[Mapbender-commits] r9578 - trunk/mapbender/http/html
svn_mapbender at osgeo.org
Wed Sep 7 05:42:40 PDT 2016
Author: armin11
Date: 2016-09-07 05:42:40 -0700 (Wed, 07 Sep 2016)
New Revision: 9578
trunk/mapbender/http/html/mod_treefolderPlain.php
Further functions to allow support of wms time dimension
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php 2016-09-07 12:42:19 UTC (rev 9577)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php 2016-09-07 12:42:40 UTC (rev 9578)
@@ -713,12 +713,10 @@
else{
setTimeout('setNodeImage("'+path+'", "closed_folder.png");', 100);
if(reset_lock){
lock_update=false;
handleSelectedWMS(path, true);
function handleSelectedWMS(path){
@@ -786,7 +784,49 @@
+function setDimensionUserValue(j,k,l,dimensionIndex,userValue) {
+ if(!j && !k&& !l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my = mb_mapObj[j].wms[k].objLayer[l];
+ var myWms = mb_mapObj[j].wms[k];
+ //delete all userValues from other layers of this wms
+ for (var k=0;k< myWms.objLayer.length;k++) {
+ for (var i=0;i< myWms.objLayer[k].layer_dimension.length;i++) {
+ myWms.objLayer[k].layer_dimension[i].userValue = "";
+ my.layer_dimension[dimensionIndex].userValue = userValue;
+ //openfolder = true;
+ treeState = getState();
+ reloadTree();
+//function for buggy servers which do not support real iso8601 patterns for UTC :-(
+function makeDateTimeBetter(dateTimeIso) {
+ return dateTimeIso.replace('+00:00','Z');
+function snapToDiscreteValue(userValue,extent) {
+ //call it via sync ajax call :-(
+ transformUrl = '../php/mod_transformTimeDimension.php?operation=snapToGrid&extent='+encodeURIComponent(extent)+'&userValue='+encodeURIComponent(userValue);
+ var response = $.ajax({
+ url: transformUrl,
+ type: "GET",
+ async: false,
+ success: function (data) {
+ return data;
+ error: function() {
+ alert("An error occured!");
+ }).responseText;
+ var jsonValue = JSON.parse(response);
+ return jsonValue.data[0].value;
function openDimensionSelectHtml(j,k,l,dimensionIndex) {
if(!j && !k&& !l){
j=selectedMap;
@@ -796,19 +836,18 @@
//extract/calculate discrete values for time!
- //alert(JSON.stringify(mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex]));
- //var userValue = encodeURI(mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].userValue); //not already defined in mapobj!!
- var extent = encodeURI(mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent);
- var dimdefault = encodeURI(mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].default);
+ var userValue = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].userValue; //not already defined in mapobj!!
+ var extent = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent;
+ var dimdefault = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].default;
var dialogHtml = "<div id='timeline'></div>";
- $("<div id='selectDimensionDialog' title='<?php echo _mb('Select layer dimension');?>'><?php echo _mb('Please select an additional dimension value');?>: </div>").dialog(
+ $("<div id='selectDimensionDialog' title='<?php echo _mb('Select layer dimension');?>'><?php echo _mb('Please select a value for TIME. One single element can be dragged on timeline after selection. Scale may be altered by scrollinng.');?>: </div>").dialog(
bgiframe: true,
autoOpen: true,
modal: false,
+ width: 400,
closeOnEscape: false,
- //open: function(event, ui) { $(".ui-dialog-titlebar-close").hide()}, //hide closing x - but only for element with special id!!!
