[Mapbender-commits] r8625 - in trunk/mapbender/http/extensions/mobilemap: _build js js/dev mod_mapbender query query/mapserver query/mapserver/dhm_rlp
svn_mapbender at osgeo.org
Wed May 22 07:44:11 PDT 2013
Author: armin11
Date: 2013-05-22 07:44:11 -0700 (Wed, 22 May 2013)
New Revision: 8625
Added:
trunk/mapbender/http/extensions/mobilemap/query/mapserver/
trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm.map
trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm_rlp/
trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm_rlp/dhm.rlp.tfw
trunk/mapbender/http/extensions/mobilemap/query/mapserver/wms_dhm_template.map
trunk/mapbender/http/extensions/mobilemap/query/rasterqueryWms.php
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/js/dev/1_ngms_olextent.js
trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php
New possibility to integrate a wms raster resource to get height information for the mobilemap extension.
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.js 2013-05-22 14:44:11 UTC (rev 8625)
@@ -52,7 +52,7 @@
- //Default Koordinatenabfrage / Rasterquery
+ //Default Koordinatenabfrage / Rasterquery / RasterqueryWms
if(querylayer == "dhm"){
setMarkerhint(window.lang.convert('Meldung:'),window.lang.convert('bitte warten...'));
var featureurl = 'query/rasterquery.php?'
@@ -61,6 +61,15 @@
loadFeature(featureurl);
//alert("Um eine Ebene abzufragen selektieren Sie bitte unter Abfrage --> Abfrageebene w\u00e4hlen die gew\u00fcnschte Ebenen aus!");
+ else if(querylayer == "dhmWms"){
+ setMarkerhint(window.lang.convert('Meldung:'),window.lang.convert('bitte warten...'));
+ var featureurl = 'query/rasterqueryWms.php?'
+ + 'coord=' + lonlat.lon + ', ' + lonlat.lat
+ + '&lang=' + actuallang;
+ // alert("lon: "+lonlat.lon+" - lat: ".lonlat.lat);
+ //loadFeature(featureurl);
+ //alert("Um eine Ebene abzufragen selektieren Sie bitte unter Abfrage --> Abfrageebene w\u00e4hlen die gew\u00fcnschte Ebenen aus!");
else if(querylayer == "pois"){
var activepoilayer = poilayer.params.LAYERS;
var featureurl = 'query/poiquery.php?'
@@ -99,7 +108,7 @@
//Abfrageebene darstellen
showQuerylayer: function(){
var querylayer = $('#queryselect').val();
- if(querylayer == "dhm"){
+ if(querylayer == "dhm" || querylayer == "dhmWms"){
setMarkerhint(window.lang.convert('Standardabfrage:'),window.lang.convert('Koordinaten + Hoehe'));
else{
@@ -114,7 +123,7 @@
function showQuerylayer(){
else{
@@ -130,9 +139,9 @@
url: myurl,
//data: {layers:mylayers,imgsize:myimgsize},
success: function(ergebnis){
- alert(myurl);
+ //alert(myurl);
if(ergebnis){
- alert(ergebnis);
+ //alert(ergebnis);
if(ergebnis.length < 5){
ergebnis = window.lang.convert('Kein Ergebnis!');
@@ -661,11 +670,17 @@
} else {
var fiPopUp = false;
- if (fiPopUp) {
+ if (fiPopUp == true ) {
} else {
- $.mobile.changePage($("#featureinforesult"),pageTransition);
- $("#ficontentdiv").text(window.lang.convert("Bitte warten..."));
+ if (querylayer.length == 0) {
+ //featureInfo on dhm
+ } else {
+ $.mobile.changePage($("#featureinforesult"),pageTransition);
+ $("#ficontentdiv").text(window.lang.convert("Bitte warten..."));
if(querylayer.length>0){
@@ -700,7 +715,9 @@
} else {
// Standardabfrage, falls keiner ausgewählt ist
- var featureurl = 'query/rasterquery.php?coord='+lonlat.lon+ ', '+lonlat.lat+'&lang='+actuallang;
+ //d.h. dhm!
