[Mapbender-commits] r8617 - in trunk/mapbender: http/classes http/javascripts http/php http_auth/http
svn_mapbender at osgeo.org
Wed May 8 07:49:34 PDT 2013
Author: armin11
Date: 2013-05-08 07:49:34 -0700 (Wed, 08 May 2013)
New Revision: 8617
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/http/php/mod_getServiceDisclaimer.php
trunk/mapbender/http/php/mod_getWmcDisclaimer.php
trunk/mapbender/http/php/mod_layerISOMetadata.php
trunk/mapbender/http/php/wms.php
trunk/mapbender/http_auth/http/index.php
Fix some small problem when showing disclaimer and less exceptions
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/classes/class_user.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -63,7 +63,7 @@
$this->id = Mapbender::session()->get("mb_user_id");
if ($this->id == '' || !isset($this->id)) {
$this->id = (integer)PUBLIC_USER;
- $e = new mb_exception("class_user: no user_id found in session use PUBLIC_USER with id - ".PUBLIC_USER." - !");
+ $e = new mb_notice("class_user: no user_id found in session use PUBLIC_USER with id - ".PUBLIC_USER." - !");
try{
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -439,7 +439,7 @@
$touServiceConnector = new connector($mapbenderProtocol."localhost".$_SERVER['SCRIPT_NAME']."/../../php/mod_getServiceDisclaimer.php?resource=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
$touForWMS = $touServiceConnector->file;
//add only those who have no special tou defined -
- if ($touForWMS != ''){
+ if ($touForWMS != 'free'){
$tou .= $touHeader.$touForWMS;
//set the tou to be accepted - TODO maybe do this after the button which deletes the message window - from a ajax request.
Modified: trunk/mapbender/http/php/mod_getServiceDisclaimer.php
--- trunk/mapbender/http/php/mod_getServiceDisclaimer.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/php/mod_getServiceDisclaimer.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -28,8 +28,7 @@
$testMatch = $_REQUEST["id"];
$pattern = '/^[\d]*$/';
if (!preg_match($pattern,$testMatch)){
- //echo 'id: <b>'.$testMatch.'</b> is not valid.<br/>';
- echo 'Parameter <b>id</b> is not valid (integer).<br/>';
+ echo 'id: <b>'.$testMatch.'</b> is not valid.<br/>';
die();
$id = (integer)$testMatch;
@@ -40,8 +39,7 @@
//validate to wms, wfs
$testMatch = $_REQUEST["type"];
if (!($testMatch == 'wms' or $testMatch == 'wfs')){
- //echo 'type: <b>'.$testMatch.'</b> is not valid.<br/>';
- echo 'Parameter <b>type</b> is not valid (wms,wfs).<br/>';
+ echo 'type: <b>'.$testMatch.'</b> is not valid.<br/>';
die();
$type = $testMatch;
@@ -52,8 +50,7 @@
$testMatch = $_REQUEST["languageCode"];
if (!($testMatch == 'de' or $testMatch == 'en' or $testMatch == 'fr')){
- echo 'Parameter <b>type</b> is not valid (de,fr,en).<br/>';
die();
$languageCode = $testMatch;
@@ -64,8 +61,7 @@
$testMatch = $_REQUEST["withHeader"];
if (!($testMatch == 'true' or $testMatch == 'false')){
- echo 'Parameter <b>withHeader</b> is not valid (true or false).<br/>';
die();
if ($testMatch == 'true'){
@@ -80,8 +76,7 @@
$testMatch = $_REQUEST["asTable"];
- echo 'Parameter <b>asTable</b> is not valid (true or false).<br/>';
die();
@@ -329,7 +324,7 @@
} else {
echo $htmlHeader['noInformation']."<br>" ;
- echo "";//since it is not neccessary to give information about nothing ;-)
+ echo "free";//since it is not neccessary to give information about nothing ;-)
Modified: trunk/mapbender/http/php/mod_getWmcDisclaimer.php
--- trunk/mapbender/http/php/mod_getWmcDisclaimer.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/php/mod_getWmcDisclaimer.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -26,8 +26,7 @@
die();
@@ -40,8 +39,7 @@
//look for whitelist in mapbender.conf
$HOSTNAME_WHITELIST_array = explode(",",HOSTNAME_WHITELIST);
if (!in_array($testMatch,$HOSTNAME_WHITELIST_array)) {
- //echo "Requested hostname <b>".$testMatch."</b> not whitelist! Please control your mapbender.conf.";
- echo "Requested <b>hostName</b> not in whitelist! Please control your mapbender.conf.";
+ echo "Requested hostname <b>".$testMatch."</b> not whitelist! Please control your mapbender.conf.";
$e = new mb_notice("Whitelist: ".HOSTNAME_WHITELIST);
$e = new mb_notice($testMatch." not found in whitelist!");
die();
@@ -56,8 +54,7 @@
- echo 'Parameter <b>languageCode</b> is not valid (de,en,fr).<br/>';
die();
@@ -113,7 +110,7 @@
$touServiceConnector = new connector("http://localhost".$_SERVER['SCRIPT_NAME']."/../mod_getServiceDisclaimer.php?type=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
