.length;var touch;for(var i=0;i<num;++i){touch=this.getTouchClientXY(touches[i]);x+=touch.clientX;y+=touch.clientY;}
+evt.clientX=x/num;evt.clientY=y/num;}
+if(this.includeXY){evt.xy=this.getMousePosition(evt);}
+this.triggerEvent(type,evt);},getTouchClientXY:function(evt){var win=window.olMockWin||window,winPageX=win.pageXOffset,winPageY=win.pageYOffset,x=evt.clientX,y=evt.clientY;if(evt.pageY===0&&Math.floor(y)>Math.floor(evt.pageY)||evt.pageX===0&&Math.floor(x)>Math.floor(evt.pageX)){x=x-winPageX;y=y-winPageY;}else if(y<(evt.pageY-winPageY)||x<(evt.pageX-winPageX)){x=evt.pageX-winPageX;y=evt.pageY-winPageY;}
+evt.olClientX=x;evt.olClientY=y;return{clientX:x,clientY:y};},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;this.element.offsets=null;},getMousePosition:function(evt){if(!this.includeXY){this.clearMouseCache();}else if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true;}
+if(!this.element.scrolls){var viewportElement=OpenLayers.Util.getViewportElement();this.element.scrolls=[window.pageXOffset||viewportElement.scrollLeft,window.pageYOffset||viewportElement.scrollTop];}
+if(!this.element.lefttop){this.element.lefttop=[(document.documentElement.clientLeft||0),(document.documentElement.clientTop||0)];}
+if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
+return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
+-this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
+-this.element.lefttop[1]);},addMsTouchListener:function(element,type,handler){var eventHandler=this.eventHandler;var touches=this._msTouches;function msHandler(evt){handler(OpenLayers.Util.applyDefaults({stopPropagation:function(){for(var i=touches.length-1;i>=0;--i){touches[i].stopPropagation();}},preventDefault:function(){for(var i=touches.length-1;i>=0;--i){touches[i].preventDefault();}},type:type},evt));}
+switch(type){case'touchstart':return this.addMsTouchListenerStart(element,type,msHandler);case'touchend':return this.addMsTouchListenerEnd(element,type,msHandler);case'touchmove':return this.addMsTouchListenerMove(element,type,msHandler);default:throw'Unknown touch event type';}},addMsTouchListenerStart:function(element,type,handler){var touches=this._msTouches;var cb=function(e){var alreadyInArray=false;for(var i=0,ii=touches.length;i<ii;++i){if(touches[i].pointerId==e.pointerId){alreadyInArray=true;break;}}
+if(!alreadyInArray){touches.push(e);}
+e.touches=touches.slice();handler(e);};OpenLayers.Event.observe(element,'MSPointerDown',cb);var internalCb=function(e){for(var i=0,ii=touches.length;i<ii;++i){if(touches[i].pointerId==e.pointerId){touches.splice(i,1);break;}}};OpenLayers.Event.observe(element,'MSPointerUp',internalCb);},addMsTouchListenerMove:function(element,type,handler){var touches=this._msTouches;var cb=function(e){if(e.pointerType==e.MSPOINTER_TYPE_MOUSE&&e.buttons==0){return;}
+if(touches.length==1&&touches[0].pageX==e.pageX&&touches[0].pageY==e.pageY){return;}
+for(var i=0,ii=touches.length;i<ii;++i){if(touches[i].pointerId==e.pointerId){touches[i]=e;break;}}
+e.touches=touches.slice();handler(e);};OpenLayers.Event.observe(element,'MSPointerMove',cb);},addMsTouchListenerEnd:function(element,type,handler){var touches=this._msTouches;var cb=function(e){for(var i=0,ii=touches.length;i<ii;++i){if(touches[i].pointerId==e.pointerId){touches.splice(i,1);break;}}
+e.touches=touches.slice();handler(e);};OpenLayers.Event.observe(element,'MSPointerUp',cb);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Events.buttonclick=OpenLayers.Class({target:null,events:['mousedown','mouseup','click','dblclick','touchstart','touchmove','touchend','keydown'],startRegEx:/^mousedown|touchstart$/,cancelRegEx:/^touchmove$/,completeRegEx:/^mouseup|touchend$/,initialize:function(target){this.target=target;for(var i=this.events.length-1;i>=0;--i){this.target.register(this.events[i],this,this.buttonClick,{extension:true});}},destroy:function(){for(var i=this.events.length-1;i>=0;--i){this.target.unregister(this.events[i],this,this.buttonClick);}
+delete this.target;},getPressedButton:function(element){var depth=3,button;do{if(OpenLayers.Element.hasClass(element,"olButton")){button=element;break;}
+element=element.parentNode;}while(--depth>0&&element);return button;},ignore:function(element){var depth=3,ignore=false;do{if(element.nodeName.toLowerCase()==='a'){ignore=true;break;}
+element=element.parentNode;}while(--depth>0&&element);return ignore;},buttonClick:function(evt){var propagate=true,element=OpenLayers.Event.element(evt);if(element&&(OpenLayers.Event.isLeftClick(evt)||!~evt.type.indexOf("mouse"))){var button=this.getPressedButton(element);if(button){if(evt.type==="keydown"){switch(evt.keyCode){case OpenLayers.Event.KEY_RETURN:case OpenLayers.Event.KEY_SPACE:this.target.triggerEvent("buttonclick",{buttonElement:button});OpenLayers.Event.stop(evt);propagate=false;break;}}else if(this.startEvt){if(this.completeRegEx.test(evt.type)){var pos=OpenLayers.Util.pagePosition(button);var viewportElement=OpenLayers.Util.getViewportElement();var scrollTop=window.pageYOffset||viewportElement.scrollTop;var scrollLeft=window.pageXOffset||viewportElement.scrollLeft;pos[0]=pos[0]-scrollLeft;pos[1]=pos[1]-scrollTop;this.target.triggerEvent("buttonclick",{buttonElement:button,buttonXY:{x:this.startEvt.clientX-pos[0],y:this.startEvt.clientY-pos[1]}});}
+if(this.cancelRegEx.test(evt.type)){delete this.startEvt;}
+OpenLayers.Event.stop(evt);propagate=false;}
+if(this.startRegEx.test(evt.type)){this.startEvt=evt;OpenLayers.Event.stop(evt);propagate=false;}}else{propagate=!this.ignore(OpenLayers.Event.element(evt));delete this.startEvt;}}
+return propagate;}});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handlerOptions:null,handler:null,eventListeners:null,events:null,initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.events=null;}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}
+this.div=null;},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister("buttonclick",this,this.onButtonClick);}
+this.removeButtons();this.buttons=null;this.position=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register("buttonclick",this,this.onButtonClick);},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz={w:18,h:18};var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgL
ocation=OpenLayers.Util.getImageLocation(img);var btn=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+id,xy,sz,imgLocation,"absolute");btn.style.cursor="pointer";this.div.appendChild(btn);btn.action=id;btn.className="olButton";this.buttons.push(btn);return btn;},_removeButton:function(btn){this.div.removeChild(btn);OpenLayers.Util.removeItem(this.buttons,btn);},removeButtons:function(){for(var i=this.buttons.length-1;i>=0;--i){this._removeButton(this.buttons[i]);}},onButtonClick:function(evt){var btn=evt.buttonElement;switch(btn.action){case"panup":this.map.pan(0,-this.getSlideFactor("h"));break;case"pandown":this.map.pan(0,this.getSlideFactor("h"));break;case"panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case"panright":this.map.pan(this.getSlideFactor("w"),0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}},getSlideFactor:function(dim){return this.slideRatio?this.map.getSize()[di
m]*this.slideRatio:this.slideFactor;},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,zoomWorldIcon:false,panIcons:true,forceFixedZoomLevel:false,mouseDragStart:null,deltaY:null,zoomStart:null,destroy:function(){this._removeZoomBar();this.map.events.un({"changebaselayer":this.redraw,"updatesize":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart;},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.on({"changebaselayer":this.redraw,"updatesize":this.redraw,scope:this});},redraw:function(){if(this.div!=null){this.removeButtons();this._removeZoomBar();}
+this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz={w:18,h:18};if(this.panIcons){var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
+this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
+this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);}
+else{this._addButton("zoomin","zoom-plus-mini.png",px,sz);centered=this._addZoomBar(px.add(0,sz.h));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);if(this.zoomWorldIcon){centered=centered.add(0,sz.h+3);this._addButton("zoomworld","zoom-world-mini.png",centered,sz);}}
+return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImageLocation("slider.png");var id=this.id+"_"+this.map.id;var minZoom=this.map.getMinZoom();var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),{w:20,h:9},imgLocation,"absolute");slider.style.cursor="move";this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true,{includeXY:true});this.sliderEvents.on({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp});var sz={w:this.zoomStopWidth,h:this.zoomStopHeight*(this.map.getNumZoomLevels()-minZoom)};var imgLocation=OpenLayers.Util.getImageLocation("zoombar.png");var div=null;if(OpenLayers.Util.alphaHack()){var id=this.id+"_"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,{w:sz.w,h:this.
zoomStopHeight},imgLocation,"absolute",null,"crop");div.style.height=sz.h+"px";}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation);}
+div.style.cursor="pointer";div.className="olButton";this.zoombarDiv=div;this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*(this.map.getNumZoomLevels()-minZoom));return centered;},_removeZoomBar:function(){this.sliderEvents.un({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp});this.sliderEvents.destroy();this.div.removeChild(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar);},onButtonClick:function(evt){OpenLayers.Control.PanZoom.prototype.onButtonClick.apply(this,arguments);if(evt.buttonElement===this.zoombarDiv){var levels=evt.buttonXY.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom){level
s=Math.floor(levels);}
+var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);}},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&!OpenLayers.Event.isSingleTouch(evt)){return;}
+this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
+this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
+if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
+this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){var string;if(OpenLayers.Format&&OpenLayers.Format.WKT){string=OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));}else{string=Object.prototype.toString.call(this);}
return string;},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var geom;if(OpenLayers.Format&&OpenLayers.Format.WKT){var format=OpenLayers.Geometry.fromWKT.format;if(!format){format=new OpenLayers.Format.WKT();OpenLayers.Geometry.fromWKT.format=format;}
@@ -259,8 +308,8 @@
if(tolerance){var dist;if(intersection){if(point){var segs=[seg1,seg2];var seg,x,y;outer:for(var i=0;i<2;++i){seg=segs[i];for(var j=1;j<3;++j){x=seg["x"+j];y=seg["y"+j];dist=Math.sqrt(Math.pow(x-intersection.x,2)+
Math.pow(y-intersection.y,2));if(dist<tolerance){intersection.x=x;intersection.y=y;break outer;}}}}}else{var segs=[seg1,seg2];var source,target,x,y,p,result;outer:for(var i=0;i<2;++i){source=segs[i];target=segs[(i+1)%2];for(var j=1;j<3;++j){p={x:source["x"+j],y:source["y"+j]};result=OpenLayers.Geometry.distanceToSegment(p,target);if(result.distance<tolerance){if(point){intersection=new OpenLayers.Geometry.Point(p.x,p.y);}else{intersection=true;}
break outer;}}}}}
-return intersection;};OpenLayers.Geometry.distanceToSegment=function(point,segment){var x0=point.x;var y0=point.y;var x1=segment.x1;var y1=segment.y1;var x2=segment.x2;var y2=segment.y2;var dx=x2-x1;var dy=y2-y1;var along=((dx*(x0-x1))+(dy*(y0-y1)))/(Math.pow(dx,2)+Math.pow(dy,2));var x,y;if(along<=0.0){x=x1;y=y1;}else if(along>=1.0){x=x2;y=y2;}else{x=x1+along*dx;y=y1+along*dy;}
-return{distance:Math.sqrt(Math.pow(x-x0,2)+Math.pow(y-y0,2)),x:x,y:y};};OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
+return intersection;};OpenLayers.Geometry.distanceToSegment=function(point,segment){var result=OpenLayers.Geometry.distanceSquaredToSegment(point,segment);result.distance=Math.sqrt(result.distance);return result;};OpenLayers.Geometry.distanceSquaredToSegment=function(point,segment){var x0=point.x;var y0=point.y;var x1=segment.x1;var y1=segment.y1;var x2=segment.x2;var y2=segment.y2;var dx=x2-x1;var dy=y2-y1;var along=((dx*(x0-x1))+(dy*(y0-y1)))/(Math.pow(dx,2)+Math.pow(dy,2));var x,y;if(along<=0.0){x=x1;y=y1;}else if(along>=1.0){x=x2;y=y2;}else{x=x1+along*dx;y=y1+along*dy;}
+return{distance:Math.pow(x-x0,2)+Math.pow(y-y0,2),x:x,y:y,along:along};};OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0,len=this.components.length;i<len;i++){strings.push(this.components[i].toShortString());}
return strings.join(",");},calculateBounds:function(){this.bounds=null;var bounds=new OpenLayers.Bounds();var components=this.components;if(components){for(var i=0,len=components.length;i<len;i++){bounds.extend(components[i].getBounds());}}
if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(OpenLayers.Util.isArray(components))){components=[components];}
@@ -334,8 +383,10 @@
return removed;},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
this.bounds=null;}
-return this;},getCentroid:function(){if(this.components&&(this.components.length>2)){var sumX=0.0;var sumY=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x)*(b.x*c.y-c.x*b.y);sumY+=(b.y+c.y)*(b.x*c.y-c.x*b.y);}
-var area=-1*this.getArea();var x=sumX/(6*area);var y=sumY/(6*area);return new OpenLayers.Geometry.Point(x,y);}else{return null;}},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0,len=this.components.length;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
+return this;},getCentroid:function(){if(this.components){var len=this.components.length;if(len>0&&len<=2){return this.components[0].clone();}else if(len>2){var sumX=0.0;var sumY=0.0;var x0=this.components[0].x;var y0=this.components[0].y;var area=-1*this.getArea();if(area!=0){for(var i=0;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x-2*x0)*((b.x-x0)*(c.y-y0)-(c.x-x0)*(b.y-y0));sumY+=(b.y+c.y-2*y0)*((b.x-x0)*(c.y-y0)-(c.x-x0)*(b.y-y0));}
+var x=x0+sumX/(6*area);var y=y0+sumY/(6*area);}else{for(var i=0;i<len-1;i++){sumX+=this.components[i].x;sumY+=this.components[i].y;}
+var x=sumX/(len-1);var y=sumY/(len-1);}
+return new OpenLayers.Geometry.Point(x,y);}else{return null;}}},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0,len=this.components.length;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
area=-sum/2.0;}
return area;},getGeodesicArea:function(projection){var ring=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){ring=this.clone().transform(projection,gg);}}
var area=0.0;var len=ring.components&&ring.components.length;if(len>2){var p1,p2;for(var i=0;i<len-1;i++){p1=ring.components[i];p2=ring.components[i+1];area+=OpenLayers.Util.rad(p2.x-p1.x)*(2+Math.sin(OpenLayers.Util.rad(p1.y))+
@@ -349,7 +400,45 @@
if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0,len=geometry.components.length;i<len;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
+return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,touch:false,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0)|(evt.metaKey?OpenLayers.Handler.MOD_META:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.touch=false;this.active=false;return true;},startTouch:function(){if(!this.touch){this.touch=true;var events=["mousedown","mouseup","mousemove","click","dblclick","mouseout"];for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}}},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.MOD_META=8;OpenLayers.Handle
r.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,citeCompliant:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,lastTouchPx:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
+var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+this.cancel();if(this.layer.map!=null){this.destroyFeature(true);this.layer.destroy(false);}
+this.layer=null;return true;},destroyFeature:function(force){if(this.layer&&(force||!this.persist)){this.layer.destroyFeatures();}
+this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel){var key=cancel?"cancel":"done";this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);this.destroyFeature(cancel);},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){if(!this.point){this.createFeature(pixel);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
+return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){this.startTouch();this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
+this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
+return true;},up:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
+if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
+if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+if(this.persist){this.destroyPersistedFeature();}
+this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
+return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.la
yer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousIndex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=len
gth*Math.cos(direction);var dy=length*Math.sin(direction);this.insertDeltaXY(dx,dy);},insertDeflectionLength:function(deflection,length){var previousIndex=this.getCurrentPointIndex()-1;if(previousIndex>0){var p1=this.line.geometry.components[previousIndex];var p0=this.line.geometry.components[previousIndex-1];var theta=Math.atan2(p1.y-p0.y,p1.x-p0.x);this.insertDirectionLength((theta*180/Math.PI)+deflection,length);}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1;},undo:function(){var geometry=this.line.geometry;var components=geometry.components;var index=this.getCurrentPointIndex()-1;var target=components[index];var undone=geometry.removeComponent(target);if(undone){if(this.touch&&index>0){components=geometry.components;var lastpt=components[index-1];var curptidx=this.getCurrentPointIndex();var curpt=components[curptidx];curpt.x=lastpt.x;curpt.y=lastpt.y;}
+if(!this.redoStack){this.redoStack=[];}
+this.redoStack.push(target);this.drawFeature();}
+return undone;},redo:function(){var target=this.redoStack&&this.redoStack.pop();if(target){this.line.geometry.addComponent(target,this.getCurrentPointIndex());this.drawFeature();}
+return!!target;},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){if(!this.line){this.createFeature(pixel);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
+return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
+this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;if(this.touch){this.modifyFeature(evt.xy,!!this.lastUp);OpenLayers.Event.stop(evt);}}
+if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
+this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+if(this.maxVertices&&this.line&&this.line.geometry.components.length===this.maxVertices){this.removePoint();this.finalize();}else{this.addPoint(evt.xy);}
+return false;}
+if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy,!!this.lastUp);}
+return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
+this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
+this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
break;}}}}}
@@ -359,61 +448,241 @@
return intersect;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var result;if(!edge&&this.intersects(geometry)){result=0;}else{result=OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[geometry,options]);}
return result;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Event={observers:false,KEY_SPACE:32,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
-if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
-return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
-if(!this.observers){this.observers={};}
-if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
-element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
-var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
-this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Sa
fari|KHTML/)||element.detachEvent){name='keydown';}}
-var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
-foundEntry=true;break;}
-i++;}}
-if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
-return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
-OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend","keydown"],listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:false,extensions:null,extensionCount:null,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};this.extensions={};this.extensionCount={};if(element!=null){this.attachToElement(element);}},destroy:function(){for(var e in this.extensions){if(typeof this.extensions[e]!=="boolean"){this.extensions[e].destroy();}}
-this.extensions=null;if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
-this.element=null;this.listeners=null;this.object=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}else{this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);}
-this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){OpenLayers.Event.observe(element,this.BROWSER_EVENTS[i],this.eventHandler);}
-OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func,priority){if(type in OpenLayers.Events&&!this.extensions[type]){this.extensions[type]=new OpenLayers.Events[type](this);}
-if(func!=null){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(!listeners){listeners=[];this.listeners[type]=listeners;this.extensionCount[type]=0;}
-var listener={obj:obj,func:func};if(priority){listeners.splice(this.extensionCount[type],0,listener);if(typeof priority==="object"&&priority.extension){this.extensionCount[type]++;}}else{listeners.push(listener);}}},registerPriority:function(type,obj,func){this.register(type,obj,func,true);},un:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return undefined;}
-if(evt==null){evt={};}
-evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
-listeners=listeners.slice();var continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
-if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}
-return continueChain;},handleBrowserEvent:function(evt){var type=evt.type,listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
-var touches=evt.touches;if(touches&&touches[0]){var x=0;var y=0;var num=touches.length;var touch;for(var i=0;i<num;++i){touch=touches[i];x+=touch.clientX;y+=touch.clientY;}
-evt.clientX=x/num;evt.clientY=y/num;}
-if(this.includeXY){evt.xy=this.getMousePosition(evt);}
-this.triggerEvent(type,evt);},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;var body=document.body;if(body&&!((body.scrollTop!=0||body.scrollLeft!=0)&&navigator.userAgent.match(/iPhone/i))){this.element.offsets=null;}},getMousePosition:function(evt){if(!this.includeXY){this.clearMouseCache();}else if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true;}
-if(!this.element.scrolls){var viewportElement=OpenLayers.Util.getViewportElement();this.element.scrolls=[viewportElement.scrollLeft,viewportElement.scrollTop];}
-if(!this.element.lefttop){this.element.lefttop=[(document.documentElement.clientLeft||0),(document.documentElement.clientTop||0)];}
-if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
-return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
--this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
--this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(!(p instanceof OpenLayers.Projection)){p=new OpenLayers.Projection(p);}
-if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i
=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
+OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},getCurrentPointIndex:function(){return this.line.geometry.components.length-2;},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
+if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
+if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
+this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
+return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(force){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,force);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
+return geometry;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,featureDx:0,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var ratio=extent.getWidth()/this.map.getExtent().getWidth(),extent=extent.scale(1/ratio);this.extent=extent.wrapDateLine(this.map.getMaxExtent()).scale(ratio);}
+if(resolutionChanged){this.resolution=null;}
+return true;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMaxExtent();}
+if(!bounds.intersectsBounds(this.extent,{worldBounds:worldBounds})){style={display:"none"};}else{this.calculateFeatureDx(bounds,worldBounds);}
+var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
+this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
+return rendered;}}},calculateFeatureDx:function(bounds,worldBounds){this.featureDx=0;if(worldBounds){var worldWidth=worldBounds.getWidth(),rendererCenterX=(this.extent.left+this.extent.right)/2,featureCenterX=(bounds.left+bounds.right)/2,worldsAway=Math.round((featureCenterX-rendererCenterX)/worldWidth);this.featureDx=worldsAway*worldWidth;}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
+if(symbolizer.fill===false){delete result.fillColor;}
+OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0,labelAlign:'cm'};OpenLayers.Renderer.symbol={"star":[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],"cross":[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],"x":[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],"square":[0,0,0,1,1,1,1,0,0,0],"triangle":[0,10,10,10,5,0,0,10]};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,cachedSymbolBounds:{},initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={
};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},setExtent:function(){OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);return false;},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){return OpenLayers.CANVAS_SUPPORTED;},setSize:function(size){this.size=size.clone();var root=this.root;root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);var bounds=feature.geometry.getBounds();var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMax
Extent();}
+var intersects=bounds&&bounds.intersectsBounds(this.extent,{worldBounds:worldBounds});rendered=(style.display!=="none")&&!!bounds&&intersects;if(rendered){this.features[feature.id]=[feature,style];}
+else{delete(this.features[feature.id]);}
+this.pendingRedraw=true;}
+if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
+return rendered;},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
+return;}
+switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style,featureId);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style,featureId);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style,featureId);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style,featureId);break;default:break;}},drawExternalGraphic:function(geometry,style,featureId){var img=new Image();var title=style.title||style.graphicTitle;if(title){img.title=title;}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;var onLoad=function(){if(!this.features[featureId]){return;}
+var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=(p0+xOffset)|0;var y=(p1+yOffset)|0;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},drawNamedSymbol:function(geometry,style,featureId){var x,y,cx,cy,i,symbolBounds,scaling,angle;var unscaledStrokeWidth;var deg2rad=Math.PI/180.0;var symbol=OpenLayers.Renderer.symbol[style.graphicName];if(!symbol){throw new Error(style.graphicName+' is not a valid symbol name');}
+if(!symbol.length||symbol.length<2)return;var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(isNaN(p0)||isNaN(p1))return;this.canvas.lineCap="round";this.canvas.lineJoin="round";if(this.hitDetection){this.hitContext.lineCap="round";this.hitContext.lineJoin="round";}
+if(style.graphicName in this.cachedSymbolBounds){symbolBounds=this.cachedSymbolBounds[style.graphicName];}else{symbolBounds=new OpenLayers.Bounds();for(i=0;i<symbol.length;i+=2){symbolBounds.extend(new OpenLayers.LonLat(symbol[i],symbol[i+1]));}
+this.cachedSymbolBounds[style.graphicName]=symbolBounds;}
+this.canvas.save();if(this.hitDetection){this.hitContext.save();}
+this.canvas.translate(p0,p1);if(this.hitDetection){this.hitContext.translate(p0,p1);}
+angle=deg2rad*style.rotation;if(!isNaN(angle)){this.canvas.rotate(angle);if(this.hitDetection){this.hitContext.rotate(angle);}}
+scaling=2.0*style.pointRadius/Math.max(symbolBounds.getWidth(),symbolBounds.getHeight());this.canvas.scale(scaling,scaling);if(this.hitDetection){this.hitContext.scale(scaling,scaling);}
+cx=symbolBounds.getCenterLonLat().lon;cy=symbolBounds.getCenterLonLat().lat;this.canvas.translate(-cx,-cy);if(this.hitDetection){this.hitContext.translate(-cx,-cy);}
+unscaledStrokeWidth=style.strokeWidth;style.strokeWidth=unscaledStrokeWidth/scaling;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.canvas.lineTo(x,y);}
+this.canvas.closePath();this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitContext.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.hitContext.lineTo(x,y);}
+this.hitContext.closePath();this.hitContext.fill();}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.canvas.lineTo(x,y);}
+this.canvas.closePath();this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style,scaling);this.hitContext.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.hitContext.moveTo(x,y);this.hitContext.lineTo(x,y);}
+this.hitContext.closePath();this.hitContext.stroke();}}
+style.strokeWidth=unscaledStrokeWidth;this.canvas.restore();if(this.hitDetection){this.hitContext.restore();}
+this.setCanvasStyle("reset");},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},featureIdToHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
+var hex="000000"+id.toString(16);var len=hex.length;hex="#"+hex.substring(len-6,len);return hex;},setHitContextStyle:function(type,featureId,symbolizer,strokeScaling){var hex=this.featureIdToHex(featureId);if(type=="fill"){this.hitContext.globalAlpha=1.0;this.hitContext.fillStyle=hex;}else if(type=="stroke"){this.hitContext.globalAlpha=1.0;this.hitContext.strokeStyle=hex;if(typeof strokeScaling==="undefined"){this.hitContext.lineWidth=symbolizer.strokeWidth+2;}else{if(!isNaN(strokeScaling)){this.hitContext.lineWidth=symbolizer.strokeWidth+2.0/strokeScaling;}}}else{this.hitContext.globalAlpha=0;this.hitContext.lineWidth=1;}},drawPoint:function(geometry,style,featureId){if(style.graphic!==false){if(style.externalGraphic){this.drawExternalGraphic(geometry,style,featureId);}else if(style.graphicName&&(style.graphicName!="circle")){this.drawNamedSymbol(geometry,style,featureId);}else{var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var twoPi=M
ath.PI*2;var radius=style.pointRadius;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.fill();}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.stroke();}
+this.setCanvasStyle("reset");}}}}},drawLineString:function(geometry,style,featureId){style=OpenLayers.Util.applyDefaults({fill:false},style);this.drawLinearRing(geometry,style,featureId);},drawLinearRing:function(geometry,style,featureId){if(style.fill!==false){this.setCanvasStyle("fill",style);this.renderPath(this.canvas,geometry,style,featureId,"fill");if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"fill");}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.renderPath(this.canvas,geometry,style,featureId,"stroke");if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"stroke");}}
+this.setCanvasStyle("reset");},renderPath:function(context,geometry,style,featureId,type){var components=geometry.components;var len=components.length;context.beginPath();var start=this.getLocalXY(components[0]);var x=start[0];var y=start[1];if(!isNaN(x)&&!isNaN(y)){context.moveTo(start[0],start[1]);for(var i=1;i<len;++i){var pt=this.getLocalXY(components[i]);context.lineTo(pt[0],pt[1]);}
+if(type==="fill"){context.fill();}else{context.stroke();}}},drawPolygon:function(geometry,style,featureId){var components=geometry.components;var len=components.length;this.drawLinearRing(components[0],style,featureId);for(var i=1;i<len;++i){this.canvas.globalCompositeOperation="destination-out";if(this.hitDetection){this.hitContext.globalCompositeOperation="destination-out";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({stroke:false,fillOpacity:1.0},style),featureId);this.canvas.globalCompositeOperation="source-over";if(this.hitDetection){this.hitContext.globalCompositeOperation="source-over";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({fill:false},style),featureId);}},drawText:function(location,style){var pt=this.getLocalXY(location);this.setCanvasStyle("reset");this.canvas.fillStyle=style.fontColor;this.canvas.globalAlpha=style.fontOpacity||1.0;var fontStyle=[style.fontStyle?style.fontStyle:"normal","normal",style.fontWeight?style.fontWeight:"normal",style.fontSize?style.fontSize:"1em",style.fontFamily?style.fontFamily:"sans-serif"].join(" ");var labelRows=style.label.split('\n');var numRows=labelRows.length;if(this.canvas.fillText){this.canvas.font=fontStyle;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[1]]||"middle";var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.measureText('Mg').height||this.canvas.measureText('xx').width;pt[1]+=lineHeight*vfactor*(numRows-1);for(var i=0;i<numRows;i++){if(style.labelOutlineWidth){this.canvas.save();this.canvas.globalAlpha=style.labelOutlineOpacity||style.fontOpacity||1.0;this.canvas.strokeStyle=style.labelOutlineColor;this.canvas.lineWidth=style.labelOutlineWidth;this.canvas.strokeText(labelRows[i],pt[0],pt[1]+(lineHeight*i)+1);this.canvas.restore();}
+this.canvas.fillText(labelRows[i],pt[0],pt[1]+(lineHeight*i));}}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=fontStyle;var hfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[0]];if(hfactor==null){hfactor=-.5;}
+var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.mozMeasureText('xx');pt[1]+=lineHeight*(1+(vfactor*numRows));for(var i=0;i<numRows;i++){var x=pt[0]+(hfactor*this.canvas.mozMeasureText(labelRows[i]));var y=pt[1]+(i*lineHeight);this.canvas.translate(x,y);this.canvas.mozDrawText(labelRows[i]);this.canvas.translate(-x,-y);}}
+this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=((point.x-this.featureDx)/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);this.features={};if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}},getFeatureIdFromEvent:function(evt){var featureId,feature;if(this.hitDetection&&this.root.style.display!=="none"){if(!this.map.dragging){var xy=evt.xy;var x=xy.x|0;var y=xy.y|0;var data=this.hitContext.getImageData(x,y,1,1).data;if(data[3]===255){var id=data[2]+(256*(data[1]+(256*data[0])));if(id){featureId="OpenLayers_Feature_Vector_"+(id-1+this.hitOverflow);try{feature=this.features[featureId][0];}catch(err){}}}}}
+return feature;},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
+this.redraw();},redraw:function(){if(!this.locked){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}
+var labelMap=[];var feature,geometry,style;var worldBounds=(this.map.baseLayer&&this.map.baseLayer.wrapDateLine)&&this.map.getMaxExtent();for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
+feature=this.features[id][0];geometry=feature.geometry;this.calculateFeatureDx(geometry.getBounds(),worldBounds);style=this.features[id][1];this.drawGeometry(geometry,style,feature.id);if(style.label){labelMap.push([feature,style]);}}
+var item;for(var i=0,len=labelMap.length;i<len;++i){item=labelMap[i];this.drawText(item[0].geometry.getCentroid(),item[1]);}}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={"l":"left","r":"right","t":"top","b":"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={"l":0,"r":-1,"t":0,"b":-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=fa
lse;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.preventDefault(evt);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
+document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},dragmove:function(evt){this.lastMoveEvt=evt;if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
+if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
+this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
+this.last=evt.xy;}
+return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
+var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){this.startTouch();return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;if(this.dragging){this.mousemove(this.lastMoveEvt);}},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,observeElement:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},d
estroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.observeElement=this.observeElement||document;for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(this.observeElement,this.KEY_EVENTS[i],this.eventListener);}
+return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(this.observeElement,this.KEY_EVENTS[i],this.eventListener);}
+deactivated=true;}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{documentDrag:false,geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertex:null,vertices:null,virtualVertices:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,createVertices:true,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Contro
l.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(OpenLayers.Util.isArray(this.deleteCodes))){this.deleteCodes=[this.deleteCodes];}
+var dragCallbacks={down:function(pixel){this.vertex=null;var feature=this.layer.getFeatureFromEvent(this.handlers.drag.evt);if(feature){this.dragStart(feature);}else if(this.clickout){this._unselect=this.feature;}},move:function(pixel){delete this._unselect;if(this.vertex){this.dragVertex(this.vertex,pixel);}},up:function(){this.handlers.drag.stopDown=false;if(this._unselect){this.unselectFeature(this._unselect);delete this._unselect;}},done:function(pixel){if(this.vertex){this.dragComplete(this.vertex);}}};var dragOptions={documentDrag:this.documentDrag,stopDown:false};var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions),drag:new OpenLayers.Handler.Drag(this,dragCallbacks,dragOptions)};},destroy:function(){if(this.map){this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});}
+this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});return(this.handlers.keyboard.activate()&&this.handlers.drag.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.handlers.drag.deactivate();this.handlers.keyboard.deactivate();var feature=this.feature;if(feature&&feature.geometry&&feature.layer){this.unselectFeature(feature);}
+deactivated=true;}
+return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(this.feature===feature||(this.geometryTypes&&OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)==-1)){return;}
+if(this.beforeSelectFeature(feature)!==false){if(this.feature){this.unselectFeature(this.feature);}
+this.feature=feature;this.layer.selectedFeatures.push(feature);this.layer.drawFeature(feature,'select');this.modified=false;this.resetVertices();this.onModificationStart(this.feature);}
+var modified=feature.modified;if(feature.geometry&&!(modified&&modified.geometry)){this._originalGeometry=feature.geometry.clone();}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
+this.layer.drawFeature(this.feature,'default');this.feature=null;OpenLayers.Util.removeItem(this.layer.selectedFeatures,feature);this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature){var isPoint=feature.geometry.CLASS_NAME=='OpenLayers.Geometry.Point';if(!this.standalone&&((!feature._sketch&&isPoint)||!feature._sketch)){if(this.toggle&&this.feature===feature){this._unselect=feature;}
+this.selectFeature(feature);}
+if(feature._sketch||isPoint){this.vertex=feature;this.handlers.drag.stopDown=true;}},dragVertex:function(vertex,pixel){var pos=this.map.getLonLatFromViewPortPx(pixel);var geom=vertex.geometry;geom.move(pos.lon-geom.x,pos.lat-geom.y);this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
+if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+this.layer.drawFeature(this.feature,this.standalone?undefined:'select');}
+this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;if(this.modified&&this._originalGeometry){var feature=this.feature;feature.modified=OpenLayers.Util.extend(feature.modified,{geometry:this._originalGeometry});delete this._originalGeometry;}}},resetVertices:function(){if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
+if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
+if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
+if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
+if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.layer.getFeatureFromEvent(this.handlers.drag.evt);if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:'select');this.modified=true;this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vert
ex,component,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
+for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
+if(control.createVertices&&geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
+collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.dragHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.F
eature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
+if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
+geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.radiusHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.handlers.drag.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;O
penLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,interval:0,maxDelta:Number.POSITIVE_INFINITY,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var overScrollableDiv=false;var allowScroll=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{var overflow;if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);overflow=style.getPropertyValue("overflow");}
+overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
+if(!allowScroll){allowScroll=OpenLayers.Element.hasClass(elem,'olScrollable');if(!allowScroll){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(elem==layer.div||elem==layer.pane){allowScroll=true;break;}}}}
+overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
+if(!overScrollableDiv&&overMapDiv){if(allowScroll){var delta=0;if(e.wheelDelta){delta=e.wheelDelta;if(delta%160===0){delta=delta*0.75;}
+delta=delta/120;}else if(e.detail){delta=-(e.detail/Math.abs(e.detail));}
+this.delta+=delta;window.clearTimeout(this._timeoutId);if(this.interval&&Math.abs(this.delta)<this.maxDelta){var evt=OpenLayers.Util.extend({},e);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(evt);},this),this.interval);}else{this.wheelZoom(e);}}
+OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){e.xy=this.map.events.getMousePosition(e);if(delta<0){this.callback("down",[e,this.cumulative?Math.max(-this.maxDelta,delta):-1]);}else{this.callback("up",[e,this.cumulative?Math.min(this.maxDelta,delta):1]);}}},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return t
rue;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Tile=OpenLayers.Class({events:null,eventListeners:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.setBounds(bounds);this.url=url;if(size){this.size=size.clone();}
+this.id=OpenLayers.Util.createUniqueID("Tile_");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.eventListeners=null;this.events=null;},draw:function(force){if(!force){this.clear();}
+var draw=this.shouldDraw();if(draw&&!force&&this.events.triggerEvent("beforedraw")===false){draw=null;}
+return draw;},shouldDraw:function(){var withinMaxExtent=false,maxExtent=this.layer.maxExtent;if(maxExtent){var map=this.layer.map;var worldBounds=map.baseLayer.wrapDateLine&&map.getMaxExtent();if(this.bounds.intersectsBounds(maxExtent,{inclusive:false,worldBounds:worldBounds})){withinMaxExtent=true;}}
+return withinMaxExtent||this.layer.displayOutsideMaxExtent;},setBounds:function(bounds){bounds=bounds.clone();if(this.layer.map.baseLayer.wrapDateLine){var worldExtent=this.layer.map.getMaxExtent(),tolerance=this.layer.map.getResolution();bounds=bounds.wrapDateLine(worldExtent,{leftTolerance:tolerance,rightTolerance:tolerance});}
+this.bounds=bounds;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.setBounds(bounds);this.position=position.clone();if(redraw){this.draw();}},clear:function(draw){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.vendorPrefix=(function(){"use strict";var VENDOR_PREFIXES=["","O","ms","Moz","Webkit"],divStyle=document.createElement("div").style,cssCache={},jsCache={};function domToCss(prefixedDom){if(!prefixedDom){return null;}
+return prefixedDom.replace(/([A-Z])/g,function(c){return"-"+c.toLowerCase();}).replace(/^ms-/,"-ms-");}
+function css(property){if(cssCache[property]===undefined){var domProperty=property.replace(/(-[\s\S])/g,function(c){return c.charAt(1).toUpperCase();});var prefixedDom=style(domProperty);cssCache[property]=domToCss(prefixedDom);}
+return cssCache[property];}
+function js(obj,property){if(jsCache[property]===undefined){var tmpProp,i=0,l=VENDOR_PREFIXES.length,prefix,isStyleObj=(typeof obj.cssText!=="undefined");jsCache[property]=null;for(;i<l;i++){prefix=VENDOR_PREFIXES[i];if(prefix){if(!isStyleObj){prefix=prefix.toLowerCase();}
+tmpProp=prefix+property.charAt(0).toUpperCase()+property.slice(1);}else{tmpProp=property;}
+if(obj[tmpProp]!==undefined){jsCache[property]=tmpProp;break;}}}
+return jsCache[property];}
+function style(property){return js(divStyle,property);}
+return{css:css,js:js,style:style,cssCache:cssCache,jsCache:jsCache};}());OpenLayers.Animation=(function(window){var requestAnimationFrame=OpenLayers.Util.vendorPrefix.js(window,"requestAnimationFrame");var isNative=!!(requestAnimationFrame);var requestFrame=(function(){var request=window[requestAnimationFrame]||function(callback,element){window.setTimeout(callback,16);};return function(callback,element){request.apply(window,[callback,element]);};})();var counter=0;var loops={};function start(callback,duration,element){duration=duration>0?duration:Number.POSITIVE_INFINITY;var id=++counter;var start=+new Date;loops[id]=function(){if(loops[id]&&+new Date-start<=duration){callback();if(loops[id]){requestFrame(loops[id],element);}}else{delete loops[id];}};requestFrame(loops[id],element);return id;}
+function stop(id){delete loops[id];}
+return{isNative:isNative,requestFrame:requestFrame,start:start,stop:stop};})(window);OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,maxGetUrlLength:null,canvasContext:null,crossOriginKeyword:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();if(this.maxGetUrlLength!=null||this.layer.gutter||this.layerAlphaHack){this.frame=document.createElement("div");this.frame.style.position="absolute";this.frame.style.overflow="hidden";}
+if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}},destroy:function(){if(this.imgDiv){this.clear();this.imgDiv=null;this.frame=null;}
+this.asyncRequestId=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},draw:function(){var shouldDraw=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(shouldDraw){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+if(this.isLoading){this._loadEvent="reload";}else{this.isLoading=true;this._loadEvent="loadstart";}
+this.renderTile();this.positionTile();}else if(shouldDraw===false){this.unload();}
+return shouldDraw;},renderTile:function(){if(this.layer.async){var id=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,function(url){if(id==this.asyncRequestId){this.url=url;this.initImage();}},this);}else{this.url=this.layer.getURL(this.bounds);this.initImage();}},positionTile:function(){var style=this.getTile().style,size=this.frame?this.size:this.layer.getImageSize(this.bounds),ratio=1;if(this.layer instanceof OpenLayers.Layer.Grid){ratio=this.layer.getServerResolution()/this.layer.map.getResolution();}
+style.left=this.position.x+"px";style.top=this.position.y+"px";style.width=Math.round(ratio*size.w)+"px";style.height=Math.round(ratio*size.h)+"px";},clear:function(){OpenLayers.Tile.prototype.clear.apply(this,arguments);var img=this.imgDiv;if(img){var tile=this.getTile();if(tile.parentNode===this.layer.div){this.layer.div.removeChild(tile);}
+this.setImgSrc();if(this.layerAlphaHack===true){img.style.filter="";}
+OpenLayers.Element.removeClass(img,"olImageLoadError");}
+this.canvasContext=null;},getImage:function(){if(!this.imgDiv){this.imgDiv=OpenLayers.Tile.Image.IMAGE.cloneNode(false);var style=this.imgDiv.style;if(this.frame){var left=0,top=0;if(this.layer.gutter){left=this.layer.gutter/this.layer.tileSize.w*100;top=this.layer.gutter/this.layer.tileSize.h*100;}
+style.left=-left+"%";style.top=-top+"%";style.width=(2*left+100)+"%";style.height=(2*top+100)+"%";}
+style.visibility="hidden";style.opacity=0;if(this.layer.opacity<1){style.filter='alpha(opacity='+
+(this.layer.opacity*100)+')';}
+style.position="absolute";if(this.layerAlphaHack){style.paddingTop=style.height;style.height="0";style.width="100%";}
+if(this.frame){this.frame.appendChild(this.imgDiv);}}
+return this.imgDiv;},setImage:function(img){this.imgDiv=img;},initImage:function(){if(!this.url&&!this.imgDiv){this.isLoading=false;return;}
+this.events.triggerEvent('beforeload');this.layer.div.appendChild(this.getTile());this.events.triggerEvent(this._loadEvent);var img=this.getImage();var src=img.getAttribute('src')||'';if(this.url&&OpenLayers.Util.isEquivalentUrl(src,this.url)){this._loadTimeout=window.setTimeout(OpenLayers.Function.bind(this.onImageLoad,this),0);}else{this.stopLoading();if(this.crossOriginKeyword){img.removeAttribute("crossorigin");}
+OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(this.onImageLoad,this));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(this.onImageError,this));this.imageReloadAttempts=0;this.setImgSrc(this.url);}},setImgSrc:function(url){var img=this.imgDiv;if(url){img.style.visibility='hidden';img.style.opacity=0;if(this.crossOriginKeyword){if(url.substr(0,5)!=='data:'){img.setAttribute("crossorigin",this.crossOriginKeyword);}else{img.removeAttribute("crossorigin");}}
+img.src=url;}else{this.stopLoading();this.imgDiv=null;if(img.parentNode){img.parentNode.removeChild(img);}}},getTile:function(){return this.frame?this.frame:this.getImage();},createBackBuffer:function(){if(!this.imgDiv||this.isLoading){return;}
+var backBuffer;if(this.frame){backBuffer=this.frame.cloneNode(false);backBuffer.appendChild(this.imgDiv);}else{backBuffer=this.imgDiv;}
+this.imgDiv=null;return backBuffer;},onImageLoad:function(){var img=this.imgDiv;this.stopLoading();img.style.visibility='inherit';img.style.opacity=this.layer.opacity;this.isLoading=false;this.canvasContext=null;this.events.triggerEvent("loadend");if(this.layerAlphaHack===true){img.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+
+img.src+"', sizingMethod='scale')";}},onImageError:function(){var img=this.imgDiv;if(img.src!=null){this.imageReloadAttempts++;if(this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.setImgSrc(this.layer.getURL(this.bounds));}else{OpenLayers.Element.addClass(img,"olImageLoadError");this.events.triggerEvent("loaderror");this.onImageLoad();}}},stopLoading:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);window.clearTimeout(this._loadTimeout);delete this._loadTimeout;},getCanvasContext:function(){if(OpenLayers.CANVAS_SUPPORTED&&this.imgDiv&&!this.isLoading){if(!this.canvasContext){var canvas=document.createElement("canvas");canvas.width=this.size.w;canvas.height=this.size.h;this.canvasContext=canvas.getContext("2d");this.canvasContext.drawImage(this.imgDiv,0,0);}
+return this.canvasContext;}},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.IMAGE=(function(){var img=new Image();img.className="olTileImage";img.galleryImg="no";return img;}());OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
+sourceSplit=true;splits=splits[1];}
+if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
+if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
+if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
+if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
+if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
+splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
+for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
+targetSplit=true;}}
+if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
+return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear();},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
+var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
+this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
ed){nextElement=this.getNextElement(nextIndex);}
+return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
+return returnVal;},Z_ORDER_DRAWING_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal==0){returnVal=1;}
+return returnVal;},Z_ORDER_Y_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal===0){var result=nextNode._boundsBottom-newNode._boundsBottom;returnVal=(result===0)?1:result;}
+return returnVal;}};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,xOffset:0,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",LABEL_OUTLINE_SUFFIX:"_outline",initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(options&&(options.zIndexing||options.yOrdering)){this.indexer=new OpenLayers.ElementsIndexer(options.yOrdering);}},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){var child
;var root=this.vectorRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
+root=this.textRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
+if(this.indexer){this.indexer.clear();}},setExtent:function(extent,resolutionChanged){var coordSysUnchanged=OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var rightOfDateLine,ratio=extent.getWidth()/this.map.getExtent().getWidth(),extent=extent.scale(1/ratio),world=this.map.getMaxExtent();if(world.right>extent.left&&world.right<extent.right){rightOfDateLine=true;}else if(world.left>extent.left&&world.left<extent.right){rightOfDateLine=false;}
+if(rightOfDateLine!==this.rightOfDateLine||resolutionChanged){coordSysUnchanged=false;this.xOffset=rightOfDateLine===true?world.getWidth()/resolution:0;}
+this.rightOfDateLine=rightOfDateLine;}
+return coordSysUnchanged;},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;var rendered=true;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0,len=geometry.components.length;i<len;i++){rendered=this.drawGeometry(geometry.components[i],style,featureId)&&rendered;}
+return rendered;}
+rendered=false;var removeBackground=false;if(style.display!="none"){if(style.backgroundGraphic){this.redrawBackgroundNode(geometry.id,geometry,style,featureId);}else{removeBackground=true;}
+rendered=this.redrawNode(geometry.id,geometry,style,featureId);}
+if(rendered==false){var node=document.getElementById(geometry.id);if(node){if(node._style.backgroundGraphic){removeBackground=true;}
+node.parentNode.removeChild(node);}}
+if(removeBackground){var node=document.getElementById(geometry.id+this.BACKGROUND_ID_SUFFIX);if(node){node.parentNode.removeChild(node);}}
+return rendered;},redrawNode:function(id,geometry,style,featureId){style=this.applyDefaultSymbolizer(style);var node=this.nodeFactory(id,this.getNodeType(geometry,style));node._featureId=featureId;node._boundsBottom=geometry.getBounds().bottom;node._geometryClass=geometry.CLASS_NAME;node._style=style;var drawResult=this.drawGeometryNode(node,geometry,style);if(drawResult===false){return false;}
+node=drawResult.node;if(this.indexer){var insert=this.indexer.insert(node);if(insert){this.vectorRoot.insertBefore(node,insert);}else{this.vectorRoot.appendChild(node);}}else{if(node.parentNode!==this.vectorRoot){this.vectorRoot.appendChild(node);}}
+this.postDraw(node);return drawResult.complete;},redrawBackgroundNode:function(id,geometry,style,featureId){var backgroundStyle=OpenLayers.Util.extend({},style);backgroundStyle.externalGraphic=backgroundStyle.backgroundGraphic;backgroundStyle.graphicXOffset=backgroundStyle.backgroundXOffset;backgroundStyle.graphicYOffset=backgroundStyle.backgroundYOffset;backgroundStyle.graphicZIndex=backgroundStyle.backgroundGraphicZIndex;backgroundStyle.graphicWidth=backgroundStyle.backgroundWidth||backgroundStyle.graphicWidth;backgroundStyle.graphicHeight=backgroundStyle.backgroundHeight||backgroundStyle.graphicHeight;backgroundStyle.backgroundGraphic=null;backgroundStyle.backgroundXOffset=null;backgroundStyle.backgroundYOffset=null;backgroundStyle.backgroundGraphicZIndex=null;return this.redrawNode(id+this.BACKGROUND_ID_SUFFIX,geometry,backgroundStyle,null);},drawGeometryNode:function(node,geometry,style){style=style||node._style;var options={'isFilled':style.fill===undefined?true:style.