+ var featureurl = 'query/rasterqueryWms.php?coord='+lonlat.lon+ ', '+lonlat.lat+'&lang='+actuallang;
+ //alert(featureurl);
Modified: trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/_build/ngms_event.min.js 2013-05-22 14:44:11 UTC (rev 8625)
@@ -1,8 +1,8 @@
OpenLayers.Control.Click=OpenLayers.Class(OpenLayers.Control,{defaultHandlerOptions:{single:!0,pixelTolerance:0,stopSingle:!1},initialize:function(a){this.handlerOptions=OpenLayers.Util.applyDefaults((a||{}).handlerOptions||{},this.defaultHandlerOptions);OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Click(this,{click:this.onClick},this.handlerOptions)},onClick:function(a){var b=map.getLonLatFromViewPortPx(a.xy),c=$("#queryselect").val(),d=$("#select-lang").val(),
-e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);"dhm"==c?(setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")),a="query/rasterquery.php?coord="+b.lon+", "+b.lat+"&lang="+d):"pois"==c?a="query/poiquery.php?qx="+b.lon+"&qy="+b.lat+"&qlayer="+poilayer.params.LAYERS+
-"&qextent="+map.getExtent().toBBOX()+"&qsize="+map.size.w+" "+map.size.h+"&lang="+d:(setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")),a="query/proxy.php?wms=SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c+"&layers="+c+"&QUERY_LAYERS="+c+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html");loadFeature(a)},showQuerylayer:function(){var a=$("#queryselect").val();
-"dhm"==a?setMarkerhint(window.lang.convert("Standardabfrage:"),window.lang.convert("Koordinaten + Hoehe")):setMarkerhint(window.lang.convert("aktuelle Abfrageebene:"),a)},CLASS_NAME:"OpenLayers.Control.Click"});function showQuerylayer(){var a=$("#queryselect").val();"dhm"==a?setMarkerhint(window.lang.convert("Standardabfrage:"),window.lang.convert("Koordinaten + Hoehe")):setMarkerhint(window.lang.convert("aktuelle Abfrageebene:"),a)}
-function loadFeature(a){$.ajax({type:"GET",url:a,success:function(b){alert(a);b&&(alert(b),5>b.length&&(b=window.lang.convert("Kein Ergebnis!")),setMarkerhint(window.lang.convert("Abfrageergebnis:"),b))}})}
+e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);"dhm"==c?(setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")),a="query/rasterquery.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a)):"dhmWms"==c?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):
+("pois"==c?a="query/poiquery.php?qx="+b.lon+"&qy="+b.lat+"&qlayer="+poilayer.params.LAYERS+"&qextent="+map.getExtent().toBBOX()+"&qsize="+map.size.w+" "+map.size.h+"&lang="+d:(setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")),a="query/proxy.php?wms=SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c+"&layers="+c+"&QUERY_LAYERS="+c+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+
+"&INFO_FORMAT=text/html"),loadFeature(a))},showQuerylayer:function(){var a=$("#queryselect").val();"dhm"==a||"dhmWms"==a?setMarkerhint(window.lang.convert("Standardabfrage:"),window.lang.convert("Koordinaten + Hoehe")):setMarkerhint(window.lang.convert("aktuelle Abfrageebene:"),a)},CLASS_NAME:"OpenLayers.Control.Click"});
+function showQuerylayer(){var a=$("#queryselect").val();"dhm"==a||"dhmWms"==a?setMarkerhint(window.lang.convert("Standardabfrage:"),window.lang.convert("Koordinaten + Hoehe")):setMarkerhint(window.lang.convert("aktuelle Abfrageebene:"),a)}function loadFeature(a){$.ajax({type:"GET",url:a,success:function(a){a&&(5>a.length&&(a=window.lang.convert("Kein Ergebnis!")),setMarkerhint(window.lang.convert("Abfrageergebnis:"),a))}})}
OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:!1,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.eTop||(this.eTop=document.createElement("div"),this.eTop.className=this.displayClass+"Top",this.div.appendChild(this.eTop),this.eTop.style.visibility=""==this.topOutUnits||""==this.topInUnits?"hidden":"visible",this.eBottom=document.createElement("div"),
