[Mapbender-commits] r9636 - trunk/mapbender/http/geoportal/xslt
svn_mapbender at osgeo.org
Tue Jan 3 13:08:08 PST 2017
Author: armin11
Date: 2017-01-03 13:08:08 -0800 (Tue, 03 Jan 2017)
New Revision: 9636
trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
New version from JRC (Nov 2016)
Modified: trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
--- trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl 2017-01-03 13:48:32 UTC (rev 9635)
+++ trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl 2017-01-03 21:08:08 UTC (rev 9636)
@@ -1,2408 +1,2762 @@
-<?xml version="1.0" encoding="UTF-8"?>
- Copyright 2015-2016 EUROPEAN UNION
- Licensed under the EUPL, Version 1.1 or - as soon they will be approved by
- the European Commission - subsequent versions of the EUPL (the "Licence");
- You may not use this work except in compliance with the Licence.
- You may obtain a copy of the Licence at:
- http://ec.europa.eu/idabc/eupl
- Unless required by applicable law or agreed to in writing, software
- distributed under the Licence is distributed on an "AS IS" basis,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the Licence for the specific language governing permissions and
- limitations under the Licence.
- Authors: European Commission - Joint Research Centre
- Andrea Perego <andrea.perego at jrc.ec.europa.eu>
- Contributors: ISA GeoDCAT-AP Working Group
- <dcat_application_profile-geo at joinup.ec.europa.eu>
- This work was supported by the EU Interoperability Solutions for
- European Public Administrations Programme (http://ec.europa.eu/isa)
- through Action 1.17: Re-usable INSPIRE Reference Platform
- (http://ec.europa.eu/isa/actions/01-trusted-information-exchange/1-17action_en.htm).
- PURPOSE AND USAGE
- This XSLT is a proof of concept for the implementation of the specification
- concerning the geospatial profile of DCAT-AP (GeoDCAT-AP), available on
- Joinup, the collaboration platform of the EU ISA Programme:
- https://joinup.ec.europa.eu/node/139283/
- As such, this XSLT must be considered as unstable, and can be updated any
- time based on the revisions to the GeoDCAT-AP specifications and
- related work in the framework of INSPIRE and the EU ISA Programme.
-<xsl:transform xmlns:adms="http://www.w3.org/ns/adms#" xmlns:cnt="http://www.w3.org/2011/content#" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dcat="http://www.w3.org/ns/dcat#" xmlns:dct="http://purl.org/dc/terms/" xmlns:dctype="http://purl.org/dc/dcmitype/" xmlns:earl="http://www.w3.org/ns/earl#" xmlns:foaf="http://xmlns.com/foaf/0.1/" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="http://www.opengis.net/gml" xmlns:gmx="http://www.isotc211.org/2005/gmx" xmlns:gsp="http://www.opengis.net/ont/geosparql#" xmlns:i="http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:i-gp="http://inspire.ec.europa.eu/schemas/geoportal/1.0" xmlns:locn="http://www.w3.org/ns/locn#" xmlns:owl="http://www.w3.org/2002/07/owl#" xmlns:org="http://www.w3.org/ns/org#" xmlns:prov="http://www.w3.org/ns/prov#" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:rdfs="http://www.w3.org/2000/01/rdf-schema#" xmlns:schema="http://schema.org/" xmlns:
skos="http://www.w3.org/2004/02/skos/core#" xmlns:srv="http://www.isotc211.org/2005/srv" xmlns:vcard="http://www.w3.org/2006/vcard/ns#" xmlns:wdrs="http://www.w3.org/2007/05/powder-s#" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" exclude-result-prefixes="earl gco gmd gml gmx i i-gp srv xlink xsi xsl wdrs" version="1.0">
- <xsl:output method="xml" indent="yes" encoding="utf-8" cdata-section-elements="locn:geometry"/>
- Global variables
-<!-- Variables $core and $extended. -->
- These variables are meant to be placeholders for the IDs used for the core and extended profiles of GeoDCAT-AP.
- <xsl:variable name="core">core</xsl:variable>
- <xsl:variable name="extended">extended</xsl:variable>
- Mapping parameters
- This section includes mapping parameters by the XSLT processor used, or, possibly, manually.
-<!-- Parameter $profile -->
- This parameter specifies the GeoDCAT-AP profile to be used:
- - value "core": the GeoDCAT-AP Core profile, which includes only the INSPIRE and ISO 19115 core metadata elements supported in DCAT-AP
- - value "extended": the GeoDCAT-AP Extended profile, which defines mappings for all the INSPIRE and ISO 19115 core metadata elements
- The current specifications for the core and extended GeoDCAT-AP profiles are available on the Joinup collaboration platform:
-<!-- Uncomment to use GeoDCAT-AP Core -->
- <xsl:param name="profile" select="$core"/>
-<!-- Uncomment to use GeoDCAT-AP Extended -->
- <xsl:param name="profile" select="$extended"/>
-<!-- Parameter $CoupledResourceLookUp -->
- This parameter specifies whether the coupled resource, referenced via @xlink:href, should be looked up to fetch the resource's unique resource identifier (i.e., code and code space). More precisely:
- - value "enabled": The coupled resource is looked up
- - value "disabled": The coupled resource is not looked up
- The default value is "enabled" for GeoDCAT-AP Extended, and "disabled" otherwise.
- CAVEAT: Using this feature may cause the transformation to hang, in case the URL in @xlink:href is broken, the request hangs indefinitely, or does not return the expected resource (e.g., and HTML page, instead of an XML-encoded ISO 19139 record). It is strongly recommended that this issue is dealt with by using appropriate configuration parameters and error handling (e.g., by specifying a timeout on HTTP calls and by setting the HTTP Accept header to "application/xml").
- <xsl:param name="CoupledResourceLookUp">
- <xsl:choose>
- <xsl:when test="$profile = $extended">
- <xsl:text>enabled</xsl:text>
- </xsl:when>
- <xsl:otherwise>
- <xsl:text>disabled</xsl:text>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- Other global parameters
-<!-- Variables to be used to convert strings into lower/uppercase by using the translate() function. -->
- <xsl:variable name="lowercase">abcdefghijklmnopqrstuvwxyz</xsl:variable>
- <xsl:variable name="uppercase">ABCDEFGHIJKLMNOPQRSTUVWXYZ</xsl:variable>
-<!-- URIs, URNs and names for spatial reference system registers. -->
- <xsl:param name="EpsgSrsBaseUri">http://www.opengis.net/def/crs/EPSG/0</xsl:param>
- <xsl:param name="EpsgSrsBaseUrn">urn:ogc:def:crs:EPSG</xsl:param>
- <xsl:param name="EpsgSrsName">EPSG Coordinate Reference Systems</xsl:param>
- <xsl:param name="OgcSrsBaseUri">http://www.opengis.net/def/crs/OGC</xsl:param>
- <xsl:param name="OgcSrsBaseUrn">urn:ogc:def:crs:OGC</xsl:param>
- <xsl:param name="OgcSrsName">OGC Coordinate Reference Systems</xsl:param>
-<!-- URI and URN for CRS84. -->
- <xsl:param name="Crs84Uri" select="concat($OgcSrsBaseUri,'/1.3/CRS84')"/>
- <xsl:param name="Crs84Urn" select="concat($OgcSrsBaseUrn,':1.3:CRS84')"/>
-<!-- URI and URN for ETRS89. -->
- <xsl:param name="Etrs89Uri" select="concat($EpsgSrsBaseUri,'/4258')"/>
- <xsl:param name="Etrs89Urn" select="concat($EpsgSrsBaseUrn,'::4258')"/>
-<!-- URI and URN of the spatial reference system (SRS) used in the bounding box.
- The default SRS is CRS84. If a different SRS is used, also parameter
- $SrsAxisOrder must be specified. -->
-<!-- The SRS URI is used in the WKT and GML encodings of the bounding box. -->
- <xsl:param name="SrsUri" select="$Crs84Uri"/>
-<!-- The SRS URN is used in the GeoJSON encoding of the bounding box. -->
- <xsl:param name="SrsUrn" select="$Crs84Urn"/>
-<!-- Axis order for the reference SRS:
- - "LonLat": longitude / latitude
- - "LatLon": latitude / longitude.
- The axis order must be specified only if the reference SRS is different from CRS84.
- If the reference SRS is CRS84, this parameter is ignored. -->
- <xsl:param name="SrsAxisOrder">LonLat</xsl:param>
-<!-- Namespaces -->
- <xsl:param name="xsd">http://www.w3.org/2001/XMLSchema#</xsl:param>
- <xsl:param name="dct">http://purl.org/dc/terms/</xsl:param>
- <xsl:param name="dctype">http://purl.org/dc/dcmitype/</xsl:param>
-<!-- Currently not used.
- <xsl:param name="timeUri">http://placetime.com/</xsl:param>
- <xsl:param name="timeInstantUri" select="concat($timeUri,'instant/gregorian/')"/>
- <xsl:param name="timeIntervalUri" select="concat($timeUri,'interval/gregorian/')"/>
- <xsl:param name="dcat">http://www.w3.org/ns/dcat#</xsl:param>
- <xsl:param name="gsp">http://www.opengis.net/ont/geosparql#</xsl:param>
- <xsl:param name="foaf">http://xmlns.com/foaf/0.1/</xsl:param>
- <xsl:param name="vcard">http://www.w3.org/2006/vcard/ns#</xsl:param>
-<!-- Old params used for the SRS
- <xsl:param name="ogcCrsBaseUri">http://www.opengis.net/def/EPSG/0/</xsl:param>
- <xsl:param name="ogcCrsBaseUrn">urn:ogc:def:EPSG::</xsl:param>
- <xsl:param name="inspire">http://inspire.ec.europa.eu/schemas/md/</xsl:param>
- <xsl:param name="kos">http://ec.europa.eu/open-data/kos/</xsl:param>
- <xsl:param name="kosil" select="concat($kos,'interoperability-level/')"/>
- <xsl:param name="kosdst" select="concat($kos,'dataset-type/')"/>
- <xsl:param name="kosdss" select="concat($kos,'dataset-status/Completed')"/>
- <xsl:param name="kosdoct" select="concat($kos,'documentation-type/')"/>
- <xsl:param name="koslic" select="concat($kos,'licence/EuropeanCommission')"/>
- <xsl:param name="op">http://publications.europa.eu/resource/authority/</xsl:param>
- <xsl:param name="opcountry" select="concat($op,'country/')"/>
- <xsl:param name="oplang" select="concat($op,'language/')"/>
- <xsl:param name="opcb" select="concat($op,'corporate-body/')"/>
- <xsl:param name="opfq" select="concat($op,'frequency/')"/>
- <xsl:param name="cldFrequency">http://purl.org/cld/freq/</xsl:param>
-<!-- This is used as the datatype for the GeoJSON-based encoding of the bounding box. -->
- <xsl:param name="geojsonMediaTypeUri">https://www.iana.org/assignments/media-types/application/vnd.geo+json</xsl:param>
-<!-- INSPIRE code list URIs -->
- <xsl:param name="INSPIRECodelistUri">http://inspire.ec.europa.eu/metadata-codelist/</xsl:param>
- <xsl:param name="SpatialDataServiceCategoryCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceCategory')"/>
- <xsl:param name="DegreeOfConformityCodelistUri" select="concat($INSPIRECodelistUri,'DegreeOfConformity')"/>
- <xsl:param name="ResourceTypeCodelistUri" select="concat($INSPIRECodelistUri,'ResourceType')"/>
- <xsl:param name="ResponsiblePartyRoleCodelistUri" select="concat($INSPIRECodelistUri,'ResponsiblePartyRole')"/>
- <xsl:param name="SpatialDataServiceTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceType')"/>
- <xsl:param name="TopicCategoryCodelistUri" select="concat($INSPIRECodelistUri,'TopicCategory')"/>
-<!-- INSPIRE code list URIs (not yet supported; the URI pattern is tentative) -->
- <xsl:param name="SpatialRepresentationTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialRepresentationTypeCode')"/>
- <xsl:param name="MaintenanceFrequencyCodelistUri" select="concat($INSPIRECodelistUri,'MaintenanceFrequencyCode')"/>
-<!-- INSPIRE glossary URI -->
- <xsl:param name="INSPIREGlossaryUri">http://inspire.ec.europa.eu/glossary/</xsl:param>
- Master template
- <xsl:template match="/">
- <rdf:RDF>
- <xsl:apply-templates select="gmd:MD_Metadata|//gmd:MD_Metadata"/>
- </rdf:RDF>
- </xsl:template>
- Metadata template
- <xsl:template match="gmd:MD_Metadata|//gmd:MD_Metadata">
- Parameters to create HTTP URIs for the resource and the corresponding metadata record
- These parameters must be customised depending on the strategy used to assign HTTP URIs.
- The default rule implies that HTTP URIs are specified for the metadata file identifier
- (metadata URI) and the resource identifier (resource URI).
- <xsl:param name="ResourceUri">
- <xsl:variable name="rURI" select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/*/gmd:code/gco:CharacterString"/>
- <xsl:if test="$rURI != '' and ( starts-with($rURI, 'http://') or starts-with($rURI, 'https://') )">
- <xsl:value-of select="$rURI"/>
- </xsl:if>
- </xsl:param>
- <xsl:param name="MetadataUri">
- <xsl:variable name="mURI" select="gmd:fileIdentifier/gco:CharacterString"/>
- <xsl:if test="$mURI != '' and ( starts-with($mURI, 'http://') or starts-with($mURI, 'https://') )">
- <xsl:value-of select="$mURI"/>
- </xsl:if>
- </xsl:param>
- Other parameters
-<!-- Metadata language: corresponding Alpha-2 codes -->
- <xsl:param name="ormlang">
- <xsl:choose>
- <xsl:when test="gmd:language/gmd:LanguageCode/@codeListValue != ''">
- <xsl:value-of select="translate(gmd:language/gmd:LanguageCode/@codeListValue,$uppercase,$lowercase)"/>
- </xsl:when>
- <xsl:when test="gmd:language/gmd:LanguageCode != ''">
- <xsl:value-of select="translate(gmd:language/gmd:LanguageCode,$uppercase,$lowercase)"/>
- </xsl:when>
- <xsl:when test="gmd:language/gco:CharacterString != ''">
- <xsl:value-of select="translate(gmd:language/gco:CharacterString,$uppercase,$lowercase)"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="MetadataLanguage">
- <xsl:choose>
- <xsl:when test="$ormlang = 'bul'">
- <xsl:text>bg</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'cze'">
- <xsl:text>cs</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'dan'">
- <xsl:text>da</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'ger'">
- <xsl:text>de</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'gre'">
- <xsl:text>el</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'eng'">
- <xsl:text>en</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'spa'">
- <xsl:text>es</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'est'">
- <xsl:text>et</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'fin'">
- <xsl:text>fi</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'fre'">
- <xsl:text>fr</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'gle'">
- <xsl:text>ga</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'hrv'">
- <xsl:text>hr</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'ita'">
- <xsl:text>it</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'lav'">
- <xsl:text>lv</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'lit'">
- <xsl:text>lt</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'hun'">
- <xsl:text>hu</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'mlt'">
- <xsl:text>mt</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'dut'">
- <xsl:text>nl</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'pol'">
- <xsl:text>pl</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'por'">
- <xsl:text>pt</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'rum'">
- <xsl:text>ru</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'slo'">
- <xsl:text>sk</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'slv'">
- <xsl:text>sl</xsl:text>
- </xsl:when>
- <xsl:when test="$ormlang = 'swe'">
- <xsl:text>sv</xsl:text>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="$ormlang"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
-<!-- Resource language: corresponding Alpha-2 codes -->
- <xsl:param name="orrlang">
- <xsl:choose>
- <xsl:when test="gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue != ''">
- <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue,$uppercase,$lowercase)"/>
- </xsl:when>
- <xsl:when test="gmd:identificationInfo/*/gmd:language/gmd:LanguageCode != ''">
- <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gmd:LanguageCode,$uppercase,$lowercase)"/>
- </xsl:when>
- <xsl:when test="gmd:identificationInfo/*/gmd:language/gco:CharacterString != ''">
- <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gco:CharacterString,$uppercase,$lowercase)"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="ResourceLanguage">
- <xsl:choose>
- <xsl:when test="$orrlang = 'bul'">
- </xsl:when>
- <xsl:when test="$orrlang = 'cze'">
- </xsl:when>
- <xsl:when test="$orrlang = 'dan'">
- </xsl:when>
- <xsl:when test="$orrlang = 'ger'">
- </xsl:when>
- <xsl:when test="$orrlang = 'gre'">
- </xsl:when>
- <xsl:when test="$orrlang = 'eng'">
- </xsl:when>
- <xsl:when test="$orrlang = 'spa'">
- </xsl:when>
- <xsl:when test="$orrlang = 'est'">
- </xsl:when>
- <xsl:when test="$orrlang = 'fin'">
- </xsl:when>
- <xsl:when test="$orrlang = 'fre'">
- </xsl:when>
- <xsl:when test="$orrlang = 'gle'">
- </xsl:when>
- <xsl:when test="$orrlang = 'hrv'">
- </xsl:when>
- <xsl:when test="$orrlang = 'ita'">
- </xsl:when>
- <xsl:when test="$orrlang = 'lav'">
- </xsl:when>
- <xsl:when test="$orrlang = 'lit'">
- </xsl:when>
- <xsl:when test="$orrlang = 'hun'">
- </xsl:when>
- <xsl:when test="$orrlang = 'mlt'">
- </xsl:when>
- <xsl:when test="$orrlang = 'dut'">
- </xsl:when>
- <xsl:when test="$orrlang = 'pol'">
- </xsl:when>
- <xsl:when test="$orrlang = 'por'">
- </xsl:when>
- <xsl:when test="$orrlang = 'rum'">
- </xsl:when>
- <xsl:when test="$orrlang = 'slo'">
- </xsl:when>
- <xsl:when test="$orrlang = 'slv'">
- </xsl:when>
- <xsl:when test="$orrlang = 'swe'">
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="$orrlang"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="ResourceType">
- <xsl:value-of select="gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue"/>
- </xsl:param>
- <xsl:param name="ServiceType">
- <xsl:value-of select="gmd:identificationInfo/*/srv:serviceType/gco:LocalName"/>
- </xsl:param>
- <xsl:param name="ResourceTitle">
- <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:title/gco:CharacterString"/>
- </xsl:param>
- <xsl:param name="ResourceAbstract">
- <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:abstract/gco:CharacterString"/>
- </xsl:param>
- <xsl:param name="Lineage">
- <xsl:value-of select="gmd:dataQualityInfo/*/gmd:lineage/*/gmd:statement/gco:CharacterString"/>
- </xsl:param>
- <xsl:param name="MetadataDate">
- <xsl:choose>
- <xsl:when test="gmd:dateStamp/gco:Date">
- <xsl:value-of select="gmd:dateStamp/gco:Date"/>
- </xsl:when>
- <xsl:when test="gmd:dateStamp/gco:DateTime">
