[Mapbender-commits] r9196 - trunk/mapbender/http/plugins
    svn_mapbender at osgeo.org
    Tue May  5 02:42:48 PDT 2015
Author: armin11
Date: 2015-05-05 02:42:48 -0700 (Tue, 05 May 2015)
New Revision: 9196
   trunk/mapbender/http/plugins/mb_digitize_widget.php
More translations
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-05-05 06:44:56 UTC (rev 9195)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-05-05 09:42:48 UTC (rev 9196)
@@ -71,26 +71,26 @@
 var DigitizeApi = function (o) {
     var digitizeHtml = '<div title="<?php echo _mb("Sketch");?>">' +
-        '<div class="digitize-image digitize-point"></div>' +
-        '<div class="digitize-image digitize-line"></div>' +
-        '<div class="digitize-image digitize-polygon"></div>' +
-        '<div class="digitize-image digitize-attributes editFeatureCollection"></div>' +
+        '<div  title="<?php echo _mb("Digitize new point");?>"class="digitize-image digitize-point"></div>' +
+        '<div  title="<?php echo _mb("Digitize new line");?>"class="digitize-image digitize-line"></div>' +
+        '<div  title="<?php echo _mb("Digitize new polygon");?>"class="digitize-image digitize-polygon"></div>' +
+        '<div  title="<?php echo _mb("Attributes of collection");?>"class="digitize-image digitize-attributes editFeatureCollection"></div>' +
         '</div>';
     var editHtml = '<div title="<?php echo _mb("Edit feature");?>">' +
         '<div class="digitize-preview"></div>' +
         '<span>my polygon</span><br></br>' +
-        '<div class="digitize-image digitize-style"></div>' +
-        '<div class="digitize-image digitize-attributes"></div>' +
+        '<div title="<?php echo _mb("Edit style");?>" class="digitize-image digitize-style"></div>' +
+        '<div title="<?php echo _mb("Edit attributes");?>" class="digitize-image digitize-attributes"></div>' +
         // '<div class="digitize-image digitize-add"></div>' +
-        '<div class="digitize-image digitize-remove"></div>' +
-        '<div class="digitize-image digitize-pencil"></div>' +
+        '<div title="<?php echo _mb("Delete feature");?>" class="digitize-image digitize-remove"></div>' +
+        '<div title="<?php echo _mb("Edit geometry");?>" class="digitize-image digitize-pencil"></div>' +
         '<fieldset class="fieldset-auto-width digitize-hidden">' +
-        '<div class="digitize-image digitize-move"></div>' +
-        '<div class="digitize-image digitize-add-vertex"></div>' +
-        '<div class="digitize-image digitize-move-vertex"></div>' +
-        '<div class="digitize-image digitize-delete-vertex"></div></fieldset>' +
-        '<div class="digitize-image digitize-export digitize-export-edit-dialog"></div>' +
+        '<div title="<?php echo _mb("Move geometry");?>" class="digitize-image digitize-move"></div>' +
+        '<div title="<?php echo _mb("Add vertex");?>" class="digitize-image digitize-add-vertex"></div>' +
+        '<div title="<?php echo _mb("Move vertex");?>" class="digitize-image digitize-move-vertex"></div>' +
+        '<div title="<?php echo _mb("Delete vertex");?>" class="digitize-image digitize-delete-vertex"></div></fieldset>' +
+        '<div title="<?php echo _mb("Export geometry");?>" class="digitize-image digitize-export digitize-export-edit-dialog"></div>' +
         '</div>';
     var editAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
@@ -100,17 +100,17 @@
         '<table><tr><td><?php echo _mb("Name");?></td><td><input type="text" name="name" value="<?php echo _mb("Name");?>"></input></td></tr>' +
         '<tr><td><?php echo _mb("Description");?></td><td><input type="text" name="description" value="<?php echo _mb("Description CDATA");?>"></input></td></tr>' +
         '</table><br></br>' +
-        '<div class="digitize-image digitize-add"></div>' +
-        '<div class="digitize-image digitize-save"></div>' +
+        '<div title="<?php echo _mb("Add attribute");?>" class="digitize-image digitize-add"></div>' +
+        '<div title="<?php echo _mb("Save object");?>" class="digitize-image digitize-save"></div>' +
         '</div>';
     var tableEditAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
         '<div class="digitize-preview"></div><br></br>' +
         '<div class="attrAccordion">' +
         '</div><br></br>' +
         '</div>';
     var editStyleHtml = '<div title="<?php echo _mb("Edit style");?>">' +
@@ -133,7 +133,7 @@
         '<tr><td><?php echo _mb("Fill color");?>:</td><td><input type="color" name="fill" value="#ff0000"></input></td></tr>' +
         '<tr><td><?php echo _mb("Fill opacity");?>:</td><td><div class="opacity-slider" data-name="fill-opacity"></div></td></tr>' +
+        '<div title="<?php echo _mb("Save styling");?>" class="digitize-image digitize-save"></div>' +
         '<button name="digitize-reset-style"><?php echo _mb("Reset");?></button>' +
         '</div>';
@@ -709,13 +709,23 @@
                         styleRows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
-                    } else if( k == "area" || k == "boundary-length" || k == "track-length"){ // ||  k == "Boundary-Length [m]"
+                    } else if( k == "area" || k == "boundary-length" || k == "track-length"){
+				switch(k) {
+				    case "area":
+				        header = "<?php echo _mb("Area [m²]");?>";
+				        break;
+				    case "boundary-length":
+				        header = "<?php echo _mb("Boundary length [m]");?>";
+				        break;
+				    case "track-length":
+				        header = "<?php echo _mb("Length [m]");?>";
+				        break;
+                            	geometryDiv.append('<div><p class = " geometry-p "name="' + k + '">'+ header +' : ' + v + '</p></div>');
-                            geometryDiv.append('<div><p class = " geometry-p "name="' + k + '">'+ k +' : ' + v + '</p></div>');
                     } else{
-                        customRows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td><td><img class="removeCustomFeatAttr" src="../img/button_digitize/geomRemove.png"></td></tr>';
+                        customRows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td><td><img class="removeCustomFeatAttr" src="../img/button_digitize/geomRemove.png" title="<?php echo _mb("Remove attribute");?>"></td></tr>';
@@ -1022,12 +1032,12 @@
                     if (geom.geomType == 'polygon') {
 			//TODO: use attributes area and length - not complex strings!
-                        editedFeature.properties['Area [m²]'] = data[0];
-                        editedFeature.properties['Boundary-Length [m]'] = data[1];
+                        editedFeature.properties['area'] = data[0];
+                        editedFeature.properties['boundary-length'] = data[1];
                     } else {
-                        editedFeature.properties['Length [m]'] = data[0];
+                        editedFeature.properties['track-length'] = data[0];
More information about the Mapbender_commits