this.eBottom.className=this.displayClass+"Bottom",this.div.appendChild(this.eBottom),this.eBottom.style.visibility=""==this.bottomOutUnits||""==this.bottomInUnits?"hidden":"visible");this.map.events.register("moveend",this,this.update);this.update();return this.div},getBarLen:function(a){var b=parseInt(Math.log(a)/Math.log(10)),b=Math.pow(10,b),a=parseInt(a/b);return(5<a?5:2<a?2:1)*b},update:function(){var a=this.map.getResolution();if(a){var b=this.map.getUnits(),c=OpenLayers.INCHES_PER_UNIT,d=this.maxWidth*
a*c[b],e=1;!0===this.geodesic&&(e=(this.map.getGeodesicPixelSize().w||1.0E-6)*this.maxWidth/(d/c.km),d*=e);var f,g;1E5<d?(f=this.topOutUnits,g=this.bottomOutUnits):(f=this.topInUnits,g=this.bottomInUnits);var h=d/c[f],j=d/c[g],d=this.getBarLen(h),j=this.getBarLen(j),h=d/c[b]*c[f],j=j/c[b]*c[g],b=h/a/e,a=j/a/e;"visible"==this.eBottom.style.visibility&&(this.eBottom.style.width=Math.round(a)+"px");"visible"==this.eTop.style.visibility&&(this.eTop.style.width=Math.round(b)+"px",this.eTop.innerHTML=d+
@@ -22,10 +22,10 @@
c.append($("<div>",{"class":"icon layer_visibility layer_checked",text:" "}).click(function(){switchVisibility($(this).parent())}));c.append($("<div>",{"class":"icon move arrow_up",text:" "}).click(function(){up(a)}));h=$('<div class="collapsible unselected" data-role="collapsible" data-collapsed="true" data-theme="a" data-content-theme="c" data-inset="true"></div>');h.append("<h3>"+b+"</h3>");var j=$("<table></table>"),m=$("<tr></tr>"),n=$('<td class="layerinfo"></td>');g&&n.append($("<div>",{"class":"icon layer_preview",
text:" "}).click(function(){zoomToBbox(k);$.mobile.changePage($("#mappage"),pageTransition)}));n.append("</br><p>"+l+"%</p>");g=$("<td></td>");g.append("<p><b>"+e+"</b></p><p>"+f+"</p>");g.append("<p><b>"+b+"</b></p><p>"+d+"</p>");m.append(n);m.append(g);j.append(m);h.append(j);c.append(h);return c}var maxlayers=5,maxresults=40,baseinfo=[];searchUrl="mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&maxResults="+maxresults;
function addmyLayer(){OpenLayers.Control.Click=OpenLayers.Class(OpenLayers.Control,{defaultHandlerOptions:{single:!0,pixelTolerance:0,stopSingle:!1},initialize:function(a){this.handlerOptions=OpenLayers.Util.applyDefaults((a||{}).handlerOptions||{},this.defaultHandlerOptions);OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Click(this,{click:this.onClick},this.handlerOptions)},onClick:function(a){var b=map.getLonLatFromViewPortPx(a.xy),c=$("#ownlist").find(".query_checked").parent(),
-d=$("#select-lang").val(),e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);(e="p"===$("#select-feature-info").val()?!0:!1)?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):($.mobile.changePage($("#featureinforesult"),pageTransition),$("#ficontentdiv").text(window.lang.convert("Bitte warten...")));
-0<c.length?(a=c.attr("getmapurl")+"&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),setMarkerhint("Abfrageergebnis:",a)):(a=$('<iframe src="'+
-a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterquery.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("#mapbendersearchfield").live("keypress",
-function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
+d=$("#select-lang").val(),e=new OpenLayers.Geometry.Point(b.lon,b.lat),f=new OpenLayers.Geometry.Point(b.lon,b.lat);vector_marker.removeAllFeatures();vector_marker.addFeatures([new OpenLayers.Feature.Vector(e,{},olSearchSymbol),new OpenLayers.Feature.Vector(f,{},olFeaturequerySymbol)]);e="p"===$("#select-feature-info").val()?!0:!1;!0==e?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):0==c.length?setMarkerhint(window.lang.convert("Meldung:"),window.lang.convert("bitte warten...")):
