[Mapbender-commits] r8931 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org
Wed Jun 25 02:47:29 PDT 2014
Author: hwbllmnn
Date: 2014-06-25 02:47:29 -0700 (Wed, 25 Jun 2014)
New Revision: 8931
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
always add uuid, created and updated properties
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-06-25 09:21:48 UTC (rev 8930)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-06-25 09:47:29 UTC (rev 8931)
@@ -367,6 +367,7 @@
editStyleDialog.find('.digitize-save').bind('click', function() {
editStyleDialog.dialog('close');
+ feature.properties.updated = new Date().toISOString();
kml.refresh(url);
editStyleDialog.find('input[name="fill"]').spectrum();
@@ -446,6 +447,8 @@
feature.properties[k] = v;
attributesDialog.dialog('close');
editDialog.dialog('close');
kml.refresh(url);
@@ -636,6 +639,7 @@
editedFeature.geometry.coordinates[0].push([v.pos.x, v.pos.y]);
+ editedFeature.properties.updated = new Date().toISOString();
kml.refresh(digitizingFor);
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2014-06-25 09:21:48 UTC (rev 8930)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2014-06-25 09:47:29 UTC (rev 8931)
@@ -196,7 +196,9 @@
multi.e.setElement("Mapbender:icon","../img/marker/red.png");
- itm.data.features.push(JSON.parse(multi.toString()));
+ var feat = JSON.parse(multi.toString());
+ itm.data.features.push(feat);
this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
$map.setMapRequest();
@@ -552,14 +554,7 @@
feats = self.cache[url][map.getSrs()];
if(!feats) {
$.each(item.data.features, function(_, v) {
- if(v.geometry.type === 'Polygon') {
- $.each(v.geometry.coordinates, function(_, coords) {
- if(coords[0][0] !== coords[coords.length-1][0]
- || coords[0][1] !== coords[coords.length-1][1]) {
- coords.push(coords[0]);
+ self.fixupFeature(v);
$.ajax({
url: '../php/transformgeojson.php?targetEPSG=' + map.getSrs(),
@@ -581,6 +576,27 @@
$.each(feats, $.proxy(self, self.renderFeature(canvas)));
+ fixupFeature: function(feat) {
+ if(feat.geometry.type === 'Polygon') {
+ $.each(feat.geometry.coordinates, function(_, coords) {
+ if(coords[0][0] !== coords[coords.length-1][0]
+ || coords[0][1] !== coords[coords.length-1][1]) {
+ coords.push(coords[0]);
+ if(!feat.properties.uuid) {
+ feat.properties.uuid = UUID.genV1().toString();
+ if(!feat.properties.updated) {
+ feat.properties.updated = new Date().toISOString();
+ if(!feat.properties.created) {
+ feat.properties.created = new Date().toISOString();
More information about the Mapbender_commits
