[Mapbender-commits] r8809 - in trunk/mapbender: conf http/classes http/plugins
svn_mapbender at osgeo.org
Tue Apr 1 07:34:09 PDT 2014
Author: armin11
Date: 2014-04-01 07:34:09 -0700 (Tue, 01 Apr 2014)
New Revision: 8809
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/http/classes/class_wms_owsproxy_log.php
trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js
trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php
Bugfixes for owsproxy_log, define LIMIT for LOG export in mapbender.conf
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2014-04-01 07:15:51 UTC (rev 8808)
+++ trunk/mapbender/conf/mapbender.conf-dist 2014-04-01 14:34:09 UTC (rev 8809)
@@ -69,6 +69,9 @@
#define("OWSPROXY_SESSION_GRABBING_WHITELIST", "localhost,127.0.0.1");
#Parameter to steer if owsproxy support mapbender hq printing for mapserver with duplicated mapfiles named _4.map
define("OWSPROXY_SUPPORT_HQ_PRINTING", false);
+# LIMIT for count of rows, that maybe exported at once from owsproxy_log module
+#define("OWS_LOG_EXPORT_LIMIT_CSV", 1000);
+define("OWS_LOG_EXPORT_LIMIT", 1000);
# Definitions for HTTP Authentication
Modified: trunk/mapbender/http/classes/class_wms_owsproxy_log.php
--- trunk/mapbender/http/classes/class_wms_owsproxy_log.php 2014-04-01 07:15:51 UTC (rev 8808)
+++ trunk/mapbender/http/classes/class_wms_owsproxy_log.php 2014-04-01 14:34:09 UTC (rev 8809)
@@ -25,7 +25,7 @@
private static $SEPARATOR_VALUE = "\t";
private static $SEPARATOR_ROW = "\n";
- private static $LIMIT_INT = 1000;
+ private static $LIMIT_INT = OWS_LOG_EXPORT_LIMIT;
private static $LIMIT_SQL = " ORDER BY m.log_id DESC LIMIT ";
@@ -204,7 +204,7 @@
." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$4"
." AND m.fkey_wms_id = $1 AND m.proxy_log_timestamp >= $2"
." AND m.proxy_log_timestamp <= $3)".$join
- ." GROUP BY ".$selectColumns
+ ." GROUP BY m.log_id, ".$selectColumns
. WmsOwsLogCsv::$LIMIT_SQL . WmsOwsLogCsv::$LIMIT_INT;
$result = db_prep_query($sql,$v,$t);
@@ -230,7 +230,7 @@
." AND m.fkey_mb_user_id = $1 AND m.proxy_log_timestamp >= $2"
." AND m.proxy_log_timestamp <= $3".$whereWms.")".$join
$this->readResult($result);
@@ -312,17 +312,17 @@
$offsetPrice = null;
$sumPixel = 0;
$sumPrice = 0;
+ if ($result != false) {
+ $num_fields = pg_num_fields($result);
+ for ( $i = 0; $i < $num_fields; $i++ ){
+ $field_name = pg_field_name($result , $i);
+ $this->resultHeader[] = $field_name;
- $num_fields = pg_num_fields($result);
- for ( $i = 0; $i < $num_fields; $i++ ){
- $field_name = pg_field_name($result , $i);
- $this->resultHeader[] = $field_name;
- // keep offsets of prixel and price row
- if($field_name === "pixel") $offsetPixel = $i;
- else if($field_name === "price") $offsetPrice = $i;
+ // keep offsets of prixel and price row
+ if($field_name === "pixel") $offsetPixel = $i;
+ else if($field_name === "price") $offsetPrice = $i;
$i = 0;
while($row = db_fetch_row($result)){
foreach( $row as $key=>$value){
Modified: trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js
--- trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js 2014-04-01 07:15:51 UTC (rev 8808)
+++ trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js 2014-04-01 14:34:09 UTC (rev 8809)
@@ -149,7 +149,9 @@
type: "post",
dataType: "json",
data: parameter,
+ async: false,
success: function(data){
+ //alert(data.header);
lastRequestData = null;
if(data.error != "") {
alert(data.error);
Modified: trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php
--- trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php 2014-04-01 07:15:51 UTC (rev 8808)
+++ trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php 2014-04-01 14:34:09 UTC (rev 8809)
@@ -2,6 +2,7 @@
require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+$LIMIT_INT = OWS_LOG_EXPORT_LIMIT;
if(isset($_REQUEST['userGuiId'])) {
$id = (integer)$_REQUEST['userGuiId'];
@@ -31,12 +32,11 @@
$t = array('i');
$users = array();
$wmses = array();
- $sql = "SELECT w.wms_id,w.wms_title,u.mb_user_id,u.mb_user_name,m.log_id"
+ $sql = "SELECT DISTINCT u.mb_user_id, w.wms_id,w.wms_title,u.mb_user_name"
." FROM mb_proxy_log AS m INNER JOIN wms AS w ON"
." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$1)"
." INNER JOIN mb_user u ON(m.fkey_mb_user_id = u.mb_user_id)"
- ." ORDER BY m.log_id DESC LIMIT 1000";
+ ." ORDER BY u.mb_user_name ASC, u.mb_user_id ";
while($row = db_fetch_assoc($result)){
$users[$row['mb_user_id']] = $row['mb_user_name'];
@@ -181,4 +181,4 @@
die ("Der 'serviceType'".$serviceType." ist nicht unterstuetzt.");
\ No newline at end of file
More information about the Mapbender_commits