fill,'isStroked':style.stroke===undefined?!!style.strokeWidth:style.stroke};var drawn;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.graphic===false){options.isFilled=false;options.isStroked=false;}
+drawn=this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;drawn=this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":drawn=this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":drawn=this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Rectangle":drawn=this.drawRectangle(node,geometry);break;default:break;}
+node._options=options;if(drawn!=false){return{node:this.setStyle(node,style,options,geometry),complete:drawn};}else{return false;}},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},removeText:function(featureId){var label=document.getElementById(featureId+this.LABEL_ID_SUFFIX);if(label){this.textRoot.removeChild(label);}
+var outline=document.getElementById(featureId+this.LABEL_OUTLINE_SUFFIX);if(outline){this.textRoot.removeChild(outline);}},getFeatureIdFromEvent:function(evt){var target=evt.target;var useElement=target&&target.correspondingUseElement;var node=useElement?useElement:(target||evt.srcElement);return node._featureId;},eraseGeometry:function(geometry,featureId){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")||(geometry.CLASS_NAME=="OpenLayers.Geometry.Collection")){for(var i=0,len=geometry.components.length;i<len;i++){this.eraseGeometry(geometry.components[i],featureId);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){if(element.geometry){element.geometry.destroy();element.geometry=null;}
+element.parentNode.removeChild(element);if(this.indexer){this.indexer.remove(element);}
+if(element._style.backgroundGraphic){var backgroundId=geometry.id+this.BACKGROUND_ID_SUFFIX;var bElem=OpenLayers.Util.getElement(backgroundId);if(bElem&&bElem.parentNode){bElem.parentNode.removeChild(bElem);}}}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
+return node;},nodeTypeCompare:function(node,type){},createNode:function(type,id){},moveRoot:function(renderer){var root=this.root;if(renderer.root.parentNode==this.rendererRoot){root=renderer.root;}
+root.parentNode.removeChild(root);renderer.rendererRoot.appendChild(root);},getRenderLayerId:function(){return this.root.parentNode.parentNode.id;},isComplexSymbol:function(graphicName){return(graphicName!="circle")&&!!graphicName;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,allowDepress:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){if(this.map){this.map.events.unregister("buttonclick",this,this.onButtonClick);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var ctl,i=this.controls.length-1;i>=0;i--){ctl=this.controls[i];if(ctl.events){ctl.events.un({activate:this.iconOn,deactivate:this.iconOff});}
+ctl.panel_div=null;}
+this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
+if(this.saveState===true){this.defaultControl=null;}
+this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];this.activeState[control.id]=control.deactivate();}
+this.redraw();return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(this.outsideViewport){this.events.attachToElement(this.div);this.events.register("buttonclick",this,this.onButtonClick);}else{this.map.events.register("buttonclick",this,this.onButtonClick);}
+this.addControlsToMap(this.controls);return this.div;},redraw:function(){for(var l=this.div.childNodes.length,i=l-1;i>=0;i--){this.div.removeChild(this.div.childNodes[i]);}
+this.div.innerHTML="";if(this.active){for(var i=0,len=this.controls.length;i<len;i++){this.div.appendChild(this.controls[i].panel_div);}}},activateControl:function(control){if(!this.active){return false;}
+if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
+if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
+return;}
+if(this.allowDepress&&control.active){control.deactivate();}else{var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
+control.activate();}},addControls:function(controls){if(!(OpenLayers.Util.isArray(controls))){controls=[controls];}
+this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var control=controls[i],element=this.createControlMarkup(control);OpenLayers.Element.addClass(element,control.displayClass+"ItemInactive");OpenLayers.Element.addClass(element,"olButton");if(control.title!=""&&!element.title){element.title=control.title;}
+control.panel_div=element;}
+if(this.map){this.addControlsToMap(controls);this.redraw();}},createControlMarkup:function(control){return document.createElement("div");},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
+control.events.on({activate:this.iconOn,deactivate:this.iconOff});}},iconOn:function(){var d=this.panel_div;var re=new RegExp("\\b("+this.displayClass+"Item)Inactive\\b");d.className=d.className.replace(re,"$1Active");},iconOff:function(){var d=this.panel_div;var re=new RegExp("\\b("+this.displayClass+"Item)Active\\b");d.className=d.className.replace(re,"$1Inactive");},onButtonClick:function(evt){var controls=this.controls,button=evt.buttonElement;for(var i=controls.length-1;i>=0;--i){if(controls[i].panel_div===button){this.activateControl(controls[i]);break;}}},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Pane
l"});OpenLayers.Tween=OpenLayers.Class({easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,minFrameRate:null,startTime:null,animationId:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.minFrameRate=options.minFrameRate||30;this.time=0;this.startTime=new Date().getTime();OpenLayers.Animation.stop(this.animationId);this.animationId=null;if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.animationId=OpenLayers.Animation.start(OpenLayers.Function.bind(this.play,this));},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+OpenLayers.Animation.stop(this.animationId);this.animationId=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){throw new TypeError('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){if((new Date().getTime()-this.startTime)/this.time<=1000/this.minFrameRate){this.callbacks.eachStep.call(this,value);}}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:nul
l,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(typeof Proj4js=="object"){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(!(p instanceof OpenLayers.Projection)){p=new OpenLayers.Projection(p);}
+if((typeof Proj4js=="object")&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.defaults={"EPSG:4326":{units:"degrees",maxExtent:[-180,-90,180,90],yx:true},"CRS:84":{units:"degrees",maxExtent:[-180,-90,180,90]},"EPSG:900913":{units:"m",maxExtent:[-20037508.34,-20037508.34,20037508.34,20037508.34]}};OpenLayers.Projection.addTransform=function(from,to,method){if(method===OpenLayers.Projection.nullTransform){var defaults=OpenLayers.Projection.defaults[from];if(defaults&&!OpenLayers.Projection.defaults[to]){OpenLayers.Projection.defaults[to]=defaults;}}
if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source&&dest){if(!(source instanceof OpenLayers.Projection)){source=new OpenLayers.Projection(source);}
if(!(dest instanceof OpenLayers.Projection)){dest=new OpenLayers.Projection(dest);}
if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else{var sourceCode=source.getCode();var destCode=dest.getCode();var transforms=OpenLayers.Projection.transforms;if(transforms[sourceCode]&&transforms[sourceCode][destCode]){transforms[sourceCode][destCode](point);}}}
return point;};OpenLayers.Projection.nullTransform=function(point){return point;};(function(){var pole=20037508.34;function inverseMercator(xy){xy.x=180*xy.x/pole;xy.y=180/Math.PI*(2*Math.atan(Math.exp((xy.y/pole)*Math.PI))-Math.PI/2);return xy;}
-function forwardMercator(xy){xy.x=xy.x*pole/180;xy.y=Math.log(Math.tan((90+xy.y)*Math.PI/360))/Math.PI*pole;return xy;}
+function forwardMercator(xy){xy.x=xy.x*pole/180;var y=Math.log(Math.tan((90+xy.y)*Math.PI/360))/Math.PI*pole;xy.y=Math.max(-20037508.34,Math.min(y,20037508.34));return xy;}
function map(base,codes){var add=OpenLayers.Projection.addTransform;var same=OpenLayers.Projection.nullTransform;var i,len,code,other,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add(base,code,forwardMercator);add(code,base,inverseMercator);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}}
var mercator=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"],geographic=["CRS:84","urn:ogc:def:crs:EPSG:6.6:4326","EPSG:4326"],i;for(i=mercator.length-1;i>=0;--i){map(mercator[i],geographic);}
-for(i=geographic.length-1;i>=0;--i){map(geographic[i],mercator);}})();OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1000},id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,options:null,tileSize:null,projection:"EPSG:4326",units:null,resolutions:null,maxResolution:null,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+for(i=geographic.length-1;i>=0;--i){map(geographic[i],mercator);}})();OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1000},id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,options:null,tileSize:null,projection:"EPSG:4326",units:null,resolutions:null,maxResolution:null,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:false,autoUpdateSize:true,eventListeners:null,panTween:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,zoomTween:null,zoomMethod:OpenLayers.Easing.Quad.easeOut,zoomDuration:20,paddingForPopups:null,layerContainerOriginPx:null,minPx:null,maxPx:null,initialize:function(div,option
this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';this.options=OpenLayers.Util.extend({},options);OpenLayers.Util.extend(this,options);var projCode=this.projection instanceof OpenLayers.Projection?this.projection.projCode:this.projection;OpenLayers.Util.applyDefaults(this,OpenLayers.Projection.defaults[projCode]);if(this.maxExtent&&!(this.maxExtent instanceof OpenLayers.Bounds)){this.maxExtent=new OpenLayers.Bounds(this.maxExtent);}
if(this.minExtent&&!(this.minExtent instanceof OpenLayers.Bounds)){this.minExtent=new OpenLayers.Bounds(this.minExtent);}
if(this.restrictedExtent&&!(this.restrictedExtent instanceof OpenLayers.Bounds)){this.restrictedExtent=new OpenLayers.Bounds(this.restrictedExtent);}
if(this.center&&!(this.center instanceof OpenLayers.LonLat)){this.center=new OpenLayers.LonLat(this.center);}
this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
-OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,null,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.width='100px';this.layerContainerDiv.style.height='100px';this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-if(parseFloat(navigator.appVersion.split("MSIE")[1])<9){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,null,this.fallThrough,{includeXY:true});if(OpenLayers.TileManager&&this.tileManager!==null){if(!(this.tileManager instanceof OpenLayers.TileManager)){this.tileManager=new OpenLayers.TileManager(this.tileManager);}
+this.tileManager.addMap(this);}
+id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.layerContainerOriginPx={x:0,y:0};this.applyTransform();this.viewPortDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.autoUpdateSize===true){this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
if(this.controls==null){this.controls=[];if(OpenLayers.Control!=null){if(OpenLayers.Control.Navigation){this.controls.push(new OpenLayers.Control.Navigation());}else if(OpenLayers.Control.TouchNavigation){this.controls.push(new OpenLayers.Control.TouchNavigation());}
@@ -421,15 +690,19 @@
if(OpenLayers.Control.ArgParser){this.controls.push(new OpenLayers.Control.ArgParser());}
if(OpenLayers.Control.Attribution){this.controls.push(new OpenLayers.Control.Attribution());}}}
for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
-this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){delete this.center;this.addLayers(options.layers);if(options.center&&!this.getCenter()){this.setCenter(options.center,options.zoom);}}},getViewport:function(){return this.viewPortDiv;},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){delete this.center;delete this.zoom;this.addLayers(options.layers);if(options.center&&!this.getCenter()){this.setCenter(options.center,options.zoom);}}
+if(this.panMethod){this.panTween=new OpenLayers.Tween(this.panMethod);}
+if(this.zoomMethod&&this.applyTransform.transform){this.zoomTween=new OpenLayers.Tween(this.zoomMethod);}},getViewport:function(){return this.viewPortDiv;},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
if(this.panTween){this.panTween.stop();this.panTween=null;}
-OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+if(this.zoomTween){this.zoomTween.stop();this.zoomTween=null;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}
this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
this.controls=null;}
if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
this.layers=null;}
-if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
-this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+if(this.viewPortDiv&&this.viewPortDiv.parentNode){this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.tileManager){this.tileManager.removeMap(this);this.tileManager=null;}
+if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
this.events.destroy();this.events=null;this.options=null;},setOptions:function(options){var updatePxExtent=this.minPx&&options.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,options);updatePxExtent&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:true});},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var fo
undLayer=null;for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
+zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){return false;}}
@@ -458,25 +731,27 @@
popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
-var center=this.getCachedCenter();if(this.baseLayer!=null&¢er!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
+var center=this.getCachedCenter();if(this.baseLayer!=null&¢er!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}
+this.events.triggerEvent("updatesize");},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCachedCenter();}
if(resolution==null){resolution=this.getResolution();}
if((center!=null)&&(resolution!=null)){var halfWDeg=(this.size.w*resolution)/2;var halfHDeg=(this.size.h*resolution)/2;extent=new OpenLayers.Bounds(center.lon-halfWDeg,center.lat-halfHDeg,center.lon+halfWDeg,center.lat+halfHDeg);}
return extent;},getCenter:function(){var center=null;var cachedCenter=this.getCachedCenter();if(cachedCenter){center=cachedCenter.clone();}
return center;},getCachedCenter:function(){if(!this.center&&this.size){this.center=this.getLonLatFromViewPortPx({x:this.size.w/2,y:this.size.h/2});}
-return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});if(options.dragging){if(dx!=0||dy!=0){this.moveByPx(dx,dy);}}else{var centerPx=this.getViewPortPxFromLonLat(this.getCachedCenter());var newCenterPx=centerPx.add(dx,dy);if(this.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.moveTo(newCenterLonLat);if(this.dragging){this.dragging=false;this.events.triggerEvent("moveend");}}}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCachedCenter();if(lonlat.equals(center)){return;}
-var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
+return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});if(options.dragging){if(dx!=0||dy!=0){this.moveByPx(dx,dy);}}else{var centerPx=this.getViewPortPxFromLonLat(this.getCachedCenter());var newCenterPx=centerPx.add(dx,dy);if(this.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.moveTo(newCenterLonLat);if(this.dragging){this.dragging=false;this.events.triggerEvent("moveend");}}}}},panTo:function(lonlat){if(this.panTween&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){var center=this.getCachedCenter();if(lonlat.equals(center)){return;}
+var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){if(this.panTween){this.panTween.stop();}
+if(this.zoomTween){this.zoomTween.stop();}
+this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
dx=wrapDateLine||x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction?Math.round(dx):0;dy=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction?Math.round(dy):0;if(dx||dy){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
-this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;}
-if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
-var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility&&(layer===this.baseLayer||layer.inRange)){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
-this.events.triggerEvent("move");}},adjustZoom:function(zoom){var resolution,resolutions=this.baseLayer.resolutions,maxResolution=this.getMaxExtent().getWidth()/this.size.w;if(this.getResolutionForZoom(zoom)>maxResolution){for(var i=zoom|0,ii=resolutions.length;i<ii;++i){if(resolutions[i]<=maxResolution){zoom=i;break;}}}
-return zoom;},moveTo:function(lonlat,zoom,options){if(lonlat!=null&&!(lonlat instanceof OpenLayers.LonLat)){lonlat=new OpenLayers.LonLat(lonlat);}
+this.center=null;if(dx){this.layerContainerOriginPx.x-=dx;this.minPx.x-=dx;this.maxPx.x-=dx;}
+if(dy){this.layerContainerOriginPx.y-=dy;this.minPx.y-=dy;this.maxPx.y-=dy;}
+this.applyTransform();var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility&&(layer===this.baseLayer||layer.inRange)){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
+this.events.triggerEvent("move");}},adjustZoom:function(zoom){if(this.baseLayer&&this.baseLayer.wrapDateLine){var resolution,resolutions=this.baseLayer.resolutions,maxResolution=this.getMaxExtent().getWidth()/this.size.w;if(this.getResolutionForZoom(zoom)>maxResolution){if(this.fractionalZoom){zoom=this.getZoomForResolution(maxResolution);}else{for(var i=zoom|0,ii=resolutions.length;i<ii;++i){if(resolutions[i]<=maxResolution){zoom=i;break;}}}}}
+return zoom;},getMinZoom:function(){return this.adjustZoom(0);},moveTo:function(lonlat,zoom,options){if(lonlat!=null&&!(lonlat instanceof OpenLayers.LonLat)){lonlat=new OpenLayers.LonLat(lonlat);}
if(!options){options={};}
if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
-if(this.baseLayer.wrapDateLine){var requestedZoom=zoom;zoom=this.adjustZoom(zoom);if(zoom!==requestedZoom){lonlat=this.getCenter();}}
+var requestedZoom=zoom;zoom=this.adjustZoom(zoom);if(zoom!==requestedZoom){lonlat=this.getCenter();}
var dragging=options.dragging||this.dragging;var forceZoomChange=options.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();this.center=lonlat.clone();}
if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.center;}
if(zoom==null){zoom=this.getZoom();}
@@ -487,16 +762,16 @@
extent.bottom);}
else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
extent.top);}}}
-var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||dragging){dragging||this.events.triggerEvent("movestart");if(centerChanged){if(!zoomChanged&&this.center){this.centerLayerContainer(lonlat);}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||dragging){dragging||this.events.triggerEvent("movestart",{zoomChanged:zoomChanged});if(centerChanged){if(!zoomChanged&&this.center){this.centerLayerContainer(lonlat);}
-var res=zoomChanged?this.getResolutionForZoom(zoom):this.getResolution();if(zoomChanged||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var maxExtent=this.getMaxExtent({restricted:true});var maxExtentCenter=maxExtent.getCenterLonLat();var lonDelta=this.center.lon-maxExtentCenter.lon;var latDelta=maxExtentCenter.lat-this.center.lat;var extentWidth=Math.round(maxExtent.getWidth()/res);var extentHeight=Math.round(maxExtent.getHeight()/res);this.minPx={x:(this.size.w-extentWidth)/2-lonDelta/res,y:(this.size.h-extentHeight)/2-latDelta/res};this.maxPx={x:this.minPx.x+Math.round(maxExtent.getWidth()/res),y:this.minPx.y+Math.round(maxExtent.getHeight()/res)};}
+var res=zoomChanged?this.getResolutionForZoom(zoom):this.getResolution();if(zoomChanged||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerOriginPx.x=0;this.layerContainerOriginPx.y=0;this.applyTransform();var maxExtent=this.getMaxExtent({restricted:true});var maxExtentCenter=maxExtent.getCenterLonLat();var lonDelta=this.center.lon-maxExtentCenter.lon;var latDelta=maxExtentCenter.lat-this.center.lat;var extentWidth=Math.round(maxExtent.getWidth()/res);var extentHeight=Math.round(maxExtent.getHeight()/res);this.minPx={x:(this.size.w-extentWidth)/2-lonDelta/res,y:(this.size.h-extentHeight)/2-latDelta/res};this.maxPx={x:this.minPx.x+Math.round(maxExtent.getWidth()/res),y:this.minPx.y+Math.round(maxExtent.getHeight()/res)};}
if(zoomChanged){this.zoom=zoom;this.resolution=res;}
var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}
bounds=this.baseLayer.getExtent();for(var i=this.layers.length-1;i>=0;--i){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||layer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}}}
this.events.triggerEvent("move");dragging||this.events.triggerEvent("moveend");if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}
-this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=parseInt(this.layerContainerDiv.style.left);var oldTop=parseInt(this.layerContainerDiv.style.top);var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.layerContainerDiv.style.left=newLeft+"px";this.layerContainerDiv.style.top=newTop+"px";var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();var worldBounds=this.baseLayer.wrapDateLine&&maxExtent;valid=maxExtent.containsLonLat(lonlat,{worldBounds:worldBounds});}
+this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=this.layerContainerOriginPx.x;var oldTop=this.layerContainerOriginPx.y;var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.applyTransform((this.layerContainerOriginPx.x=newLeft),(this.layerContainerOriginPx.y=newTop));var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();var worldBounds=this.baseLayer.wrapDateLine&&maxExtent;valid=maxExtent.containsLonLat(lonlat,{worldBounds:worldBounds});}
return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
@@ -508,15 +783,24 @@
return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
-return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){if(!(bounds instanceof OpenLayers.Bounds)){bounds=new OpenLayers.Bounds(bounds);}
+return zoom;},zoomTo:function(zoom,xy){var map=this;if(map.isValidZoomLevel(zoom)){if(map.baseLayer.wrapDateLine){zoom=map.adjustZoom(zoom);}
+if(map.zoomTween){var currentRes=map.getResolution(),targetRes=map.getResolutionForZoom(zoom),start={scale:1},end={scale:currentRes/targetRes};if(map.zoomTween.playing&&map.zoomTween.duration<3*map.zoomDuration){map.zoomTween.finish={scale:map.zoomTween.finish.scale*end.scale};}else{if(!xy){var size=map.getSize();xy={x:size.w/2,y:size.h/2};}
+map.zoomTween.start(start,end,map.zoomDuration,{minFrameRate:50,callbacks:{eachStep:function(data){var containerOrigin=map.layerContainerOriginPx,scale=data.scale,dx=((scale-1)*(containerOrigin.x-xy.x))|0,dy=((scale-1)*(containerOrigin.y-xy.y))|0;map.applyTransform(containerOrigin.x+dx,containerOrigin.y+dy,scale);},done:function(data){map.applyTransform();var resolution=map.getResolution()/data.scale,zoom=map.getZoomForResolution(resolution,true)
+map.moveTo(map.getZoomTargetCenter(xy,resolution),zoom,true);}}});}}else{var center=xy?map.getZoomTargetCenter(xy,map.getResolutionForZoom(zoom)):null;map.setCenter(center,zoom);}}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){if(!(bounds instanceof OpenLayers.Bounds)){bounds=new OpenLayers.Bounds(bounds);}
var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var halfWDeg=(this.size.w*res)/2;var halfHDeg=(this.size.h*res)/2;var center=this.getCachedCenter();var extent=new OpenLayers.Bounds(center.lon-halfWDeg,center.lat-halfHDeg,center.lon+halfWDeg,center.lat+halfHDeg);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
-return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
-return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
-return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,metadata:null,initiali
ze:function(name,options){this.metadata={};this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+return px;},getZoomTargetCenter:function(xy,resolution){var lonlat=null,size=this.getSize(),deltaX=size.w/2-xy.x,deltaY=xy.y-size.h/2,zoomPoint=this.getLonLatFromPixel(xy);if(zoomPoint){lonlat=new OpenLayers.LonLat(zoomPoint.lon+deltaX*resolution,zoomPoint.lat+deltaY*resolution);}
+return lonlat;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
+return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=this.layerContainerOriginPx.x;var dY=this.layerContainerOriginPx.y;viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-this.layerContainerOriginPx.x;var dY=-this.layerContainerOriginPx.y;layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},applyTransform:function(x,y,scale){scale=scale||1;var origin=this.layerContainerOriginPx,needTransform=scale!==1;x=x||origin.x;y=y||origin.y;var style=this.layerContainerDiv.style,transform=this.applyTransform.transform,template=this.applyTransform.template;if(transform===undefined){transform=OpenLayers.Util.vendorPrefix.style('transform');this.applyTransform.transform=transform;if(transform){var computedStyle=OpenLayers.Element.getStyle(this.viewPortDiv,OpenLayers.Util.vendorPrefix.css('transform'));if(!computedStyle||computedStyle!=='none'){template=['translate3d(',',0) ','scale3d(',',1)'];style[transform]=[template[0],'0,0',template[1]].join('');}
+if(!template||!~style[transform].indexOf(template[0])){template=['translate(',') ','scale(',')'];}
+this.applyTransform.template=template;}}
+if(transform!==null&&(template[0]==='translate3d('||needTransform===true)){if(needTransform===true&&template[0]==='translate('){x-=origin.x;y-=origin.y;style.left=origin.x+'px';style.top=origin.y+'px';}
+style[transform]=[template[0],x,'px,',y,'px',template[1],template[2],scale,',',scale,template[3]].join('');}else{style.left=x+'px';style.top=y+'px';if(transform!==null){style[transform]='';}}},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,metadata:null,initialize:function(name,options){this.metadata={};options=OpenLa
yers.Util.extend({},options);if(this.alwaysInRange!=null){options.alwaysInRange=this.alwaysInRange;}
+this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
this.events.destroy();}
@@ -536,7 +820,7 @@
this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len,p;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
-if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
+if(this.options.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
@@ -578,260 +862,119 @@
return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Tile=OpenLayers.Class({events:null,eventListeners:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.setBounds(bounds);this.url=url;if(size){this.size=size.clone();}
-this.id=OpenLayers.Util.createUniqueID("Tile_");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();this.eventListeners=null;this.events=null;},draw:function(deferred){if(!deferred){this.clear();}
-var draw=this.shouldDraw();if(draw&&!deferred){draw=this.events.triggerEvent("beforedraw")!==false;}
-return draw;},shouldDraw:function(){var withinMaxExtent=false,maxExtent=this.layer.maxExtent;if(maxExtent){var map=this.layer.map;var worldBounds=map.baseLayer.wrapDateLine&&map.getMaxExtent();if(this.bounds.intersectsBounds(maxExtent,{inclusive:false,worldBounds:worldBounds})){withinMaxExtent=true;}}
-return withinMaxExtent||this.layer.displayOutsideMaxExtent;},setBounds:function(bounds){bounds=bounds.clone();if(this.layer.map.baseLayer.wrapDateLine){var worldExtent=this.layer.map.getMaxExtent(),tolerance=this.layer.map.getResolution();bounds=bounds.wrapDateLine(worldExtent,{leftTolerance:tolerance,rightTolerance:tolerance});}
-this.bounds=bounds;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
-this.setBounds(bounds);this.position=position.clone();if(redraw){this.draw();}},clear:function(draw){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,blankImageUrl:"data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",maxGetUrlLength:null,canvasContext:null,crossOriginKeyword:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();if(this.maxGetUrlLength!=null||this.layer.gutter||this.layerAlphaHack){this.frame=document.createElement("div");this.frame.style.position="absolute";this.frame.style.overflow="hidden";}
-if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}},destroy:function(){if(this.imgDiv){this.clear();this.imgDiv=null;this.frame=null;}
-this.asyncRequestId=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},draw:function(){var drawn=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(drawn){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
-if(this.isLoading){this._loadEvent="reload";}else{this.isLoading=true;this._loadEvent="loadstart";}
-this.positionTile();this.renderTile();}else{this.unload();}
-return drawn;},renderTile:function(){this.layer.div.appendChild(this.getTile());if(this.layer.async){var id=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,function(url){if(id==this.asyncRequestId){this.url=url;this.initImage();}},this);}else{this.url=this.layer.getURL(this.bounds);this.initImage();}},positionTile:function(){var style=this.getTile().style,size=this.frame?this.size:this.layer.getImageSize(this.bounds);style.left=this.position.x+"%";style.top=this.position.y+"%";style.width=size.w+"%";style.height=size.h+"%";},clear:function(){OpenLayers.Tile.prototype.clear.apply(this,arguments);var img=this.imgDiv;if(img){OpenLayers.Event.stopObservingElement(img);var tile=this.getTile();if(tile.parentNode===this.layer.div){this.layer.div.removeChild(tile);}
-this.setImgSrc();if(this.layerAlphaHack===true){img.style.filter="";}
-OpenLayers.Element.removeClass(img,"olImageLoadError");}
-this.canvasContext=null;},getImage:function(){if(!this.imgDiv){this.imgDiv=document.createElement("img");this.imgDiv.className="olTileImage";this.imgDiv.galleryImg="no";var style=this.imgDiv.style;if(this.frame){var left=0,top=0;if(this.layer.gutter){left=this.layer.gutter/this.layer.tileSize.w*100;top=this.layer.gutter/this.layer.tileSize.h*100;}
-style.left=-left+"%";style.top=-top+"%";style.width=(2*left+100)+"%";style.height=(2*top+100)+"%";}
-style.visibility="hidden";style.opacity=0;if(this.layer.opacity<1){style.filter='alpha(opacity='+
-(this.layer.opacity*100)+')';}
-style.position="absolute";if(this.layerAlphaHack){style.paddingTop=style.height;style.height="0";style.width="100%";}
-if(this.frame){this.frame.appendChild(this.imgDiv);}}
-return this.imgDiv;},initImage:function(){this.events.triggerEvent(this._loadEvent);var img=this.getImage();if(this.url&&img.getAttribute("src")==this.url){this.onImageLoad();}else{var load=OpenLayers.Function.bind(function(){OpenLayers.Event.stopObservingElement(img);OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(this.onImageLoad,this));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(this.onImageError,this));this.imageReloadAttempts=0;this.setImgSrc(this.url);},this);if(img.getAttribute("src")==this.blankImageUrl){load();}else{OpenLayers.Event.observe(img,"load",load);OpenLayers.Event.observe(img,"error",load);if(this.crossOriginKeyword){img.removeAttribute("crossorigin");}
-img.src=this.blankImageUrl;}}},setImgSrc:function(url){var img=this.imgDiv;img.style.visibility='hidden';img.style.opacity=0;if(url){if(this.crossOriginKeyword){if(url.substr(0,5)!=='data:'){img.setAttribute("crossorigin",this.crossOriginKeyword);}else{img.removeAttribute("crossorigin");}}
-img.src=url;}},getTile:function(){return this.frame?this.frame:this.getImage();},createBackBuffer:function(){if(!this.imgDiv||this.isLoading){return;}
-var backBuffer;if(this.frame){backBuffer=this.frame.cloneNode(false);backBuffer.appendChild(this.imgDiv);}else{backBuffer=this.imgDiv;}
-this.imgDiv=null;return backBuffer;},onImageLoad:function(){var img=this.imgDiv;OpenLayers.Event.stopObservingElement(img);img.style.visibility='inherit';img.style.opacity=this.layer.opacity;this.isLoading=false;this.canvasContext=null;this.events.triggerEvent("loadend");if(parseFloat(navigator.appVersion.split("MSIE")[1])<7&&this.layer&&this.layer.div){var span=document.createElement("span");span.style.display="none";var layerDiv=this.layer.div;layerDiv.appendChild(span);window.setTimeout(function(){span.parentNode===layerDiv&&span.parentNode.removeChild(span);},0);}
-if(this.layerAlphaHack===true){img.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+
-img.src+"', sizingMethod='scale')";}},onImageError:function(){var img=this.imgDiv;if(img.src!=null){this.imageReloadAttempts++;if(this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.setImgSrc(this.layer.getURL(this.bounds));}else{OpenLayers.Element.addClass(img,"olImageLoadError");this.events.triggerEvent("loaderror");this.onImageLoad();}}},getCanvasContext:function(){if(OpenLayers.CANVAS_SUPPORTED&&this.imgDiv&&!this.isLoading){if(!this.canvasContext){var canvas=document.createElement("canvas");canvas.width=this.size.w;canvas.height=this.size.h;this.canvasContext=canvas.getContext("2d");this.canvasContext.drawImage(this.imgDiv,0,0);}
-return this.canvasContext;}},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,tileClass:OpenLayers.Tile.Image,grid:null,singleTile:false,ratio:1.5,buffer:0,transitionEffect:null,numLoadingTiles:0,tileLoadingDelay:85,serverResolutions:null,moveTimerId:null,deferMoveGriddedTiles:null,tileQueueId:null,tileQueue:null,loading:false,backBuffer:null,gridResolution:null,backBufferResolution:null,backBufferLonLat:null,backBufferTimerId:null,removeBackBufferDelay:null,className:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.grid=[];this.tileQueue=[];if(this.removeBackBufferDelay===null){this.removeBackBufferDelay=this.singleTile?0:2500;}
-if(this.className===null){this.className=this.singleTile?'olLayerGridSingleTile':'olLayerGrid';}
-if(!OpenLayers.Animation.isNative){this.deferMoveGriddedTiles=OpenLayers.Function.bind(function(){this.moveGriddedTiles(true);this.moveTimerId=null;},this);}},setMap:function(map){OpenLayers.Layer.HTTPRequest.prototype.setMap.call(this,map);OpenLayers.Element.addClass(this.div,this.className);},removeMap:function(map){if(this.moveTimerId!==null){window.clearTimeout(this.moveTimerId);this.moveTimerId=null;}
-this.clearTileQueue();if(this.backBufferTimerId!==null){window.clearTimeout(this.backBufferTimerId);this.backBufferTimerId=null;}},destroy:function(){this.removeBackBuffer();this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){this.clearTileQueue();if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[iRow];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.destroyTile(tile);}}
-this.grid=[];this.gridResolution=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
+paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,tileClass:OpenLayers.Tile.Image,grid:null,singleTile:false,ratio:1.5,buffer:0,transitionEffect:"resize",numLoadingTiles:0,serverResolutions:null,loading:false,backBuffer:null,gridResolution:null,backBufferResolution:null,backBufferLonLat:null,backBufferTimerId:null,removeBackBufferDelay:null,className:null,gridLayout:null,rowSign:null,transitionendEvents:['transitionend','webkitTransitionEnd','otransitionend','oTransitionEnd'],initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.grid=[];this._removeBackBuffer=OpenLayers.Function.bind(this.removeBackBuffer,this);this.initProperties();this.rowSign=this.tileOriginCorner.s
ubstr(0,1)==="t"?1:-1;},initProperties:function(){if(this.options.removeBackBufferDelay===undefined){this.removeBackBufferDelay=this.singleTile?0:2500;}
+if(this.options.className===undefined){this.className=this.singleTile?'olLayerGridSingleTile':'olLayerGrid';}},setMap:function(map){OpenLayers.Layer.HTTPRequest.prototype.setMap.call(this,map);OpenLayers.Element.addClass(this.div,this.className);},removeMap:function(map){this.removeBackBuffer();},destroy:function(){this.removeBackBuffer();this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[iRow];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.destroyTile(tile);}}
+this.grid=[];this.gridResolution=null;this.gridLayout=null;}},addOptions:function(newOptions,reinitialize){var singleTileChanged=newOptions.singleTile!==undefined&&newOptions.singleTile!==this.singleTile;OpenLayers.Layer.HTTPRequest.prototype.addOptions.apply(this,arguments);if(this.map&&singleTileChanged){this.initProperties();this.clearGrid();this.tileSize=this.options.tileSize;this.setTileSize();this.moveTo(null,true);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];obj.gridResolution=null;obj.backBuffer=null;obj.backBufferTimerId=null;obj.tileQueue=[];obj.tileQueueId=null;obj.loading=false;obj.moveTimerId=null;return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();var resolution=this.map.getResolution();var serverResolution=this.getServerResolution(resolution);if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){if(zoomChanged&&this.transitionEffect!=='resize'){this.removeBackBuffer();}
-if(!zoomChanged||this.transitionEffect==='resize'){this.applyBackBuffer(serverResolution);}
-this.initSingleTile(bounds);}}else{forceReTile=forceReTile||!tilesBounds.intersectsBounds(bounds,{worldBounds:this.map.baseLayer.wrapDateLine&&this.map.getMaxExtent()});if(resolution!==serverResolution){bounds=this.map.calculateBounds(null,serverResolution);if(forceReTile){var scale=serverResolution/resolution;this.transformDiv(scale);}}else{this.div.style.width='100%';this.div.style.height='100%';this.div.style.left='0%';this.div.style.top='0%';}
-if(forceReTile){if(zoomChanged&&this.transitionEffect==='resize'){this.applyBackBuffer(serverResolution);}
+obj.grid=[];obj.gridResolution=null;obj.backBuffer=null;obj.backBufferTimerId=null;obj.loading=false;obj.numLoadingTiles=0;return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();var resolution=this.map.getResolution();var serverResolution=this.getServerResolution(resolution);if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){if(zoomChanged&&this.transitionEffect!=='resize'){this.removeBackBuffer();}
+if(!zoomChanged||this.transitionEffect==='resize'){this.applyBackBuffer(resolution);}
+this.initSingleTile(bounds);}}else{forceReTile=forceReTile||!tilesBounds.intersectsBounds(bounds,{worldBounds:this.map.baseLayer.wrapDateLine&&this.map.getMaxExtent()});if(forceReTile){if(zoomChanged&&(this.transitionEffect==='resize'||this.gridResolution===resolution)){this.applyBackBuffer(resolution);}
this.initGriddedTiles(bounds);}else{this.moveGriddedTiles();}}}},getTileData:function(loc){var data=null,x=loc.lon,y=loc.lat,numRows=this.grid.length;if(this.map&&numRows){var res=this.map.getResolution(),tileWidth=this.tileSize.w,tileHeight=this.tileSize.h,bounds=this.grid[0][0].bounds,left=bounds.left,top=bounds.top;if(x<left){if(this.map.baseLayer.wrapDateLine){var worldWidth=this.map.getMaxExtent().getWidth();var worldsAway=Math.ceil((left-x)/worldWidth);x+=worldWidth*worldsAway;}}
var dtx=(x-left)/(res*tileWidth);var dty=(top-y)/(res*tileHeight);var col=Math.floor(dtx);var row=Math.floor(dty);if(row>=0&&row<numRows){var tile=this.grid[row][col];if(tile){data={tile:tile,i:Math.floor((dtx-col)*tileWidth),j:Math.floor((dty-row)*tileHeight)};}}}
-return data;},queueTileDraw:function(evt){var tile=evt.object;if(!~OpenLayers.Util.indexOf(this.tileQueue,tile)){this.tileQueue.push(tile);}
-if(!this.tileQueueId){this.tileQueueId=OpenLayers.Animation.start(OpenLayers.Function.bind(this.drawTileFromQueue,this),null,this.div);}
-return false;},drawTileFromQueue:function(){if(this.tileQueue.length===0){this.clearTileQueue();}else{this.tileQueue.shift().draw(true);}},clearTileQueue:function(){OpenLayers.Animation.stop(this.tileQueueId);this.tileQueueId=null;this.tileQueue=[];},destroyTile:function(tile){this.removeTileMonitoringHooks(tile);tile.destroy();},getServerResolution:function(resolution){resolution=resolution||this.map.getResolution();if(this.serverResolutions&&OpenLayers.Util.indexOf(this.serverResolutions,resolution)===-1){var i,serverResolution;for(i=this.serverResolutions.length-1;i>=0;i--){serverResolution=this.serverResolutions[i];if(serverResolution>resolution){resolution=serverResolution;break;}}
-if(i===-1){throw'no appropriate resolution in serverResolutions';}}
-return resolution;},getServerZoom:function(){var resolution=this.getServerResolution();return this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,resolution):this.map.getZoomForResolution(resolution)+(this.zoomOffset||0);},transformDiv:function(scale){this.div.style.width=100*scale+'%';this.div.style.height=100*scale+'%';var size=this.map.getSize();var lcX=parseInt(this.map.layerContainerDiv.style.left,10);var lcY=parseInt(this.map.layerContainerDiv.style.top,10);var x=(lcX-(size.w/2.0))*(scale-1);var y=(lcY-(size.h/2.0))*(scale-1);this.div.style.left=x+'%';this.div.style.top=y+'%';},getResolutionScale:function(){return parseInt(this.div.style.width,10)/100;},applyBackBuffer:function(resolution){if(this.backBufferTimerId!==null){this.removeBackBuffer();}
+return data;},destroyTile:function(tile){this.removeTileMonitoringHooks(tile);tile.destroy();},getServerResolution:function(resolution){var distance=Number.POSITIVE_INFINITY;resolution=resolution||this.map.getResolution();if(this.serverResolutions&&OpenLayers.Util.indexOf(this.serverResolutions,resolution)===-1){var i,newDistance,newResolution,serverResolution;for(i=this.serverResolutions.length-1;i>=0;i--){newResolution=this.serverResolutions[i];newDistance=Math.abs(newResolution-resolution);if(newDistance>distance){break;}
+distance=newDistance;serverResolution=newResolution;}
+resolution=serverResolution;}
+return resolution;},getServerZoom:function(){var resolution=this.getServerResolution();return this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,resolution):this.map.getZoomForResolution(resolution)+(this.zoomOffset||0);},applyBackBuffer:function(resolution){if(this.backBufferTimerId!==null){this.removeBackBuffer();}
var backBuffer=this.backBuffer;if(!backBuffer){backBuffer=this.createBackBuffer();if(!backBuffer){return;}
-this.div.insertBefore(backBuffer,this.div.firstChild);this.backBuffer=backBuffer;var topLeftTileBounds=this.grid[0][0].bounds;this.backBufferLonLat={lon:topLeftTileBounds.left,lat:topLeftTileBounds.top};this.backBufferResolution=this.gridResolution;}
-var style=backBuffer.style;var ratio=this.backBufferResolution/resolution;style.width=100*ratio+'%';style.height=100*ratio+'%';var position=this.getViewPortPxFromLonLat(this.backBufferLonLat,resolution);var leftOffset=parseInt(this.map.layerContainerDiv.style.left,10);var topOffset=parseInt(this.map.layerContainerDiv.style.top,10);backBuffer.style.left=Math.round(position.x-leftOffset)+'%';backBuffer.style.top=Math.round(position.y-topOffset)+'%';},createBackBuffer:function(){var backBuffer;if(this.grid.length>0){backBuffer=document.createElement('div');backBuffer.id=this.div.id+'_bb';backBuffer.className='olBackBuffer';backBuffer.style.position='absolute';backBuffer.style.width='100%';backBuffer.style.height='100%';for(var i=0,lenI=this.grid.length;i<lenI;i++){for(var j=0,lenJ=this.grid[i].length;j<lenJ;j++){var tile=this.grid[i][j].createBackBuffer();if(!tile){continue;}
-tile.style.top=(i*this.tileSize.h)+'%';tile.style.left=(j*this.tileSize.w)+'%';backBuffer.appendChild(tile);}}}
-return backBuffer;},removeBackBuffer:function(){if(this.backBuffer){this.div.removeChild(this.backBuffer);this.backBuffer=null;this.backBufferResolution=null;if(this.backBufferTimerId!==null){window.clearTimeout(this.backBufferTimerId);this.backBufferTimerId=null;}}},moveByPx:function(dx,dy){if(!this.singleTile){this.moveGriddedTiles();}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
+if(resolution===this.gridResolution){this.div.insertBefore(backBuffer,this.div.firstChild);}else{this.map.baseLayer.div.parentNode.insertBefore(backBuffer,this.map.baseLayer.div);}
+this.backBuffer=backBuffer;var topLeftTileBounds=this.grid[0][0].bounds;this.backBufferLonLat={lon:topLeftTileBounds.left,lat:topLeftTileBounds.top};this.backBufferResolution=this.gridResolution;}
+var ratio=this.backBufferResolution/resolution;var tiles=backBuffer.childNodes,tile;for(var i=tiles.length-1;i>=0;--i){tile=tiles[i];tile.style.top=((ratio*tile._i*tile._h)|0)+'px';tile.style.left=((ratio*tile._j*tile._w)|0)+'px';tile.style.width=Math.round(ratio*tile._w)+'px';tile.style.height=Math.round(ratio*tile._h)+'px';}
+var position=this.getViewPortPxFromLonLat(this.backBufferLonLat,resolution);var leftOffset=this.map.layerContainerOriginPx.x;var topOffset=this.map.layerContainerOriginPx.y;backBuffer.style.left=Math.round(position.x-leftOffset)+'px';backBuffer.style.top=Math.round(position.y-topOffset)+'px';},createBackBuffer:function(){var backBuffer;if(this.grid.length>0){backBuffer=document.createElement('div');backBuffer.id=this.div.id+'_bb';backBuffer.className='olBackBuffer';backBuffer.style.position='absolute';var map=this.map;backBuffer.style.zIndex=this.transitionEffect==='resize'?this.getZIndex()-1:map.Z_INDEX_BASE.BaseLayer-
+(map.getNumLayers()-map.getLayerIndex(this));for(var i=0,lenI=this.grid.length;i<lenI;i++){for(var j=0,lenJ=this.grid[i].length;j<lenJ;j++){var tile=this.grid[i][j],markup=this.grid[i][j].createBackBuffer();if(markup){markup._i=i;markup._j=j;markup._w=tile.size.w;markup._h=tile.size.h;markup.id=tile.id+'_bb';backBuffer.appendChild(markup);}}}}
+return backBuffer;},removeBackBuffer:function(){if(this._transitionElement){for(var i=this.transitionendEvents.length-1;i>=0;--i){OpenLayers.Event.stopObserving(this._transitionElement,this.transitionendEvents[i],this._removeBackBuffer);}
+delete this._transitionElement;}
+if(this.backBuffer){if(this.backBuffer.parentNode){this.backBuffer.parentNode.removeChild(this.backBuffer);}
+this.backBuffer=null;this.backBufferResolution=null;if(this.backBufferTimerId!==null){window.clearTimeout(this.backBufferTimerId);this.backBufferTimerId=null;}}},moveByPx:function(dx,dy){if(!this.singleTile){this.moveGriddedTiles();}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio,10);size.w=parseInt(size.w*this.ratio,10);}
OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getTilesBounds:function(){var bounds=null;var length=this.grid.length;if(length){var bottomLeftTileBounds=this.grid[length-1][0].bounds,width=this.grid[0].length*bottomLeftTileBounds.getWidth(),height=this.grid.length*bottomLeftTileBounds.getHeight();bounds=new OpenLayers.Bounds(bottomLeftTileBounds.left,bottomLeftTileBounds.bottom,bottomLeftTileBounds.left+width,bottomLeftTileBounds.bottom+height);}
-return bounds;},initSingleTile:function(bounds){this.clearTileQueue();var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var px=this.map.getLayerPxFromLonLat({lon:tileBounds.left,lat:tileBounds.top});if(!this.grid.length){this.grid[0]=[];}
+return bounds;},initSingleTile:function(bounds){this.events.triggerEvent("retile");var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var px=this.map.getLayerPxFromLonLat({lon:tileBounds.left,lat:tileBounds.top});if(!this.grid.length){this.grid[0]=[];}
var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
-this.removeExcessTiles(1,1);this.gridResolution=this.getServerResolution();},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=bounds.top-(origin.lat+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},getTileOrigin:function(){var origin=this.tileOrigin;if(!origin){var extent=this.getMaxExtent();var edges=({"tl":["left","top"],"tr":["right","top"],"bl":["left","bottom"],
"br":["right","bottom"]})[this.tileOriginCorner];origin=new OpenLayers.LonLat(extent[edges[0]],extent[edges[1]]);}
-return origin;},initGriddedTiles:function(bounds){this.clearTileQueue();var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
-Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
-Math.max(1,2*this.buffer);var origin=this.getTileOrigin();var resolution=this.getServerResolution();var tileLayout=this.calculateGridLayout(bounds,origin,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);var tileData=[],center=this.map.getCenter();do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
-tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
+this.removeExcessTiles(1,1);this.gridResolution=this.getServerResolution();},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var rowSign=this.rowSign;var offsetlat=rowSign*(origin.lat-bounds.top+tilelat);var tilerow=Math[~rowSign?'floor':'ceil'](offsetlat/tilelat)-this.buffer*rowSign;return{tilelon:tilelon,tilelat:tilelat,startcol:tilecol,startrow:tilerow};},getTileOrigin:function(){var origin=this.tileOrigin;if(!origin){var extent=this.getMaxExtent();var edges=({"tl":["left","top"],"tr":["right","top"],"bl":["left","bottom"],"br":["right","bottom"]})[this.tileOriginCorner];origin=new OpenLayers.LonLat(extent[edges[0]],extent[edges[1]]);}
+return origin;},getTileBoundsForGridIndex:function(row,col){var origin=this.getTileOrigin();var tileLayout=this.gridLayout;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;var startcol=tileLayout.startcol;var startrow=tileLayout.startrow;var rowSign=this.rowSign;return new OpenLayers.Bounds(origin.lon+(startcol+col)*tilelon,origin.lat-(startrow+row*rowSign)*tilelat*rowSign,origin.lon+(startcol+col+1)*tilelon,origin.lat-(startrow+(row-1)*rowSign)*tilelat*rowSign);},initGriddedTiles:function(bounds){this.events.triggerEvent("retile");var viewSize=this.map.getSize();var origin=this.getTileOrigin();var resolution=this.map.getResolution(),serverResolution=this.getServerResolution(),ratio=resolution/serverResolution,tileSize={w:this.tileSize.w/ratio,h:this.tileSize.h/ratio};var minRows=Math.ceil(viewSize.h/tileSize.h)+
+2*this.buffer+1;var minCols=Math.ceil(viewSize.w/tileSize.w)+
+2*this.buffer+1;var tileLayout=this.calculateGridLayout(bounds,origin,serverResolution);this.gridLayout=tileLayout;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;var layerContainerDivLeft=this.map.layerContainerOriginPx.x;var layerContainerDivTop=this.map.layerContainerOriginPx.y;var tileBounds=this.getTileBoundsForGridIndex(0,0);var startPx=this.map.getViewPortPxFromLonLat(new OpenLayers.LonLat(tileBounds.left,tileBounds.top));startPx.x=Math.round(startPx.x)-layerContainerDivLeft;startPx.y=Math.round(startPx.y)-layerContainerDivTop;var tileData=[],center=this.map.getCenter();var rowidx=0;do{var row=this.grid[rowidx];if(!row){row=[];this.grid.push(row);}
+var colidx=0;do{tileBounds=this.getTileBoundsForGridIndex(rowidx,colidx);var px=startPx.clone();px.x=px.x+colidx*Math.round(tileSize.w);px.y=px.y+rowidx*Math.round(tileSize.h);var tile=row[colidx];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
var tileCenter=tileBounds.getCenterLonLat();tileData.push({tile:tile,distance:Math.pow(tileCenter.lon-center.lon,2)+
-Math.pow(tileCenter.lat-center.lat,2)});tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols);tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows);this.removeExcessTiles(rowidx,colidx);this.gridResolution=this.getServerResolution();tileData.sort(function(a,b){return a.distance-b.distance;});for(var i=0,ii=tileData.length;i<ii;++i){tileData[i].tile.draw();}},getMaxExtent:function(){return this.maxExtent;},addTile:function(bounds,position){var tile=new this.tileClass(this,position,bounds,null,this.tileSize,this.tileOptions);tile.events.register("beforedraw",this,this.queueTileDraw);return tile;},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.loading===false){this.loading=true;this.events.triggerEvent("loadstart");}
-this.events.triggerEvent("tileloadstart",{tile:tile});this.numLoadingTiles++;};tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded",{tile:tile});if(this.tileQueue.length===0&&this.numLoadingTiles===0){this.loading=false;this.events.triggerEvent("loadend");if(this.backBuffer){this.backBufferTimerId=window.setTimeout(OpenLayers.Function.bind(this.removeBackBuffer,this),this.removeBackBufferDelay);}}};tile.onLoadError=function(){this.events.triggerEvent("tileerror",{tile:tile});};tile.events.on({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,"loaderror":tile.onLoadError,scope:this});},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,"loaderror":tile.onLoadError,scope:this});},moveGriddedTiles:function(deferred){if(!deferred&&!OpenLayers.Animation.isNative){if(this.moveTimerId!=null){window.clearTimeout(this.moveTime
rId);}
-this.moveTimerId=window.setTimeout(this.deferMoveGriddedTiles,this.tileLoadingDelay);return;}
-var buffer=this.buffer||1;var scale=this.getResolutionScale();while(true){var tlViewPort={x:(this.grid[0][0].position.x*scale)+
-parseInt(this.div.style.left,10)+
-parseInt(this.map.layerContainerDiv.style.left),y:(this.grid[0][0].position.y*scale)+
-parseInt(this.div.style.top,10)+
-parseInt(this.map.layerContainerDiv.style.top)};var tileSize={w:this.tileSize.w*scale,h:this.tileSize.h*scale};if(tlViewPort.x>-tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-tileSize.h*buffer){this.shiftRow(false);}else{break;}}},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.getServerResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0,len=modelRow.length;i<len;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
-if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.getServerResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){var i,l;while(this.grid.length>rows){var row=this.grid.pop();for(i=0,l=row.length;i<l;i++){var tile=row[i];this.destroyTile(tile);}}
+Math.pow(tileCenter.lat-center.lat,2)});colidx+=1;}while((tileBounds.right<=bounds.right+tilelon*this.buffer)||colidx<minCols);rowidx+=1;}while((tileBounds.bottom>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows);this.removeExcessTiles(rowidx,colidx);var resolution=this.getServerResolution();this.gridResolution=resolution;tileData.sort(function(a,b){return a.distance-b.distance;});for(var i=0,ii=tileData.length;i<ii;++i){tileData[i].tile.draw();}},getMaxExtent:function(){return this.maxExtent;},addTile:function(bounds,position){var tile=new this.tileClass(this,position,bounds,null,this.tileSize,this.tileOptions);this.events.triggerEvent("addtile",{tile:tile});return tile;},addTileMonitoringHooks:function(tile){var replacingCls='olTileReplacing';tile.onLoadStart=function(){if(this.loading===false){this.loading=true;this.events.triggerEvent("loadstart");}
+this.events.triggerEvent("tileloadstart",{tile:tile});this.numLoadingTiles++;if(!this.singleTile&&this.backBuffer&&this.gridResolution===this.backBufferResolution){OpenLayers.Element.addClass(tile.getTile(),replacingCls);}};tile.onLoadEnd=function(evt){this.numLoadingTiles--;var aborted=evt.type==='unload';this.events.triggerEvent("tileloaded",{tile:tile,aborted:aborted});if(!this.singleTile&&!aborted&&this.backBuffer&&this.gridResolution===this.backBufferResolution){var tileDiv=tile.getTile();if(OpenLayers.Element.getStyle(tileDiv,'display')==='none'){var bufferTile=document.getElementById(tile.id+'_bb');if(bufferTile){bufferTile.parentNode.removeChild(bufferTile);}}
+OpenLayers.Element.removeClass(tileDiv,replacingCls);}
+if(this.numLoadingTiles===0){if(this.backBuffer){if(this.backBuffer.childNodes.length===0){this.removeBackBuffer();}else{this._transitionElement=aborted?this.div.lastChild:tile.imgDiv;var transitionendEvents=this.transitionendEvents;for(var i=transitionendEvents.length-1;i>=0;--i){OpenLayers.Event.observe(this._transitionElement,transitionendEvents[i],this._removeBackBuffer);}
+this.backBufferTimerId=window.setTimeout(this._removeBackBuffer,this.removeBackBufferDelay);}}
+this.loading=false;this.events.triggerEvent("loadend");}};tile.onLoadError=function(){this.events.triggerEvent("tileerror",{tile:tile});};tile.events.on({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,"loaderror":tile.onLoadError,scope:this});},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,"loaderror":tile.onLoadError,scope:this});},moveGriddedTiles:function(){var buffer=this.buffer+1;while(true){var tlTile=this.grid[0][0];var tlViewPort={x:tlTile.position.x+
+this.map.layerContainerOriginPx.x,y:tlTile.position.y+
+this.map.layerContainerOriginPx.y};var ratio=this.getServerResolution()/this.map.getResolution();var tileSize={w:Math.round(this.tileSize.w*ratio),h:Math.round(this.tileSize.h*ratio)};if(tlViewPort.x>-tileSize.w*(buffer-1)){this.shiftColumn(true,tileSize);}else if(tlViewPort.x<-tileSize.w*buffer){this.shiftColumn(false,tileSize);}else if(tlViewPort.y>-tileSize.h*(buffer-1)){this.shiftRow(true,tileSize);}else if(tlViewPort.y<-tileSize.h*buffer){this.shiftRow(false,tileSize);}else{break;}}},shiftRow:function(prepend,tileSize){var grid=this.grid;var rowIndex=prepend?0:(grid.length-1);var sign=prepend?-1:1;var rowSign=this.rowSign;var tileLayout=this.gridLayout;tileLayout.startrow+=sign*rowSign;var modelRow=grid[rowIndex];var row=grid[prepend?'pop':'shift']();for(var i=0,len=row.length;i<len;i++){var tile=row[i];var position=modelRow[i].position.clone();position.y+=tileSize.h*sign;tile.moveTo(this.getTileBoundsForGridIndex(rowIndex,i),position);}
+grid[prepend?'unshift':'push'](row);},shiftColumn:function(prepend,tileSize){var grid=this.grid;var colIndex=prepend?0:(grid[0].length-1);var sign=prepend?-1:1;var tileLayout=this.gridLayout;tileLayout.startcol+=sign;for(var i=0,len=grid.length;i<len;i++){var row=grid[i];var position=row[colIndex].position.clone();var tile=row[prepend?'pop':'shift']();position.x+=tileSize.w*sign;tile.moveTo(this.getTileBoundsForGridIndex(i,colIndex),position);row[prepend?'unshift':'push'](tile);}},removeExcessTiles:function(rows,columns){var i,l;while(this.grid.length>rows){var row=this.grid.pop();for(i=0,l=row.length;i<l;i++){var tile=row[i];this.destroyTile(tile);}}
for(i=0,l=this.grid.length;i<l;i++){while(this.grid[i].length>columns){var row=this.grid[i];var tile=row.pop();this.destroyTile(tile);}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
-return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,data:null,reqFeatures:null,priv:null,error:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,han
dler:null,eventListeners:null,events:null,initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();this.events=null;}
-this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
-if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
-this.handlers=null;}
-if(this.map){this.map.removeControl(this);this.map=null;}
-this.div=null;},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
-if(this.title!=""){this.div.title=this.title;}}
-if(px!=null){this.position=px.clone();}
-this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
-if(this.handler){this.handler.activate();}
-this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
-this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("deactivate");return true;}
-return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",template:"${layers}",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&
layer.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
-this.div.innerHTML=OpenLayers.String.format(this.template,{layers:attributions.join(this.separator)});}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:false,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},destroy:function(){},read:function(data){throw new Error('Read not implemented.');},write:function(object){throw new Error('Write not implemented.');},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:" ",space:" ",newline:"\n",level:0,pretty:false,nativeJSON:(function(){return!!(window.JSON&&typeof JSON.parse=="function"&&typeof JSON.stringify=="function");})(),read:function(json,filter){var object;if(this.nativeJSON){object=JSON.parse(json,filter);}else try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\
d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
-return filter(k,v);}
-object=walk('',object);}}}catch(e){}
-if(this.keepData){this.data=object;}
-return object;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){try{json=(!this.pretty&&this.nativeJSON)?JSON.stringify(value):this.serialize[type].apply(this,[value]);}catch(err){OpenLayers.Console.error("Trouble serializing: "+err);}}
-return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
-return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
-if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
-if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
-var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0,len=array.length;i<len;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),json);}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
-c=b.charCodeAt();return'\\u00'+
-Math.floor(c/16).toString(16)+
-(c%16).toString(16);})+'"';}
-return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
-return'"'+date.getFullYear()+'-'+
-format(date.getMonth()+1)+'-'+
-format(date.getDate())+'T'+
-format(date.getHours())+':'+
-format(date.getMinutes())+':'+
-format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Kinetic=OpenLayers.Class({threshold:0,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){OpenLayers.Animation.stop(this.timerId);this.timerId=undefined;this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>this.nbPoints){this.points.pop();}},end:function(xy){var last,now=new Date().getTime();for(var i=0,l=this.points.length,point;i<l;i++){point=this.points[i];if(now-point.tick>this.delay){break;}
-last=point;}
-if(!last){return;}
-var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
-Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
-var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
-return{speed:speed,theta:theta};},move:function(info,callback){var v0=info.speed;var fx=Math.cos(info.theta);var fy=-Math.sin(info.theta);var initialTime=new Date().getTime();var lastX=0;var lastY=0;var timerCallback=function(){if(this.timerId==null){return;}
-var t=new Date().getTime()-initialTime;var p=(-this.deceleration*Math.pow(t,2))/2.0+v0*t;var x=p*fx;var y=p*fy;var args={};args.end=false;var v=-this.deceleration*t+v0;if(v<=0){OpenLayers.Animation.stop(this.timerId);this.timerId=null;args.end=true;}
-args.x=x-lastX;args.y=y-lastY;lastX=x;lastY=y;callback(args.x,args.y,args.end);};this.timerId=OpenLayers.Animation.start(OpenLayers.Function.bind(timerCallback,this));},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-if(typeof this.context=="function"){context=this.context(feature);}
-return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
-options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
-var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
-this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(evt){if(!this.touch){this.unregist
erMouseListeners();this.touch=true;}
-this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
-return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
-return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
-return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
-this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this.passesDblclickTolerance(evt)){if(this["double"]){this.callback("dblclick",[evt]);}
-this.clearTimer();}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.stop(evt);}
-this.handleDouble(evt);}
-if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
-return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
-Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
-if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.clientX,clientY:touch.clientY};}}
-return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;this.touch=false;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,touch:false,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this
.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
-document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-return propagate;},dragmove:function(evt){this.lastMoveEvt=evt;if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
-if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
-this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
-this.last=evt.xy;}
-return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
-var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
-document.onselectstart=this.oldOnselectstart;}
-return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,scope:this});}
-return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;if(this.dragging){this.mousemove(this.lastMoveEvt);}},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
-if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
-return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.touch=false;this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
-return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null},'touchstart':{'in':'click','out':'clickout'}},feature:null,lastFeature:n
ull,down:null,up:null,touch:false,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
-return OpenLayers.Event.isMultiTouch(evt)?true:this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.stop(evt);},mousedown:function(evt){if(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt)){this.down=evt.xy;}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.getServerResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.getServerZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
+return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
+return false;},deactivate:function(){if(this.active){this.active=false;return true;}
+return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:false,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.layer.events.on({"refresh":this.load,scope:this});if(this.layer.visibility==true||this.preload){this.load();}else{this.layer.events.on({"visibilitychanged":this.load,scope:this});}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"refresh":this.load,"visibilitychanged":this.load,scope:this});}
+return deactivated;},load:function(options){var layer=this.layer;layer.events.triggerEvent("loadstart",{filter:layer.filter});layer.protocol.read(OpenLayers.Util.applyDefaults({callback:this.merge,filter:layer.filter,scope:this},options));layer.events.un({"visibilitychanged":this.load,scope:this});},merge:function(resp){var layer=this.layer;layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=layer.projection;var local=layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
+layer.addFeatures(features);}
+layer.events.triggerEvent("loadend",{response:resp});},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Control.Zoom=OpenLayers.Class(OpenLayers.Control,{zoomInText:"+",zoomInId:"olZoomInLink",zoomOutText:"\u2212",zoomOutId:"olZoomOutLink",draw:function(){var div=OpenLayers.Control.prototype.draw.apply(this),links=this.getOrCreateLinks(div),zoomIn=links.zoomIn,zoomOut=links.zoomOut,eventsInstance=this.map.events;if(zoomOut.parentNode!==div){eventsInstance=this.events;eventsInstance.attachToElement(zoomOut.parentNode);}
+eventsInstance.register("buttonclick",this,this.onZoomClick);this.zoomInLink=zoomIn;this.zoomOutLink=zoomOut;return div;},getOrCreateLinks:function(el){var zoomIn=document.getElementById(this.zoomInId),zoomOut=document.getElementById(this.zoomOutId);if(!zoomIn){zoomIn=document.createElement("a");zoomIn.href="#zoomIn";zoomIn.appendChild(document.createTextNode(this.zoomInText));zoomIn.className="olControlZoomIn";el.appendChild(zoomIn);}
+OpenLayers.Element.addClass(zoomIn,"olButton");if(!zoomOut){zoomOut=document.createElement("a");zoomOut.href="#zoomOut";zoomOut.appendChild(document.createTextNode(this.zoomOutText));zoomOut.className="olControlZoomOut";el.appendChild(zoomOut);}
+OpenLayers.Element.addClass(zoomOut,"olButton");return{zoomIn:zoomIn,zoomOut:zoomOut};},onZoomClick:function(evt){var button=evt.buttonElement;if(button===this.zoomInLink){this.map.zoomIn();}else if(button===this.zoomOutLink){this.map.zoomOut();}},destroy:function(){if(this.map){this.map.events.unregister("buttonclick",this,this.onZoomClick);}
+delete this.zoomInLink;delete this.zoomOutLink;OpenLayers.Control.prototype.destroy.apply(this);},CLASS_NAME:"OpenLayers.Control.Zoom"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
+if(this.layer!=null&&this.marker!=null){this.layer.removeMarker(this.marker);}
+this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
+if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
+return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){if(!this.popup){var anchor=(this.marker)?this.marker.icon:null;var popupClass=this.popupClass?this.popupClass:OpenLayers.Popup.Anchored;this.popup=new popupClass(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
+if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
+this.popup.feature=this;}
+return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
+this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
+this.geometry=null;this.modified=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
+return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
+return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
+var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
+var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",str
okeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},'delete':{display:"none"}};OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
+this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
+this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
+if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
+if(rules.length>0&&appliedRules==false){style.display="none";}
+if(style.label!=null&&typeof style.label!=="string"){style.label=String(style.label);}
+return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
+if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
+if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
+return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
+return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
+return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
+return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
+options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
+return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},toString:function(){var string;if(OpenLayers.Format&&OpenLayers.Format.CQL){string=OpenLayers.Format.CQL.prototype.write(this);}else{string=Object.prototype.toString.call(this);}
+return string;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
+if(feature.geometry.intersects(geom)){intersect=true;}}
+break;default:throw new Error('evaluate is not implemented for this filter type.');}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"moveend":this.update,"refresh":this.update,"visibilitychanged":this.update,scope:this});this.update();}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"moveend":this.update,"refresh":this.update,"visibilitychanged":this.update,scope:this});}
+return deactivated;},update:function(options){var mapBounds=this.getMapBounds();if(mapBounds!==null&&((options&&options.force)||(this.layer.visibility&&this.layer.calculateInRange()&&this.invalidBounds(mapBounds)))){this.calculateBounds(mapBounds);this.resolution=this.layer.map.getResolution();this.triggerRead(options);}},getMapBounds:function(){if(this.layer.map===null){return null;}
+var bounds=this.layer.map.getExtent();if(bounds&&!this.layer.projection.equals(this.layer.map.getProjectionObject())){bounds=bounds.clone().transform(this.layer.map.getProjectionObject(),this.layer.projection);}
+return bounds;},invalidBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
+var invalid=!this.bounds||!this.bounds.containsBounds(mapBounds);if(!invalid&&this.resFactor){var ratio=this.resolution/this.layer.map.getResolution();invalid=(ratio>=this.resFactor||ratio<=(1/this.resFactor));}
+return invalid;},calculateBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
+var center=mapBounds.getCenterLonLat();var dataWidth=mapBounds.getWidth()*this.ratio;var dataHeight=mapBounds.getHeight()*this.ratio;this.bounds=new OpenLayers.Bounds(center.lon-(dataWidth/2),center.lat-(dataHeight/2),center.lon+(dataWidth/2),center.lat+(dataHeight/2));},triggerRead:function(options){if(this.response&&!(options&&options.noAbort===true)){this.layer.protocol.abort(this.response);this.layer.events.triggerEvent("loadend");}
+var evt={filter:this.createFilter()};this.layer.events.triggerEvent("loadstart",evt);this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:evt.filter,callback:this.merge,scope:this},options));},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
+return filter;},merge:function(resp){this.layer.destroyFeatures();if(resp.success()){var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
+this.layer.addFeatures(features);}}else{this.bounds=null;}
+this.response=null;this.layer.events.triggerEvent("loadend",{response:resp});},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null},'touchstart':{'in':'click','out':'clickout'}},feature:null,lastFeature:null,down:null,up:null,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},touchstart:function(evt){this.startTouch();return OpenLayers.Event.isMultiTouch(evt)?true:this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.preventDefault(evt);},mousedown:function(evt){if(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt)){this.down=ev
t.xy;}
return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick"||type=="touchstart");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
-if(this.feature){if(type==="touchstart"){OpenLayers.Event.stop(evt);}
+if(this.feature){if(type==="touchstart"){OpenLayers.Event.preventDefault(evt);}
var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
+this.feature=null;}}else if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.touch=false;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
-return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={d
rag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(this.handlers.feature.touch&&!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.handlers.feature.touch&&this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,ar
guments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
-return activated;},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},
CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',{x:-9999,y:-9999});this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenL
ayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
-return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
-return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,keyMask:null,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel({x:position.left,y:position.bottom});var maxXY=this.map.getLonLatFromPixel({x:position.right,y:position.top});bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent
.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:1,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
-this.kinetic=new OpenLayers.Kinetic(config);}
-this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
-this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
-this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
-this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
-var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
-overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
-if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
-overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
-if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
-OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
-if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Con
trol,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;if(this.pinchZoom){this.pinchZoom.destroy();}
-this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
-if(this.pinchZoom){this.pinchZoom.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
-this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
-var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(
newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,citeCompliant:false,mouseD
own:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-this.cancel();if(this.layer.map!=null){this.destroyFeature(true);this.layer.destroy(false);}
-this.layer=null;this.touch=false;return true;},destroyFeature:function(force){if(this.layer&&(force||!this.persist)){this.layer.destroyFeatures();}
-this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel){var key=cancel?"cancel":"done";this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);this.destroyFeature(cancel);},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){if(!this.point){this.createFeature(pixel);}
-var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
-return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
-this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
-this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
-return true;},up:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
-if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
-if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
-if(this.persist){this.destroyPersistedFeature();}
-this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
-return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Events.buttonclick=OpenLayers.Class({target:null,events:['mousedown','mouseup','click','dblclick','touchstart','touchmove','touchend','keydown'],startRegEx:/^mousedown|touchstart$/,cancelRegEx:/^touchmove$/,completeRegEx:/^mouseup|touchend$/,initialize:function(target){this.target=target;for(var i=this.events.length-1;i>=0;--i){this.target.register(this.events[i],this,this.buttonClick,{extension:true});}},destroy:function(){for(var i=this.events.length-1;i>=0;--i){this.target.unregister(this.events[i],this,this.buttonClick);}
-delete this.target;},getPressedButton:function(element){var depth=3,button;do{if(OpenLayers.Element.hasClass(element,"olButton")){button=element;break;}
-element=element.parentNode;}while(--depth>0&&element);return button;},buttonClick:function(evt){var propagate=true,element=OpenLayers.Event.element(evt);if(element&&(OpenLayers.Event.isLeftClick(evt)||!~evt.type.indexOf("mouse"))){var button=this.getPressedButton(element);if(button){if(evt.type==="keydown"){switch(evt.keyCode){case OpenLayers.Event.KEY_RETURN:case OpenLayers.Event.KEY_SPACE:this.target.triggerEvent("buttonclick",{buttonElement:button});OpenLayers.Event.stop(evt);propagate=false;break;}}else if(this.startEvt){if(this.completeRegEx.test(evt.type)){var pos=OpenLayers.Util.pagePosition(button);this.target.triggerEvent("buttonclick",{buttonElement:button,buttonXY:{x:this.startEvt.clientX-pos[0],y:this.startEvt.clientY-pos[1]}});}
-if(this.cancelRegEx.test(evt.type)){delete this.startEvt;}
-OpenLayers.Event.stop(evt);propagate=false;}
-if(this.startRegEx.test(evt.type)){this.startEvt=evt;OpenLayers.Event.stop(evt);propagate=false;}}else{delete this.startEvt;}}
-return propagate;}});OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:false,pinching:false,last:null,start:null,touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-OpenLayers.Event.stop(evt);return propagate;},touchmove:function(evt){if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;OpenLayers.Event.stop(evt);}
-return true;},touchend:function(evt){if(this.started){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;}
-return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.clientX-t1.clientX,2)+
-Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerCenter:null,pinchOrigin:null,currentCenter:null,autoActivate:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerCenter,scope:this});this.updateContainerCenter();}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.apply(this,arguments);if(this.map&&this.map.events){this.map.events.un({moveend:this.updateContainerCenter,scope:this});}
-return deactivated;},updateContainerCenter:function(){var container=this.map.layerContainerDiv;this.containerCenter={x:parseInt(container.style.left,10)+50,y:parseInt(container.style.top,10)+50};},pinchStart:function(evt,pinchData){this.pinchOrigin=evt.xy;this.currentCenter=evt.xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerCenter=this.containerCenter;var pinchOrigin=this.pinchOrigin;var current=evt.xy;var dx=Math.round((current.x-pinchOrigin.x)+(scale-1)*(containerCenter.x-pinchOrigin.x));var dy=Math.round((current.y-pinchOrigin.y)+(scale-1)*(containerCenter.y-pinchOrigin.y));this.applyTransform("translate("+dx+"px, "+dy+"px) scale("+scale+")");this.currentCenter=current;},applyTransform:function(transform){var style=this.map.layerContainerDiv.style;style['-webkit-transform']=transform;style['-moz-transform']=transform;},pinchDone:function(evt,start,last){this.applyTransform("");var zoom=this.map.getZoomForResolution(this.map.getResolution()/l
ast.scale,true);if(zoom!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.div.clientWidth=this.map.div.clientWidth;this.map.setCenter(location,zoom);}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.pinchZoom){this.pinchZoom.destroy();delete this.pinchZoom;}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();this.pinchZoom.activate();return true;}
-return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();this.pinchZoom.deactivate();return true;}
-return false;},draw:function(){var clickCallbacks={click:this.defaultClick,dblclick:this.defaultDblClick};var clickOptions=OpenLayers.Util.extend({"double":true,stopDouble:true,pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",forma
t:"image/jpeg"},isBaseLayer:true,encodeBBOX:false,noMagic:false,yx:{},initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);if(parseFloat(params.VERSION)>=1.3&&!params.EXCEPTIONS){params.EXCEPTIONS="INIMAGE";}
-newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){var projCode=this.projection.getCode();return parseFloat(this.params.VERSION)>=1.3&&!!(this.yx[projCode]||OpenLayers.Projection.defaults[projCode].yx);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=this.map.getProjectionObject();var projectionCode=this.projection&&this.pr
ojection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=value;}else{this.params.SRS=value;}
-if(typeof this.params.TRANSPARENT=="boolean"){newParams.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";}
-return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,featureDx:0,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var ratio=extent.getWidth()/this.map.getExtent().getWidth(),extent=extent.scale(1/ratio);this.extent=extent.wrapDateLine(this.map.getMaxExtent()).scale(ratio);}
-if(resolutionChanged){this.resolution=null;}
-return true;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
-if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMaxExtent();}
-if(!bounds.intersectsBounds(this.extent,{worldBounds:worldBounds})){style={display:"none"};}else{this.calculateFeatureDx(bounds,worldBounds);}
-var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
-this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
-return rendered;}}},calculateFeatureDx:function(bounds,worldBounds){this.featureDx=0;if(worldBounds){var worldWidth=worldBounds.getWidth(),rendererCenterX=(this.extent.left+this.extent.right)/2,featureCenterX=(bounds.left+bounds.right)/2,worldsAway=Math.round((featureCenterX-rendererCenterX)/worldWidth);this.featureDx=worldsAway*worldWidth;}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
-for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
-if(symbolizer.fill===false){delete result.fillColor;}
-OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0,labelAlign:'cm'};OpenLayers.Renderer.symbol={"star":[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],"cross":[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],"x":[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],"square":[0,0,0,1,1,1,1,0,0,0],"triangle":[0,10,10,10,5,0,0,10]};OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.styl
e["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);this.styles["delete"]=new OpenLayers.Style(style);break;}}}
+Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}
+this.up=this.down=null;}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
+return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["def
OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
if(!this.styles[intent]){intent="default";}
@@ -847,7 +990,7 @@
this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
-obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{renderers:this.renderers.join('\n')}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;var newSize=this.map.getSize();newSize.w=newSize.w*this.ratio;newSize.h=newSize.h*this.ratio;this.renderer.setSize(newSize);}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.str
ategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);var newSize=this.map.getSize();newSize.w=newSize.w*this.ratio;newSize.h=newSize.h*this.ratio;this.renderer.setSize(newSize);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility='hidden';var viewSize=this.map.getSize(),viewWidth=viewSize.w,viewHeight=viewSize.h,offsetLeft=(viewWidth/2*this.ratio)-viewWidth/2,offsetTop=(viewHeight/2*this.ratio)-viewHeight/2;offsetLeft+=parseInt(this.map.layerContainerDiv.style.left,10);offsetLeft=-Math.round(offsetLeft);offsetTop+
=parseInt(this.map.layerContainerDiv.style.top,10);offsetTop=-Math.round(offsetTop);this.div.style.left=offsetLeft+'px';this.div.style.top=offsetTop+'px';var extent=this.map.getExtent().scale(this.ratio);coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility='visible';if(OpenLayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
+obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{renderers:this.renderers.join('\n')}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;var newSize=this.map.getSize();newSize.w=newSize.w*this.ratio;newSize.h=newSize.h*this.ratio;this.renderer.setSize(newSize);}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.str
ategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);var newSize=this.map.getSize();newSize.w=newSize.w*this.ratio;newSize.h=newSize.h*this.ratio;this.renderer.setSize(newSize);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility='hidden';var viewSize=this.map.getSize(),viewWidth=viewSize.w,viewHeight=viewSize.h,offsetLeft=(viewWidth/2*this.ratio)-viewWidth/2,offsetTop=(viewHeight/2*this.ratio)-viewHeight/2;offsetLeft+=this.map.layerContainerOriginPx.x;offsetLeft=-Math.round(offsetLeft);offsetTop+=this.map.layerCo
ntainerOriginPx.y;offsetTop=-Math.round(offsetTop);this.div.style.left=offsetLeft+'px';this.div.style.top=offsetTop+'px';var extent=this.map.getExtent().scale(this.ratio);coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility='visible';if(OpenLayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}
if(!this.drawn||zoomChanged||!coordSysUnchanged){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
@@ -882,114 +1025,84 @@
return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){if(maxExtent===null){maxExtent=new OpenLayers.Bounds();}
maxExtent.extend(geometry.getBounds());}}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{geolocation:navigator.geolocation,bind:true,watch:false,geolocationOptions:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
-if(OpenLayers.Control.prototype.activate.apply(this,arguments)){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);}else{this.getCurrentLocation();}
-return true;}
-return false;},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},geolocate:function(position){var center=new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());if(this.bind){this.map.setCenter(center);}
-this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},getCurrentLocation:function(){if(!this.active||this.watch){return false;}
-this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return true;},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.P
oint.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousInd
ex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=length*Math.cos(direction);var dy=length*Math.sin(direction);this.insertDeltaXY(dx,dy);},insertDeflectionLength:function(deflection,length){var previousIndex=this.getCurrentPointIndex()-1;if(previousIndex>0){var p1=this.line.geometry.components[previousIndex];var p0=this.line.geometry.components[previousIndex-1];var theta=Math.atan2(p1.y-p0.y,p1.x-p0.x);this.insertDirectionLength((theta*180/Math.PI)+deflection,length);}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1;},undo:function(){var geometry=this.line.geometry;var components=geometry.components;var index=this.getCurrentPointIndex()-1;var target=components[index];var undone=geometry.removeComponent(target);if(undone){if(!this.redoStack){this.redoStack=[];}
-this.redoStack.push(target);this.drawFeature();}
-return undone;},redo:function(){var target=this.redoStack&&this.redoStack.pop();if(target){this.line.geometry.addComponent(target,this.getCurrentPointIndex());this.drawFeature();}
-return!!target;},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){if(!this.line){this.createFeature(pixel);}
-var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
-return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
-this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;if(this.touch){this.modifyFeature(evt.xy,!!this.lastUp);OpenLayers.Event.stop(evt);}}
-if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
-this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
-if(this.maxVertices&&this.line&&this.line.geometry.components.length===this.maxVertices){this.removePoint();this.finalize();}else{this.addPoint(evt.xy);}
-return false;}
-if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy,!!this.lastUp);}
-return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
-this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
-if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
-this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
-this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features
[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
-OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},getCurrentPointIndex:function(){return this.line.geometry.components.length-2;},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
-if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
-if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
-this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
-return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(force){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,force);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
-return geometry;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,cachedSymbolBounds:{},initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},setExtent:function(){OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);return false;},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){return OpenLayers.CANVAS_SUPPORTED;},setSize:function(size){this.size=size.clone();var root=this.root;root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height
=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);var bounds=feature.geometry.getBounds();var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMaxExtent();}
-var intersects=bounds&&bounds.intersectsBounds(this.extent,{worldBounds:worldBounds});rendered=(style.display!=="none")&&!!bounds&&intersects;if(rendered){this.features[feature.id]=[feature,style];}
-else{delete(this.features[feature.id]);}
-this.pendingRedraw=true;}
-if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
-return rendered;},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
-return;}
-switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style,featureId);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style,featureId);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style,featureId);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style,featureId);break;default:break;}},drawExternalGraphic:function(geometry,style,featureId){var img=new Image();if(style.graphicTitle){img.title=style.graphicTitle;}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;var onLoad=function(){if(!this.features[featureId]){return;}
-var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=(p0+xOffset)|0;var y=(p1+yOffset)|0;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},drawNamedSymbol:function(geometry,style,featureId){var x,y,cx,cy,i,symbolBounds,scaling,angle;var unscaledStrokeWidth;var deg2rad=Math.PI/180.0;var symbol=OpenLayers.Renderer.symbol[style.graphicName];if(!symbol){throw new Error(style.graphicName+' is not a valid symbol name');}
-if(!symbol.length||symbol.length<2)return;var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(isNaN(p0)||isNaN(p1))return;this.canvas.lineCap="round";this.canvas.lineJoin="round";if(this.hitDetection){this.hitContext.lineCap="round";this.hitContext.lineJoin="round";}
-if(style.graphicName in this.cachedSymbolBounds){symbolBounds=this.cachedSymbolBounds[style.graphicName];}else{symbolBounds=new OpenLayers.Bounds();for(i=0;i<symbol.length;i+=2){symbolBounds.extend(new OpenLayers.LonLat(symbol[i],symbol[i+1]));}
-this.cachedSymbolBounds[style.graphicName]=symbolBounds;}
-this.canvas.save();if(this.hitDetection){this.hitContext.save();}
-this.canvas.translate(p0,p1);if(this.hitDetection){this.hitContext.translate(p0,p1);}
-angle=deg2rad*style.rotation;if(!isNaN(angle)){this.canvas.rotate(angle);if(this.hitDetection){this.hitContext.rotate(angle);}}
-scaling=2.0*style.pointRadius/Math.max(symbolBounds.getWidth(),symbolBounds.getHeight());this.canvas.scale(scaling,scaling);if(this.hitDetection){this.hitContext.scale(scaling,scaling);}
-cx=symbolBounds.getCenterLonLat().lon;cy=symbolBounds.getCenterLonLat().lat;this.canvas.translate(-cx,-cy);if(this.hitDetection){this.hitContext.translate(-cx,-cy);}
-unscaledStrokeWidth=style.strokeWidth;style.strokeWidth=unscaledStrokeWidth/scaling;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.canvas.lineTo(x,y);}
-this.canvas.closePath();this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitContext.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.hitContext.lineTo(x,y);}
-this.hitContext.closePath();this.hitContext.fill();}}
-if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.canvas.moveTo(x,y);this.canvas.lineTo(x,y);}
-this.canvas.closePath();this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style,scaling);this.hitContext.beginPath();for(i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];if(i==0)this.hitContext.moveTo(x,y);this.hitContext.lineTo(x,y);}
-this.hitContext.closePath();this.hitContext.stroke();}}
-style.strokeWidth=unscaledStrokeWidth;this.canvas.restore();if(this.hitDetection){this.hitContext.restore();}
-this.setCanvasStyle("reset");},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},featureIdToHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
-var hex="000000"+id.toString(16);var len=hex.length;hex="#"+hex.substring(len-6,len);return hex;},setHitContextStyle:function(type,featureId,symbolizer,strokeScaling){var hex=this.featureIdToHex(featureId);if(type=="fill"){this.hitContext.globalAlpha=1.0;this.hitContext.fillStyle=hex;}else if(type=="stroke"){this.hitContext.globalAlpha=1.0;this.hitContext.strokeStyle=hex;if(typeof strokeScaling==="undefined"){this.hitContext.lineWidth=symbolizer.strokeWidth+2;}else{if(!isNaN(strokeScaling)){this.hitContext.lineWidth=symbolizer.strokeWidth+2.0/strokeScaling;}}}else{this.hitContext.globalAlpha=0;this.hitContext.lineWidth=1;}},drawPoint:function(geometry,style,featureId){if(style.graphic!==false){if(style.externalGraphic){this.drawExternalGraphic(geometry,style,featureId);}else if(style.graphicName&&(style.graphicName!="circle")){this.drawNamedSymbol(geometry,style,featureId);}else{var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var twoPi=M
ath.PI*2;var radius=style.pointRadius;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.fill();}}
-if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.stroke();}
-this.setCanvasStyle("reset");}}}}},drawLineString:function(geometry,style,featureId){style=OpenLayers.Util.applyDefaults({fill:false},style);this.drawLinearRing(geometry,style,featureId);},drawLinearRing:function(geometry,style,featureId){if(style.fill!==false){this.setCanvasStyle("fill",style);this.renderPath(this.canvas,geometry,style,featureId,"fill");if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"fill");}}
-if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.renderPath(this.canvas,geometry,style,featureId,"stroke");if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"stroke");}}
-this.setCanvasStyle("reset");},renderPath:function(context,geometry,style,featureId,type){var components=geometry.components;var len=components.length;context.beginPath();var start=this.getLocalXY(components[0]);var x=start[0];var y=start[1];if(!isNaN(x)&&!isNaN(y)){context.moveTo(start[0],start[1]);for(var i=1;i<len;++i){var pt=this.getLocalXY(components[i]);context.lineTo(pt[0],pt[1]);}
-if(type==="fill"){context.fill();}else{context.stroke();}}},drawPolygon:function(geometry,style,featureId){var components=geometry.components;var len=components.length;this.drawLinearRing(components[0],style,featureId);for(var i=1;i<len;++i){this.canvas.globalCompositeOperation="destination-out";if(this.hitDetection){this.hitContext.globalCompositeOperation="destination-out";}
-this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({stroke:false,fillOpacity:1.0},style),featureId);this.canvas.globalCompositeOperation="source-over";if(this.hitDetection){this.hitContext.globalCompositeOperation="source-over";}
-this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({fill:false},style),featureId);}},drawText:function(location,style){var pt=this.getLocalXY(location);this.setCanvasStyle("reset");this.canvas.fillStyle=style.fontColor;this.canvas.globalAlpha=style.fontOpacity||1.0;var fontStyle=[style.fontStyle?style.fontStyle:"normal","normal",style.fontWeight?style.fontWeight:"normal",style.fontSize?style.fontSize:"1em",style.fontFamily?style.fontFamily:"sans-serif"].join(" ");var labelRows=style.label.split('\n');var numRows=labelRows.length;if(this.canvas.fillText){this.canvas.font=fontStyle;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[1]]||"middle";var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
-var lineHeight=this.canvas.measureText('Mg').height||this.canvas.measureText('xx').width;pt[1]+=lineHeight*vfactor*(numRows-1);for(var i=0;i<numRows;i++){if(style.labelOutlineWidth){this.canvas.save();this.canvas.strokeStyle=style.labelOutlineColor;this.canvas.lineWidth=style.labelOutlineWidth;this.canvas.strokeText(labelRows[i],pt[0],pt[1]+(lineHeight*i)+1);this.canvas.restore();}
-this.canvas.fillText(labelRows[i],pt[0],pt[1]+(lineHeight*i));}}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=fontStyle;var hfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[0]];if(hfactor==null){hfactor=-.5;}
-var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
-var lineHeight=this.canvas.mozMeasureText('xx');pt[1]+=lineHeight*(1+(vfactor*numRows));for(var i=0;i<numRows;i++){var x=pt[0]+(hfactor*this.canvas.mozMeasureText(labelRows[i]));var y=pt[1]+(i*lineHeight);this.canvas.translate(x,y);this.canvas.mozDrawText(labelRows[i]);this.canvas.translate(-x,-y);}}
-this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=((point.x-this.featureDx)/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);this.features={};if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}},getFeatureIdFromEvent:function(evt){var featureId,feature;if(this.hitDetection&&this.root.style.display!=="none"){if(!this.map.dragging){var xy=evt.xy;var x=xy.x|0;var y=xy.y|0;var data=this.hitContext.getImageData(x,y,1,1).data;if(data[3]===255){var id=data[2]+(256*(data[1]+(256*data[0])));if(id){featureId="OpenLayers.Feature.Vector_"+(id-1+this.hitOverflow);try{feature=this.features[featureId][0];}catch(err){}}}}}
-return feature;},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
-for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
-this.redraw();},redraw:function(){if(!this.locked){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}
-var labelMap=[];var feature,geometry,style;var worldBounds=(this.map.baseLayer&&this.map.baseLayer.wrapDateLine)&&this.map.getMaxExtent();for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
-feature=this.features[id][0];geometry=feature.geometry;this.calculateFeatureDx(geometry.getBounds(),worldBounds);style=this.features[id][1];this.drawGeometry(geometry,style,feature.id);if(style.label){labelMap.push([feature,style]);}}
-var item;for(var i=0,len=labelMap.length;i<len;++i){item=labelMap[i];this.drawText(item[0].geometry.getCentroid(),item[1]);}}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={"l":"left","r":"right","t":"top","b":"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={"l":0,"r":-1,"t":0,"b":-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear();},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
-var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
-this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
ed){nextElement=this.getNextElement(nextIndex);}
-return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
-return returnVal;},Z_ORDER_DRAWING_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal==0){returnVal=1;}
-return returnVal;},Z_ORDER_Y_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal===0){var result=nextNode._boundsBottom-newNode._boundsBottom;returnVal=(result===0)?1:result;}
-return returnVal;}};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,xOffset:0,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",LABEL_OUTLINE_SUFFIX:"_outline",initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(options&&(options.zIndexing||options.yOrdering)){this.indexer=new OpenLayers.ElementsIndexer(options.yOrdering);}},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){var child
;var root=this.vectorRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
-root=this.textRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
-if(this.indexer){this.indexer.clear();}},setExtent:function(extent,resolutionChanged){var coordSysUnchanged=OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var rightOfDateLine,ratio=extent.getWidth()/this.map.getExtent().getWidth(),extent=extent.scale(1/ratio),world=this.map.getMaxExtent();if(world.right>extent.left&&world.right<extent.right){rightOfDateLine=true;}else if(world.left>extent.left&&world.left<extent.right){rightOfDateLine=false;}
-if(rightOfDateLine!==this.rightOfDateLine||resolutionChanged){coordSysUnchanged=false;this.xOffset=rightOfDateLine===true?world.getWidth()/resolution:0;}
-this.rightOfDateLine=rightOfDateLine;}
-return coordSysUnchanged;},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;var rendered=true;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0,len=geometry.components.length;i<len;i++){rendered=this.drawGeometry(geometry.components[i],style,featureId)&&rendered;}
-return rendered;}
-rendered=false;var removeBackground=false;if(style.display!="none"){if(style.backgroundGraphic){this.redrawBackgroundNode(geometry.id,geometry,style,featureId);}else{removeBackground=true;}
-rendered=this.redrawNode(geometry.id,geometry,style,featureId);}
-if(rendered==false){var node=document.getElementById(geometry.id);if(node){if(node._style.backgroundGraphic){removeBackground=true;}
-node.parentNode.removeChild(node);}}
-if(removeBackground){var node=document.getElementById(geometry.id+this.BACKGROUND_ID_SUFFIX);if(node){node.parentNode.removeChild(node);}}
-return rendered;},redrawNode:function(id,geometry,style,featureId){style=this.applyDefaultSymbolizer(style);var node=this.nodeFactory(id,this.getNodeType(geometry,style));node._featureId=featureId;node._boundsBottom=geometry.getBounds().bottom;node._geometryClass=geometry.CLASS_NAME;node._style=style;var drawResult=this.drawGeometryNode(node,geometry,style);if(drawResult===false){return false;}
-node=drawResult.node;if(this.indexer){var insert=this.indexer.insert(node);if(insert){this.vectorRoot.insertBefore(node,insert);}else{this.vectorRoot.appendChild(node);}}else{if(node.parentNode!==this.vectorRoot){this.vectorRoot.appendChild(node);}}
-this.postDraw(node);return drawResult.complete;},redrawBackgroundNode:function(id,geometry,style,featureId){var backgroundStyle=OpenLayers.Util.extend({},style);backgroundStyle.externalGraphic=backgroundStyle.backgroundGraphic;backgroundStyle.graphicXOffset=backgroundStyle.backgroundXOffset;backgroundStyle.graphicYOffset=backgroundStyle.backgroundYOffset;backgroundStyle.graphicZIndex=backgroundStyle.backgroundGraphicZIndex;backgroundStyle.graphicWidth=backgroundStyle.backgroundWidth||backgroundStyle.graphicWidth;backgroundStyle.graphicHeight=backgroundStyle.backgroundHeight||backgroundStyle.graphicHeight;backgroundStyle.backgroundGraphic=null;backgroundStyle.backgroundXOffset=null;backgroundStyle.backgroundYOffset=null;backgroundStyle.backgroundGraphicZIndex=null;return this.redrawNode(id+this.BACKGROUND_ID_SUFFIX,geometry,backgroundStyle,null);},drawGeometryNode:function(node,geometry,style){style=style||node._style;var options={'isFilled':style.fill===undefined?true:style.
