[Mapbender-commits] r9335 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Dec 10 01:03:01 PST 2015
Author: armin11
Date: 2015-12-10 01:03:01 -0800 (Thu, 10 Dec 2015)
New Revision: 9335
trunk/mapbender/http/classes/class_metadata_new.php
Fix for serving categories, keywords and tagclouds from searchinterface and resources dataset and wfs
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php 2015-12-09 12:02:26 UTC (rev 9334)
+++ trunk/mapbender/http/classes/class_metadata_new.php 2015-12-10 09:03:01 UTC (rev 9335)
@@ -921,8 +921,8 @@
if ($this->resultTarget == 'webclient') {
$this->allJSON = new stdClass;
- $this->allJSON->categories = $this->json->decode($this->keyJSON);
- $this->allJSON->keywords = $this->json->decode($this->catJSON);
+ $this->allJSON->categories = $this->json->decode($this->catJSON);
+ $this->allJSON->keywords = $this->json->decode($this->keyJSON);
//load filter from file getFromStorage
$admin = new administration();
$filename = $this->tempFolder."/".$this->searchId."_filter.json";
@@ -982,6 +982,32 @@
if ($this->resultTarget == 'internal') {
$this->internalResult = $this->wfsJSON;
+ if ($this->resultTarget == 'webclient') {
+ $this->allJSON = new stdClass;
+ //load filter from file getFromStorage
+ $admin = new administration();
+ $filename = $this->tempFolder."/".$this->searchId."_filter.json";
+ $fileExists = $admin->getFromStorage($filename,TMP_SEARCH_RESULT_STORAGE);
+ if ($fileExists == false) {
+ $e = new mb_exception("class_metadata_new.php: No filter json exists!");
+ } else {
+ $filterJSON = $fileExists;
+ $filterJSON = $this->json->decode($filterJSON);
+ $this->allJSON->filter = $filterJSON;
+ $this->allJSON->wfs = $this->json->decode($this->wfsJSON);
+ //$e = new mb_exception("originFromHeader: ".$this->originFromHeader);
+ if ($this->originFromHeader != false) {
+ header('Access-Control-Allow-Origin: '.$this->originFromHeader);
+ //if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
+ // header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
+ echo $this->json->encode($this->allJSON);
+ //echo "test";
$e = new mb_notice("Time to generate WFS-Metadata: ".$usedTime);
@@ -1011,6 +1037,32 @@
if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
echo $this->wmcJSON;
+ } else {
+ $this->allJSON->wmc = $this->json->decode($this->wmcJSON);
+ //echo "test";
$usedTime2 = $this->microtime_float() - $starttime;
//echo "<br>used time: ".$usedTime."<br>";
@@ -1042,6 +1094,32 @@
echo $this->datasetJSON;
+ } else {
+ $this->allJSON->dataset = $this->json->decode($this->datasetJSON);
+ //echo "test";
More information about the Mapbender_commits