+($.mobile.changePage($("#featureinforesult"),pageTransition),$("#ficontentdiv").text(window.lang.convert("Bitte warten...")));0<c.length?(a=c.attr("getmapurl")+"&SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1&mapfile="+c.attr("name")+"&layers="+c.attr("name")+"&QUERY_LAYERS="+c.attr("name")+"&SRS="+featurequerySrc+"&BBOX="+map.getExtent().toBBOX()+"&WIDTH="+map.size.w+"&HEIGHT="+map.size.h+"&X="+a.xy.x+"&Y="+a.xy.y+"&INFO_FORMAT=text/html&FORMAT=image/png&STYLES=",e?(a=$('<iframe src="'+a+'" class="query_iframe"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),
+setMarkerhint("Abfrageergebnis:",a)):(a=$('<iframe src="'+a+'" class="query_iframe_full"><p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'),$("#ficontentdiv").text(""),$("#ficontentdiv").append(a))):(a="query/rasterqueryWms.php?coord="+b.lon+", "+b.lat+"&lang="+d,loadFeature(a))},CLASS_NAME:"OpenLayers.Control.Click"});$("#mapbenderbut").click(function(){$.mobile.changePage($("#mod_mapbender"),pageTransition);refresh()});$("#mapbendersearchformbut").click(function(){searchMaps(searchUrl+
+"&searchText="+$("#mapbendersearchfield").val())});$("#mapbendersearchfield").live("keypress",function(a){13===a.keyCode&&searchMaps(searchUrl+"&searchText="+$("#mapbendersearchfield").val())});$("div[data-role=collapsible]").live("expand",function(){$("div[data-role=collapsible]").not($(this)).trigger("collapse")});$(".addToMapBut").click(function(){$("div[data-role=collapsible]").not(".ui-collapsible-collapsed").trigger("collapse");$.mobile.changePage($("#mappage"),pageTransition)});addBaselayers()}
function preview(a,b,c){$.ajax({previewurl:a,layerid:b,bbox:c,success:function(){$("#preview").find("div[data-role=content]").empty();$("#preview").find("div[data-role=content]").append('<img src="'+$(this).attr("previewurl")+'" alt="image" style="width:200px;">');var a=$(this).attr("bbox"),b=$(this).attr("layerid");$("#preview_zoom").click(function(){getOpenlayersIndex(b);zoomToBbox(a);$.mobile.changePage($("#mappage"),pageTransition)});$("#preview").popup("open")}})}
getInfo=function(a){$("#info_content").empty();$("#info_content").append(a);$("#info").popup("open")};function getOpenlayersIndex(a){for(var b=0;b<map.layers.length;b++)if(map.layers[b].name==a)return b;return-1}function addOpenlayer(a,b,c){a=new OpenLayers.Layer.WMS(a,c,{layers:b,format:"image/png",transparent:"TRUE",transitionEffect:"resize"},{projection:mapProj,units:projUnits,opacity:0.8,singleTile:!0,isBaseLayer:!1,visibility:!0,alwaysInRange:!0});map.addLayer(a);map.setLayerIndex(a,0)}
function removeOpenlayer(a){a=getOpenlayersIndex(a);0<=a&&map.removeLayer(map.layers[a])}function setOpenBaselayer(a){a=getOpenlayersIndex(a);0<=a&&map.setBaseLayer(map.layers[a])}function selectOpenlayer(a,b){var c=getOpenlayersIndex(a);0<=c&&map.layers[c].setVisibility(b)}
Modified: trunk/mapbender/http/extensions/mobilemap/js/dev/1_ngms_olextent.js
--- trunk/mapbender/http/extensions/mobilemap/js/dev/1_ngms_olextent.js 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/js/dev/1_ngms_olextent.js 2013-05-22 14:44:11 UTC (rev 8625)
@@ -51,7 +51,7 @@
@@ -60,6 +60,15 @@
@@ -98,7 +107,7 @@
else{
@@ -113,7 +122,7 @@
else{
@@ -129,9 +138,9 @@
url: myurl,
- alert(myurl);
+ //alert(myurl);
if(ergebnis){
- alert(ergebnis);
Modified: trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js
--- trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/js/ngms_event.min.js 2013-05-22 14:44:11 UTC (rev 8625)
@@ -1,8 +1,8 @@
@@ -22,10 +22,10 @@
Modified: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js 2013-05-22 14:44:11 UTC (rev 8625)
@@ -78,11 +78,17 @@
} else {
- if (fiPopUp) {
} else {
+ } else {
@@ -117,7 +123,9 @@
} else {
+ //d.h. dhm!