fill,'isStroked':style.stroke===undefined?!!style.strokeWidth:style.stroke};var drawn;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.graphic===false){options.isFilled=false;options.isStroked=false;}
-drawn=this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;drawn=this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":drawn=this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":drawn=this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Rectangle":drawn=this.drawRectangle(node,geometry);break;default:break;}
-node._options=options;if(drawn!=false){return{node:this.setStyle(node,style,options,geometry),complete:drawn};}else{return false;}},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},removeText:function(featureId){var label=document.getElementById(featureId+this.LABEL_ID_SUFFIX);if(label){this.textRoot.removeChild(label);}
-var outline=document.getElementById(featureId+this.LABEL_OUTLINE_SUFFIX);if(outline){this.textRoot.removeChild(outline);}},getFeatureIdFromEvent:function(evt){var target=evt.target;var useElement=target&&target.correspondingUseElement;var node=useElement?useElement:(target||evt.srcElement);return node._featureId;},eraseGeometry:function(geometry,featureId){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")||(geometry.CLASS_NAME=="OpenLayers.Geometry.Collection")){for(var i=0,len=geometry.components.length;i<len;i++){this.eraseGeometry(geometry.components[i],featureId);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){if(element.geometry){element.geometry.destroy();element.geometry=null;}
-element.parentNode.removeChild(element);if(this.indexer){this.indexer.remove(element);}
-if(element._style.backgroundGraphic){var backgroundId=geometry.id+this.BACKGROUND_ID_SUFFIX;var bElem=OpenLayers.Util.getElement(backgroundId);if(bElem&&bElem.parentNode){bElem.parentNode.removeChild(bElem);}}}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
-return node;},nodeTypeCompare:function(node,type){},createNode:function(type,id){},moveRoot:function(renderer){var root=this.root;if(renderer.root.parentNode==this.rendererRoot){root=renderer.root;}
-root.parentNode.removeChild(root);renderer.rendererRoot.appendChild(root);},getRenderLayerId:function(){return this.root.parentNode.parentNode.id;},isComplexSymbol:function(graphicName){return(graphicName!="circle")&&!!graphicName;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){laye
r=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
+this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
+this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
+if(this.layers){this.map.removeLayer(this.layer);}}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer],layer,feature,l,numExcept;for(l=0;l<layers.length;++l){layer=layers[l];numExcept=0;if(layer.selectedFeatures!=null){while(layer.selectedFeatures.length>numExcept){feature=layer.selectedFeatures[numExcept];if(!options||options.except!=feature){this.unselect(feature);}else{++numExcept;}}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
+this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
=this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;if(feature._prevHighlighter==undefined){delete feature._lastHighlighter;}else if(feature._prevHighlighter==this.id){delete feature._prevHighlighter;}else{feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;}
+layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
+layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel({x:position.left,y:position.bottom});var maxXY=this.map.getLonLatFromPixel({x:position.right,y:position.top});var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
+var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];this.events.triggerEvent("boxselectionstart",{layers:layers});var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
+this.multiple=prevMultiple;this.events.triggerEvent("boxselectionend",{layers:layers});}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
+OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
+this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",template:"${layers}",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&laye
r.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
+this.div.innerHTML=OpenLayers.String.format(this.template,{layers:attributions.join(this.separator)});}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Kinetic=OpenLayers.Class({threshold:0,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){OpenLayers.Animation.stop(this.timerId);this.timerId=undefined;this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>this.nbPoints){this.points.pop();}},end:function(xy){var last,now=new Date().getTime();for(var i=0,l=this.points.length,point;i<l;i++){point=this.points[i];if(now-point.tick>this.delay){break;}
+last=point;}
+if(!last){return;}
+var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
+Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
+var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
+return{speed:speed,theta:theta};},move:function(info,callback){var v0=info.speed;var fx=Math.cos(info.theta);var fy=-Math.sin(info.theta);var initialTime=new Date().getTime();var lastX=0;var lastY=0;var timerCallback=function(){if(this.timerId==null){return;}
+var t=new Date().getTime()-initialTime;var p=(-this.deceleration*Math.pow(t,2))/2.0+v0*t;var x=p*fx;var y=p*fy;var args={};args.end=false;var v=-this.deceleration*t+v0;if(v<=0){OpenLayers.Animation.stop(this.timerId);this.timerId=null;args.end=true;}
+args.x=x-lastX;args.y=y-lastY;lastX=x;lastY=y;callback(args.x,args.y,args.end);};this.timerId=OpenLayers.Animation.start(OpenLayers.Function.bind(timerCallback,this));},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
+return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
+return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
+return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
+return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',{x:
-9999,y:-9999});this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,
end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
+return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
+return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,keyMask:null,alwaysZoom:false,zoomOnClick:true,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds,targetCenterPx=position.getCenterPixel();if(!this.out){var minXY=this.map.getLonLatFromPixel({x:position.left,y:position.bottom});var maxXY=this.map.getLonLatFromPixel({x:position.right,y:position.top});bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=position.right-position.left;var pixHeight=position.bottom-position.top;var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(targetCenterPx);var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;
var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+var lastZoom=this.map.getZoom(),size=this.map.getSize(),centerPx={x:size.w/2,y:size.h/2},zoom=this.map.getZoomForExtent(bounds),oldRes=this.map.getResolution(),newRes=this.map.getResolutionForZoom(zoom);if(oldRes==newRes){this.map.setCenter(this.map.getLonLatFromPixel(targetCenterPx));}else{var zoomOriginPx={x:(oldRes*targetCenterPx.x-newRes*centerPx.x)/(oldRes-newRes),y:(oldRes*targetCenterPx.y-newRes*centerPx.y)/(oldRes-newRes)};this.map.zoomTo(zoom,zoomOriginPx);}
+if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else if(this.zoomOnClick){if(!this.out){this.map.zoomTo(this.map.getZoom()+1,position);}else{this.map.zoomTo(this.map.getZoom()-1,position);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:0,documentDrag:false,kinetic:null,enableKinetic:true,kineticInterval:10,draw:function(){if(this.enableKinetic&&OpenLayers.Kinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+this.kinetic=new OpenLayers.Kinetic(config);}
+this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
+this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
+this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(evt){this.startTouch();this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
+return true;},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
+this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this.passesDblclickTolerance(evt)){if(this["double"]){this.callback("dblclick",[evt]);}
+this.clearTimer();}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.preventDefault(evt);}
+this.handleDouble(evt);}
+if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
+return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
+Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.olClientX,clientY:touch.olClientY};}}
+return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;if(this.pinchZoom){this.pinchZoom.destroy();}
+this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+if(this.pinchZoom){this.pinchZoom.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();var wheelOptions=this.map.fractionalZoom?{}:{cumulative:false,interval:50,maxDelta:6};this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{up:this.wheelUp,down:this.wheelDown},OpenLayers.Util.extend(wheelOptions,this.mouseWheelOptions));if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.ma
p.zoomOut();}},defaultDblClick:function(evt){this.map.zoomTo(this.map.zoom+1,evt.xy);},defaultDblRightClick:function(evt){this.map.zoomTo(this.map.zoom-1,evt.xy);},wheelChange:function(evt,deltaZ){if(!this.map.fractionalZoom){deltaZ=Math.round(deltaZ);}
+var currentZoom=this.map.getZoom(),newZoom=currentZoom+deltaZ;newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
+this.map.zoomTo(newZoom,evt.xy);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",format:"image/jpeg"},isBaseLayer:true,encodeBBOX:false,noMagic:false,yx:{},initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);if(parseFloat(params.VERSION)>=1.3&&!params.EXCEPTIONS){params.EXCEPTIONS="INIMAGE";}
+newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){var projCode=this.projection.getCode();return parseFloat(this.params.VERSION)>=1.3&&!!(this.yx[projCode]||(OpenLayers.Projection.defaults[projCode]&&OpenLayers.Projection.defaults[projCode].yx));},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=this.map.getProjectionObject()
;var projectionCode=this.projection&&this.projection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=value;}else{this.params.SRS=value;}
+if(typeof this.params.TRANSPARENT=="boolean"){newParams.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";}
+return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({projection:"EPSG:900913",numZoomLevels:19},options);}
+OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name||this.name,url||this.url,{},options]);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.getServerResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.getServerZoom();if(this.wrapDateLine){var limit=Math.pow(2,z);x=((x%limit)+limit)%limit;}
+return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){var coordSysUnchanged=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution(),left=-extent.left/resolution,top=extent.top/resolution;if(resolutionChanged){this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.si
ze.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(this.xOffset,0);return true;}else{var inRange=this.translate(left-this.left+this.xOffset,top-this.top);if(!inRange){this.setExtent(extent,true);}
return coordSysUnchanged&&inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":nodeType="path";break;default:break;}
-return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));var widthFactor=1;var pos;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){pos=this.getPosition(node);if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var titleNode=node.getElementsByTagName("title");if(titleNode.length>0){titleNode[0].firstChild.textContent=style.graphicTitle;}else{var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}}
-if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(pos.x+xOffset).toFixed());node.setAttributeNS(null,"y",(pos.y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);node.onclick=OpenLayers.Renderer.SVG.preventDefault;}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3;var size=offset*2;var src=this.importSymbol(style.graphicName);pos=this.getPosition(node);widthFactor=this.symbolMetrics[src.id][0]*3/size;var parent=no
de.parentNode;var nextSibling=node.nextSibling;if(parent){parent.removeChild(node);}
+return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var title=style.title||style.graphicTitle;if(title){node.setAttributeNS(null,"title",title);var titleNode=node.getElementsByTagName("title");if(titleNode.length>0){titleNode[0].firstChild.textContent=title;}else{var label=this.nodeFactory(null,"title");label.textContent=title;node.appendChild(label);}}
+var r=parseFloat(node.getAttributeNS(null,"r"));var widthFactor=1;var pos;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){pos=this.getPosition(node);if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(pos.x+xOffset).toFixed());node.setAttributeNS(null,"y",(pos.y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"xlink:href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);node.onclick=OpenLayers.Event.preventDefault;}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3;var size=offset*2;var src=this.importSymbol(style.graphicName);pos=this.getPosition(node);widthFactor=this.symbolMetrics[src.id][0]*3/size;var parent=nod
node.firstChild&&node.removeChild(node.firstChild);node.appendChild(src.firstChild.cloneNode(true));node.setAttributeNS(null,"viewBox",src.getAttributeNS(null,"viewBox"));node.setAttributeNS(null,"width",size);node.setAttributeNS(null,"height",size);node.setAttributeNS(null,"x",pos.x-offset);node.setAttributeNS(null,"y",pos.y-offset);if(nextSibling){parent.insertBefore(node,nextSibling);}else if(parent){parent.appendChild(node);}}else{node.setAttributeNS(null,"r",style.pointRadius);}
var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)&&pos){node._rotation=rotation;rotation|=0;if(node.nodeName!=="svg"){node.setAttributeNS(null,"transform","rotate("+rotation+" "+pos.x+" "+
pos.y+")");}else{var metrics=this.symbolMetrics[src.id];node.firstChild.setAttributeNS(null,"transform","rotate("
@@ -1002,7 +1115,8 @@
if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
return node;},dashStyle:function(style,widthFactor){var w=style.strokeWidth*widthFactor;var str=style.strokeDashstyle;switch(str){case'solid':return'none';case'dot':return[1,4*w].join();case'dash':return[4*w,4*w].join();case'dashdot':return[4*w,4*w,1,4*w].join();case'longdash':return[8*w,4*w].join();case'longdashdot':return[8*w,4*w,1,4*w].join();default:return OpenLayers.String.trim(str).replace(/\s+/g,",");}},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){var svg=this.nodeFactory(this.container.id+"_svgRoot","svg");svg.style.display="block";return svg;},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"g");},createDefs:function(){var defs=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(defs);return defs;},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=((geometry.x-this.featureDx)/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);return node;}else{return false;}},drawLineString:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS
(null,"points",componentsResult.path);return(componentsResult.complete?node:null);}else{return false;}},drawLinearRing:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(componentsResult.complete?node:null);}else{return false;}},drawPolygon:function(node,geometry){var d="";var draw=true;var complete=true;var linearRingResult,path;for(var j=0,len=geometry.components.length;j<len;j++){d+=" M";linearRingResult=this.getComponentsString(geometry.components[j].components," ");path=linearRingResult.path;if(path){d+=" "+path;complete=linearRingResult.complete&&complete;}else{draw=false;}}
-d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");return complete?node:null;}else{return false;}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=((geometry.x-this.featureDx)/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);return node;}else{return false;}},drawText:function(featureId,style,location){var drawOutline=(!!style.labelOutlineWidth);if(drawOutline){var outlineStyle=OpenLayers.Util.extend({},style);outlineStyle.fontColor=outlineStyle.labelOutlineColor;outlineStyle.fontStrokeColor=outlineStyle.labelOutlineColor;outlineStyle.fontStrokeWidth=style.labelOutlineWidth;delete outlineStyle.labelOutlineWidth;this.drawText(featureId,outlineStyle,location);}
+d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");return complete?node:null;}else{return false;}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=((geometry.x-this.featureDx)/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);return node;}else{return false;}},drawText:function(featureId,style,location){var drawOutline=(!!style.labelOutlineWidth);if(drawOutline){var outlineStyle=OpenLayers.Util.extend({},style);outlineStyle.fontColor=outlineStyle.labelOutlineColor;outlineStyle.fontStrokeColor=outlineStyle.labelOutlineColor;outlineStyle.fontStrokeWidth=style.labelOutlineWidth;if(style.labelOutlineOpacity){outlineStyle.fontOpacity=style.labelOutlineOpacity;}
+delete outlineStyle.labelOutlineWidth;this.drawText(featureId,outlineStyle,location);}
var resolution=this.getResolution();var x=((location.x-this.featureDx)/resolution+this.left);var y=(location.y/resolution-this.top);var suffix=(drawOutline)?this.LABEL_OUTLINE_SUFFIX:this.LABEL_ID_SUFFIX;var label=this.nodeFactory(featureId+suffix,"text");label.setAttributeNS(null,"x",x);label.setAttributeNS(null,"y",-y);if(style.fontColor){label.setAttributeNS(null,"fill",style.fontColor);}
if(style.fontStrokeColor){label.setAttributeNS(null,"stroke",style.fontStrokeColor);}
if(style.fontStrokeWidth){label.setAttributeNS(null,"stroke-width",style.fontStrokeWidth);}
@@ -1030,69 +1144,79 @@
var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]=[Math.max(width,height),symbolExtent.getCenterLonLat().lon,symbolExtent.getCenterLonLat().lat];this.defs.appendChild(symbolNode);return symbolNode;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot?target.parentNode._featureId:undefined;}
-return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};this.handlerOption
s.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{renderers:layer.renderers,rendererOptions:layer.rendererOptions});if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
-var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){lay
er.renderer.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
-this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
-this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
-this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
-if(this.layers){this.map.removeLayer(this.layer);}}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
-layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
-layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel({x:position.left,y:position.bottom});var maxXY=this.map.getLonLatFromPixel({x:position.right,y:position.top});var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
-var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];this.events.triggerEvent("boxselectionstart",{layers:layers});var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
-this.multiple=prevMultiple;this.events.triggerEvent("boxselectionend",{layers:layers});}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
-OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
-this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,observeElement:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.observeElement=this.observeElement||document;for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(this.observeElement,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(this.observeElement,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,createVertices:true,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.C
ontrol.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(OpenLayers.Util.isArray(this.deleteCodes))){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
-var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyboard.activate()&&OpenLayers.Control.p
rototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
-this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
-this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}
-var modified=feature.modified;if(feature.geometry&&!(modified&&modified.geometry)){this._originalGeometry=feature.geometry.clone();}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
-this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;if(this.modified&&this._originalGeometry){var feature=this.feature;feature.modified=OpenLayers.Util.extend(feature.modified,{geometry:this._originalGeometry});delete this._originalGeometry;}}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.modified=true;this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i
,vertex,component,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(control.createVertices&&geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.dragHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.F
eature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.radiusHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourc
eSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
-sourceSplit=true;splits=splits[1];}
-if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
-if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
-if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
-if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
-if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
-return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
-splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
-for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
-targetSplit=true;}}
-if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
-return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.ProxyHost="";OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),makeSameOrigin:function(url,proxy){var sameOrigin=url.indexOf("http")!==0;var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
-if(!sameOrigin){if(proxy){if(typeof proxy=="function"){url=proxy(url);}else{url=proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
-return url;},issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var customRequestedWithHeader=false,headerKey;for(headerKey in config.headers){if(config.headers.hasOwnProperty(headerKey)){if(headerKey.toLowerCase()==='x-requested-with'){customRequestedWithHeader=true;}}}
+return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){OpenLayers.Event.preventDefault(e);};OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:false,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},destroy:function(){},read:function(data){throw new Error('Read not implemented.');},write:function(object){throw new Error('Write not implemented.');},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:" ",space:" ",newline:"\n",level:0,pretty:false,nativeJSON:(function(){return!!(window.JSON&&typeof JSON.parse=="function"&&typeof JSON.stringify=="function");})(),read:function(jso
n,filter){var object;if(this.nativeJSON){object=JSON.parse(json,filter);}else try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
+return filter(k,v);}
+object=walk('',object);}}}catch(e){}
+if(this.keepData){this.data=object;}
+return object;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){try{json=(!this.pretty&&this.nativeJSON)?JSON.stringify(value):this.serialize[type].apply(this,[value]);}catch(err){OpenLayers.Console.error("Trouble serializing: "+err);}}
+return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
+return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
+if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
+if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
+var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0,len=array.length;i<len;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),json);}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);})+'"';}
+return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
+return'"'+date.getFullYear()+'-'+
+format(date.getMonth()+1)+'-'+
+format(date.getDate())+'T'+
+format(date.getHours())+':'+
+format(date.getMinutes())+':'+
+format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
+if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
+break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
+break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
+break;case"FeatureCollection":for(var i=0,len=obj.features.length;i<len;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;}}
+return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
+obj.type);}else{valid=true;}
+break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
+obj.type+" to "+type);}}
+return valid;},parseFeature:function(obj){var feature,geometry,attributes,bbox;attributes=(obj.properties)?obj.properties:{};bbox=(obj.geometry&&obj.geometry.bbox)||obj.bbox;try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
+feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
+if(obj.id){feature.fid=obj.id;}
+return feature;},parseGeometry:function(obj){if(obj==null){return null;}
+var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(OpenLayers.Util.isArray(obj.geometries))){throw"GeometryCollection must have geometries array: "+obj;}
+var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
+geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(OpenLayers.Util.isArray(obj.coordinates))){throw"Geometry must have coordinates array: "+obj;}
+if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
+try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
+if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},parseCoords:{"point":function(array){if(this.ignoreExtraDims==false&&array.length!=2){throw"Only 2D points are supported: "+array;}
+return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+lines.push(l);}
+return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
+return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
+polys.push(p);}
+return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(OpenLayers.Util.isArray(obj)){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
+geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
+return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"name","properties":{"name":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"name","properties":{"name":"EPSG:"+code}};}}
+return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);var json={"type":"Feature","properties":feature.attributes,"geometry":geom};if(feature.fid!=null){json.id=feature.fid;}
+return json;},'geometry':function(geometry){if(geometry==null){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
+return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
+return array;},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
+return array;},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
+return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
+return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
+return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.ProxyHost="";if(!OpenLayers.Request){OpenLayers.Request={};}
+OpenLayers.Util.extend(OpenLayers.Request,{DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),makeSameOrigin:function(url,proxy){var sameOrigin=url.indexOf("http")!==0;var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
+if(!sameOrigin){if(proxy){if(typeof proxy=="function"){url=proxy(url);}else{url=proxy+encodeURIComponent(url);}}}
+return url;},issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=config||{};config.headers=config.headers||{};config=OpenLayers.Util.applyDefaults(config,defaultConfig);config.headers=OpenLayers.Util.applyDefaults(config.headers,defaultConfig.headers);var customRequestedWithHeader=false,headerKey;for(headerKey in config.headers){if(config.headers.hasOwnProperty(headerKey)){if(headerKey.toLowerCase()==='x-requested-with'){customRequestedWithHeader=true;}}}
if(customRequestedWithHeader===false){config.headers['X-Requested-With']='XMLHttpRequest';}
var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));url=OpenLayers.Request.makeSameOrigin(url,config.proxy);request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
@@ -1102,7 +1226,7 @@
complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
-return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}});(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
if(cXMLHttpRequest.onopen)
@@ -1139,100 +1263,13 @@
try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
try{oRequest.status=oRequest._object.status;}catch(e){}
try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
-oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:false,updateWithPOST:false,deleteWithPOST:false,wildcarded:false,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var format=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=function(filter,params){return format.write(filter,params);};}},destroy:function(){this.params=null;this.headers=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this
,arguments);options=options||{};options.params=OpenLayers.Util.applyDefaults(options.params,this.options.params);options=OpenLayers.Util.applyDefaults(options,this.options);if(options.filter&&this.filterToParams){options.params=this.filterToParams(options.filter,options.params);}
-var readWithPOST=(options.readWithPOST!==undefined)?options.readWithPOST:this.readWithPOST;var resp=new OpenLayers.Protocol.Response({requestType:"read"});if(readWithPOST){var headers=options.headers||{};headers["Content-Type"]="application/x-www-form-urlencoded";resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,resp,options),data:OpenLayers.Util.getParameterString(options.params),headers:headers});}else{resp.priv=OpenLayers.Request.GET({url:options.url,callback:this.createCallback(this.handleRead,resp,options),params:options.params,headers:options.headers});}
-return resp;},handleRead:function(resp,options){this.handleResponse(resp,options);},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:features,requestType:"create"});resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleCreate,resp,options),headers:options.headers,data:this.format.write(features)});return resp;},handleCreate:function(resp,options){this.handleResponse(resp,options);},update:function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"update"});var method=this.updateWithPOST?"POST":"PUT";resp.priv=OpenLayers.Request[method]({url:url,callback:this.createCallback(this.handleUpdate,resp,options),headers:options.headers,data:this.format.write(fea
ture)});return resp;},handleUpdate:function(resp,options){this.handleResponse(resp,options);},"delete":function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"delete"});var method=this.deleteWithPOST?"POST":"DELETE";var requestOptions={url:url,callback:this.createCallback(this.handleDelete,resp,options),headers:options.headers};if(this.deleteWithPOST){requestOptions.data=this.format.write(feature);}
-resp.priv=OpenLayers.Request[method](requestOptions);return resp;},handleDelete:function(resp,options){this.handleResponse(resp,options);},handleResponse:function(resp,options){var request=resp.priv;if(options.callback){if(request.status>=200&&request.status<300){if(resp.requestType!="delete"){resp.features=this.parseFeatures(request);}
-resp.code=OpenLayers.Protocol.Response.SUCCESS;}else{resp.code=OpenLayers.Protocol.Response.FAILURE;}
-options.callback.call(options.scope,resp);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(!doc||doc.length<=0){return null;}
-return this.format.read(doc);},commit:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=[],nResponses=0;var types={};types[OpenLayers.State.INSERT]=[];types[OpenLayers.State.UPDATE]=[];types[OpenLayers.State.DELETE]=[];var feature,list,requestFeatures=[];for(var i=0,len=features.length;i<len;++i){feature=features[i];list=types[feature.state];if(list){list.push(feature);requestFeatures.push(feature);}}
-var nRequests=(types[OpenLayers.State.INSERT].length>0?1:0)+
-types[OpenLayers.State.UPDATE].length+
-types[OpenLayers.State.DELETE].length;var success=true;var finalResponse=new OpenLayers.Protocol.Response({reqFeatures:requestFeatures});function insertCallback(response){var len=response.features?response.features.length:0;var fids=new Array(len);for(var i=0;i<len;++i){fids[i]=response.features[i].fid;}
-finalResponse.insertIds=fids;callback.apply(this,[response]);}
-function callback(response){this.callUserCallback(response,options);success=success&&response.success();nResponses++;if(nResponses>=nRequests){if(options.callback){finalResponse.code=success?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.apply(options.scope,[finalResponse]);}}}
-var queue=types[OpenLayers.State.INSERT];if(queue.length>0){resp.push(this.create(queue,OpenLayers.Util.applyDefaults({callback:insertCallback,scope:this},options.create)));}
-queue=types[OpenLayers.State.UPDATE];for(var i=queue.length-1;i>=0;--i){resp.push(this.update(queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options.update)));}
-queue=types[OpenLayers.State.DELETE];for(var i=queue.length-1;i>=0;--i){resp.push(this["delete"](queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options["delete"])));}
-return resp;},abort:function(response){if(response){response.priv.abort();}},callUserCallback:function(resp,options){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}},CLASS_NAME:"OpenLayers.Protocol.HTTP"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
-if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
-break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
-break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
-break;case"FeatureCollection":for(var i=0,len=obj.features.length;i<len;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;}}
-return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
-obj.type);}else{valid=true;}
-break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
-obj.type+" to "+type);}}
-return valid;},parseFeature:function(obj){var feature,geometry,attributes,bbox;attributes=(obj.properties)?obj.properties:{};bbox=(obj.geometry&&obj.geometry.bbox)||obj.bbox;try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
-feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
-if(obj.id){feature.fid=obj.id;}
-return feature;},parseGeometry:function(obj){if(obj==null){return null;}
-var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(OpenLayers.Util.isArray(obj.geometries))){throw"GeometryCollection must have geometries array: "+obj;}
-var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(OpenLayers.Util.isArray(obj.coordinates))){throw"Geometry must have coordinates array: "+obj;}
-if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
-try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
-if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},parseCoords:{"point":function(array){if(this.ignoreExtraDims==false&&array.length!=2){throw"Only 2D points are supported: "+array;}
-return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-lines.push(l);}
-return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
-return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
-polys.push(p);}
-return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(OpenLayers.Util.isArray(obj)){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
-geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
-return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"name","properties":{"name":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"name","properties":{"name":"EPSG:"+code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);var json={"type":"Feature","properties":feature.attributes,"geometry":geom};if(feature.fid!=null){json.id=feature.fid;}
-return json;},'geometry':function(geometry){if(geometry==null){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
-return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array;},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
-return array;},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
-return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
-return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
-return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.getServerResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.getServerZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
-return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
-return false;},deactivate:function(){if(this.active){this.active=false;return true;}
-return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:false,activate:function(){if(OpenLayers.Strategy.prototype.activate.apply(this,arguments)){this.layer.events.on({"refresh":this.load,scope:this});if(this.layer.visibility==true||this.preload){this.load();}else{this.layer.events.on({"visibilitychanged":this.load,scope:this});}
-return true;}
-return false;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"refresh":this.load,"visibilitychanged":this.load,scope:this});}
-return deactivated;},load:function(options){var layer=this.layer;layer.events.triggerEvent("loadstart");layer.protocol.read(OpenLayers.Util.applyDefaults({callback:OpenLayers.Function.bind(this.merge,this,layer.map.getProjectionObject()),filter:layer.filter},options));layer.events.un({"visibilitychanged":this.load,scope:this});},merge:function(mapProjection,resp){var layer=this.layer;layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){if(!mapProjection.equals(layer.projection)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(layer.projection,mapProjection);}}}
-layer.addFeatures(features);}
-layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Control.Zoom=OpenLayers.Class(OpenLayers.Control,{zoomInText:"+",zoomInId:"olZoomInLink",zoomOutText:"-",zoomOutId:"olZoomOutLink",draw:function(){var div=OpenLayers.Control.prototype.draw.apply(this),links=this.getOrCreateLinks(div),zoomIn=links.zoomIn,zoomOut=links.zoomOut,eventsInstance=this.map.events;if(zoomOut.parentNode!==div){eventsInstance=this.events;eventsInstance.attachToElement(zoomOut.parentNode);}
-eventsInstance.register("buttonclick",this,this.onZoomClick);this.zoomInLink=zoomIn;this.zoomOutLink=zoomOut;return div;},getOrCreateLinks:function(el){var zoomIn=document.getElementById(this.zoomInId),zoomOut=document.getElementById(this.zoomOutId);if(!zoomIn){zoomIn=document.createElement("a");zoomIn.href="#zoomIn";zoomIn.appendChild(document.createTextNode(this.zoomInText));zoomIn.className="olControlZoomIn";el.appendChild(zoomIn);}
-OpenLayers.Element.addClass(zoomIn,"olButton");if(!zoomOut){zoomOut=document.createElement("a");zoomOut.href="#zoomOut";zoomOut.appendChild(document.createTextNode(this.zoomOutText));zoomOut.className="olControlZoomOut";el.appendChild(zoomOut);}
-OpenLayers.Element.addClass(zoomOut,"olButton");return{zoomIn:zoomIn,zoomOut:zoomOut};},onZoomClick:function(evt){var button=evt.buttonElement;if(button===this.zoomInLink){this.map.zoomIn();}else if(button===this.zoomOutLink){this.map.zoomOut();}},destroy:function(){if(this.map){this.map.events.unregister("buttonclick",this,this.onZoomClick);}
-delete this.zoomInLink;delete this.zoomOutLink;OpenLayers.Control.prototype.destroy.apply(this);},CLASS_NAME:"OpenLayers.Control.Zoom"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,allowDepress:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){if(this.map){this.map.events.unregister("buttonclick",this,this.onButtonClick);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var ctl,i=this.controls.length-1;i>=0;i--){ctl=this.controls[i];if(ctl.events){ctl.events.un({activate:this.iconOn,deactivate:this.iconOff});}
-ctl.panel_div=null;}
-this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
-if(this.saveState===true){this.defaultControl=null;}
-this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];this.activeState[control.id]=control.deactivate();}
-this.redraw();return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(this.outsideViewport){this.events.attachToElement(this.div);this.events.register("buttonclick",this,this.onButtonClick);}else{this.map.events.register("buttonclick",this,this.onButtonClick);}
-this.addControlsToMap(this.controls);return this.div;},redraw:function(){for(var l=this.div.childNodes.length,i=l-1;i>=0;i--){this.div.removeChild(this.div.childNodes[i]);}
-this.div.innerHTML="";if(this.active){for(var i=0,len=this.controls.length;i<len;i++){this.div.appendChild(this.controls[i].panel_div);}}},activateControl:function(control){if(!this.active){return false;}
-if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
-if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
-return;}
-if(this.allowDepress&&control.active){control.deactivate();}else{var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
-control.activate();}},addControls:function(controls){if(!(OpenLayers.Util.isArray(controls))){controls=[controls];}
-this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var control=controls[i],element=this.createControlMarkup(control);OpenLayers.Element.addClass(element,control.displayClass+"ItemInactive");OpenLayers.Element.addClass(element,"olButton");if(control.title!=""&&!element.title){element.title=control.title;}
-control.panel_div=element;}
-if(this.map){this.addControlsToMap(controls);this.redraw();}},createControlMarkup:function(control){return document.createElement("div");},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
-control.events.on({activate:this.iconOn,deactivate:this.iconOff});}},iconOn:function(){var d=this.panel_div;var re=new RegExp("\\b("+this.displayClass+"Item)Inactive\\b");d.className=d.className.replace(re,"$1Active");},iconOff:function(){var d=this.panel_div;var re=new RegExp("\\b("+this.displayClass+"Item)Active\\b");d.className=d.className.replace(re,"$1Inactive");},onButtonClick:function(evt){var controls=this.controls,button=evt.buttonElement;for(var i=controls.length-1;i>=0;--i){if(controls[i].panel_div===button){this.activateControl(controls[i]);break;}}},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Pane
l"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,observeElement:null,draw:function(){var observeElement=this.observeElement||document;this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress},{observeElement:observeElement});},defaultKeyPress:function(evt){var size,handled=true;switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();brea
k;case 45:case 109:case 189:case 95:this.map.zoomOut();break;default:handled=false;}
-if(handled){OpenLayers.Event.stop(evt);}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{handlerOptions:null,callbacks:null,displaySystem:'metric',geodesic:false,displaySystemUnits:{geographic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};if(!OpenLayers.Request){OpenLayers.Request={};}
+OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);if(this.type===OpenLayers.Filter.Comparison.LIKE&&options.matchCase===undefined){this.matchCase=null;}},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
+var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
+break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
+break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;case OpenLayers.Filter.Comparison.IS_NULL:result=(got===null);break;}
+return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){throw new Error("'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison");}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Comparison.IS_NULL="NULL";OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{callbacks:null,displaySystem:'metric',geodesic:false,displaySystemUnits:{geographic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new handler(this,this.callbacks,this.handlerOptions);},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},cancel:function(){this.cancelDelay();this.handler.cancel();},setImmediate:function(immediate){this.immediate=immediate;if(this.immediate){this.callbacks.modify=this.measureImmediate;}else{delete this.callbacks.modify;}},updateHandler:function(handler,options){var active=this.active;if(active){this.deactivate();}
this.handler=new handler(this,this.callbacks,options);if(active){this.activate();}},measureComplete:function(geometry){this.cancelDelay();this.measure(geometry,"measure");},measurePartial:function(point,geometry){this.cancelDelay();geometry=geometry.clone();if(this.handler.freehandMode(this.handler.evt)){this.measure(geometry,"measurepartial");}else{this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(geometry,"measurepartial");},this),this.partialDelay);}},measureImmediate:function(point,feature,drawing){if(drawing&&!this.handler.freehandMode(this.handler.evt)){this.cancelDelay();this.measure(feature.geometry,"measurepartial");}},cancelDelay:function(){if(this.delayedTrigger!==null){window.clearTimeout(this.delayedTrigger);this.delayedTrigger=null;}},measure:function(geometry,eventType){var stat,order;if(geometry.CLASS_NAME.indexOf('LineString')>-1){stat=this.getBestLength(geometry);order=1;}else{stat=this.getBestAr
ea(geometry);order=2;}
this.events.triggerEvent(eventType,{measure:stat[0],units:stat[1],order:order,geometry:geometry});},getBestArea:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,area;for(var i=0,len=units.length;i<len;++i){unit=units[i];area=this.getArea(geometry,unit);if(area>1){break;}}
@@ -1241,17 +1278,90 @@
return area;},getBestLength:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,length;for(var i=0,len=units.length;i<len;++i){unit=units[i];length=this.getLength(geometry,unit);if(length>1){break;}}
return[length,unit];},getLength:function(geometry,units){var length,geomUnits;if(this.geodesic){length=geometry.getGeodesicLength(this.map.getProjectionObject());geomUnits="m";}else{length=geometry.getLength();geomUnits=this.map.getUnits();}
var inPerDisplayUnit=OpenLayers.INCHES_PER_UNIT[units];if(inPerDisplayUnit){var inPerMapUnit=OpenLayers.INCHES_PER_UNIT[geomUnits];length*=(inPerMapUnit/inPerDisplayUnit);}
-return length;},CLASS_NAME:"OpenLayers.Control.Measure"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,serverResolutions:null,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+return length;},CLASS_NAME:"OpenLayers.Control.Measure"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:false,featureAdded:function(){},initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{renderers:layer.renderers,rendererOptions:layer.rendererOptions});if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
+var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
+this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
+if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
+if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
+if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
+return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
+if(typeof this.context=="function"){context=this.context(feature);}
+return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
+options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:false,pinching:false,last:null,start:null,touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else if(this.started){return false;}else{this.started=false;this.start=null;this.last=null;}
+OpenLayers.Event.preventDefault(evt);return propagate;},touchmove:function(evt){if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;OpenLayers.Event.stop(evt);}else if(this.started){return false;}
+return true;},touchend:function(evt){if(this.started&&!OpenLayers.Event.isMultiTouch(evt)){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;return false;}
+return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
+return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.olClientX-t1.olClientX,2)+
+Math.pow(t0.olClientY-t1.olClientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",url:['http://a.tile.openstreetmap.org/${z}/${x}/${y}.png','http://b.tile.openstreetmap.org/${z}/${x}/${y}.png','http://c.tile.openstreetmap.org/${z}/${x}/${y}.png'],attribution:"© <a href='http://www.openstreetmap.org/copyright'>OpenStreetMap</a> contributors",sphericalMercator:true,wrapDateLine:true,tileOptions:null,initialize:function(name,url,options){OpenLayers.Layer.XYZ.prototype.initialize.apply(this,arguments);this.tileOptions=OpenLayers.Util.extend({crossOriginKeyword:'anonymous'},this.options&&this.options.tileOptions);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
+this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();this.layer.events.un({"visibilitychanged":this.reset,scope:this});}
+return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Format.QueryStringFilter=(function(){var cmpToStr={};cmpToStr[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";cmpToStr[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN]="lt";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";cmpToStr[OpenLaye
rs.Filter.Comparison.LIKE]="ilike";function regex2value(value){value=value.replace(/%/g,"\\%");value=value.replace(/\\\\\.(\*)?/g,function($0,$1){return $1?$0:"\\\\_";});value=value.replace(/\\\\\.\*/g,"\\\\%");value=value.replace(/(\\)?\.(\*)?/g,function($0,$1,$2){return $1||$2?$0:"_";});value=value.replace(/(\\)?\.\*/g,function($0,$1){return $1?$0:"%";});value=value.replace(/\\\./g,".");value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"*";});return value;}
+return OpenLayers.Class(OpenLayers.Format,{wildcarded:false,srsInBBOX:false,write:function(filter,params){params=params||{};var className=filter.CLASS_NAME;var filterType=className.substring(className.lastIndexOf(".")+1);switch(filterType){case"Spatial":switch(filter.type){case OpenLayers.Filter.Spatial.BBOX:params.bbox=filter.value.toArray();if(this.srsInBBOX&&filter.projection){params.bbox.push(filter.projection.getCode());}
+break;case OpenLayers.Filter.Spatial.DWITHIN:params.tolerance=filter.distance;case OpenLayers.Filter.Spatial.WITHIN:params.lon=filter.value.x;params.lat=filter.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+filter.type);}
+break;case"Comparison":var op=cmpToStr[filter.type];if(op!==undefined){var value=filter.value;if(filter.type==OpenLayers.Filter.Comparison.LIKE){value=regex2value(value);if(this.wildcarded){value="%"+value+"%";}}
+params[filter.property+"__"+op]=value;params.queryable=params.queryable||[];params.queryable.push(filter.property);}else{OpenLayers.Console.warn("Unknown comparison filter type "+filter.type);}
+break;case"Logical":if(filter.type===OpenLayers.Filter.Logical.AND){for(var i=0,len=filter.filters.length;i<len;i++){params=this.write(filter.filters[i],params);}}else{OpenLayers.Console.warn("Unsupported logical filter type "+filter.type);}
+break;default:OpenLayers.Console.warn("Unknown filter type "+filterType);}
+return params;},CLASS_NAME:"OpenLayers.Format.QueryStringFilter"});})();OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.events.register('mousemove',this,this.redraw);this.map.events.register('mouseout',this,this.reset);this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('mousemove',this,this.redraw);this.map.events.unregister('mouseout',this,this.reset);this.element.innerHTML="";return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left=
"";this.div.top="";this.element=this.div;}
+return this.div;},redraw:function(evt){var lonLat;if(evt==null){this.reset();return;}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
+{this.lastXy=evt.xy;return;}
+lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
+if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
+this.lastXy=evt.xy;}
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},reset:function(evt){if(this.emptyString!=null){this.element.innerHTML=this.emptyString;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
+lonLat.lon.toFixed(digits)+
+this.separator+
+lonLat.lat.toFixed(digits)+
+this.suffix;return newHtml;},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,pinchOrigin:null,currentCenter:null,autoActivate:true,preserveCenter:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},pinchStart:function(evt,pinchData){var xy=(this.preserveCenter)?this.map.getPixelFromLonLat(this.map.getCenter()):evt.xy;this.pinchOrigin=xy;this.currentCenter=xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerOrigin=this.map.layerContainerOriginPx;var pinchOrigin=this.pinchOrigin;var current=(this.preserveCenter)?this.map.getPixelFromLonLat(this.map.getCenter()):evt.xy;var dx=Math.round((containerOrigin.x+current.x-pinchOrigin.x)+(scale-1)*(containerOrigin.x-pinchOrigin.x));var
dy=Math.round((containerOrigin.y+current.y-pinchOrigin.y)+(scale-1)*(containerOrigin.y-pinchOrigin.y));this.map.applyTransform(dx,dy,scale);this.currentCenter=current;},pinchDone:function(evt,start,last){this.map.applyTransform();var zoom=this.map.getZoomForResolution(this.map.getResolution()/last.scale,true);if(zoom!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.div.clientWidth=this.map.div.clientWidth;this.map.setCenter(location,zoom);}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:false,autoActivate:t
rue,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.pinchZoom){this.pinchZoom.destroy();delete this.pinchZoom;}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();this.pinchZoom.activate();return true;}
+return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();this.pinchZoom.deactivate();return true;}
+return false;},draw:function(){var clickCallbacks={click:this.defaultClick,dblclick:this.defaultDblClick};var clickOptions=OpenLayers.Util.extend({"double":true,stopDouble:true,pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){this.map.zoomTo(this.map.zoom+1,evt.xy);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,t
config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
-if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
+if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);}
if(!this.tileFullExtent){this.tileFullExtent=this.maxExtent;}}},moveTo:function(bounds,zoomChanged,dragging){if(zoomChanged||!this.matrix){this.updateMatrixProperties();}
return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMTS(this.options);}
obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getIdentifier:function(){return this.getServerZoom();},getMatrix:function(){var matrix;if(!this.matrixIds||this.matrixIds.length===0){matrix={identifier:this.getIdentifier()};}else{if("scaleDenominator"in this.matrixIds[0]){var denom=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.getServerResolution()/0.28E-3;var diff=Number.POSITIVE_INFINITY;var delta;for(var i=0,ii=this.matrixIds.length;i<ii;++i){delta=Math.abs(1-(this.matrixIds[i].scaleDenominator/denom));if(delta<diff){diff=delta;matrix=this.matrixIds[i];}}}else{matrix=this.matrixIds[this.getIdentifier()];}}
-return matrix;},getTileInfo:function(loc){var res=this.getServerResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;var dimensions=this.dimensions,params;if(this.requestEncoding.toUpperCase()==="REST"){params=this.params;if(typeof this.url==="string"&&this.url.indexOf("{")!==-1){var template=this.url.replace(/\{/g,"${");var context={style:this.style,Style:this.style,TileMatrixSet:this.matrixSet,TileMatrix:this.matrix.identifier,TileRow:info.row,TileCol:info.col};if(dimensions){var dimension,i;for(i=dimensions.
length-1;i>=0;--i){dimension=dimensions[i];context[dimension]=params[dimension.toUpperCase()];}}
+return matrix;},getTileInfo:function(loc){var res=this.getServerResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;var dimensions=this.dimensions,params;if(OpenLayers.Util.isArray(this.url)){url=this.selectUrl([this.version,this.style,this.matrixSet,this.matrix.identifier,info.row,info.col].join(","),this.url);}else{url=this.url;}
+if(this.requestEncoding.toUpperCase()==="REST"){params=this.params;if(url.indexOf("{")!==-1){var template=url.replace(/\{/g,"${");var context={style:this.style,Style:this.style,TileMatrixSet:this.matrixSet,TileMatrix:this.matrix.identifier,TileRow:info.row,TileCol:info.col};if(dimensions){var dimension,i;for(i=dimensions.length-1;i>=0;--i){dimension=dimensions[i];context[dimension]=params[dimension.toUpperCase()];}}
url=OpenLayers.String.format(template,context);}else{var path=this.version+"/"+this.layer+"/"+this.style+"/";if(dimensions){for(var i=0;i<dimensions.length;i++){if(params[dimensions[i]]){path=path+params[dimensions[i]]+"/";}}}
-path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(OpenLayers.Util.isArray(this.url)){url=this.selectUrl(path,this.url);}else{url=this.url;}
-if(!url.match(/\/$/)){url=url+"/";}
+path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(!url.match(/\/$/)){url=url+"/";}
url=url+path;}}else if(this.requestEncoding.toUpperCase()==="KVP"){params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
-return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},CLASS_NAME:"OpenLayers.Layer.WMTS"});
\ No newline at end of file
+return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
+return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,data:null,reqFeatures:null,priv:null,error:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:false,updateWithPO
ST:false,deleteWithPOST:false,wildcarded:false,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var format=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=function(filter,params){return format.write(filter,params);};}},destroy:function(){this.params=null;this.headers=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=options||{};options.params=OpenLayers.Util.applyDefaults(options.params,this.options.params);options=OpenLayers.Util.applyDefaults(options,this.options);if(options.filter&&this.filterToParams){options.params=this.filterToParams(options.filter,options.params);}
+var readWithPOST=(options.readWithPOST!==undefined)?options.readWithPOST:this.readWithPOST;var resp=new OpenLayers.Protocol.Response({requestType:"read"});if(readWithPOST){var headers=options.headers||{};headers["Content-Type"]="application/x-www-form-urlencoded";resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,resp,options),data:OpenLayers.Util.getParameterString(options.params),headers:headers});}else{resp.priv=OpenLayers.Request.GET({url:options.url,callback:this.createCallback(this.handleRead,resp,options),params:options.params,headers:options.headers});}
+return resp;},handleRead:function(resp,options){this.handleResponse(resp,options);},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:features,requestType:"create"});resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleCreate,resp,options),headers:options.headers,data:this.format.write(features)});return resp;},handleCreate:function(resp,options){this.handleResponse(resp,options);},update:function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"update"});var method=this.updateWithPOST?"POST":"PUT";resp.priv=OpenLayers.Request[method]({url:url,callback:this.createCallback(this.handleUpdate,resp,options),headers:options.headers,data:this.format.write(fea
