[Mapbender-commits] r9815 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Tue Nov 14 07:46:40 PST 2017
Author: armin11
Date: 2017-11-14 07:46:40 -0800 (Tue, 14 Nov 2017)
New Revision: 9815
trunk/mapbender/http/classes/class_owsMetadataUrl.php
trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
trunk/mapbender/http/php/wfs.php
Enhancement of handling of unique resource identifier for inspire
Modified: trunk/mapbender/http/classes/class_owsMetadataUrl.php
--- trunk/mapbender/http/classes/class_owsMetadataUrl.php 2017-11-14 15:43:06 UTC (rev 9814)
+++ trunk/mapbender/http/classes/class_owsMetadataUrl.php 2017-11-14 15:46:40 UTC (rev 9815)
@@ -150,6 +150,7 @@
//add one entry foreach found element
$i = 0;
foreach ($this->urlArray as $url) {
+ //$e = new mb_exception($url);
//TODO: For wms:
//$xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setAttribute("type", $this->typeArray[$i]);
//$xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/Format')->item(0)->nodeValue = $this->formatArray[$i];
@@ -161,27 +162,38 @@
case "1.1.0":
$xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setAttribute("format", $this->formatArray[$i]);
- $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setValue = $this->urlArray[$i];
+ $textNode = $metadataUrlDomObject->createTextNode($this->urlArray[$i]);
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->nodeValue = "";
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->appendChild($textNode);
+//$e = new mb_exception("class_owsMetadataUrl: 1.1.0: value: ".$this->urlArray[$i]);
break;
case "1.0.0":
break;
case "2.0.0":
$xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setAttribute("xlink:href", $url);
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL')->item(0)->setAttribute("xlink:href", $this->urlArray[$i]);
break;
case "2.0.2":
break;
break;
case 'wms':
- $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/Format')->item(0)->setValue = $this->formatArray[$i];
- $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/OnlineResource')->item(0)->setAttribute("xlink:href", $url);
+ $textNode = $metadataUrlDomObject->createTextNode($this->formatArray[$i]);
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/Format')->item(0)->nodeValue = "";
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/Format')->item(0)->nodeValue->appendChild($textNode);
+ $xpathMetadataUrl->query('/mb:metadataurl/MetadataURL/OnlineResource')->item(0)->setAttribute("xlink:href", $this->urlArray[$i]);
break;
//clone node and add if afterwards
Modified: trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
--- trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php 2017-11-14 15:43:06 UTC (rev 9814)
+++ trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php 2017-11-14 15:46:40 UTC (rev 9815)
@@ -180,7 +180,7 @@
//check if entries are filled
//read information from metadata table
$sql = <<<SQL
- select mb_metadata.title, mb_metadata.abstract, mb_metadata.ref_system, mb_metadata.datasetid, mb_metadata.origin from mb_metadata where mb_metadata.uuid = $1;
+ select mb_metadata.title, mb_metadata.abstract, mb_metadata.ref_system, mb_metadata.datasetid, mb_metadata.datasetid_codespace, mb_metadata.origin from mb_metadata where mb_metadata.uuid = $1;
SQL;
$v = array($recordId);
$t = array('s');
@@ -260,6 +260,7 @@
$mapbenderMetadata['datasetId'] = $mbMetadata['datasetid'];
$mapbenderMetadata['mdOrigin'] = $mbMetadata['origin'];
$mapbenderMetadata['serviceUuid'] = $mbMetadata['uuid'];
+ $mapbenderMetadata['metadataId'] = $mbMetadata['metadata_id'];
$mapbenderMetadata['serviceTimestamp'] = strtotime($mbMetadata['wms_timestamp']);
$mapbenderMetadata['serviceTimestampCreate'] = strtotime($mbMetadata['wms_timestamp_create']);
//$mapbenderMetadata['serviceTimestamp'] = date("Y-m-d",strtotime($mb_metadata['lastchanged']));
@@ -267,7 +268,7 @@
//$mapbenderMetadata['serviceTimestampCreate'] = date("Y-m-d",strtotime($mb_metadata['lastchanged']));
$mapbenderMetadata['serviceDepartment'] = $mbMetadata['responsible_party'];
$mapbenderMetadata['serviceDepartmentMail'] = "kontakt at geoportal.rlp.de";
- //$mapbenderMetadata['serviceGroupId'] = $mbMetadata['fkey_mb_group_id'];
+ $mapbenderMetadata['serviceGroupId'] = $mbMetadata['fkey_mb_group_id'];
$mapbenderMetadata['serviceOwnerId'] = $mbMetadata['fkey_mb_user_id'];
//TODO!
