[Mapbender-commits] r9375 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Tue Jan 19 03:06:05 PST 2016
Author: armin11
Date: 2016-01-19 03:06:05 -0800 (Tue, 19 Jan 2016)
New Revision: 9375
Added:
   trunk/mapbender/http/php/mod_owsproxy_wfs_conf.php
Simple html page to define which wfs should be proxied and logged
Added: trunk/mapbender/http/php/mod_owsproxy_wfs_conf.php
--- trunk/mapbender/http/php/mod_owsproxy_wfs_conf.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_owsproxy_wfs_conf.php	2016-01-19 11:06:05 UTC (rev 9375)
@@ -0,0 +1,265 @@
+<?php
+# $Id: mod_owsproxy_conf.php 8786 2014-02-28 12:57:18Z verenadiewald $
+# http://www.mapbender.org/index.php/mod_owsproxy_wfs_conf.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc.,  59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+include(dirname(__FILE__)."/../php/mb_validateSession.php");
+include(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownwfs = $admin->getWfsByWfsOwner($_SESSION["mb_user_id"]);
+#need admin functions: getWmsLogTag, getWmsPrice, setWmsLogTag, setWmsPrice
+#can set log only when proxy on, can set price only when log on
+#read out the request
+ function array2str($array, $pre = '', $pad = '', $sep = ', ')
+     $str = '';
+     if(is_array($array)) {
+         if(count($array)) {
+             foreach($array as $v) {
+                 $str .= $pre.$v.$pad.$sep;
+             $str = substr($str, 0, -strlen($sep));
+     } else {
+         $str .= $pre.$array.$pad;
+     return $str;
+function validateint($inData) {
+  $intRetVal = 0;
+  $IntValue = intval($inData);
+  $StrValue = strval($IntValue);
+  if($StrValue == $inData) {
+    $intRetVal = $IntValue;
+  return $intRetVal;
+if(isset($_REQUEST["save"])){
+#if(isset($_REQUEST["wms_id"]) && isset($_REQUEST["status"])){
+	#$admin->setWMSOWSstring(intval($_REQUEST["wms_id"]),$_REQUEST["status"]);
+#print_r($_POST);
+#TODO deactivate proxy, logs and prices for all owned wms
+#TODO
+#$wms_list=array2str($ownwms);
+#print $wms_list;
+//$admin->unsetWmsProxy($wms_list);#TODO not delete owsproxy urls but update each entry! -> this would not delete log or usage of proxy!!!
+#serialize ownwms - to list and do sql
+#for the definitions in the form set the params
+#sequentialy read out the post variables
+if(isset($_POST["save"])) {
+foreach ($_POST as $var => $value) {
+	#select those which are relevant (hidden fields for proxy and log)
+	#identify them
+	$parts=explode("_",$var);
+	#echo "All vars: <br>";
+	#echo $var." = ".$value."<br>";
+	$value=validateint($value);
+	if ($parts[0]!= 'status' && $parts[2]=='price'){ #for the pricing in the textfield
+		if($parts[0] == "wfs") {
+            		$admin->setWfsPrice(intval($value),intval($parts[1]));
+	#check the hidden fields if some log should be set
+	if ($parts[2]=='log' && $parts[0]=='status'){
+		#set the log value to 1 or 0
+        if($parts[2]=='log'){
+            $admin->setWfsLogTag(intval($parts[1]),$value);
+		#if value is 0 then set the price to 0 to. there would be is no sense to have a price set - maybe change this behavior
+		if ($value==0) {
+		#echo "log: $var = $value<br>";
+	#check proxy fields
+	if ($parts[0]=='status' && $parts[2]=='proxy'){
+		#echo ("proxy settings identified: WMS_ID: ".intval($parts[1])." Value: ".$value."<br>");
+		#echo ("Is active?: ");
+		#if ($admin->getWMSOWSstring(intval($parts[1]))=="") {echo " no";} else {echo " yes";}
+		#echo ("<br>");
+		#check if proxy should be activated and is not set
+		if ($value==1 && $admin->getWFSOWSstring(intval($parts[1])) == "") {
+		#activate it!