+resp.priv=OpenLayers.Request[method](requestOptions);return resp;},handleDelete:function(resp,options){this.handleResponse(resp,options);},handleResponse:function(resp,options){var request=resp.priv;if(options.callback){if(request.status>=200&&request.status<300){if(resp.requestType!="delete"){resp.features=this.parseFeatures(request);}
+resp.code=OpenLayers.Protocol.Response.SUCCESS;}else{resp.code=OpenLayers.Protocol.Response.FAILURE;}
+options.callback.call(options.scope,resp);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(!doc||doc.length<=0){return null;}
+return this.format.read(doc);},commit:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=[],nResponses=0;var types={};types[OpenLayers.State.INSERT]=[];types[OpenLayers.State.UPDATE]=[];types[OpenLayers.State.DELETE]=[];var feature,list,requestFeatures=[];for(var i=0,len=features.length;i<len;++i){feature=features[i];list=types[feature.state];if(list){list.push(feature);requestFeatures.push(feature);}}
+var nRequests=(types[OpenLayers.State.INSERT].length>0?1:0)+
+types[OpenLayers.State.UPDATE].length+
+types[OpenLayers.State.DELETE].length;var success=true;var finalResponse=new OpenLayers.Protocol.Response({reqFeatures:requestFeatures});function insertCallback(response){var len=response.features?response.features.length:0;var fids=new Array(len);for(var i=0;i<len;++i){fids[i]=response.features[i].fid;}
+finalResponse.insertIds=fids;callback.apply(this,[response]);}
+function callback(response){this.callUserCallback(response,options);success=success&&response.success();nResponses++;if(nResponses>=nRequests){if(options.callback){finalResponse.code=success?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.apply(options.scope,[finalResponse]);}}}
+var queue=types[OpenLayers.State.INSERT];if(queue.length>0){resp.push(this.create(queue,OpenLayers.Util.applyDefaults({callback:insertCallback,scope:this},options.create)));}
+queue=types[OpenLayers.State.UPDATE];for(var i=queue.length-1;i>=0;--i){resp.push(this.update(queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options.update)));}
+queue=types[OpenLayers.State.DELETE];for(var i=queue.length-1;i>=0;--i){resp.push(this["delete"](queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options["delete"])));}
+return resp;},abort:function(response){if(response){response.priv.abort();}},callUserCallback:function(resp,options){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}},CLASS_NAME:"OpenLayers.Protocol.HTTP"});OpenLayers.TileManager=OpenLayers.Class({cacheSize:256,tilesPerFrame:2,frameDelay:16,moveDelay:100,zoomDelay:200,maps:null,tileQueueId:null,tileQueue:null,tileCache:null,tileCacheIndex:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.maps=[];this.tileQueueId={};this.tileQueue={};this.tileCache={};this.tileCacheIndex=[];},addMap:function(map){if(this._destroyed||!OpenLayers.Layer.Grid){return;}
+this.maps.push(map);this.tileQueue[map.id]=[];for(var i=0,ii=map.layers.length;i<ii;++i){this.addLayer({layer:map.layers[i]});}
+map.events.on({move:this.move,zoomend:this.zoomEnd,changelayer:this.changeLayer,addlayer:this.addLayer,preremovelayer:this.removeLayer,scope:this});},removeMap:function(map){if(this._destroyed||!OpenLayers.Layer.Grid){return;}
+window.clearTimeout(this.tileQueueId[map.id]);if(map.layers){for(var i=0,ii=map.layers.length;i<ii;++i){this.removeLayer({layer:map.layers[i]});}}
+if(map.events){map.events.un({move:this.move,zoomend:this.zoomEnd,changelayer:this.changeLayer,addlayer:this.addLayer,preremovelayer:this.removeLayer,scope:this});}
+delete this.tileQueue[map.id];delete this.tileQueueId[map.id];OpenLayers.Util.removeItem(this.maps,map);},move:function(evt){this.updateTimeout(evt.object,this.moveDelay,true);},zoomEnd:function(evt){this.updateTimeout(evt.object,this.zoomDelay);},changeLayer:function(evt){if(evt.property==='visibility'||evt.property==='params'){this.updateTimeout(evt.object,0);}},addLayer:function(evt){var layer=evt.layer;if(layer instanceof OpenLayers.Layer.Grid){layer.events.on({addtile:this.addTile,retile:this.clearTileQueue,scope:this});var i,j,tile;for(i=layer.grid.length-1;i>=0;--i){for(j=layer.grid[i].length-1;j>=0;--j){tile=layer.grid[i][j];this.addTile({tile:tile});if(tile.url&&!tile.imgDiv){this.manageTileCache({object:tile});}}}}},removeLayer:function(evt){var layer=evt.layer;if(layer instanceof OpenLayers.Layer.Grid){this.clearTileQueue({object:layer});if(layer.events){layer.events.un({addtile:this.addTile,retile:this.clearTileQueue,scope:this});}
+if(layer.grid){var i,j,tile;for(i=layer.grid.length-1;i>=0;--i){for(j=layer.grid[i].length-1;j>=0;--j){tile=layer.grid[i][j];this.unloadTile({object:tile});}}}}},updateTimeout:function(map,delay,nice){window.clearTimeout(this.tileQueueId[map.id]);var tileQueue=this.tileQueue[map.id];if(!nice||tileQueue.length){this.tileQueueId[map.id]=window.setTimeout(OpenLayers.Function.bind(function(){this.drawTilesFromQueue(map);if(tileQueue.length){this.updateTimeout(map,this.frameDelay);}},this),delay);}},addTile:function(evt){if(evt.tile instanceof OpenLayers.Tile.Image){evt.tile.events.on({beforedraw:this.queueTileDraw,beforeload:this.manageTileCache,loadend:this.addToCache,unload:this.unloadTile,scope:this});}else{this.removeLayer({layer:evt.tile.layer});}},unloadTile:function(evt){var tile=evt.object;tile.events.un({beforedraw:this.queueTileDraw,beforeload:this.manageTileCache,loadend:this.addToCache,unload:this.unloadTile,scope:this});OpenLayers.Util.removeItem(this.tileQueue[tile
.layer.map.id],tile);},queueTileDraw:function(evt){var tile=evt.object;var queued=false;var layer=tile.layer;var url=layer.getURL(tile.bounds);var img=this.tileCache[url];if(img&&img.className!=='olTileImage'){delete this.tileCache[url];OpenLayers.Util.removeItem(this.tileCacheIndex,url);img=null;}
+if(layer.url&&(layer.async||!img)){var tileQueue=this.tileQueue[layer.map.id];if(!~OpenLayers.Util.indexOf(tileQueue,tile)){tileQueue.push(tile);}
+queued=true;}
+return!queued;},drawTilesFromQueue:function(map){var tileQueue=this.tileQueue[map.id];var limit=this.tilesPerFrame;var animating=map.zoomTween&&map.zoomTween.playing;while(!animating&&tileQueue.length&&limit){tileQueue.shift().draw(true);--limit;}},manageTileCache:function(evt){var tile=evt.object;var img=this.tileCache[tile.url];if(img){if(img.parentNode&&OpenLayers.Element.hasClass(img.parentNode,'olBackBuffer')){img.parentNode.removeChild(img);img.id=null;}
+if(!img.parentNode){img.style.visibility='hidden';img.style.opacity=0;tile.setImage(img);OpenLayers.Util.removeItem(this.tileCacheIndex,tile.url);this.tileCacheIndex.push(tile.url);}}},addToCache:function(evt){var tile=evt.object;if(!this.tileCache[tile.url]){if(!OpenLayers.Element.hasClass(tile.imgDiv,'olImageLoadError')){if(this.tileCacheIndex.length>=this.cacheSize){delete this.tileCache[this.tileCacheIndex[0]];this.tileCacheIndex.shift();}
+this.tileCache[tile.url]=tile.imgDiv;this.tileCacheIndex.push(tile.url);}}},clearTileQueue:function(evt){var layer=evt.object;var tileQueue=this.tileQueue[layer.map.id];for(var i=tileQueue.length-1;i>=0;--i){if(tileQueue[i].layer===layer){tileQueue.splice(i,1);}}},destroy:function(){for(var i=this.maps.length-1;i>=0;--i){this.removeMap(this.maps[i]);}
+this.maps=null;this.tileQueue=null;this.tileQueueId=null;this.tileCache=null;this.tileCacheIndex=null;this._destroyed=true;}});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,observeElement:null,draw:function(){var observeElement=this.observeElement||document;this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress},{observeElement:observeElement});},defaultKeyPress:function(evt){var size,handled=true;var target=OpenLayers.Event.element(evt);if(target&&(target.tagName=='INPUT'||target.tagName=='TEXTAREA'||target.tagName=='SELECT')){return;}
+switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();break;default:handled=false;}
+if(handled){OpenLayers.Event.stop(evt);}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});
Modified: trunk/mapbender/http/extensions/mobilemap/js/dev/2_ngms_global.js
--- trunk/mapbender/http/extensions/mobilemap/js/dev/2_ngms_global.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/dev/2_ngms_global.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -40,18 +40,17 @@
graphicName: 'circle'};
//OpenLayers Symbol (Objekt) GPS-Lokalisierung, mögliche Namen: "star", "cross", "x", "square", "triangle", "circle"
-var olGpsSymbol = { graphicName: 'cross',
- strokeColor: '#871D33',
- strokeWidth: 2,
- fillOpacity: 0,
- pointRadius: 12 };
+var olGpsSymbol = { externalGraphic: 'css/images/gpspoint.png',
+ graphicHeight: 16,
+ graphicWidth:16
//OpenLayers Symbol (Objekt) zur Markierung der GPS-Kreisfarbe + Stil
-var olGpscircleStyle = { fillOpacity: 0.1,
- fillColor: '#000',
+var olGpscircleStyle = { fillOpacity: 0.2,
+ fillColor: '#06C',
+ strokeColor: '#06C',
strokeOpacity: 0.6 };
// default style für Zeichnungen
var sketchSymbolizers = {
"Point": {
@@ -78,7 +77,65 @@
fillOpacity: 0.5
+//Styles für Markierungen
+var umkreisstyles = new OpenLayers.StyleMap({
+ "default": new OpenLayers.Style(null, {
+ rules: [
+ new OpenLayers.Rule({
+ symbolizer: {
+ "Point": {
+ pointRadius: 5,
+ graphicName: "circle",
+ fillColor: "white",
+ fillOpacity: 0.6,
+ strokeWidth: 1,
+ strokeOpacity: 1,
+ strokeColor: "#CC0000"
+ "Line": {
+ strokeWidth: 3,
+ strokeOpacity: 1,
+ "Polygon": {
+ strokeWidth: 2,
+ strokeOpacity: 1,
+ fillColor: "#CC0000",
+//Hilfsfunktion zur Ermittlung des Symbols
+var poicontext = {
+ getGraphic: function(feature) {
+ return feature.attributes.symbol;
+//Template für POIs
+var poitemplate = {
+ externalGraphic: 'config/img/symbol/'+ "${getGraphic}", graphicHeight: 26, graphicWidth:26, cursor:"pointer"
+//Template für selektierte POIs
+var selectpoiTemplate = {
+ externalGraphic: 'config/img/symbol/'+ "${getGraphic}", graphicHeight: 26, graphicWidth:26, cursor:"pointer", fillOpacity: 0.7
+//Definieren der POI-Styles
+var poiStyle = new OpenLayers.Style(poitemplate, {context: poicontext});
+var poiStyleselect = new OpenLayers.Style(selectpoiTemplate, {context: poicontext});
+//StyleMap der POIs
+var styleMapPoi = new OpenLayers.StyleMap({
+ 'default':poiStyle,
+ 'select':poiStyleselect
//default Style für Zeich- / Messfunktion)
var style = new OpenLayers.Style();
style.addRules([
Modified: trunk/mapbender/http/extensions/mobilemap/js/dev/3_ngms_layer.js
--- trunk/mapbender/http/extensions/mobilemap/js/dev/3_ngms_layer.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/dev/3_ngms_layer.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -1,6 +1,9 @@
//Vektorlayer
var vector_marker = new OpenLayers.Layer.Vector("Vector Layer", {});
+//GPS Marker
+var gps_marker = new OpenLayers.Layer.Vector("gps_marker", {
+ rendererOptions: {zIndexing: true}
//Baselayer
var atkis_praes_tms = new OpenLayers.Layer.TMS( "atkis_praes_tms",
"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/",
@@ -93,5 +96,5 @@
//Layer hinzufügen
function addmyLayer(){//Layer hinzufügen
- map.addLayers([atkis_praes_tms, luftbilder, grenze_leer, likar, naturschutzgebiet, vector_marker]);
+ map.addLayers([atkis_praes_tms, luftbilder, grenze_leer, likar, naturschutzgebiet, gps_marker, vector_marker]);
Modified: trunk/mapbender/http/extensions/mobilemap/js/dev/4_ngms_base.js
--- trunk/mapbender/http/extensions/mobilemap/js/dev/4_ngms_base.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/dev/4_ngms_base.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -45,7 +45,7 @@
//map.zoomToMaxExtent();
//map.setCenter(new OpenLayers.LonLat(739108, 6403856),10);
- var geolocate = new OpenLayers.Control.Geolocate({
+ /* var geolocate = new OpenLayers.Control.Geolocate({
geolocationOptions: {
enableHighAccuracy: true,
@@ -55,8 +55,8 @@
map.addControl(geolocate);
- geolocate.events.register("locationupdated", this, function(e) {
+/* geolocate.events.register("locationupdated", this, function(e) {
vector_marker.removeAllFeatures();
vector_marker.addFeatures([
@@ -76,14 +76,7 @@
olGpscircleStyle
- console.log(e.point.x + " - " + e.point.y);
- console.log(map.maxExtent.top);
- console.log(map.maxExtent.bottom);
- console.log(map.maxExtent.left);
- console.log(map.maxExtent.right);
- //Wenn Standoert innerhalb Maxextent
if(e.point.x > map.maxExtent.left && e.point.x < map.maxExtent.right && e.point.y > map.maxExtent.bottom && e.point.y < map.maxExtent.top){
setMarkerhint(window.lang.convert('Positionsgenauigkeit:'),'~ ' + e.position.coords.accuracy + ' Meter');
map.zoomToExtent(vector_marker.getDataExtent());
@@ -92,7 +85,7 @@
alert(window.lang.convert('Die ermittelte Position liegt außerhalb des darstellbaren Kartenausschnitts!'));
$('#markerhint').css('visibility','hidden');
Modified: trunk/mapbender/http/extensions/mobilemap/js/dev/5_ngms_jq.js
--- trunk/mapbender/http/extensions/mobilemap/js/dev/5_ngms_jq.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/dev/5_ngms_jq.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -3,7 +3,6 @@
//Initialisierung
$(document).ready(function() {
// Start with the map page
if (window.location.hash && window.location.hash!='#mappage') {
$.mobile.changePage($("#mappage"),pageTransition);
@@ -100,7 +99,7 @@
//Suchfeld
- $('#searchfield').live('keypress', function(e) {
+ $(document).on('keypress', '#searchfield', function(e) {
if(e.keyCode === 13){
searchCall();
@@ -110,10 +109,40 @@
$(".mapbackbut").click(function(){
$('body').css('overflow', 'hidden');
+ //Popup für erweitertes Popup-Menü initialisieren und öffnen
+ $("#popupMenu").popup();
+ $("#menubut").click(function(){
+ $("#popupMenu").popup( "open" );
+ //Popup für Geolocation Dialog öffnen
+ $("#popupMenu_gps").popup();
+ $("#locatebut").click(function(){
+ $("#popupMenu_gps").popup( "open");
+ //Ausrichtung Popup links oben berechnen und mit hilfsdiv popuppos ausrichten
+ var popupheight = $("#popupMenu_gps").height() / 2 + 68;
+ $('#popuppos').css({top: popupheight+'px'});
+ $("#popupMenu_gps").popup( "open", {x:0,y:0,positionTo:'#popuppos'});
+ //GPS Status ändern
+ $("#gpsstatus").change(function(){
+ var mystatus = this.value;
+ if(mystatus === "on"){
+ startgpsWatch();
+ else{
+ stopgpsWatch();
//Geolocation Aktivieren
- $("#locatebut").click(function(){
+/* $("#locatebut").click(function(){
setMarkerhint(window.lang.convert('Meldung:'),window.lang.convert('bitte warten...'));
var control = map.getControlsBy("id", "locate-control")[0];
if (control.active) {
@@ -121,7 +150,7 @@
} else {
control.activate();
//Baselayer einstellen
@@ -234,7 +263,7 @@
//Suchbutton
- $('.searchbutton').live('touchstart', function(e) {
+ $(document).on('touchstart', '.searchbutton', function(e) {
$(this).css("border","2px solid #808080");
@@ -733,4 +762,115 @@
+//GPS Start Watch Funktion
+var startgpsWatch = function(){
+ if(navigator.geolocation){
+ $('#gpsmessage').html('<div id="gpsmessagebox">start watching...</div>');
+ gpswatch = navigator.geolocation.watchPosition(gpsokCallback, gpsfailCallback, gpsOptions);
+//GPS Stop Watch Funktion
+var stopgpsWatch = function(){
+ navigator.geolocation.clearWatch(gpswatch);
+ $('#gpsmessage').html("");
+ $("#gpsinfo").css('visibility','hidden');
+ gps_marker.removeAllFeatures();
+ $("#activePosition").val("");
+//GPS Erfolgs Callback
+var gpsokCallback = function(position){
+ var gpsmsg = '' +
+ 'Lat: ' + position.coords.latitude + "<br>" +
+ 'Lon: ' + position.coords.longitude + "<br>" +
+ 'Genauigkeit: ~' + Math.round(position.coords.accuracy) + ' m';
+ /*var gpszoombut = '<br>' +
+ '<a href="#" id="zoomGpspoint" data-role="button" data-icon="arrow-r" data-iconpos="right" data-inline="true" data-mini="true" >Zoom auf Position</a>' +
+ '<br><br>' +
+ '<a href="#" id="searchGpspoint" data-role="button" data-icon="search" data-iconpos="right" data-inline="true" data-mini="true" >Suche in der Nähe</a>' +
+ '<br><br>';*/
+ var gpszoombut = '<br>' +
+ '<br><br>';
+ $('#gpsmessage').html(gpszoombut);
+ $('#gpsinfo').html('<strong>Positionierung aktiv</strong><br>' + gpsmsg);
+ $("#gpsinfo").css('visibility','visible');
+ var wgspoint = new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude);
+ var transpoint = wgspoint.transform(wgs84Proj,mapProj);
+ //Zoombutton erzeugen
+ $("#zoomGpspoint").bind( "click", function(event, ui) {
+ map.setCenter(transpoint,getZoomlevel());
+ $("#zoomGpspoint").button();
+ //Suchbutton erzeugen
+ $("#searchGpspoint").bind( "click", function(event, ui) {
+ $.mobile.changePage($("#searchpage2"),pageTransition);
+ $("#searchSort").val('sortdist1');
+ $('#searchSort').selectmenu('refresh');
+ $('#search_results_poi').empty();
+ $('#searchfield_poi').empty();
+ $("#searchGpspoint").button();
+ $("#activePosition").val(Math.round(transpoint.lon) + "," + Math.round(transpoint.lat));
+ //Wenn Standoert innerhalb Maxextent
+ if(transpoint.lon > map.maxExtent.left && transpoint.lon < map.maxExtent.right && transpoint.lat > map.maxExtent.bottom && transpoint.lat < map.maxExtent.top){
+ var geompoint = new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat);
+ var geompoint1 = new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat);
+ gps_marker.addFeatures([
+ new OpenLayers.Feature.Vector(
+ geompoint,
+ olGpsSymbol
+ OpenLayers.Geometry.Polygon.createRegularPolygon(
+ new OpenLayers.Geometry.Point(transpoint.lon, transpoint.lat),
+ position.coords.accuracy / 2,
+ 50,
+ 0
+ olGpscircleStyle
+ //Immer im center halten
+ if($('#gpscenter').val() === "on"){
+ map.setCenter(transpoint);
+ else{
+ alert(window.lang.convert('Die ermittelte Position liegt außerhalb des darstellbaren Kartenausschnitts!'));
+ $("#gpsstatus").val('off');
+ $("#gpsstatus").slider('refresh');
+ stopgpsWatch();
+//GPS Fehler Callback
+var gpsfailCallback = function(e){
+ var msg = 'Fehler ' + e.code + ': ' + e.message;
+ //console.log(msg);
+//GPS Optionen
+var gpsOptions = {
+ enableHighAccuracy: true,
+ timeout: 5000,
+ maximumAge: 0
Added: trunk/mapbender/http/extensions/mobilemap/js/jquery.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/jquery.min.js (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/js/jquery.min.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -0,0 +1,5 @@
+/*! jQuery v1.9.1 | (c) 2005, 2012 jQuery Foundation, Inc. | jquery.org/license
+//@ sourceMappingURL=jquery.min.map
+*/(function(e,t){var n,r,i=typeof t,o=e.document,a=e.location,s=e.jQuery,u=e.$,l={},c=[],p="1.9.1",f=c.concat,d=c.push,h=c.slice,g=c.indexOf,m=l.toString,y=l.hasOwnProperty,v=p.trim,b=function(e,t){return new b.fn.init(e,t,r)},x=/[+-]?(?:\d*\.|)\d+(?:[eE][+-]?\d+|)/.source,w=/\S+/g,T=/^[\s\uFEFF\xA0]+|[\s\uFEFF\xA0]+$/g,N=/^(?:(<[\w\W]+>)[^>]*|#([\w-]*))$/,C=/^<(\w+)\s*\/?>(?:<\/\1>|)$/,k=/^[\],:{}\s]*$/,E=/(?:^|:|,)(?:\s*\[)+/g,S=/\\(?:["\\\/bfnrt]|u[\da-fA-F]{4})/g,A=/"[^"\\\r\n]*"|true|false|null|-?(?:\d+\.|)\d+(?:[eE][+-]?\d+|)/g,j=/^-ms-/,D=/-([\da-z])/gi,L=function(e,t){return t.toUpperCase()},H=function(e){(o.addEventListener||"load"===e.type||"complete"===o.readyState)&&(q(),b.ready())},q=function(){o.addEventListener?(o.removeEventListener("DOMContentLoaded",H,!1),e.removeEventListener("load",H,!1)):(o.detachEvent("onreadystatechange",H),e.detachEvent("onload",H))};b.fn=b.prototype={jquery:p,constructor:b,init:function(e,n,r){var i,a;if(!e)return this;if("string"==t
ypeof e){if(i="<"===e.charAt(0)&&">"===e.charAt(e.length-1)&&e.length>=3?[null,e,null]:N.exec(e),!i||!i[1]&&n)return!n||n.jquery?(n||r).find(e):this.constructor(n).find(e);if(i[1]){if(n=n instanceof b?n[0]:n,b.merge(this,b.parseHTML(i[1],n&&n.nodeType?n.ownerDocument||n:o,!0)),C.test(i[1])&&b.isPlainObject(n))for(i in n)b.isFunction(this[i])?this[i](n[i]):this.attr(i,n[i]);return this}if(a=o.getElementById(i[2]),a&&a.parentNode){if(a.id!==i[2])return r.find(e);this.length=1,this[0]=a}return this.context=o,this.selector=e,this}return e.nodeType?(this.context=this[0]=e,this.length=1,this):b.isFunction(e)?r.ready(e):(e.selector!==t&&(this.selector=e.selector,this.context=e.context),b.makeArray(e,this))},selector:"",length:0,size:function(){return this.length},toArray:function(){return h.call(this)},get:function(e){return null==e?this.toArray():0>e?this[this.length+e]:this[e]},pushStack:function(e){var t=b.merge(this.constructor(),e);return t.prevObject=this,t.context=this.conte
xt,t},each:function(e,t){return b.each(this,e,t)},ready:function(e){return b.ready.promise().done(e),this},slice:function(){return this.pushStack(h.apply(this,arguments))},first:function(){return this.eq(0)},last:function(){return this.eq(-1)},eq:function(e){var t=this.length,n=+e+(0>e?t:0);return this.pushStack(n>=0&&t>n?[this[n]]:[])},map:function(e){return this.pushStack(b.map(this,function(t,n){return e.call(t,n,t)}))},end:function(){return this.prevObject||this.constructor(null)},push:d,sort:[].sort,splice:[].splice},b.fn.init.prototype=b.fn,b.extend=b.fn.extend=function(){var e,n,r,i,o,a,s=arguments[0]||{},u=1,l=arguments.length,c=!1;for("boolean"==typeof s&&(c=s,s=arguments[1]||{},u=2),"object"==typeof s||b.isFunction(s)||(s={}),l===u&&(s=this,--u);l>u;u++)if(null!=(o=arguments[u]))for(i in o)e=s[i],r=o[i],s!==r&&(c&&r&&(b.isPlainObject(r)||(n=b.isArray(r)))?(n?(n=!1,a=e&&b.isArray(e)?e:[]):a=e&&b.isPlainObject(e)?e:{},s[i]=b.extend(c,a,r)):r!==t&&(s[i]=r));return s},
b.extend({noConflict:function(t){return e.$===b&&(e.$=u),t&&e.jQuery===b&&(e.jQuery=s),b},isReady:!1,readyWait:1,holdReady:function(e){e?b.readyWait++:b.ready(!0)},ready:function(e){if(e===!0?!--b.readyWait:!b.isReady){if(!o.body)return setTimeout(b.ready);b.isReady=!0,e!==!0&&--b.readyWait>0||(n.resolveWith(o,[b]),b.fn.trigger&&b(o).trigger("ready").off("ready"))}},isFunction:function(e){return"function"===b.type(e)},isArray:Array.isArray||function(e){return"array"===b.type(e)},isWindow:function(e){return null!=e&&e==e.window},isNumeric:function(e){return!isNaN(parseFloat(e))&&isFinite(e)},type:function(e){return null==e?e+"":"object"==typeof e||"function"==typeof e?l[m.call(e)]||"object":typeof e},isPlainObject:function(e){if(!e||"object"!==b.type(e)||e.nodeType||b.isWindow(e))return!1;try{if(e.constructor&&!y.call(e,"constructor")&&!y.call(e.constructor.prototype,"isPrototypeOf"))return!1}catch(n){return!1}var r;for(r in e);return r===t||y.call(e,r)},isEmptyObject:functio
n(e){var t;for(t in e)return!1;return!0},error:function(e){throw Error(e)},parseHTML:function(e,t,n){if(!e||"string"!=typeof e)return null;"boolean"==typeof t&&(n=t,t=!1),t=t||o;var r=C.exec(e),i=!n&&[];return r?[t.createElement(r[1])]:(r=b.buildFragment([e],t,i),i&&b(i).remove(),b.merge([],r.childNodes))},parseJSON:function(n){return e.JSON&&e.JSON.parse?e.JSON.parse(n):null===n?n:"string"==typeof n&&(n=b.trim(n),n&&k.test(n.replace(S,"@").replace(A,"]").replace(E,"")))?Function("return "+n)():(b.error("Invalid JSON: "+n),t)},parseXML:function(n){var r,i;if(!n||"string"!=typeof n)return null;try{e.DOMParser?(i=new DOMParser,r=i.parseFromString(n,"text/xml")):(r=new ActiveXObject("Microsoft.XMLDOM"),r.async="false",r.loadXML(n))}catch(o){r=t}return r&&r.documentElement&&!r.getElementsByTagName("parsererror").length||b.error("Invalid XML: "+n),r},noop:function(){},globalEval:function(t){t&&b.trim(t)&&(e.execScript||function(t){e.eval.call(e,t)})(t)},camelCase:function(e){retu
rn e.replace(j,"ms-").replace(D,L)},nodeName:function(e,t){return e.nodeName&&e.nodeName.toLowerCase()===t.toLowerCase()},each:function(e,t,n){var r,i=0,o=e.length,a=M(e);if(n){if(a){for(;o>i;i++)if(r=t.apply(e[i],n),r===!1)break}else for(i in e)if(r=t.apply(e[i],n),r===!1)break}else if(a){for(;o>i;i++)if(r=t.call(e[i],i,e[i]),r===!1)break}else for(i in e)if(r=t.call(e[i],i,e[i]),r===!1)break;return e},trim:v&&!v.call("\ufeff\u00a0")?function(e){return null==e?"":v.call(e)}:function(e){return null==e?"":(e+"").replace(T,"")},makeArray:function(e,t){var n=t||[];return null!=e&&(M(Object(e))?b.merge(n,"string"==typeof e?[e]:e):d.call(n,e)),n},inArray:function(e,t,n){var r;if(t){if(g)return g.call(t,e,n);for(r=t.length,n=n?0>n?Math.max(0,r+n):n:0;r>n;n++)if(n in t&&t[n]===e)return n}return-1},merge:function(e,n){var r=n.length,i=e.length,o=0;if("number"==typeof r)for(;r>o;o++)e[i++]=n[o];else while(n[o]!==t)e[i++]=n[o++];return e.length=i,e},grep:function(e,t,n){var r,i=[],o=0,
a=e.length;for(n=!!n;a>o;o++)r=!!t(e[o],o),n!==r&&i.push(e[o]);return i},map:function(e,t,n){var r,i=0,o=e.length,a=M(e),s=[];if(a)for(;o>i;i++)r=t(e[i],i,n),null!=r&&(s[s.length]=r);else for(i in e)r=t(e[i],i,n),null!=r&&(s[s.length]=r);return f.apply([],s)},guid:1,proxy:function(e,n){var r,i,o;return"string"==typeof n&&(o=e[n],n=e,e=o),b.isFunction(e)?(r=h.call(arguments,2),i=function(){return e.apply(n||this,r.concat(h.call(arguments)))},i.guid=e.guid=e.guid||b.guid++,i):t},access:function(e,n,r,i,o,a,s){var u=0,l=e.length,c=null==r;if("object"===b.type(r)){o=!0;for(u in r)b.access(e,n,u,r[u],!0,a,s)}else if(i!==t&&(o=!0,b.isFunction(i)||(s=!0),c&&(s?(n.call(e,i),n=null):(c=n,n=function(e,t,n){return c.call(b(e),n)})),n))for(;l>u;u++)n(e[u],r,s?i:i.call(e[u],u,n(e[u],r)));return o?e:c?n.call(e):l?n(e[0],r):a},now:function(){return(new Date).getTime()}}),b.ready.promise=function(t){if(!n)if(n=b.Deferred(),"complete"===o.readyState)setTimeout(b.ready);else if(o.addEventList
ener)o.addEventListener("DOMContentLoaded",H,!1),e.addEventListener("load",H,!1);else{o.attachEvent("onreadystatechange",H),e.attachEvent("onload",H);var r=!1;try{r=null==e.frameElement&&o.documentElement}catch(i){}r&&r.doScroll&&function a(){if(!b.isReady){try{r.doScroll("left")}catch(e){return setTimeout(a,50)}q(),b.ready()}}()}return n.promise(t)},b.each("Boolean Number String Function Array Date RegExp Object Error".split(" "),function(e,t){l["[object "+t+"]"]=t.toLowerCase()});function M(e){var t=e.length,n=b.type(e);return b.isWindow(e)?!1:1===e.nodeType&&t?!0:"array"===n||"function"!==n&&(0===t||"number"==typeof t&&t>0&&t-1 in e)}r=b(o);var _={};function F(e){var t=_[e]={};return b.each(e.match(w)||[],function(e,n){t[n]=!0}),t}b.Callbacks=function(e){e="string"==typeof e?_[e]||F(e):b.extend({},e);var n,r,i,o,a,s,u=[],l=!e.once&&[],c=function(t){for(r=e.memory&&t,i=!0,a=s||0,s=0,o=u.length,n=!0;u&&o>a;a++)if(u[a].apply(t[0],t[1])===!1&&e.stopOnFalse){r=!1;break}n=!1,u&
&(l?l.length&&c(l.shift()):r?u=[]:p.disable())},p={add:function(){if(u){var t=u.length;(function i(t){b.each(t,function(t,n){var r=b.type(n);"function"===r?e.unique&&p.has(n)||u.push(n):n&&n.length&&"string"!==r&&i(n)})})(arguments),n?o=u.length:r&&(s=t,c(r))}return this},remove:function(){return u&&b.each(arguments,function(e,t){var r;while((r=b.inArray(t,u,r))>-1)u.splice(r,1),n&&(o>=r&&o--,a>=r&&a--)}),this},has:function(e){return e?b.inArray(e,u)>-1:!(!u||!u.length)},empty:function(){return u=[],this},disable:function(){return u=l=r=t,this},disabled:function(){return!u},lock:function(){return l=t,r||p.disable(),this},locked:function(){return!l},fireWith:function(e,t){return t=t||[],t=[e,t.slice?t.slice():t],!u||i&&!l||(n?l.push(t):c(t)),this},fire:function(){return p.fireWith(this,arguments),this},fired:function(){return!!i}};return p},b.extend({Deferred:function(e){var t=[["resolve","done",b.Callbacks("once memory"),"resolved"],["reject","fail",b.Callbacks("once memory"
),"rejected"],["notify","progress",b.Callbacks("memory")]],n="pending",r={state:function(){return n},always:function(){return i.done(arguments).fail(arguments),this},then:function(){var e=arguments;return b.Deferred(function(n){b.each(t,function(t,o){var a=o[0],s=b.isFunction(e[t])&&e[t];i[o[1]](function(){var e=s&&s.apply(this,arguments);e&&b.isFunction(e.promise)?e.promise().done(n.resolve).fail(n.reject).progress(n.notify):n[a+"With"](this===r?n.promise():this,s?[e]:arguments)})}),e=null}).promise()},promise:function(e){return null!=e?b.extend(e,r):r}},i={};return r.pipe=r.then,b.each(t,function(e,o){var a=o[2],s=o[3];r[o[1]]=a.add,s&&a.add(function(){n=s},t[1^e][2].disable,t[2][2].lock),i[o[0]]=function(){return i[o[0]+"With"](this===i?r:this,arguments),this},i[o[0]+"With"]=a.fireWith}),r.promise(i),e&&e.call(i,i),i},when:function(e){var t=0,n=h.call(arguments),r=n.length,i=1!==r||e&&b.isFunction(e.promise)?r:0,o=1===i?e:b.Deferred(),a=function(e,t,n){return function(r){
t[e]=this,n[e]=arguments.length>1?h.call(arguments):r,n===s?o.notifyWith(t,n):--i||o.resolveWith(t,n)}},s,u,l;if(r>1)for(s=Array(r),u=Array(r),l=Array(r);r>t;t++)n[t]&&b.isFunction(n[t].promise)?n[t].promise().done(a(t,l,n)).fail(o.reject).progress(a(t,u,s)):--i;return i||o.resolveWith(l,n),o.promise()}}),b.support=function(){var t,n,r,a,s,u,l,c,p,f,d=o.createElement("div");if(d.setAttribute("className","t"),d.innerHTML=" <link/><table></table><a href='/a'>a</a><input type='checkbox'/>",n=d.getElementsByTagName("*"),r=d.getElementsByTagName("a")[0],!n||!r||!n.length)return{};s=o.createElement("select"),l=s.appendChild(o.createElement("option")),a=d.getElementsByTagName("input")[0],r.style.cssText="top:1px;float:left;opacity:.5",t={getSetAttribute:"t"!==d.className,leadingWhitespace:3===d.firstChild.nodeType,tbody:!d.getElementsByTagName("tbody").length,htmlSerialize:!!d.getElementsByTagName("link").length,style:/top/.test(r.getAttribute("style")),hrefNormalized:"/a"===r.get
Attribute("href"),opacity:/^0.5/.test(r.style.opacity),cssFloat:!!r.style.cssFloat,checkOn:!!a.value,optSelected:l.selected,enctype:!!o.createElement("form").enctype,html5Clone:"<:nav></:nav>"!==o.createElement("nav").cloneNode(!0).outerHTML,boxModel:"CSS1Compat"===o.compatMode,deleteExpando:!0,noCloneEvent:!0,inlineBlockNeedsLayout:!1,shrinkWrapBlocks:!1,reliableMarginRight:!0,boxSizingReliable:!0,pixelPosition:!1},a.checked=!0,t.noCloneChecked=a.cloneNode(!0).checked,s.disabled=!0,t.optDisabled=!l.disabled;try{delete d.test}catch(h){t.deleteExpando=!1}a=o.createElement("input"),a.setAttribute("value",""),t.input=""===a.getAttribute("value"),a.value="t",a.setAttribute("type","radio"),t.radioValue="t"===a.value,a.setAttribute("checked","t"),a.setAttribute("name","t"),u=o.createDocumentFragment(),u.appendChild(a),t.appendChecked=a.checked,t.checkClone=u.cloneNode(!0).cloneNode(!0).lastChild.checked,d.attachEvent&&(d.attachEvent("onclick",function(){t.noCloneEvent=!1}),d.clone
Node(!0).click());for(f in{submit:!0,change:!0,focusin:!0})d.setAttribute(c="on"+f,"t"),t[f+"Bubbles"]=c in e||d.attributes[c].expando===!1;return d.style.backgroundClip="content-box",d.cloneNode(!0).style.backgroundClip="",t.clearCloneStyle="content-box"===d.style.backgroundClip,b(function(){var n,r,a,s="padding:0;margin:0;border:0;display:block;box-sizing:content-box;-moz-box-sizing:content-box;-webkit-box-sizing:content-box;",u=o.getElementsByTagName("body")[0];u&&(n=o.createElement("div"),n.style.cssText="border:0;width:0;height:0;position:absolute;top:0;left:-9999px;margin-top:1px",u.appendChild(n).appendChild(d),d.innerHTML="<table><tr><td></td><td>t</td></tr></table>",a=d.getElementsByTagName("td"),a[0].style.cssText="padding:0;margin:0;border:0;display:none",p=0===a[0].offsetHeight,a[0].style.display="",a[1].style.display="none",t.reliableHiddenOffsets=p&&0===a[0].offsetHeight,d.innerHTML="",d.style.cssText="box-sizing:border-box;-moz-box-sizing:border-box;-webkit-bo
x-sizing:border-box;padding:1px;border:1px;display:block;width:4px;margin-top:1%;position:absolute;top:1%;",t.boxSizing=4===d.offsetWidth,t.doesNotIncludeMarginInBodyOffset=1!==u.offsetTop,e.getComputedStyle&&(t.pixelPosition="1%"!==(e.getComputedStyle(d,null)||{}).top,t.boxSizingReliable="4px"===(e.getComputedStyle(d,null)||{width:"4px"}).width,r=d.appendChild(o.createElement("div")),r.style.cssText=d.style.cssText=s,r.style.marginRight=r.style.width="0",d.style.width="1px",t.reliableMarginRight=!parseFloat((e.getComputedStyle(r,null)||{}).marginRight)),typeof d.style.zoom!==i&&(d.innerHTML="",d.style.cssText=s+"width:1px;padding:1px;display:inline;zoom:1",t.inlineBlockNeedsLayout=3===d.offsetWidth,d.style.display="block",d.innerHTML="<div></div>",d.firstChild.style.width="5px",t.shrinkWrapBlocks=3!==d.offsetWidth,t.inlineBlockNeedsLayout&&(u.style.zoom=1)),u.removeChild(n),n=d=a=r=null)}),n=s=u=l=r=a=null,t}();var O=/(?:\{[\s\S]*\}|\[[\s\S]*\])$/,B=/([A-Z])/g;function P(e,
n,r,i){if(b.acceptData(e)){var o,a,s=b.expando,u="string"==typeof n,l=e.nodeType,p=l?b.cache:e,f=l?e[s]:e[s]&&s;if(f&&p[f]&&(i||p[f].data)||!u||r!==t)return f||(l?e[s]=f=c.pop()||b.guid++:f=s),p[f]||(p[f]={},l||(p[f].toJSON=b.noop)),("object"==typeof n||"function"==typeof n)&&(i?p[f]=b.extend(p[f],n):p[f].data=b.extend(p[f].data,n)),o=p[f],i||(o.data||(o.data={}),o=o.data),r!==t&&(o[b.camelCase(n)]=r),u?(a=o[n],null==a&&(a=o[b.camelCase(n)])):a=o,a}}function R(e,t,n){if(b.acceptData(e)){var r,i,o,a=e.nodeType,s=a?b.cache:e,u=a?e[b.expando]:b.expando;if(s[u]){if(t&&(o=n?s[u]:s[u].data)){b.isArray(t)?t=t.concat(b.map(t,b.camelCase)):t in o?t=[t]:(t=b.camelCase(t),t=t in o?[t]:t.split(" "));for(r=0,i=t.length;i>r;r++)delete o[t[r]];if(!(n?$:b.isEmptyObject)(o))return}(n||(delete s[u].data,$(s[u])))&&(a?b.cleanData([e],!0):b.support.deleteExpando||s!=s.window?delete s[u]:s[u]=null)}}}b.extend({cache:{},expando:"jQuery"+(p+Math.random()).replace(/\D/g,""),noData:{embed:!0,object:
"clsid:D27CDB6E-AE6D-11cf-96B8-444553540000",applet:!0},hasData:function(e){return e=e.nodeType?b.cache[e[b.expando]]:e[b.expando],!!e&&!$(e)},data:function(e,t,n){return P(e,t,n)},removeData:function(e,t){return R(e,t)},_data:function(e,t,n){return P(e,t,n,!0)},_removeData:function(e,t){return R(e,t,!0)},acceptData:function(e){if(e.nodeType&&1!==e.nodeType&&9!==e.nodeType)return!1;var t=e.nodeName&&b.noData[e.nodeName.toLowerCase()];return!t||t!==!0&&e.getAttribute("classid")===t}}),b.fn.extend({data:function(e,n){var r,i,o=this[0],a=0,s=null;if(e===t){if(this.length&&(s=b.data(o),1===o.nodeType&&!b._data(o,"parsedAttrs"))){for(r=o.attributes;r.length>a;a++)i=r[a].name,i.indexOf("data-")||(i=b.camelCase(i.slice(5)),W(o,i,s[i]));b._data(o,"parsedAttrs",!0)}return s}return"object"==typeof e?this.each(function(){b.data(this,e)}):b.access(this,function(n){return n===t?o?W(o,e,b.data(o,e)):null:(this.each(function(){b.data(this,e,n)}),t)},null,n,arguments.length>1,null,!0)},remo
veData:function(e){return this.each(function(){b.removeData(this,e)})}});function W(e,n,r){if(r===t&&1===e.nodeType){var i="data-"+n.replace(B,"-$1").toLowerCase();if(r=e.getAttribute(i),"string"==typeof r){try{r="true"===r?!0:"false"===r?!1:"null"===r?null:+r+""===r?+r:O.test(r)?b.parseJSON(r):r}catch(o){}b.data(e,n,r)}else r=t}return r}function $(e){var t;for(t in e)if(("data"!==t||!b.isEmptyObject(e[t]))&&"toJSON"!==t)return!1;return!0}b.extend({queue:function(e,n,r){var i;return e?(n=(n||"fx")+"queue",i=b._data(e,n),r&&(!i||b.isArray(r)?i=b._data(e,n,b.makeArray(r)):i.push(r)),i||[]):t},dequeue:function(e,t){t=t||"fx";var n=b.queue(e,t),r=n.length,i=n.shift(),o=b._queueHooks(e,t),a=function(){b.dequeue(e,t)};"inprogress"===i&&(i=n.shift(),r--),o.cur=i,i&&("fx"===t&&n.unshift("inprogress"),delete o.stop,i.call(e,a,o)),!r&&o&&o.empty.fire()},_queueHooks:function(e,t){var n=t+"queueHooks";return b._data(e,n)||b._data(e,n,{empty:b.Callbacks("once memory").add(function(){b._r
emoveData(e,t+"queue"),b._removeData(e,n)})})}}),b.fn.extend({queue:function(e,n){var r=2;return"string"!=typeof e&&(n=e,e="fx",r--),r>arguments.length?b.queue(this[0],e):n===t?this:this.each(function(){var t=b.queue(this,e,n);b._queueHooks(this,e),"fx"===e&&"inprogress"!==t[0]&&b.dequeue(this,e)})},dequeue:function(e){return this.each(function(){b.dequeue(this,e)})},delay:function(e,t){return e=b.fx?b.fx.speeds[e]||e:e,t=t||"fx",this.queue(t,function(t,n){var r=setTimeout(t,e);n.stop=function(){clearTimeout(r)}})},clearQueue:function(e){return this.queue(e||"fx",[])},promise:function(e,n){var r,i=1,o=b.Deferred(),a=this,s=this.length,u=function(){--i||o.resolveWith(a,[a])};"string"!=typeof e&&(n=e,e=t),e=e||"fx";while(s--)r=b._data(a[s],e+"queueHooks"),r&&r.empty&&(i++,r.empty.add(u));return u(),o.promise(n)}});var I,z,X=/[\t\r\n]/g,U=/\r/g,V=/^(?:input|select|textarea|button|object)$/i,Y=/^(?:a|area)$/i,J=/^(?:checked|selected|autofocus|autoplay|async|controls|defer|disabl
ed|hidden|loop|multiple|open|readonly|required|scoped)$/i,G=/^(?:checked|selected)$/i,Q=b.support.getSetAttribute,K=b.support.input;b.fn.extend({attr:function(e,t){return b.access(this,b.attr,e,t,arguments.length>1)},removeAttr:function(e){return this.each(function(){b.removeAttr(this,e)})},prop:function(e,t){return b.access(this,b.prop,e,t,arguments.length>1)},removeProp:function(e){return e=b.propFix[e]||e,this.each(function(){try{this[e]=t,delete this[e]}catch(n){}})},addClass:function(e){var t,n,r,i,o,a=0,s=this.length,u="string"==typeof e&&e;if(b.isFunction(e))return this.each(function(t){b(this).addClass(e.call(this,t,this.className))});if(u)for(t=(e||"").match(w)||[];s>a;a++)if(n=this[a],r=1===n.nodeType&&(n.className?(" "+n.className+" ").replace(X," "):" ")){o=0;while(i=t[o++])0>r.indexOf(" "+i+" ")&&(r+=i+" ");n.className=b.trim(r)}return this},removeClass:function(e){var t,n,r,i,o,a=0,s=this.length,u=0===arguments.length||"string"==typeof e&&e;if(b.isFunction(e))r
eturn this.each(function(t){b(this).removeClass(e.call(this,t,this.className))});if(u)for(t=(e||"").match(w)||[];s>a;a++)if(n=this[a],r=1===n.nodeType&&(n.className?(" "+n.className+" ").replace(X," "):"")){o=0;while(i=t[o++])while(r.indexOf(" "+i+" ")>=0)r=r.replace(" "+i+" "," ");n.className=e?b.trim(r):""}return this},toggleClass:function(e,t){var n=typeof e,r="boolean"==typeof t;return b.isFunction(e)?this.each(function(n){b(this).toggleClass(e.call(this,n,this.className,t),t)}):this.each(function(){if("string"===n){var o,a=0,s=b(this),u=t,l=e.match(w)||[];while(o=l[a++])u=r?u:!s.hasClass(o),s[u?"addClass":"removeClass"](o)}else(n===i||"boolean"===n)&&(this.className&&b._data(this,"__className__",this.className),this.className=this.className||e===!1?"":b._data(this,"__className__")||"")})},hasClass:function(e){var t=" "+e+" ",n=0,r=this.length;for(;r>n;n++)if(1===this[n].nodeType&&(" "+this[n].className+" ").replace(X," ").indexOf(t)>=0)return!0;return!1},val:function(e)
{var n,r,i,o=this[0];{if(arguments.length)return i=b.isFunction(e),this.each(function(n){var o,a=b(this);1===this.nodeType&&(o=i?e.call(this,n,a.val()):e,null==o?o="":"number"==typeof o?o+="":b.isArray(o)&&(o=b.map(o,function(e){return null==e?"":e+""})),r=b.valHooks[this.type]||b.valHooks[this.nodeName.toLowerCase()],r&&"set"in r&&r.set(this,o,"value")!==t||(this.value=o))});if(o)return r=b.valHooks[o.type]||b.valHooks[o.nodeName.toLowerCase()],r&&"get"in r&&(n=r.get(o,"value"))!==t?n:(n=o.value,"string"==typeof n?n.replace(U,""):null==n?"":n)}}}),b.extend({valHooks:{option:{get:function(e){var t=e.attributes.value;return!t||t.specified?e.value:e.text}},select:{get:function(e){var t,n,r=e.options,i=e.selectedIndex,o="select-one"===e.type||0>i,a=o?null:[],s=o?i+1:r.length,u=0>i?s:o?i:0;for(;s>u;u++)if(n=r[u],!(!n.selected&&u!==i||(b.support.optDisabled?n.disabled:null!==n.getAttribute("disabled"))||n.parentNode.disabled&&b.nodeName(n.parentNode,"optgroup"))){if(t=b(n).val(),
o)return t;a.push(t)}return a},set:function(e,t){var n=b.makeArray(t);return b(e).find("option").each(function(){this.selected=b.inArray(b(this).val(),n)>=0}),n.length||(e.selectedIndex=-1),n}}},attr:function(e,n,r){var o,a,s,u=e.nodeType;if(e&&3!==u&&8!==u&&2!==u)return typeof e.getAttribute===i?b.prop(e,n,r):(a=1!==u||!b.isXMLDoc(e),a&&(n=n.toLowerCase(),o=b.attrHooks[n]||(J.test(n)?z:I)),r===t?o&&a&&"get"in o&&null!==(s=o.get(e,n))?s:(typeof e.getAttribute!==i&&(s=e.getAttribute(n)),null==s?t:s):null!==r?o&&a&&"set"in o&&(s=o.set(e,r,n))!==t?s:(e.setAttribute(n,r+""),r):(b.removeAttr(e,n),t))},removeAttr:function(e,t){var n,r,i=0,o=t&&t.match(w);if(o&&1===e.nodeType)while(n=o[i++])r=b.propFix[n]||n,J.test(n)?!Q&&G.test(n)?e[b.camelCase("default-"+n)]=e[r]=!1:e[r]=!1:b.attr(e,n,""),e.removeAttribute(Q?n:r)},attrHooks:{type:{set:function(e,t){if(!b.support.radioValue&&"radio"===t&&b.nodeName(e,"input")){var n=e.value;return e.setAttribute("type",t),n&&(e.value=n),t}}}},prop
Fix:{tabindex:"tabIndex",readonly:"readOnly","for":"htmlFor","class":"className",maxlength:"maxLength",cellspacing:"cellSpacing",cellpadding:"cellPadding",rowspan:"rowSpan",colspan:"colSpan",usemap:"useMap",frameborder:"frameBorder",contenteditable:"contentEditable"},prop:function(e,n,r){var i,o,a,s=e.nodeType;if(e&&3!==s&&8!==s&&2!==s)return a=1!==s||!b.isXMLDoc(e),a&&(n=b.propFix[n]||n,o=b.propHooks[n]),r!==t?o&&"set"in o&&(i=o.set(e,r,n))!==t?i:e[n]=r:o&&"get"in o&&null!==(i=o.get(e,n))?i:e[n]},propHooks:{tabIndex:{get:function(e){var n=e.getAttributeNode("tabindex");return n&&n.specified?parseInt(n.value,10):V.test(e.nodeName)||Y.test(e.nodeName)&&e.href?0:t}}}}),z={get:function(e,n){var r=b.prop(e,n),i="boolean"==typeof r&&e.getAttribute(n),o="boolean"==typeof r?K&&Q?null!=i:G.test(n)?e[b.camelCase("default-"+n)]:!!i:e.getAttributeNode(n);return o&&o.value!==!1?n.toLowerCase():t},set:function(e,t,n){return t===!1?b.removeAttr(e,n):K&&Q||!G.test(n)?e.setAttribute(!Q&&b.p
ropFix[n]||n,n):e[b.camelCase("default-"+n)]=e[n]=!0,n}},K&&Q||(b.attrHooks.value={get:function(e,n){var r=e.getAttributeNode(n);return b.nodeName(e,"input")?e.defaultValue:r&&r.specified?r.value:t},set:function(e,n,r){return b.nodeName(e,"input")?(e.defaultValue=n,t):I&&I.set(e,n,r)}}),Q||(I=b.valHooks.button={get:function(e,n){var r=e.getAttributeNode(n);return r&&("id"===n||"name"===n||"coords"===n?""!==r.value:r.specified)?r.value:t},set:function(e,n,r){var i=e.getAttributeNode(r);return i||e.setAttributeNode(i=e.ownerDocument.createAttribute(r)),i.value=n+="","value"===r||n===e.getAttribute(r)?n:t}},b.attrHooks.contenteditable={get:I.get,set:function(e,t,n){I.set(e,""===t?!1:t,n)}},b.each(["width","height"],function(e,n){b.attrHooks[n]=b.extend(b.attrHooks[n],{set:function(e,r){return""===r?(e.setAttribute(n,"auto"),r):t}})})),b.support.hrefNormalized||(b.each(["href","src","width","height"],function(e,n){b.attrHooks[n]=b.extend(b.attrHooks[n],{get:function(e){var r=e.g
etAttribute(n,2);return null==r?t:r}})}),b.each(["href","src"],function(e,t){b.propHooks[t]={get:function(e){return e.getAttribute(t,4)}}})),b.support.style||(b.attrHooks.style={get:function(e){return e.style.cssText||t},set:function(e,t){return e.style.cssText=t+""}}),b.support.optSelected||(b.propHooks.selected=b.extend(b.propHooks.selected,{get:function(e){var t=e.parentNode;return t&&(t.selectedIndex,t.parentNode&&t.parentNode.selectedIndex),null}})),b.support.enctype||(b.propFix.enctype="encoding"),b.support.checkOn||b.each(["radio","checkbox"],function(){b.valHooks[this]={get:function(e){return null===e.getAttribute("value")?"on":e.value}}}),b.each(["radio","checkbox"],function(){b.valHooks[this]=b.extend(b.valHooks[this],{set:function(e,n){return b.isArray(n)?e.checked=b.inArray(b(e).val(),n)>=0:t}})});var Z=/^(?:input|select|textarea)$/i,et=/^key/,tt=/^(?:mouse|contextmenu)|click/,nt=/^(?:focusinfocus|focusoutblur)$/,rt=/^([^.]*)(?:\.(.+)|)$/;function it(){return!0}f
unction ot(){return!1}b.event={global:{},add:function(e,n,r,o,a){var s,u,l,c,p,f,d,h,g,m,y,v=b._data(e);if(v){r.handler&&(c=r,r=c.handler,a=c.selector),r.guid||(r.guid=b.guid++),(u=v.events)||(u=v.events={}),(f=v.handle)||(f=v.handle=function(e){return typeof b===i||e&&b.event.triggered===e.type?t:b.event.dispatch.apply(f.elem,arguments)},f.elem=e),n=(n||"").match(w)||[""],l=n.length;while(l--)s=rt.exec(n[l])||[],g=y=s[1],m=(s[2]||"").split(".").sort(),p=b.event.special[g]||{},g=(a?p.delegateType:p.bindType)||g,p=b.event.special[g]||{},d=b.extend({type:g,origType:y,data:o,handler:r,guid:r.guid,selector:a,needsContext:a&&b.expr.match.needsContext.test(a),namespace:m.join(".")},c),(h=u[g])||(h=u[g]=[],h.delegateCount=0,p.setup&&p.setup.call(e,o,m,f)!==!1||(e.addEventListener?e.addEventListener(g,f,!1):e.attachEvent&&e.attachEvent("on"+g,f))),p.add&&(p.add.call(e,d),d.handler.guid||(d.handler.guid=r.guid)),a?h.splice(h.delegateCount++,0,d):h.push(d),b.event.global[g]=!0;e=null}
},remove:function(e,t,n,r,i){var o,a,s,u,l,c,p,f,d,h,g,m=b.hasData(e)&&b._data(e);if(m&&(c=m.events)){t=(t||"").match(w)||[""],l=t.length;while(l--)if(s=rt.exec(t[l])||[],d=g=s[1],h=(s[2]||"").split(".").sort(),d){p=b.event.special[d]||{},d=(r?p.delegateType:p.bindType)||d,f=c[d]||[],s=s[2]&&RegExp("(^|\\.)"+h.join("\\.(?:.*\\.|)")+"(\\.|$)"),u=o=f.length;while(o--)a=f[o],!i&&g!==a.origType||n&&n.guid!==a.guid||s&&!s.test(a.namespace)||r&&r!==a.selector&&("**"!==r||!a.selector)||(f.splice(o,1),a.selector&&f.delegateCount--,p.remove&&p.remove.call(e,a));u&&!f.length&&(p.teardown&&p.teardown.call(e,h,m.handle)!==!1||b.removeEvent(e,d,m.handle),delete c[d])}else for(d in c)b.event.remove(e,d+t[l],n,r,!0);b.isEmptyObject(c)&&(delete m.handle,b._removeData(e,"events"))}},trigger:function(n,r,i,a){var s,u,l,c,p,f,d,h=[i||o],g=y.call(n,"type")?n.type:n,m=y.call(n,"namespace")?n.namespace.split("."):[];if(l=f=i=i||o,3!==i.nodeType&&8!==i.nodeType&&!nt.test(g+b.event.triggered)&&(g.i
ndexOf(".")>=0&&(m=g.split("."),g=m.shift(),m.sort()),u=0>g.indexOf(":")&&"on"+g,n=n[b.expando]?n:new b.Event(g,"object"==typeof n&&n),n.isTrigger=!0,n.namespace=m.join("."),n.namespace_re=n.namespace?RegExp("(^|\\.)"+m.join("\\.(?:.*\\.|)")+"(\\.|$)"):null,n.result=t,n.target||(n.target=i),r=null==r?[n]:b.makeArray(r,[n]),p=b.event.special[g]||{},a||!p.trigger||p.trigger.apply(i,r)!==!1)){if(!a&&!p.noBubble&&!b.isWindow(i)){for(c=p.delegateType||g,nt.test(c+g)||(l=l.parentNode);l;l=l.parentNode)h.push(l),f=l;f===(i.ownerDocument||o)&&h.push(f.defaultView||f.parentWindow||e)}d=0;while((l=h[d++])&&!n.isPropagationStopped())n.type=d>1?c:p.bindType||g,s=(b._data(l,"events")||{})[n.type]&&b._data(l,"handle"),s&&s.apply(l,r),s=u&&l[u],s&&b.acceptData(l)&&s.apply&&s.apply(l,r)===!1&&n.preventDefault();if(n.type=g,!(a||n.isDefaultPrevented()||p._default&&p._default.apply(i.ownerDocument,r)!==!1||"click"===g&&b.nodeName(i,"a")||!b.acceptData(i)||!u||!i[g]||b.isWindow(i))){f=i[u],f&&
(i[u]=null),b.event.triggered=g;try{i[g]()}catch(v){}b.event.triggered=t,f&&(i[u]=f)}return n.result}},dispatch:function(e){e=b.event.fix(e);var n,r,i,o,a,s=[],u=h.call(arguments),l=(b._data(this,"events")||{})[e.type]||[],c=b.event.special[e.type]||{};if(u[0]=e,e.delegateTarget=this,!c.preDispatch||c.preDispatch.call(this,e)!==!1){s=b.event.handlers.call(this,e,l),n=0;while((o=s[n++])&&!e.isPropagationStopped()){e.currentTarget=o.elem,a=0;while((i=o.handlers[a++])&&!e.isImmediatePropagationStopped())(!e.namespace_re||e.namespace_re.test(i.namespace))&&(e.handleObj=i,e.data=i.data,r=((b.event.special[i.origType]||{}).handle||i.handler).apply(o.elem,u),r!==t&&(e.result=r)===!1&&(e.preventDefault(),e.stopPropagation()))}return c.postDispatch&&c.postDispatch.call(this,e),e.result}},handlers:function(e,n){var r,i,o,a,s=[],u=n.delegateCount,l=e.target;if(u&&l.nodeType&&(!e.button||"click"!==e.type))for(;l!=this;l=l.parentNode||this)if(1===l.nodeType&&(l.disabled!==!0||"click"!==e
.type)){for(o=[],a=0;u>a;a++)i=n[a],r=i.selector+" ",o[r]===t&&(o[r]=i.needsContext?b(r,this).index(l)>=0:b.find(r,this,null,[l]).length),o[r]&&o.push(i);o.length&&s.push({elem:l,handlers:o})}return n.length>u&&s.push({elem:this,handlers:n.slice(u)}),s},fix:function(e){if(e[b.expando])return e;var t,n,r,i=e.type,a=e,s=this.fixHooks[i];s||(this.fixHooks[i]=s=tt.test(i)?this.mouseHooks:et.test(i)?this.keyHooks:{}),r=s.props?this.props.concat(s.props):this.props,e=new b.Event(a),t=r.length;while(t--)n=r[t],e[n]=a[n];return e.target||(e.target=a.srcElement||o),3===e.target.nodeType&&(e.target=e.target.parentNode),e.metaKey=!!e.metaKey,s.filter?s.filter(e,a):e},props:"altKey bubbles cancelable ctrlKey currentTarget eventPhase metaKey relatedTarget shiftKey target timeStamp view which".split(" "),fixHooks:{},keyHooks:{props:"char charCode key keyCode".split(" "),filter:function(e,t){return null==e.which&&(e.which=null!=t.charCode?t.charCode:t.keyCode),e}},mouseHooks:{props:"button
buttons clientX clientY fromElement offsetX offsetY pageX pageY screenX screenY toElement".split(" "),filter:function(e,n){var r,i,a,s=n.button,u=n.fromElement;return null==e.pageX&&null!=n.clientX&&(i=e.target.ownerDocument||o,a=i.documentElement,r=i.body,e.pageX=n.clientX+(a&&a.scrollLeft||r&&r.scrollLeft||0)-(a&&a.clientLeft||r&&r.clientLeft||0),e.pageY=n.clientY+(a&&a.scrollTop||r&&r.scrollTop||0)-(a&&a.clientTop||r&&r.clientTop||0)),!e.relatedTarget&&u&&(e.relatedTarget=u===e.target?n.toElement:u),e.which||s===t||(e.which=1&s?1:2&s?3:4&s?2:0),e}},special:{load:{noBubble:!0},click:{trigger:function(){return b.nodeName(this,"input")&&"checkbox"===this.type&&this.click?(this.click(),!1):t}},focus:{trigger:function(){if(this!==o.activeElement&&this.focus)try{return this.focus(),!1}catch(e){}},delegateType:"focusin"},blur:{trigger:function(){return this===o.activeElement&&this.blur?(this.blur(),!1):t},delegateType:"focusout"},beforeunload:{postDispatch:function(e){e.result!
==t&&(e.originalEvent.returnValue=e.result)}}},simulate:function(e,t,n,r){var i=b.extend(new b.Event,n,{type:e,isSimulated:!0,originalEvent:{}});r?b.event.trigger(i,null,t):b.event.dispatch.call(t,i),i.isDefaultPrevented()&&n.preventDefault()}},b.removeEvent=o.removeEventListener?function(e,t,n){e.removeEventListener&&e.removeEventListener(t,n,!1)}:function(e,t,n){var r="on"+t;e.detachEvent&&(typeof e[r]===i&&(e[r]=null),e.detachEvent(r,n))},b.Event=function(e,n){return this instanceof b.Event?(e&&e.type?(this.originalEvent=e,this.type=e.type,this.isDefaultPrevented=e.defaultPrevented||e.returnValue===!1||e.getPreventDefault&&e.getPreventDefault()?it:ot):this.type=e,n&&b.extend(this,n),this.timeStamp=e&&e.timeStamp||b.now(),this[b.expando]=!0,t):new b.Event(e,n)},b.Event.prototype={isDefaultPrevented:ot,isPropagationStopped:ot,isImmediatePropagationStopped:ot,preventDefault:function(){var e=this.originalEvent;this.isDefaultPrevented=it,e&&(e.preventDefault?e.preventDefault()
:e.returnValue=!1)},stopPropagation:function(){var e=this.originalEvent;this.isPropagationStopped=it,e&&(e.stopPropagation&&e.stopPropagation(),e.cancelBubble=!0)},stopImmediatePropagation:function(){this.isImmediatePropagationStopped=it,this.stopPropagation()}},b.each({mouseenter:"mouseover",mouseleave:"mouseout"},function(e,t){b.event.special[e]={delegateType:t,bindType:t,handle:function(e){var n,r=this,i=e.relatedTarget,o=e.handleObj;
+return(!i||i!==r&&!b.contains(r,i))&&(e.type=o.origType,n=o.handler.apply(this,arguments),e.type=t),n}}}),b.support.submitBubbles||(b.event.special.submit={setup:function(){return b.nodeName(this,"form")?!1:(b.event.add(this,"click._submit keypress._submit",function(e){var n=e.target,r=b.nodeName(n,"input")||b.nodeName(n,"button")?n.form:t;r&&!b._data(r,"submitBubbles")&&(b.event.add(r,"submit._submit",function(e){e._submit_bubble=!0}),b._data(r,"submitBubbles",!0))}),t)},postDispatch:function(e){e._submit_bubble&&(delete e._submit_bubble,this.parentNode&&!e.isTrigger&&b.event.simulate("submit",this.parentNode,e,!0))},teardown:function(){return b.nodeName(this,"form")?!1:(b.event.remove(this,"._submit"),t)}}),b.support.changeBubbles||(b.event.special.change={setup:function(){return Z.test(this.nodeName)?(("checkbox"===this.type||"radio"===this.type)&&(b.event.add(this,"propertychange._change",function(e){"checked"===e.originalEvent.propertyName&&(this._just_changed=!0)}),b.e
vent.add(this,"click._change",function(e){this._just_changed&&!e.isTrigger&&(this._just_changed=!1),b.event.simulate("change",this,e,!0)})),!1):(b.event.add(this,"beforeactivate._change",function(e){var t=e.target;Z.test(t.nodeName)&&!b._data(t,"changeBubbles")&&(b.event.add(t,"change._change",function(e){!this.parentNode||e.isSimulated||e.isTrigger||b.event.simulate("change",this.parentNode,e,!0)}),b._data(t,"changeBubbles",!0))}),t)},handle:function(e){var n=e.target;return this!==n||e.isSimulated||e.isTrigger||"radio"!==n.type&&"checkbox"!==n.type?e.handleObj.handler.apply(this,arguments):t},teardown:function(){return b.event.remove(this,"._change"),!Z.test(this.nodeName)}}),b.support.focusinBubbles||b.each({focus:"focusin",blur:"focusout"},function(e,t){var n=0,r=function(e){b.event.simulate(t,e.target,b.event.fix(e),!0)};b.event.special[t]={setup:function(){0===n++&&o.addEventListener(e,r,!0)},teardown:function(){0===--n&&o.removeEventListener(e,r,!0)}}}),b.fn.extend({o
n:function(e,n,r,i,o){var a,s;if("object"==typeof e){"string"!=typeof n&&(r=r||n,n=t);for(a in e)this.on(a,n,r,e[a],o);return this}if(null==r&&null==i?(i=n,r=n=t):null==i&&("string"==typeof n?(i=r,r=t):(i=r,r=n,n=t)),i===!1)i=ot;else if(!i)return this;return 1===o&&(s=i,i=function(e){return b().off(e),s.apply(this,arguments)},i.guid=s.guid||(s.guid=b.guid++)),this.each(function(){b.event.add(this,e,i,r,n)})},one:function(e,t,n,r){return this.on(e,t,n,r,1)},off:function(e,n,r){var i,o;if(e&&e.preventDefault&&e.handleObj)return i=e.handleObj,b(e.delegateTarget).off(i.namespace?i.origType+"."+i.namespace:i.origType,i.selector,i.handler),this;if("object"==typeof e){for(o in e)this.off(o,n,e[o]);return this}return(n===!1||"function"==typeof n)&&(r=n,n=t),r===!1&&(r=ot),this.each(function(){b.event.remove(this,e,r,n)})},bind:function(e,t,n){return this.on(e,null,t,n)},unbind:function(e,t){return this.off(e,null,t)},delegate:function(e,t,n,r){return this.on(t,e,n,r)},undelegate:fun
ction(e,t,n){return 1===arguments.length?this.off(e,"**"):this.off(t,e||"**",n)},trigger:function(e,t){return this.each(function(){b.event.trigger(e,t,this)})},triggerHandler:function(e,n){var r=this[0];return r?b.event.trigger(e,n,r,!0):t}}),function(e,t){var n,r,i,o,a,s,u,l,c,p,f,d,h,g,m,y,v,x="sizzle"+-new Date,w=e.document,T={},N=0,C=0,k=it(),E=it(),S=it(),A=typeof t,j=1<<31,D=[],L=D.pop,H=D.push,q=D.slice,M=D.indexOf||function(e){var t=0,n=this.length;for(;n>t;t++)if(this[t]===e)return t;return-1},_="[\\x20\\t\\r\\n\\f]",F="(?:\\\\.|[\\w-]|[^\\x00-\\xa0])+",O=F.replace("w","w#"),B="([*^$|!~]?=)",P="\\["+_+"*("+F+")"+_+"*(?:"+B+_+"*(?:(['\"])((?:\\\\.|[^\\\\])*?)\\3|("+O+")|)|)"+_+"*\\]",R=":("+F+")(?:\\(((['\"])((?:\\\\.|[^\\\\])*?)\\3|((?:\\\\.|[^\\\\()[\\]]|"+P.replace(3,8)+")*)|.*)\\)|)",W=RegExp("^"+_+"+|((?:^|[^\\\\])(?:\\\\.)*)"+_+"+$","g"),$=RegExp("^"+_+"*,"+_+"*"),I=RegExp("^"+_+"*([\\x20\\t\\r\\n\\f>+~])"+_+"*"),z=RegExp(R),X=RegExp("^"+O+"$"),U={ID:RegExp("^#
("+F+")"),CLASS:RegExp("^\\.("+F+")"),NAME:RegExp("^\\[name=['\"]?("+F+")['\"]?\\]"),TAG:RegExp("^("+F.replace("w","w*")+")"),ATTR:RegExp("^"+P),PSEUDO:RegExp("^"+R),CHILD:RegExp("^:(only|first|last|nth|nth-last)-(child|of-type)(?:\\("+_+"*(even|odd|(([+-]|)(\\d*)n|)"+_+"*(?:([+-]|)"+_+"*(\\d+)|))"+_+"*\\)|)","i"),needsContext:RegExp("^"+_+"*[>+~]|:(even|odd|eq|gt|lt|nth|first|last)(?:\\("+_+"*((?:-\\d)?\\d*)"+_+"*\\)|)(?=[^-]|$)","i")},V=/[\x20\t\r\n\f]*[+~]/,Y=/^[^{]+\{\s*\[native code/,J=/^(?:#([\w-]+)|(\w+)|\.([\w-]+))$/,G=/^(?:input|select|textarea|button)$/i,Q=/^h\d$/i,K=/'|\\/g,Z=/\=[\x20\t\r\n\f]*([^'"\]]*)[\x20\t\r\n\f]*\]/g,et=/\\([\da-fA-F]{1,6}[\x20\t\r\n\f]?|.)/g,tt=function(e,t){var n="0x"+t-65536;return n!==n?t:0>n?String.fromCharCode(n+65536):String.fromCharCode(55296|n>>10,56320|1023&n)};try{q.call(w.documentElement.childNodes,0)[0].nodeType}catch(nt){q=function(e){var t,n=[];while(t=this[e++])n.push(t);return n}}function rt(e){return Y.test(e+"")}function i
t(){var e,t=[];return e=function(n,r){return t.push(n+=" ")>i.cacheLength&&delete e[t.shift()],e[n]=r}}function ot(e){return e[x]=!0,e}function at(e){var t=p.createElement("div");try{return e(t)}catch(n){return!1}finally{t=null}}function st(e,t,n,r){var i,o,a,s,u,l,f,g,m,v;if((t?t.ownerDocument||t:w)!==p&&c(t),t=t||p,n=n||[],!e||"string"!=typeof e)return n;if(1!==(s=t.nodeType)&&9!==s)return[];if(!d&&!r){if(i=J.exec(e))if(a=i[1]){if(9===s){if(o=t.getElementById(a),!o||!o.parentNode)return n;if(o.id===a)return n.push(o),n}else if(t.ownerDocument&&(o=t.ownerDocument.getElementById(a))&&y(t,o)&&o.id===a)return n.push(o),n}else{if(i[2])return H.apply(n,q.call(t.getElementsByTagName(e),0)),n;if((a=i[3])&&T.getByClassName&&t.getElementsByClassName)return H.apply(n,q.call(t.getElementsByClassName(a),0)),n}if(T.qsa&&!h.test(e)){if(f=!0,g=x,m=t,v=9===s&&e,1===s&&"object"!==t.nodeName.toLowerCase()){l=ft(e),(f=t.getAttribute("id"))?g=f.replace(K,"\\$&"):t.setAttribute("id",g),g="[id='
"+g+"'] ",u=l.length;while(u--)l[u]=g+dt(l[u]);m=V.test(e)&&t.parentNode||t,v=l.join(",")}if(v)try{return H.apply(n,q.call(m.querySelectorAll(v),0)),n}catch(b){}finally{f||t.removeAttribute("id")}}}return wt(e.replace(W,"$1"),t,n,r)}a=st.isXML=function(e){var t=e&&(e.ownerDocument||e).documentElement;return t?"HTML"!==t.nodeName:!1},c=st.setDocument=function(e){var n=e?e.ownerDocument||e:w;return n!==p&&9===n.nodeType&&n.documentElement?(p=n,f=n.documentElement,d=a(n),T.tagNameNoComments=at(function(e){return e.appendChild(n.createComment("")),!e.getElementsByTagName("*").length}),T.attributes=at(function(e){e.innerHTML="<select></select>";var t=typeof e.lastChild.getAttribute("multiple");return"boolean"!==t&&"string"!==t}),T.getByClassName=at(function(e){return e.innerHTML="<div class='hidden e'></div><div class='hidden'></div>",e.getElementsByClassName&&e.getElementsByClassName("e").length?(e.lastChild.className="e",2===e.getElementsByClassName("e").length):!1}),T.getByNam
e=at(function(e){e.id=x+0,e.innerHTML="<a name='"+x+"'></a><div name='"+x+"'></div>",f.insertBefore(e,f.firstChild);var t=n.getElementsByName&&n.getElementsByName(x).length===2+n.getElementsByName(x+0).length;return T.getIdNotName=!n.getElementById(x),f.removeChild(e),t}),i.attrHandle=at(function(e){return e.innerHTML="<a href='#'></a>",e.firstChild&&typeof e.firstChild.getAttribute!==A&&"#"===e.firstChild.getAttribute("href")})?{}:{href:function(e){return e.getAttribute("href",2)},type:function(e){return e.getAttribute("type")}},T.getIdNotName?(i.find.ID=function(e,t){if(typeof t.getElementById!==A&&!d){var n=t.getElementById(e);return n&&n.parentNode?[n]:[]}},i.filter.ID=function(e){var t=e.replace(et,tt);return function(e){return e.getAttribute("id")===t}}):(i.find.ID=function(e,n){if(typeof n.getElementById!==A&&!d){var r=n.getElementById(e);return r?r.id===e||typeof r.getAttributeNode!==A&&r.getAttributeNode("id").value===e?[r]:t:[]}},i.filter.ID=function(e){var t=e.rep
lace(et,tt);return function(e){var n=typeof e.getAttributeNode!==A&&e.getAttributeNode("id");return n&&n.value===t}}),i.find.TAG=T.tagNameNoComments?function(e,n){return typeof n.getElementsByTagName!==A?n.getElementsByTagName(e):t}:function(e,t){var n,r=[],i=0,o=t.getElementsByTagName(e);if("*"===e){while(n=o[i++])1===n.nodeType&&r.push(n);return r}return o},i.find.NAME=T.getByName&&function(e,n){return typeof n.getElementsByName!==A?n.getElementsByName(name):t},i.find.CLASS=T.getByClassName&&function(e,n){return typeof n.getElementsByClassName===A||d?t:n.getElementsByClassName(e)},g=[],h=[":focus"],(T.qsa=rt(n.querySelectorAll))&&(at(function(e){e.innerHTML="<select><option selected=''></option></select>",e.querySelectorAll("[selected]").length||h.push("\\["+_+"*(?:checked|disabled|ismap|multiple|readonly|selected|value)"),e.querySelectorAll(":checked").length||h.push(":checked")}),at(function(e){e.innerHTML="<input type='hidden' i=''/>",e.querySelectorAll("[i^='']").lengt
