[Mapbender-commits] r8808 - trunk/mapbender/http/print
svn_mapbender at osgeo.org
Tue Apr 1 00:15:51 PDT 2014
Author: armin11
Date: 2014-04-01 00:15:51 -0700 (Tue, 01 Apr 2014)
New Revision: 8808
Added:
trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.json
trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.odg
trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.pdf
New A4 template for multipage legends
Added: trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.json
--- trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.json (rev 0)
+++ trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.json 2014-04-01 07:15:51 UTC (rev 8808)
@@ -0,0 +1,188 @@
+ "type" : "templatePDF",
+ "orientation" : "P",
+ "units" : "mm",
+ "format" : "a4",
+ "controls" : [
+ "id" : "title",
+ "label" : "Titel",
+ "type" : "text",
+ "size" : 20,
+ "pageElementsLink" : {
+ "titel" : "value"
+ "id" : "dpi",
+ "label" : "DPI",
+ "type" : "select",
+ "size" : 20,
+ "karte" : "res_dpi"
+ "options" : [
+ "value" : "72",
+ "label" : "72 dpi"
+ "value" : "144",
+ "label" : "144 dpi"
+ "value" : "288",
+ "label" : "288 dpi"
+ "id" : "comment1",
+ "label" : "Kommentar",
+ "type" : "textarea",
+ "size" : 5,
+ "kommentar1" : "value"
+ "id" : "angle",
+ "label" : "Winkel",
+ "type" : "text",
+ "nordpfeil" : "angle",
+ "karte" : "angle",
+ "minikarte" : "angle"
+ "id" : "coordinates",
+ "type" : "hidden"
+ "id" : "scale",
+ "label" : "Maßstab",
+ "type" : "text",
+ "scale" : "value"
+ "pages" : [
+ "tpl" : "Hochformat_A4_Legende_mehrseitig.pdf",
+ "useTplPage" : 1,
+ "elements" : {
+ "karte" : {
+ "type" : "map",
+ "res_dpi" : 72,
+ "x_ul" : 9.4,
+ "y_ul" : 34.1,
+ "width" : 190.4,
+ "height" : 241,
+ "coords" : 1,
+ "coords_font_family" : "Arial",
+ "coords_font_size" : 8
+ "permanentImage":{
+ "type":"permanentImage"
+ "messung" : {
+ "type" : "measure",
+ "do_fill" : 0,
+ "fill_color" : {
+ "r" : 255,
+ "g" : 0,
+ "b" : 0
+ "do_stroke" : 0,
+ "stroke_color" : {
+ "r" : 0,
+ "g" : 0,
+ "b" : 0
+ "line_style" : {
+ "width" : 1.0
+ "minikarte" : {
+ "type" : "overview",
+ "res_dpi" : 72,
+ "x_ul" : 9.2,
+ "y_ul" : 34.1,
+ "width" : 40,
+ "height" : 40
+ "titel" : {
+ "type" : "text",
+ "x_ul" : 10,
+ "y_ul" : 9,
+ "font_family" : "Arial",
+ "font_size" : 15
+ "scale" : {
+ "type" : "text",
+ "x_ul" : 32.5,
+ "y_ul" : 17,
+ "font_size" : 11,
+ "value" : "scale"
+ "date" : {
+ "type" : "text",
+ "x_ul" : 32.5,
+ "y_ul" : 25,
+ "font_size" : 11,
+ "value" : "date"
+ "time" : {
+ "type" : "text",
+ "x_ul" : 58,
+ "y_ul" : 25,
+ "font_size" : 11,
+ "value" : "time"
+ "nordpfeil" : {
+ "type" : "image",
+ "x_ul" : 184,
+ "y_ul" : 49,
+ "width" : 16,
+ "height" : 16,
+ "angle" : 0,
+ "filename" : "./img/northarrow.png"
+ "kommentar1" : {
+ "type" : "para",
+ "x_ul" : 81.2,
+ "y_ul" : 18.2,
+ "font_size" : 11,
+ "width" : 40,
+ "height" : 6,
+ "align" : "L",
+ "border" : 0,
+ "fill" : 1,
+ "border_width" : 0.5
+ "useTplPage" : 2,
+ "elements" : {
+ "legende" : {
+ "type" : "legend",
+ "x_ul" : 7,
+ "y_ul" : 36,
+ "width" : 90,
+ "height" : 180,
+ "font_size" : 10.5,
+ "scale" : 0.9
Added: trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.odg
(Binary files differ)
Property changes on: trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.odg
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.pdf
Property changes on: trunk/mapbender/http/print/Hochformat_A4_Legende_mehrseitig.pdf
More information about the Mapbender_commits
