[Mapbender-commits] r8656 - branches/2.7/http/javascripts
svn_mapbender at osgeo.org
Fri Jun 14 01:48:22 PDT 2013
Author: verenadiewald
Date: 2013-06-14 01:48:22 -0700 (Fri, 14 Jun 2013)
New Revision: 8656
branches/2.7/http/javascripts/mod_key.php
correct event and key handling for current browsers
Modified: branches/2.7/http/javascripts/mod_key.php
--- branches/2.7/http/javascripts/mod_key.php 2013-06-14 08:47:55 UTC (rev 8655)
+++ branches/2.7/http/javascripts/mod_key.php 2013-06-14 08:48:22 UTC (rev 8656)
@@ -46,16 +46,17 @@
echo ");";
-if(ie){
+//if(ie){
mb_registerInitFunctions('mod_key_init()');
function mod_key_init(){
for(var i=0; i<mb_key_elements.length; i++){
if(mb_key_elements[i] == "body"){
- $('body').live('keydown', function(e) {
- var tag = e.target.tagName.toLowerCase();
+ $('body').focus();
+ $(document).bind('keydown', function(e) {
+ var tag = e.target.tagName.toLowerCase();
if (tag != 'input' && tag != 'textarea') {
- mod_key_Keyhandler();
+ mod_key_Keyhandler(e);
@@ -64,13 +65,13 @@
var currentKeyId = mb_key_ids[i];
- mod_key_Keyhandler(currentKeyId);
+ mod_key_Keyhandler(e, currentKeyId);
-function mod_key_Keyhandler(frameName){
+function mod_key_Keyhandler(event, frameName){
if(frameName){
var code = eval("window.frames['"+frameName+"'].event.keyCode");
focus();
@@ -78,10 +79,11 @@
else{
var code = event.keyCode;
- if(code == 187 || code == 107){
+ //console.log(code);
+ if(code == 187 || code == 107 || code == 171){
zoom(mod_key_map,true, '2.0');
- if(code == 189 || code == 109){
+ if(code == 189 || code == 109 || code == 173){
zoom(mod_key_map,false, '2.0');
if(code == 32 || code == 13){
More information about the Mapbender_commits
