[Mapbender-commits] r9816 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Nov 14 08:33:02 PST 2017
Author: armin11
Date: 2017-11-14 08:33:02 -0800 (Tue, 14 Nov 2017)
New Revision: 9816
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Enhancement for INSPIRE ATOM Feed generator - support of new unique resource identifier
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2017-11-14 15:46:40 UTC (rev 9815)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2017-11-14 16:33:02 UTC (rev 9816)
@@ -697,69 +697,42 @@
//Handle CRS - maybe in 'urn:ogc:def:crs:EPSG:6.9:4326' or 'EPSG:4326' or 'epsg:4326' or 'urn:ogc:def:crs:EPSG::4326' format!
//*********************** New use crs class for checking if the order has to be changed in the filter!!!
$crsObject = new Crs($crs);
- if ($crsObject->alterAxisOrder("wms"."_".$mapbenderMetadata[$i]->wms_version) == true) {
+ if ($crsObject->alterAxisOrder("wms"."_".$mapbenderMetadata[$m]->wms_version) == true) {
$alterAxisOrder = true;
} else {
$alterAxisOrder = false;
$epsgId = $crsObject->identifierCode;
- //TODO test this also in sqls from mapbenders database - see wms 1.3.0 - for layer metadata
- //explode strings
- //alter all to uppercase
- /*$crsUpper = str_replace("epsg","EPSG",$crs);
- //explode strings
- $crsUpperArray = explode(":",$crsUpper);
- switch (count($crsUpperArray)) {
- case 7:
- $epsgId = $crsUpperArray[6];
- break;
- case 2:
- $epsgId = $crsUpperArray[1];
- break;
+ switch ($generateFrom) {
+ case "wmslayer":
+ $serviceType = "wms";
+ $serviceId = $mapbenderMetadata[$m]->fkey_wms_id;
+ $ownerId = $mapbenderMetadata[$m]->wms_owner;
+ break;
+ case "wfs":
+ $serviceType = "wfs";
+ $serviceId = $mapbenderMetadata[$m]->wfs_id;
+ $ownerId = $mapbenderMetadata[$m]->wfs_owner;
+ break;
+ case "dataurl":
+ break;
+ case "metadata":
+ $serviceType = "metadata";
+ $serviceId = $mapbenderMetadata[$m]->metadata_id;
+ $ownerId = $mapbenderMetadata[$m]->md_owner;
+ break;
+ default:
+ break;
- //check if order have to be altered
- if (strpos($crsUpper,'urn') !== false) {
- //check if axis order should be changed
- if (check_epsg_wms_13($epsgId)) {
- //alter order of axis for 4326
- $alterAxisOrder = true;
- } else {
- $alterAxisOrder = false;
- //infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
- if (!isset($mapbenderMetadata[$m]->fkey_mb_group_id) or is_null($mapbenderMetadata[$m]->fkey_mb_group_id) or $mapbenderMetadata[$m]->fkey_mb_group_id == 0){
- $e = new mb_exception("mod_inspireDownloadFeed.php: fkey_mb_group_id not found!");
- //Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
- $sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone, a.timestamp FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
- if ($generateFrom != "wfs") {
- $vDep = array($mapbenderMetadata[$m]->wms_owner);
- } else {
- $vDep = array($mapbenderMetadata[$m]->wfs_owner);
- $tDep = array('i');
- $resDep = db_prep_query($sqlDep, $vDep, $tDep);
- $departmentMetadata = db_fetch_array($resDep);
- } else {
- $e = new mb_exception("mod_inspireDownloadFeed.php: fkey_mb_group_id found!");
- $sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone, timestamp FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
- $vDep = array($mapbenderMetadata[$m]->fkey_mb_group_id);
- //infos about the owner of the service - he is the man who administrate the metadata - register the service
- $sql = "SELECT mb_user_email, timestamp ";
- $sql .= "FROM mb_user WHERE mb_user_id = $1";