h&&h.push("[*^$]="+_+"*(?:\"\"|'')"),e.querySelectorAll(":enabled").length||h.push(":enabled",":disabled"),e.querySelectorAll("*,:x"),h.push(",.*:")})),(T.matchesSelector=rt(m=f.matchesSelector||f.mozMatchesSelector||f.webkitMatchesSelector||f.oMatchesSelector||f.msMatchesSelector))&&at(function(e){T.disconnectedMatch=m.call(e,"div"),m.call(e,"[s!='']:x"),g.push("!=",R)}),h=RegExp(h.join("|")),g=RegExp(g.join("|")),y=rt(f.contains)||f.compareDocumentPosition?function(e,t){var n=9===e.nodeType?e.documentElement:e,r=t&&t.parentNode;return e===r||!(!r||1!==r.nodeType||!(n.contains?n.contains(r):e.compareDocumentPosition&&16&e.compareDocumentPosition(r)))}:function(e,t){if(t)while(t=t.parentNode)if(t===e)return!0;return!1},v=f.compareDocumentPosition?function(e,t){var r;return e===t?(u=!0,0):(r=t.compareDocumentPosition&&e.compareDocumentPosition&&e.compareDocumentPosition(t))?1&r||e.parentNode&&11===e.parentNode.nodeType?e===n||y(w,e)?-1:t===n||y(w,t)?1:0:4&r?-1:1:e.compareDocu
mentPosition?-1:1}:function(e,t){var r,i=0,o=e.parentNode,a=t.parentNode,s=[e],l=[t];if(e===t)return u=!0,0;if(!o||!a)return e===n?-1:t===n?1:o?-1:a?1:0;if(o===a)return ut(e,t);r=e;while(r=r.parentNode)s.unshift(r);r=t;while(r=r.parentNode)l.unshift(r);while(s[i]===l[i])i++;return i?ut(s[i],l[i]):s[i]===w?-1:l[i]===w?1:0},u=!1,[0,0].sort(v),T.detectDuplicates=u,p):p},st.matches=function(e,t){return st(e,null,null,t)},st.matchesSelector=function(e,t){if((e.ownerDocument||e)!==p&&c(e),t=t.replace(Z,"='$1']"),!(!T.matchesSelector||d||g&&g.test(t)||h.test(t)))try{var n=m.call(e,t);if(n||T.disconnectedMatch||e.document&&11!==e.document.nodeType)return n}catch(r){}return st(t,p,null,[e]).length>0},st.contains=function(e,t){return(e.ownerDocument||e)!==p&&c(e),y(e,t)},st.attr=function(e,t){var n;return(e.ownerDocument||e)!==p&&c(e),d||(t=t.toLowerCase()),(n=i.attrHandle[t])?n(e):d||T.attributes?e.getAttribute(t):((n=e.getAttributeNode(t))||e.getAttribute(t))&&e[t]===!0?t:n&&n.speci
fied?n.value:null},st.error=function(e){throw Error("Syntax error, unrecognized expression: "+e)},st.uniqueSort=function(e){var t,n=[],r=1,i=0;if(u=!T.detectDuplicates,e.sort(v),u){for(;t=e[r];r++)t===e[r-1]&&(i=n.push(r));while(i--)e.splice(n[i],1)}return e};function ut(e,t){var n=t&&e,r=n&&(~t.sourceIndex||j)-(~e.sourceIndex||j);if(r)return r;if(n)while(n=n.nextSibling)if(n===t)return-1;return e?1:-1}function lt(e){return function(t){var n=t.nodeName.toLowerCase();return"input"===n&&t.type===e}}function ct(e){return function(t){var n=t.nodeName.toLowerCase();return("input"===n||"button"===n)&&t.type===e}}function pt(e){return ot(function(t){return t=+t,ot(function(n,r){var i,o=e([],n.length,t),a=o.length;while(a--)n[i=o[a]]&&(n[i]=!(r[i]=n[i]))})})}o=st.getText=function(e){var t,n="",r=0,i=e.nodeType;if(i){if(1===i||9===i||11===i){if("string"==typeof e.textContent)return e.textContent;for(e=e.firstChild;e;e=e.nextSibling)n+=o(e)}else if(3===i||4===i)return e.nodeValue}else
for(;t=e[r];r++)n+=o(t);return n},i=st.selectors={cacheLength:50,createPseudo:ot,match:U,find:{},relative:{">":{dir:"parentNode",first:!0}," ":{dir:"parentNode"},"+":{dir:"previousSibling",first:!0},"~":{dir:"previousSibling"}},preFilter:{ATTR:function(e){return e[1]=e[1].replace(et,tt),e[3]=(e[4]||e[5]||"").replace(et,tt),"~="===e[2]&&(e[3]=" "+e[3]+" "),e.slice(0,4)},CHILD:function(e){return e[1]=e[1].toLowerCase(),"nth"===e[1].slice(0,3)?(e[3]||st.error(e[0]),e[4]=+(e[4]?e[5]+(e[6]||1):2*("even"===e[3]||"odd"===e[3])),e[5]=+(e[7]+e[8]||"odd"===e[3])):e[3]&&st.error(e[0]),e},PSEUDO:function(e){var t,n=!e[5]&&e[2];return U.CHILD.test(e[0])?null:(e[4]?e[2]=e[4]:n&&z.test(n)&&(t=ft(n,!0))&&(t=n.indexOf(")",n.length-t)-n.length)&&(e[0]=e[0].slice(0,t),e[2]=n.slice(0,t)),e.slice(0,3))}},filter:{TAG:function(e){return"*"===e?function(){return!0}:(e=e.replace(et,tt).toLowerCase(),function(t){return t.nodeName&&t.nodeName.toLowerCase()===e})},CLASS:function(e){var t=k[e+" "];retu
rn t||(t=RegExp("(^|"+_+")"+e+"("+_+"|$)"))&&k(e,function(e){return t.test(e.className||typeof e.getAttribute!==A&&e.getAttribute("class")||"")})},ATTR:function(e,t,n){return function(r){var i=st.attr(r,e);return null==i?"!="===t:t?(i+="","="===t?i===n:"!="===t?i!==n:"^="===t?n&&0===i.indexOf(n):"*="===t?n&&i.indexOf(n)>-1:"$="===t?n&&i.slice(-n.length)===n:"~="===t?(" "+i+" ").indexOf(n)>-1:"|="===t?i===n||i.slice(0,n.length+1)===n+"-":!1):!0}},CHILD:function(e,t,n,r,i){var o="nth"!==e.slice(0,3),a="last"!==e.slice(-4),s="of-type"===t;return 1===r&&0===i?function(e){return!!e.parentNode}:function(t,n,u){var l,c,p,f,d,h,g=o!==a?"nextSibling":"previousSibling",m=t.parentNode,y=s&&t.nodeName.toLowerCase(),v=!u&&!s;if(m){if(o){while(g){p=t;while(p=p[g])if(s?p.nodeName.toLowerCase()===y:1===p.nodeType)return!1;h=g="only"===e&&!h&&"nextSibling"}return!0}if(h=[a?m.firstChild:m.lastChild],a&&v){c=m[x]||(m[x]={}),l=c[e]||[],d=l[0]===N&&l[1],f=l[0]===N&&l[2],p=d&&m.childNodes[d];whil
e(p=++d&&p&&p[g]||(f=d=0)||h.pop())if(1===p.nodeType&&++f&&p===t){c[e]=[N,d,f];break}}else if(v&&(l=(t[x]||(t[x]={}))[e])&&l[0]===N)f=l[1];else while(p=++d&&p&&p[g]||(f=d=0)||h.pop())if((s?p.nodeName.toLowerCase()===y:1===p.nodeType)&&++f&&(v&&((p[x]||(p[x]={}))[e]=[N,f]),p===t))break;return f-=i,f===r||0===f%r&&f/r>=0}}},PSEUDO:function(e,t){var n,r=i.pseudos[e]||i.setFilters[e.toLowerCase()]||st.error("unsupported pseudo: "+e);return r[x]?r(t):r.length>1?(n=[e,e,"",t],i.setFilters.hasOwnProperty(e.toLowerCase())?ot(function(e,n){var i,o=r(e,t),a=o.length;while(a--)i=M.call(e,o[a]),e[i]=!(n[i]=o[a])}):function(e){return r(e,0,n)}):r}},pseudos:{not:ot(function(e){var t=[],n=[],r=s(e.replace(W,"$1"));return r[x]?ot(function(e,t,n,i){var o,a=r(e,null,i,[]),s=e.length;while(s--)(o=a[s])&&(e[s]=!(t[s]=o))}):function(e,i,o){return t[0]=e,r(t,null,o,n),!n.pop()}}),has:ot(function(e){return function(t){return st(e,t).length>0}}),contains:ot(function(e){return function(t){return(t.t
extContent||t.innerText||o(t)).indexOf(e)>-1}}),lang:ot(function(e){return X.test(e||"")||st.error("unsupported lang: "+e),e=e.replace(et,tt).toLowerCase(),function(t){var n;do if(n=d?t.getAttribute("xml:lang")||t.getAttribute("lang"):t.lang)return n=n.toLowerCase(),n===e||0===n.indexOf(e+"-");while((t=t.parentNode)&&1===t.nodeType);return!1}}),target:function(t){var n=e.location&&e.location.hash;return n&&n.slice(1)===t.id},root:function(e){return e===f},focus:function(e){return e===p.activeElement&&(!p.hasFocus||p.hasFocus())&&!!(e.type||e.href||~e.tabIndex)},enabled:function(e){return e.disabled===!1},disabled:function(e){return e.disabled===!0},checked:function(e){var t=e.nodeName.toLowerCase();return"input"===t&&!!e.checked||"option"===t&&!!e.selected},selected:function(e){return e.parentNode&&e.parentNode.selectedIndex,e.selected===!0},empty:function(e){for(e=e.firstChild;e;e=e.nextSibling)if(e.nodeName>"@"||3===e.nodeType||4===e.nodeType)return!1;return!0},parent:func
tion(e){return!i.pseudos.empty(e)},header:function(e){return Q.test(e.nodeName)},input:function(e){return G.test(e.nodeName)},button:function(e){var t=e.nodeName.toLowerCase();return"input"===t&&"button"===e.type||"button"===t},text:function(e){var t;return"input"===e.nodeName.toLowerCase()&&"text"===e.type&&(null==(t=e.getAttribute("type"))||t.toLowerCase()===e.type)},first:pt(function(){return[0]}),last:pt(function(e,t){return[t-1]}),eq:pt(function(e,t,n){return[0>n?n+t:n]}),even:pt(function(e,t){var n=0;for(;t>n;n+=2)e.push(n);return e}),odd:pt(function(e,t){var n=1;for(;t>n;n+=2)e.push(n);return e}),lt:pt(function(e,t,n){var r=0>n?n+t:n;for(;--r>=0;)e.push(r);return e}),gt:pt(function(e,t,n){var r=0>n?n+t:n;for(;t>++r;)e.push(r);return e})}};for(n in{radio:!0,checkbox:!0,file:!0,password:!0,image:!0})i.pseudos[n]=lt(n);for(n in{submit:!0,reset:!0})i.pseudos[n]=ct(n);function ft(e,t){var n,r,o,a,s,u,l,c=E[e+" "];if(c)return t?0:c.slice(0);s=e,u=[],l=i.preFilter;while(s){(
!n||(r=$.exec(s)))&&(r&&(s=s.slice(r[0].length)||s),u.push(o=[])),n=!1,(r=I.exec(s))&&(n=r.shift(),o.push({value:n,type:r[0].replace(W," ")}),s=s.slice(n.length));for(a in i.filter)!(r=U[a].exec(s))||l[a]&&!(r=l[a](r))||(n=r.shift(),o.push({value:n,type:a,matches:r}),s=s.slice(n.length));if(!n)break}return t?s.length:s?st.error(e):E(e,u).slice(0)}function dt(e){var t=0,n=e.length,r="";for(;n>t;t++)r+=e[t].value;return r}function ht(e,t,n){var i=t.dir,o=n&&"parentNode"===i,a=C++;return t.first?function(t,n,r){while(t=t[i])if(1===t.nodeType||o)return e(t,n,r)}:function(t,n,s){var u,l,c,p=N+" "+a;if(s){while(t=t[i])if((1===t.nodeType||o)&&e(t,n,s))return!0}else while(t=t[i])if(1===t.nodeType||o)if(c=t[x]||(t[x]={}),(l=c[i])&&l[0]===p){if((u=l[1])===!0||u===r)return u===!0}else if(l=c[i]=[p],l[1]=e(t,n,s)||r,l[1]===!0)return!0}}function gt(e){return e.length>1?function(t,n,r){var i=e.length;while(i--)if(!e[i](t,n,r))return!1;return!0}:e[0]}function mt(e,t,n,r,i){var o,a=[],s=0,u
=e.length,l=null!=t;for(;u>s;s++)(o=e[s])&&(!n||n(o,r,i))&&(a.push(o),l&&t.push(s));return a}function yt(e,t,n,r,i,o){return r&&!r[x]&&(r=yt(r)),i&&!i[x]&&(i=yt(i,o)),ot(function(o,a,s,u){var l,c,p,f=[],d=[],h=a.length,g=o||xt(t||"*",s.nodeType?[s]:s,[]),m=!e||!o&&t?g:mt(g,f,e,s,u),y=n?i||(o?e:h||r)?[]:a:m;if(n&&n(m,y,s,u),r){l=mt(y,d),r(l,[],s,u),c=l.length;while(c--)(p=l[c])&&(y[d[c]]=!(m[d[c]]=p))}if(o){if(i||e){if(i){l=[],c=y.length;while(c--)(p=y[c])&&l.push(m[c]=p);i(null,y=[],l,u)}c=y.length;while(c--)(p=y[c])&&(l=i?M.call(o,p):f[c])>-1&&(o[l]=!(a[l]=p))}}else y=mt(y===a?y.splice(h,y.length):y),i?i(null,a,y,u):H.apply(a,y)})}function vt(e){var t,n,r,o=e.length,a=i.relative[e[0].type],s=a||i.relative[" "],u=a?1:0,c=ht(function(e){return e===t},s,!0),p=ht(function(e){return M.call(t,e)>-1},s,!0),f=[function(e,n,r){return!a&&(r||n!==l)||((t=n).nodeType?c(e,n,r):p(e,n,r))}];for(;o>u;u++)if(n=i.relative[e[u].type])f=[ht(gt(f),n)];else{if(n=i.filter[e[u].type].apply(null,e[
u].matches),n[x]){for(r=++u;o>r;r++)if(i.relative[e[r].type])break;return yt(u>1&>(f),u>1&&dt(e.slice(0,u-1)).replace(W,"$1"),n,r>u&&vt(e.slice(u,r)),o>r&&vt(e=e.slice(r)),o>r&&dt(e))}f.push(n)}return gt(f)}function bt(e,t){var n=0,o=t.length>0,a=e.length>0,s=function(s,u,c,f,d){var h,g,m,y=[],v=0,b="0",x=s&&[],w=null!=d,T=l,C=s||a&&i.find.TAG("*",d&&u.parentNode||u),k=N+=null==T?1:Math.random()||.1;for(w&&(l=u!==p&&u,r=n);null!=(h=C[b]);b++){if(a&&h){g=0;while(m=e[g++])if(m(h,u,c)){f.push(h);break}w&&(N=k,r=++n)}o&&((h=!m&&h)&&v--,s&&x.push(h))}if(v+=b,o&&b!==v){g=0;while(m=t[g++])m(x,y,u,c);if(s){if(v>0)while(b--)x[b]||y[b]||(y[b]=L.call(f));y=mt(y)}H.apply(f,y),w&&!s&&y.length>0&&v+t.length>1&&st.uniqueSort(f)}return w&&(N=k,l=T),x};return o?ot(s):s}s=st.compile=function(e,t){var n,r=[],i=[],o=S[e+" "];if(!o){t||(t=ft(e)),n=t.length;while(n--)o=vt(t[n]),o[x]?r.push(o):i.push(o);o=S(e,bt(i,r))}return o};function xt(e,t,n){var r=0,i=t.length;for(;i>r;r++)st(e,t[r],n);retu
rn n}function wt(e,t,n,r){var o,a,u,l,c,p=ft(e);if(!r&&1===p.length){if(a=p[0]=p[0].slice(0),a.length>2&&"ID"===(u=a[0]).type&&9===t.nodeType&&!d&&i.relative[a[1].type]){if(t=i.find.ID(u.matches[0].replace(et,tt),t)[0],!t)return n;e=e.slice(a.shift().value.length)}o=U.needsContext.test(e)?0:a.length;while(o--){if(u=a[o],i.relative[l=u.type])break;if((c=i.find[l])&&(r=c(u.matches[0].replace(et,tt),V.test(a[0].type)&&t.parentNode||t))){if(a.splice(o,1),e=r.length&&dt(a),!e)return H.apply(n,q.call(r,0)),n;break}}}return s(e,p)(r,t,d,n,V.test(e)),n}i.pseudos.nth=i.pseudos.eq;function Tt(){}i.filters=Tt.prototype=i.pseudos,i.setFilters=new Tt,c(),st.attr=b.attr,b.find=st,b.expr=st.selectors,b.expr[":"]=b.expr.pseudos,b.unique=st.uniqueSort,b.text=st.getText,b.isXMLDoc=st.isXML,b.contains=st.contains}(e);var at=/Until$/,st=/^(?:parents|prev(?:Until|All))/,ut=/^.[^:#\[\.,]*$/,lt=b.expr.match.needsContext,ct={children:!0,contents:!0,next:!0,prev:!0};b.fn.extend({find:function(e){var
t,n,r,i=this.length;if("string"!=typeof e)return r=this,this.pushStack(b(e).filter(function(){for(t=0;i>t;t++)if(b.contains(r[t],this))return!0}));for(n=[],t=0;i>t;t++)b.find(e,this[t],n);return n=this.pushStack(i>1?b.unique(n):n),n.selector=(this.selector?this.selector+" ":"")+e,n},has:function(e){var t,n=b(e,this),r=n.length;return this.filter(function(){for(t=0;r>t;t++)if(b.contains(this,n[t]))return!0})},not:function(e){return this.pushStack(ft(this,e,!1))},filter:function(e){return this.pushStack(ft(this,e,!0))},is:function(e){return!!e&&("string"==typeof e?lt.test(e)?b(e,this.context).index(this[0])>=0:b.filter(e,this).length>0:this.filter(e).length>0)},closest:function(e,t){var n,r=0,i=this.length,o=[],a=lt.test(e)||"string"!=typeof e?b(e,t||this.context):0;for(;i>r;r++){n=this[r];while(n&&n.ownerDocument&&n!==t&&11!==n.nodeType){if(a?a.index(n)>-1:b.find.matchesSelector(n,e)){o.push(n);break}n=n.parentNode}}return this.pushStack(o.length>1?b.unique(o):o)},index:func
tion(e){return e?"string"==typeof e?b.inArray(this[0],b(e)):b.inArray(e.jquery?e[0]:e,this):this[0]&&this[0].parentNode?this.first().prevAll().length:-1},add:function(e,t){var n="string"==typeof e?b(e,t):b.makeArray(e&&e.nodeType?[e]:e),r=b.merge(this.get(),n);return this.pushStack(b.unique(r))},addBack:function(e){return this.add(null==e?this.prevObject:this.prevObject.filter(e))}}),b.fn.andSelf=b.fn.addBack;function pt(e,t){do e=e[t];while(e&&1!==e.nodeType);return e}b.each({parent:function(e){var t=e.parentNode;return t&&11!==t.nodeType?t:null},parents:function(e){return b.dir(e,"parentNode")},parentsUntil:function(e,t,n){return b.dir(e,"parentNode",n)},next:function(e){return pt(e,"nextSibling")},prev:function(e){return pt(e,"previousSibling")},nextAll:function(e){return b.dir(e,"nextSibling")},prevAll:function(e){return b.dir(e,"previousSibling")},nextUntil:function(e,t,n){return b.dir(e,"nextSibling",n)},prevUntil:function(e,t,n){return b.dir(e,"previousSibling",n)},si
blings:function(e){return b.sibling((e.parentNode||{}).firstChild,e)},children:function(e){return b.sibling(e.firstChild)},contents:function(e){return b.nodeName(e,"iframe")?e.contentDocument||e.contentWindow.document:b.merge([],e.childNodes)}},function(e,t){b.fn[e]=function(n,r){var i=b.map(this,t,n);return at.test(e)||(r=n),r&&"string"==typeof r&&(i=b.filter(r,i)),i=this.length>1&&!ct[e]?b.unique(i):i,this.length>1&&st.test(e)&&(i=i.reverse()),this.pushStack(i)}}),b.extend({filter:function(e,t,n){return n&&(e=":not("+e+")"),1===t.length?b.find.matchesSelector(t[0],e)?[t[0]]:[]:b.find.matches(e,t)},dir:function(e,n,r){var i=[],o=e[n];while(o&&9!==o.nodeType&&(r===t||1!==o.nodeType||!b(o).is(r)))1===o.nodeType&&i.push(o),o=o[n];return i},sibling:function(e,t){var n=[];for(;e;e=e.nextSibling)1===e.nodeType&&e!==t&&n.push(e);return n}});function ft(e,t,n){if(t=t||0,b.isFunction(t))return b.grep(e,function(e,r){var i=!!t.call(e,r,e);return i===n});if(t.nodeType)return b.grep(e,
function(e){return e===t===n});if("string"==typeof t){var r=b.grep(e,function(e){return 1===e.nodeType});if(ut.test(t))return b.filter(t,r,!n);t=b.filter(t,r)}return b.grep(e,function(e){return b.inArray(e,t)>=0===n})}function dt(e){var t=ht.split("|"),n=e.createDocumentFragment();if(n.createElement)while(t.length)n.createElement(t.pop());return n}var ht="abbr|article|aside|audio|bdi|canvas|data|datalist|details|figcaption|figure|footer|header|hgroup|mark|meter|nav|output|progress|section|summary|time|video",gt=/ jQuery\d+="(?:null|\d+)"/g,mt=RegExp("<(?:"+ht+")[\\s/>]","i"),yt=/^\s+/,vt=/<(?!area|br|col|embed|hr|img|input|link|meta|param)(([\w:]+)[^>]*)\/>/gi,bt=/<([\w:]+)/,xt=/<tbody/i,wt=/<|&#?\w+;/,Tt=/<(?:script|style|link)/i,Nt=/^(?:checkbox|radio)$/i,Ct=/checked\s*(?:[^=]|=\s*.checked.)/i,kt=/^$|\/(?:java|ecma)script/i,Et=/^true\/(.*)/,St=/^\s*<!(?:\[CDATA\[|--)|(?:\]\]|--)>\s*$/g,At={option:[1,"<select multiple='multiple'>","</select>"],legend:[1,"<fieldset>","</fiel
dset>"],area:[1,"<map>","</map>"],param:[1,"<object>","</object>"],thead:[1,"<table>","</table>"],tr:[2,"<table><tbody>","</tbody></table>"],col:[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"],td:[3,"<table><tbody><tr>","</tr></tbody></table>"],_default:b.support.htmlSerialize?[0,"",""]:[1,"X<div>","</div>"]},jt=dt(o),Dt=jt.appendChild(o.createElement("div"));At.optgroup=At.option,At.tbody=At.tfoot=At.colgroup=At.caption=At.thead,At.th=At.td,b.fn.extend({text:function(e){return b.access(this,function(e){return e===t?b.text(this):this.empty().append((this[0]&&this[0].ownerDocument||o).createTextNode(e))},null,e,arguments.length)},wrapAll:function(e){if(b.isFunction(e))return this.each(function(t){b(this).wrapAll(e.call(this,t))});if(this[0]){var t=b(e,this[0].ownerDocument).eq(0).clone(!0);this[0].parentNode&&t.insertBefore(this[0]),t.map(function(){var e=this;while(e.firstChild&&1===e.firstChild.nodeType)e=e.firstChild;return e}).append(this)}return this},wrapIn
ner:function(e){return b.isFunction(e)?this.each(function(t){b(this).wrapInner(e.call(this,t))}):this.each(function(){var t=b(this),n=t.contents();n.length?n.wrapAll(e):t.append(e)})},wrap:function(e){var t=b.isFunction(e);return this.each(function(n){b(this).wrapAll(t?e.call(this,n):e)})},unwrap:function(){return this.parent().each(function(){b.nodeName(this,"body")||b(this).replaceWith(this.childNodes)}).end()},append:function(){return this.domManip(arguments,!0,function(e){(1===this.nodeType||11===this.nodeType||9===this.nodeType)&&this.appendChild(e)})},prepend:function(){return this.domManip(arguments,!0,function(e){(1===this.nodeType||11===this.nodeType||9===this.nodeType)&&this.insertBefore(e,this.firstChild)})},before:function(){return this.domManip(arguments,!1,function(e){this.parentNode&&this.parentNode.insertBefore(e,this)})},after:function(){return this.domManip(arguments,!1,function(e){this.parentNode&&this.parentNode.insertBefore(e,this.nextSibling)})},remove:
function(e,t){var n,r=0;for(;null!=(n=this[r]);r++)(!e||b.filter(e,[n]).length>0)&&(t||1!==n.nodeType||b.cleanData(Ot(n)),n.parentNode&&(t&&b.contains(n.ownerDocument,n)&&Mt(Ot(n,"script")),n.parentNode.removeChild(n)));return this},empty:function(){var e,t=0;for(;null!=(e=this[t]);t++){1===e.nodeType&&b.cleanData(Ot(e,!1));while(e.firstChild)e.removeChild(e.firstChild);e.options&&b.nodeName(e,"select")&&(e.options.length=0)}return this},clone:function(e,t){return e=null==e?!1:e,t=null==t?e:t,this.map(function(){return b.clone(this,e,t)})},html:function(e){return b.access(this,function(e){var n=this[0]||{},r=0,i=this.length;if(e===t)return 1===n.nodeType?n.innerHTML.replace(gt,""):t;if(!("string"!=typeof e||Tt.test(e)||!b.support.htmlSerialize&&mt.test(e)||!b.support.leadingWhitespace&&yt.test(e)||At[(bt.exec(e)||["",""])[1].toLowerCase()])){e=e.replace(vt,"<$1></$2>");try{for(;i>r;r++)n=this[r]||{},1===n.nodeType&&(b.cleanData(Ot(n,!1)),n.innerHTML=e);n=0}catch(o){}}n&&this
.empty().append(e)},null,e,arguments.length)},replaceWith:function(e){var t=b.isFunction(e);return t||"string"==typeof e||(e=b(e).not(this).detach()),this.domManip([e],!0,function(e){var t=this.nextSibling,n=this.parentNode;n&&(b(this).remove(),n.insertBefore(e,t))})},detach:function(e){return this.remove(e,!0)},domManip:function(e,n,r){e=f.apply([],e);var i,o,a,s,u,l,c=0,p=this.length,d=this,h=p-1,g=e[0],m=b.isFunction(g);if(m||!(1>=p||"string"!=typeof g||b.support.checkClone)&&Ct.test(g))return this.each(function(i){var o=d.eq(i);m&&(e[0]=g.call(this,i,n?o.html():t)),o.domManip(e,n,r)});if(p&&(l=b.buildFragment(e,this[0].ownerDocument,!1,this),i=l.firstChild,1===l.childNodes.length&&(l=i),i)){for(n=n&&b.nodeName(i,"tr"),s=b.map(Ot(l,"script"),Ht),a=s.length;p>c;c++)o=l,c!==h&&(o=b.clone(o,!0,!0),a&&b.merge(s,Ot(o,"script"))),r.call(n&&b.nodeName(this[c],"table")?Lt(this[c],"tbody"):this[c],o,c);if(a)for(u=s[s.length-1].ownerDocument,b.map(s,qt),c=0;a>c;c++)o=s[c],kt.test(o
.type||"")&&!b._data(o,"globalEval")&&b.contains(u,o)&&(o.src?b.ajax({url:o.src,type:"GET",dataType:"script",async:!1,global:!1,"throws":!0}):b.globalEval((o.text||o.textContent||o.innerHTML||"").replace(St,"")));l=i=null}return this}});function Lt(e,t){return e.getElementsByTagName(t)[0]||e.appendChild(e.ownerDocument.createElement(t))}function Ht(e){var t=e.getAttributeNode("type");return e.type=(t&&t.specified)+"/"+e.type,e}function qt(e){var t=Et.exec(e.type);return t?e.type=t[1]:e.removeAttribute("type"),e}function Mt(e,t){var n,r=0;for(;null!=(n=e[r]);r++)b._data(n,"globalEval",!t||b._data(t[r],"globalEval"))}function _t(e,t){if(1===t.nodeType&&b.hasData(e)){var n,r,i,o=b._data(e),a=b._data(t,o),s=o.events;if(s){delete a.handle,a.events={};for(n in s)for(r=0,i=s[n].length;i>r;r++)b.event.add(t,n,s[n][r])}a.data&&(a.data=b.extend({},a.data))}}function Ft(e,t){var n,r,i;if(1===t.nodeType){if(n=t.nodeName.toLowerCase(),!b.support.noCloneEvent&&t[b.expando]){i=b._data(t);f
or(r in i.events)b.removeEvent(t,r,i.handle);t.removeAttribute(b.expando)}"script"===n&&t.text!==e.text?(Ht(t).text=e.text,qt(t)):"object"===n?(t.parentNode&&(t.outerHTML=e.outerHTML),b.support.html5Clone&&e.innerHTML&&!b.trim(t.innerHTML)&&(t.innerHTML=e.innerHTML)):"input"===n&&Nt.test(e.type)?(t.defaultChecked=t.checked=e.checked,t.value!==e.value&&(t.value=e.value)):"option"===n?t.defaultSelected=t.selected=e.defaultSelected:("input"===n||"textarea"===n)&&(t.defaultValue=e.defaultValue)}}b.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(e,t){b.fn[e]=function(e){var n,r=0,i=[],o=b(e),a=o.length-1;for(;a>=r;r++)n=r===a?this:this.clone(!0),b(o[r])[t](n),d.apply(i,n.get());return this.pushStack(i)}});function Ot(e,n){var r,o,a=0,s=typeof e.getElementsByTagName!==i?e.getElementsByTagName(n||"*"):typeof e.querySelectorAll!==i?e.querySelectorAll(n||"*"):t;if(!s)for(s=[],r=e.childNodes||e;null!=(o=r[a]);a++
)!n||b.nodeName(o,n)?s.push(o):b.merge(s,Ot(o,n));return n===t||n&&b.nodeName(e,n)?b.merge([e],s):s}function Bt(e){Nt.test(e.type)&&(e.defaultChecked=e.checked)}b.extend({clone:function(e,t,n){var r,i,o,a,s,u=b.contains(e.ownerDocument,e);if(b.support.html5Clone||b.isXMLDoc(e)||!mt.test("<"+e.nodeName+">")?o=e.cloneNode(!0):(Dt.innerHTML=e.outerHTML,Dt.removeChild(o=Dt.firstChild)),!(b.support.noCloneEvent&&b.support.noCloneChecked||1!==e.nodeType&&11!==e.nodeType||b.isXMLDoc(e)))for(r=Ot(o),s=Ot(e),a=0;null!=(i=s[a]);++a)r[a]&&Ft(i,r[a]);if(t)if(n)for(s=s||Ot(e),r=r||Ot(o),a=0;null!=(i=s[a]);a++)_t(i,r[a]);else _t(e,o);return r=Ot(o,"script"),r.length>0&&Mt(r,!u&&Ot(e,"script")),r=s=i=null,o},buildFragment:function(e,t,n,r){var i,o,a,s,u,l,c,p=e.length,f=dt(t),d=[],h=0;for(;p>h;h++)if(o=e[h],o||0===o)if("object"===b.type(o))b.merge(d,o.nodeType?[o]:o);else if(wt.test(o)){s=s||f.appendChild(t.createElement("div")),u=(bt.exec(o)||["",""])[1].toLowerCase(),c=At[u]||At._default
,s.innerHTML=c[1]+o.replace(vt,"<$1></$2>")+c[2],i=c[0];while(i--)s=s.lastChild;if(!b.support.leadingWhitespace&&yt.test(o)&&d.push(t.createTextNode(yt.exec(o)[0])),!b.support.tbody){o="table"!==u||xt.test(o)?"<table>"!==c[1]||xt.test(o)?0:s:s.firstChild,i=o&&o.childNodes.length;while(i--)b.nodeName(l=o.childNodes[i],"tbody")&&!l.childNodes.length&&o.removeChild(l)
+}b.merge(d,s.childNodes),s.textContent="";while(s.firstChild)s.removeChild(s.firstChild);s=f.lastChild}else d.push(t.createTextNode(o));s&&f.removeChild(s),b.support.appendChecked||b.grep(Ot(d,"input"),Bt),h=0;while(o=d[h++])if((!r||-1===b.inArray(o,r))&&(a=b.contains(o.ownerDocument,o),s=Ot(f.appendChild(o),"script"),a&&Mt(s),n)){i=0;while(o=s[i++])kt.test(o.type||"")&&n.push(o)}return s=null,f},cleanData:function(e,t){var n,r,o,a,s=0,u=b.expando,l=b.cache,p=b.support.deleteExpando,f=b.event.special;for(;null!=(n=e[s]);s++)if((t||b.acceptData(n))&&(o=n[u],a=o&&l[o])){if(a.events)for(r in a.events)f[r]?b.event.remove(n,r):b.removeEvent(n,r,a.handle);l[o]&&(delete l[o],p?delete n[u]:typeof n.removeAttribute!==i?n.removeAttribute(u):n[u]=null,c.push(o))}}});var Pt,Rt,Wt,$t=/alpha\([^)]*\)/i,It=/opacity\s*=\s*([^)]*)/,zt=/^(top|right|bottom|left)$/,Xt=/^(none|table(?!-c[ea]).+)/,Ut=/^margin/,Vt=RegExp("^("+x+")(.*)$","i"),Yt=RegExp("^("+x+")(?!px)[a-z%]+$","i"),Jt=RegExp("^([+-
])=("+x+")","i"),Gt={BODY:"block"},Qt={position:"absolute",visibility:"hidden",display:"block"},Kt={letterSpacing:0,fontWeight:400},Zt=["Top","Right","Bottom","Left"],en=["Webkit","O","Moz","ms"];function tn(e,t){if(t in e)return t;var n=t.charAt(0).toUpperCase()+t.slice(1),r=t,i=en.length;while(i--)if(t=en[i]+n,t in e)return t;return r}function nn(e,t){return e=t||e,"none"===b.css(e,"display")||!b.contains(e.ownerDocument,e)}function rn(e,t){var n,r,i,o=[],a=0,s=e.length;for(;s>a;a++)r=e[a],r.style&&(o[a]=b._data(r,"olddisplay"),n=r.style.display,t?(o[a]||"none"!==n||(r.style.display=""),""===r.style.display&&nn(r)&&(o[a]=b._data(r,"olddisplay",un(r.nodeName)))):o[a]||(i=nn(r),(n&&"none"!==n||!i)&&b._data(r,"olddisplay",i?n:b.css(r,"display"))));for(a=0;s>a;a++)r=e[a],r.style&&(t&&"none"!==r.style.display&&""!==r.style.display||(r.style.display=t?o[a]||"":"none"));return e}b.fn.extend({css:function(e,n){return b.access(this,function(e,n,r){var i,o,a={},s=0;if(b.isArray(n)){
for(o=Rt(e),i=n.length;i>s;s++)a[n[s]]=b.css(e,n[s],!1,o);return a}return r!==t?b.style(e,n,r):b.css(e,n)},e,n,arguments.length>1)},show:function(){return rn(this,!0)},hide:function(){return rn(this)},toggle:function(e){var t="boolean"==typeof e;return this.each(function(){(t?e:nn(this))?b(this).show():b(this).hide()})}}),b.extend({cssHooks:{opacity:{get:function(e,t){if(t){var n=Wt(e,"opacity");return""===n?"1":n}}}},cssNumber:{columnCount:!0,fillOpacity:!0,fontWeight:!0,lineHeight:!0,opacity:!0,orphans:!0,widows:!0,zIndex:!0,zoom:!0},cssProps:{"float":b.support.cssFloat?"cssFloat":"styleFloat"},style:function(e,n,r,i){if(e&&3!==e.nodeType&&8!==e.nodeType&&e.style){var o,a,s,u=b.camelCase(n),l=e.style;if(n=b.cssProps[u]||(b.cssProps[u]=tn(l,u)),s=b.cssHooks[n]||b.cssHooks[u],r===t)return s&&"get"in s&&(o=s.get(e,!1,i))!==t?o:l[n];if(a=typeof r,"string"===a&&(o=Jt.exec(r))&&(r=(o[1]+1)*o[2]+parseFloat(b.css(e,n)),a="number"),!(null==r||"number"===a&&isNaN(r)||("number"!==a||
b.cssNumber[u]||(r+="px"),b.support.clearCloneStyle||""!==r||0!==n.indexOf("background")||(l[n]="inherit"),s&&"set"in s&&(r=s.set(e,r,i))===t)))try{l[n]=r}catch(c){}}},css:function(e,n,r,i){var o,a,s,u=b.camelCase(n);return n=b.cssProps[u]||(b.cssProps[u]=tn(e.style,u)),s=b.cssHooks[n]||b.cssHooks[u],s&&"get"in s&&(a=s.get(e,!0,r)),a===t&&(a=Wt(e,n,i)),"normal"===a&&n in Kt&&(a=Kt[n]),""===r||r?(o=parseFloat(a),r===!0||b.isNumeric(o)?o||0:a):a},swap:function(e,t,n,r){var i,o,a={};for(o in t)a[o]=e.style[o],e.style[o]=t[o];i=n.apply(e,r||[]);for(o in t)e.style[o]=a[o];return i}}),e.getComputedStyle?(Rt=function(t){return e.getComputedStyle(t,null)},Wt=function(e,n,r){var i,o,a,s=r||Rt(e),u=s?s.getPropertyValue(n)||s[n]:t,l=e.style;return s&&(""!==u||b.contains(e.ownerDocument,e)||(u=b.style(e,n)),Yt.test(u)&&Ut.test(n)&&(i=l.width,o=l.minWidth,a=l.maxWidth,l.minWidth=l.maxWidth=l.width=u,u=s.width,l.width=i,l.minWidth=o,l.maxWidth=a)),u}):o.documentElement.currentStyle&&(Rt=f
unction(e){return e.currentStyle},Wt=function(e,n,r){var i,o,a,s=r||Rt(e),u=s?s[n]:t,l=e.style;return null==u&&l&&l[n]&&(u=l[n]),Yt.test(u)&&!zt.test(n)&&(i=l.left,o=e.runtimeStyle,a=o&&o.left,a&&(o.left=e.currentStyle.left),l.left="fontSize"===n?"1em":u,u=l.pixelLeft+"px",l.left=i,a&&(o.left=a)),""===u?"auto":u});function on(e,t,n){var r=Vt.exec(t);return r?Math.max(0,r[1]-(n||0))+(r[2]||"px"):t}function an(e,t,n,r,i){var o=n===(r?"border":"content")?4:"width"===t?1:0,a=0;for(;4>o;o+=2)"margin"===n&&(a+=b.css(e,n+Zt[o],!0,i)),r?("content"===n&&(a-=b.css(e,"padding"+Zt[o],!0,i)),"margin"!==n&&(a-=b.css(e,"border"+Zt[o]+"Width",!0,i))):(a+=b.css(e,"padding"+Zt[o],!0,i),"padding"!==n&&(a+=b.css(e,"border"+Zt[o]+"Width",!0,i)));return a}function sn(e,t,n){var r=!0,i="width"===t?e.offsetWidth:e.offsetHeight,o=Rt(e),a=b.support.boxSizing&&"border-box"===b.css(e,"boxSizing",!1,o);if(0>=i||null==i){if(i=Wt(e,t,o),(0>i||null==i)&&(i=e.style[t]),Yt.test(i))return i;r=a&&(b.support.bo
xSizingReliable||i===e.style[t]),i=parseFloat(i)||0}return i+an(e,t,n||(a?"border":"content"),r,o)+"px"}function un(e){var t=o,n=Gt[e];return n||(n=ln(e,t),"none"!==n&&n||(Pt=(Pt||b("<iframe frameborder='0' width='0' height='0'/>").css("cssText","display:block !important")).appendTo(t.documentElement),t=(Pt[0].contentWindow||Pt[0].contentDocument).document,t.write("<!doctype html><html><body>"),t.close(),n=ln(e,t),Pt.detach()),Gt[e]=n),n}function ln(e,t){var n=b(t.createElement(e)).appendTo(t.body),r=b.css(n[0],"display");return n.remove(),r}b.each(["height","width"],function(e,n){b.cssHooks[n]={get:function(e,r,i){return r?0===e.offsetWidth&&Xt.test(b.css(e,"display"))?b.swap(e,Qt,function(){return sn(e,n,i)}):sn(e,n,i):t},set:function(e,t,r){var i=r&&Rt(e);return on(e,t,r?an(e,n,r,b.support.boxSizing&&"border-box"===b.css(e,"boxSizing",!1,i),i):0)}}}),b.support.opacity||(b.cssHooks.opacity={get:function(e,t){return It.test((t&&e.currentStyle?e.currentStyle.filter:e.style.f
ilter)||"")?.01*parseFloat(RegExp.$1)+"":t?"1":""},set:function(e,t){var n=e.style,r=e.currentStyle,i=b.isNumeric(t)?"alpha(opacity="+100*t+")":"",o=r&&r.filter||n.filter||"";n.zoom=1,(t>=1||""===t)&&""===b.trim(o.replace($t,""))&&n.removeAttribute&&(n.removeAttribute("filter"),""===t||r&&!r.filter)||(n.filter=$t.test(o)?o.replace($t,i):o+" "+i)}}),b(function(){b.support.reliableMarginRight||(b.cssHooks.marginRight={get:function(e,n){return n?b.swap(e,{display:"inline-block"},Wt,[e,"marginRight"]):t}}),!b.support.pixelPosition&&b.fn.position&&b.each(["top","left"],function(e,n){b.cssHooks[n]={get:function(e,r){return r?(r=Wt(e,n),Yt.test(r)?b(e).position()[n]+"px":r):t}}})}),b.expr&&b.expr.filters&&(b.expr.filters.hidden=function(e){return 0>=e.offsetWidth&&0>=e.offsetHeight||!b.support.reliableHiddenOffsets&&"none"===(e.style&&e.style.display||b.css(e,"display"))},b.expr.filters.visible=function(e){return!b.expr.filters.hidden(e)}),b.each({margin:"",padding:"",border:"Width
"},function(e,t){b.cssHooks[e+t]={expand:function(n){var r=0,i={},o="string"==typeof n?n.split(" "):[n];for(;4>r;r++)i[e+Zt[r]+t]=o[r]||o[r-2]||o[0];return i}},Ut.test(e)||(b.cssHooks[e+t].set=on)});var cn=/%20/g,pn=/\[\]$/,fn=/\r?\n/g,dn=/^(?:submit|button|image|reset|file)$/i,hn=/^(?:input|select|textarea|keygen)/i;b.fn.extend({serialize:function(){return b.param(this.serializeArray())},serializeArray:function(){return this.map(function(){var e=b.prop(this,"elements");return e?b.makeArray(e):this}).filter(function(){var e=this.type;return this.name&&!b(this).is(":disabled")&&hn.test(this.nodeName)&&!dn.test(e)&&(this.checked||!Nt.test(e))}).map(function(e,t){var n=b(this).val();return null==n?null:b.isArray(n)?b.map(n,function(e){return{name:t.name,value:e.replace(fn,"\r\n")}}):{name:t.name,value:n.replace(fn,"\r\n")}}).get()}}),b.param=function(e,n){var r,i=[],o=function(e,t){t=b.isFunction(t)?t():null==t?"":t,i[i.length]=encodeURIComponent(e)+"="+encodeURIComponent(t)};i
f(n===t&&(n=b.ajaxSettings&&b.ajaxSettings.traditional),b.isArray(e)||e.jquery&&!b.isPlainObject(e))b.each(e,function(){o(this.name,this.value)});else for(r in e)gn(r,e[r],n,o);return i.join("&").replace(cn,"+")};function gn(e,t,n,r){var i;if(b.isArray(t))b.each(t,function(t,i){n||pn.test(e)?r(e,i):gn(e+"["+("object"==typeof i?t:"")+"]",i,n,r)});else if(n||"object"!==b.type(t))r(e,t);else for(i in t)gn(e+"["+i+"]",t[i],n,r)}b.each("blur focus focusin focusout load resize scroll unload click dblclick mousedown mouseup mousemove mouseover mouseout mouseenter mouseleave change select submit keydown keypress keyup error contextmenu".split(" "),function(e,t){b.fn[t]=function(e,n){return arguments.length>0?this.on(t,null,e,n):this.trigger(t)}}),b.fn.hover=function(e,t){return this.mouseenter(e).mouseleave(t||e)};var mn,yn,vn=b.now(),bn=/\?/,xn=/#.*$/,wn=/([?&])_=[^&]*/,Tn=/^(.*?):[ \t]*([^\r\n]*)\r?$/gm,Nn=/^(?:about|app|app-storage|.+-extension|file|res|widget):$/,Cn=/^(?:GET|HEA
D)$/,kn=/^\/\//,En=/^([\w.+-]+:)(?:\/\/([^\/?#:]*)(?::(\d+)|)|)/,Sn=b.fn.load,An={},jn={},Dn="*/".concat("*");try{yn=a.href}catch(Ln){yn=o.createElement("a"),yn.href="",yn=yn.href}mn=En.exec(yn.toLowerCase())||[];function Hn(e){return function(t,n){"string"!=typeof t&&(n=t,t="*");var r,i=0,o=t.toLowerCase().match(w)||[];if(b.isFunction(n))while(r=o[i++])"+"===r[0]?(r=r.slice(1)||"*",(e[r]=e[r]||[]).unshift(n)):(e[r]=e[r]||[]).push(n)}}function qn(e,n,r,i){var o={},a=e===jn;function s(u){var l;return o[u]=!0,b.each(e[u]||[],function(e,u){var c=u(n,r,i);return"string"!=typeof c||a||o[c]?a?!(l=c):t:(n.dataTypes.unshift(c),s(c),!1)}),l}return s(n.dataTypes[0])||!o["*"]&&s("*")}function Mn(e,n){var r,i,o=b.ajaxSettings.flatOptions||{};for(i in n)n[i]!==t&&((o[i]?e:r||(r={}))[i]=n[i]);return r&&b.extend(!0,e,r),e}b.fn.load=function(e,n,r){if("string"!=typeof e&&Sn)return Sn.apply(this,arguments);var i,o,a,s=this,u=e.indexOf(" ");return u>=0&&(i=e.slice(u,e.length),e=e.slice(0,u)),
b.isFunction(n)?(r=n,n=t):n&&"object"==typeof n&&(a="POST"),s.length>0&&b.ajax({url:e,type:a,dataType:"html",data:n}).done(function(e){o=arguments,s.html(i?b("<div>").append(b.parseHTML(e)).find(i):e)}).complete(r&&function(e,t){s.each(r,o||[e.responseText,t,e])}),this},b.each(["ajaxStart","ajaxStop","ajaxComplete","ajaxError","ajaxSuccess","ajaxSend"],function(e,t){b.fn[t]=function(e){return this.on(t,e)}}),b.each(["get","post"],function(e,n){b[n]=function(e,r,i,o){return b.isFunction(r)&&(o=o||i,i=r,r=t),b.ajax({url:e,type:n,dataType:o,data:r,success:i})}}),b.extend({active:0,lastModified:{},etag:{},ajaxSettings:{url:yn,type:"GET",isLocal:Nn.test(mn[1]),global:!0,processData:!0,async:!0,contentType:"application/x-www-form-urlencoded; charset=UTF-8",accepts:{"*":Dn,text:"text/plain",html:"text/html",xml:"application/xml, text/xml",json:"application/json, text/javascript"},contents:{xml:/xml/,html:/html/,json:/json/},responseFields:{xml:"responseXML",text:"responseText"},con
verters:{"* text":e.String,"text html":!0,"text json":b.parseJSON,"text xml":b.parseXML},flatOptions:{url:!0,context:!0}},ajaxSetup:function(e,t){return t?Mn(Mn(e,b.ajaxSettings),t):Mn(b.ajaxSettings,e)},ajaxPrefilter:Hn(An),ajaxTransport:Hn(jn),ajax:function(e,n){"object"==typeof e&&(n=e,e=t),n=n||{};var r,i,o,a,s,u,l,c,p=b.ajaxSetup({},n),f=p.context||p,d=p.context&&(f.nodeType||f.jquery)?b(f):b.event,h=b.Deferred(),g=b.Callbacks("once memory"),m=p.statusCode||{},y={},v={},x=0,T="canceled",N={readyState:0,getResponseHeader:function(e){var t;if(2===x){if(!c){c={};while(t=Tn.exec(a))c[t[1].toLowerCase()]=t[2]}t=c[e.toLowerCase()]}return null==t?null:t},getAllResponseHeaders:function(){return 2===x?a:null},setRequestHeader:function(e,t){var n=e.toLowerCase();return x||(e=v[n]=v[n]||e,y[e]=t),this},overrideMimeType:function(e){return x||(p.mimeType=e),this},statusCode:function(e){var t;if(e)if(2>x)for(t in e)m[t]=[m[t],e[t]];else N.always(e[N.status]);return this},abort:functi
on(e){var t=e||T;return l&&l.abort(t),k(0,t),this}};if(h.promise(N).complete=g.add,N.success=N.done,N.error=N.fail,p.url=((e||p.url||yn)+"").replace(xn,"").replace(kn,mn[1]+"//"),p.type=n.method||n.type||p.method||p.type,p.dataTypes=b.trim(p.dataType||"*").toLowerCase().match(w)||[""],null==p.crossDomain&&(r=En.exec(p.url.toLowerCase()),p.crossDomain=!(!r||r[1]===mn[1]&&r[2]===mn[2]&&(r[3]||("http:"===r[1]?80:443))==(mn[3]||("http:"===mn[1]?80:443)))),p.data&&p.processData&&"string"!=typeof p.data&&(p.data=b.param(p.data,p.traditional)),qn(An,p,n,N),2===x)return N;u=p.global,u&&0===b.active++&&b.event.trigger("ajaxStart"),p.type=p.type.toUpperCase(),p.hasContent=!Cn.test(p.type),o=p.url,p.hasContent||(p.data&&(o=p.url+=(bn.test(o)?"&":"?")+p.data,delete p.data),p.cache===!1&&(p.url=wn.test(o)?o.replace(wn,"$1_="+vn++):o+(bn.test(o)?"&":"?")+"_="+vn++)),p.ifModified&&(b.lastModified[o]&&N.setRequestHeader("If-Modified-Since",b.lastModified[o]),b.etag[o]&&N.setRequestHeader("I
f-None-Match",b.etag[o])),(p.data&&p.hasContent&&p.contentType!==!1||n.contentType)&&N.setRequestHeader("Content-Type",p.contentType),N.setRequestHeader("Accept",p.dataTypes[0]&&p.accepts[p.dataTypes[0]]?p.accepts[p.dataTypes[0]]+("*"!==p.dataTypes[0]?", "+Dn+"; q=0.01":""):p.accepts["*"]);for(i in p.headers)N.setRequestHeader(i,p.headers[i]);if(p.beforeSend&&(p.beforeSend.call(f,N,p)===!1||2===x))return N.abort();T="abort";for(i in{success:1,error:1,complete:1})N[i](p[i]);if(l=qn(jn,p,n,N)){N.readyState=1,u&&d.trigger("ajaxSend",[N,p]),p.async&&p.timeout>0&&(s=setTimeout(function(){N.abort("timeout")},p.timeout));try{x=1,l.send(y,k)}catch(C){if(!(2>x))throw C;k(-1,C)}}else k(-1,"No Transport");function k(e,n,r,i){var c,y,v,w,T,C=n;2!==x&&(x=2,s&&clearTimeout(s),l=t,a=i||"",N.readyState=e>0?4:0,r&&(w=_n(p,N,r)),e>=200&&300>e||304===e?(p.ifModified&&(T=N.getResponseHeader("Last-Modified"),T&&(b.lastModified[o]=T),T=N.getResponseHeader("etag"),T&&(b.etag[o]=T)),204===e?(c=!0,C
="nocontent"):304===e?(c=!0,C="notmodified"):(c=Fn(p,w),C=c.state,y=c.data,v=c.error,c=!v)):(v=C,(e||!C)&&(C="error",0>e&&(e=0))),N.status=e,N.statusText=(n||C)+"",c?h.resolveWith(f,[y,C,N]):h.rejectWith(f,[N,C,v]),N.statusCode(m),m=t,u&&d.trigger(c?"ajaxSuccess":"ajaxError",[N,p,c?y:v]),g.fireWith(f,[N,C]),u&&(d.trigger("ajaxComplete",[N,p]),--b.active||b.event.trigger("ajaxStop")))}return N},getScript:function(e,n){return b.get(e,t,n,"script")},getJSON:function(e,t,n){return b.get(e,t,n,"json")}});function _n(e,n,r){var i,o,a,s,u=e.contents,l=e.dataTypes,c=e.responseFields;for(s in c)s in r&&(n[c[s]]=r[s]);while("*"===l[0])l.shift(),o===t&&(o=e.mimeType||n.getResponseHeader("Content-Type"));if(o)for(s in u)if(u[s]&&u[s].test(o)){l.unshift(s);break}if(l[0]in r)a=l[0];else{for(s in r){if(!l[0]||e.converters[s+" "+l[0]]){a=s;break}i||(i=s)}a=a||i}return a?(a!==l[0]&&l.unshift(a),r[a]):t}function Fn(e,t){var n,r,i,o,a={},s=0,u=e.dataTypes.slice(),l=u[0];if(e.dataFilter&&(t=e.d
ataFilter(t,e.dataType)),u[1])for(i in e.converters)a[i.toLowerCase()]=e.converters[i];for(;r=u[++s];)if("*"!==r){if("*"!==l&&l!==r){if(i=a[l+" "+r]||a["* "+r],!i)for(n in a)if(o=n.split(" "),o[1]===r&&(i=a[l+" "+o[0]]||a["* "+o[0]])){i===!0?i=a[n]:a[n]!==!0&&(r=o[0],u.splice(s--,0,r));break}if(i!==!0)if(i&&e["throws"])t=i(t);else try{t=i(t)}catch(c){return{state:"parsererror",error:i?c:"No conversion from "+l+" to "+r}}}l=r}return{state:"success",data:t}}b.ajaxSetup({accepts:{script:"text/javascript, application/javascript, application/ecmascript, application/x-ecmascript"},contents:{script:/(?:java|ecma)script/},converters:{"text script":function(e){return b.globalEval(e),e}}}),b.ajaxPrefilter("script",function(e){e.cache===t&&(e.cache=!1),e.crossDomain&&(e.type="GET",e.global=!1)}),b.ajaxTransport("script",function(e){if(e.crossDomain){var n,r=o.head||b("head")[0]||o.documentElement;return{send:function(t,i){n=o.createElement("script"),n.async=!0,e.scriptCharset&&(n.chars
et=e.scriptCharset),n.src=e.url,n.onload=n.onreadystatechange=function(e,t){(t||!n.readyState||/loaded|complete/.test(n.readyState))&&(n.onload=n.onreadystatechange=null,n.parentNode&&n.parentNode.removeChild(n),n=null,t||i(200,"success"))},r.insertBefore(n,r.firstChild)},abort:function(){n&&n.onload(t,!0)}}}});var On=[],Bn=/(=)\?(?=&|$)|\?\?/;b.ajaxSetup({jsonp:"callback",jsonpCallback:function(){var e=On.pop()||b.expando+"_"+vn++;return this[e]=!0,e}}),b.ajaxPrefilter("json jsonp",function(n,r,i){var o,a,s,u=n.jsonp!==!1&&(Bn.test(n.url)?"url":"string"==typeof n.data&&!(n.contentType||"").indexOf("application/x-www-form-urlencoded")&&Bn.test(n.data)&&"data");return u||"jsonp"===n.dataTypes[0]?(o=n.jsonpCallback=b.isFunction(n.jsonpCallback)?n.jsonpCallback():n.jsonpCallback,u?n[u]=n[u].replace(Bn,"$1"+o):n.jsonp!==!1&&(n.url+=(bn.test(n.url)?"&":"?")+n.jsonp+"="+o),n.converters["script json"]=function(){return s||b.error(o+" was not called"),s[0]},n.dataTypes[0]="json",a=e
[o],e[o]=function(){s=arguments},i.always(function(){e[o]=a,n[o]&&(n.jsonpCallback=r.jsonpCallback,On.push(o)),s&&b.isFunction(a)&&a(s[0]),s=a=t}),"script"):t});var Pn,Rn,Wn=0,$n=e.ActiveXObject&&function(){var e;for(e in Pn)Pn[e](t,!0)};function In(){try{return new e.XMLHttpRequest}catch(t){}}function zn(){try{return new e.ActiveXObject("Microsoft.XMLHTTP")}catch(t){}}b.ajaxSettings.xhr=e.ActiveXObject?function(){return!this.isLocal&&In()||zn()}:In,Rn=b.ajaxSettings.xhr(),b.support.cors=!!Rn&&"withCredentials"in Rn,Rn=b.support.ajax=!!Rn,Rn&&b.ajaxTransport(function(n){if(!n.crossDomain||b.support.cors){var r;return{send:function(i,o){var a,s,u=n.xhr();if(n.username?u.open(n.type,n.url,n.async,n.username,n.password):u.open(n.type,n.url,n.async),n.xhrFields)for(s in n.xhrFields)u[s]=n.xhrFields[s];n.mimeType&&u.overrideMimeType&&u.overrideMimeType(n.mimeType),n.crossDomain||i["X-Requested-With"]||(i["X-Requested-With"]="XMLHttpRequest");try{for(s in i)u.setRequestHeader(s,i[
s])}catch(l){}u.send(n.hasContent&&n.data||null),r=function(e,i){var s,l,c,p;try{if(r&&(i||4===u.readyState))if(r=t,a&&(u.onreadystatechange=b.noop,$n&&delete Pn[a]),i)4!==u.readyState&&u.abort();else{p={},s=u.status,l=u.getAllResponseHeaders(),"string"==typeof u.responseText&&(p.text=u.responseText);try{c=u.statusText}catch(f){c=""}s||!n.isLocal||n.crossDomain?1223===s&&(s=204):s=p.text?200:404}}catch(d){i||o(-1,d)}p&&o(s,c,p,l)},n.async?4===u.readyState?setTimeout(r):(a=++Wn,$n&&(Pn||(Pn={},b(e).unload($n)),Pn[a]=r),u.onreadystatechange=r):r()},abort:function(){r&&r(t,!0)}}}});var Xn,Un,Vn=/^(?:toggle|show|hide)$/,Yn=RegExp("^(?:([+-])=|)("+x+")([a-z%]*)$","i"),Jn=/queueHooks$/,Gn=[nr],Qn={"*":[function(e,t){var n,r,i=this.createTween(e,t),o=Yn.exec(t),a=i.cur(),s=+a||0,u=1,l=20;if(o){if(n=+o[2],r=o[3]||(b.cssNumber[e]?"":"px"),"px"!==r&&s){s=b.css(i.elem,e,!0)||n||1;do u=u||".5",s/=u,b.style(i.elem,e,s+r);while(u!==(u=i.cur()/a)&&1!==u&&--l)}i.unit=r,i.start=s,i.end=o[1]?
s+(o[1]+1)*n:n}return i}]};function Kn(){return setTimeout(function(){Xn=t}),Xn=b.now()}function Zn(e,t){b.each(t,function(t,n){var r=(Qn[t]||[]).concat(Qn["*"]),i=0,o=r.length;for(;o>i;i++)if(r[i].call(e,t,n))return})}function er(e,t,n){var r,i,o=0,a=Gn.length,s=b.Deferred().always(function(){delete u.elem}),u=function(){if(i)return!1;var t=Xn||Kn(),n=Math.max(0,l.startTime+l.duration-t),r=n/l.duration||0,o=1-r,a=0,u=l.tweens.length;for(;u>a;a++)l.tweens[a].run(o);return s.notifyWith(e,[l,o,n]),1>o&&u?n:(s.resolveWith(e,[l]),!1)},l=s.promise({elem:e,props:b.extend({},t),opts:b.extend(!0,{specialEasing:{}},n),originalProperties:t,originalOptions:n,startTime:Xn||Kn(),duration:n.duration,tweens:[],createTween:function(t,n){var r=b.Tween(e,l.opts,t,n,l.opts.specialEasing[t]||l.opts.easing);return l.tweens.push(r),r},stop:function(t){var n=0,r=t?l.tweens.length:0;if(i)return this;for(i=!0;r>n;n++)l.tweens[n].run(1);return t?s.resolveWith(e,[l,t]):s.rejectWith(e,[l,t]),this}}),c=
l.props;for(tr(c,l.opts.specialEasing);a>o;o++)if(r=Gn[o].call(l,e,c,l.opts))return r;return Zn(l,c),b.isFunction(l.opts.start)&&l.opts.start.call(e,l),b.fx.timer(b.extend(u,{elem:e,anim:l,queue:l.opts.queue})),l.progress(l.opts.progress).done(l.opts.done,l.opts.complete).fail(l.opts.fail).always(l.opts.always)}function tr(e,t){var n,r,i,o,a;for(i in e)if(r=b.camelCase(i),o=t[r],n=e[i],b.isArray(n)&&(o=n[1],n=e[i]=n[0]),i!==r&&(e[r]=n,delete e[i]),a=b.cssHooks[r],a&&"expand"in a){n=a.expand(n),delete e[r];for(i in n)i in e||(e[i]=n[i],t[i]=o)}else t[r]=o}b.Animation=b.extend(er,{tweener:function(e,t){b.isFunction(e)?(t=e,e=["*"]):e=e.split(" ");var n,r=0,i=e.length;for(;i>r;r++)n=e[r],Qn[n]=Qn[n]||[],Qn[n].unshift(t)},prefilter:function(e,t){t?Gn.unshift(e):Gn.push(e)}});function nr(e,t,n){var r,i,o,a,s,u,l,c,p,f=this,d=e.style,h={},g=[],m=e.nodeType&&nn(e);n.queue||(c=b._queueHooks(e,"fx"),null==c.unqueued&&(c.unqueued=0,p=c.empty.fire,c.empty.fire=function(){c.unqueued||p(
)}),c.unqueued++,f.always(function(){f.always(function(){c.unqueued--,b.queue(e,"fx").length||c.empty.fire()})})),1===e.nodeType&&("height"in t||"width"in t)&&(n.overflow=[d.overflow,d.overflowX,d.overflowY],"inline"===b.css(e,"display")&&"none"===b.css(e,"float")&&(b.support.inlineBlockNeedsLayout&&"inline"!==un(e.nodeName)?d.zoom=1:d.display="inline-block")),n.overflow&&(d.overflow="hidden",b.support.shrinkWrapBlocks||f.always(function(){d.overflow=n.overflow[0],d.overflowX=n.overflow[1],d.overflowY=n.overflow[2]}));for(i in t)if(a=t[i],Vn.exec(a)){if(delete t[i],u=u||"toggle"===a,a===(m?"hide":"show"))continue;g.push(i)}if(o=g.length){s=b._data(e,"fxshow")||b._data(e,"fxshow",{}),"hidden"in s&&(m=s.hidden),u&&(s.hidden=!m),m?b(e).show():f.done(function(){b(e).hide()}),f.done(function(){var t;b._removeData(e,"fxshow");for(t in h)b.style(e,t,h[t])});for(i=0;o>i;i++)r=g[i],l=f.createTween(r,m?s[r]:0),h[r]=s[r]||b.style(e,r),r in s||(s[r]=l.start,m&&(l.end=l.start,l.start="wi
dth"===r||"height"===r?1:0))}}function rr(e,t,n,r,i){return new rr.prototype.init(e,t,n,r,i)}b.Tween=rr,rr.prototype={constructor:rr,init:function(e,t,n,r,i,o){this.elem=e,this.prop=n,this.easing=i||"swing",this.options=t,this.start=this.now=this.cur(),this.end=r,this.unit=o||(b.cssNumber[n]?"":"px")},cur:function(){var e=rr.propHooks[this.prop];return e&&e.get?e.get(this):rr.propHooks._default.get(this)},run:function(e){var t,n=rr.propHooks[this.prop];return this.pos=t=this.options.duration?b.easing[this.easing](e,this.options.duration*e,0,1,this.options.duration):e,this.now=(this.end-this.start)*t+this.start,this.options.step&&this.options.step.call(this.elem,this.now,this),n&&n.set?n.set(this):rr.propHooks._default.set(this),this}},rr.prototype.init.prototype=rr.prototype,rr.propHooks={_default:{get:function(e){var t;return null==e.elem[e.prop]||e.elem.style&&null!=e.elem.style[e.prop]?(t=b.css(e.elem,e.prop,""),t&&"auto"!==t?t:0):e.elem[e.prop]},set:function(e){b.fx.step
[e.prop]?b.fx.step[e.prop](e):e.elem.style&&(null!=e.elem.style[b.cssProps[e.prop]]||b.cssHooks[e.prop])?b.style(e.elem,e.prop,e.now+e.unit):e.elem[e.prop]=e.now}}},rr.propHooks.scrollTop=rr.propHooks.scrollLeft={set:function(e){e.elem.nodeType&&e.elem.parentNode&&(e.elem[e.prop]=e.now)}},b.each(["toggle","show","hide"],function(e,t){var n=b.fn[t];b.fn[t]=function(e,r,i){return null==e||"boolean"==typeof e?n.apply(this,arguments):this.animate(ir(t,!0),e,r,i)}}),b.fn.extend({fadeTo:function(e,t,n,r){return this.filter(nn).css("opacity",0).show().end().animate({opacity:t},e,n,r)},animate:function(e,t,n,r){var i=b.isEmptyObject(e),o=b.speed(t,n,r),a=function(){var t=er(this,b.extend({},e),o);a.finish=function(){t.stop(!0)},(i||b._data(this,"finish"))&&t.stop(!0)};return a.finish=a,i||o.queue===!1?this.each(a):this.queue(o.queue,a)},stop:function(e,n,r){var i=function(e){var t=e.stop;delete e.stop,t(r)};return"string"!=typeof e&&(r=n,n=e,e=t),n&&e!==!1&&this.queue(e||"fx",[]),th
is.each(function(){var t=!0,n=null!=e&&e+"queueHooks",o=b.timers,a=b._data(this);if(n)a[n]&&a[n].stop&&i(a[n]);else for(n in a)a[n]&&a[n].stop&&Jn.test(n)&&i(a[n]);for(n=o.length;n--;)o[n].elem!==this||null!=e&&o[n].queue!==e||(o[n].anim.stop(r),t=!1,o.splice(n,1));(t||!r)&&b.dequeue(this,e)})},finish:function(e){return e!==!1&&(e=e||"fx"),this.each(function(){var t,n=b._data(this),r=n[e+"queue"],i=n[e+"queueHooks"],o=b.timers,a=r?r.length:0;for(n.finish=!0,b.queue(this,e,[]),i&&i.cur&&i.cur.finish&&i.cur.finish.call(this),t=o.length;t--;)o[t].elem===this&&o[t].queue===e&&(o[t].anim.stop(!0),o.splice(t,1));for(t=0;a>t;t++)r[t]&&r[t].finish&&r[t].finish.call(this);delete n.finish})}});function ir(e,t){var n,r={height:e},i=0;for(t=t?1:0;4>i;i+=2-t)n=Zt[i],r["margin"+n]=r["padding"+n]=e;return t&&(r.opacity=r.width=e),r}b.each({slideDown:ir("show"),slideUp:ir("hide"),slideToggle:ir("toggle"),fadeIn:{opacity:"show"},fadeOut:{opacity:"hide"},fadeToggle:{opacity:"toggle"}},functio
n(e,t){b.fn[e]=function(e,n,r){return this.animate(t,e,n,r)}}),b.speed=function(e,t,n){var r=e&&"object"==typeof e?b.extend({},e):{complete:n||!n&&t||b.isFunction(e)&&e,duration:e,easing:n&&t||t&&!b.isFunction(t)&&t};return r.duration=b.fx.off?0:"number"==typeof r.duration?r.duration:r.duration in b.fx.speeds?b.fx.speeds[r.duration]:b.fx.speeds._default,(null==r.queue||r.queue===!0)&&(r.queue="fx"),r.old=r.complete,r.complete=function(){b.isFunction(r.old)&&r.old.call(this),r.queue&&b.dequeue(this,r.queue)},r},b.easing={linear:function(e){return e},swing:function(e){return.5-Math.cos(e*Math.PI)/2}},b.timers=[],b.fx=rr.prototype.init,b.fx.tick=function(){var e,n=b.timers,r=0;for(Xn=b.now();n.length>r;r++)e=n[r],e()||n[r]!==e||n.splice(r--,1);n.length||b.fx.stop(),Xn=t},b.fx.timer=function(e){e()&&b.timers.push(e)&&b.fx.start()},b.fx.interval=13,b.fx.start=function(){Un||(Un=setInterval(b.fx.tick,b.fx.interval))},b.fx.stop=function(){clearInterval(Un),Un=null},b.fx.speeds={slo
w:600,fast:200,_default:400},b.fx.step={},b.expr&&b.expr.filters&&(b.expr.filters.animated=function(e){return b.grep(b.timers,function(t){return e===t.elem}).length}),b.fn.offset=function(e){if(arguments.length)return e===t?this:this.each(function(t){b.offset.setOffset(this,e,t)});var n,r,o={top:0,left:0},a=this[0],s=a&&a.ownerDocument;if(s)return n=s.documentElement,b.contains(n,a)?(typeof a.getBoundingClientRect!==i&&(o=a.getBoundingClientRect()),r=or(s),{top:o.top+(r.pageYOffset||n.scrollTop)-(n.clientTop||0),left:o.left+(r.pageXOffset||n.scrollLeft)-(n.clientLeft||0)}):o},b.offset={setOffset:function(e,t,n){var r=b.css(e,"position");"static"===r&&(e.style.position="relative");var i=b(e),o=i.offset(),a=b.css(e,"top"),s=b.css(e,"left"),u=("absolute"===r||"fixed"===r)&&b.inArray("auto",[a,s])>-1,l={},c={},p,f;u?(c=i.position(),p=c.top,f=c.left):(p=parseFloat(a)||0,f=parseFloat(s)||0),b.isFunction(t)&&(t=t.call(e,n,o)),null!=t.top&&(l.top=t.top-o.top+p),null!=t.left&&(l.left
=t.left-o.left+f),"using"in t?t.using.call(e,l):i.css(l)}},b.fn.extend({position:function(){if(this[0]){var e,t,n={top:0,left:0},r=this[0];return"fixed"===b.css(r,"position")?t=r.getBoundingClientRect():(e=this.offsetParent(),t=this.offset(),b.nodeName(e[0],"html")||(n=e.offset()),n.top+=b.css(e[0],"borderTopWidth",!0),n.left+=b.css(e[0],"borderLeftWidth",!0)),{top:t.top-n.top-b.css(r,"marginTop",!0),left:t.left-n.left-b.css(r,"marginLeft",!0)}}},offsetParent:function(){return this.map(function(){var e=this.offsetParent||o.documentElement;while(e&&!b.nodeName(e,"html")&&"static"===b.css(e,"position"))e=e.offsetParent;return e||o.documentElement})}}),b.each({scrollLeft:"pageXOffset",scrollTop:"pageYOffset"},function(e,n){var r=/Y/.test(n);b.fn[e]=function(i){return b.access(this,function(e,i,o){var a=or(e);return o===t?a?n in a?a[n]:a.document.documentElement[i]:e[i]:(a?a.scrollTo(r?b(a).scrollLeft():o,r?o:b(a).scrollTop()):e[i]=o,t)},e,i,arguments.length,null)}});function or
(e){return b.isWindow(e)?e:9===e.nodeType?e.defaultView||e.parentWindow:!1}b.each({Height:"height",Width:"width"},function(e,n){b.each({padding:"inner"+e,content:n,"":"outer"+e},function(r,i){b.fn[i]=function(i,o){var a=arguments.length&&(r||"boolean"!=typeof i),s=r||(i===!0||o===!0?"margin":"border");return b.access(this,function(n,r,i){var o;return b.isWindow(n)?n.document.documentElement["client"+e]:9===n.nodeType?(o=n.documentElement,Math.max(n.body["scroll"+e],o["scroll"+e],n.body["offset"+e],o["offset"+e],o["client"+e])):i===t?b.css(n,r,s):b.style(n,r,i,s)},n,a?i:t,a,null)}})}),e.jQuery=e.$=b,"function"==typeof define&&define.amd&&define.amd.jQuery&&define("jquery",[],function(){return b})})(window);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/mobilemap/js/jquery.mobile.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/jquery.mobile.min.js (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/js/jquery.mobile.min.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -0,0 +1,7 @@
+/*! jQuery Mobile 1.3.1 | Git HEAD hash: 74b4bec <> 2013-05-07T17:40:22Z | (c) 2010, 2013 jQuery Foundation, Inc. | jquery.org/license */
+(function(e,t,i){"function"==typeof define&&define.amd?define(["jquery"],function(n){return i(n,e,t),n.mobile}):i(e.jQuery,e,t)})(this,document,function(e,t,i,n){(function(e){e.mobile={}})(e),function(e,t,n){var a={};e.mobile=e.extend(e.mobile,{version:"1.3.1",ns:"",subPageUrlKey:"ui-page",activePageClass:"ui-page-active",activeBtnClass:"ui-btn-active",focusClass:"ui-focus",ajaxEnabled:!0,hashListeningEnabled:!0,linkBindingEnabled:!0,defaultPageTransition:"fade",maxTransitionWidth:!1,minScrollBack:250,touchOverflowEnabled:!1,defaultDialogTransition:"pop",pageLoadErrorMessage:"Error Loading Page",pageLoadErrorMessageTheme:"e",phonegapNavigationEnabled:!1,autoInitializePage:!0,pushStateEnabled:!0,ignoreContentEnabled:!1,orientationChangeEnabled:!0,buttonMarkup:{hoverDelay:200},window:e(t),document:e(i),keyCode:{ALT:18,BACKSPACE:8,CAPS_LOCK:20,COMMA:188,COMMAND:91,COMMAND_LEFT:91,COMMAND_RIGHT:93,CONTROL:17,DELETE:46,DOWN:40,END:35,ENTER:13,ESCAPE:27,HOME:36,INSERT:45,LEFT:37,M
ENU:93,NUMPAD_ADD:107,NUMPAD_DECIMAL:110,NUMPAD_DIVIDE:111,NUMPAD_ENTER:108,NUMPAD_MULTIPLY:106,NUMPAD_SUBTRACT:109,PAGE_DOWN:34,PAGE_UP:33,PERIOD:190,RIGHT:39,SHIFT:16,SPACE:32,TAB:9,UP:38,WINDOWS:91},behaviors:{},silentScroll:function(i){"number"!==e.type(i)&&(i=e.mobile.defaultHomeScroll),e.event.special.scrollstart.enabled=!1,setTimeout(function(){t.scrollTo(0,i),e.mobile.document.trigger("silentscroll",{x:0,y:i})},20),setTimeout(function(){e.event.special.scrollstart.enabled=!0},150)},nsNormalizeDict:a,nsNormalize:function(t){return t?a[t]||(a[t]=e.camelCase(e.mobile.ns+t)):n},getInheritedTheme:function(e,t){for(var i,n,a=e[0],o="",s=/ui-(bar|body|overlay)-([a-z])\b/;a&&(i=a.className||"",!(i&&(n=s.exec(i))&&(o=n[2])));)a=a.parentNode;return o||t||"a"},closestPageData:function(e){return e.closest(':jqmData(role="page"), :jqmData(role="dialog")').data("mobile-page")},enhanceable:function(e){return this.haveParents(e,"enhance")},hijackable:function(e){return this.havePare
nts(e,"ajax")},haveParents:function(t,i){if(!e.mobile.ignoreContentEnabled)return t;for(var n,a,o,s=t.length,r=e(),l=0;s>l;l++){for(a=t.eq(l),o=!1,n=t[l];n;){var d=n.getAttribute?n.getAttribute("data-"+e.mobile.ns+i):"";if("false"===d){o=!0;break}n=n.parentNode}o||(r=r.add(a))}return r},getScreenHeight:function(){return t.innerHeight||e.mobile.window.height()}},e.mobile),e.fn.jqmData=function(t,i){var a;return t!==n&&(t&&(t=e.mobile.nsNormalize(t)),a=2>arguments.length||i===n?this.data(t):this.data(t,i)),a},e.jqmData=function(t,i,a){var o;return i!==n&&(o=e.data(t,i?e.mobile.nsNormalize(i):i,a)),o},e.fn.jqmRemoveData=function(t){return this.removeData(e.mobile.nsNormalize(t))},e.jqmRemoveData=function(t,i){return e.removeData(t,e.mobile.nsNormalize(i))},e.fn.removeWithDependents=function(){e.removeWithDependents(this)},e.removeWithDependents=function(t){var i=e(t);(i.jqmData("dependents")||e()).remove(),i.remove()},e.fn.addDependents=function(t){e.addDependents(e(this),t)},e
.addDependents=function(t,i){var n=e(t).jqmData("dependents")||e();e(t).jqmData("dependents",e.merge(n,i))},e.fn.getEncodedText=function(){return e("<div/>").text(e(this).text()).html()},e.fn.jqmEnhanceable=function(){return e.mobile.enhanceable(this)},e.fn.jqmHijackable=function(){return e.mobile.hijackable(this)};var o=e.find,s=/:jqmData\(([^)]*)\)/g;e.find=function(t,i,n,a){return t=t.replace(s,"[data-"+(e.mobile.ns||"")+"$1]"),o.call(this,t,i,n,a)},e.extend(e.find,o),e.find.matches=function(t,i){return e.find(t,null,null,i)},e.find.matchesSelector=function(t,i){return e.find(i,null,null,[t]).length>0}}(e,this),function(e,t){var i=0,n=Array.prototype.slice,a=e.cleanData;e.cleanData=function(t){for(var i,n=0;null!=(i=t[n]);n++)try{e(i).triggerHandler("remove")}catch(o){}a(t)},e.widget=function(i,n,a){var o,s,r,l,d=i.split(".")[0];i=i.split(".")[1],o=d+"-"+i,a||(a=n,n=e.Widget),e.expr[":"][o.toLowerCase()]=function(t){return!!e.data(t,o)},e[d]=e[d]||{},s=e[d][i],r=e[d][i]=f
unction(e,i){return this._createWidget?(arguments.length&&this._createWidget(e,i),t):new r(e,i)},e.extend(r,s,{version:a.version,_proto:e.extend({},a),_childConstructors:[]}),l=new n,l.options=e.widget.extend({},l.options),e.each(a,function(t,i){e.isFunction(i)&&(a[t]=function(){var e=function(){return n.prototype[t].apply(this,arguments)},a=function(e){return n.prototype[t].apply(this,e)};return function(){var t,n=this._super,o=this._superApply;return this._super=e,this._superApply=a,t=i.apply(this,arguments),this._super=n,this._superApply=o,t}}())}),r.prototype=e.widget.extend(l,{widgetEventPrefix:s?l.widgetEventPrefix:i},a,{constructor:r,namespace:d,widgetName:i,widgetFullName:o}),s?(e.each(s._childConstructors,function(t,i){var n=i.prototype;e.widget(n.namespace+"."+n.widgetName,r,i._proto)}),delete s._childConstructors):n._childConstructors.push(r),e.widget.bridge(i,r)},e.widget.extend=function(i){for(var a,o,s=n.call(arguments,1),r=0,l=s.length;l>r;r++)for(a in s[r])o=
s[r][a],s[r].hasOwnProperty(a)&&o!==t&&(i[a]=e.isPlainObject(o)?e.isPlainObject(i[a])?e.widget.extend({},i[a],o):e.widget.extend({},o):o);return i},e.widget.bridge=function(i,a){var o=a.prototype.widgetFullName||i;e.fn[i]=function(s){var r="string"==typeof s,l=n.call(arguments,1),d=this;return s=!r&&l.length?e.widget.extend.apply(null,[s].concat(l)):s,r?this.each(function(){var n,a=e.data(this,o);return a?e.isFunction(a[s])&&"_"!==s.charAt(0)?(n=a[s].apply(a,l),n!==a&&n!==t?(d=n&&n.jquery?d.pushStack(n.get()):n,!1):t):e.error("no such method '"+s+"' for "+i+" widget instance"):e.error("cannot call methods on "+i+" prior to initialization; "+"attempted to call method '"+s+"'")}):this.each(function(){var t=e.data(this,o);t?t.option(s||{})._init():e.data(this,o,new a(s,this))}),d}},e.Widget=function(){},e.Widget._childConstructors=[],e.Widget.prototype={widgetName:"widget",widgetEventPrefix:"",defaultElement:"<div>",options:{disabled:!1,create:null},_createWidget:function(t,n){
n=e(n||this.defaultElement||this)[0],this.element=e(n),this.uuid=i++,this.eventNamespace="."+this.widgetName+this.uuid,this.options=e.widget.extend({},this.options,this._getCreateOptions(),t),this.bindings=e(),this.hoverable=e(),this.focusable=e(),n!==this&&(e.data(n,this.widgetFullName,this),this._on(!0,this.element,{remove:function(e){e.target===n&&this.destroy()}}),this.document=e(n.style?n.ownerDocument:n.document||n),this.window=e(this.document[0].defaultView||this.document[0].parentWindow)),this._create(),this._trigger("create",null,this._getCreateEventData()),this._init()},_getCreateOptions:e.noop,_getCreateEventData:e.noop,_create:e.noop,_init:e.noop,destroy:function(){this._destroy(),this.element.unbind(this.eventNamespace).removeData(this.widgetName).removeData(this.widgetFullName).removeData(e.camelCase(this.widgetFullName)),this.widget().unbind(this.eventNamespace).removeAttr("aria-disabled").removeClass(this.widgetFullName+"-disabled "+"ui-state-disabled"),this.
