[Mapbender-commits] r8932 - trunk/mapbender/http/extensions
    svn_mapbender at osgeo.org
    Wed Jun 25 03:30:11 PDT 2014
Author: hwbllmnn
Date: 2014-06-25 03:30:11 -0700 (Wed, 25 Jun 2014)
New Revision: 8932
Added:
   trunk/mapbender/http/extensions/uuid.js
added uuid.js
Added: trunk/mapbender/http/extensions/uuid.js
--- trunk/mapbender/http/extensions/uuid.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/uuid.js	2014-06-25 10:30:11 UTC (rev 8932)
@@ -0,0 +1,311 @@
+ * UUID.js: The RFC-compliant UUID generator for JavaScript.
+ * @fileOverview
+ * @author  LiosK
+ * @version 3.2
+ * @license The MIT License: Copyright (c) 2010-2012 LiosK.
+/** @constructor */
+var UUID;
+UUID = (function(overwrittenUUID) {
+// Core Component {{{
+/** @lends UUID */
+function UUID() {}
+ * The simplest function to get an UUID string.
+ * @returns {string} A version 4 UUID string.
+UUID.generate = function() {
+  var rand = UUID._getRandomInt, hex = UUID._hexAligner;
+  return  hex(rand(32), 8)          // time_low
+        + hex(rand(16), 4)          // time_mid
+        + hex(0x4000 | rand(12), 4) // time_hi_and_version
+        + hex(0x8000 | rand(14), 4) // clock_seq_hi_and_reserved clock_seq_low
+        + hex(rand(48), 12);        // node
+ * Returns an unsigned x-bit random integer.
+ * @param {int} x A positive integer ranging from 0 to 53, inclusive.
+ * @returns {int} An unsigned x-bit random integer (0 <= f(x) < 2^x).
+UUID._getRandomInt = function(x) {
+  if (x <   0) return NaN;
+  if (x <= 30) return (0 | Math.random() * (1 <<      x));
+  if (x <= 53) return (0 | Math.random() * (1 <<     30))
+                    + (0 | Math.random() * (1 << x - 30)) * (1 << 30);
+  return NaN;
+ * Returns a function that converts an integer to a zero-filled string.
+ * @param {int} radix
+ * @returns {function(num, length)}
+UUID._getIntAligner = function(radix) {
+  return function(num, length) {
+    var str = num.toString(radix), i = length - str.length, z = "0";
+    for (; i > 0; i >>>= 1, z += z) { if (i & 1) { str = z + str; } }
+    return str;
+UUID._hexAligner = UUID._getIntAligner(16);
+// UUID Object Component {{{
+ * Names of each UUID field.
+ * @type string[]
+ * @constant
+ * @since 3.0
+UUID.FIELD_NAMES = ["timeLow", "timeMid", "timeHiAndVersion",
+                    "clockSeqHiAndReserved", "clockSeqLow", "node"];
+ * Sizes of each UUID field.
+ * @type int[]
+ * @constant
+ * @since 3.0
+UUID.FIELD_SIZES = [32, 16, 16, 8, 8, 48];
+ * Generates a version 4 {@link UUID}.
+ * @returns {UUID} A version 4 {@link UUID} object.
+ * @since 3.0
+UUID.genV4 = function() {
+  var rand = UUID._getRandomInt;
+  return new UUID()._init(rand(32), rand(16), // time_low time_mid
+                          0x4000 | rand(12),  // time_hi_and_version
+                          0x80   | rand(6),   // clock_seq_hi_and_reserved
+                          rand(8), rand(48)); // clock_seq_low node
+ * Converts hexadecimal UUID string to an {@link UUID} object.
+ * @param {string} strId UUID hexadecimal string representation ("xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx").
+ * @returns {UUID} {@link UUID} object or null.
+ * @since 3.0
+UUID.parse = function(strId) {
+  var r, p = /^\s*(urn:uuid:|\{)?([0-9a-f]{8})-([0-9a-f]{4})-([0-9a-f]{4})-([0-9a-f]{2})([0-9a-f]{2})-([0-9a-f]{12})(\})?\s*$/i;
+  if (r = p.exec(strId)) {
+    var l = r[1] || "", t = r[8] || "";
+    if (((l + t) === "") ||
+        (l === "{" && t === "}") ||
+        (l.toLowerCase() === "urn:uuid:" && t === "")) {
+      return new UUID()._init(parseInt(r[2], 16), parseInt(r[3], 16),
+                              parseInt(r[4], 16), parseInt(r[5], 16),
+                              parseInt(r[6], 16), parseInt(r[7], 16));
+  return null;
+ * Initializes {@link UUID} object.
+ * @param {uint32} [timeLow=0] time_low field (octet 0-3).
+ * @param {uint16} [timeMid=0] time_mid field (octet 4-5).
+ * @param {uint16} [timeHiAndVersion=0] time_hi_and_version field (octet 6-7).
+ * @param {uint8} [clockSeqHiAndReserved=0] clock_seq_hi_and_reserved field (octet 8).
+ * @param {uint8} [clockSeqLow=0] clock_seq_low field (octet 9).
+ * @param {uint48} [node=0] node field (octet 10-15).
+ * @returns {UUID} this.
