[Mapbender-commits] r9624 - trunk/mapbender/resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Tue Nov 8 05:46:46 PST 2016
Author: armin11
Date: 2016-11-08 05:46:46 -0800 (Tue, 08 Nov 2016)
New Revision: 9624
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Bugfix for missing blank in translation file
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2016-11-08 13:44:50 UTC (rev 9623)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2016-11-08 13:46:46 UTC (rev 9624)
@@ -4164,6 +4164,6 @@
msgid "Bequeath contact info from service to coupled dataset metadata (Registry)"
msgstr "Vererbe Metadatenkontaktinformationen des Dienstes auf alle gekoppelten Datensatz-Metadaten (Registry)"
-msgid "Bequeath contact information from this service to all coupled dataset metadata. This function activates the dataset metadata proxy and the url of the original metadata will be exchanged with a geoportal proxy url. Check this to have the contact information of service and dataset in sync. It will use the contact information of the geoportal organization role system instead of the contact information which originates from the dataset metadata. This maybe usefull for a better exchange of geo-metadata with open data catalogues/portals. <b>Important:</b> The service have to be updated after changing this flag!"
+msgid "Bequeath contact information from this service to all coupled dataset metadata. This function activates the dataset metadata proxy and the url of the original metadata will be exchanged with a geoportal proxy url. Check this to have the contact information of service and dataset in sync. It will use the contact information of the geoportal organization role system instead of the contact information which originates from the dataset metadata. This maybe usefull for a better exchange of geo-metadata with open data catalogues/portals. <b>Important:</b> The service have to be updated after changing this flag!"
msgstr "Vererbung der Metadatenkontaktinformationen auf die gekoppelten Datensatz-Metadaten. Diese Funktion aktiviert den Metadatenproxy und die URL des originären Metadatensatzes wird durch eine URL auf die Registry ersetzt. Bei Auslieferung des Metadatensatzes erfolgt der Austausch der Informationen zum Metadatenkontakt `on the fly`. Mit dieser Option können diese Informationen zwischen den Diensten und den Datensätzen synchron gehalten werden und ein Austausch von Metadaten mit externen Portalen/Katalogen (z.B. OpenData Portalen) wird stark vereinfacht. <b>Wichtig:</b> der Dienst muss nach Änderung dieser Einstellung aktualisiert werden!"
More information about the Mapbender_commits
