[Mapbender-commits] r9536 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Jul 11 02:15:26 PDT 2016
Author: armin11
Date: 2016-07-11 02:15:25 -0700 (Mon, 11 Jul 2016)
New Revision: 9536
trunk/mapbender/http/javascripts/mod_addWMS.php
trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
Fix for wrong commit
Modified: trunk/mapbender/http/javascripts/mod_addWMS.php
--- trunk/mapbender/http/javascripts/mod_addWMS.php 2016-07-11 09:12:29 UTC (rev 9535)
+++ trunk/mapbender/http/javascripts/mod_addWMS.php 2016-07-11 09:15:25 UTC (rev 9536)
@@ -45,7 +45,6 @@
return /^(https?|ftp):\/\/(((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:)*@)?(((\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5]))|((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?)(:\d*)?)(\/((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)+(\/(([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)*)*)?)?(\?((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900
-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|[\uE000-\uF8FF]|\/|\?)*)?(\#((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|\/|\?)*)?$/i.test(value);
-<<<<<<< .mine
function paramterbuild(url){
if(url.indexOf("?") == -1){
url += '?';
@@ -90,52 +89,6 @@
dialogContainer.dialog({title: "WebMapService hinzufügen"});
-function paramterbuild(url){
- if(url.indexOf("?") == -1){
- url += '?';
- //if (url.indexOf("VERSION=") == -1) {
- // url += '&VERSION=9.9.9';
- if(url.indexOf("REQUEST=") == -1){
- url += '&REQUEST=GetCapabilities';
- if (url.indexOf("SERVICE=") == -1){
- url += '&SERVICE=WMS';
- return url;
-function mod_addWMS() {
- var dialogContainer = $("<form/>")
- var input = $("<input type='text' name='test'/>");
- var label = "<div>Capabilities - URL:</div>";
- var submitButton = $("<input type='submit' title='Speichern'/>");
- submitButton.click(function ( event ) {
- dialogContainer.dialog("close");
- event.preventDefault();
- var url = input.val().trim();
- if (validateUrl(url)) {
- mod_addWMS_load(paramterbuild(url));
- } else {
- input.css({border: '1px solid #FF435C'});
- //input.addClass()
- //debugger;
- dialogContainer.dialog({title: "Es handelt sich nicht um eine URL."});
- dialogContainer.append(label);
- dialogContainer.append(input);
- dialogContainer.append(submitButton);
- dialogContainer.dialog({title: "WebMapService hinzufügen"});
->>>>>>> .r9534
function base64_encode(data) {
// Encodes string using MIME base64 algorithm
Modified: trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
--- trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js 2016-07-11 09:12:29 UTC (rev 9535)
+++ trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js 2016-07-11 09:15:25 UTC (rev 9536)
@@ -102,7 +102,6 @@
return url;
var mod_addWms_general = function (js, param) {
-<<<<<<< .mine
var ind = getMapObjIndexByName('mapframe1');
var map = mb_mapObj[ind];
var success = false;
@@ -169,74 +168,6 @@
mb_execloadWmsSubFunctions({
wms: map.wms.length > 0 ? map.wms[map.wms.length - 1] : null
- var ind = getMapObjIndexByName('mapframe1');
- var map = mb_mapObj[ind];
- var success = false;
- if (js) {
- var oldWmsCount = wms.length;
- eval(js);
- if (errorcall) {
- var errorcall = errorcall.split("|");
- var dialogContainer = $("<form/>");
- if (errorcall[0] == "null") {
- errorcall[0] = "Fehler";
- var input = $("<input type='text' value='" + errorcall[1] + "' name='test'/>");
- var label = "<div>" + errorcall[0] + "</div>";
- submitButton.click(function (event) {
- var urlError = input.val();
- if (validateUrl(urlError)) {
- } else {
- dialogContainer.dialog({title: "WebMapService konnte nicht geladen werden"});
- var newWmsCount = wms.length;
- if (newWmsCount > oldWmsCount) {
- success = true;
- mb_mapObjaddWMS('mapframe1');
- var lastwms = map.wms[map.wms.length - 1];
- if (param && param.options && typeof param.options.zoomToExtent === "number" && param.options.zoomToExtent === 1) {
- // zoom to bbox
- var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
- for (var i = 0; i < lastwms.gui_epsg.length; i++) {
- if (map.epsg == lastwms.gui_epsg[i]) {
- bbox_minx = parseFloat(lastwms.gui_minx[i]);
- bbox_miny = parseFloat(lastwms.gui_miny[i]);
- bbox_maxx = parseFloat(lastwms.gui_maxx[i]);
- bbox_maxy = parseFloat(lastwms.gui_maxy[i]);
- if (bbox_minx === null || bbox_miny === null || bbox_maxx === null || bbox_maxy === null) {
- continue;
- map.calculateExtent(new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy));
- map.setMapRequest();
- break;
- if (typeof param === "object"
- && typeof param.callback === "function"
- && typeof param.options === "object"
- param.options.success = success;
- param.callback(param.options);
- mb_execloadWmsSubFunctions({
- wms: map.wms.length > 0 ? map.wms[map.wms.length - 1] : null
->>>>>>> .r9534
function mod_addWMSById_ajax(gui_id, wms_id, param) {
var options = {
More information about the Mapbender_commits
