[Mapbender-commits] r9376 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org
Tue Jan 19 03:11:22 PST 2016
Author: armin11
Date: 2016-01-19 03:11:22 -0800 (Tue, 19 Jan 2016)
New Revision: 9376
trunk/mapbender/owsproxy/http/index.php
Possibility to log owsproxy secured wfs getfeature requests
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2016-01-19 11:06:05 UTC (rev 9375)
+++ trunk/mapbender/owsproxy/http/index.php 2016-01-19 11:11:22 UTC (rev 9376)
@@ -278,7 +278,7 @@
//$request = $query->getRequest();
// Ergaenzungen secured UMN Requests
- #log proxy requests
+ //log proxy requests
if ($n->getWmsLogTag($arrayOnlineresources['wms_id']) == 1) {#do log to db
#get price out of db
$price = intval($n->getWmsPrice($arrayOnlineresources['wms_id']));
@@ -327,10 +327,18 @@
$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
$request = stripslashes($request);
+ if ($n->getWfsLogTag($arrayOnlineresources['wfs_id']) == 1) {
+ //get price out of db
+ $price = intval($n->getWfsPrice($arrayOnlineresources['wfs_id']));
+ $log_id = $n->logWfsProxyRequest($arrayOnlineresources['wfs_id'], $_SESSION['mb_user_id'], $request,
+ $price, 0, $reqParams['typename']);
+ } else {
+ $log_id = false;
if (isset($auth)) {
- getFeature($request, $auth);
+ getFeature($log_id, $request, $auth);
} else {
- getFeature($request);
+ getFeature($log_id, $request);
break;
case 'describefeaturetype':
@@ -492,10 +500,10 @@
* @param string the url of the GetFeature request
* @return echo the content of the GetFeature document
-function getFeature($url, $auth = false)
+function getFeature($log_id, $url, $auth = false)
global $reqParams;
- $content = getDocumentContent(false, $url, "Content-Type: application/xml", $auth);
+ $content = getDocumentContent($log_id, $url, "Content-Type: application/xml", $auth);
@@ -930,6 +938,8 @@
function getDocumentContent($log_id, $url, $header = false)
global $reqParams, $n;
+ //debug
+ $startTime = microtime();
if (func_num_args() == 4) { //new for HTTP Authentication
$auth = func_get_arg(3);
$d = new connector($url, $auth);
@@ -937,6 +947,8 @@
$d = new connector($url);
$content = $d->file;
+ $endTime = microtime();
+ $e = new mb_exception("owsproxy/http/index.php: Time for getting remote resource: ".(string)($endTime - $startTime));
if (strtoupper($reqParams["request"]) == "GETMAP") { // getmap
$pattern_exc = '~EXCEPTION~i';
preg_match($pattern_exc, $content, $exception);
@@ -991,16 +1003,17 @@
return true;
} elseif (strtoupper($reqParams["request"]) == "GETFEATURE") {
- $e = new mb_exception("getfeature invoked");
+ $e = new mb_notice("owsproxy/http/index.php: GetFeature invoked");
//parse featureCollection and get number of objects
libxml_use_internal_errors(true);
try {
$featureCollectionXml = simplexml_load_string($content);
if ($featureCollectionXml === false) {
foreach(libxml_get_errors() as $error) {
- $err = new mb_exception("owsproxy/index.php:".$error->message);
+ $err = new mb_exception("owsproxy/http/index.php:".$error->message);
- throw new Exception("owsproxy/index.php:".'Cannot parse featureCollection XML!');
+ throw new Exception("owsproxy/http/index.php:".'Cannot parse featureCollection XML!');
//TODO give error message
@@ -1009,15 +1022,40 @@
if ($featureCollectionXml !== false) {
- $featureCollectionXml->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+ //$featureCollectionXml->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+ $featureCollectionXml->registerXPathNamespace("ogc", "http://www.opengis.net/ogc");
+ $featureCollectionXml->registerXPathNamespace("wfs", "http://www.opengis.net/wfs");
$featureCollectionXml->registerXPathNamespace("gco", "http://www.isotc211.org/2005/gco");
$featureCollectionXml->registerXPathNamespace("gml", "http://www.opengis.net/gml");
$featureCollectionXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
$featureCollectionXml->registerXPathNamespace("xsi", "http://www.w3.org/2001/XMLSchema-instance");
$featureCollectionXml->registerXPathNamespace("default", "");
- $numberOfFeatures = $featureCollectionXml->xpath('//wfs:FeatureCollection/@numberOfFeatures');
- $numberOfFeatures = $numberOfFeatures[0];
- $e = new mb_exception("owsproxy/index.php: ".$numberOfFeatures." delivered features from wfs ");
+ preg_match('@version=(?P<version>\d\.\d\.\d)&@i', strtolower($url), $version);
+ if (!$version['version']) {
+ $e = new mb_notice("owsproxy/http/index.php: No version for wfs request given in url!");
+ switch ($version['version']) {
+ case "1.0.0":
+ //get # of features from counting features
+ $numberOfFeatures = $featureCollectionXml->xpath('//wfs:FeatureCollection/gml:featureMember');
+ $numberOfFeatures = count($numberOfFeatures);
+ $e = new mb_notice("owsproxy/index.php: wfs version ".$version[1]." used");
+ break;
+ case "1.1.0":
+ //get # of features from attribut
+ $numberOfFeatures = $featureCollectionXml->xpath('//wfs:FeatureCollection/@numberOfFeatures');
+ $numberOfFeatures = $numberOfFeatures[0];
+ break;
+ $e = new mb_notice("owsproxy/http/index.php: ".$numberOfFeatures." delivered features from wfs.");
+ //TODO: enhance error management
+ if ($log_id !== false) {
+ $n->updateWfsLog(1, '', '', $numberOfFeatures, $log_id);
+ $e = new mb_notice("owsproxy/http/index.php: Time for counting: ". (string)($endTime - $startTime));
+ $e = new mb_notice("owsproxy/http/index.php: Memory used for XML String: ".getVariableUsage($content)/1000000 ."MB");
if (header !== false) {
header($header);
@@ -1050,4 +1088,9 @@
return $foundUserId;
+function getVariableUsage($var) {
+ $total_memory = memory_get_usage();
+ $tmp = unserialize(serialize($var));
+ return memory_get_usage() - $total_memory;
More information about the Mapbender_commits
