[Mapbender-commits] r9535 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Mon Jul 11 02:12:30 PDT 2016
Author: armin11
Date: 2016-07-11 02:12:29 -0700 (Mon, 11 Jul 2016)
New Revision: 9535
   trunk/mapbender/http/javascripts/mod_addWMS.php
   trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
Fix - thanx to karl owesny
Modified: trunk/mapbender/http/javascripts/mod_addWMS.php
--- trunk/mapbender/http/javascripts/mod_addWMS.php	2016-07-10 15:44:09 UTC (rev 9534)
+++ trunk/mapbender/http/javascripts/mod_addWMS.php	2016-07-11 09:12:29 UTC (rev 9535)
@@ -45,6 +45,7 @@
     return /^(https?|ftp):\/\/(((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:)*@)?(((\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5]))|((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?)(:\d*)?)(\/((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)+(\/(([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)*)*)?)?(\?((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900
 -\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|[\uE000-\uF8FF]|\/|\?)*)?(\#((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|\/|\?)*)?$/i.test(value);
+<<<<<<< .mine
 function paramterbuild(url){
     if(url.indexOf("?") == -1){
         url += '?';
@@ -64,6 +65,51 @@
 function mod_addWMS() {
     var dialogContainer = $("<form/>")
+    var input = $("<input type='text' name='test' style='margin:5px 0px;width:100%;' placeholder='URL eingeben'/>");
+    var label = "<div>Capabilities - URL:</div>";
+    var submitButton = $("<input type='submit' title='Speichern'/>");
+    submitButton.click(function ( event ) {
+        dialogContainer.dialog("close");
+        event.preventDefault();
+        var url = input.val().trim();
+        if (validateUrl(url)) {
+            mod_addWMS_load(paramterbuild(url));
+        } else {
+            input.css({border: '1px solid #FF435C'});
+            //input.addClass()
+            //debugger;
+            dialogContainer.dialog({title: "Es handelt sich nicht um eine URL."});
+    dialogContainer.append(label);
+    dialogContainer.append(input);
+    dialogContainer.append(submitButton);
+    dialogContainer.dialog({title: "WebMapService hinzufügen"});
+function paramterbuild(url){
+    if(url.indexOf("?") == -1){
+        url += '?';
+    //if (url.indexOf("VERSION=") == -1) {
+      //  url += '&VERSION=9.9.9';
+    if(url.indexOf("REQUEST=") == -1){
+        url += '&REQUEST=GetCapabilities';
+    if (url.indexOf("SERVICE=") == -1){
+        url += '&SERVICE=WMS';
+    return url;
+function mod_addWMS() {
+    var dialogContainer = $("<form/>")
     var input = $("<input type='text' name='test'/>");
@@ -89,6 +135,7 @@
+>>>>>>> .r9534
 function base64_encode(data) {
    // Encodes string using MIME base64 algorithm
Modified: trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
--- trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js	2016-07-10 15:44:09 UTC (rev 9534)
+++ trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js	2016-07-11 09:12:29 UTC (rev 9535)
@@ -102,6 +102,7 @@
     return url;
 var mod_addWms_general = function (js, param) {
+<<<<<<< .mine
     var ind = getMapObjIndexByName('mapframe1');
     var map = mb_mapObj[ind];
     var success = false;
@@ -114,6 +115,73 @@
             if (errorcall[0] == "null") {
                 errorcall[0] = "Fehler";
+            var input = $("<input type='text' value='" + errorcall[1] + "' name='test' style='width:100%;margin:5px 0px;'/>");
+            var label = "<div>" + errorcall[0] + "</div>";
+            submitButton.click(function (event) {
+                var urlError = input.val();
+                if (validateUrl(urlError)) {
+                } else {
+            dialogContainer.dialog({title: "WebMapService konnte nicht geladen werden"});
+        var newWmsCount = wms.length;
+        if (newWmsCount > oldWmsCount) {
+            success = true;
+            mb_mapObjaddWMS('mapframe1');
+            var lastwms = map.wms[map.wms.length - 1];
+            if (param && param.options && typeof param.options.zoomToExtent === "number" && param.options.zoomToExtent === 1) {
+                // zoom to bbox
+                var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+                for (var i = 0; i < lastwms.gui_epsg.length; i++) {
+                    if (map.epsg == lastwms.gui_epsg[i]) {
+                        bbox_minx = parseFloat(lastwms.gui_minx[i]);
+                        bbox_miny = parseFloat(lastwms.gui_miny[i]);
+                        bbox_maxx = parseFloat(lastwms.gui_maxx[i]);
+                        bbox_maxy = parseFloat(lastwms.gui_maxy[i]);
+                        if (bbox_minx === null || bbox_miny === null || bbox_maxx === null || bbox_maxy === null) {
+                            continue;
+                        map.calculateExtent(new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy));
+                        map.setMapRequest();
+                        break;
+    if (typeof param === "object"
+        && typeof param.callback === "function"
+        && typeof param.options === "object"
+        param.options.success = success;
+        param.callback(param.options);
+    mb_execloadWmsSubFunctions({
+        wms: map.wms.length > 0 ? map.wms[map.wms.length - 1] : null
+    var ind = getMapObjIndexByName('mapframe1');
+    var map = mb_mapObj[ind];
+    var success = false;
+    if (js) {
+        var oldWmsCount = wms.length;
+        eval(js);
+        if (errorcall) {
+            var errorcall = errorcall.split("|");
+            var dialogContainer = $("<form/>");
+            if (errorcall[0] == "null") {
+                errorcall[0] = "Fehler";
             var input = $("<input type='text' value='" + errorcall[1] + "' name='test'/>");
@@ -168,6 +236,7 @@
+>>>>>>> .r9534
 function mod_addWMSById_ajax(gui_id, wms_id, param) {
     var options = {
More information about the Mapbender_commits