+ $departmentMetadata = $admin->getOrgaInfoFromRegistry($serviceType, $serviceId, $ownerId);
+ $userMetadata['mb_user_email'] = $departmentMetadata['mb_user_email'];
+ $userMetadata['timestamp'] = $departmentMetadata['mb_user_timestamp'];
case "wmslayer":
$v = array($mapbenderMetadata[$m]->wms_owner);
@@ -779,10 +752,6 @@
$hasPermission = true;
break;
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- $userMetadata = db_fetch_array($res);
//check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
/*if ($generateFrom != "wfs") {
$hasPermission=$admin->getLayerPermission($mapbenderMetadata[$m]->fkey_wms_id,$mapbenderMetadata[$m]->layer_name,PUBLIC_USER);
@@ -869,10 +838,18 @@
$feed->setAttribute("xmlns:lang", "de");
//echo "<test>".$mapbenderMetadata['fkey_wms_id'].":".$mapbenderMetadata['wms_owner']."</test>";
+ //pull the namespace from database
+ $metadataArray['datasetid_codespace'] = $mapbenderMetadata[$m]->datasetid_codespace;
+ $uniqueResourceIdentifierCodespace = $admin->getIdentifierCodespaceFromRegistry($departmentMetadata, $metadataArray);
+ //overwrite datasetid_codespace
+ $mapbenderMetadata[$m]->datasetid_codespace = $uniqueResourceIdentifierCodespace;
//qualifying id of the referenced ressource: Either dataset id or the id of the metadata record
- if (isset($mapbenderMetadata[$m]->datasetid) && $mapbenderMetadata[$m]->datasetid != '' ) {
+ /*if (isset($mapbenderMetadata[$m]->datasetid) && $mapbenderMetadata[$m]->datasetid != '' ) {
$ressourceId = $mapbenderMetadata[$m]->datasetid_codespace."#".$mapbenderMetadata[$m]->datasetid;
//check if the metadata set has a title and abstract if not given (in case of dataurl, use layer information!)
//first use metadata title then layer title
@@ -1923,10 +1900,14 @@
$mapbenderMetadata[$indexMapbenderMetadata]->format = $row['format'];
$mapbenderMetadata[$indexMapbenderMetadata]->md_timestamp = $row['md_timestamp'];
//check if codespace was given in metadata or it must be generated from uuid and default codespace
- if (($mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace == '' or !isset($mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace)) or ($mapbenderMetadata[$indexMapbenderMetadata]->datasetid == '' or !isset($mapbenderMetadata[$indexMapbenderMetadata]->datasetid))) {
+ /*if (($mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace == '' or !isset($mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace)) or ($mapbenderMetadata[$indexMapbenderMetadata]->datasetid == '' or !isset($mapbenderMetadata[$indexMapbenderMetadata]->datasetid))) {
//generate one:
$mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace = METADATA_DEFAULT_CODESPACE;
$mapbenderMetadata[$indexMapbenderMetadata]->datasetid = $mapbenderMetadata[$indexMapbenderMetadata]->metadata_uuid;
+ if ($mapbenderMetadata[$indexMapbenderMetadata]->datasetid == '' or !isset($mapbenderMetadata[$indexMapbenderMetadata]->datasetid)) {
+ //generate one:
+ $mapbenderMetadata[$indexMapbenderMetadata]->datasetid = $mapbenderMetadata[$indexMapbenderMetadata]->metadata_uuid;
//$e = new mb_exception("test");
//overwrite some elements if the feed should be generated from metadata itself: access constraints, use limitations, ...
@@ -2018,10 +1999,14 @@
//$mapbenderMetadata[$indexMapbenderMetadata]->format = $row['format'];
//generate one:
+ //generate one:
if ($generateFrom == "wfs" or $mapbenderMetadata[$indexMapbenderMetadata]->origin == "wfs") {
$latlonbbox = explode(",",$mapbenderMetadata[$indexMapbenderMetadata]->latlonbbox);
More information about the Mapbender_commits