bindings.unbind(this.eventNamespace),this.hoverable.removeClass("ui-state-hover"),this.focusable.removeClass("ui-state-focus")},_destroy:e.noop,widget:function(){return this.element},option:function(i,n){var a,o,s,r=i;if(0===arguments.length)return e.widget.extend({},this.options);if("string"==typeof i)if(r={},a=i.split("."),i=a.shift(),a.length){for(o=r[i]=e.widget.extend({},this.options[i]),s=0;a.length-1>s;s++)o[a[s]]=o[a[s]]||{},o=o[a[s]];if(i=a.pop(),n===t)return o[i]===t?null:o[i];o[i]=n}else{if(n===t)return this.options[i]===t?null:this.options[i];r[i]=n}return this._setOptions(r),this},_setOptions:function(e){var t;for(t in e)this._setOption(t,e[t]);return this},_setOption:function(e,t){return this.options[e]=t,"disabled"===e&&(this.widget().toggleClass(this.widgetFullName+"-disabled ui-state-disabled",!!t).attr("aria-disabled",t),this.hoverable.removeClass("ui-state-hover"),this.focusable.removeClass("ui-state-focus")),this},enable:function(){return this._setOption(
"disabled",!1)},disable:function(){return this._setOption("disabled",!0)},_on:function(i,n,a){var o,s=this;"boolean"!=typeof i&&(a=n,n=i,i=!1),a?(n=o=e(n),this.bindings=this.bindings.add(n)):(a=n,n=this.element,o=this.widget()),e.each(a,function(a,r){function l(){return i||s.options.disabled!==!0&&!e(this).hasClass("ui-state-disabled")?("string"==typeof r?s[r]:r).apply(s,arguments):t}"string"!=typeof r&&(l.guid=r.guid=r.guid||l.guid||e.guid++);var d=a.match(/^(\w+)\s*(.*)$/),c=d[1]+s.eventNamespace,h=d[2];h?o.delegate(h,c,l):n.bind(c,l)})},_off:function(e,t){t=(t||"").split(" ").join(this.eventNamespace+" ")+this.eventNamespace,e.unbind(t).undelegate(t)},_delay:function(e,t){function i(){return("string"==typeof e?n[e]:e).apply(n,arguments)}var n=this;return setTimeout(i,t||0)},_hoverable:function(t){this.hoverable=this.hoverable.add(t),this._on(t,{mouseenter:function(t){e(t.currentTarget).addClass("ui-state-hover")},mouseleave:function(t){e(t.currentTarget).removeClass("ui-s
tate-hover")}})},_focusable:function(t){this.focusable=this.focusable.add(t),this._on(t,{focusin:function(t){e(t.currentTarget).addClass("ui-state-focus")},focusout:function(t){e(t.currentTarget).removeClass("ui-state-focus")}})},_trigger:function(t,i,n){var a,o,s=this.options[t];if(n=n||{},i=e.Event(i),i.type=(t===this.widgetEventPrefix?t:this.widgetEventPrefix+t).toLowerCase(),i.target=this.element[0],o=i.originalEvent)for(a in o)a in i||(i[a]=o[a]);return this.element.trigger(i,n),!(e.isFunction(s)&&s.apply(this.element[0],[i].concat(n))===!1||i.isDefaultPrevented())}},e.each({show:"fadeIn",hide:"fadeOut"},function(t,i){e.Widget.prototype["_"+t]=function(n,a,o){"string"==typeof a&&(a={effect:a});var s,r=a?a===!0||"number"==typeof a?i:a.effect||i:t;a=a||{},"number"==typeof a&&(a={duration:a}),s=!e.isEmptyObject(a),a.complete=o,a.delay&&n.delay(a.delay),s&&e.effects&&e.effects.effect[r]?n[t](a):r!==t&&n[r]?n[r](a.duration,a.easing,o):n.queue(function(i){e(this)[t](),o&&o.ca
ll(n[0]),i()})}})}(e),function(e,t){e.widget("mobile.widget",{_createWidget:function(){e.Widget.prototype._createWidget.apply(this,arguments),this._trigger("init")},_getCreateOptions:function(){var i=this.element,n={};return e.each(this.options,function(e){var a=i.jqmData(e.replace(/[A-Z]/g,function(e){return"-"+e.toLowerCase()}));a!==t&&(n[e]=a)}),n},enhanceWithin:function(t,i){this.enhance(e(this.options.initSelector,e(t)),i)},enhance:function(t,i){var n,a,o=e(t);o=e.mobile.enhanceable(o),i&&o.length&&(n=e.mobile.closestPageData(o),a=n&&n.keepNativeSelector()||"",o=o.not(a)),o[this.widgetName]()},raise:function(e){throw"Widget ["+this.widgetName+"]: "+e}})}(e),function(e){e.extend(e.mobile,{loadingMessageTextVisible:n,loadingMessageTheme:n,loadingMessage:n,showPageLoadingMsg:function(t,i,n){e.mobile.loading("show",t,i,n)},hidePageLoadingMsg:function(){e.mobile.loading("hide")},loading:function(){this.loaderWidget.loader.apply(this.loaderWidget,arguments)}});var t="ui-loade
r",i=e("html"),a=e.mobile.window;e.widget("mobile.loader",{options:{theme:"a",textVisible:!1,html:"",text:"loading"},defaultHtml:"<div class='"+t+"'>"+"<span class='ui-icon ui-icon-loading'></span>"+"<h1></h1>"+"</div>",fakeFixLoader:function(){var t=e("."+e.mobile.activeBtnClass).first();this.element.css({top:e.support.scrollTop&&a.scrollTop()+a.height()/2||t.length&&t.offset().top||100})},checkLoaderPosition:function(){var t=this.element.offset(),i=a.scrollTop(),n=e.mobile.getScreenHeight();(i>t.top||t.top-i>n)&&(this.element.addClass("ui-loader-fakefix"),this.fakeFixLoader(),a.unbind("scroll",this.checkLoaderPosition).bind("scroll",e.proxy(this.fakeFixLoader,this)))},resetHtml:function(){this.element.html(e(this.defaultHtml).html())},show:function(o,s,r){var l,d,c;this.resetHtml(),"object"===e.type(o)?(c=e.extend({},this.options,o),o=c.theme||e.mobile.loadingMessageTheme):(c=this.options,o=o||e.mobile.loadingMessageTheme||c.theme),d=s||e.mobile.loadingMessage||c.text,i.ad
dClass("ui-loading"),(e.mobile.loadingMessage!==!1||c.html)&&(l=e.mobile.loadingMessageTextVisible!==n?e.mobile.loadingMessageTextVisible:c.textVisible,this.element.attr("class",t+" ui-corner-all ui-body-"+o+" ui-loader-"+(l||s||o.text?"verbose":"default")+(c.textonly||r?" ui-loader-textonly":"")),c.html?this.element.html(c.html):this.element.find("h1").text(d),this.element.appendTo(e.mobile.pageContainer),this.checkLoaderPosition(),a.bind("scroll",e.proxy(this.checkLoaderPosition,this)))},hide:function(){i.removeClass("ui-loading"),e.mobile.loadingMessage&&this.element.removeClass("ui-loader-fakefix"),e.mobile.window.unbind("scroll",this.fakeFixLoader),e.mobile.window.unbind("scroll",this.checkLoaderPosition)}}),a.bind("pagecontainercreate",function(){e.mobile.loaderWidget=e.mobile.loaderWidget||e(e.mobile.loader.prototype.defaultHtml).loader()})}(e,this),function(e,t,n){function a(e){return e=e||location.href,"#"+e.replace(/^[^#]*#?(.*)$/,"$1")}var o,s="hashchange",r=i,l=e
.event.special,d=r.documentMode,c="on"+s in t&&(d===n||d>7);e.fn[s]=function(e){return e?this.bind(s,e):this.trigger(s)},e.fn[s].delay=50,l[s]=e.extend(l[s],{setup:function(){return c?!1:(e(o.start),n)},teardown:function(){return c?!1:(e(o.stop),n)}}),o=function(){function i(){var n=a(),r=p(d);n!==d?(u(d=n,r),e(t).trigger(s)):r!==d&&(location.href=location.href.replace(/#.*/,"")+r),o=setTimeout(i,e.fn[s].delay)}var o,l={},d=a(),h=function(e){return e},u=h,p=h;return l.start=function(){o||i()},l.stop=function(){o&&clearTimeout(o),o=n},t.attachEvent&&!t.addEventListener&&!c&&function(){var t,n;l.start=function(){t||(n=e.fn[s].src,n=n&&n+a(),t=e('<iframe tabindex="-1" title="empty"/>').hide().one("load",function(){n||u(a()),i()}).attr("src",n||"javascript:0").insertAfter("body")[0].contentWindow,r.onpropertychange=function(){try{"title"===event.propertyName&&(t.document.title=r.title)}catch(e){}})},l.stop=h,p=function(){return a(t.location.href)},u=function(i,n){var a=t.documen
t,o=e.fn[s].domain;i!==n&&(a.title=r.title,a.open(),o&&a.write('<script>document.domain="'+o+'"</script>'),a.close(),t.location.hash=i)}}(),l}()}(e,this),function(e){t.matchMedia=t.matchMedia||function(e){var t,i=e.documentElement,n=i.firstElementChild||i.firstChild,a=e.createElement("body"),o=e.createElement("div");return o.id="mq-test-1",o.style.cssText="position:absolute;top:-100em",a.style.background="none",a.appendChild(o),function(e){return o.innerHTML='<style media="'+e+'"> #mq-test-1 { width: 42px; }</style>',i.insertBefore(a,n),t=42===o.offsetWidth,i.removeChild(a),{matches:t,media:e}}}(i),e.mobile.media=function(e){return t.matchMedia(e).matches}}(e),function(e){var t={touch:"ontouchend"in i};e.mobile.support=e.mobile.support||{},e.extend(e.support,t),e.extend(e.mobile.support,t)}(e),function(e){e.extend(e.support,{orientation:"orientation"in t&&"onorientationchange"in t})}(e),function(e,n){function a(e){var t=e.charAt(0).toUpperCase()+e.substr(1),i=(e+" "+p.j
oin(t+" ")+t).split(" ");for(var a in i)if(u[i[a]]!==n)return!0}function o(e,t,n){for(var a,o=i.createElement("div"),s=function(e){return e.charAt(0).toUpperCase()+e.substr(1)},r=function(e){return""===e?"":"-"+e.charAt(0).toLowerCase()+e.substr(1)+"-"},l=function(i){var n=r(i)+e+": "+t+";",l=s(i),d=l+(""===l?e:s(e));o.setAttribute("style",n),o.style[d]&&(a=!0)},d=n?n:p,c=0;d.length>c;c++)l(d[c]);return!!a}function s(){var a="transform-3d",o=e.mobile.media("(-"+p.join("-"+a+"),(-")+"-"+a+"),("+a+")");if(o)return!!o;var s=i.createElement("div"),r={MozTransform:"-moz-transform",transform:"transform"};h.append(s);for(var l in r)s.style[l]!==n&&(s.style[l]="translate3d( 100px, 1px, 1px )",o=t.getComputedStyle(s).getPropertyValue(r[l]));return!!o&&"none"!==o}function r(){var t,i,n=location.protocol+"//"+location.host+location.pathname+"ui-dir/",a=e("head base"),o=null,s="";return a.length?s=a.attr("href"):a=o=e("<base>",{href:n}).appendTo("head"),t=e("<a href='testurl' />").prepe
ndTo(h),i=t[0].href,a[0].href=s||location.pathname,o&&o.remove(),0===i.indexOf(n)}function l(){var e,n=i.createElement("x"),a=i.documentElement,o=t.getComputedStyle;return"pointerEvents"in n.style?(n.style.pointerEvents="auto",n.style.pointerEvents="x",a.appendChild(n),e=o&&"auto"===o(n,"").pointerEvents,a.removeChild(n),!!e):!1}function d(){var e=i.createElement("div");return e.getBoundingClientRect!==n}function c(){var e=t,i=navigator.userAgent,n=navigator.platform,a=i.match(/AppleWebKit\/([0-9]+)/),o=!!a&&a[1],s=i.match(/Fennec\/([0-9]+)/),r=!!s&&s[1],l=i.match(/Opera Mobi\/([0-9]+)/),d=!!l&&l[1];return(n.indexOf("iPhone")>-1||n.indexOf("iPad")>-1||n.indexOf("iPod")>-1)&&o&&534>o||e.operamini&&"[object OperaMini]"==={}.toString.call(e.operamini)||l&&7458>d||i.indexOf("Android")>-1&&o&&533>o||r&&6>r||"palmGetResource"in t&&o&&534>o||i.indexOf("MeeGo")>-1&&i.indexOf("NokiaBrowser/8.5.0")>-1?!1:!0}var h=e("<body>").prependTo("html"),u=h[0].style,p=["Webkit","Moz","O"],m="pal
mGetResource"in t,f=t.opera,g=t.operamini&&"[object OperaMini]"==={}.toString.call(t.operamini),b=t.blackberry&&!a("-webkit-transform");e.extend(e.mobile,{browser:{}}),e.mobile.browser.oldIE=function(){var e=3,t=i.createElement("div"),n=t.all||[];do t.innerHTML="<!--[if gt IE "+ ++e+"]><br><![endif]-->";while(n[0]);return e>4?e:!e}(),e.extend(e.support,{cssTransitions:"WebKitTransitionEvent"in t||o("transition","height 100ms linear",["Webkit","Moz",""])&&!e.mobile.browser.oldIE&&!f,pushState:"pushState"in history&&"replaceState"in history&&!(t.navigator.userAgent.indexOf("Firefox")>=0&&t.top!==t)&&-1===t.navigator.userAgent.search(/CriOS/),mediaquery:e.mobile.media("only all"),cssPseudoElement:!!a("content"),touchOverflow:!!a("overflowScrolling"),cssTransform3d:s(),boxShadow:!!a("boxShadow")&&!b,fixedPosition:c(),scrollTop:("pageXOffset"in t||"scrollTop"in i.documentElement||"scrollTop"in h[0])&&!m&&!g,dynamicBaseTag:r(),cssPointerEvents:l(),boundingRect:d()}),h.remove();var
v=function(){var e=t.navigator.userAgent;return e.indexOf("Nokia")>-1&&(e.indexOf("Symbian/3")>-1||e.indexOf("Series60/5")>-1)&&e.indexOf("AppleWebKit")>-1&&e.match(/(BrowserNG|NokiaBrowser)\/7\.[0-3]/)}();e.mobile.gradeA=function(){return(e.support.mediaquery||e.mobile.browser.oldIE&&e.mobile.browser.oldIE>=7)&&(e.support.boundingRect||null!==e.fn.jquery.match(/1\.[0-7+]\.[0-9+]?/))},e.mobile.ajaxBlacklist=t.blackberry&&!t.WebKitPoint||g||v,v&&e(function(){e("head link[rel='stylesheet']").attr("rel","alternate stylesheet").attr("rel","stylesheet")}),e.support.boxShadow||e("html").addClass("ui-mobile-nosupport-boxshadow")}(e),function(e,t){var i,n=e.mobile.window;e.event.special.navigate=i={bound:!1,pushStateEnabled:!0,originalEventName:t,isPushStateEnabled:function(){return e.support.pushState&&e.mobile.pushStateEnabled===!0&&this.isHashChangeEnabled()},isHashChangeEnabled:function(){return e.mobile.hashListeningEnabled===!0},popstate:function(t){var i=new e.Event("navigat
e"),a=new e.Event("beforenavigate"),o=t.originalEvent.state||{};location.href,n.trigger(a),a.isDefaultPrevented()||(t.historyState&&e.extend(o,t.historyState),i.originalEvent=t,setTimeout(function(){n.trigger(i,{state:o})},0))},hashchange:function(t){var i=new e.Event("navigate"),a=new e.Event("beforenavigate");n.trigger(a),a.isDefaultPrevented()||(i.originalEvent=t,n.trigger(i,{state:t.hashchangeState||{}}))},setup:function(){i.bound||(i.bound=!0,i.isPushStateEnabled()?(i.originalEventName="popstate",n.bind("popstate.navigate",i.popstate)):i.isHashChangeEnabled()&&(i.originalEventName="hashchange",n.bind("hashchange.navigate",i.hashchange)))}}}(e),function(e,i){var n,a,o="&ui-state=dialog";e.mobile.path=n={uiStateKey:"&ui-state",urlParseRE:/^\s*(((([^:\/#\?]+:)?(?:(\/\/)((?:(([^:@\/#\?]+)(?:\:([^:@\/#\?]+))?)@)?(([^:\/#\?\]\[]+|\[[^\/\]@#?]+\])(?:\:([0-9]+))?))?)?)?((\/?(?:[^\/\?#]+\/+)*)([^\?#]*)))?(\?[^#]+)?)(#.*)?/,getLocation:function(e){var t=e?this.parseUrl(e):locatio
n,i=this.parseUrl(e||location.href).hash;return i="#"===i?"":i,t.protocol+"//"+t.host+t.pathname+t.search+i},parseLocation:function(){return this.parseUrl(this.getLocation())},parseUrl:function(t){if("object"===e.type(t))return t;var i=n.urlParseRE.exec(t||"")||[];return{href:i[0]||"",hrefNoHash:i[1]||"",hrefNoSearch:i[2]||"",domain:i[3]||"",protocol:i[4]||"",doubleSlash:i[5]||"",authority:i[6]||"",username:i[8]||"",password:i[9]||"",host:i[10]||"",hostname:i[11]||"",port:i[12]||"",pathname:i[13]||"",directory:i[14]||"",filename:i[15]||"",search:i[16]||"",hash:i[17]||""}},makePathAbsolute:function(e,t){if(e&&"/"===e.charAt(0))return e;e=e||"",t=t?t.replace(/^\/|(\/[^\/]*|[^\/]+)$/g,""):"";for(var i=t?t.split("/"):[],n=e.split("/"),a=0;n.length>a;a++){var o=n[a];switch(o){case".":break;case"..":i.length&&i.pop();break;default:i.push(o)}}return"/"+i.join("/")},isSameDomain:function(e,t){return n.parseUrl(e).domain===n.parseUrl(t).domain},isRelativeUrl:function(e){return""===n.
parseUrl(e).protocol},isAbsoluteUrl:function(e){return""!==n.parseUrl(e).protocol},makeUrlAbsolute:function(e,t){if(!n.isRelativeUrl(e))return e;t===i&&(t=this.documentBase);var a=n.parseUrl(e),o=n.parseUrl(t),s=a.protocol||o.protocol,r=a.protocol?a.doubleSlash:a.doubleSlash||o.doubleSlash,l=a.authority||o.authority,d=""!==a.pathname,c=n.makePathAbsolute(a.pathname||o.filename,o.pathname),h=a.search||!d&&o.search||"",u=a.hash;return s+r+l+c+h+u},addSearchParams:function(t,i){var a=n.parseUrl(t),o="object"==typeof i?e.param(i):i,s=a.search||"?";return a.hrefNoSearch+s+("?"!==s.charAt(s.length-1)?"&":"")+o+(a.hash||"")},convertUrlToDataUrl:function(e){var i=n.parseUrl(e);return n.isEmbeddedPage(i)?i.hash.split(o)[0].replace(/^#/,"").replace(/\?.*$/,""):n.isSameDomain(i,this.documentBase)?i.hrefNoHash.replace(this.documentBase.domain,"").split(o)[0]:t.decodeURIComponent(e)},get:function(e){return e===i&&(e=n.parseLocation().hash),n.stripHash(e).replace(/[^\/]*\.[^\/*]+$/,"")},s
et:function(e){location.hash=e},isPath:function(e){return/\//.test(e)},clean:function(e){return e.replace(this.documentBase.domain,"")},stripHash:function(e){return e.replace(/^#/,"")},stripQueryParams:function(e){return e.replace(/\?.*$/,"")},cleanHash:function(e){return n.stripHash(e.replace(/\?.*$/,"").replace(o,""))},isHashValid:function(e){return/^#[^#]+$/.test(e)},isExternal:function(e){var t=n.parseUrl(e);return t.protocol&&t.domain!==this.documentUrl.domain?!0:!1},hasProtocol:function(e){return/^(:?\w+:)/.test(e)},isEmbeddedPage:function(e){var t=n.parseUrl(e);return""!==t.protocol?!this.isPath(t.hash)&&t.hash&&(t.hrefNoHash===this.documentUrl.hrefNoHash||this.documentBaseDiffers&&t.hrefNoHash===this.documentBase.hrefNoHash):/^#/.test(t.href)},squash:function(e,t){var i,a,o,s,r=this.isPath(e),l=this.parseUrl(e),d=l.hash,c="";return t=t||(n.isPath(e)?n.getLocation():n.getDocumentUrl()),a=r?n.stripHash(e):e,a=n.isPath(l.hash)?n.stripHash(l.hash):a,s=a.indexOf(this.uiSt
ateKey),s>-1&&(c=a.slice(s),a=a.slice(0,s)),i=n.makeUrlAbsolute(a,t),o=this.parseUrl(i).search,r?((n.isPath(d)||0===d.replace("#","").indexOf(this.uiStateKey))&&(d=""),c&&-1===d.indexOf(this.uiStateKey)&&(d+=c),-1===d.indexOf("#")&&""!==d&&(d="#"+d),i=n.parseUrl(i),i=i.protocol+"//"+i.host+i.pathname+o+d):i+=i.indexOf("#")>-1?c:"#"+c,i},isPreservableHash:function(e){return 0===e.replace("#","").indexOf(this.uiStateKey)}},n.documentUrl=n.parseLocation(),a=e("head").find("base"),n.documentBase=a.length?n.parseUrl(n.makeUrlAbsolute(a.attr("href"),n.documentUrl.href)):n.documentUrl,n.documentBaseDiffers=n.documentUrl.hrefNoHash!==n.documentBase.hrefNoHash,n.getDocumentUrl=function(t){return t?e.extend({},n.documentUrl):n.documentUrl.href},n.getDocumentBase=function(t){return t?e.extend({},n.documentBase):n.documentBase.href}}(e),function(e,t){e.mobile.path,e.mobile.History=function(e,t){this.stack=e||[],this.activeIndex=t||0},e.extend(e.mobile.History.prototype,{getActive:functi
on(){return this.stack[this.activeIndex]},getLast:function(){return this.stack[this.previousIndex]},getNext:function(){return this.stack[this.activeIndex+1]},getPrev:function(){return this.stack[this.activeIndex-1]},add:function(e,t){t=t||{},this.getNext()&&this.clearForward(),t.hash&&-1===t.hash.indexOf("#")&&(t.hash="#"+t.hash),t.url=e,this.stack.push(t),this.activeIndex=this.stack.length-1},clearForward:function(){this.stack=this.stack.slice(0,this.activeIndex+1)},find:function(e,t,i){t=t||this.stack;var n,a,o,s=t.length;for(a=0;s>a;a++)if(n=t[a],(decodeURIComponent(e)===decodeURIComponent(n.url)||decodeURIComponent(e)===decodeURIComponent(n.hash))&&(o=a,i))return o;return o},closest:function(e){var i,n=this.activeIndex;return i=this.find(e,this.stack.slice(0,n)),i===t&&(i=this.find(e,this.stack.slice(n),!0),i=i===t?i:i+n),i},direct:function(i){var n=this.closest(i.url),a=this.activeIndex;n!==t&&(this.activeIndex=n,this.previousIndex=a),a>n?(i.present||i.back||e.noop)(thi
s.getActive(),"back"):n>a?(i.present||i.forward||e.noop)(this.getActive(),"forward"):n===t&&i.missing&&i.missing(this.getActive())}})}(e),function(e){var a=e.mobile.path,o=location.href;e.mobile.Navigator=function(t){this.history=t,this.ignoreInitialHashChange=!0,e.mobile.window.bind({"popstate.history":e.proxy(this.popstate,this),"hashchange.history":e.proxy(this.hashchange,this)})},e.extend(e.mobile.Navigator.prototype,{squash:function(n,o){var s,r,l=a.isPath(n)?a.stripHash(n):n;return r=a.squash(n),s=e.extend({hash:l,url:r},o),t.history.replaceState(s,s.title||i.title,r),s},hash:function(e,t){var i,n,o;if(i=a.parseUrl(e),n=a.parseLocation(),n.pathname+n.search===i.pathname+i.search)o=i.hash?i.hash:i.pathname+i.search;else if(a.isPath(e)){var s=a.parseUrl(t);o=s.pathname+s.search+(a.isPreservableHash(s.hash)?s.hash.replace("#",""):"")}else o=e;return o},go:function(n,o,s){var r,l,d,c,h=e.event.special.navigate.isPushStateEnabled();l=a.squash(n),d=this.hash(n,l),s&&d!==a.st
ripHash(a.parseLocation().hash)&&(this.preventNextHashChange=s),this.preventHashAssignPopState=!0,t.location.hash=d,this.preventHashAssignPopState=!1,r=e.extend({url:l,hash:d,title:i.title},o),h&&(c=new e.Event("popstate"),c.originalEvent={type:"popstate",state:null},this.squash(n,r),s||(this.ignorePopState=!0,e.mobile.window.trigger(c))),this.history.add(r.url,r)},popstate:function(t){var i,s;if(e.event.special.navigate.isPushStateEnabled())return this.preventHashAssignPopState?(this.preventHashAssignPopState=!1,t.stopImmediatePropagation(),n):this.ignorePopState?(this.ignorePopState=!1,n):!t.originalEvent.state&&1===this.history.stack.length&&this.ignoreInitialHashChange&&(this.ignoreInitialHashChange=!1,location.href===o)?(t.preventDefault(),n):(i=a.parseLocation().hash,!t.originalEvent.state&&i?(s=this.squash(i),this.history.add(s.url,s),t.historyState=s,n):(this.history.direct({url:(t.originalEvent.state||{}).url||i,present:function(i,n){t.historyState=e.extend({},i),t.
historyState.direction=n}}),n))},hashchange:function(t){var o,s;if(e.event.special.navigate.isHashChangeEnabled()&&!e.event.special.navigate.isPushStateEnabled()){if(this.preventNextHashChange)return this.preventNextHashChange=!1,t.stopImmediatePropagation(),n;o=this.history,s=a.parseLocation().hash,this.history.direct({url:s,present:function(i,n){t.hashchangeState=e.extend({},i),t.hashchangeState.direction=n},missing:function(){o.add(s,{hash:s,title:i.title})}})}}})}(e),function(e){e.mobile.navigate=function(t,i,n){e.mobile.navigate.navigator.go(t,i,n)},e.mobile.navigate.history=new e.mobile.History,e.mobile.navigate.navigator=new e.mobile.Navigator(e.mobile.navigate.history);var t=e.mobile.path.parseLocation();e.mobile.navigate.history.add(t.href,{hash:t.hash})}(e),function(e,t,i,n){function a(e){for(;e&&e.originalEvent!==n;)e=e.originalEvent;return e}function o(t,i){var o,s,r,l,d,c,h,u,p,m=t.type;if(t=e.Event(t),t.type=i,o=t.originalEvent,s=e.event.props,m.search(/^(mouse
|click)/)>-1&&(s=q),o)for(h=s.length,l;h;)l=s[--h],t[l]=o[l];if(m.search(/mouse(down|up)|click/)>-1&&!t.which&&(t.which=1),-1!==m.search(/^touch/)&&(r=a(o),m=r.touches,d=r.changedTouches,c=m&&m.length?m[0]:d&&d.length?d[0]:n))for(u=0,p=k.length;p>u;u++)l=k[u],t[l]=c[l];return t}function s(t){for(var i,n,a={};t;){i=e.data(t,T);for(n in i)i[n]&&(a[n]=a.hasVirtualBinding=!0);t=t.parentNode}return a}function r(t,i){for(var n;t;){if(n=e.data(t,T),n&&(!i||n[i]))return t;t=t.parentNode}return null}function l(){M=!1}function d(){M=!0}function c(){U=0,O.length=0,H=!1,d()}function h(){l()}function u(){p(),S=setTimeout(function(){S=0,c()},e.vmouse.resetTimerDuration)}function p(){S&&(clearTimeout(S),S=0)}function m(t,i,n){var a;return(n&&n[t]||!n&&r(i.target,t))&&(a=o(i,t),e(i.target).trigger(a)),a}function f(t){var i=e.data(t.target,D);if(!(H||U&&U===i)){var n=m("v"+t.type,t);n&&(n.isDefaultPrevented()&&t.preventDefault(),n.isPropagationStopped()&&t.stopPropagation(),n.isImmediateProp
agationStopped()&&t.stopImmediatePropagation())}}function g(t){var i,n,o=a(t).touches;if(o&&1===o.length&&(i=t.target,n=s(i),n.hasVirtualBinding)){U=L++,e.data(i,D,U),p(),h(),I=!1;var r=a(t).touches[0];A=r.pageX,N=r.pageY,m("vmouseover",t,n),m("vmousedown",t,n)}}function b(e){M||(I||m("vmousecancel",e,s(e.target)),I=!0,u())}function v(t){if(!M){var i=a(t).touches[0],n=I,o=e.vmouse.moveDistanceThreshold,r=s(t.target);I=I||Math.abs(i.pageX-A)>o||Math.abs(i.pageY-N)>o,I&&!n&&m("vmousecancel",t,r),m("vmousemove",t,r),u()}}function _(e){if(!M){d();var t,i=s(e.target);if(m("vmouseup",e,i),!I){var n=m("vclick",e,i);n&&n.isDefaultPrevented()&&(t=a(e).changedTouches[0],O.push({touchID:U,x:t.clientX,y:t.clientY}),H=!0)}m("vmouseout",e,i),I=!1,u()}}function C(t){var i,n=e.data(t,T);if(n)for(i in n)if(n[i])return!0;return!1}function x(){}function y(t){var i=t.substr(1);return{setup:function(){C(this)||e.data(this,T,{});var n=e.data(this,T);n[t]=!0,j[t]=(j[t]||0)+1,1===j[t]&&B.bind(i,f),
e(this).bind(i,x),F&&(j.touchstart=(j.touchstart||0)+1,1===j.touchstart&&B.bind("touchstart",g).bind("touchend",_).bind("touchmove",v).bind("scroll",b))},teardown:function(){--j[t],j[t]||B.unbind(i,f),F&&(--j.touchstart,j.touchstart||B.unbind("touchstart",g).unbind("touchmove",v).unbind("touchend",_).unbind("scroll",b));var n=e(this),a=e.data(this,T);a&&(a[t]=!1),n.unbind(i,x),C(this)||n.removeData(T)}}}var w,T="virtualMouseBindings",D="virtualTouchID",P="vmouseover vmousedown vmousemove vmouseup vclick vmouseout vmousecancel".split(" "),k="clientX clientY pageX pageY screenX screenY".split(" "),E=e.event.mouseHooks?e.event.mouseHooks.props:[],q=e.event.props.concat(E),j={},S=0,A=0,N=0,I=!1,O=[],H=!1,M=!1,F="addEventListener"in i,B=e(i),L=1,U=0;e.vmouse={moveDistanceThreshold:10,clickDistanceThreshold:10,resetTimerDuration:1500};for(var z=0;P.length>z;z++)e.event.special[P[z]]=y(P[z]);F&&i.addEventListener("click",function(t){var i,a,o,s,r,l,d=O.length,c=t.target;if(d)for(i=
t.clientX,a=t.clientY,w=e.vmouse.clickDistanceThreshold,o=c;o;){for(s=0;d>s;s++)if(r=O[s],l=0,o===c&&w>Math.abs(r.x-i)&&w>Math.abs(r.y-a)||e.data(o,D)===r.touchID)return t.preventDefault(),t.stopPropagation(),n;o=o.parentNode}},!0)}(e,t,i),function(e,t,n){function a(t,i,n){var a=n.type;n.type=i,e.event.dispatch.call(t,n),n.type=a}var o=e(i);e.each("touchstart touchmove touchend tap taphold swipe swipeleft swiperight scrollstart scrollstop".split(" "),function(t,i){e.fn[i]=function(e){return e?this.bind(i,e):this.trigger(i)},e.attrFn&&(e.attrFn[i]=!0)});var s=e.mobile.support.touch,r="touchmove scroll",l=s?"touchstart":"mousedown",d=s?"touchend":"mouseup",c=s?"touchmove":"mousemove";e.event.special.scrollstart={enabled:!0,setup:function(){function t(e,t){i=t,a(o,i?"scrollstart":"scrollstop",e)}var i,n,o=this,s=e(o);s.bind(r,function(a){e.event.special.scrollstart.enabled&&(i||t(a,!0),clearTimeout(n),n=setTimeout(function(){t(a,!1)},50))})}},e.event.special.tap={tapholdThresho
ld:750,setup:function(){var t=this,i=e(t);i.bind("vmousedown",function(n){function s(){clearTimeout(d)}function r(){s(),i.unbind("vclick",l).unbind("vmouseup",s),o.unbind("vmousecancel",r)}function l(e){r(),c===e.target&&a(t,"tap",e)}if(n.which&&1!==n.which)return!1;var d,c=n.target;n.originalEvent,i.bind("vmouseup",s).bind("vclick",l),o.bind("vmousecancel",r),d=setTimeout(function(){a(t,"taphold",e.Event("taphold",{target:c}))
+},e.event.special.tap.tapholdThreshold)})}},e.event.special.swipe={scrollSupressionThreshold:30,durationThreshold:1e3,horizontalDistanceThreshold:30,verticalDistanceThreshold:75,start:function(t){var i=t.originalEvent.touches?t.originalEvent.touches[0]:t;return{time:(new Date).getTime(),coords:[i.pageX,i.pageY],origin:e(t.target)}},stop:function(e){var t=e.originalEvent.touches?e.originalEvent.touches[0]:e;return{time:(new Date).getTime(),coords:[t.pageX,t.pageY]}},handleSwipe:function(t,i){i.time-t.time<e.event.special.swipe.durationThreshold&&Math.abs(t.coords[0]-i.coords[0])>e.event.special.swipe.horizontalDistanceThreshold&&Math.abs(t.coords[1]-i.coords[1])<e.event.special.swipe.verticalDistanceThreshold&&t.origin.trigger("swipe").trigger(t.coords[0]>i.coords[0]?"swipeleft":"swiperight")},setup:function(){var t=this,i=e(t);i.bind(l,function(t){function a(t){s&&(o=e.event.special.swipe.stop(t),Math.abs(s.coords[0]-o.coords[0])>e.event.special.swipe.scrollSupressionThresho
ld&&t.preventDefault())}var o,s=e.event.special.swipe.start(t);i.bind(c,a).one(d,function(){i.unbind(c,a),s&&o&&e.event.special.swipe.handleSwipe(s,o),s=o=n})})}},e.each({scrollstop:"scrollstart",taphold:"tap",swipeleft:"swipe",swiperight:"swipe"},function(t,i){e.event.special[t]={setup:function(){e(this).bind(i,e.noop)}}})}(e,this),function(e){e.event.special.throttledresize={setup:function(){e(this).bind("resize",o)},teardown:function(){e(this).unbind("resize",o)}};var t,i,n,a=250,o=function(){i=(new Date).getTime(),n=i-s,n>=a?(s=i,e(this).trigger("throttledresize")):(t&&clearTimeout(t),t=setTimeout(o,a-n))},s=0}(e),function(e,t){function a(){var e=o();e!==s&&(s=e,d.trigger(c))}var o,s,r,l,d=e(t),c="orientationchange",h={0:!0,180:!0};if(e.support.orientation){var u=t.innerWidth||d.width(),p=t.innerHeight||d.height(),m=50;r=u>p&&u-p>m,l=h[t.orientation],(r&&l||!r&&!l)&&(h={"-90":!0,90:!0})}e.event.special.orientationchange=e.extend({},e.event.special.orientationchange,{setu
p:function(){return e.support.orientation&&!e.event.special.orientationchange.disabled?!1:(s=o(),d.bind("throttledresize",a),n)},teardown:function(){return e.support.orientation&&!e.event.special.orientationchange.disabled?!1:(d.unbind("throttledresize",a),n)},add:function(e){var t=e.handler;e.handler=function(e){return e.orientation=o(),t.apply(this,arguments)}}}),e.event.special.orientationchange.orientation=o=function(){var n=!0,a=i.documentElement;return n=e.support.orientation?h[t.orientation]:a&&1.1>a.clientWidth/a.clientHeight,n?"portrait":"landscape"},e.fn[c]=function(e){return e?this.bind(c,e):this.trigger(c)},e.attrFn&&(e.attrFn[c]=!0)}(e,this),function(e){e.widget("mobile.page",e.mobile.widget,{options:{theme:"c",domCache:!1,keepNativeDefault:":jqmData(role='none'), :jqmData(role='nojs')"},_create:function(){return this._trigger("beforecreate")===!1?!1:(this.element.attr("tabindex","0").addClass("ui-page ui-body-"+this.options.theme),this._on(this.element,{pagebef
orehide:"removeContainerBackground",pagebeforeshow:"_handlePageBeforeShow"}),n)},_handlePageBeforeShow:function(){this.setContainerBackground()},removeContainerBackground:function(){e.mobile.pageContainer.removeClass("ui-overlay-"+e.mobile.getInheritedTheme(this.element.parent()))},setContainerBackground:function(t){this.options.theme&&e.mobile.pageContainer.addClass("ui-overlay-"+(t||this.options.theme))},keepNativeSelector:function(){var t=this.options,i=t.keepNative&&e.trim(t.keepNative);return i&&t.keepNative!==t.keepNativeDefault?[t.keepNative,t.keepNativeDefault].join(", "):t.keepNativeDefault}})}(e),function(e,t,i){var n=function(n){return n===i&&(n=!0),function(i,a,o,s){var r=new e.Deferred,l=a?" reverse":"",d=e.mobile.urlHistory.getActive(),c=d.lastScroll||e.mobile.defaultHomeScroll,h=e.mobile.getScreenHeight(),u=e.mobile.maxTransitionWidth!==!1&&e.mobile.window.width()>e.mobile.maxTransitionWidth,p=!e.support.cssTransitions||u||!i||"none"===i||Math.max(e.mobile.win
dow.scrollTop(),c)>e.mobile.getMaxScrollForTransition(),m=" ui-page-pre-in",f=function(){e.mobile.pageContainer.toggleClass("ui-mobile-viewport-transitioning viewport-"+i)},g=function(){e.event.special.scrollstart.enabled=!1,t.scrollTo(0,c),setTimeout(function(){e.event.special.scrollstart.enabled=!0},150)},b=function(){s.removeClass(e.mobile.activePageClass+" out in reverse "+i).height("")},v=function(){n?s.animationComplete(_):_(),s.height(h+e.mobile.window.scrollTop()).addClass(i+" out"+l)},_=function(){s&&n&&b(),C()},C=function(){o.css("z-index",-10),o.addClass(e.mobile.activePageClass+m),e.mobile.focusPage(o),o.height(h+c),g(),o.css("z-index",""),p||o.animationComplete(x),o.removeClass(m).addClass(i+" in"+l),p&&x()},x=function(){n||s&&b(),o.removeClass("out in reverse "+i).height(""),f(),e.mobile.window.scrollTop()!==c&&g(),r.resolve(i,a,o,s,!0)};return f(),s&&!p?v():_(),r.promise()}},a=n(),o=n(!1),s=function(){return 3*e.mobile.getScreenHeight()};e.mobile.defaultTransi
tionHandler=a,e.mobile.transitionHandlers={"default":e.mobile.defaultTransitionHandler,sequential:a,simultaneous:o},e.mobile.transitionFallbacks={},e.mobile._maybeDegradeTransition=function(t){return t&&!e.support.cssTransform3d&&e.mobile.transitionFallbacks[t]&&(t=e.mobile.transitionFallbacks[t]),t},e.mobile.getMaxScrollForTransition=e.mobile.getMaxScrollForTransition||s}(e,this),function(e,n){function a(t){!f||f.closest("."+e.mobile.activePageClass).length&&!t||f.removeClass(e.mobile.activeBtnClass),f=null}function o(){_=!1,v.length>0&&e.mobile.changePage.apply(null,v.pop())}function s(t,i,n,a){i&&i.data("mobile-page")._trigger("beforehide",null,{nextPage:t}),t.data("mobile-page")._trigger("beforeshow",null,{prevPage:i||e("")}),e.mobile.hidePageLoadingMsg(),n=e.mobile._maybeDegradeTransition(n);var o=e.mobile.transitionHandlers[n||"default"]||e.mobile.defaultTransitionHandler,s=o(n,a,t,i);return s.done(function(){i&&i.data("mobile-page")._trigger("hide",null,{nextPage:t}),
t.data("mobile-page")._trigger("show",null,{prevPage:i||e("")})}),s}function r(t,i){i&&t.attr("data-"+e.mobile.ns+"role",i),t.page()}function l(){var t=e.mobile.activePage&&c(e.mobile.activePage);return t||w.hrefNoHash}function d(e){for(;e&&("string"!=typeof e.nodeName||"a"!==e.nodeName.toLowerCase());)e=e.parentNode;return e}function c(t){var i=e(t).closest(".ui-page").jqmData("url"),n=w.hrefNoHash;return i&&p.isPath(i)||(i=n),p.makeUrlAbsolute(i,n)}var h=e.mobile.window,u=(e("html"),e("head")),p=e.extend(e.mobile.path,{getFilePath:function(t){var i="&"+e.mobile.subPageUrlKey;return t&&t.split(i)[0].split(C)[0]},isFirstPageUrl:function(t){var i=p.parseUrl(p.makeUrlAbsolute(t,this.documentBase)),a=i.hrefNoHash===this.documentUrl.hrefNoHash||this.documentBaseDiffers&&i.hrefNoHash===this.documentBase.hrefNoHash,o=e.mobile.firstPage,s=o&&o[0]?o[0].id:n;return a&&(!i.hash||"#"===i.hash||s&&i.hash.replace(/^#/,"")===s)},isPermittedCrossDomainRequest:function(t,i){return e.mobile.
allowCrossDomainPages&&"file:"===t.protocol&&-1!==i.search(/^https?:/)}}),m=null,f=null,g=e.Deferred(),b=e.mobile.navigate.history,v=[],_=!1,C="&ui-state=dialog",x=u.children("base"),y=p.documentUrl,w=p.documentBase,T=(p.documentBaseDiffers,e.mobile.getScreenHeight),D=e.support.dynamicBaseTag?{element:x.length?x:e("<base>",{href:w.hrefNoHash}).prependTo(u),set:function(e){e=p.parseUrl(e).hrefNoHash,D.element.attr("href",p.makeUrlAbsolute(e,w))},reset:function(){D.element.attr("href",w.hrefNoSearch)}}:n;e.mobile.getDocumentUrl=p.getDocumentUrl,e.mobile.getDocumentBase=p.getDocumentBase,e.mobile.back=function(){var e=t.navigator;this.phonegapNavigationEnabled&&e&&e.app&&e.app.backHistory?e.app.backHistory():t.history.back()},e.mobile.focusPage=function(e){var t=e.find("[autofocus]"),i=e.find(".ui-title:eq(0)");return t.length?(t.focus(),n):(i.length?i.focus():e.focus(),n)};var P,k,E=!0;P=function(){if(E){var t=e.mobile.urlHistory.getActive();if(t){var i=h.scrollTop();t.lastScr
oll=e.mobile.minScrollBack>i?e.mobile.defaultHomeScroll:i}}},k=function(){setTimeout(P,100)},h.bind(e.support.pushState?"popstate":"hashchange",function(){E=!1}),h.one(e.support.pushState?"popstate":"hashchange",function(){E=!0}),h.one("pagecontainercreate",function(){e.mobile.pageContainer.bind("pagechange",function(){E=!0,h.unbind("scrollstop",k),h.bind("scrollstop",k)})}),h.bind("scrollstop",k),e.mobile._maybeDegradeTransition=e.mobile._maybeDegradeTransition||function(e){return e},e.mobile.resetActivePageHeight=function(t){var i=e("."+e.mobile.activePageClass),n=parseFloat(i.css("padding-top")),a=parseFloat(i.css("padding-bottom")),o=parseFloat(i.css("border-top-width")),s=parseFloat(i.css("border-bottom-width"));t="number"==typeof t?t:T(),i.css("min-height",t-n-a-o-s)},e.fn.animationComplete=function(t){return e.support.cssTransitions?e(this).one("webkitAnimationEnd animationend",t):(setTimeout(t,0),e(this))},e.mobile.path=p,e.mobile.base=D,e.mobile.urlHistory=b,e.mobil
e.dialogHashKey=C,e.mobile.allowCrossDomainPages=!1,e.mobile._bindPageRemove=function(){var t=e(this);!t.data("mobile-page").options.domCache&&t.is(":jqmData(external-page='true')")&&t.bind("pagehide.remove",function(){var t=e(this),i=new e.Event("pageremove");t.trigger(i),i.isDefaultPrevented()||t.removeWithDependents()})},e.mobile.loadPage=function(t,i){var a=e.Deferred(),o=e.extend({},e.mobile.loadPage.defaults,i),s=null,d=null,c=p.makeUrlAbsolute(t,l());o.data&&"get"===o.type&&(c=p.addSearchParams(c,o.data),o.data=n),o.data&&"post"===o.type&&(o.reloadPage=!0);var h=p.getFilePath(c),u=p.convertUrlToDataUrl(c);if(o.pageContainer=o.pageContainer||e.mobile.pageContainer,s=o.pageContainer.children("[data-"+e.mobile.ns+"url='"+u+"']"),0===s.length&&u&&!p.isPath(u)&&(s=o.pageContainer.children("#"+u).attr("data-"+e.mobile.ns+"url",u).jqmData("url",u)),0===s.length)if(e.mobile.firstPage&&p.isFirstPageUrl(h))e.mobile.firstPage.parent().length&&(s=e(e.mobile.firstPage));else if(p.
isEmbeddedPage(h))return a.reject(c,i),a.promise();if(s.length){if(!o.reloadPage)return r(s,o.role),a.resolve(c,i,s),D&&!i.prefetch&&D.set(t),a.promise();d=s}var m=o.pageContainer,f=new e.Event("pagebeforeload"),g={url:t,absUrl:c,dataUrl:u,deferred:a,options:o};if(m.trigger(f,g),f.isDefaultPrevented())return a.promise();if(o.showLoadMsg)var b=setTimeout(function(){e.mobile.showPageLoadingMsg()},o.loadMsgDelay),v=function(){clearTimeout(b),e.mobile.hidePageLoadingMsg()};return D&&i.prefetch===n&&D.reset(),e.mobile.allowCrossDomainPages||p.isSameDomain(y,c)?e.ajax({url:h,type:o.type,data:o.data,contentType:o.contentType,dataType:"html",success:function(l,m,f){var b=e("<div></div>"),_=l.match(/<title[^>]*>([^<]*)/)&&RegExp.$1,C=RegExp("(<[^>]+\\bdata-"+e.mobile.ns+"role=[\"']?page[\"']?[^>]*>)"),x=RegExp("\\bdata-"+e.mobile.ns+"url=[\"']?([^\"'>]*)[\"']?");if(C.test(l)&&RegExp.$1&&x.test(RegExp.$1)&&RegExp.$1&&(t=h=p.getFilePath(e("<div>"+RegExp.$1+"</div>").text())),D&&i.prefe
tch===n&&D.set(h),b.get(0).innerHTML=l,s=b.find(":jqmData(role='page'), :jqmData(role='dialog')").first(),s.length||(s=e("<div data-"+e.mobile.ns+"role='page'>"+(l.split(/<\/?body[^>]*>/gim)[1]||"")+"</div>")),_&&!s.jqmData("title")&&(~_.indexOf("&")&&(_=e("<div>"+_+"</div>").text()),s.jqmData("title",_)),!e.support.dynamicBaseTag){var y=p.get(h);s.find("[src], link[href], a[rel='external'], :jqmData(ajax='false'), a[target]").each(function(){var t=e(this).is("[href]")?"href":e(this).is("[src]")?"src":"action",i=e(this).attr(t);i=i.replace(location.protocol+"//"+location.host+location.pathname,""),/^(\w+:|#|\/)/.test(i)||e(this).attr(t,y+i)})}s.attr("data-"+e.mobile.ns+"url",p.convertUrlToDataUrl(h)).attr("data-"+e.mobile.ns+"external-page",!0).appendTo(o.pageContainer),s.one("pagecreate",e.mobile._bindPageRemove),r(s,o.role),c.indexOf("&"+e.mobile.subPageUrlKey)>-1&&(s=o.pageContainer.children("[data-"+e.mobile.ns+"url='"+u+"']")),o.showLoadMsg&&v(),g.xhr=f,g.textStatus=m,g
.page=s,o.pageContainer.trigger("pageload",g),a.resolve(c,i,s,d)},error:function(t,n,s){D&&D.set(p.get()),g.xhr=t,g.textStatus=n,g.errorThrown=s;var r=new e.Event("pageloadfailed");o.pageContainer.trigger(r,g),r.isDefaultPrevented()||(o.showLoadMsg&&(v(),e.mobile.showPageLoadingMsg(e.mobile.pageLoadErrorMessageTheme,e.mobile.pageLoadErrorMessage,!0),setTimeout(e.mobile.hidePageLoadingMsg,1500)),a.reject(c,i))}}):a.reject(c,i),a.promise()},e.mobile.loadPage.defaults={type:"get",data:n,reloadPage:!1,role:n,showLoadMsg:!1,pageContainer:n,loadMsgDelay:50},e.mobile.changePage=function(t,d){if(_)return v.unshift(arguments),n;var c,h=e.extend({},e.mobile.changePage.defaults,d);h.pageContainer=h.pageContainer||e.mobile.pageContainer,h.fromPage=h.fromPage||e.mobile.activePage,c="string"==typeof t;var u=h.pageContainer,m=new e.Event("pagebeforechange"),f={toPage:t,options:h};if(f.absUrl=c?p.makeUrlAbsolute(t,l()):t.data("absUrl"),u.trigger(m,f),!m.isDefaultPrevented()){if(t=f.toPage,c
="string"==typeof t,_=!0,c)return h.target=t,e.mobile.loadPage(t,h).done(function(t,i,n,a){_=!1,i.duplicateCachedPage=a,n.data("absUrl",f.absUrl),e.mobile.changePage(n,i)}).fail(function(){a(!0),o(),h.pageContainer.trigger("pagechangefailed",f)}),n;t[0]!==e.mobile.firstPage[0]||h.dataUrl||(h.dataUrl=y.hrefNoHash);var g=h.fromPage,x=h.dataUrl&&p.convertUrlToDataUrl(h.dataUrl)||t.jqmData("url"),w=x,T=(p.getFilePath(x),b.getActive()),D=0===b.activeIndex,P=0,k=i.title,E="dialog"===h.role||"dialog"===t.jqmData("role");if(g&&g[0]===t[0]&&!h.allowSamePageTransition)return _=!1,u.trigger("pagechange",f),h.fromHashChange&&b.direct({url:x}),n;r(t,h.role),h.fromHashChange&&(P="back"===d.direction?-1:1);try{i.activeElement&&"body"!==i.activeElement.nodeName.toLowerCase()?e(i.activeElement).blur():e("input:focus, textarea:focus, select:focus").blur()}catch(q){}var j=!1;E&&T&&(T.url&&T.url.indexOf(C)>-1&&e.mobile.activePage&&!e.mobile.activePage.is(".ui-dialog")&&b.activeIndex>0&&(h.chang
eHash=!1,j=!0),x=T.url||"",x+=!j&&x.indexOf("#")>-1?C:"#"+C,0===b.activeIndex&&x===b.initialDst&&(x+=C));var S=T?t.jqmData("title")||t.children(":jqmData(role='header')").find(".ui-title").text():k;if(S&&k===i.title&&(k=S),t.jqmData("title")||t.jqmData("title",k),h.transition=h.transition||(P&&!D?T.transition:n)||(E?e.mobile.defaultDialogTransition:e.mobile.defaultPageTransition),!P&&j&&(b.getActive().pageUrl=w),x&&!h.fromHashChange){var A;!p.isPath(x)&&0>x.indexOf("#")&&(x="#"+x),A={transition:h.transition,title:k,pageUrl:w,role:h.role},h.changeHash!==!1&&e.mobile.hashListeningEnabled?e.mobile.navigate(x,A,!0):t[0]!==e.mobile.firstPage[0]&&e.mobile.navigate.history.add(x,A)}i.title=k,e.mobile.activePage=t,h.reverse=h.reverse||0>P,s(t,g,h.transition,h.reverse).done(function(i,n,s,r,l){a(),h.duplicateCachedPage&&h.duplicateCachedPage.remove(),l||e.mobile.focusPage(t),o(),u.trigger("pagechange",f)})}},e.mobile.changePage.defaults={transition:n,reverse:!1,changeHash:!0,fromHash
Change:!1,role:n,duplicateCachedPage:n,pageContainer:n,showLoadMsg:!0,dataUrl:n,fromPage:n,allowSamePageTransition:!1},e.mobile.navreadyDeferred=e.Deferred(),e.mobile._registerInternalEvents=function(){var i=function(t,i){var a,o,s,r,l=!0;return!e.mobile.ajaxEnabled||t.is(":jqmData(ajax='false')")||!t.jqmHijackable().length||t.attr("target")?!1:(a=t.attr("action"),r=(t.attr("method")||"get").toLowerCase(),a||(a=c(t),"get"===r&&(a=p.parseUrl(a).hrefNoSearch),a===w.hrefNoHash&&(a=y.hrefNoSearch)),a=p.makeUrlAbsolute(a,c(t)),p.isExternal(a)&&!p.isPermittedCrossDomainRequest(y,a)?!1:(i||(o=t.serializeArray(),m&&m[0].form===t[0]&&(s=m.attr("name"),s&&(e.each(o,function(e,t){return t.name===s?(s="",!1):n}),s&&o.push({name:s,value:m.attr("value")}))),l={url:a,options:{type:r,data:e.param(o),transition:t.jqmData("transition"),reverse:"reverse"===t.jqmData("direction"),reloadPage:!0}}),l))};e.mobile.document.delegate("form","submit",function(t){var n=i(e(this));n&&(e.mobile.changePag
e(n.url,n.options),t.preventDefault())}),e.mobile.document.bind("vclick",function(t){var n,o,s=t.target,r=!1;if(!(t.which>1)&&e.mobile.linkBindingEnabled){if(m=e(s),e.data(s,"mobile-button")){if(!i(e(s).closest("form"),!0))return;s.parentNode&&(s=s.parentNode)}else{if(s=d(s),!s||"#"===p.parseUrl(s.getAttribute("href")||"#").hash)return;if(!e(s).jqmHijackable().length)return}~s.className.indexOf("ui-link-inherit")?s.parentNode&&(o=e.data(s.parentNode,"buttonElements")):o=e.data(s,"buttonElements"),o?s=o.outer:r=!0,n=e(s),r&&(n=n.closest(".ui-btn")),n.length>0&&!n.hasClass("ui-disabled")&&(a(!0),f=n,f.addClass(e.mobile.activeBtnClass))}}),e.mobile.document.bind("click",function(i){if(e.mobile.linkBindingEnabled&&!i.isDefaultPrevented()){var o,s=d(i.target),r=e(s);if(s&&!(i.which>1)&&r.jqmHijackable().length){if(o=function(){t.setTimeout(function(){a(!0)},200)},r.is(":jqmData(rel='back')"))return e.mobile.back(),!1;var l=c(r),h=p.makeUrlAbsolute(r.attr("href")||"#",l);if(!e.mob
ile.ajaxEnabled&&!p.isEmbeddedPage(h))return o(),n;if(-1!==h.search("#")){if(h=h.replace(/[^#]*#/,""),!h)return i.preventDefault(),n;h=p.isPath(h)?p.makeUrlAbsolute(h,l):p.makeUrlAbsolute("#"+h,y.hrefNoHash)}var u=r.is("[rel='external']")||r.is(":jqmData(ajax='false')")||r.is("[target]"),m=u||p.isExternal(h)&&!p.isPermittedCrossDomainRequest(y,h);if(m)return o(),n;var f=r.jqmData("transition"),g="reverse"===r.jqmData("direction")||r.jqmData("back"),b=r.attr("data-"+e.mobile.ns+"rel")||n;e.mobile.changePage(h,{transition:f,reverse:g,role:b,link:r}),i.preventDefault()}}}),e.mobile.document.delegate(".ui-page","pageshow.prefetch",function(){var t=[];e(this).find("a:jqmData(prefetch)").each(function(){var i=e(this),n=i.attr("href");n&&-1===e.inArray(n,t)&&(t.push(n),e.mobile.loadPage(n,{role:i.attr("data-"+e.mobile.ns+"rel"),prefetch:!0}))})}),e.mobile._handleHashChange=function(i,a){var o=p.stripHash(i),s=0===e.mobile.urlHistory.stack.length?"none":n,r={changeHash:!1,fromHashCh
ange:!0,reverse:"back"===a.direction};if(e.extend(r,a,{transition:(b.getLast()||{}).transition||s}),b.activeIndex>0&&o.indexOf(C)>-1&&b.initialDst!==o){if(e.mobile.activePage&&!e.mobile.activePage.is(".ui-dialog"))return"back"===a.direction?e.mobile.back():t.history.forward(),n;o=a.pageUrl;var l=e.mobile.urlHistory.getActive();e.extend(r,{role:l.role,transition:l.transition,reverse:"back"===a.direction})}o?(o=p.isPath(o)?o:p.makeUrlAbsolute("#"+o,w),o===p.makeUrlAbsolute("#"+b.initialDst,w)&&b.stack.length&&b.stack[0].url!==b.initialDst.replace(C,"")&&(o=e.mobile.firstPage),e.mobile.changePage(o,r)):e.mobile.changePage(e.mobile.firstPage,r)},h.bind("navigate",function(t,i){var n;t.originalEvent&&t.originalEvent.isDefaultPrevented()||(n=e.event.special.navigate.originalEventName.indexOf("hashchange")>-1?i.state.hash:i.state.url,n||(n=e.mobile.path.parseLocation().hash),n&&"#"!==n&&0!==n.indexOf("#"+e.mobile.path.uiStateKey)||(n=location.href),e.mobile._handleHashChange(n,i.st
ate))}),e.mobile.document.bind("pageshow",e.mobile.resetActivePageHeight),e.mobile.window.bind("throttledresize",e.mobile.resetActivePageHeight)},e(function(){g.resolve()}),e.when(g,e.mobile.navreadyDeferred).done(function(){e.mobile._registerInternalEvents()})}(e),function(e){e.mobile.transitionFallbacks.flip="fade"}(e,this),function(e){e.mobile.transitionFallbacks.flow="fade"}(e,this),function(e){e.mobile.transitionFallbacks.pop="fade"}(e,this),function(e){e.mobile.transitionHandlers.slide=e.mobile.transitionHandlers.simultaneous,e.mobile.transitionFallbacks.slide="fade"}(e,this),function(e){e.mobile.transitionFallbacks.slidedown="fade"}(e,this),function(e){e.mobile.transitionFallbacks.slidefade="fade"}(e,this),function(e){e.mobile.transitionFallbacks.slideup="fade"}(e,this),function(e){e.mobile.transitionFallbacks.turn="fade"}(e,this),function(e){e.mobile.page.prototype.options.degradeInputs={color:!1,date:!1,datetime:!1,"datetime-local":!1,email:!1,month:!1,number:!1,ran
ge:"number",search:"text",tel:!1,time:!1,url:!1,week:!1},e.mobile.document.bind("pagecreate create",function(t){var i,n=e.mobile.closestPageData(e(t.target));n&&(i=n.options,e(t.target).find("input").not(n.keepNativeSelector()).each(function(){var t=e(this),n=this.getAttribute("type"),a=i.degradeInputs[n]||"text";if(i.degradeInputs[n]){var o=e("<div>").html(t.clone()).html(),s=o.indexOf(" type=")>-1,r=s?/\s+type=["']?\w+['"]?/:/\/?>/,l=' type="'+a+'" data-'+e.mobile.ns+'type="'+n+'"'+(s?"":">");t.replaceWith(o.replace(r,l))}}))})}(e),function(e){e.widget("mobile.dialog",e.mobile.widget,{options:{closeBtn:"left",closeBtnText:"Close",overlayTheme:"a",corners:!0,initSelector:":jqmData(role='dialog')"},_handlePageBeforeShow:function(){this._isCloseable=!0,this.options.overlayTheme&&this.element.page("removeContainerBackground").page("setContainerBackground",this.options.overlayTheme)},_create:function(){var t=this.element,i=this.options.corners?" ui-corner-all":"",n=e("<div/>",{
role:"dialog","class":"ui-dialog-contain ui-overlay-shadow"+i});t.addClass("ui-dialog ui-overlay-"+this.options.overlayTheme),t.wrapInner(n),t.bind("vclick submit",function(t){var i,n=e(t.target).closest("vclick"===t.type?"a":"form");n.length&&!n.jqmData("transition")&&(i=e.mobile.urlHistory.getActive()||{},n.attr("data-"+e.mobile.ns+"transition",i.transition||e.mobile.defaultDialogTransition).attr("data-"+e.mobile.ns+"direction","reverse"))}),this._on(t,{pagebeforeshow:"_handlePageBeforeShow"}),e.extend(this,{_createComplete:!1}),this._setCloseBtn(this.options.closeBtn)},_setCloseBtn:function(t){var i,n,a=this;this._headerCloseButton&&(this._headerCloseButton.remove(),this._headerCloseButton=null),"none"!==t&&(n="left"===t?"left":"right",i=e("<a href='#' class='ui-btn-"+n+"' data-"+e.mobile.ns+"icon='delete' data-"+e.mobile.ns+"iconpos='notext'>"+this.options.closeBtnText+"</a>"),this.element.children().find(":jqmData(role='header')").first().prepend(i),this._createComplete
&&e.fn.buttonMarkup&&i.buttonMarkup(),this._createComplete=!0,i.bind("click",function(){a.close()}),this._headerCloseButton=i)},_setOption:function(e,t){"closeBtn"===e&&this._setCloseBtn(t),this._super(e,t)},close:function(){var t,i,n=e.mobile.navigate.history;this._isCloseable&&(this._isCloseable=!1,e.mobile.hashListeningEnabled&&n.activeIndex>0?e.mobile.back():(t=Math.max(0,n.activeIndex-1),i=n.stack[t].pageUrl||n.stack[t].url,n.previousIndex=n.activeIndex,n.activeIndex=t,e.mobile.path.isPath(i)||(i=e.mobile.path.makeUrlAbsolute("#"+i)),e.mobile.changePage(i,{direction:"back",changeHash:!1,fromHashChange:!0})))}}),e.mobile.document.delegate(e.mobile.dialog.prototype.options.initSelector,"pagecreate",function(){e.mobile.dialog.prototype.enhance(this)})}(e,this),function(e){e.mobile.page.prototype.options.backBtnText="Back",e.mobile.page.prototype.options.addBackBtn=!1,e.mobile.page.prototype.options.backBtnTheme=null,e.mobile.page.prototype.options.headerTheme="a",e.mobile.
page.prototype.options.footerTheme="a",e.mobile.page.prototype.options.contentTheme=null,e.mobile.document.bind("pagecreate",function(t){var i=e(t.target),n=i.data("mobile-page").options,a=i.jqmData("role"),o=n.theme;e(":jqmData(role='header'), :jqmData(role='footer'), :jqmData(role='content')",i).jqmEnhanceable().each(function(){var t,s,r,l,d=e(this),c=d.jqmData("role"),h=d.jqmData("theme"),u=h||n.contentTheme||"dialog"===a&&o;if(d.addClass("ui-"+c),"header"===c||"footer"===c){var p=h||("header"===c?n.headerTheme:n.footerTheme)||o;d.addClass("ui-bar-"+p).attr("role","header"===c?"banner":"contentinfo"),"header"===c&&(t=d.children("a, button"),s=t.hasClass("ui-btn-left"),r=t.hasClass("ui-btn-right"),s=s||t.eq(0).not(".ui-btn-right").addClass("ui-btn-left").length,r=r||t.eq(1).addClass("ui-btn-right").length),n.addBackBtn&&"header"===c&&e(".ui-page").length>1&&i.jqmData("url")!==e.mobile.path.stripHash(location.hash)&&!s&&(l=e("<a href='javascript:void(0);' class='ui-btn-left
' data-"+e.mobile.ns+"rel='back' data-"+e.mobile.ns+"icon='arrow-l'>"+n.backBtnText+"</a>").attr("data-"+e.mobile.ns+"theme",n.backBtnTheme||p).prependTo(d)),d.children("h1, h2, h3, h4, h5, h6").addClass("ui-title").attr({role:"heading","aria-level":"1"})}else"content"===c&&(u&&d.addClass("ui-body-"+u),d.attr("role","main"))})})}(e),function(e,t){function n(e){for(var t;e&&(t="string"==typeof e.className&&e.className+" ",!(t&&t.indexOf("ui-btn ")>-1&&0>t.indexOf("ui-disabled ")));)e=e.parentNode;return e}function a(n,a,o,s,r){var l=e.data(n[0],"buttonElements");n.removeClass(a).addClass(o),l&&(l.bcls=e(i.createElement("div")).addClass(l.bcls+" "+o).removeClass(a).attr("class"),s!==t&&(l.hover=s),l.state=r)}var o=function(e,i){var n=e.getAttribute(i);return"true"===n?!0:"false"===n?!1:null===n?t:n};e.fn.buttonMarkup=function(n){var a,r=this,l="data-"+e.mobile.ns;n=n&&"object"===e.type(n)?n:{};for(var d=0;r.length>d;d++){var c,h,u,p,m,f,g=r.eq(d),b=g[0],v=e.extend({},e.fn.butt
onMarkup.defaults,{icon:n.icon!==t?n.icon:o(b,l+"icon"),iconpos:n.iconpos!==t?n.iconpos:o(b,l+"iconpos"),theme:n.theme!==t?n.theme:o(b,l+"theme")||e.mobile.getInheritedTheme(g,"c"),inline:n.inline!==t?n.inline:o(b,l+"inline"),shadow:n.shadow!==t?n.shadow:o(b,l+"shadow"),corners:n.corners!==t?n.corners:o(b,l+"corners"),iconshadow:n.iconshadow!==t?n.iconshadow:o(b,l+"iconshadow"),mini:n.mini!==t?n.mini:o(b,l+"mini")},n),_="ui-btn-inner",C="ui-btn-text",x=!1,y="up";for(a in v)v[a]===t||null===v[a]?g.removeAttr(l+a):b.setAttribute(l+a,v[a]);for("popup"===o(b,l+"rel")&&g.attr("href")&&(b.setAttribute("aria-haspopup",!0),b.setAttribute("aria-owns",g.attr("href"))),f=e.data("INPUT"===b.tagName||"BUTTON"===b.tagName?b.parentNode:b,"buttonElements"),f?(b=f.outer,g=e(b),u=f.inner,p=f.text,e(f.icon).remove(),f.icon=null,x=f.hover,y=f.state):(u=i.createElement(v.wrapperEls),p=i.createElement(v.wrapperEls)),m=v.icon?i.createElement("span"):null,s&&!f&&s(),v.theme||(v.theme=e.mobile.getIn
heritedTheme(g,"c")),c="ui-btn ",c+=x?"ui-btn-hover-"+v.theme:"",c+=y?" ui-btn-"+y+"-"+v.theme:"",c+=v.shadow?" ui-shadow":"",c+=v.corners?" ui-btn-corner-all":"",v.mini!==t&&(c+=v.mini===!0?" ui-mini":" ui-fullsize"),v.inline!==t&&(c+=v.inline===!0?" ui-btn-inline":" ui-btn-block"),v.icon&&(v.icon="ui-icon-"+v.icon,v.iconpos=v.iconpos||"left",h="ui-icon "+v.icon,v.iconshadow&&(h+=" ui-icon-shadow")),v.iconpos&&(c+=" ui-btn-icon-"+v.iconpos,"notext"!==v.iconpos||g.attr("title")||g.attr("title",g.getEncodedText())),f&&g.removeClass(f.bcls||""),g.removeClass("ui-link").addClass(c),u.className=_,p.className=C,f||u.appendChild(p),m&&(m.className=h,f&&f.icon||(m.innerHTML=" ",u.appendChild(m)));b.firstChild&&!f;)p.appendChild(b.firstChild);f||b.appendChild(u),f={hover:x,state:y,bcls:c,outer:b,inner:u,text:p,icon:m},e.data(b,"buttonElements",f),e.data(u,"buttonElements",f),e.data(p,"buttonElements",f),m&&e.data(m,"buttonElements",f)}return this},e.fn.buttonMarkup.defaults={co
rners:!0,shadow:!0,iconshadow:!0,wrapperEls:"span"};var s=function(){var i,o,r=e.mobile.buttonMarkup.hoverDelay;e.mobile.document.bind({"vmousedown vmousecancel vmouseup vmouseover vmouseout focus blur scrollstart":function(s){var l,d=e(n(s.target)),c=s.originalEvent&&/^touch/.test(s.originalEvent.type),h=s.type;d.length&&(l=d.attr("data-"+e.mobile.ns+"theme"),"vmousedown"===h?c?i=setTimeout(function(){a(d,"ui-btn-up-"+l,"ui-btn-down-"+l,t,"down")},r):a(d,"ui-btn-up-"+l,"ui-btn-down-"+l,t,"down"):"vmousecancel"===h||"vmouseup"===h?a(d,"ui-btn-down-"+l,"ui-btn-up-"+l,t,"up"):"vmouseover"===h||"focus"===h?c?o=setTimeout(function(){a(d,"ui-btn-up-"+l,"ui-btn-hover-"+l,!0,"")},r):a(d,"ui-btn-up-"+l,"ui-btn-hover-"+l,!0,""):("vmouseout"===h||"blur"===h||"scrollstart"===h)&&(a(d,"ui-btn-hover-"+l+" ui-btn-down-"+l,"ui-btn-up-"+l,!1,"up"),i&&clearTimeout(i),o&&clearTimeout(o)))},"focusin focus":function(t){e(n(t.target)).addClass(e.mobile.focusClass)},"focusout blur":function(t){e(
n(t.target)).removeClass(e.mobile.focusClass)}}),s=null};e.mobile.document.bind("pagecreate create",function(t){e(":jqmData(role='button'), .ui-bar > a, .ui-header > a, .ui-footer > a, .ui-bar > :jqmData(role='controlgroup') > a",t.target).jqmEnhanceable().not("button, input, .ui-btn, :jqmData(role='none'), :jqmData(role='nojs')").buttonMarkup()})}(e),function(e,t){e.widget("mobile.collapsible",e.mobile.widget,{options:{expandCueText:" click to expand contents",collapseCueText:" click to collapse contents",collapsed:!0,heading:"h1,h2,h3,h4,h5,h6,legend",collapsedIcon:"plus",expandedIcon:"minus",iconpos:"left",theme:null,contentTheme:null,inset:!0,corners:!0,mini:!1,initSelector:":jqmData(role='collapsible')"},_create:function(){var i=this.element,n=this.options,a=i.addClass("ui-collapsible"),o=i.children(n.heading).first(),s=a.wrapInner("<div class='ui-collapsible-content'></div>").children(".ui-collapsible-content"),r=i.closest(":jqmData(role='collapsible-set')").addClass("
ui-collapsible-set"),l="";o.is("legend")&&(o=e("<div role='heading'>"+o.html()+"</div>").insertBefore(o),o.next().remove()),r.length?(n.theme||(n.theme=r.jqmData("theme")||e.mobile.getInheritedTheme(r,"c")),n.contentTheme||(n.contentTheme=r.jqmData("content-theme")),n.collapsedIcon=i.jqmData("collapsed-icon")||r.jqmData("collapsed-icon")||n.collapsedIcon,n.expandedIcon=i.jqmData("expanded-icon")||r.jqmData("expanded-icon")||n.expandedIcon,n.iconpos=i.jqmData("iconpos")||r.jqmData("iconpos")||n.iconpos,n.inset=r.jqmData("inset")!==t?r.jqmData("inset"):!0,n.corners=!1,n.mini||(n.mini=r.jqmData("mini"))):n.theme||(n.theme=e.mobile.getInheritedTheme(i,"c")),n.inset&&(l+=" ui-collapsible-inset",n.corners&&(l+=" ui-corner-all")),n.contentTheme&&(l+=" ui-collapsible-themed-content",s.addClass("ui-body-"+n.contentTheme)),""!==l&&a.addClass(l),o.insertBefore(s).addClass("ui-collapsible-heading").append("<span class='ui-collapsible-heading-status'></span>").wrapInner("<a href='#' clas
s='ui-collapsible-heading-toggle'></a>").find("a").first().buttonMarkup({shadow:!1,corners:!1,iconpos:n.iconpos,icon:n.collapsedIcon,mini:n.mini,theme:n.theme}),a.bind("expand collapse",function(t){if(!t.isDefaultPrevented()){var i=e(this),a="collapse"===t.type;t.preventDefault(),o.toggleClass("ui-collapsible-heading-collapsed",a).find(".ui-collapsible-heading-status").text(a?n.expandCueText:n.collapseCueText).end().find(".ui-icon").toggleClass("ui-icon-"+n.expandedIcon,!a).toggleClass("ui-icon-"+n.collapsedIcon,a||n.expandedIcon===n.collapsedIcon).end().find("a").first().removeClass(e.mobile.activeBtnClass),i.toggleClass("ui-collapsible-collapsed",a),s.toggleClass("ui-collapsible-content-collapsed",a).attr("aria-hidden",a),s.trigger("updatelayout")}}).trigger(n.collapsed?"collapse":"expand"),o.bind("tap",function(){o.find("a").first().addClass(e.mobile.activeBtnClass)}).bind("click",function(e){var t=o.is(".ui-collapsible-heading-collapsed")?"expand":"collapse";a.trigger(t)
,e.preventDefault(),e.stopPropagation()})}}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.collapsible.prototype.enhanceWithin(t.target)})}(e),function(e){e.mobile.behaviors.addFirstLastClasses={_getVisibles:function(e,t){var i;return t?i=e.not(".ui-screen-hidden"):(i=e.filter(":visible"),0===i.length&&(i=e.not(".ui-screen-hidden"))),i},_addFirstLastClasses:function(e,t,i){e.removeClass("ui-first-child ui-last-child"),t.eq(0).addClass("ui-first-child").end().last().addClass("ui-last-child"),i||this.element.trigger("updatelayout")}}}(e),function(e,t){e.widget("mobile.collapsibleset",e.mobile.widget,e.extend({options:{initSelector:":jqmData(role='collapsible-set')"},_create:function(){var i=this.element.addClass("ui-collapsible-set"),n=this.options;n.theme||(n.theme=e.mobile.getInheritedTheme(i,"c")),n.contentTheme||(n.contentTheme=i.jqmData("content-theme")),n.corners||(n.corners=i.jqmData("corners")),i.jqmData("inset")!==t&&(n.inset=i.jqmData("inset")),n.in
set=n.inset!==t?n.inset:!0,n.corners=n.corners!==t?n.corners:!0,n.corners&&n.inset&&i.addClass("ui-corner-all"),i.jqmData("collapsiblebound")||i.jqmData("collapsiblebound",!0).bind("expand",function(t){var i=e(t.target).closest(".ui-collapsible");i.parent().is(":jqmData(role='collapsible-set')")&&i.siblings(".ui-collapsible").trigger("collapse")})},_init:function(){var e=this.element,t=e.children(":jqmData(role='collapsible')"),i=t.filter(":jqmData(collapsed='false')");
+this._refresh("true"),i.trigger("expand")},_refresh:function(t){var i=this.element.children(":jqmData(role='collapsible')");e.mobile.collapsible.prototype.enhance(i.not(".ui-collapsible")),this._addFirstLastClasses(i,this._getVisibles(i,t),t)},refresh:function(){this._refresh(!1)}},e.mobile.behaviors.addFirstLastClasses)),e.mobile.document.bind("pagecreate create",function(t){e.mobile.collapsibleset.prototype.enhanceWithin(t.target)})}(e),function(e){e.fn.fieldcontain=function(){return this.addClass("ui-field-contain ui-body ui-br").contents().filter(function(){return 3===this.nodeType&&!/\S/.test(this.nodeValue)}).remove()},e(i).bind("pagecreate create",function(t){e(":jqmData(role='fieldcontain')",t.target).jqmEnhanceable().fieldcontain()})}(e),function(e){e.fn.grid=function(t){return this.each(function(){var i,n=e(this),a=e.extend({grid:null},t),o=n.children(),s={solo:1,a:2,b:3,c:4,d:5},r=a.grid;if(!r)if(5>=o.length)for(var l in s)s[l]===o.length&&(r=l);else r="a",n.addCl
ass("ui-grid-duo");i=s[r],n.addClass("ui-grid-"+r),o.filter(":nth-child("+i+"n+1)").addClass("ui-block-a"),i>1&&o.filter(":nth-child("+i+"n+2)").addClass("ui-block-b"),i>2&&o.filter(":nth-child("+i+"n+3)").addClass("ui-block-c"),i>3&&o.filter(":nth-child("+i+"n+4)").addClass("ui-block-d"),i>4&&o.filter(":nth-child("+i+"n+5)").addClass("ui-block-e")})}}(e),function(e,t){e.widget("mobile.navbar",e.mobile.widget,{options:{iconpos:"top",grid:null,initSelector:":jqmData(role='navbar')"},_create:function(){var n=this.element,a=n.find("a"),o=a.filter(":jqmData(icon)").length?this.options.iconpos:t;n.addClass("ui-navbar ui-mini").attr("role","navigation").find("ul").jqmEnhanceable().grid({grid:this.options.grid}),a.buttonMarkup({corners:!1,shadow:!1,inline:!0,iconpos:o}),n.delegate("a","vclick",function(t){var n=e(t.target).is("a")?e(this):e(this).parent("a");if(!n.is(".ui-disabled, .ui-btn-active")){a.removeClass(e.mobile.activeBtnClass),e(this).addClass(e.mobile.activeBtnClass);va
r o=e(this);e(i).one("pagehide",function(){o.removeClass(e.mobile.activeBtnClass)})}}),n.closest(".ui-page").bind("pagebeforeshow",function(){a.filter(".ui-state-persist").addClass(e.mobile.activeBtnClass)})}}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.navbar.prototype.enhanceWithin(t.target)})}(e),function(e){var t={};e.widget("mobile.listview",e.mobile.widget,e.extend({options:{theme:null,countTheme:"c",headerTheme:"b",dividerTheme:"b",icon:"arrow-r",splitIcon:"arrow-r",splitTheme:"b",corners:!0,shadow:!0,inset:!1,initSelector:":jqmData(role='listview')"},_create:function(){var e=this,t="";t+=e.options.inset?" ui-listview-inset":"",e.options.inset&&(t+=e.options.corners?" ui-corner-all":"",t+=e.options.shadow?" ui-shadow":""),e.element.addClass(function(e,i){return i+" ui-listview"+t}),e.refresh(!0)},_findFirstElementByTagName:function(e,t,i,n){var a={};for(a[i]=a[n]=!0;e;){if(a[e.nodeName])return e;e=e[t]}return null},_getChildrenByTagName:function(t
,i,n){var a=[],o={};for(o[i]=o[n]=!0,t=t.firstChild;t;)o[t.nodeName]&&a.push(t),t=t.nextSibling;return e(a)},_addThumbClasses:function(t){var i,n,a=t.length;for(i=0;a>i;i++)n=e(this._findFirstElementByTagName(t[i].firstChild,"nextSibling","img","IMG")),n.length&&(n.addClass("ui-li-thumb"),e(this._findFirstElementByTagName(n[0].parentNode,"parentNode","li","LI")).addClass(n.is(".ui-li-icon")?"ui-li-has-icon":"ui-li-has-thumb"))},refresh:function(t){this.parentPage=this.element.closest(".ui-page"),this._createSubPages();var n,a,o,s,r,l,d,c,h,u,p,m,f=this.options,g=this.element,b=g.jqmData("dividertheme")||f.dividerTheme,v=g.jqmData("splittheme"),_=g.jqmData("spliticon"),C=g.jqmData("icon"),x=this._getChildrenByTagName(g[0],"li","LI"),y=!!e.nodeName(g[0],"ol"),w=!e.support.cssPseudoElement,T=g.attr("start"),D={};y&&w&&g.find(".ui-li-dec").remove(),y&&(T||0===T?w?d=parseInt(T,10):(c=parseInt(T,10)-1,g.css("counter-reset","listnumbering "+c)):w&&(d=1)),f.theme||(f.theme=e.mobile.