$mapbenderMetadata['serviceAccessConstraints'] = "Please ask the contact point!";
@@ -326,7 +327,7 @@
$sql = <<<SQL
+ select mb_metadata.title, mb_metadata.abstract, mb_metadata.ref_system, mb_metadata.datasetid_codespace , mb_metadata.datasetid, mb_metadata.origin from mb_metadata where mb_metadata.uuid = $1;
SQL;
$t = array('s');
@@ -406,7 +407,7 @@
$sql = <<<SQL
SQL;
$t = array('s');
@@ -467,8 +468,36 @@
break;
+ //infos about the registrating department, check first if a special metadata point of contact is defined in the service table
+ switch ($generateFrom) {
+ case "wmslayer":
+ $type = "wms";
+ $serviceId = $mapbenderMetadata['serviceId'];
+ $ownerId =$mapbenderMetadata['serviceOwnerId'];
+ break;
+ case "wfs":
+ $type = "wfs";
+ break;
+ case "dataurl":
+ $type = "wms";
+ break;
+ case "metadata":
+ $type = "metadata";
+ $serviceId = $mapbenderMetadata['metadataId'];
+ break;
+ $departmentMetadata = $admin->getOrgaInfoFromRegistry($type, $serviceId, $ownerId);
+ $userMetadata['mb_user_email'] = $departmentMetadata['mb_user_email'];
//infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
- if (!isset($mapbenderMetadata['serviceGroupId']) or is_null($mapbenderMetadata['serviceGroupId']) or $mapbenderMetadata['serviceGroupId'] == 0){
+ /*if (!isset($mapbenderMetadata['serviceGroupId']) or is_null($mapbenderMetadata['serviceGroupId']) or $mapbenderMetadata['serviceGroupId'] == 0){
$e = new mb_exception("mod_inspireAtomFeedISOMetadata.php: fkey_mb_group_id not found!");
//Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
$sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
@@ -492,7 +521,7 @@
$t = array('i');
$res = db_prep_query($sql,$v,$t);
$userMetadata = db_fetch_array($res);
//check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
//$hasPermission=$admin->getLayerPermission($mapbenderMetadata['serviceId'],$mapbenderMetadata['layer_name'],PUBLIC_USER);
$hasPermission = true;//Is always true for ATOM Service Feeds!
@@ -947,7 +976,7 @@
//Resource Constraints B 8
//do a right mapping for fees and accessconstraints to inspire MD Constraints!