Added: trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm.map
--- trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm.map (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm.map 2013-05-22 14:44:11 UTC (rev 8625)
@@ -0,0 +1,10 @@
+MAP
+NAME "test"
+LAYER # raster layer
+ NAME "mydhm"
+ DATA "dhm_rlp/dhm.rlp.tif"
+ STATUS default
+ TYPE RASTER
+ TEMPLATE "template/query.html"
+END
+END
Added: trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm_rlp/dhm.rlp.tfw
--- trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm_rlp/dhm.rlp.tfw (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/query/mapserver/dhm_rlp/dhm.rlp.tfw 2013-05-22 14:44:11 UTC (rev 8625)
@@ -0,0 +1,6 @@
+ 9.99671659
+ 0.00000000
+ 0.00000000
+ -9.99671659
+ 288578.552
+ 5650307.803
Added: trunk/mapbender/http/extensions/mobilemap/query/mapserver/wms_dhm_template.map
--- trunk/mapbender/http/extensions/mobilemap/query/mapserver/wms_dhm_template.map (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/query/mapserver/wms_dhm_template.map 2013-05-22 14:44:11 UTC (rev 8625)
@@ -0,0 +1,97 @@
+MAP
+ NAME 'hdm_query'
+ SIZE 1000 1000
+ UNITS meters
+ SYMBOLSET '../symbols/symbolsatkis_neu.sym'
+ FONTSET '../fonts/fonts.list'
+ EXTENT 290000 5420000 466000 5648000
+ PROJECTION
+ 'init=epsg:25832'
+ END
+ IMAGECOLOR 192 192 192
+ IMAGEQUALITY 86
+#http://mgeospatial.wordpress.com/2010/01/16/how-to-produce-8bits-agg-homemade-colors-palette-with-mapserver/
+#OUTPUTFORMAT
+# NAME "png8bitaggauto"
+# DRIVER "AGG/PNG"
+# MIMETYPE "image/png"
+# IMAGEMODE "pc256"
+# EXTENSION "png"
+# FORMATOPTION "TRANSPARENT=ON"
+# FORMATOPTION "INTERLACE=OFF"
+# FORMATOPTION "QUANTIZE_FORCE=ON"
+# FORMATOPTION "QUANTIZE_COLORS=256"
+#END
+OUTPUTFORMAT
+ NAME png
+ DRIVER AGG/PNG
+ MIMETYPE "image/png"
+ IMAGEMODE RGBA
+ EXTENSION "png"
+ FORMATOPTION "INTERLACE=OFF"
+END
+ LEGEND
+ IMAGECOLOR 255 255 255
+ STATUS ON
+ KEYSIZE 18 12
+ LABEL
+ TYPE BITMAP
+ SIZE MEDIUM
+ COLOR 0 0 0
+ END
+ END
+ WEB
+ IMAGEPATH '/data/umn/tmp/'
+ IMAGEURL '/data/umn/tmp/'
+ METADATA
+ 'wms_title' 'DHM RP Geotiff'
+ 'wms_abstract' 'DHM RP Geotiff'
+ 'wms_onlineresource' 'http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map'
+#http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=wms
+ 'wms_srs' 'EPSG:25832 EPSG:31466 EPSG:31467 EPSG:4326 EPSG:4258 EPSG:900913'
+ 'wms_extent' '290000 5420000 466000 5648000'
+ 'ows_keywordlist' 'DHM'
+ 'ows_fees' 'none' #Gebuehren
+ 'ows_accessconstraints' 'none' #Zugriffsbeschraenkungen
+ 'ows_addresstype' 'postal'
+ 'ows_address' 'Ferdinand-Sauerbruch-Str. 15'
+ 'ows_city' 'Koblenz'
+ 'ows_stateorprovince' 'RLP'
+ 'ows_postcode' '56073'
+ 'ows_country' 'Deutschland'
+ 'ows_contactperson' 'Armin Retterath'
+ 'ows_contactinformation' ''
+ 'ows_contactorganization' 'KGSt. GDI-RP'
+ 'ows_contactposition' ''
+ 'ows_contactelectronicmailaddress''kontakt at geoportal.rlp.de'
+ 'wms_contactfacsimiletelephone' '0261-492466'
+ 'wms_contactvoicetelephone' '0261-492472'