getInheritedTheme(this.element,"c"));for(var P=0,k=x.length;k>P;P++){if(n=x.eq(P),a="ui-li",t||!n.hasClass("ui-li")){o=n.jqmData("theme")||f.theme,s=this._getChildrenByTagName(n[0],"a","A");var E="list-divider"===n.jqmData("role");s.length&&!E?(p=n.jqmData("icon"),n.buttonMarkup({wrapperEls:"div",shadow:!1,corners:!1,iconpos:"right",icon:s.length>1||p===!1?!1:p||C||f.icon,theme:o}),p!==!1&&1===s.length&&n.addClass("ui-li-has-arrow"),s.first().removeClass("ui-link").addClass("ui-link-inherit"),s.length>1&&(a+=" ui-li-has-alt",r=s.last(),l=v||r.jqmData("theme")||f.splitTheme,m=r.jqmData("icon"),r.appendTo(n).attr("title",e.trim(r.getEncodedText())).addClass("ui-li-link-alt").empty().buttonMarkup({shadow:!1,corners:!1,theme:o,icon:!1,iconpos:"notext"}).find(".ui-btn-inner").append(e(i.createElement("span")).buttonMarkup({shadow:!0,corners:!0,theme:l,iconpos:"notext",icon:m||p||_||f.splitIcon})))):E?(a+=" ui-li-divider ui-bar-"+(n.jqmData("theme")||b),n.attr("role","heading"),y&
&(T||0===T?w?d=parseInt(T,10):(h=parseInt(T,10)-1,n.css("counter-reset","listnumbering "+h)):w&&(d=1))):a+=" ui-li-static ui-btn-up-"+o}y&&w&&0>a.indexOf("ui-li-divider")&&(u=a.indexOf("ui-li-static")>0?n:n.find(".ui-link-inherit"),u.addClass("ui-li-jsnumbering").prepend("<span class='ui-li-dec'>"+d++ +". </span>")),D[a]||(D[a]=[]),D[a].push(n[0])}for(a in D)e(D[a]).addClass(a).children(".ui-btn-inner").addClass(a);g.find("h1, h2, h3, h4, h5, h6").addClass("ui-li-heading").end().find("p, dl").addClass("ui-li-desc").end().find(".ui-li-aside").each(function(){var t=e(this);t.prependTo(t.parent())}).end().find(".ui-li-count").each(function(){e(this).closest("li").addClass("ui-li-has-count")}).addClass("ui-btn-up-"+(g.jqmData("counttheme")||this.options.countTheme)+" ui-btn-corner-all"),this._addThumbClasses(x),this._addThumbClasses(g.find(".ui-link-inherit")),this._addFirstLastClasses(x,this._getVisibles(x,t),t),this._trigger("afterrefresh")},_idStringEscape:function(e){return
e.replace(/[^a-zA-Z0-9]/g,"-")},_createSubPages:function(){var i,a=this.element,o=a.closest(".ui-page"),s=o.jqmData("url"),r=s||o[0][e.expando],l=a.attr("id"),d=this.options,c="data-"+e.mobile.ns,h=this,u=o.find(":jqmData(role='footer')").jqmData("id");if(t[r]===n&&(t[r]=-1),l=l||++t[r],e(a.find("li>ul, li>ol").toArray().reverse()).each(function(t){var n,o,r=e(this),h=r.attr("id")||l+"-"+t,p=r.parent(),m=e(r.prevAll().toArray().reverse()),f=m.length?m:e("<span>"+e.trim(p.contents()[0].nodeValue)+"</span>"),g=f.first().getEncodedText(),b=(s||"")+"&"+e.mobile.subPageUrlKey+"="+h,v=r.jqmData("theme")||d.theme,_=r.jqmData("counttheme")||a.jqmData("counttheme")||d.countTheme;i=!0,n=r.detach().wrap("<div "+c+"role='page' "+c+"url='"+b+"' "+c+"theme='"+v+"' "+c+"count-theme='"+_+"'><div "+c+"role='content'></div></div>").parent().before("<div "+c+"role='header' "+c+"theme='"+d.headerTheme+"'><div class='ui-title'>"+g+"</div></div>").after(u?e("<div "+c+"role='footer' "+c+"id='"+u+"
'>"):"").parent().appendTo(e.mobile.pageContainer),n.page(),o=p.find("a:first"),o.length||(o=e("<a/>").html(f||g).prependTo(p.empty())),o.attr("href","#"+b)}).listview(),i&&o.is(":jqmData(external-page='true')")&&o.data("mobile-page").options.domCache===!1){var p=function(t,i){var n,a=i.nextPage,r=new e.Event("pageremove");i.nextPage&&(n=a.jqmData("url"),0!==n.indexOf(s+"&"+e.mobile.subPageUrlKey)&&(h.childPages().remove(),o.trigger(r),r.isDefaultPrevented()||o.removeWithDependents()))};o.unbind("pagehide.remove").bind("pagehide.remove",p)}},childPages:function(){var t=this.parentPage.jqmData("url");return e(":jqmData(url^='"+t+"&"+e.mobile.subPageUrlKey+"')")}},e.mobile.behaviors.addFirstLastClasses)),e.mobile.document.bind("pagecreate create",function(t){e.mobile.listview.prototype.enhanceWithin(t.target)})}(e),function(e){var t=e("meta[name=viewport]"),i=t.attr("content"),n=i+",maximum-scale=1, user-scalable=no",a=i+",maximum-scale=10, user-scalable=yes",o=/(user-scalable
[\s]*=[\s]*no)|(maximum-scale[\s]*=[\s]*1)[$,\s]/.test(i);e.mobile.zoom=e.extend({},{enabled:!o,locked:!1,disable:function(i){o||e.mobile.zoom.locked||(t.attr("content",n),e.mobile.zoom.enabled=!1,e.mobile.zoom.locked=i||!1)},enable:function(i){o||e.mobile.zoom.locked&&i!==!0||(t.attr("content",a),e.mobile.zoom.enabled=!0,e.mobile.zoom.locked=!1)},restore:function(){o||(t.attr("content",i),e.mobile.zoom.enabled=!0)}})}(e),function(e){e.widget("mobile.textinput",e.mobile.widget,{options:{theme:null,mini:!1,preventFocusZoom:/iPhone|iPad|iPod/.test(navigator.platform)&&navigator.userAgent.indexOf("AppleWebKit")>-1,initSelector:"input[type='text'], input[type='search'], :jqmData(type='search'), input[type='number'], :jqmData(type='number'), input[type='password'], input[type='email'], input[type='url'], input[type='tel'], textarea, input[type='time'], input[type='date'], input[type='month'], input[type='week'], input[type='datetime'], input[type='datetime-local'], input[type='co
lor'], input:not([type]), input[type='file']",clearBtn:!1,clearSearchButtonText:null,clearBtnText:"clear text",disabled:!1},_create:function(){function t(){setTimeout(function(){a.toggleClass("ui-input-clear-hidden",!s.val())},0)}var i,a,o=this,s=this.element,r=this.options,l=r.theme||e.mobile.getInheritedTheme(this.element,"c"),d=" ui-body-"+l,c=r.mini?" ui-mini":"",h=s.is("[type='search'], :jqmData(type='search')"),u=r.clearSearchButtonText||r.clearBtnText,p=s.is("textarea, :jqmData(type='range')"),m=!!r.clearBtn&&!p,f=s.is("input")&&!s.is(":jqmData(type='range')");if(e("label[for='"+s.attr("id")+"']").addClass("ui-input-text"),i=s.addClass("ui-input-text ui-body-"+l),s[0].autocorrect===n||e.support.touchOverflow||(s[0].setAttribute("autocorrect","off"),s[0].setAttribute("autocomplete","off")),h?i=s.wrap("<div class='ui-input-search ui-shadow-inset ui-btn-corner-all ui-btn-shadow ui-icon-searchfield"+d+c+"'></div>").parent():f&&(i=s.wrap("<div class='ui-input-text ui-shado
w-inset ui-corner-all ui-btn-shadow"+d+c+"'></div>").parent()),m||h?(a=e("<a href='#' class='ui-input-clear' title='"+u+"'>"+u+"</a>").bind("click",function(e){s.val("").focus().trigger("change"),a.addClass("ui-input-clear-hidden"),e.preventDefault()}).appendTo(i).buttonMarkup({icon:"delete",iconpos:"notext",corners:!0,shadow:!0,mini:r.mini}),h||i.addClass("ui-input-has-clear"),t(),s.bind("paste cut keyup input focus change blur",t)):f||h||s.addClass("ui-corner-all ui-shadow-inset"+d+c),s.focus(function(){r.preventFocusZoom&&e.mobile.zoom.disable(!0),i.addClass(e.mobile.focusClass)}).blur(function(){i.removeClass(e.mobile.focusClass),r.preventFocusZoom&&e.mobile.zoom.enable(!0)}),s.is("textarea")){var g,b=15,v=100;this._keyup=function(){var e=s[0].scrollHeight,t=s[0].clientHeight;if(e>t){var i=parseFloat(s.css("padding-top")),n=parseFloat(s.css("padding-bottom")),a=i+n;s.height(e-a+b)}},s.on("keyup change input paste",function(){clearTimeout(g),g=setTimeout(o._keyup,v)}),thi
s._on(!0,e.mobile.document,{pagechange:"_keyup"}),e.trim(s.val())&&this._on(!0,e.mobile.window,{load:"_keyup"})}s.attr("disabled")&&this.disable()},disable:function(){var e,t=this.element.is("[type='search'], :jqmData(type='search')"),i=this.element.is("input")&&!this.element.is(":jqmData(type='range')"),n=this.element.attr("disabled",!0)&&(i||t);return e=n?this.element.parent():this.element,e.addClass("ui-disabled"),this._setOption("disabled",!0)},enable:function(){var e,t=this.element.is("[type='search'], :jqmData(type='search')"),i=this.element.is("input")&&!this.element.is(":jqmData(type='range')"),n=this.element.attr("disabled",!1)&&(i||t);return e=n?this.element.parent():this.element,e.removeClass("ui-disabled"),this._setOption("disabled",!1)}}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.textinput.prototype.enhanceWithin(t.target,!0)})}(e),function(e){e.mobile.listview.prototype.options.filter=!1,e.mobile.listview.prototype.options.filterPlaceholde
r="Filter items...",e.mobile.listview.prototype.options.filterTheme="c",e.mobile.listview.prototype.options.filterReveal=!1;var t=function(e,t){return-1===(""+e).toLowerCase().indexOf(t)};e.mobile.listview.prototype.options.filterCallback=t,e.mobile.document.delegate("ul, ol","listviewcreate",function(){var i=e(this),n=i.data("mobile-listview");if(n&&n.options.filter){n.options.filterReveal&&i.children().addClass("ui-screen-hidden");var a=e("<form>",{"class":"ui-listview-filter ui-bar-"+n.options.filterTheme,role:"search"}).submit(function(e){e.preventDefault(),s.blur()}),o=function(){var a,o=e(this),s=this.value.toLowerCase(),r=null,l=i.children(),d=o.jqmData("lastval")+"",c=!1,h="",u=n.options.filterCallback!==t;if(!d||d!==s){if(n._trigger("beforefilter","beforefilter",{input:this}),o.jqmData("lastval",s),u||s.length<d.length||0!==s.indexOf(d)?r=i.children():(r=i.children(":not(.ui-screen-hidden)"),!r.length&&n.options.filterReveal&&(r=i.children(".ui-screen-hidden"))),s){
for(var p=r.length-1;p>=0;p--)a=e(r[p]),h=a.jqmData("filtertext")||a.text(),a.is("li:jqmData(role=list-divider)")?(a.toggleClass("ui-filter-hidequeue",!c),c=!1):n.options.filterCallback(h,s,a)?a.toggleClass("ui-filter-hidequeue",!0):c=!0;r.filter(":not(.ui-filter-hidequeue)").toggleClass("ui-screen-hidden",!1),r.filter(".ui-filter-hidequeue").toggleClass("ui-screen-hidden",!0).toggleClass("ui-filter-hidequeue",!1)}else r.toggleClass("ui-screen-hidden",!!n.options.filterReveal);n._addFirstLastClasses(l,n._getVisibles(l,!1),!1)}},s=e("<input>",{placeholder:n.options.filterPlaceholder}).attr("data-"+e.mobile.ns+"type","search").jqmData("lastval","").bind("keyup change input",o).appendTo(a).textinput();n.options.inset&&a.addClass("ui-listview-filter-inset"),a.bind("submit",function(){return!1}).insertBefore(i)}})}(e),function(e){e.mobile.listview.prototype.options.autodividers=!1,e.mobile.listview.prototype.options.autodividersSelector=function(t){var i=e.trim(t.text())||null;re
turn i?i=i.slice(0,1).toUpperCase():null},e.mobile.document.delegate("ul,ol","listviewcreate",function(){var t=e(this),n=t.data("mobile-listview");if(n&&n.options.autodividers){var a=function(){t.find("li:jqmData(role='list-divider')").remove();for(var a,o,s=t.find("li"),r=null,l=0;s.length>l;l++){if(a=s[l],o=n.options.autodividersSelector(e(a)),o&&r!==o){var d=i.createElement("li");d.appendChild(i.createTextNode(o)),d.setAttribute("data-"+e.mobile.ns+"role","list-divider"),a.parentNode.insertBefore(d,a)}r=o}},o=function(){t.unbind("listviewafterrefresh",o),a(),n.refresh(),t.bind("listviewafterrefresh",o)};o()}})}(e),function(e){e(i).bind("pagecreate create",function(t){e(":jqmData(role='nojs')",t.target).addClass("ui-nojs")})}(e),function(e){e.mobile.behaviors.formReset={_handleFormReset:function(){this._on(this.element.closest("form"),{reset:function(){this._delay("_reset")}})}}}(e),function(e){e.widget("mobile.checkboxradio",e.mobile.widget,e.extend({options:{theme:null,m
ini:!1,initSelector:"input[type='checkbox'],input[type='radio']"},_create:function(){var t=this,a=this.element,o=this.options,s=function(e,t){return e.jqmData(t)||e.closest("form, fieldset").jqmData(t)},r=e(a).closest("label"),l=r.length?r:e(a).closest("form, fieldset, :jqmData(role='page'), :jqmData(role='dialog')").find("label").filter("[for='"+a[0].id+"']").first(),d=a[0].type,c=s(a,"mini")||o.mini,h=d+"-on",u=d+"-off",p=s(a,"iconpos"),m="ui-"+h,f="ui-"+u;if("checkbox"===d||"radio"===d){e.extend(this,{label:l,inputtype:d,checkedClass:m,uncheckedClass:f,checkedicon:h,uncheckedicon:u}),o.theme||(o.theme=e.mobile.getInheritedTheme(this.element,"c")),l.buttonMarkup({theme:o.theme,icon:u,shadow:!1,mini:c,iconpos:p});var g=i.createElement("div");g.className="ui-"+d,a.add(l).wrapAll(g),l.bind({vmouseover:function(t){e(this).parent().is(".ui-disabled")&&t.stopPropagation()},vclick:function(e){return a.is(":disabled")?(e.preventDefault(),n):(t._cacheVals(),a.prop("checked","radio"
===d&&!0||!a.prop("checked")),a.triggerHandler("click"),t._getInputSet().not(a).prop("checked",!1),t._updateAll(),!1)}}),a.bind({vmousedown:function(){t._cacheVals()},vclick:function(){var i=e(this);i.is(":checked")?(i.prop("checked",!0),t._getInputSet().not(i).prop("checked",!1)):i.prop("checked",!1),t._updateAll()},focus:function(){l.addClass(e.mobile.focusClass)},blur:function(){l.removeClass(e.mobile.focusClass)}}),this._handleFormReset(),this.refresh()}},_cacheVals:function(){this._getInputSet().each(function(){e(this).jqmData("cacheVal",this.checked)})},_getInputSet:function(){return"checkbox"===this.inputtype?this.element:this.element.closest("form, :jqmData(role='page'), :jqmData(role='dialog')").find("input[name='"+this.element[0].name+"'][type='"+this.inputtype+"']")},_updateAll:function(){var t=this;this._getInputSet().each(function(){var i=e(this);(this.checked||"checkbox"===t.inputtype)&&i.trigger("change")}).checkboxradio("refresh")},_reset:function(){this.refr
esh()},refresh:function(){var t=this.element[0],i=" "+e.mobile.activeBtnClass,n=this.checkedClass+(this.element.parents(".ui-controlgroup-horizontal").length?i:""),a=this.label;t.checked?a.removeClass(this.uncheckedClass+i).addClass(n).buttonMarkup({icon:this.checkedicon}):a.removeClass(n).addClass(this.uncheckedClass).buttonMarkup({icon:this.uncheckedicon}),t.disabled?this.disable():this.enable()},disable:function(){this.element.prop("disabled",!0).parent().addClass("ui-disabled")},enable:function(){this.element.prop("disabled",!1).parent().removeClass("ui-disabled")}},e.mobile.behaviors.formReset)),e.mobile.document.bind("pagecreate create",function(t){e.mobile.checkboxradio.prototype.enhanceWithin(t.target,!0)})}(e),function(e){e.widget("mobile.button",e.mobile.widget,{options:{theme:null,icon:null,iconpos:null,corners:!0,shadow:!0,iconshadow:!0,inline:null,mini:null,initSelector:"button, [type='button'], [type='submit'], [type='reset']"},_create:function(){var t,i=this.e
lement,a=function(e){var t,i={};for(t in e)null!==e[t]&&"initSelector"!==t&&(i[t]=e[t]);return i}(this.options),o="";return"A"===i[0].tagName?(i.hasClass("ui-btn")||i.buttonMarkup(),n):(this.options.theme||(this.options.theme=e.mobile.getInheritedTheme(this.element,"c")),~i[0].className.indexOf("ui-btn-left")&&(o="ui-btn-left"),~i[0].className.indexOf("ui-btn-right")&&(o="ui-btn-right"),("submit"===i.attr("type")||"reset"===i.attr("type"))&&(o?o+=" ui-submit":o="ui-submit"),e("label[for='"+i.attr("id")+"']").addClass("ui-submit"),this.button=e("<div></div>")[i.html()?"html":"text"](i.html()||i.val()).insertBefore(i).buttonMarkup(a).addClass(o).append(i.addClass("ui-btn-hidden")),t=this.button,i.bind({focus:function(){t.addClass(e.mobile.focusClass)},blur:function(){t.removeClass(e.mobile.focusClass)}}),this.refresh(),n)},_setOption:function(t,i){var n={};n[t]=i,"initSelector"!==t&&(this.button.buttonMarkup(n),this.element.attr("data-"+(e.mobile.ns||"")+t.replace(/([A-Z])/,"-
$1").toLowerCase(),i)),this._super("_setOption",t,i)},enable:function(){return this.element.attr("disabled",!1),this.button.removeClass("ui-disabled").attr("aria-disabled",!1),this._setOption("disabled",!1)},disable:function(){return this.element.attr("disabled",!0),this.button.addClass("ui-disabled").attr("aria-disabled",!0),this._setOption("disabled",!0)},refresh:function(){var t=this.element;t.prop("disabled")?this.disable():this.enable(),e(this.button.data("buttonElements").text)[t.html()?"html":"text"](t.html()||t.val())}}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.button.prototype.enhanceWithin(t.target,!0)})}(e),function(e,n){e.widget("mobile.slider",e.mobile.widget,e.extend({widgetEventPrefix:"slide",options:{theme:null,trackTheme:null,disabled:!1,initSelector:"input[type='range'], :jqmData(type='range'), :jqmData(role='slider')",mini:!1,highlight:!1},_create:function(){var a,o,s=this,r=this.element,l=e.mobile.getInheritedTheme(r,"c"),d=this.opt
ions.theme||l,c=this.options.trackTheme||l,h=r[0].nodeName.toLowerCase(),u=(this.isToggleSwitch="select"===h,r.parent().is(":jqmData(role='rangeslider')")),p=this.isToggleSwitch?"ui-slider-switch":"",m=r.attr("id"),f=e("[for='"+m+"']"),g=f.attr("id")||m+"-label",b=f.attr("id",g),v=this.isToggleSwitch?0:parseFloat(r.attr("min")),_=this.isToggleSwitch?r.find("option").length-1:parseFloat(r.attr("max")),C=t.parseFloat(r.attr("step")||1),x=this.options.mini||r.jqmData("mini")?" ui-mini":"",y=i.createElement("a"),w=e(y),T=i.createElement("div"),D=e(T),P=this.options.highlight&&!this.isToggleSwitch?function(){var t=i.createElement("div");return t.className="ui-slider-bg "+e.mobile.activeBtnClass+" ui-btn-corner-all",e(t).prependTo(D)}():!1;if(y.setAttribute("href","#"),T.setAttribute("role","application"),T.className=[this.isToggleSwitch?"ui-slider ":"ui-slider-track ",p," ui-btn-down-",c," ui-btn-corner-all",x].join(""),y.className="ui-slider-handle",T.appendChild(y),w.buttonMark
up({corners:!0,theme:d,shadow:!0}).attr({role:"slider","aria-valuemin":v,"aria-valuemax":_,"aria-valuenow":this._value(),"aria-valuetext":this._value(),title:this._value(),"aria-labelledby":g}),e.extend(this,{slider:D,handle:w,type:h,step:C,max:_,min:v,valuebg:P,isRangeslider:u,dragging:!1,beforeStart:null,userModified:!1,mouseMoved:!1}),this.isToggleSwitch){o=i.createElement("div"),o.className="ui-slider-inneroffset";for(var k=0,E=T.childNodes.length;E>k;k++)o.appendChild(T.childNodes[k]);T.appendChild(o),w.addClass("ui-slider-handle-snapping"),a=r.find("option");for(var q=0,j=a.length;j>q;q++){var S=q?"a":"b",A=q?" "+e.mobile.activeBtnClass:" ui-btn-down-"+c,N=(i.createElement("div"),i.createElement("span"));N.className=["ui-slider-label ui-slider-label-",S,A," ui-btn-corner-all"].join(""),N.setAttribute("role","img"),N.appendChild(i.createTextNode(a[q].innerHTML)),e(N).prependTo(D)}s._labels=e(".ui-slider-label",D)}b.addClass("ui-slider"),r.addClass(this.isToggleSwitch?"u
i-slider-switch":"ui-slider-input"),this._on(r,{change:"_controlChange",keyup:"_controlKeyup",blur:"_controlBlur",vmouseup:"_controlVMouseUp"}),D.bind("vmousedown",e.proxy(this._sliderVMouseDown,this)).bind("vclick",!1),this._on(i,{vmousemove:"_preventDocumentDrag"}),this._on(D.add(i),{vmouseup:"_sliderVMouseUp"}),D.insertAfter(r),this.isToggleSwitch||u||(o=this.options.mini?"<div class='ui-slider ui-mini'>":"<div class='ui-slider'>",r.add(D).wrapAll(o)),this.isToggleSwitch&&this.handle.bind({focus:function(){D.addClass(e.mobile.focusClass)},blur:function(){D.removeClass(e.mobile.focusClass)}}),this._on(this.handle,{vmousedown:"_handleVMouseDown",keydown:"_handleKeydown",keyup:"_handleKeyup"}),this.handle.bind("vclick",!1),this._handleFormReset(),this.refresh(n,n,!0)},_controlChange:function(e){return this._trigger("controlchange",e)===!1?!1:(this.mouseMoved||this.refresh(this._value(),!0),n)},_controlKeyup:function(){this.refresh(this._value(),!0,!0)},_controlBlur:function(
){this.refresh(this._value(),!0)},_controlVMouseUp:function(){this._checkedRefresh()},_handleVMouseDown:function(){this.handle.focus()},_handleKeydown:function(t){var i=this._value();if(!this.options.disabled){switch(t.keyCode){case e.mobile.keyCode.HOME:case e.mobile.keyCode.END:case e.mobile.keyCode.PAGE_UP:case e.mobile.keyCode.PAGE_DOWN:case e.mobile.keyCode.UP:case e.mobile.keyCode.RIGHT:case e.mobile.keyCode.DOWN:case e.mobile.keyCode.LEFT:t.preventDefault(),this._keySliding||(this._keySliding=!0,this.handle.addClass("ui-state-active"))}switch(t.keyCode){case e.mobile.keyCode.HOME:this.refresh(this.min);break;case e.mobile.keyCode.END:this.refresh(this.max);break;case e.mobile.keyCode.PAGE_UP:case e.mobile.keyCode.UP:case e.mobile.keyCode.RIGHT:this.refresh(i+this.step);break;case e.mobile.keyCode.PAGE_DOWN:case e.mobile.keyCode.DOWN:case e.mobile.keyCode.LEFT:this.refresh(i-this.step)}}},_handleKeyup:function(){this._keySliding&&(this._keySliding=!1,this.handle.remove
Class("ui-state-active"))},_sliderVMouseDown:function(e){return this.options.disabled||1!==e.which&&0!==e.which?!1:this._trigger("beforestart",e)===!1?!1:(this.dragging=!0,this.userModified=!1,this.mouseMoved=!1,this.isToggleSwitch&&(this.beforeStart=this.element[0].selectedIndex),this.refresh(e),this._trigger("start"),!1)},_sliderVMouseUp:function(){return this.dragging?(this.dragging=!1,this.isToggleSwitch&&(this.handle.addClass("ui-slider-handle-snapping"),this.mouseMoved?this.userModified?this.refresh(0===this.beforeStart?1:0):this.refresh(this.beforeStart):this.refresh(0===this.beforeStart?1:0)),this.mouseMoved=!1,this._trigger("stop"),!1):n},_preventDocumentDrag:function(e){return this._trigger("drag",e)===!1?!1:this.dragging&&!this.options.disabled?(this.mouseMoved=!0,this.isToggleSwitch&&this.handle.removeClass("ui-slider-handle-snapping"),this.refresh(e),this.userModified=this.beforeStart!==this.element[0].selectedIndex,!1):n},_checkedRefresh:function(){this.value!=
=this._value()&&this.refresh(this._value())},_value:function(){return this.isToggleSwitch?this.element[0].selectedIndex:parseFloat(this.element.val())},_reset:function(){this.refresh(n,!1,!0)},refresh:function(t,a,o){var s,r,l,d,c=this,h=e.mobile.getInheritedTheme(this.element,"c"),u=this.options.theme||h,p=this.options.trackTheme||h;c.slider[0].className=[this.isToggleSwitch?"ui-slider ui-slider-switch":"ui-slider-track"," ui-btn-down-"+p," ui-btn-corner-all",this.options.mini?" ui-mini":""].join(""),(this.options.disabled||this.element.attr("disabled"))&&this.disable(),this.value=this._value(),this.options.highlight&&!this.isToggleSwitch&&0===this.slider.find(".ui-slider-bg").length&&(this.valuebg=function(){var t=i.createElement("div");return t.className="ui-slider-bg "+e.mobile.activeBtnClass+" ui-btn-corner-all",e(t).prependTo(c.slider)}()),this.handle.buttonMarkup({corners:!0,theme:u,shadow:!0});var m,f,g=this.element,b=!this.isToggleSwitch,v=b?[]:g.find("option"),_=b?
parseFloat(g.attr("min")):0,C=b?parseFloat(g.attr("max")):v.length-1,x=b&&parseFloat(g.attr("step"))>0?parseFloat(g.attr("step")):1;if("object"==typeof t){if(l=t,d=8,s=this.slider.offset().left,r=this.slider.width(),m=r/((C-_)/x),!this.dragging||s-d>l.pageX||l.pageX>s+r+d)return;f=m>1?100*((l.pageX-s)/r):Math.round(100*((l.pageX-s)/r))}else null==t&&(t=b?parseFloat(g.val()||0):g[0].selectedIndex),f=100*((parseFloat(t)-_)/(C-_));if(!isNaN(f)){var y=f/100*(C-_)+_,w=(y-_)%x,T=y-w;2*Math.abs(w)>=x&&(T+=w>0?x:-x);var D=100/((C-_)/x);if(y=parseFloat(T.toFixed(5)),m===n&&(m=r/((C-_)/x)),m>1&&b&&(f=(y-_)*D*(1/x)),0>f&&(f=0),f>100&&(f=100),_>y&&(y=_),y>C&&(y=C),this.handle.css("left",f+"%"),this.handle[0].setAttribute("aria-valuenow",b?y:v.eq(y).attr("value")),this.handle[0].setAttribute("aria-valuetext",b?y:v.eq(y).getEncodedText()),this.handle[0].setAttribute("title",b?y:v.eq(y).getEncodedText()),this.valuebg&&this.valuebg.css("width",f+"%"),this._labels){var P=100*(this.handle.wid
th()/this.slider.width()),k=f&&P+(100-P)*f/100,E=100===f?0:Math.min(P+100-k,100);this._labels.each(function(){var t=e(this).is(".ui-slider-label-a");e(this).width((t?k:E)+"%")})}if(!o){var q=!1;if(b?(q=g.val()!==y,g.val(y)):(q=g[0].selectedIndex!==y,g[0].selectedIndex=y),this._trigger("beforechange",t)===!1)return!1;!a&&q&&g.trigger("change")}}},enable:function(){return this.element.attr("disabled",!1),this.slider.removeClass("ui-disabled").attr("aria-disabled",!1),this._setOption("disabled",!1)},disable:function(){return this.element.attr("disabled",!0),this.slider.addClass("ui-disabled").attr("aria-disabled",!0),this._setOption("disabled",!0)}},e.mobile.behaviors.formReset)),e.mobile.document.bind("pagecreate create",function(t){e.mobile.slider.prototype.enhanceWithin(t.target,!0)})}(e),function(e){e.widget("mobile.rangeslider",e.mobile.widget,{options:{theme:null,trackTheme:null,disabled:!1,initSelector:":jqmData(role='rangeslider')",mini:!1,highlight:!0},_create:function
(){var t,i=this.element,n=this.options.mini?"ui-rangeslider ui-mini":"ui-rangeslider",a=i.find("input").first(),o=i.find("input").last(),s=i.find("label").first(),r=e.data(a.get(0),"mobileSlider").slider,l=e.data(o.get(0),"mobileSlider").slider,d=e.data(a.get(0),"mobileSlider").handle,c=e('<div class="ui-rangeslider-sliders" />').appendTo(i);i.find("label").length>1&&(t=i.find("label").last().hide()),a.addClass("ui-rangeslider-first"),o.addClass("ui-rangeslider-last"),i.addClass(n),r.appendTo(c),l.appendTo(c),s.prependTo(i),d.prependTo(l),e.extend(this,{_inputFirst:a,_inputLast:o,_sliderFirst:r,_sliderLast:l,_targetVal:null,_sliderTarget:!1,_sliders:c,_proxy:!1}),this.refresh(),this._on(this.element.find("input.ui-slider-input"),{slidebeforestart:"_slidebeforestart",slidestop:"_slidestop",slidedrag:"_slidedrag",slidebeforechange:"_change",blur:"_change",keyup:"_change"}),this._on({mousedown:"_change"}),this._on(this.element.closest("form"),{reset:"_handleReset"}),this._on(d,
{vmousedown:"_dragFirstHandle"})},_handleReset:function(){var e=this;setTimeout(function(){e._updateHighlight()},0)},_dragFirstHandle:function(t){return e.data(this._inputFirst.get(0),"mobileSlider").dragging=!0,e.data(this._inputFirst.get(0),"mobileSlider").refresh(t),!1},_slidedrag:function(t){var i=e(t.target).is(this._inputFirst),a=i?this._inputLast:this._inputFirst;return this._sliderTarget=!1,"first"===this._proxy&&i||"last"===this._proxy&&!i?(e.data(a.get(0),"mobileSlider").dragging=!0,e.data(a.get(0),"mobileSlider").refresh(t),!1):n},_slidestop:function(t){var i=e(t.target).is(this._inputFirst);this._proxy=!1,this.element.find("input").trigger("vmouseup"),this._sliderFirst.css("z-index",i?1:"")},_slidebeforestart:function(t){this._sliderTarget=!1,e(t.originalEvent.target).hasClass("ui-slider-track")&&(this._sliderTarget=!0,this._targetVal=e(t.target).val())},_setOption:function(e){this._superApply(e),this.refresh()},refresh:function(){var e=this.element,t=this.option
s;e.find("input").slider({theme:t.theme,trackTheme:t.trackTheme,disabled:t.disabled,mini:t.mini,highlight:t.highlight}).slider("refresh"),this._updateHighlight()},_change:function(t){if("keyup"===t.type)return this._updateHighlight(),!1;var i=this,a=parseFloat(this._inputFirst.val(),10),o=parseFloat(this._inputLast.val(),10),s=e(t.target).hasClass("ui-rangeslider-first"),r=s?this._inputFirst:this._inputLast,l=s?this._inputLast:this._inputFirst;if(this._inputFirst.val()>this._inputLast.val()&&"mousedown"===t.type&&!e(t.target).hasClass("ui-slider-handle"))r.blur();else if("mousedown"===t.type)return;return a>o&&!this._sliderTarget?(r.val(s?o:a).slider("refresh"),this._trigger("normalize")):a>o&&(r.val(this._targetVal).slider("refresh"),setTimeout(function(){l.val(s?a:o).slider("refresh"),e.data(l.get(0),"mobileSlider").handle.focus(),i._sliderFirst.css("z-index",s?"":1),i._trigger("normalize")},0),this._proxy=s?"first":"last"),a===o?(e.data(r.get(0),"mobileSlider").handle.css
("z-index",1),e.data(l.get(0),"mobileSlider").handle.css("z-index",0)):(e.data(l.get(0),"mobileSlider").handle.css("z-index",""),e.data(r.get(0),"mobileSlider").handle.css("z-index","")),this._updateHighlight(),a>=o?!1:n},_updateHighlight:function(){var t=parseInt(e.data(this._inputFirst.get(0),"mobileSlider").handle.get(0).style.left,10),i=parseInt(e.data(this._inputLast.get(0),"mobileSlider").handle.get(0).style.left,10),n=i-t;this.element.find(".ui-slider-bg").css({"margin-left":t+"%",width:n+"%"})},_destroy:function(){this.element.removeClass("ui-rangeslider ui-mini").find("label").show(),this._inputFirst.after(this._sliderFirst),this._inputLast.after(this._sliderLast),this._sliders.remove(),this.element.find("input").removeClass("ui-rangeslider-first ui-rangeslider-last").slider("destroy")}}),e.widget("mobile.rangeslider",e.mobile.rangeslider,e.mobile.behaviors.formReset),e(i).bind("pagecreate create",function(t){e.mobile.rangeslider.prototype.enhanceWithin(t.target,!0)
})}(e),function(e){e.widget("mobile.selectmenu",e.mobile.widget,e.extend({options:{theme:null,disabled:!1,icon:"arrow-d",iconpos:"right",inline:!1,corners:!0,shadow:!0,iconshadow:!0,overlayTheme:"a",dividerTheme:"b",hidePlaceholderMenuItems:!0,closeText:"Close",nativeMenu:!0,preventFocusZoom:/iPhone|iPad|iPod/.test(navigator.platform)&&navigator.userAgent.indexOf("AppleWebKit")>-1,initSelector:"select:not( :jqmData(role='slider') )",mini:!1},_button:function(){return e("<div/>")
+},_setDisabled:function(e){return this.element.attr("disabled",e),this.button.attr("aria-disabled",e),this._setOption("disabled",e)},_focusButton:function(){var e=this;setTimeout(function(){e.button.focus()},40)},_selectOptions:function(){return this.select.find("option")},_preExtension:function(){var t="";~this.element[0].className.indexOf("ui-btn-left")&&(t=" ui-btn-left"),~this.element[0].className.indexOf("ui-btn-right")&&(t=" ui-btn-right"),this.select=this.element.removeClass("ui-btn-left ui-btn-right").wrap("<div class='ui-select"+t+"'>"),this.selectID=this.select.attr("id"),this.label=e("label[for='"+this.selectID+"']").addClass("ui-select"),this.isMultiple=this.select[0].multiple,this.options.theme||(this.options.theme=e.mobile.getInheritedTheme(this.select,"c"))},_destroy:function(){var e=this.element.parents(".ui-select");e.length>0&&(e.is(".ui-btn-left, .ui-btn-right")&&this.element.addClass(e.is(".ui-btn-left")?"ui-btn-left":"ui-btn-right"),this.element.insertAf
ter(e),e.remove())},_create:function(){this._preExtension(),this._trigger("beforeCreate"),this.button=this._button();var i=this,n=this.options,a=n.inline||this.select.jqmData("inline"),o=n.mini||this.select.jqmData("mini"),s=n.icon?n.iconpos||this.select.jqmData("iconpos"):!1,r=(-1===this.select[0].selectedIndex?0:this.select[0].selectedIndex,this.button.insertBefore(this.select).buttonMarkup({theme:n.theme,icon:n.icon,iconpos:s,inline:a,corners:n.corners,shadow:n.shadow,iconshadow:n.iconshadow,mini:o}));this.setButtonText(),n.nativeMenu&&t.opera&&t.opera.version&&r.addClass("ui-select-nativeonly"),this.isMultiple&&(this.buttonCount=e("<span>").addClass("ui-li-count ui-btn-up-c ui-btn-corner-all").hide().appendTo(r.addClass("ui-li-has-count"))),(n.disabled||this.element.attr("disabled"))&&this.disable(),this.select.change(function(){i.refresh(),n.nativeMenu&&this.blur()}),this._handleFormReset(),this.build()},build:function(){var t=this;this.select.appendTo(t.button).bind("v
mousedown",function(){t.button.addClass(e.mobile.activeBtnClass)}).bind("focus",function(){t.button.addClass(e.mobile.focusClass)}).bind("blur",function(){t.button.removeClass(e.mobile.focusClass)}).bind("focus vmouseover",function(){t.button.trigger("vmouseover")}).bind("vmousemove",function(){t.button.removeClass(e.mobile.activeBtnClass)}).bind("change blur vmouseout",function(){t.button.trigger("vmouseout").removeClass(e.mobile.activeBtnClass)}).bind("change blur",function(){t.button.removeClass("ui-btn-down-"+t.options.theme)}),t.button.bind("vmousedown",function(){t.options.preventFocusZoom&&e.mobile.zoom.disable(!0)}),t.label.bind("click focus",function(){t.options.preventFocusZoom&&e.mobile.zoom.disable(!0)}),t.select.bind("focus",function(){t.options.preventFocusZoom&&e.mobile.zoom.disable(!0)}),t.button.bind("mouseup",function(){t.options.preventFocusZoom&&setTimeout(function(){e.mobile.zoom.enable(!0)},0)}),t.select.bind("blur",function(){t.options.preventFocusZoom
&&e.mobile.zoom.enable(!0)})},selected:function(){return this._selectOptions().filter(":selected")},selectedIndices:function(){var e=this;return this.selected().map(function(){return e._selectOptions().index(this)}).get()},setButtonText:function(){var t=this,n=this.selected(),a=this.placeholder,o=e(i.createElement("span"));this.button.find(".ui-btn-text").html(function(){return a=n.length?n.map(function(){return e(this).text()}).get().join(", "):t.placeholder,o.text(a).addClass(t.select.attr("class")).addClass(n.attr("class"))})},setButtonCount:function(){var e=this.selected();this.isMultiple&&this.buttonCount[e.length>1?"show":"hide"]().text(e.length)},_reset:function(){this.refresh()},refresh:function(){this.setButtonText(),this.setButtonCount()},open:e.noop,close:e.noop,disable:function(){this._setDisabled(!0),this.button.addClass("ui-disabled")},enable:function(){this._setDisabled(!1),this.button.removeClass("ui-disabled")}},e.mobile.behaviors.formReset)),e.mobile.docume
nt.bind("pagecreate create",function(t){e.mobile.selectmenu.prototype.enhanceWithin(t.target,!0)})}(e),function(e,n){function a(e,t,i,n){var a=n;return a=t>e?i+(e-t)/2:Math.min(Math.max(i,n-t/2),i+e-t)}function o(){var i=e.mobile.window;return{x:i.scrollLeft(),y:i.scrollTop(),cx:t.innerWidth||i.width(),cy:t.innerHeight||i.height()}}e.widget("mobile.popup",e.mobile.widget,{options:{theme:null,overlayTheme:null,shadow:!0,corners:!0,transition:"none",positionTo:"origin",tolerance:null,initSelector:":jqmData(role='popup')",closeLinkSelector:"a:jqmData(rel='back')",closeLinkEvents:"click.popup",navigateEvents:"navigate.popup",closeEvents:"navigate.popup pagebeforechange.popup",dismissible:!0,history:!e.mobile.browser.oldIE},_eatEventAndClose:function(e){return e.preventDefault(),e.stopImmediatePropagation(),this.options.dismissible&&this.close(),!1},_resizeScreen:function(){var e=this._ui.container.outerHeight(!0);this._ui.screen.removeAttr("style"),e>this._ui.screen.height()&&th
is._ui.screen.height(e)},_handleWindowKeyUp:function(t){return this._isOpen&&t.keyCode===e.mobile.keyCode.ESCAPE?this._eatEventAndClose(t):n},_expectResizeEvent:function(){var t=o();if(this._resizeData){if(t.x===this._resizeData.winCoords.x&&t.y===this._resizeData.winCoords.y&&t.cx===this._resizeData.winCoords.cx&&t.cy===this._resizeData.winCoords.cy)return!1;clearTimeout(this._resizeData.timeoutId)}return this._resizeData={timeoutId:setTimeout(e.proxy(this,"_resizeTimeout"),200),winCoords:t},!0},_resizeTimeout:function(){this._isOpen?this._expectResizeEvent()||(this._ui.container.hasClass("ui-popup-hidden")&&(this._ui.container.removeClass("ui-popup-hidden"),this.reposition({positionTo:"window"}),this._ignoreResizeEvents()),this._resizeScreen(),this._resizeData=null,this._orientationchangeInProgress=!1):(this._resizeData=null,this._orientationchangeInProgress=!1)},_ignoreResizeEvents:function(){var e=this;this._ignoreResizeTo&&clearTimeout(this._ignoreResizeTo),this._ignore
ResizeTo=setTimeout(function(){e._ignoreResizeTo=0},1e3)},_handleWindowResize:function(){this._isOpen&&0===this._ignoreResizeTo&&(!this._expectResizeEvent()&&!this._orientationchangeInProgress||this._ui.container.hasClass("ui-popup-hidden")||this._ui.container.addClass("ui-popup-hidden").removeAttr("style"))},_handleWindowOrientationchange:function(){!this._orientationchangeInProgress&&this._isOpen&&0===this._ignoreResizeTo&&(this._expectResizeEvent(),this._orientationchangeInProgress=!0)},_handleDocumentFocusIn:function(t){var n,a=t.target,o=this._ui;if(this._isOpen){if(a!==o.container[0]){if(n=e(t.target),0===n.parents().filter(o.container[0]).length)return e(i.activeElement).one("focus",function(){n.blur()}),o.focusElement.focus(),t.preventDefault(),t.stopImmediatePropagation(),!1;o.focusElement[0]===o.container[0]&&(o.focusElement=n)}this._ignoreResizeEvents()}},_create:function(){var t={screen:e("<div class='ui-screen-hidden ui-popup-screen'></div>"),placeholder:e("<div
style='display: none;'><!-- placeholder --></div>"),container:e("<div class='ui-popup-container ui-popup-hidden'></div>")},i=this.element.closest(".ui-page"),a=this.element.attr("id"),o=this;this.options.history=this.options.history&&e.mobile.ajaxEnabled&&e.mobile.hashListeningEnabled,0===i.length&&(i=e("body")),this.options.container=this.options.container||e.mobile.pageContainer,i.append(t.screen),t.container.insertAfter(t.screen),t.placeholder.insertAfter(this.element),a&&(t.screen.attr("id",a+"-screen"),t.container.attr("id",a+"-popup"),t.placeholder.html("<!-- placeholder for "+a+" -->")),t.container.append(this.element),t.focusElement=t.container,this.element.addClass("ui-popup"),e.extend(this,{_scrollTop:0,_page:i,_ui:t,_fallbackTransition:"",_currentTransition:!1,_prereqs:null,_isOpen:!1,_tolerance:null,_resizeData:null,_ignoreResizeTo:0,_orientationchangeInProgress:!1}),e.each(this.options,function(e,t){o.options[e]=n,o._setOption(e,t,!0)}),t.screen.bind("vclick",e
.proxy(this,"_eatEventAndClose")),this._on(e.mobile.window,{orientationchange:e.proxy(this,"_handleWindowOrientationchange"),resize:e.proxy(this,"_handleWindowResize"),keyup:e.proxy(this,"_handleWindowKeyUp")}),this._on(e.mobile.document,{focusin:e.proxy(this,"_handleDocumentFocusIn")})},_applyTheme:function(e,t,i){for(var n,a=(e.attr("class")||"").split(" "),o=null,s=t+"";a.length>0;){if(o=a.pop(),n=RegExp("^ui-"+i+"-([a-z])$").exec(o),n&&n.length>1){o=n[1];break}o=null}t!==o&&(e.removeClass("ui-"+i+"-"+o),null!==t&&"none"!==t&&e.addClass("ui-"+i+"-"+s))},_setTheme:function(e){this._applyTheme(this.element,e,"body")},_setOverlayTheme:function(e){this._applyTheme(this._ui.screen,e,"overlay"),this._isOpen&&this._ui.screen.addClass("in")},_setShadow:function(e){this.element.toggleClass("ui-overlay-shadow",e)},_setCorners:function(e){this.element.toggleClass("ui-corner-all",e)},_applyTransition:function(t){this._ui.container.removeClass(this._fallbackTransition),t&&"none"!==t&&
(this._fallbackTransition=e.mobile._maybeDegradeTransition(t),"none"===this._fallbackTransition&&(this._fallbackTransition=""),this._ui.container.addClass(this._fallbackTransition))},_setTransition:function(e){this._currentTransition||this._applyTransition(e)},_setTolerance:function(t){var i={t:30,r:15,b:30,l:15};if(t!==n){var a=(t+"").split(",");switch(e.each(a,function(e,t){a[e]=parseInt(t,10)}),a.length){case 1:isNaN(a[0])||(i.t=i.r=i.b=i.l=a[0]);break;case 2:isNaN(a[0])||(i.t=i.b=a[0]),isNaN(a[1])||(i.l=i.r=a[1]);break;case 4:isNaN(a[0])||(i.t=a[0]),isNaN(a[1])||(i.r=a[1]),isNaN(a[2])||(i.b=a[2]),isNaN(a[3])||(i.l=a[3]);break;default:}}this._tolerance=i},_setOption:function(t,i){var a,o="_set"+t.charAt(0).toUpperCase()+t.slice(1);this[o]!==n&&this[o](i),a=["initSelector","closeLinkSelector","closeLinkEvents","navigateEvents","closeEvents","history","container"],e.mobile.widget.prototype._setOption.apply(this,arguments),-1===e.inArray(t,a)&&this.element.attr("data-"+(e.mo
bile.ns||"")+t.replace(/([A-Z])/,"-$1").toLowerCase(),i)},_placementCoords:function(e){var t,n,s=o(),r={x:this._tolerance.l,y:s.y+this._tolerance.t,cx:s.cx-this._tolerance.l-this._tolerance.r,cy:s.cy-this._tolerance.t-this._tolerance.b};this._ui.container.css("max-width",r.cx),t={cx:this._ui.container.outerWidth(!0),cy:this._ui.container.outerHeight(!0)},n={x:a(r.cx,t.cx,r.x,e.x),y:a(r.cy,t.cy,r.y,e.y)},n.y=Math.max(0,n.y);var l=i.documentElement,d=i.body,c=Math.max(l.clientHeight,d.scrollHeight,d.offsetHeight,l.scrollHeight,l.offsetHeight);return n.y-=Math.min(n.y,Math.max(0,n.y+t.cy-c)),{left:n.x,top:n.y}},_createPrereqs:function(t,i,n){var a,o=this;a={screen:e.Deferred(),container:e.Deferred()},a.screen.then(function(){a===o._prereqs&&t()}),a.container.then(function(){a===o._prereqs&&i()}),e.when(a.screen,a.container).done(function(){a===o._prereqs&&(o._prereqs=null,n())}),o._prereqs=a},_animate:function(t){return this._ui.screen.removeClass(t.classToRemove).addClass(t.sc
reenClassToAdd),t.prereqs.screen.resolve(),t.transition&&"none"!==t.transition&&(t.applyTransition&&this._applyTransition(t.transition),this._fallbackTransition)?(this._ui.container.animationComplete(e.proxy(t.prereqs.container,"resolve")).addClass(t.containerClassToAdd).removeClass(t.classToRemove),n):(this._ui.container.removeClass(t.classToRemove),t.prereqs.container.resolve(),n)},_desiredCoords:function(t){var i,n=null,a=o(),s=t.x,r=t.y,l=t.positionTo;if(l&&"origin"!==l)if("window"===l)s=a.cx/2+a.x,r=a.cy/2+a.y;else{try{n=e(l)}catch(d){n=null}n&&(n.filter(":visible"),0===n.length&&(n=null))}return n&&(i=n.offset(),s=i.left+n.outerWidth()/2,r=i.top+n.outerHeight()/2),("number"!==e.type(s)||isNaN(s))&&(s=a.cx/2+a.x),("number"!==e.type(r)||isNaN(r))&&(r=a.cy/2+a.y),{x:s,y:r}},_reposition:function(e){e={x:e.x,y:e.y,positionTo:e.positionTo},this._trigger("beforeposition",e),this._ui.container.offset(this._placementCoords(this._desiredCoords(e)))},reposition:function(e){this._
isOpen&&this._reposition(e)},_openPrereqsComplete:function(){this._ui.container.addClass("ui-popup-active"),this._isOpen=!0,this._resizeScreen(),this._ui.container.attr("tabindex","0").focus(),this._ignoreResizeEvents(),this._trigger("afteropen")},_open:function(t){var i=e.extend({},this.options,t),n=function(){var e=navigator.userAgent,t=e.match(/AppleWebKit\/([0-9\.]+)/),i=!!t&&t[1],n=e.match(/Android (\d+(?:\.\d+))/),a=!!n&&n[1],o=e.indexOf("Chrome")>-1;return null!==n&&"4.0"===a&&i&&i>534.13&&!o?!0:!1}();this._createPrereqs(e.noop,e.noop,e.proxy(this,"_openPrereqsComplete")),this._currentTransition=i.transition,this._applyTransition(i.transition),this.options.theme||this._setTheme(this._page.jqmData("theme")||e.mobile.getInheritedTheme(this._page,"c")),this._ui.screen.removeClass("ui-screen-hidden"),this._ui.container.removeClass("ui-popup-hidden"),this._reposition(i),this.options.overlayTheme&&n&&this.element.closest(".ui-page").addClass("ui-popup-open"),this._animate({
additionalCondition:!0,transition:i.transition,classToRemove:"",screenClassToAdd:"in",containerClassToAdd:"in",applyTransition:!1,prereqs:this._prereqs})},_closePrereqScreen:function(){this._ui.screen.removeClass("out").addClass("ui-screen-hidden")},_closePrereqContainer:function(){this._ui.container.removeClass("reverse out").addClass("ui-popup-hidden").removeAttr("style")},_closePrereqsDone:function(){this.options,this._ui.container.removeAttr("tabindex"),e.mobile.popup.active=n,this._trigger("afterclose")},_close:function(t){this._ui.container.removeClass("ui-popup-active"),this._page.removeClass("ui-popup-open"),this._isOpen=!1,this._createPrereqs(e.proxy(this,"_closePrereqScreen"),e.proxy(this,"_closePrereqContainer"),e.proxy(this,"_closePrereqsDone")),this._animate({additionalCondition:this._ui.screen.hasClass("in"),transition:t?"none":this._currentTransition,classToRemove:"in",screenClassToAdd:"out",containerClassToAdd:"reverse out",applyTransition:!0,prereqs:this._pr
ereqs})},_unenhance:function(){this._setTheme("none"),this.element.detach().insertAfter(this._ui.placeholder).removeClass("ui-popup ui-overlay-shadow ui-corner-all"),this._ui.screen.remove(),this._ui.container.remove(),this._ui.placeholder.remove()},_destroy:function(){e.mobile.popup.active===this?(this.element.one("popupafterclose",e.proxy(this,"_unenhance")),this.close()):this._unenhance()},_closePopup:function(i,n){var a,o,s=this.options,r=!1;t.scrollTo(0,this._scrollTop),i&&"pagebeforechange"===i.type&&n&&(a="string"==typeof n.toPage?n.toPage:n.toPage.jqmData("url"),a=e.mobile.path.parseUrl(a),o=a.pathname+a.search+a.hash,this._myUrl!==e.mobile.path.makeUrlAbsolute(o)?r=!0:i.preventDefault()),s.container.unbind(s.closeEvents),this.element.undelegate(s.closeLinkSelector,s.closeLinkEvents),this._close(r)},_bindContainerClose:function(){this.options.container.one(this.options.closeEvents,e.proxy(this,"_closePopup"))},open:function(i){var a,o,s,r,l,d,c=this,h=this.options;if
(!e.mobile.popup.active){if(e.mobile.popup.active=this,this._scrollTop=e.mobile.window.scrollTop(),!h.history)return c._open(i),c._bindContainerClose(),c.element.delegate(h.closeLinkSelector,h.closeLinkEvents,function(e){c.close(),e.preventDefault()}),n;if(d=e.mobile.urlHistory,o=e.mobile.dialogHashKey,s=e.mobile.activePage,r=s.is(".ui-dialog"),this._myUrl=a=d.getActive().url,l=a.indexOf(o)>-1&&!r&&d.activeIndex>0)return c._open(i),c._bindContainerClose(),n;-1!==a.indexOf(o)||r?a=e.mobile.path.parseLocation().hash+o:a+=a.indexOf("#")>-1?o:"#"+o,0===d.activeIndex&&a===d.initialDst&&(a+=o),e(t).one("beforenavigate",function(e){e.preventDefault(),c._open(i),c._bindContainerClose()}),this.urlAltered=!0,e.mobile.navigate(a,{role:"dialog"})}},close:function(){e.mobile.popup.active===this&&(this._scrollTop=e.mobile.window.scrollTop(),this.options.history&&this.urlAltered?(e.mobile.back(),this.urlAltered=!1):this._closePopup())}}),e.mobile.popup.handleLink=function(t){var i,n=t.clos
est(":jqmData(role='page')"),a=0===n.length?e("body"):n,o=e(e.mobile.path.parseUrl(t.attr("href")).hash,a[0]);o.data("mobile-popup")&&(i=t.offset(),o.popup("open",{x:i.left+t.outerWidth()/2,y:i.top+t.outerHeight()/2,transition:t.jqmData("transition"),positionTo:t.jqmData("position-to")})),setTimeout(function(){var i=t.parent().parent();i.hasClass("ui-li")&&(t=i.parent()),t.removeClass(e.mobile.activeBtnClass)},300)},e.mobile.document.bind("pagebeforechange",function(t,i){"popup"===i.options.role&&(e.mobile.popup.handleLink(i.options.link),t.preventDefault())}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.popup.prototype.enhanceWithin(t.target,!0)})}(e),function(e,t){var n=function(n){var a,o,s,r=(n.select,n._destroy),l=n.selectID,d=l?l:(e.mobile.ns||"")+"uuid-"+n.uuid,c=d+"-listbox",h=d+"-dialog",u=n.label,p=n.select.closest(".ui-page"),m=n._selectOptions(),f=n.isMultiple=n.select[0].multiple,g=l+"-button",b=l+"-menu",v=e("<div data-"+e.mobile.ns+"role='di
alog' id='"+h+"' data-"+e.mobile.ns+"theme='"+n.options.theme+"' data-"+e.mobile.ns+"overlay-theme='"+n.options.overlayTheme+"'>"+"<div data-"+e.mobile.ns+"role='header'>"+"<div class='ui-title'>"+u.getEncodedText()+"</div>"+"</div>"+"<div data-"+e.mobile.ns+"role='content'></div>"+"</div>"),_=e("<div id='"+c+"' class='ui-selectmenu'>").insertAfter(n.select).popup({theme:n.options.overlayTheme}),C=e("<ul>",{"class":"ui-selectmenu-list",id:b,role:"listbox","aria-labelledby":g}).attr("data-"+e.mobile.ns+"theme",n.options.theme).attr("data-"+e.mobile.ns+"divider-theme",n.options.dividerTheme).appendTo(_),x=e("<div>",{"class":"ui-header ui-bar-"+n.options.theme}).prependTo(_),y=e("<h1>",{"class":"ui-title"}).appendTo(x);n.isMultiple&&(s=e("<a>",{text:n.options.closeText,href:"#","class":"ui-btn-left"}).attr("data-"+e.mobile.ns+"iconpos","notext").attr("data-"+e.mobile.ns+"icon","delete").appendTo(x).buttonMarkup()),e.extend(n,{select:n.select,selectID:l,buttonId:g,menuId:b,popup
ID:c,dialogID:h,thisPage:p,menuPage:v,label:u,selectOptions:m,isMultiple:f,theme:n.options.theme,listbox:_,list:C,header:x,headerTitle:y,headerClose:s,menuPageContent:a,menuPageClose:o,placeholder:"",build:function(){var i=this;i.refresh(),i._origTabIndex===t&&(i._origTabIndex=null===i.select[0].getAttribute("tabindex")?!1:i.select.attr("tabindex")),i.select.attr("tabindex","-1").focus(function(){e(this).blur(),i.button.focus()}),i.button.bind("vclick keydown",function(t){i.options.disabled||i.isOpen||("vclick"===t.type||t.keyCode&&(t.keyCode===e.mobile.keyCode.ENTER||t.keyCode===e.mobile.keyCode.SPACE))&&(i._decideFormat(),"overlay"===i.menuType?i.button.attr("href","#"+i.popupID).attr("data-"+(e.mobile.ns||"")+"rel","popup"):i.button.attr("href","#"+i.dialogID).attr("data-"+(e.mobile.ns||"")+"rel","dialog"),i.isOpen=!0)}),i.list.attr("role","listbox").bind("focusin",function(t){e(t.target).attr("tabindex","0").trigger("vmouseover")}).bind("focusout",function(t){e(t.target)
.attr("tabindex","-1").trigger("vmouseout")}).delegate("li:not(.ui-disabled, .ui-li-divider)","click",function(t){var a=i.select[0].selectedIndex,o=i.list.find("li:not(.ui-li-divider)").index(this),s=i._selectOptions().eq(o)[0];s.selected=i.isMultiple?!s.selected:!0,i.isMultiple&&e(this).find(".ui-icon").toggleClass("ui-icon-checkbox-on",s.selected).toggleClass("ui-icon-checkbox-off",!s.selected),(i.isMultiple||a!==o)&&i.select.trigger("change"),i.isMultiple?i.list.find("li:not(.ui-li-divider)").eq(o).addClass("ui-btn-down-"+n.options.theme).find("a").first().focus():i.close(),t.preventDefault()}).keydown(function(t){var i,a,o=e(t.target),s=o.closest("li");switch(t.keyCode){case 38:return i=s.prev().not(".ui-selectmenu-placeholder"),i.is(".ui-li-divider")&&(i=i.prev()),i.length&&(o.blur().attr("tabindex","-1"),i.addClass("ui-btn-down-"+n.options.theme).find("a").first().focus()),!1;case 40:return a=s.next(),a.is(".ui-li-divider")&&(a=a.next()),a.length&&(o.blur().attr("tabin
dex","-1"),a.addClass("ui-btn-down-"+n.options.theme).find("a").first().focus()),!1;case 13:case 32:return o.trigger("click"),!1}}),i.menuPage.bind("pagehide",function(){e.mobile._bindPageRemove.call(i.thisPage)}),i.listbox.bind("popupafterclose",function(){i.close()}),i.isMultiple&&i.headerClose.click(function(){return"overlay"===i.menuType?(i.close(),!1):t}),i.thisPage.addDependents(this.menuPage)},_isRebuildRequired:function(){var e=this.list.find("li"),t=this._selectOptions();return t.text()!==e.text()},selected:function(){return this._selectOptions().filter(":selected:not( :jqmData(placeholder='true') )")},refresh:function(t){var i,n=this;this.element,this.isMultiple,(t||this._isRebuildRequired())&&n._buildList(),i=this.selectedIndices(),n.setButtonText(),n.setButtonCount(),n.list.find("li:not(.ui-li-divider)").removeClass(e.mobile.activeBtnClass).attr("aria-selected",!1).each(function(t){if(e.inArray(t,i)>-1){var a=e(this);a.attr("aria-selected",!0),n.isMultiple?a.find
(".ui-icon").removeClass("ui-icon-checkbox-off").addClass("ui-icon-checkbox-on"):a.is(".ui-selectmenu-placeholder")?a.next().addClass(e.mobile.activeBtnClass):a.addClass(e.mobile.activeBtnClass)}})},close:function(){if(!this.options.disabled&&this.isOpen){var e=this;"page"===e.menuType?(e.menuPage.dialog("close"),e.list.appendTo(e.listbox)):e.listbox.popup("close"),e._focusButton(),e.isOpen=!1}},open:function(){this.button.click()},_decideFormat:function(){function t(){var t=i.list.find("."+e.mobile.activeBtnClass+" a");0===t.length&&(t=i.list.find("li.ui-btn:not( :jqmData(placeholder='true') ) a")),t.first().focus().closest("li").addClass("ui-btn-down-"+n.options.theme)}var i=this,a=e.mobile.window,o=i.list.parent(),s=o.outerHeight(),r=(o.outerWidth(),e("."+e.mobile.activePageClass),a.scrollTop()),l=i.button.offset().top,d=a.height();a.width(),s>d-80||!e.support.scrollTop?(i.menuPage.appendTo(e.mobile.pageContainer).page(),i.menuPageContent=v.find(".ui-content"),i.menuPageC
lose=v.find(".ui-header a"),i.thisPage.unbind("pagehide.remove"),0===r&&l>d&&i.thisPage.one("pagehide",function(){e(this).jqmData("lastScroll",l)}),i.menuPage.one("pageshow",function(){t()}).one("pagehide",function(){i.close()}),i.menuType="page",i.menuPageContent.append(i.list),i.menuPage.find("div .ui-title").text(i.label.text())):(i.menuType="overlay",i.listbox.one("popupafteropen",t))},_buildList:function(){var t=this,n=this.options,a=this.placeholder,o=!0,s=t.isMultiple?"checkbox-off":"false";t.list.empty().filter(".ui-listview").listview("destroy");for(var r,l=t.select.find("option"),d=l.length,c=this.select[0],h="data-"+e.mobile.ns,u=h+"option-index",p=h+"icon",m=h+"role",f=h+"placeholder",g=i.createDocumentFragment(),b=!1,v=0;d>v;v++,b=!1){var _=l[v],C=e(_),x=_.parentNode,y=C.text(),w=i.createElement("a"),T=[];if(w.setAttribute("href","#"),w.appendChild(i.createTextNode(y)),x!==c&&"optgroup"===x.nodeName.toLowerCase()){var D=x.getAttribute("label");if(D!==r){var P=i.