+ open: function(event, ui) { $( "div[aria-labelledby='ui-dialog-title-selectDimensionDialog']" ).children().children(".ui-dialog-titlebar-close").hide()}, //hide closing x - but only for element with special id!!!
buttons: {
"<?php echo _mb('Close');?>": function(){
$('selectDimensionDialog').remove();
@@ -820,9 +859,14 @@
$(dialogHtml).appendTo("#selectDimensionDialog");
//fill timeline into div
+ if (userValue !== undefined && userValue !== false && userValue !== "" && userValue !== "undefined") {
+ userValue = makeDateTimeBetter(userValue);
+ transformUrl = '../php/mod_transformTimeDimension.php?extent='+encodeURIComponent(extent)+'&userValue='+encodeURIComponent(userValue)+'&default='+encodeURIComponent(dimdefault);
+ } else {
+ transformUrl = '../php/mod_transformTimeDimension.php?extent='+encodeURIComponent(extent)+'&default='+encodeURIComponent(dimdefault);
$.ajax({
- //url: '../php/mod_transformTimeDimension.php?extent='+extent+'&userValue='+userValue+'&default='+dimdefault,
- url: '../php/mod_transformTimeDimension.php?extent='+extent+'&default='+dimdefault,
// hide the "loading..." message
//document.getElementById('loading').style.display = 'none';
@@ -834,19 +878,42 @@
var items = new vis.DataSet(data.data);
// Configuration for the Timeline
- //var options = {};
var options = data.options;
- options.onMove = function (item,callback) {item.content = item.start.toISOString(); myWms.gui_wms_dimension_time = item.start.toISOString()+'Z'; Mapbender.modules[mod_treeGDE_map].setMapRequest();; callback(item);};
+ //check if onclick or onmove should be enabled
+ if (data.options.editable.updateTime !== 'undefined' && data.options.editable.updateTime == true) {
+ options.onMove = function (item,callback) {
+ //calculate new value for item start based on snapping to period from extent
+ item.start = new Date(snapToDiscreteValue(item.start.toISOString(),extent));
+ item.content = item.start.toISOString();
+ myWms.gui_wms_dimension_time = makeDateTimeBetter(item.start.toISOString());
+ setDimensionUserValue(j,k,l,dimensionIndex,myWms.gui_wms_dimension_time);
+ Mapbender.modules[mod_treeGDE_map].setMapRequest();
+ callback(item);
+ } else {
+ options.editable = false;
// Create a Timeline
var timeline = new vis.Timeline(container, items, options);
+ //if (data.options.editable.updateTime == 'undefined' || data.options.editable.updateTime == false) {
+ timeline.on('select', function (properties) {
+ if (properties.event.type == "tap") {
+ myWms.gui_wms_dimension_time = makeDateTimeBetter(timeline.itemsData._data[timeline.getSelection()].content);
error: function (err) {
- console.log('Error', err);
+ //console.log('Error', err);
if (err.status === 0) {
- alert('Failed to load data/basic.json.\nPlease run this example on a server.');
+ alert('Failed to load json for configuration of timeline from server.\nPlease contact your portal administrator!');
else {
- alert('Failed to load data/basic.json.');
+ alert('Failed to load json from server.');
@@ -968,18 +1035,26 @@
case "time":
timeDimensionAvailable = true;
timeDimensionIndex = dimensionIndex;
+ timeUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
break;
case "elevation":
elevationDimensionAvailable = true;
elevationDimensionIndex = dimensionIndex;
+ elevationUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
break;
if (timeDimensionAvailable === true) {
text = JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[timeDimensionIndex]);
controls.push('<img onclick="openDimensionSelectHtml('+i+','+ii+','+iii+','+timeDimensionIndex+');" width="18" height="18" alt="'+msgObj.tooltipTimeDimension+'" title="'+msgObj.tooltipTimeDimension+'" src="'+imagedir+'/../gnome/preferences-system-time.png" />');
+ if (timeUserValue !== undefined && timeUserValue !== false && timeUserValue !== "" && timeUserValue !== "undefined") {
+ controls.push('<b>'+timeUserValue+'</b>');
+ //set gui_wms_dimension_time to value of layer - only one layer of a wms should have the userValue defined - if more have this, the last one will overwrite all earlier!
+ mb_mapObj[i].wms[ii].gui_wms_dimension_time = timeUserValue;
var groupedImageStyle ='';
if (temp.has_childs == true){
groupedImageStyle ='closed_folder.png';
More information about the Mapbender_commits