+ 'wms_enable_request' '*'
+ 'wms_encoding' 'UTF-8'
+ END
+ END
+LAYER
+ NAME "mydhm"
+ DUMP TRUE
+ TYPE RASTER
+ TOLERANCE 0
+ TOLERANCEUNITS pixels
+ STATUS DEFAULT
+ PROCESSING "SCALE=AUTO"
+ #PROCESSING “BANDS=1,2,3″
+ #OFFSITE 71 74 65
+ TEMPLATE "../dhm_template.html"
+ METADATA
+ 'wms_title' 'DHM Layer'
+ 'wms_getfeatureinfo_formatlist' 'text/html,text/plain'
+ 'gml_include_items' 'all'
+ END
+END
+END
Modified: trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php
--- trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php 2013-05-21 16:02:37 UTC (rev 8624)
+++ trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php 2013-05-22 14:44:11 UTC (rev 8625)
@@ -6,7 +6,7 @@
$coord = split(',',$_GET["coord"]);
//Mapfile laden
-$map= ms_newMapObj($mapfilepath.'\map.map');
+$map= ms_newMapObj($mapfilepath.'/dhm.map');
//Punkt erzeugen
$qPoint = ms_newPointObj();
Added: trunk/mapbender/http/extensions/mobilemap/query/rasterqueryWms.php
--- trunk/mapbender/http/extensions/mobilemap/query/rasterqueryWms.php (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap/query/rasterqueryWms.php 2013-05-22 14:44:11 UTC (rev 8625)
@@ -0,0 +1,158 @@
+<?php
+//Basic configuration of mapserver client
+require_once(dirname(__FILE__)."/../../../../conf/mobilemap.conf");
+require_once(dirname(__FILE__)."/../../../classes/class_connector.php");
+$featureInfoRequestPart = '&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS='.$rquerylayer;
+$featureInfoRequestPart .= '&QUERY_LAYERS='.$rquerylayer.'&WIDTH=101&HEIGHT=101&SRS=EPSG:'.$ggepsg;
+//calculate BBOX from position
+$coord = explode(',',$_GET["coord"]);
+$bbox = (string)((double)$coord[0] - 50.0) .",".(string)((double)$coord[1] - 50.0) .",".(string)((double)$coord[0] + 50.0) .",".(string)((double)$coord[1] + 50.0);
+$featureInfoRequestPart .= '&BBOX='.$bbox.'&STYLES=&FORMAT=image/png';
+$featureInfoRequestPart .= '&INFO_FORMAT=application/vnd.ogc.gml&EXCEPTIONS=application/vnd.ogc.se_inimage&X=51&Y=51&FEATURE_COUNT=1&';
+$url = $dhmWmsFeatureInfoUrl.$featureInfoRequestPart;
+//Request ausführen
+// Open the Curl session
+$featureInfoConnector = new connector($url);
+//header("Content-Type: text/plain");
+//header("Content-Type: application/json");
+//Datenausgabe
+$gml = $featureInfoConnector->file;
+//Ergebnis parsen
+try {
+ //$xml = str_replace('xlink:href', 'xlinkhref', $xml);
+ //http://forums.devshed.com/php-development-5/simplexml-namespace-attributes-problem-452278.html
+ //http://www.leftontheweb.com/message/A_small_SimpleXML_gotcha_with_namespaces
+ $gmlObject = new SimpleXMLElement($gml);
+ if ($gmlObject === false) {
+ foreach(libxml_get_errors() as $error) {
+ $e = new mb_exception($error->message);
+ throw new Exception('Cannot parse GML from featureInfo in mobile Client!');
+catch (Exception $e) {
+ $e = new mb_exception($e->getMessage());
+if ($gmlObject !== false) {
+ //read all relevant information an put them into the mapbender wfs object
+ //xmlns="http://www.opengis.net/wfs"