+UUID.prototype._init = function() {
+  var names = UUID.FIELD_NAMES, sizes = UUID.FIELD_SIZES;
+  var bin = UUID._binAligner, hex = UUID._hexAligner;
+   * List of UUID field values (as integer values).
+   * @type int[]
+  this.intFields = new Array(6);
+   * List of UUID field values (as binary bit string values).
+   * @type string[]
+  this.bitFields = new Array(6);
+   * List of UUID field values (as hexadecimal string values).
+   * @type string[]
+  this.hexFields = new Array(6);
+  for (var i = 0; i < 6; i++) {
+    var intValue = parseInt(arguments[i] || 0);
+    this.intFields[i] = this.intFields[names[i]] = intValue;
+    this.bitFields[i] = this.bitFields[names[i]] = bin(intValue, sizes[i]);
+    this.hexFields[i] = this.hexFields[names[i]] = hex(intValue, sizes[i] / 4);
+   * UUID version number defined in RFC 4122.
+   * @type int
+  this.version = (this.intFields.timeHiAndVersion >> 12) & 0xF;
+   * 128-bit binary bit string representation.
+   * @type string
+  this.bitString = this.bitFields.join("");
+   * UUID hexadecimal string representation ("xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx").
+   * @type string
+  this.hexString = this.hexFields[0] + "-" + this.hexFields[1] + "-" + this.hexFields[2]
+                 + "-" + this.hexFields[3] + this.hexFields[4] + "-" + this.hexFields[5];
+   * UUID string representation as a URN ("urn:uuid:xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx").
+   * @type string
+  this.urn = "urn:uuid:" + this.hexString;
+  return this;
+UUID._binAligner = UUID._getIntAligner(2);
+ * Returns UUID string representation.
+ * @returns {string} {@link UUID#hexString}.
+UUID.prototype.toString = function() { return this.hexString; };
+ * Tests if two {@link UUID} objects are equal.
+ * @param {UUID} uuid
+ * @returns {bool} True if two {@link UUID} objects are equal.
+UUID.prototype.equals = function(uuid) {
+  if (!(uuid instanceof UUID)) { return false; }
+    if (this.intFields[i] !== uuid.intFields[i]) { return false; }
+  return true;
+// UUID Version 1 Component {{{
+ * Generates a version 1 {@link UUID}.
+ * @returns {UUID} A version 1 {@link UUID} object.
+ * @since 3.0
+UUID.genV1 = function() {
+  var now = new Date().getTime(), st = UUID._state;
+  if (now != st.timestamp) {
+    if (now < st.timestamp) { st.sequence++; }
+    st.timestamp = now;
+    st.tick = UUID._getRandomInt(4);
+  } else if (Math.random() < UUID._tsRatio && st.tick < 9984) {
+    // advance the timestamp fraction at a probability
+    // to compensate for the low timestamp resolution
+    st.tick += 1 + UUID._getRandomInt(4);
+  } else {
+    st.sequence++;
+  // format time fields
+  var tf = UUID._getTimeFieldValues(st.timestamp);
+  var tl = tf.low + st.tick;
+  var thav = (tf.hi & 0xFFF) | 0x1000;  // set version '0001'
+  // format clock sequence
+  st.sequence &= 0x3FFF;
+  var cshar = (st.sequence >>> 8) | 0x80; // set variant '10'
+  var csl = st.sequence & 0xFF;
+  return new UUID()._init(tl, tf.mid, thav, cshar, csl, st.node);
+ * Re-initializes version 1 UUID state.
+ * @since 3.0
+UUID.resetState = function() {
+  UUID._state = new UUID._state.constructor();
+ * Probability to advance the timestamp fraction: the ratio of tick movements to sequence increments.
+ * @type float
+UUID._tsRatio = 1 / 4;
+ * Persistent state for UUID version 1.
+ * @type UUIDState
+UUID._state = new function UUIDState() {
+  this.timestamp = 0;
+  this.sequence = rand(14);
+  this.node = (rand(8) | 1) * 0x10000000000 + rand(40); // set multicast bit '1'
+  this.tick = rand(4);  // timestamp fraction smaller than a millisecond
+ * @param {Date|int} time ECMAScript Date Object or milliseconds from 1970-01-01.
+ * @returns {object}
+UUID._getTimeFieldValues = function(time) {
+  var ts = time - Date.UTC(1582, 9, 15);
+  var hm = ((ts / 0x100000000) * 10000) & 0xFFFFFFF;
+  return  { low: ((ts & 0xFFFFFFF) * 10000) % 0x100000000,
+            mid: hm & 0xFFFF, hi: hm >>> 16, timestamp: ts };
+// Misc. Component {{{
+ * Reinstalls {@link UUID.generate} method to emulate the interface of UUID.js version 2.x.
+ * @since 3.1
+ * @deprecated Version 2.x. compatible interface is not recommended.
+UUID.makeBackwardCompatible = function() {
+  var f = UUID.generate;
+  UUID.generate = function(o) {
+    return (o && o.version == 1) ? UUID.genV1().hexString : f.call(UUID);
+  UUID.makeBackwardCompatible = function() {};
+ * Preserves the value of 'UUID' global variable set before the load of UUID.js.
+ * @since 3.2
+ * @type object
+UUID.overwrittenUUID = overwrittenUUID;
+return UUID;
+})(UUID);
+// vim: et ts=2 sw=2 fdm=marker fmr&
More information about the Mapbender_commits