- <xsl:value-of select="substring(gmd:dateStamp/gco:DateTime/text(),1,10)"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="UniqueResourceIdentifier">
- <xsl:for-each select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:identifier/*">
- <xsl:choose>
- <xsl:when test="gmd:codeSpace/gco:CharacterString/text() != ''">
- <xsl:value-of select="concat(gmd:codeSpace/gco:CharacterString/text(),gmd:code/gco:CharacterString/text())"/>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="gmd:code/gco:CharacterString/text()"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="ConstraintsRelatedToAccessAndUse">
- <xsl:apply-templates select="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
- <xsl:with-param name="MetadataLanguage" select="$MetadataLanguage"/>
- </xsl:apply-templates>
- </xsl:param>
-<!-- Conformity, expressed by using an earl:Assertion (only for the extended profile) -->
- <xsl:param name="Conformity">
- <xsl:for-each select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
- <xsl:variable name="specinfo">
- <dct:title xml:lang="{$MetadataLanguage}">
- <xsl:value-of select="gmd:title/gco:CharacterString"/>
- </dct:title>
- <xsl:apply-templates select="gmd:date/gmd:CI_Date"/>
- </xsl:variable>
- <xsl:variable name="degree">
- <xsl:choose>
- <xsl:when test="../../gmd:pass/gco:Boolean = 'true'">
- <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/conformant')"/>
- </xsl:when>
- <xsl:when test="../../gmd:pass/gco:Boolean = 'false'">
- <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notConformant')"/>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notEvaluated')"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <xsl:variable name="explanation">
- <xsl:value-of select="../../gmd:explanation/gco:CharacterString"/>
- </xsl:variable>
- <earl:Assertion>
- <xsl:if test="$ResourceUri != ''">
- <earl:subject rdf:resource="{$ResourceUri}"/>
- </xsl:if>
- <xsl:choose>
- <xsl:when test="../@xlink:href and ../@xlink:href != ''">
- <earl:test>
- <rdf:Description rdf:about="{../@xlink:href}">
- <xsl:copy-of select="$specinfo"/>
- </rdf:Description>
- </earl:test>
- </xsl:when>
- <xsl:otherwise>
- <earl:test rdf:parseType="Resource">
- </earl:test>
- </xsl:otherwise>
- </xsl:choose>
- <earl:result>
- <earl:TestResult>
- <earl:outcome rdf:resource="{$degree}"/>
- <xsl:if test="$explanation and $explanation != ''">
- <earl:info xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></earl:info>
- </xsl:if>
- </earl:TestResult>
- </earl:result>
- </earl:Assertion>
- </xsl:for-each>
- </xsl:param>
-<!-- Conformity, expressed by using a prov:Activity (only for the extended profile) -->
- </dct:title>
- </xsl:variable>
- <xsl:choose>
- </xsl:when>
- </xsl:when>
- <xsl:otherwise>
- <xsl:when test="../../gmd:pass/gco:Boolean = ''">
- </xsl:when>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- </xsl:variable>
- <xsl:variable name="Activity">
- <prov:Activity>
- <prov:used rdf:resource="{$ResourceUri}"/>
- </xsl:if>
- <prov:qualifiedAssociation rdf:parseType="Resource">
- <prov:hadPlan rdf:parseType="Resource">
- <xsl:choose>
- <prov:wasDerivedFrom rdf:resource="{../@xlink:href}"/>
- <prov:wasDerivedFrom>
- </prov:wasDerivedFrom>
- </xsl:when>
- <xsl:otherwise>
- <prov:wasDerivedFrom rdf:parseType="Resource">
- </xsl:otherwise>
- </xsl:choose>
- </prov:hadPlan>
- </prov:qualifiedAssociation>
- <prov:generated rdf:parseType="Resource">
- <dct:type rdf:resource="{$degree}"/>
- <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></dct:description>
- </xsl:if>
- </prov:generated>
- </prov:Activity>
- </xsl:variable>
- <xsl:choose>
- <xsl:when test="$ResourceUri != ''">
- <xsl:copy-of select="$Activity"/>
- </xsl:when>
- <xsl:otherwise>
- <prov:wasUsedBy>
- </prov:wasUsedBy>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:for-each>
- </xsl:param>
-<!-- Metadata character encoding (only for the extended profile) -->
- <xsl:param name="MetadataCharacterEncoding">
- <xsl:apply-templates select="gmd:characterSet/gmd:MD_CharacterSetCode"/>
- </xsl:param>
- <xsl:param name="ResourceCharacterEncoding">
- <xsl:for-each select="gmd:identificationInfo/gmd:MD_DataIdentification">
- </xsl:for-each>
- </xsl:param>
-<!-- Metadata description (metadata on metadata) -->
- <xsl:param name="MetadataDescription">
-<!-- Metadata language -->
- <xsl:if test="$ormlang != ''">
- <dct:language rdf:resource="{concat($oplang,translate($ormlang,$lowercase,$uppercase))}"/>
- </xsl:if>
-<!-- Metadata date -->
- <xsl:if test="$MetadataDate != ''">
- <dct:modified rdf:datatype="{$xsd}date">
- <xsl:value-of select="$MetadataDate"/>
- </dct:modified>
- </xsl:if>
-<!-- Metadata point of contact: only for the extended profile -->
- <xsl:if test="$profile = $extended">
- <xsl:for-each select="gmd:contact">
- <xsl:apply-templates select="gmd:CI_ResponsibleParty">
- <xsl:with-param name="ResourceType" select="$ResourceType"/>
- </xsl:for-each>
-<!-- Old version
- <xsl:apply-templates select="gmd:contact/gmd:CI_ResponsibleParty">
- </xsl:if>
-<!-- Metadata file identifier (tentative): only for the extended profile -->
- <xsl:for-each select="gmd:fileIdentifier/gco:CharacterString">
- <dct:identifier rdf:datatype="{$xsd}string"><xsl:value-of select="."/></dct:identifier>
- </xsl:for-each>
- </xsl:if>
-<!-- Metadata standard (tentative): only for the extended profile -->
- <xsl:variable name="MetadataStandardURI" select="gmd:metadataStandardName/gmx:Anchor/@xlink:href"/>
- <xsl:variable name="MetadataStandardName" select="gmd:metadataStandardName/*[self::gco:CharacterString|self::gmx:Anchor]"/>
- <xsl:variable name="MetadataStandardVersion" select="gmd:metadataStandardVersion/gco:CharacterString"/>
- <xsl:if test="$MetadataCharacterEncoding != '' or $MetadataStandardURI != '' or $MetadataStandardName != ''">
- <dct:source rdf:parseType="Resource">
- <xsl:if test="$MetadataCharacterEncoding != ''">
-<!-- Metadata character encoding (tentative): only for the extended profile -->
- <xsl:copy-of select="$MetadataCharacterEncoding"/>
- </xsl:if>
- <xsl:choose>
- <xsl:when test="$MetadataStandardURI != ''">
-<!-- Metadata standard, denoted by a URI -->
- <dct:conformsTo rdf:resource="{$MetadataStandardURI}"/>
- </xsl:when>
- <xsl:when test="$MetadataStandardName != ''">
- <dct:conformsTo rdf:parseType="Resource">
-<!-- Metadata standard name -->
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardName"/></dct:title>
- <xsl:if test="$MetadataStandardVersion != ''">
-<!-- Metadata standard version -->
- <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardVersion"/></owl:versionInfo>
- </xsl:if>
- </dct:conformsTo>
- </xsl:when>
- </xsl:choose>
- </dct:source>
- </xsl:if>
-<!-- Old version:
- <xsl:for-each select="gmd:metadataStandardName/gco:CharacterString">
- <xsl:if test="text() != '' or ../../gmd:metadataStandardVersion/gco:CharacterString/text() != ''">
- </xsl:if>
- <xsl:if test="text() != ''">
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:title>
- </xsl:if>
- <xsl:if test="../../gmd:metadataStandardName/gco:CharacterString/text() != ''">
- <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="../../gmd:metadataStandardVersion/gco:CharacterString"/></owl:versionInfo>
- </xsl:if>
- </dct:conformsTo>
- </dct:source>
- </xsl:if>
- </xsl:for-each>
- </xsl:if>
- </xsl:param>
-<!-- Resource description (resource metadata) -->
- <xsl:param name="ResourceDescription">
- <xsl:choose>
- <xsl:when test="$ResourceType = 'dataset'">
- <rdf:type rdf:resource="{$dcat}Dataset"/>
- </xsl:when>
- <xsl:when test="$ResourceType = 'series'">
- </xsl:when>
- <xsl:when test="$ResourceType = 'service'">
- <rdf:type rdf:resource="{$dctype}Service"/>
- </xsl:if>
- <xsl:if test="$ServiceType = 'discovery'">
- <rdf:type rdf:resource="{$dcat}Catalog"/>
- </xsl:if>
- </xsl:when>
- </xsl:choose>
- <dct:type rdf:resource="{$ResourceTypeCodelistUri}/{$ResourceType}"/>
- </xsl:if>
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$ResourceTitle"/></dct:title>
- <xsl:value-of select="normalize-space($ResourceAbstract)"/>
- </dct:description>
-<!-- Maintenance information (tentative) -->
- <xsl:for-each select="gmd:identificationInfo/*/gmd:resourceMaintenance">
- <xsl:apply-templates select="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode"/>
- </xsl:for-each>
-<!-- Topic category -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:topicCategory">
- </xsl:if>
-<!-- Keyword -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
- <xsl:with-param name="ServiceType" select="$ServiceType"/>
-<!-- Identifier, 0..1 -->
- <xsl:apply-templates select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/*">
-<!-- Resource locators -->
- <xsl:apply-templates select="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
-<!-- Unique Resource Identifier -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*"/>
-<!-- Coupled resources -->
- <xsl:apply-templates select="gmd:identificationInfo[1]/*/srv:operatesOn">
-<!-- Resource Language -->
- <xsl:if test="$ResourceType = 'dataset' or $ResourceType = 'series'">
- <xsl:choose>
- <xsl:when test="$orrlang != ''">
- <dct:language rdf:resource="{concat($oplang,translate($orrlang,$lowercase,$uppercase))}"/>
- </xsl:when>
- <xsl:otherwise>
-<!-- To be decided (when the resource language is not specified, it defaults to the metadata language): -->
- </xsl:if>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:if>
-<!-- Spatial service type -->
- <xsl:if test="$ResourceType = 'service' and $profile = $extended">
-<!-- Replaced by param $ServiceType -->
- <xsl:apply-templates select="gmd:identificationInfo/*/srv:serviceType">
- <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{$ServiceType}"/>
- </xsl:if>
-<!-- Spatial extent -->
- <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox"/>
- <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
-<!-- Temporal extent -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent"/>
-<!-- Creation date, publication date, date of last revision -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation"/>
-<!-- Lineage -->
- <xsl:if test="$ResourceType != 'service' and $Lineage != ''">
- <dct:provenance>
- <dct:ProvenanceStatement>
- <rdfs:label xml:lang="{$MetadataLanguage}">
- <xsl:value-of select="normalize-space($Lineage)"/>
- </rdfs:label>
- </dct:ProvenanceStatement>
- </dct:provenance>
- </xsl:if>
-<!-- Coordinate and temporal reference systems (tentative) -->
- <xsl:apply-templates select="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
- </xsl:if>
-<!-- Spatial resolution -->
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution"/>
- </xsl:if>
-<!-- Conformity -->
- <xsl:apply-templates select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
- <xsl:with-param name="ResourceUri" select="$ResourceUri"/>
- <xsl:with-param name="Conformity" select="$Conformity"/>
- <xsl:choose>
- <xsl:when test="$ResourceType = 'service' and ($ServiceType = 'discovery' or $profile = $extended)">
- <xsl:copy-of select="$ConstraintsRelatedToAccessAndUse"/>
- </xsl:when>
-<!-- Distributions -->
- <xsl:when test="$ResourceType = 'dataset' or $ResourceType = 'series'">
-<!-- Spatial representation type -->
- <xsl:variable name="SpatialRepresentationType">
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode"/>
- </xsl:variable>
- <xsl:for-each select="gmd:distributionInfo/gmd:MD_Distribution">
-<!-- Encoding -->
- <xsl:variable name="Encoding">
- <xsl:apply-templates select="gmd:distributionFormat/gmd:MD_Format/gmd:name/*"/>
- </xsl:variable>
-<!-- Resource locators (access / download URLs) -->
- <xsl:for-each select="gmd:transferOptions/*/gmd:onLine/*">
- <xsl:variable name="function" select="gmd:function/gmd:CI_OnLineFunctionCode/@codeListValue"/>
- <xsl:variable name="TitleAndDescription">
- <xsl:for-each select="gmd:name/gco:CharacterString">
- </xsl:for-each>
- <xsl:for-each select="gmd:description/gco:CharacterString">
- <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:description>
- </xsl:for-each>
- </xsl:variable>
- <xsl:choose>
- <xsl:when test="$function = 'download' or $function = 'offlineAccess' or $function = 'order'">
- <dcat:distribution>
- <dcat:Distribution>
-<!-- Title and description -->
- <xsl:copy-of select="$TitleAndDescription"/>
-<!-- Access URL -->
- <xsl:for-each select="gmd:linkage/gmd:URL">
- <dcat:accessURL rdf:resource="{.}"/>
- </xsl:for-each>
-<!-- Constraints related to access and use -->
-<!-- Spatial representation type (tentative) -->
- <xsl:copy-of select="$SpatialRepresentationType"/>
-<!-- Encoding -->
- <xsl:copy-of select="$Encoding"/>
-<!-- Resource character encoding -->
- <xsl:copy-of select="$ResourceCharacterEncoding"/>
- </xsl:if>
- </dcat:Distribution>
- </dcat:distribution>
- </xsl:when>
- <xsl:when test="$function = 'information' or $function = 'search'">
-<!-- ?? Should foaf:page be detailed with title, description, etc.? -->
- <foaf:page>
- <foaf:Document rdf:about="{.}">
- </foaf:Document>
- </foaf:page>
- </xsl:for-each>
- </xsl:when>
-<!-- ?? Should dcat:landingPage be detailed with title, description, etc.? -->
- <xsl:otherwise>
- <dcat:landingPage>
- </foaf:Document>
- </dcat:landingPage>
- </xsl:for-each>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:for-each>
- </xsl:for-each>
- </xsl:when>
- </xsl:choose>
-<!-- Responsible organisation -->
- <xsl:for-each select="gmd:identificationInfo/*/gmd:pointOfContact">
- </xsl:for-each>
- <xsl:apply-templates select="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
- </xsl:param>
- <xsl:choose>
- <xsl:choose>
- <xsl:when test="$MetadataUri != ''">
- <rdf:Description rdf:about="{$MetadataUri}">
- <rdf:type rdf:resource="{$dcat}CatalogRecord"/>
- <foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
- <xsl:copy-of select="$MetadataDescription"/>
- </xsl:when>
- <xsl:otherwise>
- <xsl:if test="normalize-space($MetadataDescription)">
- <rdf:Description>
- </xsl:if>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:if>
- <rdf:Description rdf:about="{$ResourceUri}">
- <xsl:copy-of select="$ResourceDescription"/>
- </xsl:when>
- <xsl:otherwise>
- <rdf:Description>
- <foaf:isPrimaryTopicOf>
- <rdf:Description>
- </foaf:isPrimaryTopicOf>
- </xsl:if>
- </xsl:otherwise>
- </xsl:choose>
- <xsl:if test="$profile = $extended and $ResourceUri != '' and $Conformity != ''">
- <xsl:copy-of select="$Conformity"/>
- </xsl:if>
- </xsl:template>
- Templates for specific metadata elements
- <xsl:template name="UniqueResourceIdentifier" match="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*">
- <xsl:param name="ns">
- <xsl:value-of select="gmd:codeSpace/gco:CharacterString"/>
- </xsl:param>
- <xsl:param name="code">
- <xsl:value-of select="gmd:code/gco:CharacterString"/>
- </xsl:param>
- <xsl:param name="id">
- <xsl:choose>
- <xsl:when test="$ns != ''">
- <xsl:choose>
- <xsl:when test="substring($ns,string-length($ns),1) = '/'">
- <xsl:value-of select="concat($ns,$code)"/>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="concat($ns,'/',$code)"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="$code"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="idDatatypeURI">
- <xsl:choose>
- <xsl:when test="starts-with($id, 'http://') or starts-with($id, 'https://') or starts-with($id, 'urn:')">
- <xsl:value-of select="concat($xsd,'anyURI')"/>
- </xsl:when>
- <xsl:otherwise>
- <xsl:value-of select="concat($xsd,'string')"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- <dct:identifier rdf:datatype="{$idDatatypeURI}"><xsl:value-of select="$id"/></dct:identifier>
- </xsl:template>
-<!-- Responsible Organisation -->
- <xsl:template name="ResponsibleOrganisation" match="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
- <xsl:template name="ResponsibleOrganisation" match="gmd:CI_ResponsibleParty">
- <xsl:param name="MetadataLanguage"/>
- <xsl:param name="ResourceType"/>
- <xsl:param name="role">
-<!-- ISSUE The same problem we have for ResourceLocator function: the RDSI editor saves the relevant code as the text node of the relevant element, instead of using the correct attribute (@codeListValue) -->
- <xsl:value-of select="gmd:role/gmd:CI_RoleCode/@codeListValue"/>
- </xsl:param>
- <xsl:param name="ResponsiblePartyRole">
- <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/',$role)"/>
- </xsl:param>
- <xsl:param name="IndividualURI">
- <xsl:value-of select="normalize-space(gmd:individualName/*/@xlink:href)"/>
- </xsl:param>
- <xsl:param name="IndividualName">
- <xsl:value-of select="normalize-space(gmd:individualName/*)"/>
- </xsl:param>
- <xsl:param name="OrganisationURI">
- <xsl:value-of select="normalize-space(gmd:organisationName/*/@xlink:href)"/>
- </xsl:param>
- <xsl:param name="URI">
- <xsl:choose>
- <xsl:when test="$IndividualURI != ''">
- <xsl:value-of select="$IndividualURI"/>
- </xsl:when>
- <xsl:when test="$OrganisationURI != ''">
- <xsl:value-of select="$OrganisationURI"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="OrganisationName">
- <xsl:value-of select="normalize-space(gmd:organisationName/*)"/>
- </xsl:param>
- <xsl:param name="Email">
- <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/*">
- <foaf:mbox rdf:resource="mailto:{normalize-space(.)}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="Email-vCard">
- <vcard:hasEmail rdf:resource="mailto:{normalize-space(.)}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="URL">
- <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:onlineResource/gmd:CI_OnlineResource/gmd:linkage/gmd:URL">
- <foaf:workplaceHomepage rdf:resource="{normalize-space(.)}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="URL-vCard">
- <vcard:hasURL rdf:resource="{normalize-space(.)}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="Telephone">
- <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:phone/gmd:CI_Telephone/gmd:voice/*">