$resourceConstraints=$iso19139->createElement("gmd:resourceConstraints");
- $MD_LegalConstraints=$iso19139->createElement("gmd:MD_Constraints");
+ $MD_LegalConstraints=$iso19139->createElement("gmd:MD_LegalConstraints");
$useLimitation=$iso19139->createElement("gmd:useLimitation");
$useLimitation_cs=$iso19139->createElement("gco:CharacterString");
@@ -1167,29 +1196,25 @@
//$mapbenderMetadata['mdRefSystem'] = $mbMetadata['ref_sytem'];
//$mapbenderMetadata['datasetId'] = $mbMetadata['datasetid'];
//$mapbenderMetadata['mdOrigin'] = $mbMetadata['origin'];
+ $uniqueResourceIdentifierCodespace = $admin->getIdentifierCodespaceFromRegistry($departmentMetadata, $mbMetadata);
switch ($mapbenderMetadata['mdOrigin']) {
case 'capabilities':
$operatesOn=$iso19139->createElement("srv:operatesOn");
$operatesOn->setAttribute("xlink:href", $mapbenderPath."php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$recordId);
- $operatesOn->setAttribute("uuidref", $mapbenderMetadata['datasetId']);
+ $operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$mapbenderMetadata['datasetId']);
$SV_ServiceIdentification->appendChild($operatesOn);
break;
case 'metador':
- if (defined('METADATA_DEFAULT_CODESPACE')) {
- $operatesOn->setAttribute("xlink:href", $mapbenderPath."php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$recordId);
- $operatesOn->setAttribute("uuidref", METADATA_DEFAULT_CODESPACE."#".$recordId);
- } else {
- $operatesOn->setAttribute("uuidref", "http://www.mapbender.org#".$recordId);
+ $operatesOn->setAttribute("xlink:href", $mapbenderPath."php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$recordId.'#spatial_dataset_'.md5($recordId));
+ $operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$recordId);
break;
case 'external':
- $operatesOn->setAttribute("uuidref", $recordId);
break;
default:
Modified: trunk/mapbender/http/php/wfs.php
--- trunk/mapbender/http/php/wfs.php 2017-11-14 15:43:06 UTC (rev 9814)
+++ trunk/mapbender/http/php/wfs.php 2017-11-14 15:46:40 UTC (rev 9815)
@@ -330,12 +330,15 @@
$element->setAttribute("xlink:href", $wfs_row['wfs_getfeature']);
+//get wfs id and owner of the wfs from database
//Add MetadataUrl entries from mapbender database
//Creating Metadata nodes
//read out all metadata entries for specific featuretype
$sql = <<<SQL
-SELECT metadata_id, uuid, link, linktype, md_format, origin, datasetid, md_proxy FROM mb_metadata
+SELECT metadata_id, uuid, link, linktype, md_format, origin, datasetid, datasetid_codespace, md_proxy FROM mb_metadata
INNER JOIN (SELECT * from ows_relation_metadata
WHERE fkey_featuretype_id = $featuretypeId ) as relation ON
mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin IN ('capabilities','external','metador','upload')
@@ -348,20 +351,17 @@
$datasetId = array();
$k = 0;
-while ($row_metadata = db_fetch_array($res_metadata)) {
+//infos about the registrating department, check first if a special metadata point of contact is defined in the service table
+$departmentMetadata = $admin->getOrgaInfoFromRegistry("wfs", $wfs_row["wfs_id"], $wfs_row["wfs_owner"]);
+while ($row_metadata = db_fetch_array($res_metadata)) {
+ $uniqueResourceIdentifierCodespace = $admin->getIdentifierCodespaceFromRegistry($departmentMetadata, $row_metadata);
+ //First generate all dataset ids because they are needed in the inspire extensions
if ($row_metadata["datasetid"] == '' || !isset($row_metadata["datasetid"])) {
- //this column is empty, if metador was used and the identifier for dataset id is equal to the identifier of the metadata fileidentifier. In this case we expand a standard codespace http://www.geoportal.rlp.de
- $datasetId[$k] = METADATA_DEFAULT_CODESPACE."#".$row_metadata["uuid"];
- } else {
- if (defined("METADATA_DEFAULT_CODESPACE") && METADATA_DEFAULT_CODESPACE != '') {
- } else {
- $datasetId[$k] = "http://www.mapbender.org"."#".$row_metadata["uuid"];
+ //this column is empty, if metador was used and the identifier for dataset id is equal to the identifier of the metadata fileidentifier
+ $datasetId[$k] = $uniqueResourceIdentifierCodespace.$row_metadata["uuid"];
} else {
- $datasetId[$k] = $row_metadata["datasetid"]; //really datasetid or only second part?
