[Mapbender-commits] r9178 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Wed Apr  8 02:33:44 PDT 2015
Author: armin11
Date: 2015-04-08 02:33:44 -0700 (Wed, 08 Apr 2015)
New Revision: 9178
   trunk/mapbender/http/php/mod_updateWMS.php
Enhance layout
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php	2015-04-08 09:27:50 UTC (rev 9177)
+++ trunk/mapbender/http/php/mod_updateWMS.php	2015-04-08 09:33:44 UTC (rev 9178)
@@ -156,7 +156,8 @@
 		authPassword = $("#imrAuthPassword").val();
 		authName = $("#imrAuthName").val();
+	console.log(dbOldNameArray);
+	console.log(dbCurrentNameArray);
 	var updateParams = {
 		//TODO add auth info!
 		"command": "updateWMS",
@@ -208,7 +209,6 @@
 		if($("#compare_dialog").attr("checked")) {
 			if (typeof $compareDialog == 'object') {
 				$("#compareDialog").remove();
-				$("#linkDialog").remove();
             	$compareDialog.dialog("destroy");
 			radioAuthValue = $('input:radio[name=imrHttpAuth]:checked').val();
@@ -305,11 +305,10 @@
 							$(".linkDialog").click(function () {
 								var fieldId = $(this).attr("id");
-								$selectLayerDialog = $("<div id='linkDialog'><select id='xmlLayerSelect'>" + selectboxOptions + "</select></div>").dialog({
+								$selectLayerDialog = $("<div><select id='xmlLayerSelect'>" + selectboxOptions + "</select></div>").dialog({
 									title : "Select layer",
 									buttons: {
 										"Close": function() {
 											$(this).dialog("destroy").remove();
 										"Select": function() {
@@ -323,7 +322,6 @@
 													$("#dbCurrentName_"+cntArray[1]).css("background-color","");
@@ -418,7 +416,7 @@
 	view wms metadata: <a id='metadatalink' href='' onclick="window.open(this.href,'Metadaten','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false" target="_blank"><span id="metadatatext">no WMS selected</span></a><br><br>
 <?php
-	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='120' name='capURL' id='capURL'><br />";
+	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='100' name='capURL' id='capURL'><br />";
 	echo "<input type='hidden' name='myWMS' id='myWMS' value=''><br>";
 	echo "Add the following REQUEST to the Online Resource URL to obtain the Capabilities document:<br>";
 	echo "<i>(Triple click to select and copy)</i><br>";
@@ -440,7 +438,7 @@
  	echo "Username : <input type='text' name='imrAuthName' id='imrAuthName' /><br>";
  	echo "Password : <input type='text' name='imrAuthPassword' id='imrAuthPassword'/><br><br>";
  	echo "</div>";
- 	echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL' id='myURL'><br>";
+ 	echo "Link to new WMS Capabilities URL:<br><input size='100' type='text' name='myURL' id='myURL'><br>";
 	if (defined("TWITTER_NEWS") && TWITTER_NEWS == true) {
 		echo"<input type='checkbox' name='twitter_news' id='twitter_news' checked='checked'>Publish via Twitter<br>";
More information about the Mapbender_commits