- <foaf:phone rdf:resource="tel:+{translate(translate(translate(translate(translate(normalize-space(.),' ',''),'(',''),')',''),'+',''),'.','')}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="Telephone-vCard">
- <vcard:hasTelephone rdf:resource="tel:+{translate(translate(translate(translate(translate(normalize-space(.),' ',''),'(',''),')',''),'+',''),'.','')}"/>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="Address">
- <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address">
- <xsl:variable name="deliveryPoint" select="normalize-space(gmd:deliveryPoint/*)"/>
- <xsl:variable name="city" select="normalize-space(gmd:city/*)"/>
- <xsl:variable name="administrativeArea" select="normalize-space(gmd:administrativeArea/*)"/>
- <xsl:variable name="postalCode" select="normalize-space(gmd:postalCode/*)"/>
- <xsl:variable name="country" select="normalize-space(gmd:country/*)"/>
- <locn:address>
- <locn:Address>
- <xsl:if test="$deliveryPoint != ''">
- <locn:thoroughfare><xsl:value-of select="$deliveryPoint"/></locn:thoroughfare>
- </xsl:if>
- <xsl:if test="$city != ''">
- <locn:postName><xsl:value-of select="$city"/></locn:postName>
- </xsl:if>
- <xsl:if test="$administrativeArea != ''">
- <locn:adminUnitL2><xsl:value-of select="$administrativeArea"/></locn:adminUnitL2>
- </xsl:if>
- <xsl:if test="$postalCode != ''">
- <locn:postCode><xsl:value-of select="$postalCode"/></locn:postCode>
- </xsl:if>
- <xsl:if test="$country != ''">
- <locn:adminUnitL1><xsl:value-of select="$country"/></locn:adminUnitL1>
- </xsl:if>
- </locn:Address>
- </locn:address>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="Address-vCard">
- <vcard:hasAddress>
- <vcard:Address>
- <vcard:street-address><xsl:value-of select="$deliveryPoint"/></vcard:street-address>
- </xsl:if>
- <vcard:locality><xsl:value-of select="$city"/></vcard:locality>
- </xsl:if>
- <vcard:region><xsl:value-of select="$administrativeArea"/></vcard:region>
- </xsl:if>
- <vcard:postal-code><xsl:value-of select="$postalCode"/></vcard:postal-code>
- </xsl:if>
- <vcard:country-name><xsl:value-of select="$country"/></vcard:country-name>
- </xsl:if>
- </vcard:Address>
- </vcard:hasAddress>
- </xsl:for-each>
- </xsl:param>
- <xsl:param name="ROInfo">
- <xsl:variable name="info">
- <xsl:choose>
- <xsl:when test="$IndividualName != ''">
- <rdf:type rdf:resource="{$foaf}Person"/>
- </xsl:when>
- <xsl:when test="$OrganisationName != ''">
- <rdf:type rdf:resource="{$foaf}Organization"/>
- </xsl:when>
- <xsl:otherwise>
- <rdf:type rdf:resource="{$foaf}Agent"/>
- </xsl:otherwise>
- </xsl:choose>
- <xsl:if test="$IndividualName != ''">
- <foaf:name xml:lang="{$MetadataLanguage}">
- <xsl:value-of select="$IndividualName"/>
- </foaf:name>
- <xsl:if test="$OrganisationName != ''">
- <org:memberOf>
- <xsl:choose>
- <foaf:Organization rdf:about="{$OrganisationURI}">
- <foaf:name xml:lang="{$MetadataLanguage}"><xsl:value-of select="$OrganisationName"/></foaf:name>
- </foaf:Organization>
- </xsl:when>
- <xsl:otherwise>
- <foaf:Organization>
- </xsl:otherwise>
- </xsl:choose>
- </org:memberOf>
- </xsl:if>
- </xsl:if>
- <xsl:if test="$IndividualName != '' and $OrganisationName != ''">
- <xsl:value-of select="$OrganisationName"/>
- </foaf:name>
- </xsl:if>
- <xsl:copy-of select="$Telephone"/>
- <xsl:copy-of select="$Email"/>
- <xsl:copy-of select="$URL"/>
- <xsl:copy-of select="$Address"/>
- <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString">
- <foaf:mbox rdf:resource="mailto:{.}"/>
- </xsl:for-each>
-<!-- ?? Should another property be used instead? E.g., foaf:homepage? -->
- <foaf:workplaceHomepage rdf:resource="{.}"/>
- </xsl:for-each>
- </xsl:variable>
- <xsl:choose>
- <rdf:Description rdf:resource="{$IndividualURI}">
- <xsl:copy-of select="$info"/>
- </xsl:when>
- <rdf:Description rdf:resource="{$OrganisationURI}">
- </xsl:when>
- <xsl:otherwise>
- <rdf:Description>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="ResponsibleParty">
- <xsl:choose>
- <rdf:type rdf:resource="{$vcard}Individual"/>
- </xsl:when>
- <rdf:type rdf:resource="{$vcard}Organization"/>
- </xsl:when>
- <xsl:otherwise>
- <rdf:type rdf:resource="{$vcard}Kind"/>
- </xsl:otherwise>
- </xsl:choose>
- <vcard:fn xml:lang="{$MetadataLanguage}">
- </vcard:fn>
- </xsl:if>
- <vcard:organization-name xml:lang="{$MetadataLanguage}">
- </vcard:organization-name>
- </xsl:if>
- <xsl:if test="$IndividualName = '' and $OrganisationName != ''">
- </vcard:fn>
- </xsl:if>
- <xsl:copy-of select="$Telephone-vCard"/>
- <xsl:copy-of select="$Email-vCard"/>
- <xsl:copy-of select="$URL-vCard"/>
- <xsl:copy-of select="$Address-vCard"/>
- <vcard:hasEmail rdf:resource="mailto:{.}"/>
- </xsl:for-each>
- <vcard:hasURL rdf:resource="{.}"/>
- </xsl:for-each>
- </xsl:variable>
- <xsl:choose>
- </xsl:when>
- </xsl:when>
- <xsl:otherwise>
- <rdf:Description>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:param>
- <xsl:choose>
- <xsl:when test="$role = 'resourceProvider'">
- <schema:provider>
- <xsl:copy-of select="$ROInfo"/>
- </schema:provider>
- </xsl:when>
- <xsl:when test="$role = 'custodian'">
- <rdarole:custodian>
- </rdarole:custodian>
- </xsl:when>
- <xsl:when test="$role = 'owner' and $profile = $extended">
- <dct:rightsHolder>
- </dct:rightsHolder>
- </xsl:when>
- <xsl:when test="$role = 'user'">
- <prov:wasUsedBy>
- <prov:Activity>
- <prov:wasAssociatedWith>
- </prov:wasAssociatedWith>
- </prov:Activity>
- </prov:wasUsedBy>
- </xsl:when>
- <xsl:when test="$role = 'distributor'">
- <rdarole:distributor>
- </rdarole:distributor>
- </xsl:when>
- <xsl:when test="$role = 'originator' and $profile = $extended">
- <dct:creator>
- </dct:creator>
- </xsl:when>
- <xsl:when test="$role = 'pointOfContact' and $ResourceType != 'service'">
- <dcat:contactPoint>
- <xsl:copy-of select="$ResponsibleParty"/>
- </dcat:contactPoint>
- </xsl:when>
- <xsl:when test="$role = 'principalInvestigator'">
- <dct:contributor>
- </dct:contributor>
- </xsl:when>
- <xsl:when test="$role = 'processor'">
- <prov:entityOfInfluence>
- <prov:Derivation>
- <prov:hadActivity>
- <prov:Activity>
- </prov:Activity>
- </prov:hadActivity>
- </prov:Derivation>
- </prov:entityOfInfluence>
- </xsl:when>
- <xsl:when test="$role = 'publisher'">
- <dct:publisher>
- </dct:publisher>
- </xsl:when>
- <xsl:when test="$role = 'author' and $profile = $extended">
- <dct:creator>
- </dct:creator>
- </xsl:when>
- </xsl:choose>
- <prov:qualifiedAttribution>
- <prov:Attribution>
- <prov:agent>
- </prov:agent>
- <dct:type rdf:resource="{$ResponsiblePartyRole}"/>
- </prov:Attribution>
- </prov:qualifiedAttribution>
- </xsl:if>
- </xsl:template>
-<!-- Metadata point of contact -->
- <xsl:template name="MetadataPointOfContact" match="gmd:contact/gmd:CI_ResponsibleParty">
- <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/','pointOfContact')"/>
- </xsl:param>
- <xsl:value-of select="gmd:organisationName/gco:CharacterString"/>
- </xsl:param>
- <vcard:Kind>
- </xsl:for-each>
- </vcard:Kind>
- </xsl:param>
- <prov:agent>
- </prov:agent>
- </xsl:if>
- </xsl:template>
-<!-- Resource locator -->
-<!-- Old version, applied to the resource (not to the resource distribution)
- <xsl:template name="ResourceLocator" match="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
- <xsl:choose>
- <dcat:landingPage rdf:resource="{gmd:URL}"/>
- </xsl:when>
- <foaf:homepage rdf:resource="{gmd:URL}"/>
- </xsl:when>
- </xsl:choose>
- </xsl:template>
- <xsl:template name="ResourceLocator" match="gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
- <xsl:choose>
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="../gmd:description/gco:CharacterString"/></dct:title>
- <dcat:accessURL rdf:resource="{gmd:URL}"/>
- </xsl:when>
- </xsl:when>
- </xsl:choose>
- </xsl:template>
-<!-- Coupled resource -->
- <xsl:template name="CoupledResource" match="gmd:identificationInfo[1]/*/srv:operatesOn">
- <xsl:param name="href" select="@xlink:href"/>
- <xsl:choose>
- <xsl:when test="$CoupledResourceLookUp = 'enabled' and $href != '' and (starts-with($href, 'http://') or starts-with($href, 'https://'))">
- <xsl:value-of select="document($href)//gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString"/>
- </xsl:when>
- <xsl:when test="*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString != ''">
- <xsl:value-of select="*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString"/>
- </xsl:when>
- <xsl:when test="@uuidref != ''">
- <xsl:value-of select="@uuidref"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="codespace">
- <xsl:choose>
- <xsl:value-of select="document($href)//gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString"/>
- </xsl:when>
- <xsl:when test="*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString != ''">
- <xsl:value-of select="*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="resID" select="concat($codespace, $code)"/>
- <xsl:param name="uriref" select="@uriref"/>
- <xsl:choose>
-<!-- The use of @uriref is still under discussion by the INSPIRE MIG. -->
- <xsl:when test="$uriref != ''">
- <dct:hasPart rdf:resource="{@uriref}"/>
- </xsl:when>
- <xsl:when test="$code != ''">
- <xsl:choose>
- <xsl:when test="starts-with($code, 'http://') or starts-with($code, 'https://')">
- <dct:hasPart rdf:resource="{$code}"/>
- </xsl:when>
- <xsl:otherwise>
- <dct:hasPart rdf:parseType="Resource">
- <xsl:choose>
- <xsl:when test="starts-with($resID, 'http://') or starts-with($resID, 'https://')">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$resID"/></dct:identifier>
- </xsl:when>
- <xsl:otherwise>
- <dct:identifier rdf:datatype="{$xsd}string"><xsl:value-of select="$resID"/></dct:identifier>
- </xsl:otherwise>
- </xsl:choose>
- <xsl:if test="$href != '' and $href != '' and (starts-with($href, 'http://') or starts-with($href, 'https://'))">
- <dcat:CatalogRecord rdf:about="{$href}"/>
- </xsl:if>
- </dct:hasPart>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- </xsl:choose>
- </xsl:template>
-<!-- Spatial data service type -->
- <xsl:template match="gmd:identificationInfo/*/srv:serviceType">
- <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{gco:LocalName}"/>
- </xsl:template>
- <xsl:template name="Conformity" match="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
- <xsl:param name="ResourceUri"/>
- <xsl:param name="Conformity"/>
- </dct:title>
- </xsl:variable>
- <xsl:choose>
- </xsl:when>
- </xsl:when>
- <xsl:otherwise>
- </xsl:when>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <xsl:if test="../../gmd:pass/gco:Boolean = 'true'">
- <xsl:choose>
- <dct:conformsTo rdf:resource="{../@xlink:href}"/>
- <dct:conformsTo>
- </dct:conformsTo>
- </xsl:when>
- <xsl:otherwise>
- </dct:conformsTo>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:if>
- <xsl:if test="$Conformity != '' and $ResourceUri = ''">
- </xsl:if>
- <xsl:choose>
- <wdrs:describedby>
- <earl:Assertion>
- <earl:test>
- </earl:test>
- <earl:result>
- <earl:TestResult>
- </earl:result>
- </earl:Assertion>
- </wdrs:describedby>
- </xsl:when>
- <xsl:otherwise>
- <earl:Assertion>
- </earl:test>
- <earl:result>
- <earl:TestResult>
- </earl:result>
- </earl:Assertion>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:if>
- </xsl:template>
-<!-- Geographic extent -->
- <xsl:template name="GeographicExtent" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
- <xsl:otherwise>
- <dct:spatial>
- <dct:Location>
- <xsl:for-each select="gmd:description">
- <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></rdfs:label>
- </xsl:for-each>
- <xsl:apply-templates select="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
- <xsl:apply-templates select="gmd:EX_GeographicBoundingBox"/>
- </dct:Location>
- </dct:spatial>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:template>
-<!-- Geographic identifier -->
- <xsl:template name="GeographicIdentifier" match="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
- <xsl:param name="GeoCode" select="gmd:code/*[self::gco:CharacterString|self::gmx:Anchor/@xlink:href]"/>
- <xsl:param name="GeoURI" select="gmd:code/gmx:Anchor/@xlink:href"/>
- <xsl:param name="GeoCode">
- <xsl:choose>
- <xsl:when test="gmd:code/gco:CharacterString">
- </xsl:when>
- <xsl:when test="gmd:code/gmx:Anchor">
- <xsl:value-of select="gmd:code/gmx:Anchor/@xlink:href"/>
- </xsl:when>
- </xsl:choose>
- </xsl:param>
- <xsl:param name="GeoURI">
- <xsl:if test="starts-with($GeoCode,'http://') or starts-with($GeoCode,'https://')">
- <xsl:value-of select="$GeoCode"/>
- </xsl:if>
- </xsl:param>
- <xsl:param name="GeoURN">
- <xsl:if test="starts-with($GeoCode,'urn:')">
- </xsl:if>
- </xsl:param>
- <xsl:choose>
- <xsl:when test="$GeoURI != ''">
- <xsl:choose>
- <xsl:when test="gmd:EX_GeographicBoundingBox">
- <dct:spatial>
- <dct:Location rdf:about="{$GeoURI}">
- <xsl:if test="$GeoCode != ''">
- <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="$GeoCode"/></rdfs:label>
- </xsl:if>
- </dct:Location>
- </dct:spatial>
- </xsl:when>
- <xsl:otherwise>
- <dct:spatial rdf:resource="{$GeoURI}"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- <xsl:when test="$GeoCode != ''">
- <dct:spatial rdf:parseType="Resource">
- <rdfs:seeAlso rdf:parseType="Resource">
- <xsl:choose>
- <xsl:when test="$GeoURN != ''">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$GeoURN"/></dct:identifier>
- </xsl:when>
- <xsl:otherwise>
- <skos:prefLabel xml:lang="{$MetadataLanguage}">
- </skos:prefLabel>
- </xsl:otherwise>
- </xsl:choose>
- <xsl:for-each select="gmd:authority/gmd:CI_Citation">
- <skos:inScheme>
- <skos:ConceptScheme>
- </dct:title>
- </skos:ConceptScheme>
- </skos:inScheme>
- </xsl:for-each>
- </rdfs:seeAlso>
- </dct:spatial>
- </xsl:when>
- </xsl:choose>
- </xsl:template>
-<!-- Geographic bounding box -->
- <xsl:template name="GeographicBoundingBox" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox">
- <xsl:template name="GeographicBoundingBox" match="gmd:EX_GeographicBoundingBox">
- <xsl:param name="north" select="gmd:northBoundLatitude/gco:Decimal"/>
- <xsl:param name="east" select="gmd:eastBoundLongitude/gco:Decimal"/>
- <xsl:param name="south" select="gmd:southBoundLatitude/gco:Decimal"/>
- <xsl:param name="west" select="gmd:westBoundLongitude/gco:Decimal"/>
-<!-- Bbox as a dct:Box -->
-<!-- Need to check whether this is correct - in particular, the "projection" parameter -->
- <xsl:param name="DCTBox">northlimit=<xsl:value-of select="$north"/>; eastlimit=<xsl:value-of select="$east"/>; southlimit=<xsl:value-of select="$south"/>; westlimit=<xsl:value-of select="$west"/>; projection=EPSG:<xsl:value-of select="$srid"/></xsl:param>
-<!-- Bbox as GML (GeoSPARQL) -->
- <xsl:param name="GMLLiteral">
- <xsl:choose>
- <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LonLat'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LatLon'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/></gml:upperCorner></gml:Envelope></xsl:when>
- </xsl:choose>
- </xsl:param>
-<!-- Bbox as WKT (GeoSPARQL) -->
- <xsl:param name="WKTLiteral">
- <xsl:choose>
- <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'">POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LonLat'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LatLon'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>))</xsl:when>
- </xsl:choose>
- </xsl:param>
-<!-- Bbox as GeoJSON -->
- <xsl:param name="GeoJSONLiteral">{"type":"Polygon","crs":{"type":"name","properties":{"name":"<xsl:value-of select="$SrsUrn"/>"}},"coordinates":[[[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>]]]}</xsl:param>
-<!-- Recommended geometry encodings -->
- <locn:geometry rdf:datatype="{$gsp}wktLiteral"><xsl:value-of select="$WKTLiteral"/></locn:geometry>
- <locn:geometry rdf:datatype="{$gsp}gmlLiteral"><xsl:value-of select="$GMLLiteral"/></locn:geometry>
-<!-- Additional geometry encodings -->
- <locn:geometry rdf:datatype="{$geojsonMediaTypeUri}"><xsl:value-of select="$GeoJSONLiteral"/></locn:geometry>
- <locn:geometry rdf:datatype="{$dct}Box"><xsl:value-of select="$DCTBox"/></locn:geometry>
- </dct:spatial>
- </xsl:template>
- <xsl:template name="TemporalExtent" match="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent">
- <xsl:for-each select="gmd:extent/gml:TimeInstant|gmd:extent/gml:TimePeriod">
- <xsl:if test="local-name(.) = 'TimeInstant' or ( local-name(.) = 'TimePeriod' and gml:beginPosition and gml:endPosition )">
- <xsl:variable name="dctperiod">
- <xsl:choose>
- <xsl:when test="local-name(.) = 'TimeInstant'">start=<xsl:value-of select="gml:timePosition"/>; end=<xsl:value-of select="gml:timePosition"/></xsl:when>
- <xsl:otherwise>start=<xsl:value-of select="gml:beginPosition"/>; end=<xsl:value-of select="gml:endPosition"/></xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <xsl:variable name="dateStart">
- <xsl:choose>
- <xsl:when test="local-name(.) = 'TimeInstant'"><xsl:value-of select="gml:timePosition"/></xsl:when>
- <xsl:otherwise><xsl:value-of select="gml:beginPosition"/></xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <xsl:variable name="dateEnd">
- <xsl:choose>
- <xsl:otherwise><xsl:value-of select="gml:endPosition"/></xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <dct:temporal>
- <dct:PeriodOfTime>
- <schema:startDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateStart"/></schema:startDate>
- <schema:endDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateEnd"/></schema:endDate>
- </dct:PeriodOfTime>
- </dct:temporal>
- </xsl:if>
- </xsl:for-each>
- </xsl:template>
-<!-- Dates of publication, last revision, creation -->
- <xsl:template name="ResourceDates" match="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation">
- </xsl:template>
-<!-- Generic date template -->
- <xsl:template name="Dates" match="gmd:date/gmd:CI_Date">
- <xsl:param name="date">
- <xsl:value-of select="gmd:date/gco:Date"/>
- </xsl:param>
- <xsl:param name="type">
