[Mapbender-commits] r9625 - in trunk/mapbender: conf http/classes
svn_mapbender at osgeo.org
Wed Nov 9 05:11:27 PST 2016
Author: armin11
Date: 2016-11-09 05:11:27 -0800 (Wed, 09 Nov 2016)
New Revision: 9625
trunk/mapbender/conf/isoMetadata.conf
trunk/mapbender/http/classes/class_iso19139.php
Small fix for inheritance of source notes from service to dataset metadata and more robust reading of uselimitations field for showing html version of inspire iso metadata.
Modified: trunk/mapbender/conf/isoMetadata.conf
--- trunk/mapbender/conf/isoMetadata.conf 2016-11-08 13:46:46 UTC (rev 9624)
+++ trunk/mapbender/conf/isoMetadata.conf 2016-11-09 13:11:27 UTC (rev 9625)
@@ -293,7 +293,7 @@
//B 8. Constraints related to access and use
//B 8.1. Conditions applying to access and use (23)
array( ibus => "t01_object.obj_id",
- iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_Constraints/gmd:useLimitation/gco:CharacterString",
+ iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/*/gmd:useLimitation/gco:CharacterString",
iso19139explode => "false" ,
inspire => "conditions applying to access and use",
inspiremandatory => "true",
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2016-11-08 13:46:46 UTC (rev 9624)
+++ trunk/mapbender/http/classes/class_iso19139.php 2016-11-09 13:11:27 UTC (rev 9625)
@@ -1463,7 +1463,7 @@
$sqlUpdateSourceNote = "UPDATE mb_metadata SET md_license_source_note = $1 WHERE metadata_id = $2";
$t = array('s', 'i');
$v = array($service_source_note, $metadataId);
- $res = db_prep_query($sqlUpdateSourceNote);
+ $res = db_prep_query($sqlUpdateSourceNote,$v,$t);
//$e = new mb_exception("Metadata with id ".$metadataId." inherits licence information from ".$resourceType." with resourceId ".$resourceId);
catch (Exception $e) {
More information about the Mapbender_commits
