[Mapbender-commits] r9205 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Tue Jun  9 02:36:11 PDT 2015
Author: armin11
Date: 2015-06-09 02:36:11 -0700 (Tue, 09 Jun 2015)
New Revision: 9205
Added:
   trunk/mapbender/http/php/mod_ownedGui_group.php
   trunk/mapbender/http/php/mb_getGUIs.php
   trunk/mapbender/http/php/mod_filteredGui_group.php
New module that does not allow the inheritance of gui credentials
Modified: trunk/mapbender/http/php/mb_getGUIs.php
--- trunk/mapbender/http/php/mb_getGUIs.php	2015-06-09 09:02:48 UTC (rev 9204)
+++ trunk/mapbender/http/php/mb_getGUIs.php	2015-06-09 09:36:11 UTC (rev 9205)
@@ -18,50 +18,71 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 #returns an array of all guis of the user
-function mb_getGUIs($mb_user_id){
+function mb_getGUIs($mb_user_id, $onlyOwn = false){
 	$arrayGuis = array();
-	if(isset($mb_user_id)){
-		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
-		$v = array($mb_user_id);
-		$t = array('i');
-		$res_groups = db_prep_query($sql_groups,$v,$t);
-		$cnt_groups = 0;
-		while(db_fetch_row($res_groups)){
-			$mb_user_groups[$cnt_groups] = db_result($res_groups,$cnt_groups,"fkey_mb_group_id");
-			$cnt_groups++;
-		$count_g = 0;
-		if($cnt_groups > 0){
-			$v = array();
-			$t = array();
-			$sql_g = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE( gui_mb_group.fkey_mb_group_id IN (";
-			for($i=0; $i<count($mb_user_groups);$i++){
-				if($i > 0){$sql_g .= ",";}
-				$sql_g .= "$".($i + 1);
-				array_push($v,$mb_user_groups[$i]);
-				array_push($t,'i');
+	if ($onlyOwn == false) {
+		if(isset($mb_user_id)){
+			$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+			$v = array($mb_user_id);
+			$t = array('i');
+			$res_groups = db_prep_query($sql_groups,$v,$t);
+			$cnt_groups = 0;
+			while(db_fetch_row($res_groups)){
+				$mb_user_groups[$cnt_groups] = db_result($res_groups,$cnt_groups,"fkey_mb_group_id");
+				$cnt_groups++;
-			$sql_g .= "))";
-			$res_g = db_prep_query($sql_g,$v,$t);
-			while(db_fetch_row($res_g)){
-				$arrayGuis[$count_g] = db_result($res_g, $count_g, "gui_id");
-				$count_g++;
+			$count_g = 0;
+			if($cnt_groups > 0){
+				$v = array();
+				$t = array();
+				$sql_g = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_group ";
+				$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE( gui_mb_group.fkey_mb_group_id IN (";
+				for($i=0; $i<count($mb_user_groups);$i++){
+					if($i > 0){$sql_g .= ",";}
+					$sql_g .= "$".($i + 1);
+					array_push($v,$mb_user_groups[$i]);
+					array_push($t,'i');
+				$sql_g .= "))";
+				$res_g = db_prep_query($sql_g,$v,$t);
+				while(db_fetch_row($res_g)){
+					$arrayGuis[$count_g] = db_result($res_g, $count_g, "gui_id");
+					$count_g++;
+			$sql_guis = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_user ";
+			$sql_guis .= "ON gui.gui_id = gui_mb_user.fkey_gui_id WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+			$sql_guis .= " AND gui.gui_public = 1";
+			$t = array('i');
+			$res_guis = db_prep_query($sql_guis,$v,$t);
+			$count_guis = 0;
+			while(db_fetch_row($res_guis)){
+				if( !in_array(db_result($res_guis,$count_guis,"gui_id"),$arrayGuis)){
+					$arrayGuis[$count_g] = db_result($res_guis,$count_guis,"gui_id");
+					$count_g++;
+				$count_guis++;
-		$sql_guis = "SELECT DISTINCT gui.gui_id FROM gui JOIN gui_mb_user ";
-		$sql_guis .= "ON gui.gui_id = gui_mb_user.fkey_gui_id WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
-		$sql_guis .= " AND gui.gui_public = 1";
-		$t = array('i');
-		$res_guis = db_prep_query($sql_guis,$v,$t);