+ //Setup default namespace
+ $gmlObject->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+ $gmlObject->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+ $gmlObject->registerXPathNamespace("xsi", "http://www.w3.org/2001/XMLSchema-instance");
+ //$gmlObject->registerXPathNamespace("default", "http://www.opengis.net/wfs");
+ //some debug
+ //$e = new mb_notice("XML string from memory: ".$wfs11Cap->asXML());
+ $x = $gmlObject->xpath('/msGMLOutput/mydhm_layer/mydhm_feature/value_0');
+ $hoehe = $x[0];
+ echo "Höhe: ~".$hoehe." [m]";
+} else {
+ echo "Kein Höhe gefunden!";
+//HTML generieren
+//Rückgabe
+//Mapfile laden
+//Punkt erzeugen
+$qPoint = ms_newPointObj();
+$qPoint->setXY($coord[0]*1,$coord[1]*1);
+//Layer festlegen
+$layer = $map->getLayerByName($rquerylayer);
+//Punktabfrage (Single)
+@$datQuery = $layer->queryByPoint($qPoint, MS_SINGLE, 1);
+ // UMRECHNUNG Eingabe koordinatensystem -> WGS84
+$projInObj = ms_newprojectionobj("init=epsg:$ggepsg");
+$projOutObj = ms_newprojectionobj("init=epsg:4326");
+$qPoint->project($projInObj, $projOutObj);
+$WGS_X = round($qPoint->x,6);
+$WGS_Y = round($qPoint->y,6);
+print '<div id="dhmqueryId" >';
+print ('<table border="0" cellspacing="0" cellpadding="1" class="normal">');
+//Wenn Query erfolgreich
+ if ($datQuery == MS_SUCCESS) {
+ for ($j=0; $j<$layer->getNumResults(); $j++) {
+ $result = $layer->getResult($j);
+ //Versionsüberprüfung
+ if (ms_GetVersionInt() < 50600){
+ $layer->open();
+ $shpobj = $layer->getShape($result->tileindex,$result->shapeindex);
+ else{
+ $shpobj = $layer->resultsGetShape($result->shapeindex,$result->tileindex);
+ $attr = $shpobj->values;
+ //echo round($attr["value_0"],2);
+ $hoehe = round($attr["value_0"],1);
+ if ($hoehe <0){
+ print '<tr ><td colspan="3" ><strong>'.$maplang['rasterquery_nodata'].'</strong></td></tr>';
+ else{
+ print '<tr><td>'.$maplang['rasterquery_h'].'</td><td><span class="hilite">'.$hoehe.'</span></td><td>m NN</td></tr>';
+ $shpobj->free();
+ $layer->close();
+ else{
+ print '<tr ><td colspan="3" ><strong>'.$maplang['rasterquery_noh'].'</strong></td></tr>';
+ //echo "Kein Wert verfügbar!";
+print ('<tr bgcolor="#E6E6E6"><td colspan="3" >'.$maplang['rasterquery_gps'].'</td></tr>
+ <tr>
+ <td>Lat:</td>
+ <td colspan="2">'.$WGS_Y.'</td>
+ </tr>
+ <tr>
+ <td>Lon:</td>
+ <td colspan="2">'.$WGS_X.'</td>
+ </tr>
+ <tr bgcolor="#E6E6E6">
+ <td colspan="3" >'.$maplang['rasterquery_xy'].'</td>
+ </tr>
+ <tr>
+ <td>X</td>
+ <td colspan="2">'.round($coord[0],0).'</td>
+ </tr>
+ <tr>
+ <td>Y</td>
+ <td colspan="2">'.round($coord[1],0).'</td>
+ </tr>
+ <tr>
+ <td colspan="3" align="left"><a href="javascript:void(0);" onClick="javascript:zoompoint('.round($coord[0],0).','.round($coord[1],0).');" ><img src="'.$applicationurl.'/img/ico_zoomin.png" border="0" > '.$maplang['geocode_result4'].'</a></td>
+ </tr>
+ <tr>
+ <td colspan="3" align="right">');
+print(' </td></tr></table></div>');
More information about the Mapbender_commits