+ $datasetId[$k] = $uniqueResourceIdentifierCodespace.$row_metadata["datasetid"];
//push entries into xml structure
//check for kind of link - push the right one into the link field
@@ -407,10 +407,13 @@
$k = 0;
if (is_array($metadataUrl) && count($metadataUrl) > 0) {
+$e = new mb_exception(gettype($metadataUrl)." - count - ".count($metadataUrl)." url[0]: ".$metadataUrl[0]);
+$e = new mb_exception($version);
+$e = new mb_exception($service);
$metadataUrlObject = new OwsMetadataUrl();
//$e = new mb_exception('version: '.$version);
$metadata_part = $metadataUrlObject->getOwsRepresentation($metadataUrl, $linkType, $format, 'wfs', $version);
- //$e = new mb_exception($metadata_part);
+$e = new mb_exception($metadata_part);
//insert metadata url elements into capabilities - either delete existing entries and recreate them or put them after ows:WGS84BoundingBox (WFS 2.0), wfs .....
@@ -533,23 +536,36 @@
foreach ($datasetId as $singleDatasetId) {
//$e = new mb_exception("datasetid: ".$singleDatasetId);
- //try to explode with # or / afterwards
- if (strpos($singleDatasetId, '#') !== false && count(explode('#', $singleDatasetId) == 2) ) {
- //$e = new mb_exception("found inspire dataset id");
- //build id part
- $inspire_dls_SpatialDataSetIdentifier = $doc->createElement("inspire_dls:SpatialDataSetIdentifier");
- $inspire_common_Code = $doc->createElement("inspire_common:Code");
- $inspire_common_Namespace = $doc->createElement("inspire_common:Namespace");
- $inspire_common_CodeText = $doc->createTextNode(explode('#', $singleDatasetId)[1]);
- $inspire_common_NamespaceText = $doc->createTextNode(explode('#', $singleDatasetId)[0]);
- $inspire_common_Namespace->appendChild($inspire_common_NamespaceText);
- $inspire_common_Code->appendChild($inspire_common_CodeText);
- $inspire_dls_SpatialDataSetIdentifier->appendChild($inspire_common_Code);
- $inspire_dls_SpatialDataSetIdentifier->appendChild($inspire_common_Namespace);
- $inspire_dls_ExtendedCapabilities->appendChild($inspire_dls_SpatialDataSetIdentifier);
+ //try to extract local identifier from complete unique resource identifier
+ //now try to check if a single slash is available and if the md_identifier is a url
+ $parsedUrl = parse_url($singleDatasetId);
+ if (($parsedUrl['scheme'] == 'http' || $parsedUrl['scheme'] == 'https') && strpos($parsedUrl['path'],'/') !== false) {
+ $explodedUrl = explode('/', $singleDatasetId);
+ $codeText = $explodedUrl[count($explodedUrl) - 1];
+ $namespaceText = rtrim($singleDatasetId, $codeText);
+ } else {
+ //check old way with # as separator
+ if (strpos($singleDatasetId, '#') !== false && count(explode('#', $singleDatasetId) == 2) ) {
+ $codeText = explode('#', $singleDatasetId)[1];
+ $namespaceText = explode('#', $singleDatasetId)[0];
+ } else {
+ $codeText = $singleDatasetId;
+ $namespaceText = "";
+ $inspire_dls_SpatialDataSetIdentifier = $doc->createElement("inspire_dls:SpatialDataSetIdentifier");
+ $inspire_common_Code = $doc->createElement("inspire_common:Code");
+ $inspire_common_Namespace = $doc->createElement("inspire_common:Namespace");
+ $inspire_common_CodeText = $doc->createTextNode($codeText);
+ $inspire_common_NamespaceText = $doc->createTextNode($namespaceText);
+ $inspire_common_Namespace->appendChild($inspire_common_NamespaceText);
+ $inspire_common_Code->appendChild($inspire_common_CodeText);
+ $inspire_dls_SpatialDataSetIdentifier->appendChild($inspire_common_Code);
+ $inspire_dls_SpatialDataSetIdentifier->appendChild($inspire_common_Namespace);
+ $inspire_dls_ExtendedCapabilities->appendChild($inspire_dls_SpatialDataSetIdentifier);
header("Content-type: application/xhtml+xml; charset=UTF-8");
More information about the Mapbender_commits