- <xsl:value-of select="gmd:dateType/gmd:CI_DateTypeCode/@codeListValue"/>
- </xsl:param>
- <xsl:choose>
- <xsl:when test="$type = 'publication'">
- <dct:issued rdf:datatype="{$xsd}date">
- <xsl:value-of select="$date"/>
- </dct:issued>
- </xsl:when>
- <xsl:when test="$type = 'revision'">
- </dct:modified>
- </xsl:when>
- <xsl:when test="$type = 'creation' and $profile = $extended">
- <dct:created rdf:datatype="{$xsd}date">
- </dct:created>
- </xsl:when>
- </xsl:choose>
- </xsl:template>
- <xsl:template name="ConstraintsRelatedToAccesAndUse" match="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
- <xsl:param name="LimitationsOnPublicAccess">
- <xsl:value-of select="gmd:MD_LegalConstraints/gmd:otherConstraints/gco:CharacterString"/>
- </xsl:param>
- <xsl:for-each select="gmd:useLimitation">
- <xsl:choose>
-<!-- In case the rights/licence URL IS NOT provided -->
- <xsl:when test="gco:CharacterString">
- <dct:license>
- <dct:LicenseDocument>
- <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></rdfs:label>
- </dct:LicenseDocument>
- </dct:license>
- <dct:rights>
- <dct:RightsStatement>
- </dct:RightsStatement>
- </dct:rights>
- </xsl:when>
-<!-- In case the rights/licence URL IS provided -->
- <xsl:when test="gmx:Anchor/@xlink:href">
- <dct:license rdf:resource="{gmx:Anchor/@xlink:href}"/>
- <dct:license>
- <dct:LicenseDocument rdf:about="{gmx:Anchor/@xlink:href}">
- <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gmx:Anchor)"/></rdfs:label>
- </dct:license>
- </xsl:when>
- </xsl:choose>
- </xsl:for-each>
- <xsl:for-each select="gmd:otherConstraints">
- <dct:accessRights>
- </dct:accessRights>
- </xsl:if>
- </xsl:for-each>
- <xsl:for-each select="gmd:accessConstraints">
- <dct:accessRights rdf:resource="{$MD_RestrictionCode}_{gmd:MD_RestrictionCode/@codeListValue}"/>
- </xsl:for-each>
- <xsl:for-each select="gmd:classification">
- <dct:accessRights rdf:resource="{$MD_ClassificationCode}_{gmd:MD_ClassificationCode/@codeListValue}"/>
- </xsl:for-each>
- </xsl:template>
-<!-- Keyword -->
- <xsl:template name="Keyword" match="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
- <xsl:param name="ServiceType"/>
- <xsl:param name="OriginatingControlledVocabulary">
- <xsl:for-each select="gmd:thesaurusName/gmd:CI_Citation">
- </dct:title>
- </xsl:for-each>
- </xsl:param>
- <xsl:for-each select="gmd:keyword">
- <xsl:variable name="lckw" select="translate(gco:CharacterString,$uppercase,$lowercase)"/>
- <xsl:choose>
- <xsl:when test="$OriginatingControlledVocabulary = '' and not( gmx:Anchor/@xlink:href ) and ( starts-with(gmx:Anchor/@xlink:href, 'http://') or starts-with(gmx:Anchor/@xlink:href, 'https://') )">
- <xsl:choose>
- <dc:subject xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></dc:subject>
- </xsl:if>
- </xsl:when>
- <xsl:otherwise>
- <dcat:keyword xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></dcat:keyword>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- <xsl:otherwise>
- <xsl:choose>
-<!-- In case the concept's URI is NOT provided -->
- <xsl:choose>
- <xsl:when test="$ResourceType != 'service'">
- <dcat:theme rdf:parseType="Resource">
- <xsl:value-of select="gco:CharacterString"/>
- </skos:prefLabel>
- <skos:inScheme>
- <xsl:copy-of select="$OriginatingControlledVocabulary"/>
- </skos:inScheme>
- </dcat:theme>
- </xsl:when>
- <xsl:otherwise>
- <dct:subject rdf:parseType="Resource">
- </skos:prefLabel>
- <skos:inScheme>
- </skos:inScheme>
- </dct:subject>
- </xsl:if>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
-<!-- In case the concept's URI is provided -->
- <xsl:choose>
- <dcat:theme rdf:resource="{gmx:Anchor/@xlink:href}"/>
- <skos:Concept rdf:about="{gmx:Anchor/@xlink:href}">
- <xsl:value-of select="gmx:Anchor"/>
- </skos:prefLabel>
- <skos:inScheme>
- </skos:inScheme>
- </skos:Concept>
- </xsl:when>
- <xsl:otherwise>
- <dct:subject rdf:resource="{gmx:Anchor/@xlink:href}"/>
- </xsl:if>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- </xsl:choose>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:for-each>
- </xsl:template>
- <xsl:template name="TopicCategory" match="gmd:identificationInfo/*/gmd:topicCategory">
- <xsl:param name="TopicCategory"><xsl:value-of select="gmd:MD_TopicCategoryCode"/></xsl:param>
- <dct:subject rdf:resource="{$TopicCategoryCodelistUri}/{$TopicCategory}"/>
- </xsl:template>
-<!-- Spatial resolution (unstable - to be replaced with a standard-based solution, when available) -->
- <xsl:template name="SpatialResolution" match="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution">
-<!-- dcat:granularity is deprecated -->
- <xsl:for-each select="gmd:distance/gco:Distance">
- <dcat:granularity rdf:datatype="{$xsd}string"><xsl:value-of select="."/> <xsl:value-of select="@uom"/></dcat:granularity>
- </xsl:for-each>
- <xsl:for-each select="gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator">
- <dcat:granularity rdf:datatype="{$xsd}string">1/<xsl:value-of select="gco:Integer"/></dcat:granularity>
- </xsl:for-each>
- <xsl:variable name="UoM">
- <xsl:choose>
- <xsl:when test="@uom = 'EPSG::9001' or @uom = 'urn:ogc:def:uom:EPSG::9001' or @uom = 'urn:ogc:def:uom:UCUM::m' or @uom = 'urn:ogc:def:uom:OGC::m'">
- <xsl:value-of select="concat('m',' (', at uom,')')"/>
- </xsl:when>
- <xsl:when test="@uom = 'EPSG::9002' or @uom = 'urn:ogc:def:uom:EPSG::9002' or @uom = 'urn:ogc:def:uom:UCUM::[ft_i]' or @uom = 'urn:ogc:def:uom:OGC::[ft_i]'">
- <xsl:value-of select="concat('ft',' (', at uom,')')"/>
- </xsl:when>
-<!-- To be completed -->
- <xsl:otherwise>
- <xsl:value-of select="@uom"/>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:variable>
- <rdfs:comment xml:lang="en">Spatial resolution (distance): <xsl:value-of select="."/>Â <xsl:value-of select="$UoM"/></rdfs:comment>
- </xsl:for-each>
- <rdfs:comment xml:lang="en">Spatial resolution (equivalent scale): 1:<xsl:value-of select="gco:Integer"/></rdfs:comment>
- </xsl:for-each>
- </xsl:template>
-<!-- Character encoding -->
- <xsl:template name="CharacterEncoding" match="gmd:characterSet/gmd:MD_CharacterSetCode">
- <xsl:variable name="CharSetCode">
- <xsl:choose>
- <xsl:when test="@codeListValue = 'ucs2'">
- <xsl:text>ISO-10646-UCS-2</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'ucs4'">
- <xsl:text>ISO-10646-UCS-4</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'utf7'">
- <xsl:text>UTF-7</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'utf8'">
- <xsl:text>UTF-8</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'utf16'">
- <xsl:text>UTF-16</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part1'">
- <xsl:text>ISO-8859-1</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part2'">
- <xsl:text>ISO-8859-2</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part3'">
- <xsl:text>ISO-8859-3</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part4'">
- <xsl:text>ISO-8859-4</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part5'">
- <xsl:text>ISO-8859-5</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part6'">
- <xsl:text>ISO-8859-6</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part7'">
- <xsl:text>ISO-8859-7</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part8'">
- <xsl:text>ISO-8859-8</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part9'">
- <xsl:text>ISO-8859-9</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part10'">
- <xsl:text>ISO-8859-10</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part11'">
- <xsl:text>ISO-8859-11</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part12'">
- <xsl:text>ISO-8859-12</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part13'">
- <xsl:text>ISO-8859-13</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part14'">
- <xsl:text>ISO-8859-14</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part15'">
- <xsl:text>ISO-8859-15</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = '8859part16'">
- <xsl:text>ISO-8859-16</xsl:text>
- </xsl:when>
-<!-- Mapping to be verified: multiple candidates are available in the IANA register for jis -->
- <xsl:when test="@codeListValue = 'jis'">
- <xsl:text>JIS_Encoding</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'shiftJIS'">
- <xsl:text>Shift_JIS</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'eucJP'">
- <xsl:text>EUC-JP</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'usAscii'">
- <xsl:text>US-ASCII</xsl:text>
- </xsl:when>
-<!-- Mapping to be verified: multiple candidates are available in the IANA register ebcdic -->
- <xsl:when test="@codeListValue = 'ebcdic'">
- <xsl:text>IBM037</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'eucKR'">
- <xsl:text>EUC-KR</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'big5'">
- <xsl:text>Big5</xsl:text>
- </xsl:when>
- <xsl:when test="@codeListValue = 'GB2312'">
- <xsl:text>GB2312</xsl:text>
- </xsl:when>
- </xsl:choose>
- </xsl:variable>
- <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="$CharSetCode"/></cnt:characterEncoding>
- <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="@codeListValue"/></cnt:characterEncoding>
- </xsl:template>
-<!-- Encoding -->
- <xsl:template name="Encoding" match="gmd:distributionFormat/gmd:MD_Format/gmd:name/*">
- <xsl:choose>
- <xsl:when test="@xlink:href and @xlink:href != ''">
- <dct:format rdf:resource="{@xlink:href}"/>
- <dct:format>
- <rdf:Description rdf:about="{@xlink:href}">
- <rdfs:label><xsl:value-of select="."/></rdfs:label>
- </dct:format>
- </xsl:when>
- <xsl:otherwise>
- <dct:format rdf:parseType="Resource">
- </dct:format>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:template>
-<!-- Maintenance information -->
- <xsl:template name="MaintenanceInformation" match="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode">
-<!-- The following parameter maps frequency codes used in ISO 19139 metadata to the corresponding ones of the Dublin Core Collection Description Frequency Vocabulary (when available). -->
- <xsl:param name="FrequencyCodeURI">
- <xsl:if test="@codeListValue != ''">
- <xsl:choose>
- <xsl:when test="@codeListValue = 'continual'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'continuous')"/>
- <xsl:value-of select="concat($opfq,'CONT')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'daily'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'daily')"/>
- <xsl:value-of select="concat($opfq,'DAILY')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'weekly'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'weekly')"/>
- <xsl:value-of select="concat($opfq,'WEEKLY')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'fortnightly'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'biweekly')"/>
- <xsl:value-of select="concat($opfq,'BIWEEKLY')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'monthly'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'monthly')"/>
- <xsl:value-of select="concat($opfq,'MONTHLY')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'quarterly'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'quarterly')"/>
- <xsl:value-of select="concat($opfq,'QUARTERLY')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'biannually'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'semiannual')"/>
- <xsl:value-of select="concat($opfq,'ANNUAL_2')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'annually'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'annual')"/>
- <xsl:value-of select="concat($opfq,'ANNUAL')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'asNeeded'">
-<!-- A mapping is missing in Dublin Core -->
-<!-- A mapping is missing in MDR Freq NAL -->
- <xsl:value-of select="concat($MaintenanceFrequencyCodelistUri,'/', at codeListValue)"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'irregular'">
-<!-- DC Freq voc
- <xsl:value-of select="concat($cldFrequency,'irregular')"/>
- <xsl:value-of select="concat($opfq,'IRREG')"/>
- </xsl:when>
- <xsl:when test="@codeListValue = 'notPlanned'">
- </xsl:when>
- <xsl:when test="@codeListValue = 'unknown'">
-<!-- INSPIRE Freq code list (not yet available)
- <xsl:value-of select="concat($opfq,'UNKNOWN')"/>
- </xsl:when>
- </xsl:choose>
- </xsl:if>
- </xsl:param>
- <xsl:if test="$FrequencyCodeURI != ''">
- <dct:accrualPeriodicity rdf:resource="{$FrequencyCodeURI}"/>
- </xsl:if>
- </xsl:template>
-<!-- Coordinate and temporal reference system (tentative) -->
- <xsl:template name="ReferenceSystem" match="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
- <xsl:param name="code" select="gmd:code/gco:CharacterString"/>
- <xsl:param name="codespace" select="gmd:codeSpace/gco:CharacterString"/>
- <xsl:param name="version" select="gmd:version/gco:CharacterString"/>
- <xsl:choose>
- <dct:conformsTo>
- <rdf:Description rdf:about="{$code}">
- <dct:type rdf:resource="{$INSPIREGlossaryUri}SpatialReferenceSystem"/>
- </dct:conformsTo>
- </xsl:when>
- <xsl:when test="starts-with($code, 'urn:')">
- <xsl:variable name="srid">
- <xsl:if test="starts-with(translate($code,$uppercase,$lowercase), translate($EpsgSrsBaseUrn,$uppercase,$lowercase))">
- <xsl:value-of select="substring-after(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
- </xsl:if>
- </xsl:variable>
- <xsl:variable name="sridVersion" select="substring-before(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
- <xsl:choose>
- <xsl:when test="$srid != '' and string(number($srid)) != 'NaN'">
- <dct:conformsTo>
- <rdf:Description rdf:about="{$EpsgSrsBaseUri}/{$srid}">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$code"/></dct:identifier>
- <skos:inScheme>
- <skos:ConceptScheme rdf:about="{$EpsgSrsBaseUri}">
- <dct:title xml:lang="en"><xsl:value-of select="$EpsgSrsName"/></dct:title>
- </skos:inScheme>
- <xsl:if test="$sridVersion != ''">
- <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$sridVersion"/></owl:versionInfo>
- </xsl:if>
- </dct:conformsTo>
- </xsl:when>
- <xsl:otherwise>
- <xsl:if test="$codespace != ''">
- <skos:inScheme>
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$codespace"/></dct:title>
- </skos:inScheme>
- </xsl:if>
- <xsl:if test="$version != ''">
- <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$version"/></owl:versionInfo>
- </xsl:if>
- </dct:conformsTo>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:when>
- <xsl:otherwise>
- <xsl:choose>
- <xsl:when test="$code = number($code) and (translate($codespace,$uppercase,$lowercase) = 'epsg' or starts-with(translate($codespace,$uppercase,$lowercase),translate($EpsgSrsBaseUrn,$uppercase,$lowercase)))">
- <dct:conformsTo>
- <rdf:Description rdf:about="{$EpsgSrsBaseUri}/{$code}">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="concat($EpsgSrsBaseUrn,':',$version,':',$code)"/></dct:identifier>
- <skos:inScheme>
- </skos:inScheme>
- </xsl:if>
- </dct:conformsTo>
- </xsl:when>
- <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'etrs89'">
- <dct:conformsTo>
- <rdf:Description rdf:about="{$Etrs89Uri}">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Etrs89Urn"/></dct:identifier>
- <skos:prefLabel xml:lang="en">ETRS89 - European Terrestrial Reference System 1989</skos:prefLabel>
- <skos:inScheme>
- </skos:inScheme>
- </xsl:if>
- </dct:conformsTo>
- </xsl:when>
- <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'crs84'">
- <dct:conformsTo>
- <rdf:Description rdf:about="{$Crs84Uri}">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Crs84Urn"/></dct:identifier>
- <skos:prefLabel xml:lang="en">CRS84</skos:prefLabel>
- <skos:inScheme>
- <skos:ConceptScheme rdf:about="{$OgcSrsBaseUri}">
- <dct:title xml:lang="en"><xsl:value-of select="$OgcSrsName"/></dct:title>
- </skos:inScheme>
- </xsl:if>
- </dct:conformsTo>
- </xsl:when>
- <xsl:otherwise>
- <skos:prefLabel xml:lang="{$MetadataLanguage}"><xsl:value-of select="$code"/></skos:prefLabel>
- <skos:inScheme>
- </skos:inScheme>
- </xsl:if>
- </xsl:if>
- </dct:conformsTo>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:otherwise>
- </xsl:choose>
- </xsl:template>
- <xsl:template name="SpatialRepresentationType" match="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode">
- <adms:representationTechnique rdf:resource="{$SpatialRepresentationTypeCodelistUri}/{@codeListValue}"/>
- </xsl:template>
-</xsl:transform>
\ No newline at end of file
+<?xml version="1.0" encoding="UTF-8"?>
+ Copyright 2015-2016 EUROPEAN UNION
+ Licensed under the EUPL, Version 1.1 or - as soon they will be approved by
+ the European Commission - subsequent versions of the EUPL (the "Licence");
+ You may not use this work except in compliance with the Licence.
+ You may obtain a copy of the Licence at:
+ http://ec.europa.eu/idabc/eupl
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the Licence is distributed on an "AS IS" basis,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the Licence for the specific language governing permissions and
+ limitations under the Licence.
+ Authors: European Commission - Joint Research Centre
+ Andrea Perego <andrea.perego at jrc.ec.europa.eu>
+ Contributors: ISA GeoDCAT-AP Working Group
+ <dcat_application_profile-geo at joinup.ec.europa.eu>
+ This work was supported by the EU Interoperability Solutions for
+ European Public Administrations Programme (http://ec.europa.eu/isa)
+ through Action 1.17: Re-usable INSPIRE Reference Platform
+ (http://ec.europa.eu/isa/actions/01-trusted-information-exchange/1-17action_en.htm).
+ PURPOSE AND USAGE
+ This XSLT is a proof of concept for the implementation of the specification
+ concerning the geospatial profile of DCAT-AP (GeoDCAT-AP), available on
+ Joinup, the collaboration platform of the EU ISA Programme:
+ https://joinup.ec.europa.eu/node/139283/
+ As such, this XSLT must be considered as unstable, and can be updated any
+ time based on the revisions to the GeoDCAT-AP specifications and
+ related work in the framework of INSPIRE and the EU ISA Programme.
