[Mapbender-commits] r9206 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Jun 9 02:53:22 PDT 2015
Author: armin11
Date: 2015-06-09 02:53:22 -0700 (Tue, 09 Jun 2015)
New Revision: 9206
Added:
trunk/mapbender/http/php/mod_ownedGui_User.php
New module to prohibit inheritance of external gui credentials to exzternal users
Added: trunk/mapbender/http/php/mod_ownedGui_User.php
--- trunk/mapbender/http/php/mod_ownedGui_User.php (rev 0)
+++ trunk/mapbender/http/php/mod_ownedGui_User.php 2015-06-09 09:53:22 UTC (rev 9206)
@@ -0,0 +1,293 @@
+<?php
+# $Id: mod_filteredGui_User.php 8535 2012-12-19 11:31:12Z verenadiewald $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$e_id="filteredGui_user";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+$postvars = explode(",", "selected_gui,filter2,insert,remove,filter3,remove_user,selected_user");
+foreach ($postvars as $value) {
+ $$value = $_POST[$value];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Administration</title>
+<?php
+include '../include/dyn_css.php';
+<script language="JavaScript">
+function validate(wert){
+ if(document.forms[0]["selected_gui"].selectedIndex == -1){
+ document.getElementsByName("selected_gui")[0].style.backgroundColor = '#ff0000';
+ return;
+ }else{
+ if(wert == "remove"){
+ if(document.forms[0]["remove_user[]"].selectedIndex == -1){
+ document.getElementsByName("remove_user[]")[0].style.backgroundColor = '#ff0000';
+ return;
+ document.form1.remove.value = 'true';
+ document.form1.submit();
+ if(wert == "insert"){
+ if(document.forms[0]["selected_user[]"].selectedIndex == -1){
+ document.getElementsByName("selected_user[]")[0].style.backgroundColor = '#ff0000';
+ return;
+ document.form1.insert.value = 'true';
+ * filter the Userlist by str
+function filterUser(list, all, str){
+ str=str.toLowerCase();
+ var selection=[];
+ var i,j,selected;
+ for(i=0;i<list.options.length;i++){
+ if(list.options[i].selected)
+ selection[selection.length]=list.options[i].value;
+ list.options.length = 0;
+ for(i=0; i<all.length; i++){
+ if(all[i]['name'].toLowerCase().indexOf(str)==-1)
+ continue;
+ selected=false;
+ for(j=0;j<selection.length;j++){
+ if(selection[j]==all[i]['id']){
+ selected=true;
+ break;
+ var newOption = new Option(selected?all[i]['name']+" ("+all[i]['email']+")":all[i]['name'],all[i]['id'],false,selected);
+ var title = all[i]['id']+"#"+all[i]['email'];
+ newOption.setAttribute("title", title);
+ list.options[list.options.length] = newOption;
+ * add Mail adress on selection
+function updateMail(list, all){
+ var j=0;
+ for(var i=0; i<list.options.length;i++){
+ if(list.options[i].selected){
+ for(j=j;j<all.length;j++){
+ if(all[j]['id']==list.options[i].value){
+ list.options[i].text=all[j]['name']+" ("+all[j]['email']+")";
+ list.options[i].selected = true;
+ break;
+ else{
+ list.options[i].text=all[j]['name'];
+ list.options[i].selected = false;
+ break;
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
+$fieldHeight = 20;
+$cnt_gui = 0;
+$cnt_user = 0;
+$cnt_group = 0;
+$cnt_gui_user = 0;
+$cnt_gui_group = 0;
+$gui_id_array = array();
+$exists = false;
+$logged_user_name = Mapbender::session()->get("mb_user_name");
+$logged_user_id = Mapbender::session()->get("mb_user_id");
+#echo Mapbender::session()->get("mb_user_name");
+/*handle remove, update and insert*****************************************************************/
+if($insert){
+ if(count($selected_user)>0){
+ for($i=0; $i<count($selected_user); $i++){
+ $exists = false;
+ $sql_insert = "SELECT * from gui_mb_user where fkey_gui_id = $1 and fkey_mb_user_id = $2";
+ $v = array($selected_gui,$selected_user[$i]);
+ $t = array('s','i');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
+ while(db_fetch_row($res_insert)){$exists = true;}
+ if($exists == false){
+ $sql_insert = "INSERT INTO gui_mb_user(fkey_gui_id, fkey_mb_user_id) VALUES($1, $2)";
+if($remove){
+ if(count($remove_user)>0){
+ for($i=0; $i<count($remove_user); $i++){
+ $sql_remove = "DELETE FROM gui_mb_user WHERE fkey_mb_user_id = $1 and fkey_gui_id = $2";
+ $v = array($remove_user[$i],$selected_gui);
+ $t = array('i','s');
+ db_prep_query($sql_remove,$v,$t);
+/*get allocated gui ******************************************************************************/
+$arrayGuis=mb_getGUIs($logged_user_id, true);
+$v = array();
+$t = array();
+$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
+for($i=0; $i<count($arrayGuis); $i++){
+ if($i>0){ $sql_gui .= ",";}
+ $sql_gui .= "$".($i+1);
+ array_push($v,$arrayGuis[$i]);
+ array_push($t,'s');