-		$count_guis = 0;
-		while(db_fetch_row($res_guis)){
-			if( !in_array(db_result($res_guis,$count_guis,"gui_id"),$arrayGuis)){
-				$arrayGuis[$count_g] = db_result($res_guis,$count_guis,"gui_id");
-				$count_g++;
+	} else {
+			//$e = new mb_exception("/php/mb_getGUIs.php: only owned!");
+			$count_g = 0;
+			$sql_guis .= " AND gui.gui_public = 1 AND gui_mb_user.mb_user_type = 'owner'";
+			$t = array('i');
+			$count_guis = 0;
+					$count_g++;
+				$count_guis++;
-			$count_guis++;
 	return $arrayGuis;
Modified: trunk/mapbender/http/php/mod_filteredGui_group.php
--- trunk/mapbender/http/php/mod_filteredGui_group.php	2015-06-09 09:02:48 UTC (rev 9204)
+++ trunk/mapbender/http/php/mod_filteredGui_group.php	2015-06-09 09:36:11 UTC (rev 9205)
@@ -116,6 +116,7 @@
 /*get allocated gui  ******************************************************************************/
 $arrayGuis=mb_getGUIs($logged_user_id);
+//$e = new mb_exception("/php/mb_getGUIs.php: count guis: ".count($arrayGuis));
 $v = array();
 $t = array();
 $sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
@@ -206,4 +207,4 @@
 </script>
 </body>
-</html>
\ No newline at end of file
+</html>
Added: trunk/mapbender/http/php/mod_ownedGui_group.php
--- trunk/mapbender/http/php/mod_ownedGui_group.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_ownedGui_group.php	2015-06-09 09:36:11 UTC (rev 9205)
@@ -0,0 +1,210 @@
+<?php
+# $Id: mod_filteredGui_group.php 7263 2010-12-12 10:03:45Z christoph $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$e_id="filteredGui_Group";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+$postvars = explode(",", "selected_gui,insert,remove,remove_group,selected_group");
+foreach ($postvars as $value) {
+   $$value = $_POST[$value];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Administration</title>
+<?php
+include '../include/dyn_css.php';
+<script language="JavaScript">
+function validate(wert){
+	if(document.forms[0]["selected_gui"].selectedIndex == -1){
+		document.getElementsByName("selected_gui")[0].style.backgroundColor = '#ff0000';
+		return;
+	}else{
+		if(wert == "remove"){
+			if(document.forms[0]["remove_group[]"].selectedIndex == -1){
+				document.getElementsByName("remove_group[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.remove.value = 'true';
+			document.form1.submit();
+		if(wert == "insert"){
+			if(document.forms[0]["selected_group[]"].selectedIndex == -1){
+				document.getElementsByName("selected_group[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.insert.value = 'true';
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
+$fieldHeight = 20;
+$cnt_gui = 0;
+$cnt_group = 0;
+$cnt_group = 0;
+$cnt_gui_group = 0;
+$gui_id_array = array();
+$logged_user_name = Mapbender::session()->get("mb_user_name");
+$logged_user_id = Mapbender::session()->get("mb_user_id");
+/*handle remove, update and insert*****************************************************************/
+if($insert){
+	if(count($selected_group)>0){
+		for($i=0; $i<count($selected_group); $i++){
+			$exists = false;
+			$sql_insert = "SELECT * from gui_mb_group where fkey_gui_id = $1 and fkey_mb_group_id = $2";
+			$v = array($selected_gui,$selected_group[$i]);
+			$t = array('s','i');
+			$res_insert = db_prep_query($sql_insert,$v,$t);
+			while(db_fetch_row($res_insert)){$exists = true;}
+			if($exists == false){
+				$sql_insert = "INSERT INTO gui_mb_group(fkey_gui_id, fkey_mb_group_id) VALUES($1, $2)";
+if($remove){
+	if(count($remove_group)>0){
+		for($i=0; $i<count($remove_group); $i++){