+<xsl:transform
+ xmlns:adms = "http://www.w3.org/ns/adms#"
+ xmlns:cnt = "http://www.w3.org/2011/content#"
+ xmlns:dc = "http://purl.org/dc/elements/1.1/"
+ xmlns:dcat = "http://www.w3.org/ns/dcat#"
+ xmlns:dct = "http://purl.org/dc/terms/"
+ xmlns:dctype = "http://purl.org/dc/dcmitype/"
+ xmlns:earl = "http://www.w3.org/ns/earl#"
+ xmlns:foaf = "http://xmlns.com/foaf/0.1/"
+ xmlns:gco = "http://www.isotc211.org/2005/gco"
+ xmlns:gmd = "http://www.isotc211.org/2005/gmd"
+ xmlns:gml = "http://www.opengis.net/gml"
+ xmlns:gmx = "http://www.isotc211.org/2005/gmx"
+ xmlns:gsp = "http://www.opengis.net/ont/geosparql#"
+ xmlns:i = "http://inspire.ec.europa.eu/schemas/common/1.0"
+ xmlns:i-gp = "http://inspire.ec.europa.eu/schemas/geoportal/1.0"
+ xmlns:locn = "http://www.w3.org/ns/locn#"
+ xmlns:owl = "http://www.w3.org/2002/07/owl#"
+ xmlns:org = "http://www.w3.org/ns/org#"
+ xmlns:prov = "http://www.w3.org/ns/prov#"
+ xmlns:rdf = "http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:rdfs = "http://www.w3.org/2000/01/rdf-schema#"
+ xmlns:schema = "http://schema.org/"
+ xmlns:skos = "http://www.w3.org/2004/02/skos/core#"
+ xmlns:srv = "http://www.isotc211.org/2005/srv"
+ xmlns:vcard = "http://www.w3.org/2006/vcard/ns#"
+ xmlns:wdrs = "http://www.w3.org/2007/05/powder-s#"
+ xmlns:xlink = "http://www.w3.org/1999/xlink"
+ xmlns:xsi = "http://www.w3.org/2001/XMLSchema-instance"
+ xmlns:xsl = "http://www.w3.org/1999/XSL/Transform"
+ exclude-result-prefixes="earl gco gmd gml gmx i i-gp srv xlink xsi xsl wdrs"
+ version="1.0">
+ <xsl:output method="xml"
+ indent="yes"
+ encoding="utf-8"
+ cdata-section-elements="locn:geometry" />
+ Global variables
+<!-- Variables $core and $extended. -->
+ These variables are meant to be placeholders for the IDs used for the core and extended profiles of GeoDCAT-AP.
+ <xsl:variable name="core">core</xsl:variable>
+ <xsl:variable name="extended">extended</xsl:variable>
+ Mapping parameters
+ This section includes mapping parameters by the XSLT processor used, or, possibly, manually.
+<!-- Parameter $profile -->
+ This parameter specifies the GeoDCAT-AP profile to be used:
+ - value "core": the GeoDCAT-AP Core profile, which includes only the INSPIRE and ISO 19115 core metadata elements supported in DCAT-AP
+ - value "extended": the GeoDCAT-AP Extended profile, which defines mappings for all the INSPIRE and ISO 19115 core metadata elements
+ The current specifications for the core and extended GeoDCAT-AP profiles are available on the Joinup collaboration platform:
+<!-- Uncomment to use GeoDCAT-AP Core -->
+ <xsl:param name="profile" select="$core"/>
+<!-- Uncomment to use GeoDCAT-AP Extended -->
+ <xsl:param name="profile" select="$extended"/>
+<!-- Parameter $CoupledResourceLookUp -->
+ This parameter specifies whether the coupled resource, referenced via @xlink:href, should be looked up to fetch the resource's unique resource identifier (i.e., code and code space). More precisely:
+ - value "enabled": The coupled resource is looked up
+ - value "disabled": The coupled resource is not looked up
+ The default value is "enabled" for GeoDCAT-AP Extended, and "disabled" otherwise.
+ CAVEAT: Using this feature may cause the transformation to hang, in case the URL in @xlink:href is broken, the request hangs indefinitely, or does not return the expected resource (e.g., and HTML page, instead of an XML-encoded ISO 19139 record). It is strongly recommended that this issue is dealt with by using appropriate configuration parameters and error handling (e.g., by specifying a timeout on HTTP calls and by setting the HTTP Accept header to "application/xml").
+ <xsl:param name="CoupledResourceLookUp">
+ <xsl:choose>
+ <xsl:when test="$profile = $extended">
+ <xsl:text>enabled</xsl:text>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:text>disabled</xsl:text>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ Other global parameters
+<!-- Variables to be used to convert strings into lower/uppercase by using the translate() function. -->
+ <xsl:variable name="lowercase">abcdefghijklmnopqrstuvwxyz</xsl:variable>
+ <xsl:variable name="uppercase">ABCDEFGHIJKLMNOPQRSTUVWXYZ</xsl:variable>
+<!-- URIs, URNs and names for spatial reference system registers. -->
+ <xsl:param name="EpsgSrsBaseUri">http://www.opengis.net/def/crs/EPSG/0</xsl:param>
+ <xsl:param name="EpsgSrsBaseUrn">urn:ogc:def:crs:EPSG</xsl:param>
+ <xsl:param name="EpsgSrsName">EPSG Coordinate Reference Systems</xsl:param>
+ <xsl:param name="OgcSrsBaseUri">http://www.opengis.net/def/crs/OGC</xsl:param>
+ <xsl:param name="OgcSrsBaseUrn">urn:ogc:def:crs:OGC</xsl:param>
+ <xsl:param name="OgcSrsName">OGC Coordinate Reference Systems</xsl:param>
+<!-- URI and URN for CRS84. -->
+ <xsl:param name="Crs84Uri" select="concat($OgcSrsBaseUri,'/1.3/CRS84')"/>
+ <xsl:param name="Crs84Urn" select="concat($OgcSrsBaseUrn,':1.3:CRS84')"/>
+<!-- URI and URN for ETRS89. -->
+ <xsl:param name="Etrs89Uri" select="concat($EpsgSrsBaseUri,'/4258')"/>
+ <xsl:param name="Etrs89Urn" select="concat($EpsgSrsBaseUrn,'::4258')"/>
+<!-- URI and URN of the spatial reference system (SRS) used in the bounding box.
+ The default SRS is CRS84. If a different SRS is used, also parameter
+ $SrsAxisOrder must be specified. -->
+<!-- The SRS URI is used in the WKT and GML encodings of the bounding box. -->
+ <xsl:param name="SrsUri" select="$Crs84Uri"/>
+<!-- The SRS URN is used in the GeoJSON encoding of the bounding box. -->
+ <xsl:param name="SrsUrn" select="$Crs84Urn"/>
+<!-- Axis order for the reference SRS:
+ - "LonLat": longitude / latitude
+ - "LatLon": latitude / longitude.
+ The axis order must be specified only if the reference SRS is different from CRS84.
+ If the reference SRS is CRS84, this parameter is ignored. -->
+ <xsl:param name="SrsAxisOrder">LonLat</xsl:param>
+<!-- Namespaces -->
+ <xsl:param name="xsd">http://www.w3.org/2001/XMLSchema#</xsl:param>
+ <xsl:param name="dct">http://purl.org/dc/terms/</xsl:param>
+ <xsl:param name="dctype">http://purl.org/dc/dcmitype/</xsl:param>
+<!-- Currently not used.
+ <xsl:param name="timeUri">http://placetime.com/</xsl:param>
+ <xsl:param name="timeInstantUri" select="concat($timeUri,'instant/gregorian/')"/>
+ <xsl:param name="timeIntervalUri" select="concat($timeUri,'interval/gregorian/')"/>
+ <xsl:param name="dcat">http://www.w3.org/ns/dcat#</xsl:param>
+ <xsl:param name="gsp">http://www.opengis.net/ont/geosparql#</xsl:param>
+ <xsl:param name="foaf">http://xmlns.com/foaf/0.1/</xsl:param>
+ <xsl:param name="vcard">http://www.w3.org/2006/vcard/ns#</xsl:param>
+<!-- Old params used for the SRS
+ <xsl:param name="ogcCrsBaseUri">http://www.opengis.net/def/EPSG/0/</xsl:param>
+ <xsl:param name="ogcCrsBaseUrn">urn:ogc:def:EPSG::</xsl:param>
+ <xsl:param name="inspire">http://inspire.ec.europa.eu/schemas/md/</xsl:param>
+ <xsl:param name="kos">http://ec.europa.eu/open-data/kos/</xsl:param>
+ <xsl:param name="kosil" select="concat($kos,'interoperability-level/')"/>
+ <xsl:param name="kosdst" select="concat($kos,'dataset-type/')"/>
+ <xsl:param name="kosdss" select="concat($kos,'dataset-status/Completed')"/>
+ <xsl:param name="kosdoct" select="concat($kos,'documentation-type/')"/>
+ <xsl:param name="koslic" select="concat($kos,'licence/EuropeanCommission')"/>
+ <xsl:param name="op">http://publications.europa.eu/resource/authority/</xsl:param>
+ <xsl:param name="opcountry" select="concat($op,'country/')"/>
+ <xsl:param name="oplang" select="concat($op,'language/')"/>
+ <xsl:param name="opcb" select="concat($op,'corporate-body/')"/>
+ <xsl:param name="opfq" select="concat($op,'frequency/')"/>
+ <xsl:param name="cldFrequency">http://purl.org/cld/freq/</xsl:param>
+<!-- This is used as the datatype for the GeoJSON-based encoding of the bounding box. -->
+ <xsl:param name="geojsonMediaTypeUri">https://www.iana.org/assignments/media-types/application/vnd.geo+json</xsl:param>
+<!-- INSPIRE code list URIs -->
+ <xsl:param name="INSPIRECodelistUri">http://inspire.ec.europa.eu/metadata-codelist/</xsl:param>
+ <xsl:param name="SpatialDataServiceCategoryCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceCategory')"/>
+ <xsl:param name="DegreeOfConformityCodelistUri" select="concat($INSPIRECodelistUri,'DegreeOfConformity')"/>
+ <xsl:param name="ResourceTypeCodelistUri" select="concat($INSPIRECodelistUri,'ResourceType')"/>
+ <xsl:param name="ResponsiblePartyRoleCodelistUri" select="concat($INSPIRECodelistUri,'ResponsiblePartyRole')"/>
+ <xsl:param name="SpatialDataServiceTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceType')"/>
+ <xsl:param name="TopicCategoryCodelistUri" select="concat($INSPIRECodelistUri,'TopicCategory')"/>
+<!-- INSPIRE code list URIs (not yet supported; the URI pattern is tentative) -->
+ <xsl:param name="SpatialRepresentationTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialRepresentationTypeCode')"/>
+ <xsl:param name="MaintenanceFrequencyCodelistUri" select="concat($INSPIRECodelistUri,'MaintenanceFrequencyCode')"/>
+<!-- INSPIRE glossary URI -->
+ <xsl:param name="INSPIREGlossaryUri">http://inspire.ec.europa.eu/glossary/</xsl:param>
+ Master template
+ <xsl:template match="/">
+ <rdf:RDF>
+ <xsl:apply-templates select="gmd:MD_Metadata|//gmd:MD_Metadata"/>
+ </rdf:RDF>
+ </xsl:template>
+ Metadata template
+ <xsl:template match="gmd:MD_Metadata|//gmd:MD_Metadata">
+ Parameters to create HTTP URIs for the resource and the corresponding metadata record
+ These parameters must be customised depending on the strategy used to assign HTTP URIs.
+ The default rule implies that HTTP URIs are specified for the metadata file identifier
+ (metadata URI) and the resource identifier (resource URI).
+ <xsl:param name="ResourceUri">
+ <xsl:variable name="rURI" select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/*/gmd:code/gco:CharacterString"/>
+ <xsl:if test="$rURI != '' and ( starts-with($rURI, 'http://') or starts-with($rURI, 'https://') )">
+ <xsl:value-of select="$rURI"/>
+ </xsl:if>
+ </xsl:param>
+ <xsl:param name="MetadataUri">
+ <xsl:variable name="mURI" select="gmd:fileIdentifier/gco:CharacterString"/>
+ <xsl:if test="$mURI != '' and ( starts-with($mURI, 'http://') or starts-with($mURI, 'https://') )">
+ <xsl:value-of select="$mURI"/>
+ </xsl:if>
+ </xsl:param>
+ Other parameters
+<!-- Metadata language: corresponding Alpha-2 codes -->
+ <xsl:param name="ormlang">
+ <xsl:choose>
+ <xsl:when test="gmd:language/gmd:LanguageCode/@codeListValue != ''">
+ <xsl:value-of select="translate(gmd:language/gmd:LanguageCode/@codeListValue,$uppercase,$lowercase)"/>
+ </xsl:when>
+ <xsl:when test="gmd:language/gmd:LanguageCode != ''">
+ <xsl:value-of select="translate(gmd:language/gmd:LanguageCode,$uppercase,$lowercase)"/>
+ </xsl:when>
+ <xsl:when test="gmd:language/gco:CharacterString != ''">
+ <xsl:value-of select="translate(gmd:language/gco:CharacterString,$uppercase,$lowercase)"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="MetadataLanguage">
+ <xsl:choose>
+ <xsl:when test="$ormlang = 'bul'">
+ <xsl:text>bg</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'cze'">
+ <xsl:text>cs</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'dan'">
+ <xsl:text>da</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'ger'">
+ <xsl:text>de</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'gre'">
+ <xsl:text>el</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'eng'">
+ <xsl:text>en</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'spa'">
+ <xsl:text>es</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'est'">
+ <xsl:text>et</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'fin'">
+ <xsl:text>fi</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'fre'">
+ <xsl:text>fr</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'gle'">
+ <xsl:text>ga</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'hrv'">
+ <xsl:text>hr</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'ita'">
+ <xsl:text>it</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'lav'">
+ <xsl:text>lv</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'lit'">
+ <xsl:text>lt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'hun'">
+ <xsl:text>hu</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'mlt'">
+ <xsl:text>mt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'dut'">
+ <xsl:text>nl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'pol'">
+ <xsl:text>pl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'por'">
+ <xsl:text>pt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'rum'">
+ <xsl:text>ru</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'slo'">
+ <xsl:text>sk</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'slv'">
+ <xsl:text>sl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$ormlang = 'swe'">
+ <xsl:text>sv</xsl:text>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$ormlang"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+<!-- Resource language: corresponding Alpha-2 codes -->
+ <xsl:param name="orrlang">
+ <xsl:choose>
+ <xsl:when test="gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue != ''">
+ <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue,$uppercase,$lowercase)"/>
+ </xsl:when>
+ <xsl:when test="gmd:identificationInfo/*/gmd:language/gmd:LanguageCode != ''">
+ <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gmd:LanguageCode,$uppercase,$lowercase)"/>
+ </xsl:when>
+ <xsl:when test="gmd:identificationInfo/*/gmd:language/gco:CharacterString != ''">
+ <xsl:value-of select="translate(gmd:identificationInfo/*/gmd:language/gco:CharacterString,$uppercase,$lowercase)"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="ResourceLanguage">
+ <xsl:choose>
+ <xsl:when test="$orrlang = 'bul'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'cze'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'dan'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'ger'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'gre'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'eng'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'spa'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'est'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'fin'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'fre'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'gle'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'hrv'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'ita'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'lav'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'lit'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'hun'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'mlt'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'dut'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'pol'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'por'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'rum'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'slo'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'slv'">
+ </xsl:when>
+ <xsl:when test="$orrlang = 'swe'">
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$orrlang"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="IsoScopeCode">
+ <xsl:value-of select="normalize-space(gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue)"/>
+ </xsl:param>
+ <xsl:param name="InspireResourceType">
+ <xsl:if test="$IsoScopeCode = 'dataset' or $IsoScopeCode = 'series' or $IsoScopeCode = 'service'">
+ <xsl:value-of select="$IsoScopeCode"/>
+ </xsl:if>
+ </xsl:param>
+ <xsl:param name="ResourceType">
+ <xsl:choose>
+ <xsl:when test="$IsoScopeCode = 'dataset' or $IsoScopeCode = 'nonGeographicDataset'">
+ <xsl:text>dataset</xsl:text>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="ServiceType">
+ <xsl:value-of select="gmd:identificationInfo/*/srv:serviceType/gco:LocalName"/>
+ </xsl:param>
+ <xsl:param name="ResourceTitle">
+ <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:title/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:for-each select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:title">
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></dct:title>
+ <xsl:call-template name="LocalisedString">
+ <xsl:with-param name="term">dct:title</xsl:with-param>
+ </xsl:call-template>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="ResourceAbstract">
+ <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:abstract/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:for-each select="gmd:identificationInfo[1]/*/gmd:abstract">
+ <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></dct:description>
+ <xsl:with-param name="term">dct:description</xsl:with-param>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Lineage">
+ <xsl:value-of select="gmd:dataQualityInfo/*/gmd:lineage/*/gmd:statement/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:for-each select="gmd:dataQualityInfo/*/gmd:lineage/*/gmd:statement">
+ <dct:provenance>
+ <dct:ProvenanceStatement>
+ <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></rdfs:label>
+ <xsl:with-param name="term">rdfs:label</xsl:with-param>
+ </dct:ProvenanceStatement>
+ </dct:provenance>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="MetadataDate">
+ <xsl:choose>
+ <xsl:when test="gmd:dateStamp/gco:Date">
+ <xsl:value-of select="gmd:dateStamp/gco:Date"/>
+ </xsl:when>
+ <xsl:when test="gmd:dateStamp/gco:DateTime">
+ <xsl:value-of select="substring(gmd:dateStamp/gco:DateTime/text(),1,10)"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="UniqueResourceIdentifier">
+ <xsl:for-each select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:identifier/*">
+ <xsl:choose>
+ <xsl:when test="gmd:codeSpace/gco:CharacterString/text() != ''">
+ <xsl:value-of select="concat(gmd:codeSpace/gco:CharacterString/text(),gmd:code/gco:CharacterString/text())"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="gmd:code/gco:CharacterString/text()"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="ConstraintsRelatedToAccessAndUse">
+ <xsl:apply-templates select="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
+ <xsl:with-param name="MetadataLanguage" select="$MetadataLanguage"/>
+ </xsl:apply-templates>
+ </xsl:param>
+<!-- Conformity, expressed by using an earl:Assertion (only for the extended profile) -->
+ <xsl:param name="Conformity">
+ <xsl:for-each select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+ <xsl:variable name="specinfo">