- if ($touForWMS == ''){
+ if ($touForWMS == 'free'){
$wmstou = $translation['noTouInformation'];
} else {
$wmstou = $touForWMS;
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -108,7 +108,7 @@
//infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
if (!isset($mapbenderMetadata['fkey_mb_group_id']) or is_null($mapbenderMetadata['fkey_mb_group_id']) or $mapbenderMetadata['fkey_mb_group_id'] == 0){
- $e = new mb_exception("mod_layerISOMetadata.php: fkey_mb_group_id not found!");
+ $e = new mb_notice("mod_layerISOMetadata.php: fkey_mb_group_id not found!");
//Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
$sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
$vDep = array($mapbenderMetadata['wms_owner']);
@@ -116,7 +116,7 @@
$resDep = db_prep_query($sqlDep, $vDep, $tDep);
$departmentMetadata = db_fetch_array($resDep);
} else {
- $e = new mb_exception("mod_layerISOMetadata.php: fkey_mb_group_id found!");
+ $e = new mb_notice("mod_layerISOMetadata.php: fkey_mb_group_id found!");
$sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
$vDep = array($mapbenderMetadata['fkey_mb_group_id']);
$tDep = array('i');
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http/php/wms.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -210,6 +210,9 @@
$monitor = new Layer_load_count();
$monitor->increment($layerId);
// START TO CREATE CAPABILITIES DOC
@@ -279,15 +282,16 @@
//url maybe original if proxy is not active
//set new capabilities url:
+//$e = new mb_exception($urlPrefix.$_SERVER["HTTP_HOST"].$_SERVER["PHP_SELF"]."?".$_SERVER["QUERY_STRING"]);
$tmpOR = $urlPrefix.$_SERVER["HTTP_HOST"].$_SERVER["PHP_SELF"]."?".$_SERVER["QUERY_STRING"];
$tmpOR = str_replace(SERVERIP, SERVERNAME, $tmpOR);
+//$e = new mb_exception($tmpOR);
$wms_row['wms_getcapabilities'] = $tmpOR;
if ($inspire) {
$wms_row['wms_getcapabilities'] .= "&INSPIRE=1";
+$e = new mb_notice($wms_row['wms_getcapabilities']);
$publicHasPermission=$admin->getLayerPermission($wms_row['wms_id'],$wms_row['layer_name'],PUBLIC_USER);
if ($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
if ($inspire) {
@@ -317,14 +321,23 @@
- //Creating the "OnlineResource" node
- $onlineResource = $doc->createElement("OnlineResource");
+//Creating the "OnlineResource" node
+//if($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
+ $onlineResource = $doc->createElement("OnlineResource");
$onlineResource = $service->appendChild($onlineResource);
$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
$onlineResource->setAttribute("xlink:href", $wms_row['wms_getcapabilities']);
+/* $onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId."&".session_name()."=".$sessionId;
+ if (isset($_SERVER["HTTPS"])) {
+ $onlRes = "https://" . $onlRes;
+ else {
+ $onlRes = "http://" . $onlRes;
+ //$onlineResource->setAttribute("xlink:href", $onlRes);
$onlineResource->setAttribute("xlink:type", "simple");
#Insert contact information
#Creating "Contact Information" node
@@ -530,22 +543,53 @@
$get = $HTTP->appendChild($get);
#Creating the "OnlineResource" node
+//if ($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
$onlineResource = $get->appendChild($onlineResource);
$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+/* $onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId;
+ if ($inspire) {
+ $onlRes = $onlRes."&INSPIRE=1";
+ else {
#Creating the "Post" node
$post = $doc->createElement("Post");
$post = $HTTP->appendChild($post);
$onlineResource = $post->appendChild($onlineResource);
+ if ($inspire) {
+ $onlRes = $onlRes."&INSPIRE=1&";
+ else {
+ $onlineResource->setAttribute("xlink:href", $onlRes);
#GetMap
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php 2013-05-06 14:10:59 UTC (rev 8616)
+++ trunk/mapbender/http_auth/http/index.php 2013-05-08 14:49:34 UTC (rev 8617)
@@ -90,7 +90,7 @@
unset($auth);
-$e = new mb_exception("REQUEST to HTTP_AUTH: ".strtolower($reqParams['request']));
+$e = new mb_notice("REQUEST to HTTP_AUTH: ".strtolower($reqParams['request']));
//what the proxy does
switch (strtolower($reqParams['request'])) {
@@ -291,7 +291,7 @@
function getFeatureInfo($url){
global $reqParams;
- $e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
+ $e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
header("Content-Type: ".$reqParams['info_format']);
if (func_num_args() == 2) { //new for HTTP Authentication
$auth = func_get_arg(1);
More information about the Mapbender_commits