+$sql_gui.= ") ORDER BY gui_name";
+$res_gui = db_prep_query($sql_gui,$v,$t);
+while($row = db_fetch_array($res_gui)){
+ $gui_id_array[$cnt_gui] = $row["gui_id"];
+ $gui_name[$cnt_gui] = $row["gui_name"];
+ $cnt_gui++;
+/*get all user **********************************************************************************************/
+$sql_user = "SELECT * FROM mb_user ORDER BY mb_user_name";
+$res_user = db_query($sql_user);
+while($row = db_fetch_array($res_user)){
+ $user_id[$cnt_user] = $row["mb_user_id"];
+ $user_name[$cnt_user] = $row["mb_user_name"];
+ $user_email[$cnt_user] = $row["mb_user_email"];
+ $cnt_user++;
+/*get all user from selected gui*******************************************************************/
+$sql_gui_mb_user = "SELECT mb_user.mb_user_email, mb_user.mb_user_id, mb_user.mb_user_name, gui_mb_user.fkey_gui_id FROM gui_mb_user ";
+$sql_gui_mb_user .= "INNER JOIN mb_user ON gui_mb_user.fkey_mb_user_id = mb_user.mb_user_id ";
+$sql_gui_mb_user .= "WHERE gui_mb_user.fkey_gui_id= $1 ";
+$sql_gui_mb_user .= " ORDER BY mb_user.mb_user_name";
+if(!$selected_gui){$v = array($gui_id_array[0]);}
+if($selected_gui){$v = array($selected_gui);}
+$t = array('s');
+$res_gui_mb_user = db_prep_query($sql_gui_mb_user,$v,$t);
+while($row = db_fetch_array($res_gui_mb_user)){
+ $user_id_gui[$cnt_gui_user] = $row["mb_user_id"];
+ $user_name_gui[$cnt_gui_user] = $row["mb_user_name"];
+ $user_email_gui[$cnt_gui_user] = $row["mb_user_email"];
+ $cnt_gui_user++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+/*insert projects in selectbox********************************************************************/
+echo "<div class='text1'>GUI: </div>";
+echo "<select style='background:#ffffff' class='select1' name='selected_gui' size='10' onchange='submit()'>";
+for($i=0; $i<$cnt_gui; $i++){
+ echo "<option value='" . $gui_id_array[$i] . "' ";
+ if($selected_gui && $selected_gui == $gui_id_array[$i]){
+ echo "selected";
+ echo ">" . $gui_name[$i] . "</option>"; }
+echo "</select>";
+/*filterbox****************************************************************************************/
+echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' owner-check='off' data-target-type='select' autocomplete='off'/>";
+//echo "<input type='text' value='' class='filter2' id='filter2' name='filter2' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
+/*insert all profiles in selectbox*****************************************************************/
+echo "<div class='text2'>USER:</div>";
+echo "<select style='background:#ffffff' onchange='updateMail(this, user)' class='select2' multiple='multiple' id='selecteduser' name='selected_user[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_user; $i++){
+ echo "<option value='" . $user_id[$i] . "' title='".$user_id[$i]."#".$user_email[$i]."'>" . $user_name[$i] . "</option>";
+echo "</select>";
+/*Button*******************************************************************************************/
+echo "<div class='button1'><input type='button' value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+echo "<input type='text' value='' class='filter3' id='filter3' name='filter3' onkeyup='filterUser(document.getElementById(\"removeuser\"),guiuser,this.value);'/>";
+/*insert container_profile_dependence and container_group_dependence in selectbox******************/
+echo "<div class='text3'>SELECTED USER:</div>";
+echo "<select style='background:#ffffff' onchange='updateMail(this, user)' class='select3' multiple='multiple' name='remove_user[]' id='removeuser' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui_user; $i++){
+ echo "<option value='" . $user_id_gui[$i] . "' title='".$user_id[$i]."#".$user_email_gui[$i]."'>" . $user_name_gui[$i] . "</option>";
+echo "</select>";
+echo "</form>";
+<script type='text/javascript' src="../extensions/jquery.js"></script>
+<script type='text/javascript' src="../javascripts/user.js"></script>
+<script type="text/javascript">
+document.forms[0].selected_gui.focus();
+var user=[];
+<?php
+ echo "user[".$i."]=[];\n";
+ echo "user[".$i."]['id']='" . $user_id[$i] . "';\n";
+ echo "user[".$i."]['name']='" . $user_name[$i] . "';\n";
+ echo "user[".$i."]['email']='" . $user_email[$i] . "';\n";
+var guiuser=[];
+<?php
+ echo "guiuser[".$i."]=[];\n";
+ echo "guiuser[".$i."]['id']='" . $user_id_gui[$i] . "';\n";
+ echo "guiuser[".$i."]['name']='" . $user_name_gui[$i] . "';\n";
+ echo "guiuser[".$i."]['email']='" . $user_email_gui[$i] . "';\n";
+</script>
+</body>
+</html>
More information about the Mapbender_commits
