[Mapbender-commits] r9177 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Apr 8 02:27:50 PDT 2015
Author: armin11
Date: 2015-04-08 02:27:50 -0700 (Wed, 08 Apr 2015)
New Revision: 9177
trunk/mapbender/http/php/mod_loadCapabilities.php
Enhance layout
Modified: trunk/mapbender/http/php/mod_loadCapabilities.php
--- trunk/mapbender/http/php/mod_loadCapabilities.php 2015-04-08 08:55:20 UTC (rev 9176)
+++ trunk/mapbender/http/php/mod_loadCapabilities.php 2015-04-08 09:27:50 UTC (rev 9177)
@@ -136,7 +136,7 @@
$t = array('s');
$res = db_prep_query($sql,$v,$t);
$count=0;
- echo"<select size='8' name='wmsList' style='width:600px'>";
+ echo"<select size='8' name='wmsList' style='width:500px'>";
while($row = db_fetch_array($res)){
if ($row["wms_title"]!=""){
@@ -148,7 +148,7 @@
echo "</select><br><br>";
else{
- echo"<select size='8' name='wmsList' style='width:600px' on Click='submit()'>";
+ echo"<select size='8' name='wmsList' style='width:500px' on Click='submit()'>";
echo "</td>";
@@ -162,9 +162,9 @@
#echo "Load WMS capabilities URL:<br>"
if (isset($xml_file)){
- echo"<input type='text' name='xml_file' size='50' value='".$xml_file."'><br>";
+ echo"<input type='text' name='xml_file' size='100' value='".$xml_file."'><br>";
}else{
- echo"<input type='text' name='xml_file' size='50' value='http://'><br>";
+ echo"<input type='text' name='xml_file' size='100' value='http://'><br>";
//show fields for authentication - only possible if curl is used as connector!
if (CONNECTION == 'curl') {
More information about the Mapbender_commits
