[Mapbender-commits] r8655 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Jun 14 01:47:55 PDT 2013
Author: verenadiewald
Date: 2013-06-14 01:47:55 -0700 (Fri, 14 Jun 2013)
New Revision: 8655
trunk/mapbender/http/javascripts/mod_key.php
correct event and key handling for current browsers
Modified: trunk/mapbender/http/javascripts/mod_key.php
--- trunk/mapbender/http/javascripts/mod_key.php 2013-06-13 06:02:14 UTC (rev 8654)
+++ trunk/mapbender/http/javascripts/mod_key.php 2013-06-14 08:47:55 UTC (rev 8655)
@@ -46,16 +46,17 @@
echo ");";
-if(ie){
+//if(ie){
mb_registerInitFunctions('mod_key_init()');
function mod_key_init(){
for(var i=0; i<mb_key_elements.length; i++){
if(mb_key_elements[i] == "body"){
- $('body').live('keydown', function(e) {
- var tag = e.target.tagName.toLowerCase();
+ $('body').focus();
+ $(document).bind('keydown', function(e) {
+ var tag = e.target.tagName.toLowerCase();
if (tag != 'input' && tag != 'textarea') {
- mod_key_Keyhandler();
+ mod_key_Keyhandler(e);
@@ -64,13 +65,13 @@
var currentKeyId = mb_key_ids[i];
- mod_key_Keyhandler(currentKeyId);
+ mod_key_Keyhandler(e, currentKeyId);
-function mod_key_Keyhandler(frameName){
+function mod_key_Keyhandler(event, frameName){
if(frameName){
var code = eval("window.frames['"+frameName+"'].event.keyCode");
focus();
@@ -78,10 +79,11 @@
else{
var code = event.keyCode;
- if(code == 187 || code == 107){
+ //console.log(code);
+ if(code == 187 || code == 107 || code == 171){
zoom(mod_key_map,true, '2.0');
- if(code == 189 || code == 109){
+ if(code == 189 || code == 109 || code == 173){
zoom(mod_key_map,false, '2.0');
if(code == 32 || code == 13){
@@ -100,94 +102,3 @@
mb_panMap(mod_key_map,"S");
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_key.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "var mod_key_map = '".$e_target[0]."';";
-$sql = "SELECT e_id,e_element FROM gui_element WHERE (e_element = 'body' or e_element = 'iframe') AND fkey_gui_id = $1 AND e_public = 1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
- $ids[$cnt] = $row["e_id"];
- $elements[$cnt] = $row["e_element"];
- $cnt++;
-echo "var mb_key_elements = new Array(";
-for($i=0; $i < count($elements); $i++){
- if($i > 0){
- echo ",";
- echo "'".$elements[$i]."'";
-echo ");";
-echo "var mb_key_ids = new Array(";
-for($i=0; $i < count($ids); $i++){
- if($i > 0){ echo ",";}
- echo "'".$ids[$i]."'";
-echo ");";
-if(ie){
- mb_registerInitFunctions('mod_key_init()');
-function mod_key_init(){
- for(var i=0; i<mb_key_elements.length; i++){
- if(mb_key_elements[i] == "body"){
- document.getElementById(mb_key_ids[i]).onkeydown = mod_key_Keyhandler;
- else{
- window.frames[mb_key_ids[i]].document.getElementsByTagName("body")[0].onkeydown = new Function("mod_key_Keyhandler('" +mb_key_ids[i] + "');");
- if(frameName){
- var code = eval("window.frames['"+frameName+"'].event.keyCode");
- focus();
- else{
- var code = event.keyCode;
- zoom(mod_key_map,true, '2.0');
- zoom(mod_key_map,false, '2.0');
- if(code == 32 || code == 13){
- setMapRequest(mod_key_map);
- if(code == 37){
- mb_panMap(mod_key_map,"W");
- if(code == 38){
- mb_panMap(mod_key_map,"N");
- if(code == 39){
- mb_panMap(mod_key_map,"E");
- if(code == 40){
- mb_panMap(mod_key_map,"S");
More information about the Mapbender_commits