+ <xsl:value-of select="gmd:title/gco:CharacterString"/>
+ </dct:title>
+ <xsl:apply-templates select="gmd:date/gmd:CI_Date"/>
+ </xsl:variable>
+ <xsl:variable name="degree">
+ <xsl:choose>
+ <xsl:when test="../../gmd:pass/gco:Boolean = 'true'">
+ <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/conformant')"/>
+ </xsl:when>
+ <xsl:when test="../../gmd:pass/gco:Boolean = 'false'">
+ <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notConformant')"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notEvaluated')"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <xsl:variable name="explanation">
+ <xsl:value-of select="../../gmd:explanation/gco:CharacterString"/>
+ </xsl:variable>
+ <earl:Assertion>
+ <xsl:if test="$ResourceUri != ''">
+ <earl:subject rdf:resource="{$ResourceUri}"/>
+ </xsl:if>
+ <xsl:choose>
+ <xsl:when test="../@xlink:href and ../@xlink:href != ''">
+ <earl:test>
+ <rdf:Description rdf:about="{../@xlink:href}">
+ <xsl:copy-of select="$specinfo"/>
+ </rdf:Description>
+ </earl:test>
+ </xsl:when>
+ <xsl:otherwise>
+ <earl:test rdf:parseType="Resource">
+ </earl:test>
+ </xsl:otherwise>
+ </xsl:choose>
+ <earl:result>
+ <earl:TestResult>
+ <earl:outcome rdf:resource="{$degree}"/>
+ <xsl:if test="$explanation and $explanation != ''">
+ <earl:info xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></earl:info>
+ </xsl:if>
+ </earl:TestResult>
+ </earl:result>
+ </earl:Assertion>
+ </xsl:for-each>
+ </xsl:param>
+<!-- Conformity, expressed by using a prov:Activity (only for the extended profile) -->
+ <xsl:variable name="specTitle">
+ <xsl:for-each select="gmd:title">
+ </xsl:for-each>
+ </xsl:variable>
+ </dct:title>
+ <xsl:copy-of select="$specTitle"/>
+ </xsl:variable>
+ <xsl:choose>
+ </xsl:when>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:when test="../../gmd:pass/gco:Boolean = ''">
+ </xsl:when>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ </xsl:variable>
+ <xsl:for-each select="../../gmd:explanation">
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:variable name="Activity">
+ <prov:Activity>
+ <prov:used rdf:resource="{$ResourceUri}"/>
+ </xsl:if>
+ <prov:qualifiedAssociation rdf:parseType="Resource">
+ <prov:hadPlan rdf:parseType="Resource">
+ <xsl:choose>
+ <prov:wasDerivedFrom rdf:resource="{../@xlink:href}"/>
+ <prov:wasDerivedFrom>
+ </prov:wasDerivedFrom>
+ </xsl:when>
+ <xsl:otherwise>
+ <prov:wasDerivedFrom rdf:parseType="Resource">
+ </xsl:otherwise>
+ </xsl:choose>
+ </prov:hadPlan>
+ </prov:qualifiedAssociation>
+ <prov:generated rdf:parseType="Resource">
+ <dct:type rdf:resource="{$degree}"/>
+ <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></dct:description>
+ </xsl:if>
+ <xsl:copy-of select="$explanation"/>
+ </prov:generated>
+ </prov:Activity>
+ </xsl:variable>
+ <xsl:choose>
+ <xsl:when test="$ResourceUri != ''">
+ <xsl:copy-of select="$Activity"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <prov:wasUsedBy>
+ </prov:wasUsedBy>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:param>
+<!-- Metadata character encoding (only for the extended profile) -->
+ <xsl:param name="MetadataCharacterEncoding">
+ <xsl:apply-templates select="gmd:characterSet/gmd:MD_CharacterSetCode"/>
+ </xsl:param>
+ <xsl:param name="ResourceCharacterEncoding">
+ <xsl:for-each select="gmd:identificationInfo/gmd:MD_DataIdentification">
+ </xsl:for-each>
+ </xsl:param>
+<!-- Metadata description (metadata on metadata) -->
+ <xsl:param name="MetadataDescription">
+<!-- Metadata language -->
+ <xsl:if test="$ormlang != ''">
+ <dct:language rdf:resource="{concat($oplang,translate($ormlang,$lowercase,$uppercase))}"/>
+ </xsl:if>
+<!-- Metadata date -->
+ <xsl:if test="$MetadataDate != ''">
+ <dct:modified rdf:datatype="{$xsd}date">
+ <xsl:value-of select="$MetadataDate"/>
+ </dct:modified>
+ </xsl:if>
+<!-- Metadata point of contact: only for the extended profile -->
+ <xsl:if test="$profile = $extended">
+ <xsl:for-each select="gmd:contact">
+ <xsl:apply-templates select="gmd:CI_ResponsibleParty">
+ <xsl:with-param name="ResourceType" select="$ResourceType"/>
+ </xsl:for-each>
+<!-- Old version
+ <xsl:apply-templates select="gmd:contact/gmd:CI_ResponsibleParty">
+ </xsl:if>
+<!-- Metadata file identifier (tentative): only for the extended profile -->
+ <xsl:for-each select="gmd:fileIdentifier/gco:CharacterString">
+ <dct:identifier rdf:datatype="{$xsd}string"><xsl:value-of select="."/></dct:identifier>
+ </xsl:for-each>
+ </xsl:if>
+<!-- Metadata standard (tentative): only for the extended profile -->
+ <xsl:variable name="MetadataStandardURI" select="gmd:metadataStandardName/gmx:Anchor/@xlink:href"/>
+ <xsl:variable name="MetadataStandardName" select="gmd:metadataStandardName/*[self::gco:CharacterString|self::gmx:Anchor]"/>
+ <xsl:variable name="MetadataStandardName">
+ <xsl:for-each select="gmd:metadataStandardName">
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(*[self::gco:CharacterString|self::gmx:Anchor])"/></dct:title>
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:variable name="MetadataStandardVersion" select="gmd:metadataStandardVersion/gco:CharacterString"/>
+ <xsl:if test="$MetadataCharacterEncoding != '' or $MetadataStandardURI != '' or $MetadataStandardName != ''">
+ <dct:source rdf:parseType="Resource">
+ <xsl:if test="$MetadataCharacterEncoding != ''">
+<!-- Metadata character encoding (tentative): only for the extended profile -->
+ <xsl:copy-of select="$MetadataCharacterEncoding"/>
+ </xsl:if>
+ <xsl:choose>
+ <xsl:when test="$MetadataStandardURI != ''">
+<!-- Metadata standard, denoted by a URI -->
+ <dct:conformsTo rdf:resource="{$MetadataStandardURI}"/>
+ </xsl:when>
+ <xsl:when test="$MetadataStandardName != ''">
+ <dct:conformsTo rdf:parseType="Resource">
+<!-- Metadata standard name -->
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardName"/></dct:title>
+ <xsl:copy-of select="$MetadataStandardName"/>
+ <xsl:if test="$MetadataStandardVersion != ''">
+<!-- Metadata standard version -->
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardVersion"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ </xsl:choose>
+ </dct:source>
+ </xsl:if>
+<!-- Old version:
+ <xsl:for-each select="gmd:metadataStandardName/gco:CharacterString">
+ <xsl:if test="text() != '' or ../../gmd:metadataStandardVersion/gco:CharacterString/text() != ''">
+ </xsl:if>
+ <xsl:if test="text() != ''">
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:title>
+ </xsl:if>
+ <xsl:if test="../../gmd:metadataStandardName/gco:CharacterString/text() != ''">
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="../../gmd:metadataStandardVersion/gco:CharacterString"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </dct:source>
+ </xsl:if>
+ </xsl:for-each>
+ </xsl:if>
+ </xsl:param>
+<!-- Resource description (resource metadata) -->
+ <xsl:param name="ResourceDescription">
+ <xsl:choose>
+ <xsl:when test="$ResourceType = 'dataset'">
+ <rdf:type rdf:resource="{$dcat}Dataset"/>
+ </xsl:when>
+ <xsl:when test="$ResourceType = 'series'">
+ </xsl:when>
+ <xsl:when test="$ResourceType = 'service'">
+ <rdf:type rdf:resource="{$dctype}Service"/>
+ </xsl:if>
+ <xsl:if test="$ServiceType = 'discovery'">
+ <rdf:type rdf:resource="{$dcat}Catalog"/>
+ </xsl:if>
+ </xsl:when>
+ </xsl:choose>
+ <xsl:if test="$InspireResourceType != ''">
+ <dct:type rdf:resource="{$ResourceTypeCodelistUri}/{$ResourceType}"/>
+ </xsl:if>
+ </xsl:if>
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$ResourceTitle"/></dct:title>
+ <xsl:copy-of select="$ResourceTitle"/>
+ <xsl:value-of select="normalize-space($ResourceAbstract)"/>
+ </dct:description>
+ <xsl:copy-of select="$ResourceAbstract"/>
+<!-- Maintenance information (tentative) -->
+ <xsl:for-each select="gmd:identificationInfo/*/gmd:resourceMaintenance">
+ <xsl:apply-templates select="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode"/>
+ </xsl:for-each>
+<!-- Topic category -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:topicCategory">
+ </xsl:if>
+<!-- Keyword -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
+ <xsl:with-param name="ServiceType" select="$ServiceType"/>
+<!-- Identifier, 0..1 -->
+ <xsl:apply-templates select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/*">
+<!-- Resource locators -->
+ <xsl:apply-templates select="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+<!-- Unique Resource Identifier -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*"/>
+<!-- Coupled resources -->
+ <xsl:apply-templates select="gmd:identificationInfo[1]/*/srv:operatesOn">
+<!-- Resource Language -->
+ <xsl:if test="$ResourceType = 'dataset' or $ResourceType = 'series'">
+ <xsl:choose>
+ <xsl:when test="$orrlang != ''">
+ <dct:language rdf:resource="{concat($oplang,translate($orrlang,$lowercase,$uppercase))}"/>
+ </xsl:when>
+ <xsl:otherwise>
+<!-- To be decided (when the resource language is not specified, it defaults to the metadata language): -->
+ </xsl:if>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:if>
+<!-- Spatial service type -->
+ <xsl:if test="$ResourceType = 'service' and $profile = $extended">
+<!-- Replaced by param $ServiceType -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/srv:serviceType">
+ <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{$ServiceType}"/>
+ </xsl:if>
+<!-- Spatial extent -->
+ <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox"/>
+ <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
+<!-- Temporal extent -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent"/>
+<!-- Creation date, publication date, date of last revision -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation"/>
+<!-- Lineage -->
+ <xsl:if test="$ResourceType != 'service' and $Lineage != ''">
+ <dct:provenance>
+ <xsl:value-of select="normalize-space($Lineage)"/>
+ </rdfs:label>
+ </dct:provenance>
+ <xsl:copy-of select="$Lineage"/>
+ </xsl:if>
+<!-- Coordinate and temporal reference systems (tentative) -->
+ <xsl:apply-templates select="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
+ </xsl:if>
+<!-- Spatial resolution -->
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution"/>
+ </xsl:if>
+<!-- Conformity -->
+ <xsl:apply-templates select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+ <xsl:with-param name="ResourceUri" select="$ResourceUri"/>
+ <xsl:with-param name="Conformity" select="$Conformity"/>
+ <xsl:choose>
+ <xsl:when test="$ResourceType = 'service' and ($ServiceType = 'discovery' or $profile = $extended)">
+ <xsl:copy-of select="$ConstraintsRelatedToAccessAndUse"/>
+ </xsl:when>
+<!-- Distributions -->
+ <xsl:when test="$ResourceType = 'dataset' or $ResourceType = 'series'">
+<!-- Spatial representation type -->
+ <xsl:variable name="SpatialRepresentationType">
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode"/>
+ </xsl:variable>
+ <xsl:for-each select="gmd:distributionInfo/gmd:MD_Distribution">
+<!-- Encoding -->
+ <xsl:variable name="Encoding">
+ <xsl:apply-templates select="gmd:distributionFormat/gmd:MD_Format/gmd:name/*"/>
+ </xsl:variable>
+<!-- Resource locators (access / download URLs) -->
+ <xsl:for-each select="gmd:transferOptions/*/gmd:onLine/*">
+ <xsl:variable name="function" select="gmd:function/gmd:CI_OnLineFunctionCode/@codeListValue"/>
+ <xsl:variable name="Title">
+ <xsl:for-each select="gmd:name">
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:variable name="Description">
+ <xsl:for-each select="gmd:description">
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:variable name="TitleAndDescription">
+ <xsl:for-each select="gmd:name/gco:CharacterString">
+ </xsl:for-each>
+ <xsl:for-each select="gmd:description/gco:CharacterString">
+ <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:description>
+ </xsl:for-each>
+ <xsl:copy-of select="$Title"/>
+ <xsl:copy-of select="$Description"/>
+ </xsl:variable>
+ <xsl:choose>
+ <xsl:when test="$function = 'download' or $function = 'offlineAccess' or $function = 'order'">
+ <dcat:distribution>
+ <dcat:Distribution>
+<!-- Title and description -->
+ <xsl:copy-of select="$TitleAndDescription"/>
+<!-- Access URL -->
+ <xsl:for-each select="gmd:linkage/gmd:URL">
+ <dcat:accessURL rdf:resource="{.}"/>
+ </xsl:for-each>
+<!-- Constraints related to access and use -->
+<!-- Spatial representation type (tentative) -->
+ <xsl:copy-of select="$SpatialRepresentationType"/>
+<!-- Encoding -->
+ <xsl:copy-of select="$Encoding"/>
+<!-- Resource character encoding -->
+ <xsl:copy-of select="$ResourceCharacterEncoding"/>
+ </xsl:if>
+ </dcat:Distribution>
+ </dcat:distribution>
+ </xsl:when>
+ <xsl:when test="$function = 'information' or $function = 'search'">
+<!-- ?? Should foaf:page be detailed with title, description, etc.? -->
+ <foaf:page>
+ <foaf:Document rdf:about="{.}">
+ </foaf:Document>
+ </foaf:page>
+ </xsl:for-each>
+ </xsl:when>
+<!-- ?? Should dcat:landingPage be detailed with title, description, etc.? -->
+ <xsl:otherwise>
+ <dcat:landingPage>
+ </foaf:Document>
+ </dcat:landingPage>
+ </xsl:for-each>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:when>
+ </xsl:choose>
+<!-- Responsible organisation -->
+ <xsl:for-each select="gmd:identificationInfo/*/gmd:pointOfContact">
+ </xsl:for-each>
+ <xsl:apply-templates select="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
+ </xsl:param>
+ <xsl:choose>
+ <xsl:choose>
+ <xsl:when test="$MetadataUri != ''">
+ <rdf:Description rdf:about="{$MetadataUri}">
+ <rdf:type rdf:resource="{$dcat}CatalogRecord"/>
+ <foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
+ <xsl:copy-of select="$MetadataDescription"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:if test="normalize-space($MetadataDescription)">
+ <rdf:Description>
+ </xsl:if>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:if>
+ <rdf:Description rdf:about="{$ResourceUri}">
+ <xsl:copy-of select="$ResourceDescription"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <rdf:Description>
+ <foaf:isPrimaryTopicOf>
+ <rdf:Description>
+ </foaf:isPrimaryTopicOf>
+ </xsl:if>
+ </xsl:otherwise>
+ </xsl:choose>
+ <xsl:if test="$profile = $extended and $ResourceUri != '' and $Conformity != ''">
+ <xsl:copy-of select="$Conformity"/>
+ </xsl:if>
+ </xsl:template>
+ Templates for specific metadata elements
+ <xsl:template name="UniqueResourceIdentifier" match="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*">
+ <xsl:param name="ns">
+ <xsl:value-of select="gmd:codeSpace/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:param name="code">
+ <xsl:value-of select="gmd:code/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:param name="id">
+ <xsl:choose>
+ <xsl:when test="$ns != ''">
+ <xsl:choose>
+ <xsl:when test="substring($ns,string-length($ns),1) = '/'">
+ <xsl:value-of select="concat($ns,$code)"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat($ns,'/',$code)"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$code"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="idDatatypeURI">
+ <xsl:choose>
+ <xsl:when test="starts-with($id, 'http://') or starts-with($id, 'https://') or starts-with($id, 'urn:')">
+ <xsl:value-of select="concat($xsd,'anyURI')"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat($xsd,'string')"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <dct:identifier rdf:datatype="{$idDatatypeURI}"><xsl:value-of select="$id"/></dct:identifier>
+ </xsl:template>
+<!-- Responsible Organisation -->
+ <xsl:template name="ResponsibleOrganisation" match="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
+ <xsl:template name="ResponsibleOrganisation" match="gmd:CI_ResponsibleParty">
+ <xsl:param name="MetadataLanguage"/>
+ <xsl:param name="ResourceType"/>
+ <xsl:param name="role">
+ <xsl:value-of select="gmd:role/gmd:CI_RoleCode/@codeListValue"/>
+ </xsl:param>
+ <xsl:param name="ResponsiblePartyRole">
+ <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/',$role)"/>
+ </xsl:param>
+ <xsl:param name="IndividualURI">
+ <xsl:value-of select="normalize-space(gmd:individualName/*/@xlink:href)"/>
+ </xsl:param>
+ <xsl:param name="IndividualName">
+ <xsl:value-of select="normalize-space(gmd:individualName/*)"/>
+ </xsl:param>
+ <xsl:param name="IndividualName-FOAF">
+ <xsl:for-each select="gmd:individualName">
+ <foaf:name xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(*[self::gco:CharacterString|gmx:Anchor])"/></foaf:name>
+ <xsl:with-param name="term">foaf:name</xsl:with-param>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="IndividualName-vCard">
+ <vcard:fn xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(*[self::gco:CharacterString|gmx:Anchor])"/></vcard:fn>
+ <xsl:with-param name="term">vcard:fn</xsl:with-param>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="OrganisationURI">
+ <xsl:value-of select="normalize-space(gmd:organisationName/*/@xlink:href)"/>
+ </xsl:param>
+ <xsl:param name="URI">
+ <xsl:choose>
+ <xsl:when test="$IndividualURI != ''">
+ <xsl:value-of select="$IndividualURI"/>
+ </xsl:when>
+ <xsl:when test="$OrganisationURI != ''">
+ <xsl:value-of select="$OrganisationURI"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="OrganisationName">
+ <xsl:value-of select="normalize-space(gmd:organisationName/*)"/>
+ </xsl:param>
+ <xsl:param name="OrganisationName-FOAF">
+ <xsl:for-each select="gmd:organisationName">
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="OrganisationName-vCard">
+ <vcard:organization-name xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(*[self::gco:CharacterString|gmx:Anchor])"/></vcard:organization-name>
+ <xsl:with-param name="term">vcard:organization-name</xsl:with-param>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="OrganisationNameAsIndividualName-vCard">
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Email">
+ <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/*">
+ <foaf:mbox rdf:resource="mailto:{normalize-space(.)}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Email-vCard">
+ <vcard:hasEmail rdf:resource="mailto:{normalize-space(.)}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="URL">
+ <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:onlineResource/gmd:CI_OnlineResource/gmd:linkage/gmd:URL">
+ <foaf:workplaceHomepage rdf:resource="{normalize-space(.)}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="URL-vCard">
+ <vcard:hasURL rdf:resource="{normalize-space(.)}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Telephone">
