[Mapbender-commits] r8810 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Apr 10 00:42:39 PDT 2014
Author: armin11
Date: 2014-04-10 00:42:38 -0700 (Thu, 10 Apr 2014)
New Revision: 8810
trunk/mapbender/http/classes/class_wms.php
Bugfix for metadata role system (update wms holds now contact from metadata group)
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2014-04-01 14:34:09 UTC (rev 8809)
+++ trunk/mapbender/http/classes/class_wms.php 2014-04-10 07:42:38 UTC (rev 8810)
@@ -2642,7 +2642,7 @@
//they don't come from the capabilities!
if (!$updateMetadataOnly) {
//read network_access from database
- $sql = "SELECT wms_network_access, wms_max_imagesize, inspire_annual_requests from wms WHERE wms_id = $1 ";
+ $sql = "SELECT wms_network_access, fkey_mb_group_id, wms_max_imagesize, inspire_annual_requests from wms WHERE wms_id = $1 ";
$v = array($myWMS);
$t = array('i');
$res = db_prep_query($sql,$v,$t);
@@ -2650,6 +2650,7 @@
$this->wms_network_access = $row["wms_network_access"];
$this->wms_max_imagesize = $row["wms_max_imagesize"];
$this->inspire_annual_requests = $row["inspire_annual_requests"];
+ $this->fkey_mb_group_id = $row["fkey_mb_group_id"];
//if network access is either stored in database nor given thru object, set it too a default value 0
if (!isset($this->wms_network_access) || ($this->wms_network_access == '')) {
More information about the Mapbender_commits