+			$sql_remove = "DELETE FROM gui_mb_group WHERE fkey_mb_group_id = $1 and fkey_gui_id = $2";
+			$v = array($remove_group[$i],$selected_gui);
+			$t = array('i','s');
+			db_prep_query($sql_remove,$v,$t);
+/*get allocated gui  ******************************************************************************/
+$arrayGuis=mb_getGUIs($logged_user_id, true);
+$v = array();
+$t = array();
+$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
+for($i=0; $i<count($arrayGuis); $i++){
+	if($i>0){ $sql_gui .= ",";}
+	$sql_gui .= "$".($i + 1);
+	array_push($v,$arrayGuis[$i]);
+	array_push($t,'s');
+$sql_gui.= ") ORDER BY gui_name";
+$res_gui = db_prep_query($sql_gui,$v,$t);
+while($row = db_fetch_array($res_gui)){
+	$gui_id_array[$cnt_gui] = $row["gui_id"];
+	$gui_name[$cnt_gui] = $row["gui_name"];
+	$cnt_gui++;
+/*get all groups **********************************************************************************/
+$sql_group = "SELECT * FROM mb_group ORDER BY mb_group_name";
+$res_group = db_query($sql_group);
+while($row = db_fetch_array($res_group)){
+	$group_id[$cnt_group] = $row["mb_group_id"];
+	$group_name[$cnt_group] =  $row["mb_group_name"];
+	$cnt_group++;
+/*get all groups from selected gui*****************************************************************/
+$sql_gui_group = "SELECT mb_group.mb_group_id, mb_group.mb_group_name, gui_mb_group.fkey_gui_id FROM gui_mb_group ";
+$sql_gui_group .= "INNER JOIN mb_group ON gui_mb_group.fkey_mb_group_id = mb_group.mb_group_id ";
+$sql_gui_group .= "WHERE gui_mb_group.fkey_gui_id = $1 ";
+$sql_gui_group .= "ORDER BY mb_group.mb_group_name";
+if(!$selected_gui){$v = array($gui_id_array[0]);}
+if($selected_gui){$v = array($selected_gui);}
+$t = array('s');
+$res_gui_group = db_prep_query($sql_gui_group,$v,$t);
+while($row = db_fetch_array($res_gui_group)){
+	$group_id_gui[$cnt_gui_group] = $row["mb_group_id"];
+	$group_name_gui[$cnt_gui_group] =  $row["mb_group_name"];
+	$cnt_gui_group++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+/*insert guis in selectbox*************************************************************************/
+echo "<div class='text1'>GUI: </div>";
+echo "<select style='background:#ffffff' class='select1' name='selected_gui' onChange='submit()' size='10'>";
+for($i=0; $i<$cnt_gui; $i++){
+	echo "<option value='" . $gui_id_array[$i] . "' ";
+	if($selected_gui && $selected_gui == $gui_id_array[$i]){
+		echo "selected";
+	echo ">" . $gui_name[$i]  . "</option>";
+echo "</select>";
+/*insert all groups in selectbox*******************************************************************/
+echo "<div class='text2'>GROUP:</div><br>";
+echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_group[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_group; $i++){
+	echo "<option value='" . $group_id[$i]  . "'>" . $group_name[$i]  . "</option>";
+echo "</select>";
+/*Button*******************************************************************************************/
+echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+/*insert gui_group_dependence and container_group_dependence in selectbox**************************************************/
+echo "<div class='text3'>SELECTED GROUP:</div>";
+echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_group[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui_group; $i++){
+	echo "<option value='" . $group_id_gui[$i]  . "'>" . $group_name_gui[$i]  . "</option>";
+echo "</select>";
+echo "</form>";
+<script type="text/javascript">
+document.forms[0].selected_gui.focus();
+</script>
+</body>
+</html>
More information about the Mapbender_commits
