[Mapbender-commits] r9579 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Sep 7 05:43:50 PDT 2016
Author: armin11
Date: 2016-09-07 05:43:50 -0700 (Wed, 07 Sep 2016)
New Revision: 9579
trunk/mapbender/http/classes/class_wms.php
Further functions to allow support of wms time dimension
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2016-09-07 12:42:40 UTC (rev 9578)
+++ trunk/mapbender/http/classes/class_wms.php 2016-09-07 12:43:50 UTC (rev 9579)
@@ -1553,8 +1553,8 @@
$newLayer->layer_style[$i]["legendurl"] = $currentLayer["style"][$i]["legendurl"];
$newLayer->layer_style[$i]["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
- //2016-08-31 add dimension
- $dimensionAttributes = array('name', 'units', 'unitSymbol', 'default', 'multipleValues', 'nearestValue', 'current', 'extent');
+ //2016-08-31 add dimension - user value come from wmc standard and client mapobject
+ $dimensionAttributes = array('name', 'units', 'unitSymbol', 'default', 'multipleValues', 'nearestValue', 'current', 'extent','userValue');
for ($i = 0; $i < count($currentLayer['dimension']); $i++) {
//$newLayer->layer_dimension[$i] = array();
foreach ($dimensionAttributes as $attributeName) {
@@ -1694,7 +1694,7 @@
$str .= "parent.";
//'name', 'units', 'unitSymbol', 'default', 'multipleValues', 'nearestValue', 'current', 'extent'
- $dimensionString = "wms_addLayerDimension('".$this->objLayer[$i]->layer_dimension[$j]->name."', '".$this->objLayer[$i]->layer_dimension[$j]->units."', '".$this->objLayer[$i]->layer_dimension[$j]->unitSymbol."', '".$this->objLayer[$i]->layer_dimension[$j]->default."', '".$this->objLayer[$i]->layer_dimension[$j]->multipleValues."', '".$this->objLayer[$i]->layer_dimension[$j]->nearestValue."', '".$this->objLayer[$i]->layer_dimension[$j]->current."', '".$this->objLayer[$i]->layer_dimension[$j]->extent."');";
+ $dimensionString = "wms_addLayerDimension('".$this->objLayer[$i]->layer_dimension[$j]->name."', '".$this->objLayer[$i]->layer_dimension[$j]->units."', '".$this->objLayer[$i]->layer_dimension[$j]->unitSymbol."', '".$this->objLayer[$i]->layer_dimension[$j]->default."', '".$this->objLayer[$i]->layer_dimension[$j]->multipleValues."', '".$this->objLayer[$i]->layer_dimension[$j]->nearestValue."', '".$this->objLayer[$i]->layer_dimension[$j]->current."', '".$this->objLayer[$i]->layer_dimension[$j]->extent."','".$this->objLayer[$i]->layer_dimension[$j]->userValue."');";
//$e = new mb_exception("class_wms.php: dimensionstring= ".$dimensionString);
$str .= $dimensionString;
@@ -1802,7 +1802,7 @@
echo "parent.";
- print("wms_addLayerDimension('".$this->objLayer[$i]->layer_dimension[$j]->name."', '".$this->objLayer[$i]->layer_dimension[$j]->units."', '".$this->objLayer[$i]->layer_dimension[$j]->unitSymbol."', '".$this->objLayer[$i]->layer_dimension[$j]->default."', '".$this->objLayer[$i]->layer_dimension[$j]->multipleValues."', '".$this->objLayer[$i]->layer_dimension[$j]->nearestValue."', '".$this->objLayer[$i]->layer_dimension[$j]->current."', '".$this->objLayer[$i]->layer_dimension[$j]->extent."');");
+ print("wms_addLayerDimension('".$this->objLayer[$i]->layer_dimension[$j]->name."', '".$this->objLayer[$i]->layer_dimension[$j]->units."', '".$this->objLayer[$i]->layer_dimension[$j]->unitSymbol."', '".$this->objLayer[$i]->layer_dimension[$j]->default."', '".$this->objLayer[$i]->layer_dimension[$j]->multipleValues."', '".$this->objLayer[$i]->layer_dimension[$j]->nearestValue."', '".$this->objLayer[$i]->layer_dimension[$j]->current."', '".$this->objLayer[$i]->layer_dimension[$j]->extent."','".$this->objLayer[$i]->layer_dimension[$j]->userValue."');");
@@ -3832,6 +3832,8 @@
foreach($attributeNames as $attribute) {
$this->objLayer[$layer_cnt]->layer_dimension[$count_layer_dimension]->{$attribute} = $row_dim[strtolower($attribute)];
+ //Initialize empty string for userValue from db cause this is only handled by wmc standard
+ $this->objLayer[$layer_cnt]->layer_dimension[$count_layer_dimension]->userValue = "";
$count_layer_dimension++;
More information about the Mapbender_commits