+ <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:phone/gmd:CI_Telephone/gmd:voice/*">
+ <foaf:phone rdf:resource="tel:+{translate(translate(translate(translate(translate(normalize-space(.),' ',''),'(',''),')',''),'+',''),'.','')}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Telephone-vCard">
+ <vcard:hasTelephone rdf:resource="tel:+{translate(translate(translate(translate(translate(normalize-space(.),' ',''),'(',''),')',''),'+',''),'.','')}"/>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Address">
+ <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address">
+ <xsl:variable name="deliveryPoint" select="normalize-space(gmd:deliveryPoint/*)"/>
+ <xsl:variable name="city" select="normalize-space(gmd:city/*)"/>
+ <xsl:variable name="administrativeArea" select="normalize-space(gmd:administrativeArea/*)"/>
+ <xsl:variable name="postalCode" select="normalize-space(gmd:postalCode/*)"/>
+ <xsl:variable name="country" select="normalize-space(gmd:country/*)"/>
+ <xsl:if test="$deliveryPoint != '' or $city != '' or $administrativeArea != '' or $postalCode != '' or $country != ''">
+ <locn:address>
+ <locn:Address>
+ <xsl:if test="$deliveryPoint != ''">
+ <locn:thoroughfare><xsl:value-of select="$deliveryPoint"/></locn:thoroughfare>
+ </xsl:if>
+ <xsl:if test="$city != ''">
+ <locn:postName><xsl:value-of select="$city"/></locn:postName>
+ </xsl:if>
+ <xsl:if test="$administrativeArea != ''">
+ <locn:adminUnitL2><xsl:value-of select="$administrativeArea"/></locn:adminUnitL2>
+ </xsl:if>
+ <xsl:if test="$postalCode != ''">
+ <locn:postCode><xsl:value-of select="$postalCode"/></locn:postCode>
+ </xsl:if>
+ <xsl:if test="$country != ''">
+ <locn:adminUnitL1><xsl:value-of select="$country"/></locn:adminUnitL1>
+ </xsl:if>
+ </locn:Address>
+ </locn:address>
+ </xsl:if>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="Address-vCard">
+ <vcard:hasAddress>
+ <vcard:Address>
+ <vcard:street-address><xsl:value-of select="$deliveryPoint"/></vcard:street-address>
+ </xsl:if>
+ <vcard:locality><xsl:value-of select="$city"/></vcard:locality>
+ </xsl:if>
+ <vcard:region><xsl:value-of select="$administrativeArea"/></vcard:region>
+ </xsl:if>
+ <vcard:postal-code><xsl:value-of select="$postalCode"/></vcard:postal-code>
+ </xsl:if>
+ <vcard:country-name><xsl:value-of select="$country"/></vcard:country-name>
+ </xsl:if>
+ </vcard:Address>
+ </vcard:hasAddress>
+ </xsl:if>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:param name="ROInfo">
+ <xsl:variable name="info">
+ <xsl:choose>
+ <xsl:when test="$IndividualName != ''">
+ <rdf:type rdf:resource="{$foaf}Person"/>
+ </xsl:when>
+ <xsl:when test="$OrganisationName != ''">
+ <rdf:type rdf:resource="{$foaf}Organization"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <rdf:type rdf:resource="{$foaf}Agent"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ <xsl:if test="$IndividualName != ''">
+ <xsl:value-of select="$IndividualName"/>
+ </foaf:name>
+ <xsl:copy-of select="$IndividualName-FOAF"/>
+ <xsl:if test="$OrganisationName != ''">
+ <org:memberOf>
+ <xsl:choose>
+ <foaf:Organization rdf:about="{$OrganisationURI}">
+ <foaf:name xml:lang="{$MetadataLanguage}"><xsl:value-of select="$OrganisationName"/></foaf:name>
+ <xsl:copy-of select="$OrganisationName-FOAF"/>
+ </foaf:Organization>
+ </xsl:when>
+ <xsl:otherwise>
+ <foaf:Organization>
+ </xsl:otherwise>
+ </xsl:choose>
+ </org:memberOf>
+ </xsl:if>
+ </xsl:if>
+ <xsl:if test="$IndividualName = '' and $OrganisationName != ''">
+ <xsl:value-of select="$OrganisationName"/>
+ </foaf:name>
+ </xsl:if>
+ <xsl:copy-of select="$Telephone"/>
+ <xsl:copy-of select="$Email"/>
+ <xsl:copy-of select="$URL"/>
+ <xsl:copy-of select="$Address"/>
+ <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString">
+ <foaf:mbox rdf:resource="mailto:{.}"/>
+ </xsl:for-each>
+<!-- ?? Should another property be used instead? E.g., foaf:homepage? -->
+ <foaf:workplaceHomepage rdf:resource="{.}"/>
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:choose>
+ <rdf:Description rdf:resource="{$IndividualURI}">
+ <xsl:copy-of select="$info"/>
+ </xsl:when>
+ <rdf:Description rdf:resource="{$OrganisationURI}">
+ </xsl:when>
+ <xsl:otherwise>
+ <rdf:Description>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="ResponsibleParty">
+ <xsl:choose>
+ <rdf:type rdf:resource="{$vcard}Individual"/>
+ </xsl:when>
+ <rdf:type rdf:resource="{$vcard}Organization"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <rdf:type rdf:resource="{$vcard}Kind"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </vcard:fn>
+ <xsl:copy-of select="$IndividualName-vCard"/>
+ </xsl:if>
+ <xsl:if test="$IndividualName != '' and $OrganisationName != ''">
+ </vcard:organization-name>
+ <xsl:copy-of select="$OrganisationName-vCard"/>
+ </xsl:if>
+ </vcard:fn>
+ <xsl:copy-of select="$OrganisationNameAsIndividualName-vCard"/>
+ </xsl:if>
+ <xsl:copy-of select="$Telephone-vCard"/>
+ <xsl:copy-of select="$Email-vCard"/>
+ <xsl:copy-of select="$URL-vCard"/>
+ <xsl:copy-of select="$Address-vCard"/>
+ <vcard:hasEmail rdf:resource="mailto:{.}"/>
+ </xsl:for-each>
+ <vcard:hasURL rdf:resource="{.}"/>
+ </xsl:for-each>
+ </xsl:variable>
+ <xsl:choose>
+ </xsl:when>
+ </xsl:when>
+ <xsl:otherwise>
+ <rdf:Description>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:choose>
+ <xsl:when test="$role = 'resourceProvider'">
+ <schema:provider>
+ <xsl:copy-of select="$ROInfo"/>
+ </schema:provider>
+ </xsl:when>
+ <xsl:when test="$role = 'custodian'">
+ <rdarole:custodian>
+ </rdarole:custodian>
+ </xsl:when>
+ <xsl:when test="$role = 'owner' and $profile = $extended">
+ <dct:rightsHolder>
+ </dct:rightsHolder>
+ </xsl:when>
+ <xsl:when test="$role = 'user'">
+ <prov:wasUsedBy>
+ <prov:Activity>
+ <prov:wasAssociatedWith>
+ </prov:wasAssociatedWith>
+ </prov:Activity>
+ </prov:wasUsedBy>
+ </xsl:when>
+ <xsl:when test="$role = 'distributor'">
+ <rdarole:distributor>
+ </rdarole:distributor>
+ </xsl:when>
+ <xsl:when test="$role = 'originator' and $profile = $extended">
+ <dct:creator>
+ </dct:creator>
+ </xsl:when>
+ <xsl:when test="$role = 'pointOfContact' and $ResourceType != 'service'">
+ <dcat:contactPoint>
+ <xsl:copy-of select="$ResponsibleParty"/>
+ </dcat:contactPoint>
+ </xsl:when>
+ <xsl:when test="$role = 'principalInvestigator'">
+ <dct:contributor>
+ </dct:contributor>
+ </xsl:when>
+ <xsl:when test="$role = 'processor'">
+ <prov:entityOfInfluence>
+ <prov:Derivation>
+ <prov:hadActivity>
+ <prov:Activity>
+ </prov:Activity>
+ </prov:hadActivity>
+ </prov:Derivation>
+ </prov:entityOfInfluence>
+ </xsl:when>
+ <xsl:when test="$role = 'publisher'">
+ <dct:publisher>
+ </dct:publisher>
+ </xsl:when>
+ <xsl:when test="$role = 'author' and $profile = $extended">
+ <dct:creator>
+ </dct:creator>
+ </xsl:when>
+ </xsl:choose>
+ <prov:qualifiedAttribution>
+ <prov:Attribution>
+ <prov:agent>
+ </prov:agent>
+ <dct:type rdf:resource="{$ResponsiblePartyRole}"/>
+ </prov:Attribution>
+ </prov:qualifiedAttribution>
+ </xsl:if>
+ </xsl:template>
+<!-- Metadata point of contact -->
+ <xsl:template name="MetadataPointOfContact" match="gmd:contact/gmd:CI_ResponsibleParty">
+ <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/','pointOfContact')"/>
+ </xsl:param>
+ <xsl:value-of select="gmd:organisationName/gco:CharacterString"/>
+ </xsl:param>
+ <vcard:Kind>
+ </xsl:for-each>
+ </vcard:Kind>
+ </xsl:param>
+ <prov:agent>
+ </prov:agent>
+ </xsl:if>
+ </xsl:template>
+<!-- Resource locator -->
+<!-- Old version, applied to the resource (not to the resource distribution)
+ <xsl:template name="ResourceLocator" match="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+ <xsl:choose>
+ <dcat:landingPage rdf:resource="{gmd:URL}"/>
+ </xsl:when>
+ <foaf:homepage rdf:resource="{gmd:URL}"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="ResourceLocator" match="gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+ <xsl:choose>
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="../gmd:description/gco:CharacterString"/></dct:title>
+ <dcat:accessURL rdf:resource="{gmd:URL}"/>
+ </xsl:when>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:template>
+<!-- Coupled resource -->
+ <xsl:template name="CoupledResource" match="gmd:identificationInfo[1]/*/srv:operatesOn">
+ <xsl:param name="href" select="@xlink:href"/>
+ <xsl:choose>
+ <xsl:when test="$CoupledResourceLookUp = 'enabled' and $href != '' and (starts-with($href, 'http://') or starts-with($href, 'https://'))">
+ <xsl:value-of select="document($href)//gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString"/>
+ </xsl:when>
+ <xsl:when test="*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString != ''">
+ <xsl:value-of select="*/gmd:citation/*/gmd:identifier/*/gmd:code/gco:CharacterString"/>
+ </xsl:when>
+ <xsl:when test="@uuidref != ''">
+ <xsl:value-of select="@uuidref"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="codespace">
+ <xsl:choose>
+ <xsl:value-of select="document($href)//gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString"/>
+ </xsl:when>
+ <xsl:when test="*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString != ''">
+ <xsl:value-of select="*/gmd:citation/*/gmd:identifier/*/gmd:codeSpace/gco:CharacterString"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="resID" select="concat($codespace, $code)"/>
+ <xsl:param name="uriref" select="@uriref"/>
+ <xsl:choose>
+<!-- The use of @uriref is still under discussion by the INSPIRE MIG. -->
+ <xsl:when test="$uriref != ''">
+ <dct:hasPart rdf:resource="{@uriref}"/>
+ </xsl:when>
+ <xsl:when test="$code != ''">
+ <xsl:choose>
+ <xsl:when test="starts-with($code, 'http://') or starts-with($code, 'https://')">
+ <dct:hasPart rdf:resource="{$code}"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:hasPart rdf:parseType="Resource">
+ <xsl:choose>
+ <xsl:when test="starts-with($resID, 'http://') or starts-with($resID, 'https://')">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$resID"/></dct:identifier>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:identifier rdf:datatype="{$xsd}string"><xsl:value-of select="$resID"/></dct:identifier>
+ </xsl:otherwise>
+ </xsl:choose>
+ <xsl:if test="$href != '' and $href != '' and (starts-with($href, 'http://') or starts-with($href, 'https://'))">
+ <dcat:CatalogRecord rdf:about="{$href}"/>
+ </xsl:if>
+ </dct:hasPart>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:template>
+<!-- Spatial data service type -->
+ <xsl:template match="gmd:identificationInfo/*/srv:serviceType">
+ <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{gco:LocalName}"/>
+ </xsl:template>
+ <xsl:template name="Conformity" match="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+ <xsl:param name="ResourceUri"/>
+ <xsl:param name="Conformity"/>
+ </dct:title>
+ </xsl:variable>
+ <xsl:choose>
+ </xsl:when>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:when>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <xsl:if test="../../gmd:pass/gco:Boolean = 'true'">
+ <xsl:choose>
+ <dct:conformsTo rdf:resource="{../@xlink:href}"/>
+ <dct:conformsTo>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:otherwise>
+ </dct:conformsTo>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:if>
+ <xsl:if test="$Conformity != '' and $ResourceUri = ''">
+ </xsl:if>
+ <xsl:choose>
+ <wdrs:describedby>
+ <earl:Assertion>
+ <earl:test>
+ </earl:test>
+ <earl:result>
+ <earl:TestResult>
+ </earl:result>
+ </earl:Assertion>
+ </wdrs:describedby>
+ </xsl:when>
+ <xsl:otherwise>
+ <earl:Assertion>
+ </earl:test>
+ <earl:result>
+ <earl:TestResult>
+ </earl:result>
+ </earl:Assertion>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:if>
+ </xsl:template>
+<!-- Geographic extent -->
+ <xsl:template name="GeographicExtent" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
+ <xsl:otherwise>
+ <dct:spatial>
+ <dct:Location>
+ <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></rdfs:label>
+ </xsl:for-each>
+ <xsl:apply-templates select="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
+ <xsl:apply-templates select="gmd:EX_GeographicBoundingBox"/>
+ </dct:Location>
+ </dct:spatial>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+<!-- Geographic identifier -->
+ <xsl:template name="GeographicIdentifier" match="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
+ <xsl:param name="GeoCode" select="gmd:code/*[self::gco:CharacterString|self::gmx:Anchor/@xlink:href]"/>
+ <xsl:param name="GeoURI" select="gmd:code/gmx:Anchor/@xlink:href"/>
+ <xsl:param name="GeoCode">
+ <xsl:choose>
+ <xsl:when test="gmd:code/gco:CharacterString">
+ </xsl:when>
+ <xsl:when test="gmd:code/gmx:Anchor">
+ <xsl:value-of select="gmd:code/gmx:Anchor/@xlink:href"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:param>
+ <xsl:param name="GeoURI">
+ <xsl:if test="starts-with($GeoCode,'http://') or starts-with($GeoCode,'https://')">
+ <xsl:value-of select="$GeoCode"/>
+ </xsl:if>
+ </xsl:param>
+ <xsl:param name="GeoURN">
+ <xsl:if test="starts-with($GeoCode,'urn:')">
+ </xsl:if>
+ </xsl:param>
+ <xsl:choose>
+ <xsl:when test="$GeoURI != ''">
+ <xsl:choose>
+ <xsl:when test="gmd:EX_GeographicBoundingBox">
+ <dct:spatial>
+ <dct:Location rdf:about="{$GeoURI}">
+ <xsl:if test="$GeoCode != ''">
+ <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="$GeoCode"/></rdfs:label>
+ </xsl:if>
+ </dct:Location>
+ </dct:spatial>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:spatial rdf:resource="{$GeoURI}"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ <xsl:when test="$GeoCode != ''">
+ <dct:spatial rdf:parseType="Resource">
+ <rdfs:seeAlso rdf:parseType="Resource">
+ <xsl:choose>
+ <xsl:when test="$GeoURN != ''">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$GeoURN"/></dct:identifier>
+ </xsl:when>
+ <xsl:otherwise>
+ <skos:prefLabel xml:lang="{$MetadataLanguage}">
+ </skos:prefLabel>
+ </xsl:otherwise>
+ </xsl:choose>
+ <xsl:for-each select="gmd:authority/gmd:CI_Citation">
+ <skos:inScheme>
+ <skos:ConceptScheme>
+ </dct:title>
+ </skos:ConceptScheme>
+ </skos:inScheme>
+ </xsl:for-each>
+ </rdfs:seeAlso>
+ </dct:spatial>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:template>
+<!-- Geographic bounding box -->
+ <xsl:template name="GeographicBoundingBox" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox">
+ <xsl:template name="GeographicBoundingBox" match="gmd:EX_GeographicBoundingBox">
+ <xsl:param name="north" select="gmd:northBoundLatitude/gco:Decimal"/>
+ <xsl:param name="east" select="gmd:eastBoundLongitude/gco:Decimal"/>
+ <xsl:param name="south" select="gmd:southBoundLatitude/gco:Decimal"/>
+ <xsl:param name="west" select="gmd:westBoundLongitude/gco:Decimal"/>
+<!-- Bbox as a dct:Box -->
+<!-- Need to check whether this is correct - in particular, the "projection" parameter -->
+ <xsl:param name="DCTBox">northlimit=<xsl:value-of select="$north"/>; eastlimit=<xsl:value-of select="$east"/>; southlimit=<xsl:value-of select="$south"/>; westlimit=<xsl:value-of select="$west"/>; projection=EPSG:<xsl:value-of select="$srid"/></xsl:param>
+<!-- Bbox as GML (GeoSPARQL) -->
+ <xsl:param name="GMLLiteral">
+ <xsl:choose>
+ <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LonLat'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LatLon'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/></gml:upperCorner></gml:Envelope></xsl:when>
+ </xsl:choose>
+ </xsl:param>
+<!-- Bbox as WKT (GeoSPARQL) -->
+ <xsl:param name="WKTLiteral">
+ <xsl:choose>
+ <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'">POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LonLat'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LatLon'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>))</xsl:when>
+ </xsl:choose>
+ </xsl:param>
+<!-- Bbox as GeoJSON -->
+ <xsl:param name="GeoJSONLiteral">{"type":"Polygon","crs":{"type":"name","properties":{"name":"<xsl:value-of select="$SrsUrn"/>"}},"coordinates":[[[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>]]]}</xsl:param>
+<!-- Recommended geometry encodings -->
+ <locn:geometry rdf:datatype="{$gsp}wktLiteral"><xsl:value-of select="$WKTLiteral"/></locn:geometry>
+ <locn:geometry rdf:datatype="{$gsp}gmlLiteral"><xsl:value-of select="$GMLLiteral"/></locn:geometry>
+<!-- Additional geometry encodings -->
+ <locn:geometry rdf:datatype="{$geojsonMediaTypeUri}"><xsl:value-of select="$GeoJSONLiteral"/></locn:geometry>
+ <locn:geometry rdf:datatype="{$dct}Box"><xsl:value-of select="$DCTBox"/></locn:geometry>
+ </dct:spatial>
+ </xsl:template>
+ <xsl:template name="TemporalExtent" match="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent">
+ <xsl:for-each select="gmd:extent/gml:TimeInstant|gmd:extent/gml:TimePeriod">
+ <xsl:if test="local-name(.) = 'TimeInstant' or ( local-name(.) = 'TimePeriod' and gml:beginPosition and gml:endPosition )">
+ <xsl:variable name="dctperiod">
+ <xsl:choose>
+ <xsl:when test="local-name(.) = 'TimeInstant'">start=<xsl:value-of select="gml:timePosition"/>; end=<xsl:value-of select="gml:timePosition"/></xsl:when>
+ <xsl:otherwise>start=<xsl:value-of select="gml:beginPosition"/>; end=<xsl:value-of select="gml:endPosition"/></xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <xsl:variable name="dateStart">
+ <xsl:choose>
+ <xsl:when test="local-name(.) = 'TimeInstant'"><xsl:value-of select="gml:timePosition"/></xsl:when>
+ <xsl:otherwise><xsl:value-of select="gml:beginPosition"/></xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <xsl:variable name="dateEnd">
+ <xsl:choose>
+ <xsl:otherwise><xsl:value-of select="gml:endPosition"/></xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <dct:temporal>
+ <dct:PeriodOfTime>
+ <schema:startDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateStart"/></schema:startDate>
+ <schema:endDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateEnd"/></schema:endDate>
+ </dct:PeriodOfTime>
+ </dct:temporal>
+ </xsl:if>
+ </xsl:for-each>
+ </xsl:template>
+<!-- Dates of publication, last revision, creation -->
+ <xsl:template name="ResourceDates" match="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation">
+ </xsl:template>
+<!-- Generic date template -->
+ <xsl:template name="Dates" match="gmd:date/gmd:CI_Date">
+ <xsl:param name="date">
+ <xsl:value-of select="gmd:date/gco:Date"/>
+ </xsl:param>
+ <xsl:param name="type">
+ <xsl:value-of select="gmd:dateType/gmd:CI_DateTypeCode/@codeListValue"/>
+ </xsl:param>
+ <xsl:choose>
+ <xsl:when test="$type = 'publication'">
+ <dct:issued rdf:datatype="{$xsd}date">
