[Mapbender-commits] r9334 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 9 04:02:26 PST 2015
Author: armin11
Date: 2015-12-09 04:02:26 -0800 (Wed, 09 Dec 2015)
New Revision: 9334
   trunk/mapbender/http/classes/class_iso19139.php
New possibility to manage licenses at dataset metadata level
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2015-12-09 09:00:15 UTC (rev 9333)
+++ trunk/mapbender/http/classes/class_iso19139.php	2015-12-09 12:02:26 UTC (rev 9334)
@@ -61,6 +61,7 @@
 	var $inspireCharset;
 	var $licenseSourceNote;
 	var $licenseJson;
+	//the following attribute is specific to predefined terms of use as they are managed by the mapbender database - it is the identifier (fkey) of an entry in the termsofuse table
 	var $termsOfUseRef;
 	var $accessConstraints;
 	var $fees;
@@ -416,7 +417,7 @@
 					//Look for source
 					$this->licenseSourceNote = $standardizedLicense->quelle;
 					$this->licenseJson = stripslashes($otherConstraints[1]);
-					//search in the second entry for a freetxt object
+					//search in the second entry for a freetext object
 					if ($otherConstraints[1] != ''){
 						$this->fees = $otherConstraints[1];
@@ -1077,6 +1078,21 @@
 					$this->keywordsThesaurusName[] = "";
+			//get predefined license if given in mapbender database
+			$sql = <<<SQL
+SELECT fkey_termsofuse_id FROM md_termsofuse WHERE fkey_metadata_id = $1
+SQL;
+			$v = array($metadataId);
+			$t = array('i');
+			$res = db_prep_query($sql,$v,$t);
+			//pull first entry
+			$row = db_fetch_assoc($res);
+			$this->termsOfUseRef = $row['fkey_termsofuse_id'];
+			if ($this->termsOfUseRef == null) {
+				$e = new mb_exception("no predefined license set");
+			} else {
+				$e = new mb_exception("Predefined license found: ".$this->termsOfUseRef);
 		} else {
 			$e = new mb_exception("Could not get metadata with id ".$metadataId." from DB!");
 		return false;
@@ -1352,6 +1368,7 @@
 	public function insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId){
 		//first delete old classifications - after that create new ones
+		//$e = new mb_exception($metadataId." - ".$resourceType." - ".$resourceId);
 		$this->deleteKeywordsAndCategoriesFromDB($metadataId,$resourceType,$resourceId);
 		//insert keywords and categories into tables!
 		//parse keywords and isoCategories
@@ -1532,14 +1549,69 @@
 		//delete relations from database
 		//recreate relation to license
 		//relation is set via json id
-		if ($this->licenseJson != null) {
+		//check for defined license id via editor or s.th. else
+			//search for given json lincense
+			if ($this->licenseJson != null) {
+				$licenseName = json_decode($this->licenseJson)->id;
+				if ($licenseName != null) {
+					//search for same license name in database - if not given create it!
+					$sql = <<<SQL
+					SELECT termsofuse_id from termsofuse WHERE name = $1
+SQL;
+					$v = array($licenseName);
+					$t = array('s');
+					$licenseId = $row['termsofuse_id'];
+					if ($licenseId == null) {
+						//if all relevant information is given in json - create a new entry in termsofuse table (id, name, url
+						$licenseJson = json_decode($this->licenseJson);
+						if ($licenseJson->id != null && $licenseJson->id != "" && $licenseJson->name != null && $licenseJson->name != "" && $licenseJson->url != null && $licenseJson->url != "") {
+							//insert entry into db - license should be open
+							$sql = <<<SQL
+							INSERT INTO termsofuse (name, description, descriptionlink) VALUES ($1, $2, $3);
+SQL;
+							$v = array($licenseJson->id,$licenseJson->name,$licenseJson->url);
+							$t = array('s','s','s');
+							if (!$res) {
+								$e = new mb_exception("classes/class_iso19139.php: Cannot create termsofuse entry from given json license in metadata!");
+								$licenseId = null;
+							} else {
+								$sql = <<<SQL
+SQL;
+								$v = array($licenseJson->id);
+								$t = array('s');
+				} else {
+			} else {
+				$licenseId = $this->termsOfUseRef;
+		//do the sql job
+		if ($licenseId != null) {
+			$sql = <<<SQL
+			INSERT INTO md_termsofuse (fkey_termsofuse_id, fkey_metadata_id) VALUES ($1, $2);
+SQL;
+			$v = array((integer)$licenseId,(integer)$metadataId);
+			$t = array('i','i');
+			if (!$res){
+				$e = new mb_exception("classes/class_Iso19139.php: "._mb("Cannot insert termsofuse relation!"));
-		//relation is set via metadata editor
 	public function deleteCategoriesFromCoupledResource($metadataId,$resourceType,$resourceId) {
@@ -1645,6 +1717,16 @@
 		} else {
 			$e = new mb_notice("class_Iso19139: keyword relations deleted from database!");
+		//delete license relation from db
+		$sql = "DELETE FROM md_termsofuse where fkey_metadata_id = $1 ";
+		$t = array('i');
+		if (!$res) {
+			$e = new mb_exception("class_Iso19139.php:"._mb("Cannot delete termsofuse relation for metadata with id ".$metadataId));
+		} else {
+			$e = new mb_notice("class_Iso19139.php: termsofuse relation deleted from database!");
 		$this->deleteCategoriesFromCoupledResource($metadataId,$resourceType,$resourceId);
@@ -1918,6 +2000,7 @@
 	public function insertToDB($resourceType, $resourceId){
 		$result = array(); //value/message
 		switch ($this->origin) {
 			case "capabilities":
 				//check if href is given and resource can be parsed
@@ -2001,6 +2084,7 @@
 			$e = new mb_notice("existing metadata fileIdentifier found at metadata with id: ".$metadataId[0]." - update will be performed");
 			//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
 			$res = $this->updateMetadataById($metadataId[0]);
+			$this->insertKeywordsAndCategoriesIntoDB($metadataId[0],$resourceType,$resourceId);
 		} else {
 			//check if href already exists
 			$metadataId = $this->isLinkAlreadyInDB();
@@ -2010,6 +2094,7 @@
 				$e = new mb_notice("existing metadata linkage found at metadata with id: ".$metadataId[0]." - update will be performed");
 			} else {
 				//insert new record
 				$e = new mb_notice("class_Iso19139:"."No existing metadata fileIdentifier found in mapbender metadata table. New record will be inserted with uuid: ".$this->fileIdentifier);
More information about the Mapbender_commits mailing list