createElement("li");P.setAttribute(m,"list-divider"),P.setAttribute("role","option"),P.setAttribute("tabindex","-1"),P.appendChild(i.createTextNode(D)),g.appendChild(P),r=D}}!o||_.getAttribute("value")&&0!==y.length&&!C.jqmData("placeholder")||(o=!1,b=!0,null===_.getAttribute(f)&&(this._removePlaceholderAttr=!0),_.setAttribute(f,!0),n.hidePlaceholderMenuItems&&T.push("ui-selectmenu-placeholder"),a!==y&&(a=t.placeholder=y));var k=i.createElement("li");_.disabled&&(T.push("ui-disabled"),k.setAttribute("aria-disabled",!0)),k.setAttribute(u,v),k.setAttribute(p,s),b&&k.setAttribute(f,!0),k.className=T.join(" "),k.setAttribute("role","option"),w.setAttribute("tabindex","-1"),k.appendChild(w),g.appendChild(k)}t.list[0].appendChild(g),this.isMultiple||a.length?this.headerTitle.text(this.placeholder):this.header.hide(),t.list.listview()},_button:function(){return e("<a>",{href:"#",role:"button",id:this.buttonId,"aria-haspopup":"true","aria-owns":this.menuId})},_destroy:function(){thi
s.close(),this._origTabIndex!==t&&(this._origTabIndex!==!1?this.select.attr("tabindex",this._origTabIndex):this.select.removeAttr("tabindex")),this._removePlaceholderAttr&&this._selectOptions().removeAttr("data-"+e.mobile.ns+"placeholder"),this.listbox.remove(),r.apply(this,arguments)}})};e.mobile.document.bind("selectmenubeforecreate",function(t){var i=e(t.target).data("mobile-selectmenu");i.options.nativeMenu||0!==i.element.parents(":jqmData(role='popup')").length||n(i)})}(e),function(e,t){e.widget("mobile.controlgroup",e.mobile.widget,e.extend({options:{shadow:!1,corners:!0,excludeInvisible:!0,type:"vertical",mini:!1,initSelector:":jqmData(role='controlgroup')"},_create:function(){var i=this.element,n={inner:e("<div class='ui-controlgroup-controls'></div>"),legend:e("<div role='heading' class='ui-controlgroup-label'></div>")},a=i.children("legend"),o=this;i.wrapInner(n.inner),a.length&&n.legend.append(a).insertBefore(i.children(0)),i.addClass("ui-corner-all ui-controlgrou
p"),e.extend(this,{_initialRefresh:!0}),e.each(this.options,function(e,i){o.options[e]=t,o._setOption(e,i,!0)})},_init:function(){this.refresh()},_setOption:function(i,n){var a="_set"+i.charAt(0).toUpperCase()+i.slice(1);this[a]!==t&&this[a](n),this._super(i,n),this.element.attr("data-"+(e.mobile.ns||"")+i.replace(/([A-Z])/,"-$1").toLowerCase(),n)},_setType:function(e){this.element.removeClass("ui-controlgroup-horizontal ui-controlgroup-vertical").addClass("ui-controlgroup-"+e),this.refresh()},_setCorners:function(e){this.element.toggleClass("ui-corner-all",e)},_setShadow:function(e){this.element.toggleClass("ui-shadow",e)},_setMini:function(e){this.element.toggleClass("ui-mini",e)},container:function(){return this.element.children(".ui-controlgroup-controls")},refresh:function(){var t=this.element.find(".ui-btn").not(".ui-slider-handle"),i=this._initialRefresh;e.mobile.checkboxradio&&this.element.find(":mobile-checkboxradio").checkboxradio("refresh"),this._addFirstLastClass
es(t,this.options.excludeInvisible?this._getVisibles(t,i):t,i),this._initialRefresh=!1}},e.mobile.behaviors.addFirstLastClasses)),e(function(){e.mobile.document.bind("pagecreate create",function(t){e.mobile.controlgroup.prototype.enhanceWithin(t.target,!0)})})}(e),function(e){e(i).bind("pagecreate create",function(t){e(t.target).find("a").jqmEnhanceable().not(".ui-btn, .ui-link-inherit, :jqmData(role='none'), :jqmData(role='nojs')").addClass("ui-link")})}(e),function(e,t){e.widget("mobile.fixedtoolbar",e.mobile.widget,{options:{visibleOnPageShow:!0,disablePageZoom:!0,transition:"slide",fullscreen:!1,tapToggle:!0,tapToggleBlacklist:"a, button, input, select, textarea, .ui-header-fixed, .ui-footer-fixed, .ui-popup, .ui-panel, .ui-panel-dismiss-open",hideDuringFocus:"input, textarea, select",updatePagePadding:!0,trackPersistentToolbars:!0,supportBlacklist:function(){return!e.support.fixedPosition},initSelector:":jqmData(position='fixed')"},_create:function(){var i=this,n=i.opti
ons,a=i.element,o=a.is(":jqmData(role='header')")?"header":"footer",s=a.closest(".ui-page");return n.supportBlacklist()?(i.destroy(),t):(a.addClass("ui-"+o+"-fixed"),n.fullscreen?(a.addClass("ui-"+o+"-fullscreen"),s.addClass("ui-page-"+o+"-fullscreen")):s.addClass("ui-page-"+o+"-fixed"),e.extend(this,{_thisPage:null}),i._addTransitionClass(),i._bindPageEvents(),i._bindToggleHandlers(),t)},_addTransitionClass:function(){var e=this.options.transition;e&&"none"!==e&&("slide"===e&&(e=this.element.is(".ui-header")?"slidedown":"slideup"),this.element.addClass(e))},_bindPageEvents:function(){this._thisPage=this.element.closest(".ui-page"),this._on(this._thisPage,{pagebeforeshow:"_handlePageBeforeShow",webkitAnimationStart:"_handleAnimationStart",animationstart:"_handleAnimationStart",updatelayout:"_handleAnimationStart",pageshow:"_handlePageShow",pagebeforehide:"_handlePageBeforeHide"})},_handlePageBeforeShow:function(){var t=this.options;t.disablePageZoom&&e.mobile.zoom.disable(!0
),t.visibleOnPageShow||this.hide(!0)},_handleAnimationStart:function(){this.options.updatePagePadding&&this.updatePagePadding(this._thisPage)},_handlePageShow:function(){this.updatePagePadding(this._thisPage),this.options.updatePagePadding&&this._on(e.mobile.window,{throttledresize:"updatePagePadding"})},_handlePageBeforeHide:function(t,i){var n=this.options;if(n.disablePageZoom&&e.mobile.zoom.enable(!0),n.updatePagePadding&&this._off(e.mobile.window,"throttledresize"),n.trackPersistentToolbars){var a=e(".ui-footer-fixed:jqmData(id)",this._thisPage),o=e(".ui-header-fixed:jqmData(id)",this._thisPage),s=a.length&&i.nextPage&&e(".ui-footer-fixed:jqmData(id='"+a.jqmData("id")+"')",i.nextPage)||e(),r=o.length&&i.nextPage&&e(".ui-header-fixed:jqmData(id='"+o.jqmData("id")+"')",i.nextPage)||e();(s.length||r.length)&&(s.add(r).appendTo(e.mobile.pageContainer),i.nextPage.one("pageshow",function(){r.prependTo(this),s.appendTo(this)}))}},_visible:!0,updatePagePadding:function(i){var n=
this.element,a=n.is(".ui-header"),o=parseFloat(n.css(a?"top":"bottom"));this.options.fullscreen||(i=i&&i.type===t&&i||this._thisPage||n.closest(".ui-page"),e(i).css("padding-"+(a?"top":"bottom"),n.outerHeight()+o))},_useTransition:function(t){var i=e.mobile.window,n=this.element,a=i.scrollTop(),o=n.height(),s=n.closest(".ui-page").height(),r=e.mobile.getScreenHeight(),l=n.is(":jqmData(role='header')")?"header":"footer";return!t&&(this.options.transition&&"none"!==this.options.transition&&("header"===l&&!this.options.fullscreen&&a>o||"footer"===l&&!this.options.fullscreen&&s-o>a+r)||this.options.fullscreen)},show:function(e){var t="ui-fixed-hidden",i=this.element;this._useTransition(e)?i.removeClass("out "+t).addClass("in").animationComplete(function(){i.removeClass("in")}):i.removeClass(t),this._visible=!0},hide:function(e){var t="ui-fixed-hidden",i=this.element,n="out"+("slide"===this.options.transition?" reverse":"");this._useTransition(e)?i.addClass(n).removeClass("in").a
nimationComplete(function(){i.addClass(t).removeClass(n)}):i.addClass(t).removeClass(n),this._visible=!1},toggle:function(){this[this._visible?"hide":"show"]()},_bindToggleHandlers:function(){var t,i,n=this,a=n.options,o=n.element,s=!0;o.closest(".ui-page").bind("vclick",function(t){a.tapToggle&&!e(t.target).closest(a.tapToggleBlacklist).length&&n.toggle()}).bind("focusin focusout",function(o){1025>screen.width&&e(o.target).is(a.hideDuringFocus)&&!e(o.target).closest(".ui-header-fixed, .ui-footer-fixed").length&&("focusout"!==o.type||s?"focusin"===o.type&&s&&(clearTimeout(t),s=!1,i=setTimeout(function(){n.hide()},0)):(s=!0,clearTimeout(i),t=setTimeout(function(){n.show()},0)))})},_destroy:function(){var e=this.element,t=e.is(".ui-header");e.closest(".ui-page").css("padding-"+(t?"top":"bottom"),""),e.removeClass("ui-header-fixed ui-footer-fixed ui-header-fullscreen ui-footer-fullscreen in out fade slidedown slideup ui-fixed-hidden"),e.closest(".ui-page").removeClass("ui-page-
header-fixed ui-page-footer-fixed ui-page-header-fullscreen ui-page-footer-fullscreen")}}),e.mobile.document.bind("pagecreate create",function(t){e(t.target).jqmData("fullscreen")&&e(e.mobile.fixedtoolbar.prototype.options.initSelector,t.target).not(":jqmData(fullscreen)").jqmData("fullscreen",!0),e.mobile.fixedtoolbar.prototype.enhanceWithin(t.target)})}(e),function(e){e.widget("mobile.fixedtoolbar",e.mobile.fixedtoolbar,{_create:function(){this._super(),this._workarounds()},_workarounds:function(){var e=navigator.userAgent,t=navigator.platform,i=e.match(/AppleWebKit\/([0-9]+)/),n=!!i&&i[1],a=null,o=this;if(t.indexOf("iPhone")>-1||t.indexOf("iPad")>-1||t.indexOf("iPod")>-1)a="ios";else{if(!(e.indexOf("Android")>-1))return;a="android"}if("ios"===a)o._bindScrollWorkaround();else{if(!("android"===a&&n&&534>n))return;o._bindScrollWorkaround(),o._bindListThumbWorkaround()}},_viewportOffset:function(){var t=this.element,i=t.is(".ui-header"),n=Math.abs(t.offset().top-e.mobile.wind
ow.scrollTop());return i||(n=Math.round(n-e.mobile.window.height()+t.outerHeight())-60),n},_bindScrollWorkaround:function(){var t=this;this._on(e.mobile.window,{scrollstop:function(){var e=t._viewportOffset();e>2&&t._visible&&t._triggerRedraw()}})},_bindListThumbWorkaround:function(){this.element.closest(".ui-page").addClass("ui-android-2x-fixed")},_triggerRedraw:function(){var t=parseFloat(e(".ui-page-active").css("padding-bottom"));
+e(".ui-page-active").css("padding-bottom",t+1+"px"),setTimeout(function(){e(".ui-page-active").css("padding-bottom",t+"px")},0)},destroy:function(){this._super(),this.element.closest(".ui-page-active").removeClass("ui-android-2x-fix")}})}(e),function(e,n){e.widget("mobile.panel",e.mobile.widget,{options:{classes:{panel:"ui-panel",panelOpen:"ui-panel-open",panelClosed:"ui-panel-closed",panelFixed:"ui-panel-fixed",panelInner:"ui-panel-inner",modal:"ui-panel-dismiss",modalOpen:"ui-panel-dismiss-open",pagePanel:"ui-page-panel",pagePanelOpen:"ui-page-panel-open",contentWrap:"ui-panel-content-wrap",contentWrapOpen:"ui-panel-content-wrap-open",contentWrapClosed:"ui-panel-content-wrap-closed",contentFixedToolbar:"ui-panel-content-fixed-toolbar",contentFixedToolbarOpen:"ui-panel-content-fixed-toolbar-open",contentFixedToolbarClosed:"ui-panel-content-fixed-toolbar-closed",animate:"ui-panel-animate"},animate:!0,theme:"c",position:"left",dismissible:!0,display:"reveal",initSelector:":jq
mData(role='panel')",swipeClose:!0,positionFixed:!1},_panelID:null,_closeLink:null,_page:null,_modal:null,_panelInner:null,_wrapper:null,_fixedToolbar:null,_create:function(){var t=this,i=t.element,n=i.closest(":jqmData(role='page')"),a=function(){var t=e.data(n[0],"mobilePage").options.theme,i="ui-body-"+t;return i},o=function(){var e=i.find("."+t.options.classes.panelInner);return 0===e.length&&(e=i.children().wrapAll('<div class="'+t.options.classes.panelInner+'" />').parent()),e},s=function(){var i=n.find("."+t.options.classes.contentWrap);return 0===i.length&&(i=n.children(".ui-header:not(:jqmData(position='fixed')), .ui-content:not(:jqmData(role='popup')), .ui-footer:not(:jqmData(position='fixed'))").wrapAll('<div class="'+t.options.classes.contentWrap+" "+a()+'" />').parent(),e.support.cssTransform3d&&t.options.animate&&i.addClass(t.options.classes.animate)),i},r=function(){var i=n.find("."+t.options.classes.contentFixedToolbar);return 0===i.length&&(i=n.find(".ui-hea
der:jqmData(position='fixed'), .ui-footer:jqmData(position='fixed')").addClass(t.options.classes.contentFixedToolbar),e.support.cssTransform3d&&t.options.animate&&i.addClass(t.options.classes.animate)),i};e.extend(this,{_panelID:i.attr("id"),_closeLink:i.find(":jqmData(rel='close')"),_page:i.closest(":jqmData(role='page')"),_pageTheme:a(),_panelInner:o(),_wrapper:s(),_fixedToolbar:r()}),t._addPanelClasses(),t._wrapper.addClass(this.options.classes.contentWrapClosed),t._fixedToolbar.addClass(this.options.classes.contentFixedToolbarClosed),t._page.addClass(t.options.classes.pagePanel),e.support.cssTransform3d&&t.options.animate&&this.element.addClass(t.options.classes.animate),t._bindUpdateLayout(),t._bindCloseEvents(),t._bindLinkListeners(),t._bindPageEvents(),t.options.dismissible&&t._createModal(),t._bindSwipeEvents()},_createModal:function(){var t=this;t._modal=e("<div class='"+t.options.classes.modal+"' data-panelid='"+t._panelID+"'></div>").on("mousedown",function(){t.cl
ose()}).appendTo(this._page)},_getPosDisplayClasses:function(e){return e+"-position-"+this.options.position+" "+e+"-display-"+this.options.display},_getPanelClasses:function(){var e=this.options.classes.panel+" "+this._getPosDisplayClasses(this.options.classes.panel)+" "+this.options.classes.panelClosed;return this.options.theme&&(e+=" ui-body-"+this.options.theme),this.options.positionFixed&&(e+=" "+this.options.classes.panelFixed),e},_addPanelClasses:function(){this.element.addClass(this._getPanelClasses())},_bindCloseEvents:function(){var e=this;e._closeLink.on("click.panel",function(t){return t.preventDefault(),e.close(),!1}),e.element.on("click.panel","a:jqmData(ajax='false')",function(){e.close()})},_positionPanel:function(){var t=this,i=t._panelInner.outerHeight(),n=i>e.mobile.getScreenHeight();n||!t.options.positionFixed?(n&&(t._unfixPanel(),e.mobile.resetActivePageHeight(i)),t._scrollIntoView(i)):t._fixPanel()},_scrollIntoView:function(i){e(t).scrollTop()>i&&t.scrol
lTo(0,0)},_bindFixListener:function(){this._on(e(t),{throttledresize:"_positionPanel"})},_unbindFixListener:function(){this._off(e(t),"throttledresize")},_unfixPanel:function(){this.options.positionFixed&&e.support.fixedPosition&&this.element.removeClass(this.options.classes.panelFixed)},_fixPanel:function(){this.options.positionFixed&&e.support.fixedPosition&&this.element.addClass(this.options.classes.panelFixed)},_bindUpdateLayout:function(){var e=this;e.element.on("updatelayout",function(){e._open&&e._positionPanel()})},_bindLinkListeners:function(){var t=this;t._page.on("click.panel","a",function(i){if(this.href.split("#")[1]===t._panelID&&t._panelID!==n){i.preventDefault();var a=e(this);return a.hasClass("ui-link")||(a.addClass(e.mobile.activeBtnClass),t.element.one("panelopen panelclose",function(){a.removeClass(e.mobile.activeBtnClass)})),t.toggle(),!1}})},_bindSwipeEvents:function(){var e=this,t=e._modal?e.element.add(e._modal):e.element;e.options.swipeClose&&("left"
===e.options.position?t.on("swipeleft.panel",function(){e.close()}):t.on("swiperight.panel",function(){e.close()}))},_bindPageEvents:function(){var e=this;e._page.on("panelbeforeopen",function(t){e._open&&t.target!==e.element[0]&&e.close()}).on("pagehide",function(){e._open&&e.close(!0)}).on("keyup.panel",function(t){27===t.keyCode&&e._open&&e.close()})},_open:!1,_contentWrapOpenClasses:null,_fixedToolbarOpenClasses:null,_modalOpenClasses:null,open:function(t){if(!this._open){var i=this,n=i.options,a=function(){i._page.off("panelclose"),i._page.jqmData("panel","open"),!t&&e.support.cssTransform3d&&n.animate?i.element.add(i._wrapper).on(i._transitionEndEvents,o):setTimeout(o,0),i.options.theme&&"overlay"!==i.options.display&&i._page.removeClass(i._pageTheme).addClass("ui-body-"+i.options.theme),i.element.removeClass(n.classes.panelClosed).addClass(n.classes.panelOpen),i._positionPanel(),i.options.theme&&"overlay"!==i.options.display&&i._wrapper.css("min-height",i._page.css("m
in-height")),i._contentWrapOpenClasses=i._getPosDisplayClasses(n.classes.contentWrap),i._wrapper.removeClass(n.classes.contentWrapClosed).addClass(i._contentWrapOpenClasses+" "+n.classes.contentWrapOpen),i._fixedToolbarOpenClasses=i._getPosDisplayClasses(n.classes.contentFixedToolbar),i._fixedToolbar.removeClass(n.classes.contentFixedToolbarClosed).addClass(i._fixedToolbarOpenClasses+" "+n.classes.contentFixedToolbarOpen),i._modalOpenClasses=i._getPosDisplayClasses(n.classes.modal)+" "+n.classes.modalOpen,i._modal&&i._modal.addClass(i._modalOpenClasses)},o=function(){i.element.add(i._wrapper).off(i._transitionEndEvents,o),i._page.addClass(n.classes.pagePanelOpen),i._bindFixListener(),i._trigger("open")};0>this.element.closest(".ui-page-active").length&&(t=!0),i._trigger("beforeopen"),"open"===i._page.jqmData("panel")?i._page.on("panelclose",function(){a()}):a(),i._open=!0}},close:function(t){if(this._open){var i=this.options,n=this,a=function(){!t&&e.support.cssTransform3d&&
i.animate?n.element.add(n._wrapper).on(n._transitionEndEvents,o):setTimeout(o,0),n._page.removeClass(i.classes.pagePanelOpen),n.element.removeClass(i.classes.panelOpen),n._wrapper.removeClass(i.classes.contentWrapOpen),n._fixedToolbar.removeClass(i.classes.contentFixedToolbarOpen),n._modal&&n._modal.removeClass(n._modalOpenClasses)},o=function(){n.options.theme&&"overlay"!==n.options.display&&(n._page.removeClass("ui-body-"+n.options.theme).addClass(n._pageTheme),n._wrapper.css("min-height","")),n.element.add(n._wrapper).off(n._transitionEndEvents,o),n.element.addClass(i.classes.panelClosed),n._wrapper.removeClass(n._contentWrapOpenClasses).addClass(i.classes.contentWrapClosed),n._fixedToolbar.removeClass(n._fixedToolbarOpenClasses).addClass(i.classes.contentFixedToolbarClosed),n._fixPanel(),n._unbindFixListener(),e.mobile.resetActivePageHeight(),n._page.jqmRemoveData("panel"),n._trigger("close")};0>this.element.closest(".ui-page-active").length&&(t=!0),n._trigger("beforeclo
se"),a(),n._open=!1}},toggle:function(){this[this._open?"close":"open"]()},_transitionEndEvents:"webkitTransitionEnd oTransitionEnd otransitionend transitionend msTransitionEnd",_destroy:function(){var t=this.options.classes,i=this.options.theme,n=this.element.siblings("."+t.panel).length;n?this._open&&(this._wrapper.removeClass(t.contentWrapOpen),this._fixedToolbar.removeClass(t.contentFixedToolbarOpen),this._page.jqmRemoveData("panel"),this._page.removeClass(t.pagePanelOpen),i&&this._page.removeClass("ui-body-"+i).addClass(this._pageTheme)):(this._wrapper.children().unwrap(),this._page.find("a").unbind("panelopen panelclose"),this._page.removeClass(t.pagePanel),this._open&&(this._page.jqmRemoveData("panel"),this._page.removeClass(t.pagePanelOpen),i&&this._page.removeClass("ui-body-"+i).addClass(this._pageTheme),e.mobile.resetActivePageHeight())),this._panelInner.children().unwrap(),this.element.removeClass([this._getPanelClasses(),t.panelAnimate].join(" ")).off("swipeleft.
panel swiperight.panel").off("panelbeforeopen").off("panelhide").off("keyup.panel").off("updatelayout"),this._closeLink.off("click.panel"),this._modal&&this._modal.remove(),this.element.off(this._transitionEndEvents).removeClass([t.panelUnfixed,t.panelClosed,t.panelOpen].join(" "))}}),e(i).bind("pagecreate create",function(t){e.mobile.panel.prototype.enhanceWithin(t.target)})}(e),function(e,t){e.widget("mobile.table",e.mobile.widget,{options:{classes:{table:"ui-table"},initSelector:":jqmData(role='table')"},_create:function(){var e=this;e.refresh(!0)},refresh:function(i){var n=this,a=this.element.find("thead tr");i&&this.element.addClass(this.options.classes.table),n.headers=this.element.find("tr:eq(0)").children(),n.allHeaders=n.headers.add(a.children()),a.each(function(){var o=0;e(this).children().each(function(){var s=parseInt(e(this).attr("colspan"),10),r=":nth-child("+(o+1)+")";if(e(this).jqmData("colstart",o+1),s)for(var l=0;s-1>l;l++)o++,r+=", :nth-child("+(o+1)+")";i
===t&&e(this).jqmData("cells",""),e(this).jqmData("cells",n.element.find("tr").not(a.eq(0)).not(this).children(r)),o++})}),i===t&&this.element.trigger("refresh")}}),e.mobile.document.bind("pagecreate create",function(t){e.mobile.table.prototype.enhanceWithin(t.target)})}(e),function(e,t){e.mobile.table.prototype.options.mode="columntoggle",e.mobile.table.prototype.options.columnBtnTheme=null,e.mobile.table.prototype.options.columnPopupTheme=null,e.mobile.table.prototype.options.columnBtnText="Columns...",e.mobile.table.prototype.options.classes=e.extend(e.mobile.table.prototype.options.classes,{popup:"ui-table-columntoggle-popup",columnBtn:"ui-table-columntoggle-btn",priorityPrefix:"ui-table-priority-",columnToggleTable:"ui-table-columntoggle"}),e.mobile.document.delegate(":jqmData(role='table')","tablecreate refresh",function(i){var n,a,o,s,r=e(this),l=r.data("mobile-table"),d=i.type,c=l.options,h=e.mobile.ns,u=(r.attr("id")||c.classes.popup)+"-popup";"columntoggle"===c.mod
e&&("refresh"!==d&&(l.element.addClass(c.classes.columnToggleTable),n=e("<a href='#"+u+"' class='"+c.classes.columnBtn+"' data-"+h+"rel='popup' data-"+h+"mini='true'>"+c.columnBtnText+"</a>"),a=e("<div data-"+h+"role='popup' data-"+h+"role='fieldcontain' class='"+c.classes.popup+"' id='"+u+"'></div>"),o=e("<fieldset data-"+h+"role='controlgroup'></fieldset>")),l.headers.not("td").each(function(t){var i=e(this).jqmData("priority"),n=e(this).add(e(this).jqmData("cells"));i&&(n.addClass(c.classes.priorityPrefix+i),"refresh"!==d?e("<label><input type='checkbox' checked />"+e(this).text()+"</label>").appendTo(o).children(0).jqmData("cells",n).checkboxradio({theme:c.columnPopupTheme}):e("#"+u+" fieldset div:eq("+t+")").find("input").jqmData("cells",n))}),"refresh"!==d&&o.appendTo(a),s=o===t?e("#"+u+" fieldset"):o,"refresh"!==d&&(s.on("change","input",function(){this.checked?e(this).jqmData("cells").removeClass("ui-table-cell-hidden").addClass("ui-table-cell-visible"):e(this).jqmDa
ta("cells").removeClass("ui-table-cell-visible").addClass("ui-table-cell-hidden")}),n.insertBefore(r).buttonMarkup({theme:c.columnBtnTheme}),a.insertBefore(r).popup()),l.update=function(){s.find("input").each(function(){this.checked?(this.checked="table-cell"===e(this).jqmData("cells").eq(0).css("display"),"refresh"===d&&e(this).jqmData("cells").addClass("ui-table-cell-visible")):e(this).jqmData("cells").addClass("ui-table-cell-hidden"),e(this).checkboxradio("refresh")})},e.mobile.window.on("throttledresize",l.update),l.update())})}(e),function(e){e.mobile.table.prototype.options.mode="reflow",e.mobile.table.prototype.options.classes=e.extend(e.mobile.table.prototype.options.classes,{reflowTable:"ui-table-reflow",cellLabels:"ui-table-cell-label"}),e.mobile.document.delegate(":jqmData(role='table')","tablecreate refresh",function(t){var i=e(this),n=t.type,a=i.data("mobile-table"),o=a.options;if("reflow"===o.mode){"refresh"!==n&&a.element.addClass(o.classes.reflowTable);var s=
e(a.allHeaders.get().reverse());s.each(function(){var t=e(this).jqmData("cells"),i=e(this).jqmData("colstart"),n=t.not(this).filter("thead th").length&&" ui-table-cell-label-top",a=e(this).text();if(""!==a)if(n){var s=parseInt(e(this).attr("colspan"),10),r="";s&&(r="td:nth-child("+s+"n + "+i+")"),t.filter(r).prepend("<b class='"+o.classes.cellLabels+n+"'>"+a+"</b>")}else t.prepend("<b class='"+o.classes.cellLabels+"'>"+a+"</b>")})}})}(e),function(e,t){function i(e){o=e.originalEvent,d=o.accelerationIncludingGravity,s=Math.abs(d.x),r=Math.abs(d.y),l=Math.abs(d.z),!t.orientation&&(s>7||(l>6&&8>r||8>l&&r>6)&&s>5)?c.enabled&&c.disable():c.enabled||c.enable()}e.mobile.iosorientationfixEnabled=!0;var a=navigator.userAgent;if(!(/iPhone|iPad|iPod/.test(navigator.platform)&&/OS [1-5]_[0-9_]* like Mac OS X/i.test(a)&&a.indexOf("AppleWebKit")>-1))return e.mobile.iosorientationfixEnabled=!1,n;var o,s,r,l,d,c=e.mobile.zoom;e.mobile.document.on("mobileinit",function(){e.mobile.iosorientat
ionfixEnabled&&e.mobile.window.bind("orientationchange.iosorientationfix",c.enable).bind("devicemotion.iosorientationfix",i)})}(e,this),function(e,t){function n(){a.removeClass("ui-mobile-rendering")}var a=e("html"),o=(e("head"),e.mobile.window);e(t.document).trigger("mobileinit"),e.mobile.gradeA()&&(e.mobile.ajaxBlacklist&&(e.mobile.ajaxEnabled=!1),a.addClass("ui-mobile ui-mobile-rendering"),setTimeout(n,5e3),e.extend(e.mobile,{initializePage:function(){var t=e.mobile.path,a=e(":jqmData(role='page'), :jqmData(role='dialog')"),s=t.stripHash(t.stripQueryParams(t.parseLocation().hash)),r=i.getElementById(s);a.length||(a=e("body").wrapInner("<div data-"+e.mobile.ns+"role='page'></div>").children(0)),a.each(function(){var t=e(this);t.jqmData("url")||t.attr("data-"+e.mobile.ns+"url",t.attr("id")||location.pathname+location.search)}),e.mobile.firstPage=a.first(),e.mobile.pageContainer=e.mobile.firstPage.parent().addClass("ui-mobile-viewport"),o.trigger("pagecontainercreate"),e.mob
ile.showPageLoadingMsg(),n(),e.mobile.hashListeningEnabled&&e.mobile.path.isHashValid(location.hash)&&(e(r).is(':jqmData(role="page")')||e.mobile.path.isPath(s)||s===e.mobile.dialogHashKey)?e.event.special.navigate.isPushStateEnabled()?(e.mobile.navigate.history.stack=[],e.mobile.navigate(e.mobile.path.isPath(location.hash)?location.hash:location.href)):o.trigger("hashchange",[!0]):(e.mobile.path.isHashValid(location.hash)&&(e.mobile.urlHistory.initialDst=s.replace("#","")),e.event.special.navigate.isPushStateEnabled()&&e.mobile.navigate.navigator.squash(t.parseLocation().href),e.mobile.changePage(e.mobile.firstPage,{transition:"none",reverse:!0,changeHash:!1,fromHashChange:!0}))}}),e.mobile.navreadyDeferred.resolve(),e(function(){t.scrollTo(0,1),e.mobile.defaultHomeScroll=e.support.scrollTop&&1!==e.mobile.window.scrollTop()?1:0,e.mobile.autoInitializePage&&e.mobile.initializePage(),o.load(e.mobile.silentScroll),e.support.cssPointerEvents||e.mobile.document.delegate(".ui-dis
abled","vclick",function(e){e.preventDefault(),e.stopImmediatePropagation()})}))}(e,this)});
+//@ sourceMappingURL=jquery.mobile.min.map
\ No newline at end of file
Modified: trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -11,8 +11,10 @@
this,this.increaseCounter),a.layer.events.register("loadend",this,this.decreaseCounter))},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register("preaddlayer",this,this.addLayer);for(var b=0;b<this.map.layers.length;b++){var c=this.map.layers[b];c.events.register("loadstart",this,this.increaseCounter);c.events.register("loadend",this,this.decreaseCounter)}},increaseCounter:function(){this.counter++;0<this.counter&&!this.maximized&&this.visible&&this.maximizeControl()},
decreaseCounter:function(){0<this.counter&&this.counter--;0==this.counter&&this.maximized&&this.visible&&this.minimizeControl()},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);return this.div},minimizeControl:function(a){this.div.style.display="none";this.maximized=!1;null!=a&&OpenLayers.Event.stop(a)},maximizeControl:function(a){this.div.style.display="block";this.maximized=!0;null!=a&&OpenLayers.Event.stop(a)},destroy:function(){if(this.map&&(this.map.events.unregister("preaddlayer",
this,this.addLayer),this.map.layers))for(var a=0;a<this.map.layers.length;a++){var b=this.map.layers[a];b.events.unregister("loadstart",this,this.increaseCounter);b.events.unregister("loadend",this,this.decreaseCounter)}OpenLayers.Control.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.LoadingPanel"});
-var map,clickCtrl,measureControls,olSearchSymbol={graphicName:"cross",strokeColor:"#00FFFF",strokeWidth:1,fillOpacity:0,pointRadius:11},olFeaturequerySymbol={graphicName:"circle",strokeColor:"#00FFFF",fillColor:"#00FFFF",strokeWidth:3,fillOpacity:0.2,pointRadius:15,graphicName:"circle"},olGpsSymbol={graphicName:"cross",strokeColor:"#871D33",strokeWidth:2,fillOpacity:0,pointRadius:12},olGpscircleStyle={fillOpacity:0.1,fillColor:"#000",strokeColor:"#871D33",strokeOpacity:0.6},sketchSymbolizers={Point:{pointRadius:6,
-graphicName:"square",fillColor:"white",fillOpacity:1,strokeWidth:2,strokeOpacity:0.8,strokeColor:"#00FFFF"},Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000"},Polygon:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000",fillColor:"white",fillOpacity:0.5}},style=new OpenLayers.Style;style.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);var styleMap=new OpenLayers.StyleMap({"default":style});
+var map,clickCtrl,measureControls,olSearchSymbol={graphicName:"cross",strokeColor:"#00FFFF",strokeWidth:1,fillOpacity:0,pointRadius:11},olFeaturequerySymbol={graphicName:"circle",strokeColor:"#00FFFF",fillColor:"#00FFFF",strokeWidth:3,fillOpacity:0.2,pointRadius:15,graphicName:"circle"},olGpsSymbol={externalGraphic:"css/images/gpspoint.png",graphicHeight:16,graphicWidth:16},olGpscircleStyle={fillOpacity:0.2,fillColor:"#06C",strokeColor:"#06C",strokeOpacity:0.6},sketchSymbolizers={Point:{pointRadius:6,
+graphicName:"square",fillColor:"white",fillOpacity:1,strokeWidth:2,strokeOpacity:0.8,strokeColor:"#00FFFF"},Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000"},Polygon:{strokeWidth:3,strokeOpacity:1,strokeColor:"#FF0000",fillColor:"white",fillOpacity:0.5}},umkreisstyles=new OpenLayers.StyleMap({"default":new OpenLayers.Style(null,{rules:[new OpenLayers.Rule({symbolizer:{Point:{pointRadius:5,graphicName:"circle",fillColor:"white",fillOpacity:0.6,strokeWidth:1,strokeOpacity:1,strokeColor:"#CC0000"},
+Line:{strokeWidth:3,strokeOpacity:1,strokeColor:"#CC0000"},Polygon:{strokeWidth:2,strokeOpacity:1,fillColor:"#CC0000",strokeColor:"#CC0000"}}})]})}),poicontext={getGraphic:function(a){return a.attributes.symbol}},poitemplate={externalGraphic:"config/img/symbol/${getGraphic}",graphicHeight:26,graphicWidth:26,cursor:"pointer"},selectpoiTemplate={externalGraphic:"config/img/symbol/${getGraphic}",graphicHeight:26,graphicWidth:26,cursor:"pointer",fillOpacity:0.7},poiStyle=new OpenLayers.Style(poitemplate,
+{context:poicontext}),poiStyleselect=new OpenLayers.Style(selectpoiTemplate,{context:poicontext}),styleMapPoi=new OpenLayers.StyleMap({"default":poiStyle,select:poiStyleselect}),style=new OpenLayers.Style;style.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);var styleMap=new OpenLayers.StyleMap({"default":style});
function Service(a,b,c,d,e,f,g,h){a=$("<li>",{serviceid:a,"class":"service",title:b,desc:c,getMapURL:d,status:e,logoUrl:f,symbolLink:g,avail:h});d=$('<div class="service_container"></div>');d.append($('<table style="margin: 0px; padding: 0px; float:left;"><tr style="margin: 0px; padding: 0px;"><td style="margin: 0px; padding: 0px; height:43px; width:55px; text-align: center; vertical-align: middle;"><img style="max-height: 43px; max-width: 55px; max-height: 43px;" src="'+f+'" class="service_logo" alt="Logo"/></td></tr></table>'));
d.append($("<div>",{"class":"icon layer_remove",text:" "}).click(function(){removeService($(this).parent().parent())}));d.append($("<div>",{"class":"icon layer_add",text:" "}).click(function(){addService($(this).parent().parent())}));d.append('<div class="collapsible unselected" data-role="collapsible" data-collapsed="true" data-theme="a" data-content-theme="c" data-inset="true"><h3>'+b+"</h3><h3>"+b+"</h3><p>"+c+"</p></div>");a.append(d);return a}
function BaseLayer(a,b){return $("<div>",{text:a,title:a,layerids:b,"class":"baselayer base_unchecked"}).click(function(){switchVisibility($(this))})}
@@ -25,8 +27,8 @@
d=$("#select-lang").val(),e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);e="p"===$("#select-feature-info").val()?!0:!1;!0==e?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):0==c.length?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):
($.mobile.changePage($("#featureinforesult"),pageTransition),$("#ficontentdiv").text(window.lang.convert("Bitte warten...")));0<c.length?(a=c.attr("getmapurl")+"&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),
setMarkerhint("Abfrageergebnis:",a)):(a=$('<iframe src="'+a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterqueryWms.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+
-"&searchText="+$("#mapbendersearchfield").val())});$("#mapbendersearchfield").live("keypress",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
-function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
+"&searchText="+$("#mapbendersearchfield").val())});$(document).on("keypress","#mapbendersearchfield",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$(document).on("expand","div[data-role=collapsible]",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});
+addBaselayers()}function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
getInfo=function(a){$("#info_content").empty();$("#info_content").append(a);$("#info").popup("open")};function getOpenlayersIndex(a){for(var b=0;b<map.layers.length;b++)if(map.layers[b].name==a)return b;return-1}function addOpenlayer(a,b,c){a=new OpenLayers.Layer.WMS(a,c,{layers:b,format:"image/png",transparent:"TRUE",transitionEffect:"resize"},{projection:mapProj,units:projUnits,opacity:0.8,singleTile:!0,isBaseLayer:!1,visibility:!0,alwaysInRange:!0});map.addLayer(a);map.setLayerIndex(a,0)}
function removeOpenlayer(a){a=getOpenlayersIndex(a);0<=a&&map.removeLayer(map.layers[a])}function setOpenBaselayer(a){a=getOpenlayersIndex(a);0<=a&&map.setBaseLayer(map.layers[a])}function selectOpenlayer(a,b){var c=getOpenlayersIndex(a);0<=c&&map.layers[c].setVisibility(b)}
function addOpenBaselayer(a,b){$.getJSON("mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&resourceIds="+b,function(b){$.each(b.wms.srv,function(b,c){$.each(c.layer,function(b,d){d.layer&&(d=d.layer[0]);var h=new OpenLayers.Layer.WMS(a,c.getMapUrl,{layers:d.name,format:"image/png",transparent:"false",transitionEffect:"resize"},{projection:mapProj,units:projUnits,singleTile:!0,isBaseLayer:!0,alwaysInRange:!0});map.addLayers([h])})})})}
@@ -48,21 +50,19 @@
function appendWmcData(a,b,c,d,e){$("#ownlist").empty();for(var f=[],g=0;g<a.length;g++)for(var h=a[g],j=0;j<b.length;j++){var k=b[j],l=k[1];k[0]==h.id&&f.push(OwnLayer(l.id,l.title,l.name,$(l).attr("abstract"),h.title,$(h).attr("abstract"),l.previewURL,"1"==l.queryable,h.getMapUrl,l.bbox,h.avail))}for(g=0;g<c.length;g++)for(j=0;j<f.length;j++)if(c[g].layerId==f[j].attr("layerid")){k=f[j];$("#ownlist").append(k);addOpenlayer(k.attr("layerid"),k.attr("name"),k.attr("getMapUrl"));c[g].active||switchVisibility(k);
break}validateLayers();validateArrows();b=d.split(",");a=(new OpenLayers.LonLat(b[0],b[1])).transform(e,mapProj);e=(new OpenLayers.LonLat(b[2],b[3])).transform(e,mapProj);map.zoomToExtent(new OpenLayers.Bounds(a.lon,a.lat,e.lon,e.lat))}function clearOwnlist(){for(var a=$("#ownlist").find(".layer"),b=0;b<a.length;b++)removeLayer(a[b])}
function appendWmc(a){for(var b=0;b<a.backGroundLayer.length;b++){var c=a.backGroundLayer[b];if(c.active)for(var d=$("#baselayers").find(".baselayer"),e=0;e<d.length;e++)if($(d[e]).attr("layerids")==c.name){switchVisibility(d[e]);break}}clearOwnlist();var f="";$.each(a.layerList,function(a,b){f=f+","+b.layerId});f=f.substr(1,f.length);$.getJSON(searchUrl+"&resourceIds="+f,function(b){b=parseMapBenderJson(b);appendWmcData(b.services,b.layers,a.layerList,a.wmc.bbox,a.wmc.crs);$.mobile.hidePageLoadingMsg()})}
-function addBaselayers(){$("#baselayers").empty();vector_marker=new OpenLayers.Layer.Vector("Vector Layer",{});$("#baselayers").append(BaseLayer("RLP Zusammenstellung",atkis_praes_tms.name));$("#baselayers").append(BaseLayer("Luftbilder",luftbilder.name));$("#baselayers").append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker]);for(i in baseinfo){var a=baseinfo[i][0],b=baseinfo[i][1];$("#baselayers").append(BaseLayer(a,b));
-addOpenBaselayer(a,b)}base_check($("#baselayers").find(".baselayer").first())}
+function addBaselayers(){$("#baselayers").empty();vector_marker=new OpenLayers.Layer.Vector("Vector Layer",{});gps_marker=new OpenLayers.Layer.Vector("gps_marker",{rendererOptions:{zIndexing:!0}});$("#baselayers").append(BaseLayer("RLP Zusammenstellung",atkis_praes_tms.name));$("#baselayers").append(BaseLayer("Luftbilder",luftbilder.name));$("#baselayers").append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker,gps_marker]);
+for(i in baseinfo){var a=baseinfo[i][0],b=baseinfo[i][1];$("#baselayers").append(BaseLayer(a,b));addOpenBaselayer(a,b)}base_check($("#baselayers").find(".baselayer").first())}
var initmap=function(){var a={theme:null,projection:mapProj,units:projUnits,maxExtent:mymapbounds,maxScale:mymaxscale,minScale:myminscale,numZoomLevels:myzoomlevels,scales:myscales,controls:[new OpenLayers.Control.Attribution,new OpenLayers.Control.Navigation({zoomWheelEnabled:!0}),new OpenLayers.Control.KeyboardDefaults,new OpenLayers.Control.TouchNavigation({dragPanOptions:{interval:10,enableKinetic:!0}}),new OpenLayers.Control.ScaleLine({div:document.getElementById("scaleline"),geodesic:!1,maxWidth:100,
-topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null}),new OpenLayers.Control.LoadingPanel({})]};map=new OpenLayers.Map("map",a);addmyLayer();"off"!==myzoombounds?map.zoomToExtent(myzoombounds):map.zoomToExtent(map.maxExtent);a=new OpenLayers.Control.Geolocate({id:"locate-control",geolocationOptions:{enableHighAccuracy:!0,maximumAge:0,timeout:7E3}});map.addControl(a);a.events.register("locationupdated",this,function(a){vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(a.point,
-{},olGpsSymbol),new OpenLayers.Feature.Vector(OpenLayers.Geometry.Polygon.createRegularPolygon(new OpenLayers.Geometry.Point(a.point.x,a.point.y),a.position.coords.accuracy/2,50,0),{},olGpscircleStyle)]);a.point.x>map.maxExtent.left&&a.point.x<map.maxExtent.right&&a.point.y>map.maxExtent.bottom&&a.point.y<map.maxExtent.top?(setMarkerhint(window.lang.convert("Positionsgenauigkeit:"),"~ "+a.position.coords.accuracy+" Meter"),map.zoomToExtent(vector_marker.getDataExtent())):(alert(window.lang.convert("Die ermittelte Position liegt au\u00dferhalb des darstellbaren Kartenausschnitts!")),
-$("#markerhint").css("visibility","hidden"))});a=new OpenLayers.Style;a.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);a=new OpenLayers.StyleMap({"default":a});measureControls={line:new OpenLayers.Control.Measure(OpenLayers.Handler.Path,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}}),polygon:new OpenLayers.Control.Measure(OpenLayers.Handler.Polygon,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}})};for(var b in measureControls)a=measureControls[b],a.events.on({measure:handleMeasurements,
-measurepartial:handleMeasurements}),map.addControl(a)};
-$(document).ready(function(){window.location.hash&&"#mappage"!=window.location.hash&&$.mobile.changePage($("#mappage"),pageTransition);initmap();zoomSelect&&($("#zoomscale").css("visibility","visible"),createZoomselect(),map.events.register("moveend",null,displayZoom));clickCtrl=new OpenLayers.Control.Click;map.addControl(clickCtrl);clickCtrl.activate();checkLayers();$("#autolayerchange").change(function(){directLayerChange=this.value});$("#layerbut").click(function(){$.mobile.changePage($("#layerpage"),pageTransition)});
-$("#searchbut").click(function(){$.mobile.changePage($("#searchpage"),pageTransition)});$("#helpbut").click(function(){$.mobile.changePage($("#helppage"),pageTransition)});$("#gearbut").click(function(){$.mobile.changePage($("#gearpage"),pageTransition)});$("#measurelinebut").click(function(){toggleMeasure("line")});$("#measurepolybut").click(function(){toggleMeasure("polygon")});$("#ovbut").click(function(){map.zoomToExtent(map.maxExtent)});$("#zoominbut").click(function(){map.zoomIn()});$("#zoomoutbut").click(function(){map.zoomOut()});
-$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#xheader").click(function(){$("#markerhint").css("visibility","hidden");vector_marker.removeAllFeatures()});$("#mheader").click(function(){$("#measurehint").css("visibility","hidden");toggleMeasure("off")});$("#searchformbut").click(function(){searchCall()});$("#searchfield").live("keypress",function(a){13===a.keyCode&&searchCall()});$(".mapbackbut").click(function(){$.mobile.changePage($("#mappage"),pageTransition);
-$("body").css("overflow","hidden")});$("#locatebut").click(function(){setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten..."));var a=map.getControlsBy("id","locate-control")[0];a.active?a.getCurrentLocation():a.activate()});$(".baselayer_check").click(function(){$(".baselayer_check").css("background-image","url(img/ico_basecheck.png)");$(this).css("background-image","url(img/ico_basecheck_active.png)");for(var a=0;a<map.layers.length;a++)$(this).attr("id")===map.layers[a].name&&
-map.setBaseLayer(map.layers[a]);clearanimation();checktranspage()});$(".layer_check").click(function(){for(var a=0;a<map.layers.length;a++)if($(this).attr("id")===map.layers[a].name)var b=a;map.layers[b].getVisibility()?(map.layers[b].setVisibility(!1),$(this).css("background-image","url(img/ico_check.png)")):(map.layers[b].setVisibility(!0),$(this).css("background-image","url(img/ico_check_active.png)"));clearanimation();checktranspage()});$(".poi_check").click(function(){var a=poilayer.params.LAYERS,
-b=[];""!=a&&(b=a.split(","));if(-1!=jQuery.inArray($(this).attr("id"),b)){for(a=0;a<b.length;a++)$(this).attr("id")===b[a]&&b.splice(a,1);$(this).css("background-image","url(img/ico_check.png)")}else b.push($(this).attr("id")),$(this).css("background-image","url(img/ico_check_active.png)");a=b.join(",");poilayer.mergeNewParams({layers:a});0<b.length&&poilayer.setVisibility(!0);poilayer.redraw();clearanimation();checktranspage()});$(".query_check").click(function(){$(".query_check").css("background-image",
-"url(img/ico_checkop.png)");$(this).css("background-image","url(img/ico_checkop_active.png)");var a=$(this).attr("id"),a=a.substring(0,a.length-6);$("#queryselect").val(a);clearanimation()});$(".query_check").touchstart(function(){$(this).css("background-color","#808080")});$(".layer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});$(".baselayer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});
-$(".navbuttons").touchstart(function(){$(this).css("border","2px solid #808080")});$(".navbuttons").touchend(function(){$(this).css("border","2px solid "+toolColor)});$(".searchbutton").live("touchstart",function(){$(this).css("border","2px solid #808080")});changeHand(defaultHand);$("#autolayerchange").val(directLayerChange);hideAddressBar()});
+topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null}),new OpenLayers.Control.LoadingPanel({})]};map=new OpenLayers.Map("map",a);addmyLayer();"off"!==myzoombounds?map.zoomToExtent(myzoombounds):map.zoomToExtent(map.maxExtent);a=new OpenLayers.Style;a.addRules([new OpenLayers.Rule({symbolizer:sketchSymbolizers})]);a=new OpenLayers.StyleMap({"default":a});measureControls={line:new OpenLayers.Control.Measure(OpenLayers.Handler.Path,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}}),
+polygon:new OpenLayers.Control.Measure(OpenLayers.Handler.Polygon,{persist:!0,handlerOptions:{layerOptions:{styleMap:a}}})};for(var b in measureControls)a=measureControls[b],a.events.on({measure:handleMeasurements,measurepartial:handleMeasurements}),map.addControl(a)};
+$(document).ready(function(){window.location.hash&&"#mappage"!=window.location.hash&&$.mobile.changePage($("#mappage"),pageTransition);initmap();zoomSelect&&($("#zoomscale").css("visibility","visible"),createZoomselect(),map.events.register("moveend",null,displayZoom));clickCtrl=new OpenLayers.Control.Click;map.addControl(clickCtrl);clickCtrl.activate();checkLayers();$("#autolayerchange").change(function(){directLayerChange=this.value});$("#layerbut").click(function(){$.mobile.changePage($("#layerpage"),
+pageTransition)});$("#searchbut").click(function(){$.mobile.changePage($("#searchpage"),pageTransition)});$("#helpbut").click(function(){$.mobile.changePage($("#helppage"),pageTransition)});$("#gearbut").click(function(){$.mobile.changePage($("#gearpage"),pageTransition)});$("#measurelinebut").click(function(){toggleMeasure("line")});$("#measurepolybut").click(function(){toggleMeasure("polygon")});$("#ovbut").click(function(){map.zoomToExtent(map.maxExtent)});$("#zoominbut").click(function(){map.zoomIn()});
+$("#zoomoutbut").click(function(){map.zoomOut()});$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#xheader").click(function(){$("#markerhint").css("visibility","hidden");vector_marker.removeAllFeatures()});$("#mheader").click(function(){$("#measurehint").css("visibility","hidden");toggleMeasure("off")});$("#searchformbut").click(function(){searchCall()});$(document).on("keypress","#searchfield",function(a){13===a.keyCode&&searchCall()});$(".mapbackbut").click(function(){$.mobile.changePage($("#mappage"),
+pageTransition);$("body").css("overflow","hidden")});$("#popupMenu").popup();$("#menubut").click(function(){$("#popupMenu").popup("open")});$("#popupMenu_gps").popup();$("#locatebut").click(function(){$("#popupMenu_gps").popup("open")});$("#gpsstatus").change(function(){"on"===this.value?startgpsWatch():stopgpsWatch()});$(".baselayer_check").click(function(){$(".baselayer_check").css("background-image","url(img/ico_basecheck.png)");$(this).css("background-image","url(img/ico_basecheck_active.png)");
+for(var a=0;a<map.layers.length;a++)$(this).attr("id")===map.layers[a].name&&map.setBaseLayer(map.layers[a]);clearanimation();checktranspage()});$(".layer_check").click(function(){for(var a=0;a<map.layers.length;a++)if($(this).attr("id")===map.layers[a].name)var b=a;map.layers[b].getVisibility()?(map.layers[b].setVisibility(!1),$(this).css("background-image","url(img/ico_check.png)")):(map.layers[b].setVisibility(!0),$(this).css("background-image","url(img/ico_check_active.png)"));clearanimation();
+checktranspage()});$(".poi_check").click(function(){var a=poilayer.params.LAYERS,b=[];""!=a&&(b=a.split(","));if(-1!=jQuery.inArray($(this).attr("id"),b)){for(a=0;a<b.length;a++)$(this).attr("id")===b[a]&&b.splice(a,1);$(this).css("background-image","url(img/ico_check.png)")}else b.push($(this).attr("id")),$(this).css("background-image","url(img/ico_check_active.png)");a=b.join(",");poilayer.mergeNewParams({layers:a});0<b.length&&poilayer.setVisibility(!0);poilayer.redraw();clearanimation();checktranspage()});
+$(".query_check").click(function(){$(".query_check").css("background-image","url(img/ico_checkop.png)");$(this).css("background-image","url(img/ico_checkop_active.png)");var a=$(this).attr("id"),a=a.substring(0,a.length-6);$("#queryselect").val(a);clearanimation()});$(".query_check").touchstart(function(){$(this).css("background-color","#808080")});$(".layer_check").touchstart(function(){$(this).css("background-color","#808080");$(this).css("color","#FFFFFF")});$(".baselayer_check").touchstart(function(){$(this).css("background-color",
+"#808080");$(this).css("color","#FFFFFF")});$(".navbuttons").touchstart(function(){$(this).css("border","2px solid #808080")});$(".navbuttons").touchend(function(){$(this).css("border","2px solid "+toolColor)});$(document).on("touchstart",".searchbutton",function(){$(this).css("border","2px solid #808080")});changeHand(defaultHand);$("#autolayerchange").val(directLayerChange);hideAddressBar()});
var clearanimation=function(){$(".query_check").css("background-color","#808080");$(".layer_check, .baselayer_check, .poi_check").css("background-color","#FFFFFF");$(".layer_check, .baselayer_check, .poi_check").css("color","#000000")},checktranspage=function(){"on"===directLayerChange&&$.mobile.changePage($("#mappage"),pageTransition)},checkLayers=function(){$(".baselayer_check").each(function(){for(var a=0;a<map.layers.length;a++)map.layers[a].name===$(this).attr("id")&&map.layers[a].visibility&&
$(this).css("background-image","url(img/ico_basecheck_active.png)")});$(".layer_check").each(function(){for(var a=0;a<map.layers.length;a++)map.layers[a].name===$(this).attr("id")&&map.layers[a].visibility&&$(this).css("background-image","url(img/ico_check_active.png)")});$(".poi_check").each(function(){var a=poilayer.params.LAYERS,b=[];""!=a&&(b=a.split(","));-1!=jQuery.inArray($(this).attr("id"),b)&&$(this).css("background-image","url(img/ico_check.png)")});$(".query_check").each(function(){var a=
$(this).attr("id");a.substring(0,a.length-6)===$("#queryselect").val()&&$(this).css("background-image","url(img/ico_checkop_active.png)")})};function searchCall(){"google"===searchMode?codeAddress():"streetsearch"===searchMode?searchStreet($("#searchfield").val()):"mapbendersearch"===searchMode?searchMapbender($("#searchfield").val()):alert("kein Suchmodus konfiguriert!")}function setMarkerhint(a,b){$("#xheader").html(a);$("#xcontent").html(b);$("#markerhint").css("visibility","visible")}
@@ -86,4 +86,9 @@
function handleMeasurements(a){var b=a.units,c=a.order,a=a.measure,d=document.getElementById("measureoutput"),e="",e=1==c?e+(window.lang.convert("Entfernung: ")+"<strong>"+a.toFixed(2)+"</strong> "+b):e+(window.lang.convert("Fl\u00e4che: ")+"<strong>"+a.toFixed(2)+"</strong> "+b+"<sup>2</sup>");d.innerHTML=e}
function toggleMeasure(a){clickCtrl.deactivate();$("#popupMenu").popup("close");measureControls.line.deactivate();measureControls.polygon.deactivate();"line"===a?($("#measurehint").css("visibility","visible"),measureControls[a].activate(),$("#measureoutput").html(window.lang.convert("Entfernungsmessung aktiv!"))):"polygon"===a?($("#measurehint").css("visibility","visible"),measureControls[a].activate(),$("#measureoutput").html(window.lang.convert("Fl\u00e4chenmessung aktiv!"))):clickCtrl.activate()}
function setmapsize(){window.scrollTo(0,0);var a=$.mobile.getScreenHeight(),b=$('[data-role="header"]').first().outerHeight(),c=$('[data-role="footer"]').first().outerHeight(),d=$('[data-role="content"]'),e=parseInt(d.css("padding-left").replace("px",""))+parseInt($('[data-role="content"]').css("padding-right").replace("px","")),f=parseInt(d.css("padding-top").replace("px",""))+parseInt($('[data-role="content"]').css("padding-bottom").replace("px","")),a=a-b-c-f;winwide=$(document).width();winwide-=
-e;d.css("width",winwide+"px").css("height",a+"px");$("#map").css("width",winwide+"px").css("height",a+"px")}function checkZindex(){for(var a=map.layers,b=0,c=a.length;b<c;b++)"tk_grau"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex),"Vector Layer"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex)};
+e;d.css("width",winwide+"px").css("height",a+"px");$("#map").css("width",winwide+"px").css("height",a+"px")}function checkZindex(){for(var a=map.layers,b=0,c=a.length;b<c;b++)"tk_grau"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex),"Vector Layer"===a[b].name&&alert("name:"+a[b].name+" zindex:"+a[b].div.style.zIndex)}
+var startgpsWatch=function(){navigator.geolocation&&($("#gpsmessage").html('<div id="gpsmessagebox">start watching...</div>'),gpswatch=navigator.geolocation.watchPosition(gpsokCallback,gpsfailCallback,gpsOptions))},stopgpsWatch=function(){navigator.geolocation.clearWatch(gpswatch);$("#gpsmessage").html("");$("#gpsinfo").css("visibility","hidden");gps_marker.removeAllFeatures();$("#activePosition").val("")},gpsokCallback=function(a){var b="Lat: "+a.coords.latitude+"<br>Lon: "+a.coords.longitude+"<br>Genauigkeit: ~"+
+Math.round(a.coords.accuracy)+" m";$("#gpsmessage").html('<br><a href="#" id="zoomGpspoint" data-role="button" data-icon="arrow-r" data-iconpos="right" data-inline="true" data-mini="true" >Zoom auf Position</a><br><br>');$("#gpsinfo").html("<strong>Positionierung aktiv</strong><br>"+b);$("#gpsinfo").css("visibility","visible");var c=(new OpenLayers.LonLat(a.coords.longitude,a.coords.latitude)).transform(wgs84Proj,mapProj);$("#zoomGpspoint").bind("click",function(){map.setCenter(c,getZoomlevel())});
+$("#zoomGpspoint").button();$("#searchGpspoint").bind("click",function(){$.mobile.changePage($("#searchpage2"),pageTransition);$("#searchSort").val("sortdist1");$("#searchSort").selectmenu("refresh");$("#search_results_poi").empty();$("#searchfield_poi").empty()});$("#searchGpspoint").button();$("#activePosition").val(Math.round(c.lon)+","+Math.round(c.lat));c.lon>map.maxExtent.left&&c.lon<map.maxExtent.right&&c.lat>map.maxExtent.bottom&&c.lat<map.maxExtent.top?(b=new OpenLayers.Geometry.Point(c.lon,
+c.lat),new OpenLayers.Geometry.Point(c.lon,c.lat),gps_marker.removeAllFeatures(),gps_marker.addFeatures([new OpenLayers.Feature.Vector(b,{},olGpsSymbol),new OpenLayers.Feature.Vector(OpenLayers.Geometry.Polygon.createRegularPolygon(new OpenLayers.Geometry.Point(c.lon,c.lat),a.coords.accuracy/2,50,0),{},olGpscircleStyle)]),"on"===$("#gpscenter").val()&&map.setCenter(c)):(alert(window.lang.convert("Die ermittelte Position liegt au\u00dferhalb des darstellbaren Kartenausschnitts!")),$("#gpsstatus").val("off"),
+$("#gpsstatus").slider("refresh"),stopgpsWatch())},gpsfailCallback=function(){},gpsOptions={enableHighAccuracy:!0,timeout:5E3,maximumAge:0};
Modified: trunk/mapbender/http/extensions/mobilemap/map.php
--- trunk/mapbender/http/extensions/mobilemap/map.php 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/map.php 2013-07-18 03:44:11 UTC (rev 8674)
@@ -48,7 +48,7 @@
<meta name="apple-mobile-web-app-capable" content="yes">
<link rel="apple-touch-icon" href="<?php echo $iPhoneIcon; ?>"/>
<link rel="shortcut icon" href="<?php echo $favIcon; ?>"/>
-<link rel="stylesheet" href="http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.css" />
+<link rel="stylesheet" href="../mobilemap/css/jquery.mobile.min.css" >
<link href="<?php echo $style_1; ?>" rel="stylesheet" >
<link href="<?php echo $style_2; ?>" rel="stylesheet" >
<?php if($googleapi){ ?>
@@ -56,8 +56,8 @@
<?php } ?>
<script src="../mobilemap/js/proj4js.min.js" ></script>
<script src="../mobilemap/js/OpenLayers.mobile.min.js"></script>
-<script src="http://code.jquery.com/jquery-1.8.2.min.js"></script>
-<script src="http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.js"></script>
+<script src="../mobilemap/js/jquery.min.js"></script>
+<script src="../mobilemap/js/jquery.mobile.min.js"></script>
<script src="../mobilemap/js/jquery-lang.js"></script>
<script src="../mobilemap/js/langpack/en.js" charset="utf-8" type="text/javascript"></script>
<script src="../mobilemap/backgroundlayer.php" charset="utf-8" type="text/javascript"></script>
@@ -102,62 +102,92 @@
<!-- Map Seite Start-->
<div data-role="page" id="mappage">
+<!-- Popup GPS -->
+ <div data-role="popup" id="popupMenu_gps" data-theme="a" class="ui-corner-all">
+ <a href="#" data-rel="back" data-role="button" data-theme="a" data-icon="delete" data-iconpos="notext" class="ui-btn-right">Close</a>
+ <div data-role="header" data-theme="a" class="ui-corner-top">
+ <h1>Position</h1>
+ </div>
+ <div data-role="content" data-theme="a" class="ui-corner-bottom ui-content">
+ <div style="font-size:14px; padding: 12px;">Positionierung aktivieren<br>
+ <select id="gpsstatus" data-role="slider" data-mini="true" >
+ <option value="off" selected>Off</option>
+ <option value="on">On</option>
+ </select>
+ <br>Karte automatisch auf<br>
+ Position zentrieren<br>
+ <select data-role="slider" id="gpscenter" data-mini="true" >
+ </select>
+ <div id="gpsmessage"></div>
+ </div>
+ </div>
+ </div>
+ <!-- Ende Popup GPS -->
<div data-role="content">
- <div id="logo"><a href="map.php?lang=<?php echo $mylang; ?>" target="_self"><img src="img/logo.png" ></a></div>
- <div id="map"></div>
- <div id="navbutgroup">
- <div id="ovbut" class="navbuttons" style="margin-top:2px"></div>
- <div id="zoominbut" class="navbuttons" style="margin-top:2px"></div>
- <div id="zoomoutbut" class="navbuttons" style="margin-top:2px"></div>
- </div>
+ <div id="logo"><a href="map.php?lang=<?php echo $mylang; ?>" target="_self"><img src="img/logo.png" ></a></div>
+ <div id="map"></div>
+ <div id="navbutgroup">
+ <div id="ovbut" class="navbuttons" style="margin-top:2px"></div>
+ <div id="zoominbut" class="navbuttons" style="margin-top:2px"></div>
+ <div id="zoomoutbut" class="navbuttons" style="margin-top:2px"></div>
+ </div>
<div id="navbutgrouptop">
- <?php if($mapbendermod){ ?>
- <!-- Mapbender -->
- <div id="mapbenderbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
- <?php } else { ?>
- <div id="layerbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
- <?php } ?>
- <div id="searchbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
- <div id="locatebut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
- <div id="menubut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
+ <?php if($mapbendermod){ ?>
+ <!-- Mapbender -->
+ <div id="mapbenderbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
+ <?php } else { ?>
+ <div id="layerbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
+ <?php } ?>
+ <div id="searchbut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
+ <div id="locatebut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
+ <div id="menubut" class="navbuttons" style="float:left; margin-left:2px;" ></div>
- </div>
- <div id="markerhint">
- <div id="xheader"></div>
- <div id="xcontent"></div>
- </div>
- <div id="measurehint" >
- <div id="mheader"><span lang="de">Messen</span></div>
- <div id="measureoutput"></div>
- </div>
+ </div>
+ <div id="markerhint">
+ <div id="xheader"></div>
+ <div id="xcontent"></div>
+ </div>
+ <div id="measurehint" >
+ <div id="mheader"><span lang="de">Messen</span></div>
+ <div id="measureoutput"></div>
+ </div>
- <div id="scaleline"></div>
- <div id="copyright"><span lang="de"><?php echo $copyright; ?></span></div>
- <div id="LoadingPanel"></div>
- <div id="zoomscale">
- <select name="selectzoom" id="selectzoom" onChange="changeScale(this.value);" data-inline="true" data-mini="true" data-native-menu="<?php echo $scaleselect; ?>" >
- </select>
- <label for="test"></label>
- </div>
- <div data-role="popup" id="popupMenu" data-overlay-theme="a" data-theme="a" style="max-width:2280px;" class="ui-corner-all">
+ <div id="scaleline"></div>
+ <div id="copyright"><span lang="de"><?php echo $copyright; ?></span></div>
+ <div id="LoadingPanel"></div>
+ <div id="zoomscale">
+ <select name="selectzoom" id="selectzoom" onChange="changeScale(this.value);" data-inline="true" data-mini="true" data-native-menu="<?php echo $scaleselect; ?>" >
+ </select>
+ <label for="test"></label>
+ </div>
+ <div data-role="popup" id="popupMenu" data-overlay-theme="a" data-theme="a" style="max-width:2280px;" class="ui-corner-all">
- <div data-role="header" data-theme="a" class="ui-corner-top">
- <h1>Tools</h1>
- </div>
- <div data-role="content" data-theme="d" class="ui-corner-bottom ui-content"><br>
-<table border="0" cellspacing="0" cellpadding="14">
- <tr>
- <td><div id="helpbut" class="navbuttons" ></div></td>
- <td><div id="gearbut" class="navbuttons" ></div></td>
- </tr>
- <tr>
- <td><div id="measurelinebut" class="navbuttons" ></div></td>
- <td><div id="measurepolybut" class="navbuttons" ></div></td>
- </tr>
-</table>
+ <h1>Tools</h1>
+ </div>
+ <div data-role="content" data-theme="d" class="ui-corner-bottom ui-content"><br>
+ <table border="0" cellspacing="0" cellpadding="14">
+ <tr>
+ <td><div id="helpbut" class="navbuttons" ></div></td>
+ <td><div id="gearbut" class="navbuttons" ></div></td>
+ </tr>
+ <tr>
+ <td><div id="measurelinebut" class="navbuttons" ></div></td>
+ <td><div id="measurepolybut" class="navbuttons" ></div></td>
+ </tr>
+ </table>
+ </div>
</div>
- </div>
</div>
<!-- /content -->
Modified: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-07-16 12:03:01 UTC (rev 8673)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-07-18 03:44:11 UTC (rev 8674)
@@ -145,14 +145,16 @@
//Suchfeld
- $('#mapbendersearchfield').live('keypress', function(e) {
+ //$('#mapbendersearchfield').live('keypress', function(e) {
+ $(document).on('keypress', '#mapbendersearchfield', function(e) {
if(e.keyCode === 13){
searchMaps(searchUrl+'&searchText='+$('#mapbendersearchfield').val());
// Alle anderen Layer einklappen
- $('div[data-role=collapsible]').live('expand', function(){
+ //$('div[data-role=collapsible]').live('expand', function(){
+ $(document).on('expand', 'div[data-role=collapsible]', function(e) {
$("div[data-role=collapsible]").not($(this)).trigger("collapse");
@@ -663,7 +665,9 @@
// Vektorlayer
vector_marker = new OpenLayers.Layer.Vector("Vector Layer", {});
+ gps_marker = new OpenLayers.Layer.Vector("gps_marker", {
+ rendererOptions: {zIndexing: true}
// Hintergrund:Topographie ect.
/* var atkis_praes_tms = new OpenLayers.Layer.TMS(
"Hybrid",
@@ -724,7 +728,7 @@
$('#baselayers').append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));
- map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker]);
+ map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker,gps_marker]);
// Dynamische Hintergrundkarten hinzufügen
for(i in baseinfo){
More information about the Mapbender_commits