+ <xsl:value-of select="$date"/>
+ </dct:issued>
+ </xsl:when>
+ <xsl:when test="$type = 'revision'">
+ </dct:modified>
+ </xsl:when>
+ <xsl:when test="$type = 'creation' and $profile = $extended">
+ <dct:created rdf:datatype="{$xsd}date">
+ </dct:created>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="ConstraintsRelatedToAccesAndUse" match="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
+ <xsl:param name="LimitationsOnPublicAccess">
+ <xsl:value-of select="gmd:MD_LegalConstraints/gmd:otherConstraints/gco:CharacterString"/>
+ </xsl:param>
+ <xsl:for-each select="gmd:useLimitation">
+ <xsl:choose>
+<!-- In case the rights/licence URL IS NOT provided -->
+ <xsl:when test="gco:CharacterString">
+ <dct:license>
+ <dct:LicenseDocument>
+ </dct:LicenseDocument>
+ </dct:license>
+ <dct:rights>
+ <dct:RightsStatement>
+ </dct:RightsStatement>
+ </dct:rights>
+ </xsl:when>
+<!-- In case the rights/licence URL IS provided -->
+ <xsl:when test="gmx:Anchor/@xlink:href">
+ <dct:license rdf:resource="{gmx:Anchor/@xlink:href}"/>
+ <dct:license>
+ <dct:LicenseDocument rdf:about="{gmx:Anchor/@xlink:href}">
+ <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gmx:Anchor)"/></rdfs:label>
+ </dct:license>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ <xsl:for-each select="gmd:otherConstraints">
+ <dct:accessRights>
+ </dct:accessRights>
+ </xsl:if>
+ </xsl:for-each>
+ <xsl:for-each select="gmd:accessConstraints">
+ <dct:accessRights rdf:resource="{$MD_RestrictionCode}_{gmd:MD_RestrictionCode/@codeListValue}"/>
+ </xsl:for-each>
+ <xsl:for-each select="gmd:classification">
+ <dct:accessRights rdf:resource="{$MD_ClassificationCode}_{gmd:MD_ClassificationCode/@codeListValue}"/>
+ </xsl:for-each>
+ </xsl:template>
+<!-- Keyword -->
+ <xsl:template name="Keyword" match="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
+ <xsl:param name="ServiceType"/>
+ <xsl:param name="OriginatingControlledVocabulary">
+ <xsl:for-each select="gmd:thesaurusName/gmd:CI_Citation">
+ </dct:title>
+ </xsl:for-each>
+ <xsl:value-of select="normalize-space(gco:CharacterString)"/>
+ </dct:title>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:param>
+ <xsl:for-each select="gmd:keyword">
+ <xsl:variable name="lckw" select="translate(gco:CharacterString,$uppercase,$lowercase)"/>
+ <xsl:choose>
+ <xsl:when test="normalize-space($OriginatingControlledVocabulary) = '' and not( gmx:Anchor/@xlink:href and ( starts-with(gmx:Anchor/@xlink:href, 'http://') or starts-with(gmx:Anchor/@xlink:href, 'https://') ) )">
+ <xsl:choose>
+ <dc:subject xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></dc:subject>
+ <xsl:with-param name="term">dc:subject</xsl:with-param>
+ </xsl:if>
+ </xsl:when>
+ <xsl:otherwise>
+ <dcat:keyword xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></dcat:keyword>
+ <xsl:with-param name="term">dcat:keyword</xsl:with-param>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:choose>
+<!-- In case the concept's URI is NOT provided -->
+ <xsl:choose>
+ <xsl:when test="$ResourceType != 'service'">
+ <dcat:theme rdf:parseType="Resource">
+ </skos:prefLabel>
+ <xsl:with-param name="term">skos:prefLabel</xsl:with-param>
+ <skos:inScheme>
+ <xsl:copy-of select="$OriginatingControlledVocabulary"/>
+ </skos:inScheme>
+ </dcat:theme>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:subject rdf:parseType="Resource">
+ </skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </dct:subject>
+ </xsl:if>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+<!-- In case the concept's URI is provided -->
+ <xsl:choose>
+ <dcat:theme rdf:resource="{gmx:Anchor/@xlink:href}"/>
+ <skos:Concept rdf:about="{gmx:Anchor/@xlink:href}">
+ <xsl:value-of select="gmx:Anchor"/>
+ </skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </skos:Concept>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:subject rdf:resource="{gmx:Anchor/@xlink:href}"/>
+ </xsl:if>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:template>
+ <xsl:template name="TopicCategory" match="gmd:identificationInfo/*/gmd:topicCategory">
+ <xsl:param name="TopicCategory"><xsl:value-of select="normalize-space(gmd:MD_TopicCategoryCode)"/></xsl:param>
+ <xsl:if test="$TopicCategory != ''">
+ <dct:subject rdf:resource="{$TopicCategoryCodelistUri}/{$TopicCategory}"/>
+ </xsl:if>
+ </xsl:template>
+<!-- Spatial resolution (unstable - to be replaced with a standard-based solution, when available) -->
+ <xsl:template name="SpatialResolution" match="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution">
+<!-- dcat:granularity is deprecated -->
+ <xsl:for-each select="gmd:distance/gco:Distance">
+ <dcat:granularity rdf:datatype="{$xsd}string"><xsl:value-of select="."/> <xsl:value-of select="@uom"/></dcat:granularity>
+ </xsl:for-each>
+ <xsl:for-each select="gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator">
+ <dcat:granularity rdf:datatype="{$xsd}string">1/<xsl:value-of select="gco:Integer"/></dcat:granularity>
+ </xsl:for-each>
+ <xsl:variable name="UoM">
+ <xsl:choose>
+ <xsl:when test="@uom = 'EPSG::9001' or @uom = 'urn:ogc:def:uom:EPSG::9001' or @uom = 'urn:ogc:def:uom:UCUM::m' or @uom = 'urn:ogc:def:uom:OGC::m'">
+ <xsl:value-of select="concat('m',' (', at uom,')')"/>
+ </xsl:when>
+ <xsl:when test="@uom = 'EPSG::9002' or @uom = 'urn:ogc:def:uom:EPSG::9002' or @uom = 'urn:ogc:def:uom:UCUM::[ft_i]' or @uom = 'urn:ogc:def:uom:OGC::[ft_i]'">
+ <xsl:value-of select="concat('ft',' (', at uom,')')"/>
+ </xsl:when>
+<!-- To be completed -->
+ <xsl:otherwise>
+ <xsl:value-of select="@uom"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <rdfs:comment xml:lang="en">Spatial resolution (distance): <xsl:value-of select="."/> <xsl:value-of select="$UoM"/></rdfs:comment>
+ </xsl:for-each>
+ <rdfs:comment xml:lang="en">Spatial resolution (equivalent scale): 1:<xsl:value-of select="gco:Integer"/></rdfs:comment>
+ </xsl:for-each>
+ </xsl:template>
+<!-- Character encoding -->
+ <xsl:template name="CharacterEncoding" match="gmd:characterSet/gmd:MD_CharacterSetCode">
+ <xsl:variable name="CharSetCode">
+ <xsl:choose>
+ <xsl:when test="@codeListValue = 'ucs2'">
+ <xsl:text>ISO-10646-UCS-2</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'ucs4'">
+ <xsl:text>ISO-10646-UCS-4</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'utf7'">
+ <xsl:text>UTF-7</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'utf8'">
+ <xsl:text>UTF-8</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'utf16'">
+ <xsl:text>UTF-16</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part1'">
+ <xsl:text>ISO-8859-1</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part2'">
+ <xsl:text>ISO-8859-2</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part3'">
+ <xsl:text>ISO-8859-3</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part4'">
+ <xsl:text>ISO-8859-4</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part5'">
+ <xsl:text>ISO-8859-5</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part6'">
+ <xsl:text>ISO-8859-6</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part7'">
+ <xsl:text>ISO-8859-7</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part8'">
+ <xsl:text>ISO-8859-8</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part9'">
+ <xsl:text>ISO-8859-9</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part10'">
+ <xsl:text>ISO-8859-10</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part11'">
+ <xsl:text>ISO-8859-11</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part12'">
+ <xsl:text>ISO-8859-12</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part13'">
+ <xsl:text>ISO-8859-13</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part14'">
+ <xsl:text>ISO-8859-14</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part15'">
+ <xsl:text>ISO-8859-15</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = '8859part16'">
+ <xsl:text>ISO-8859-16</xsl:text>
+ </xsl:when>
+<!-- Mapping to be verified: multiple candidates are available in the IANA register for jis -->
+ <xsl:when test="@codeListValue = 'jis'">
+ <xsl:text>JIS_Encoding</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'shiftJIS'">
+ <xsl:text>Shift_JIS</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'eucJP'">
+ <xsl:text>EUC-JP</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'usAscii'">
+ <xsl:text>US-ASCII</xsl:text>
+ </xsl:when>
+<!-- Mapping to be verified: multiple candidates are available in the IANA register ebcdic -->
+ <xsl:when test="@codeListValue = 'ebcdic'">
+ <xsl:text>IBM037</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'eucKR'">
+ <xsl:text>EUC-KR</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'big5'">
+ <xsl:text>Big5</xsl:text>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'GB2312'">
+ <xsl:text>GB2312</xsl:text>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:variable>
+ <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="$CharSetCode"/></cnt:characterEncoding>
+ <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="@codeListValue"/></cnt:characterEncoding>
+ </xsl:template>
+<!-- Encoding -->
+ <xsl:template name="Encoding" match="gmd:distributionFormat/gmd:MD_Format/gmd:name/*">
+ <xsl:choose>
+ <xsl:when test="@xlink:href and @xlink:href != ''">
+ <dct:format rdf:resource="{@xlink:href}"/>
+ <dct:format>
+ <rdf:Description rdf:about="{@xlink:href}">
+ <rdfs:label><xsl:value-of select="."/></rdfs:label>
+ </dct:format>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:format rdf:parseType="Resource">
+ </dct:format>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+<!-- Maintenance information -->
+ <xsl:template name="MaintenanceInformation" match="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode">
+<!-- The following parameter maps frequency codes used in ISO 19139 metadata to the corresponding ones of the Dublin Core Collection Description Frequency Vocabulary (when available). -->
+ <xsl:param name="FrequencyCodeURI">
+ <xsl:if test="@codeListValue != ''">
+ <xsl:choose>
+ <xsl:when test="@codeListValue = 'continual'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'continuous')"/>
+ <xsl:value-of select="concat($opfq,'CONT')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'daily'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'daily')"/>
+ <xsl:value-of select="concat($opfq,'DAILY')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'weekly'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'weekly')"/>
+ <xsl:value-of select="concat($opfq,'WEEKLY')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'fortnightly'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'biweekly')"/>
+ <xsl:value-of select="concat($opfq,'BIWEEKLY')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'monthly'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'monthly')"/>
+ <xsl:value-of select="concat($opfq,'MONTHLY')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'quarterly'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'quarterly')"/>
+ <xsl:value-of select="concat($opfq,'QUARTERLY')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'biannually'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'semiannual')"/>
+ <xsl:value-of select="concat($opfq,'ANNUAL_2')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'annually'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'annual')"/>
+ <xsl:value-of select="concat($opfq,'ANNUAL')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'asNeeded'">
+<!-- A mapping is missing in Dublin Core -->
+<!-- A mapping is missing in MDR Freq NAL -->
+ <xsl:value-of select="concat($MaintenanceFrequencyCodelistUri,'/', at codeListValue)"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'irregular'">
+<!-- DC Freq voc
+ <xsl:value-of select="concat($cldFrequency,'irregular')"/>
+ <xsl:value-of select="concat($opfq,'IRREG')"/>
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'notPlanned'">
+ </xsl:when>
+ <xsl:when test="@codeListValue = 'unknown'">
+<!-- INSPIRE Freq code list (not yet available)
+ <xsl:value-of select="concat($opfq,'UNKNOWN')"/>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:if>
+ </xsl:param>
+ <xsl:if test="$FrequencyCodeURI != ''">
+ <dct:accrualPeriodicity rdf:resource="{$FrequencyCodeURI}"/>
+ </xsl:if>
+ </xsl:template>
+<!-- Coordinate and temporal reference system (tentative) -->
+ <xsl:template name="ReferenceSystem" match="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
+ <xsl:param name="code" select="gmd:code/gco:CharacterString"/>
+ <xsl:param name="codespace" select="gmd:codeSpace/gco:CharacterString"/>
+ <xsl:param name="version" select="gmd:version/gco:CharacterString"/>
+ <xsl:choose>
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$code}">
+ <dct:type rdf:resource="{$INSPIREGlossaryUri}SpatialReferenceSystem"/>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:when test="starts-with($code, 'urn:')">
+ <xsl:variable name="srid">
+ <xsl:if test="starts-with(translate($code,$uppercase,$lowercase), translate($EpsgSrsBaseUrn,$uppercase,$lowercase))">
+ <xsl:value-of select="substring-after(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
+ </xsl:if>
+ </xsl:variable>
+ <xsl:variable name="sridVersion" select="substring-before(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
+ <xsl:choose>
+ <xsl:when test="$srid != '' and string(number($srid)) != 'NaN'">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$EpsgSrsBaseUri}/{$srid}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$code"/></dct:identifier>
+ <skos:inScheme>
+ <skos:ConceptScheme rdf:about="{$EpsgSrsBaseUri}">
+ <dct:title xml:lang="en"><xsl:value-of select="$EpsgSrsName"/></dct:title>
+ </skos:inScheme>
+ <xsl:if test="$sridVersion != ''">
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$sridVersion"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:if test="$codespace != ''">
+ <skos:inScheme>
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$codespace"/></dct:title>
+ </skos:inScheme>
+ </xsl:if>
+ <xsl:if test="$version != ''">
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$version"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:choose>
+ <xsl:when test="$code = number($code) and (translate($codespace,$uppercase,$lowercase) = 'epsg' or starts-with(translate($codespace,$uppercase,$lowercase),translate($EpsgSrsBaseUrn,$uppercase,$lowercase)))">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$EpsgSrsBaseUri}/{$code}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="concat($EpsgSrsBaseUrn,':',$version,':',$code)"/></dct:identifier>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'etrs89'">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$Etrs89Uri}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Etrs89Urn"/></dct:identifier>
+ <skos:prefLabel xml:lang="en">ETRS89 - European Terrestrial Reference System 1989</skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'crs84'">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$Crs84Uri}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Crs84Urn"/></dct:identifier>
+ <skos:prefLabel xml:lang="en">CRS84</skos:prefLabel>
+ <skos:inScheme>
+ <skos:ConceptScheme rdf:about="{$OgcSrsBaseUri}">
+ <dct:title xml:lang="en"><xsl:value-of select="$OgcSrsName"/></dct:title>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:otherwise>
+ <skos:prefLabel xml:lang="{$MetadataLanguage}"><xsl:value-of select="$code"/></skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="SpatialRepresentationType" match="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode">
+ <adms:representationTechnique rdf:resource="{$SpatialRepresentationTypeCodelistUri}/{@codeListValue}"/>
+ </xsl:template>
+<!-- Multilingual text -->
+ <xsl:template name="LocalisedString">
+ <xsl:param name="term"/>
+ <xsl:for-each select="gmd:PT_FreeText/*/gmd:LocalisedCharacterString">
+ <xsl:variable name="value" select="normalize-space(.)"/>
+ <xsl:variable name="langs">
+ <xsl:call-template name="Alpha3-to-Alpha2">
+ <xsl:with-param name="lang" select="translate(translate(@locale, $uppercase, $lowercase), '#', '')"/>
+ </xsl:call-template>
+ </xsl:variable>
+ <xsl:if test="$value != ''">
+ <xsl:element name="{$term}">
+ <xsl:attribute name="xml:lang"><xsl:value-of select="$langs"/></xsl:attribute>
+ <xsl:value-of select="$value"/>
+ </xsl:element>
+ </xsl:if>
+ </xsl:for-each>
+ </xsl:template>
+ <xsl:template name="Alpha3-to-Alpha2">
+ <xsl:param name="lang"/>
+ <xsl:choose>
+ <xsl:when test="$lang = 'bul'">
+ <xsl:text>bg</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'cze'">
+ <xsl:text>cs</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'dan'">
+ <xsl:text>da</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'ger'">
+ <xsl:text>de</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'gre'">
+ <xsl:text>el</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'eng'">
+ <xsl:text>en</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'spa'">
+ <xsl:text>es</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'est'">
+ <xsl:text>et</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'fin'">
+ <xsl:text>fi</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'fre'">
+ <xsl:text>fr</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'gle'">
+ <xsl:text>ga</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'hrv'">
+ <xsl:text>hr</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'ita'">
+ <xsl:text>it</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'lav'">
+ <xsl:text>lv</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'lit'">
+ <xsl:text>lt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'hun'">
+ <xsl:text>hu</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'mlt'">
+ <xsl:text>mt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'dut'">
+ <xsl:text>nl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'pol'">
+ <xsl:text>pl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'por'">
+ <xsl:text>pt</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'rum'">
+ <xsl:text>ru</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'slo'">
+ <xsl:text>sk</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'slv'">
+ <xsl:text>sl</xsl:text>
+ </xsl:when>
+ <xsl:when test="$lang = 'swe'">
+ <xsl:text>sv</xsl:text>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$lang"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+</xsl:transform>
More information about the Mapbender_commits
