[Mapbender-commits] r8624 - in trunk/mapbender/http/extensions/mobilemap: _build js mod_mapbender
svn_mapbender at osgeo.org
Tue May 21 09:02:37 PDT 2013
Author: armin11
Date: 2013-05-21 09:02:37 -0700 (Tue, 21 May 2013)
New Revision: 8624
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
Update for owsproxy secured feature info request in mobile client
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-05-21 15:08:21 UTC (rev 8623)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-05-21 16:02:37 UTC (rev 8624)
@@ -671,7 +671,7 @@
if(querylayer.length>0){
// Abfrage des ausgewählten Layers
var featureurl = querylayer.attr('getmapurl')
- + '&wms=SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1'
+ + '&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1'
+ '&mapfile='+ querylayer.attr('name')
+ '&layers=' + querylayer.attr('name') + '&QUERY_LAYERS=' + querylayer.attr('name')
+ '&SRS=' + featurequerySrc
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-05-21 15:08:21 UTC (rev 8623)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-05-21 16:02:37 UTC (rev 8624)
@@ -23,9 +23,9 @@
text:" "}).click(function(){zoomToBbox(k);$.mobile.changePage($("#mappage"),pageTransition)}));n.append("</br><p>"+l+"%</p>");g=$("<td></td>");g.append("<p><b>"+e+"</b></p><p>"+f+"</p>");g.append("<p><b>"+b+"</b></p><p>"+d+"</p>");m.append(n);m.append(g);j.append(m);h.append(j);c.append(h);return c}var maxlayers=5,maxresults=40,baseinfo=[];searchUrl="mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&maxResults="+maxresults;
function addmyLayer(){OpenLayers.Control.Click=OpenLayers.Class(OpenLayers.Control,{defaultHandlerOptions:{single:!0,pixelTolerance:0,stopSingle:!1},initialize:function(a){this.handlerOptions=OpenLayers.Util.applyDefaults((a||{}).handlerOptions||{},this.defaultHandlerOptions);OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Click(this,{click:this.onClick},this.handlerOptions)},onClick:function(a){var b=map.getLonLatFromViewPortPx(a.xy),c=$("#ownlist").find(".query_checked").parent(),
d=$("#select-lang").val(),e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);(e="p"===$("#select-feature-info").val()?!0:!1)?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):($.mobile.changePage($("#featureinforesult"),pageTransition),$("#ficontentdiv").text(window.lang.convert("Bitte warten...")));
-0<c.length?(a=c.attr("getmapurl")+"&wms=SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),setMarkerhint("Abfrageergebnis:",a)):(a=
-$('<iframe src="'+a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterquery.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});
-$("#mapbendersearchfield").live("keypress",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
+0<c.length?(a=c.attr("getmapurl")+"&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),setMarkerhint("Abfrageergebnis:",a)):(a=$('<iframe src="'+
+a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterquery.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("#mapbendersearchfield").live("keypress",
+function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
getInfo=function(a){$("#info_content").empty();$("#info_content").append(a);$("#info").popup("open")};function getOpenlayersIndex(a){for(var b=0;b<map.layers.length;b++)if(map.layers[b].name==a)return b;return-1}function addOpenlayer(a,b,c){a=new OpenLayers.Layer.WMS(a,c,{layers:b,format:"image/png",transparent:"TRUE",transitionEffect:"resize"},{projection:mapProj,units:projUnits,opacity:0.8,singleTile:!0,isBaseLayer:!1,visibility:!0,alwaysInRange:!0});map.addLayer(a);map.setLayerIndex(a,0)}
function removeOpenlayer(a){a=getOpenlayersIndex(a);0<=a&&map.removeLayer(map.layers[a])}function setOpenBaselayer(a){a=getOpenlayersIndex(a);0<=a&&map.setBaseLayer(map.layers[a])}function selectOpenlayer(a,b){var c=getOpenlayersIndex(a);0<=c&&map.layers[c].setVisibility(b)}
Modified: trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-05-21 15:08:21 UTC (rev 8623)
+++ trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-05-21 16:02:37 UTC (rev 8624)
@@ -23,9 +23,9 @@
Modified: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-05-21 15:08:21 UTC (rev 8623)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-05-21 16:02:37 UTC (rev 8624)
@@ -88,7 +88,7 @@
More information about the Mapbender_commits