+		$admin->setWFSOWSstring(intval($parts[1]),$value);
+		#echo "Activate Proxy for ".intval($parts[1])."<br>";
+		#check if active proxy should be deactivated
+		if ($value==0 && $admin->getWFSOWSstring(intval($parts[1])) !== "") {
+		#deactivate it
+		#echo "Deactivate Proxy for ".intval($parts[1])."<br>";
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>OWS Security Proxy</title>
+<style type="text/css">
+body{
+	font-family: Arial, Helvetica, sans-serif;
+</style>
+<script language="JavaScript" type="text/javascript">
+</script>
+</head>
+<body>
+<table>
+<?php
+#$ownwmsconf['proxy']=array();
+#$ownwmsconf['log']=array();
+#$ownwmsconf['price']=array();
+#TODO Get root layer id for showing metadata! - function should be in admin class
+echo "<form  method=\"post\" action=\"".$_SERVER["SCRIPT_NAME"]."\">
+    <i>Warning: Toggle proxy changes the url of the secured services!</i><br>
+    <table border='1'>
+        <tr valign = bottom>
+            <td>WFS ID</td>
+            <td>WFS Title</td>
+            <td>Proxy</td>
+            <td>GetFeature Log</td>
+            <td>GetFeature Price(cent/feature)</td>
+            <td>Show detailed Usage</td>
+        </tr>";
+for($i=0; $i<count($ownwfs); $i++){
+	#read out current values in db
+	if($admin->getWFSOWSstring($ownwfs[$i]) == false){ $status_proxy = 0 ;} else {$status_proxy = 1;};
+	if($admin->getWfsLogTag($ownwfs[$i]) == 1){$status_log=1;} else {$status_log=0;};
+	if ($admin->getWfsPrice($ownwfs[$i]) != 0 ){$status_price=$admin->getWfsPrice($ownwfs[$i]);} else {$status_price=0;};
+	$auth = $admin->getAuthInfoOfWFS($ownwfs[$i]);
+	if($auth['auth_type'] == ''){$status_auth = 0;} else {$status_auth = 1;};
+	echo "<tr>";
+	echo "<td>".$ownwfs[$i]."</td>";
+	echo "<td";
+	if($status_auth == 1){echo " bgcolor=\"#FF0000\"";};
+	echo ">".$admin->getWfsTitleByWfsId($ownwfs[$i]);
+	echo "<td>";
+	#for owsproxy
+	echo "<input type='checkbox' id='wfs_".$ownwfs[$i]."_proxy' name='wfs_".$ownwfs[$i]."_proxy'
+        onclick='if(this.checked){
+            document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_log\").disabled=false;
+            document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_price\").disabled=true;
+            document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_proxy\").value=\"1\";
+        }else{
+            document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_log\").checked=false;
+            document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_log\").disabled=true;
+            document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_price\").value=\"0\";
+            document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_proxy\").value=\"0\";
+            document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_log\").value=\"0\";
+	#default
+	if($status_proxy == 1){ echo " checked";  } else {echo " unchecked"; };  //if a proxy string is set
+	if($status_auth == 1){ echo " disabled";};
+	echo ">";
+	#initialize hidden field for status proxy:
+	echo "<input type=\"hidden\" name=\"status_".$ownwfs[$i]."_proxy\" id=\"status_".$ownwfs[$i]."_proxy\" value=".$status_proxy.">";
+	echo "</td>";
+	#for logging
+	echo "<td><input type='checkbox' id='wfs_".$ownwfs[$i]."_log' name='wfs_".$ownwfs[$i]."_log' onclick='if(this.checked){document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_price\").disabled=false;document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_log\").value=\"1\"}else{document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_price\").disabled=true;document.getElementById(\"wfs_\"+".$ownwfs[$i]."+\"_price\").value=\"0\";document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_log\").value=\"0\";document.getElementById(\"status_\"+".$ownwfs[$i]."+\"_price\").value=\"0\"}'";
+	#default
+	if($status_proxy==0){ echo "disabled "; };
+	if($status_log == 1){ echo " checked";  };//if a log tag is set -> to activate
+	echo ">";
+	#initialize hidden field for status log:
+	echo "<input type=\"hidden\" name=\"status_".$ownwfs[$i]."_log\" id=\"status_".$ownwfs[$i]."_log\" value=".$status_log.">";
+	echo "</td>";
+	#for pricing
+	echo "<td><input id='wfs_".$ownwfs[$i]."_price' name='wfs_".$ownwfs[$i]."_price' type='text' size='5' value='";
+	echo $status_price;
+	echo "' ";
+	#default
+	if($status_log != 1){ echo "disabled";  } else { echo "enabled";  };
+	//if($admin->getWmsPrice($ownwms[$i]) != 0){ echo "disabled";  }
+	echo ">";
+	#initialize hidden field for status price:
+	echo "<input type=\"hidden\" name=\"status_".$ownwfs[$i]."_price\" id=\"status_".$ownwfs[$i]."_price\" value=".$status_price.">";
+	echo "</td>";
+if($status_log == 1){
+echo "<td><input type=button value='Show Usage' onclick=\"var newWindow = window.open('../php/mod_UsageShow.php?wfsid=".$ownwfs[$i]."','wfs','width=800,height=700,scrollbars');newWindow.href.location='Usage of Service: ".$wfs_id."'\"></td>";
+echo "</tr>";
+echo "</table>";
+echo "<br>";
+echo "<table><tr><td bgcolor=\"#FF0000\">Service with authentication information</td></tr></table>";
+echo "<input type='submit' name='save' value='save'  ></form>";
+</table>
+</form>
+</body>
+</html>
More information about the Mapbender_commits
